[U-Boot] [PATCH 0/2] patman: Various fixes
This fixes the location of patman config file from ~/.config/patman to ~/.patman. Also addresses the creation of new config file when it isn't present.
Cc: Simon Glass sjg@chromium.org Cc: Wolfgang Denk wd@denx.de
Vikram Narayanan (2): patman: Change the location of patman config file patman: Handle creation of patman config file
tools/patman/README | 5 ++++- tools/patman/gitutil.py | 18 ++++++++++++++++++ tools/patman/settings.py | 39 +++++++++++++++++++++++++++++++++++---- 3 files changed, 57 insertions(+), 5 deletions(-)
Move the config file from ~/.config/patman to ~/.patman as it is more appropriate to have it there. Update the same in the README.
Signed-off-by: Vikram Narayanan vikram186@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Wolfgang Denk wd@denx.de --- tools/patman/README | 2 +- tools/patman/settings.py | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 7ba9e80..1af8665 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -68,7 +68,7 @@ How to configure it For most cases patman will locate and use the file 'doc/git-mailrc' in your U-Boot directory. This contains most of the aliases you will need.
-To add your own, create a file ~/.config/patman directory like this: +To add your own, create a file ~/.patman like this:
# patman alias file diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 049c709..f980071 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -69,7 +69,7 @@ def Setup(config_fname=''): """ settings = ConfigParser.SafeConfigParser() if config_fname == '': - config_fname = '%s/.config/patman' % os.getenv('HOME') + config_fname = '%s/.patman' % os.getenv('HOME') if config_fname: settings.read(config_fname)
if config_fname: settings.read(config_fname)config_fname = '%s/.patman' % os.getenv('HOME')
-- 1.7.4.1
Hello Wolfgang,
On 5/30/2012 11:04 AM, Simon Glass wrote:
On Wed, May 23, 2012 at 11:58 AM, Vikram Narayanan <vikram186@gmail.com mailto:vikram186@gmail.com> wrote:
Move the config file from ~/.config/patman to ~/.patman as it is more appropriate to have it there. Update the same in the README. Signed-off-by: Vikram Narayanan <vikram186@gmail.com <mailto:vikram186@gmail.com>> Cc: Simon Glass <sjg@chromium.org <mailto:sjg@chromium.org>> Cc: Wolfgang Denk <wd@denx.de <mailto:wd@denx.de>>
Acked-by: Simon Glass <sjg@chromium.org mailto:sjg@chromium.org>
Can you please consider this patch series? Both are acked by Simon. If you have any issues in taking this in, please let me know.
Thanks, Vikram
--- tools/patman/README | 2 +- tools/patman/settings.py | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-) diff --git a/tools/patman/README b/tools/patman/README index 7ba9e80..1af8665 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -68,7 +68,7 @@ How to configure it For most cases patman will locate and use the file 'doc/git-mailrc' in your U-Boot directory. This contains most of the aliases you will need. -To add your own, create a file ~/.config/patman directory like this: +To add your own, create a file ~/.patman like this: >>>> # patman alias file diff --git a/tools/patman/settings.py b/tools/patman/settings.py index 049c709..f980071 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -69,7 +69,7 @@ def Setup(config_fname=''): """ settings = ConfigParser.SafeConfigParser() if config_fname == '': - config_fname = '%s/.config/patman' % os.getenv('HOME') + config_fname = '%s/.patman' % os.getenv('HOME') if config_fname: settings.read(config_fname) -- 1.7.4.1
Dear Vikram Narayanan,
Applied, thanks.
patman shouts when it couldn't find a $(HOME)/.patman file. Handle it in a sane way by creating a new one for the user. It looks for a user.name and user.email in the global .gitconfig file, waits for the user input if it can't find there. Update the same in the README
Signed-off-by: Vikram Narayanan vikram186@gmail.com Acked-by: Simon Glass sjg@chromium.org Cc: Simon Glass sjg@chromium.org Cc: Wolfgang Denk wd@denx.de --- tools/patman/README | 3 +++ tools/patman/gitutil.py | 18 ++++++++++++++++++ tools/patman/settings.py | 37 ++++++++++++++++++++++++++++++++++--- 3 files changed, 55 insertions(+), 3 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 1af8665..86ede78 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -68,6 +68,9 @@ How to configure it For most cases patman will locate and use the file 'doc/git-mailrc' in your U-Boot directory. This contains most of the aliases you will need.
+During the first run patman creates a config file for you by taking the default +user name and email address from the global .gitconfig file. + To add your own, create a file ~/.patman like this:
diff --git a/tools/patman/gitutil.py b/tools/patman/gitutil.py index 48ca998..59eca99 100644 --- a/tools/patman/gitutil.py +++ b/tools/patman/gitutil.py @@ -357,6 +357,24 @@ def GetAliasFile(): fname = os.path.join(GetTopLevel(), fname.strip()) return fname
+def GetDefaultUserName(): + """Gets the user.name from .gitconfig file. + + Returns: + User name found in .gitconfig file, or None if none + """ + uname = command.OutputOneLine('git', 'config', '--global', 'user.name') + return uname + +def GetDefaultUserEmail(): + """Gets the user.email from the global .gitconfig file. + + Returns: + User's email found in .gitconfig file, or None if none + """ + uemail = command.OutputOneLine('git', 'config', '--global', 'user.email') + return uemail + def Setup(): """Set up git utils, by reading the alias files.""" settings.Setup('') diff --git a/tools/patman/settings.py b/tools/patman/settings.py index f980071..4dda17b 100644 --- a/tools/patman/settings.py +++ b/tools/patman/settings.py @@ -24,7 +24,7 @@ import os import re
import command - +import gitutil
def ReadGitAliases(fname): """Read a git alias file. This is in the form used by git: @@ -61,6 +61,33 @@ def ReadGitAliases(fname):
fd.close()
+def CreatePatmanConfigFile(config_fname): + """Creates a config file under $(HOME)/.patman if it can't find one. + + Args: + config_fname: Default config filename i.e., $(HOME)/.patman + + Returns: + None + """ + name = gitutil.GetDefaultUserName() + if name == None: + name = raw_input("Enter name: ") + + email = gitutil.GetDefaultUserEmail() + + if email == None: + email = raw_input("Enter email: ") + + try: + f = open(config_fname, 'w') + except IOError: + print "Couldn't create patman config file\n" + raise + + print >>f, "[alias]\nme: %s <%s>" % (name, email) + f.close(); + def Setup(config_fname=''): """Set up the settings module by reading config files.
@@ -70,8 +97,12 @@ def Setup(config_fname=''): settings = ConfigParser.SafeConfigParser() if config_fname == '': config_fname = '%s/.patman' % os.getenv('HOME') - if config_fname: - settings.read(config_fname) + + if not os.path.exists(config_fname): + print "No config file found ~/.patman\nCreating one...\n" + CreatePatmanConfigFile(config_fname) + + settings.read(config_fname)
for name, value in settings.items('alias'): alias[name] = value.split(',')
Applied, thanks.
Vikram Narayanan
