[U-Boot] Does U-boot supports Spansion S29GL512P NOR Flash?
In U-boot I am not seeing the support for Spansion S29GL512P NOR flash.
This chip is CFI compliant so I believe the common CFI driver should work with this chip.
Does U-boot supports S29GL512P NOR flash or I have to implement the functionality to support S29GL512P?
If anyone has tried with S29GL512P NOR flash please share the experiecne.
Thanks & Regards, Prakash
Hi Prakash,
This chip is currently supported by the common CFI NOR FLASH driver. So it should just work for your board as well.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Hi Stefan,
Thanks for details. But I didn't get it clearly.
Does it mean I have to CFI_MTD ot common CFI_DRIVER will works?
Which c source file I need to check the support for this chip?
I am using below settings. *----------------------------------------------------------------------- * FLASH related *----------------------------------------------------------------------*/ #define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE} #define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ #define CONFIG_FLASH_SHOW_PROGRESS 1
#define CONFIG_SYS_FLASH_ERASE_TOUT 220000 /* Timeout for Flash Erase (in ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 100 /* Timeout for Flash Write (in ms) */
#define CONFIG_ENV_SECT_SIZE 0x20000 /* size of one complete sector */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE-CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */
Thanks & Regards, Prakash Bedge
On Fri, Apr 9, 2010 at 11:40 AM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
Cheers, Stefan
Hi Prakash,
I don't understand this question.
- FLASH related
This looks good. With these defines the CFI driver should work. You might want to add CONFIG_SYS_FLASH_USE_BUFFER_WRITE for write speedup. And you need to configure your access timing for the chip select to the NOR Chip correctly of course.
Cheers, Stefan
me neither
Yes, we use #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1, on order to speed write ops. Our BR- and OR setting is very conservative since some signals are routed through an FPGA and are delayed. For this reason, we utilize 8 wait states.
Frank
Hi Stefan,
I was asking that do I also need to add below settings in my board config file.
/* * Dynamic MTD partition support */ #define CONFIG_CMD_MTDPARTS #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_FLASH_CFI_MTD #define MTDIDS_DEFAULT "nor0=fc000000.flash"
Chip correctly of course. In which source file I can see present access timings for the chip select. In which file I need to do these changes?
I tried with the below setting but I am getting the same error as flash not found. So I am little bit concerned. Please tell which boards supports the S29GL512P NOR flash, so that I can check for reference.
Regards, Prakash
On Fri, Apr 9, 2010 at 1:05 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
- FLASH related
Cheers, Stefan
- Dynamic MTD partition support
No, you don't need those defines for "normal" FLASH access in U-Boot.
This is not really CFI driver related. It platforms/SoC specific. Which CPU are you using? Can you access the FLASH chip from your JTAG debugger?
What are the error messages? Please post a log.
Check kilauea.h for example.
Cheers, Stefan
Prakash: As Stefan mentioned, this is probably not a CFI driver issue. Most probably a wrong/non memory controller setup. What CPU are you using, and what chip-select is the flash using?
First, you should be able to read, erase and write via the JTAG before you even think about U-Boot.
Stefan: Didn't know that. Should have known that a year ago ;-)
Hi Frank,
I am using PPC440x5 Cpu core. How to check the chip-select flash is using? Earlier I have run the same code for M29W128GH and it works fine. But with S29GL512 it is not working. Now the difference is only in size and write/read timings. So I believe it should work in smooth manner.
kilauea.h file is present in the U-boot. So does this board supports S29GL512P Nor flash chip?
Regards, Prakash
On Fri, Apr 9, 2010 at 2:40 PM, Frank Svendsbøe frank.svendsboe@gmail.comwrote:
select.
CPU
not
Hmm.. If you're supposed to boot from this device, then I assume the flash is connected to CS0.For slow devices, the memory controller is usually setup to use the GPCM. Check your options and base registers (OR0 and BR0). Everything related to timing (for GPCM controlled devices) is done in these two registers.
If you have a BDI JTAG, you can set these registers using that and try to perform flash operations from here. Again, if you can, try to access the flash using the JTAG before experimenting with U-Boot.
You mention different size.. is the port size different too?
In order to help you, I think the community needs more info about your system. Stefan asked for logs, etc.
Regards, Frank
Hi Frank,Stefan,
Please see bleow error log for I am getting in detecting CFI flash chip. I am running u-boot from CRAM temporarily.
-------- U-Boot 2009.08 (Apr 01 2010 - 17:32:17) DRAM: 2 MB Top of RAM usable for U-Boot at: 00200000 Reserving 175k for U-Boot at: 001d4000 Reserving 1040k for malloc() at: 000d0000 Reserving 128 Bytes for Board Info at: 000cff80 Reserving 56 Bytes for Global Data at: 000cff48 Stack Pointer at: 000cff28 New Stack Pointer is: 000cff28 Now running in RAM - U-Boot at: 001d4000 FLASH: flash detect cfi fwc addr fc000000 cmd ff ff00 16bit x 8 bit fwc addr fc000000 cmd f0 f000 16bit x 8 bit fwc addr fc0000aa cmd 98 9800 16bit x 8 bit is= cmd 51(Q) addr fc000020 is= ffff 5100 fwc addr fc000aaa cmd 98 9800 16bit x 8 bit is= cmd 51(Q) addr fc000020 is= ffff 5100 fwc addr fc000000 cmd ff 0000 16bit x 16 bit fwc addr fc000000 cmd f0 0000 16bit x 16 bit fwc addr fc0000aa cmd 98 0000 16bit x 16 bit is= cmd 51(Q) addr fc000020 is= ffff 0000 fwc addr fc000aaa cmd 98 0000 16bit x 16 bit is= cmd 51(Q) addr fc000020 is= ffff 0000 fwc addr fc000000 cmd ff ff00ff00 32bit x 8 bit fwc addr fc000000 cmd f0 f000f000 32bit x 8 bit fwc addr fc000154 cmd 98 98009800 32bit x 8 bit is= cmd 51(Q) addr fc000040 is= ffffffff 51005100 fwc addr fc001554 cmd 98 98009800 32bit x 8 bit is= cmd 51(Q) addr fc000040 is= ffffffff 51005100 fwc addr fc000000 cmd ff 00000000 32bit x 16 bit fwc addr fc000000 cmd f0 00000000 32bit x 16 bit fwc addr fc000154 cmd 98 00000000 32bit x 16 bit is= cmd 51(Q) addr fc000040 is= ffffffff 00000000 fwc addr fc001554 cmd 98 00000000 32bit x 16 bit is= cmd 51(Q) addr fc000040 is= ffffffff 00000000 fwc addr fc000000 cmd ff 00000000 32bit x 32 bit fwc addr fc000000 cmd f0 00000000 32bit x 32 bit fwc addr fc000154 cmd 98 00000000 32bit x 32 bit is= cmd 51(Q) addr fc000040 is= ffffffff 00000000 fwc addr fc001554 cmd 98 00000000 32bit x 32 bit is= cmd 51(Q) addr fc000040 is= ffffffff 00000000 fwrite addr fc000000 cmd ff ff00ff00ff00ff00 64 bit x 8 bit fwrite addr fc000000 cmd f0 f000f000f000f000 64 bit x 8 bit fwrite addr fc0002a8 cmd 98 9800980098009800 64 bit x 8 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 5100510051005100 fwrite addr fc002aa8 cmd 98 9800980098009800 64 bit x 8 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 5100510051005100 fwrite addr fc000000 cmd ff 0000000000000000 64 bit x 16 bit fwrite addr fc000000 cmd f0 0000000000000000 64 bit x 16 bit fwrite addr fc0002a8 cmd 98 0000000000000000 64 bit x 16 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 fwrite addr fc002aa8 cmd 98 0000000000000000 64 bit x 16 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 fwrite addr fc000000 cmd ff 0000000000000000 64 bit x 32 bit fwrite addr fc000000 cmd f0 0000000000000000 64 bit x 32 bit fwrite addr fc0002a8 cmd 98 0000000000000000 64 bit x 32 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 fwrite addr fc002aa8 cmd 98 0000000000000000 64 bit x 32 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 fwrite addr fc000000 cmd ff 0000000000000000 64 bit x 64 bit fwrite addr fc000000 cmd f0 0000000000000000 64 bit x 64 bit fwrite addr fc0002a8 cmd 98 0000000000000000 64 bit x 64 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 fwrite addr fc002aa8 cmd 98 0000000000000000 64 bit x 64 bit is= cmd 51(Q) addr fc000080 is= ffffffffffffffff 0000000000000000 not found ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB flash_protect ON: from 0xFFFC0000 to 0xFFFE81FF flash_protect ON: from 0xFFFA0000 to 0xFFFBFFFF *** failed *** ### ERROR ### Please RESET the board ###
(OR0 and BR0).
What is GPCM? Which source/header file I need to check for these settings.?
I think u-boot takes care of port size as if we do not define the port size then u-boot search with all possible port size. BTW how I can cross-check the port size?
For M29W128GH I have to do some code fixup from patch suggested by Stefan. Is there any special code fixup is required for S29GL512P flash chip support?
On Fri, Apr 9, 2010 at 6:57 PM, Frank Svendsbøe frank.svendsboe@gmail.comwrote:
using?
with
it
Regards, Frank
Hi Prakash, I didn't know that a IBM PPC440 CPU didn't contain an embedded memory controller. I assumed it did and therefore mentioned the GPCM (General Purpose Chip Select Machine - Terminology used on Freescale SoCs). Since your controller is obviously external/custom, it's hard to help you.
Hmm.. As I don't have a 440 system, it's hard to tell. But on other systems, the port-size is programmed for each chip-select, and tells the memory controller the supported bus width connected to each device for a given chip-select.
As I mentioned before, we didn't do anything special in order to get S29GL512P working for our board.
Best regards, Frank
On Fri, Apr 9, 2010 at 6:57 PM, Frank Svendsbøe frank.svendsboe@gmail.com wrote:
Regards, Frank
This is just a wild guess. Check that your memory controller setup is correct. Since you've changed your flash size, you might have a corrupt memory controller setup. On our Freescale system, we initially had problems when increasing flash size due to where we've decided to put the internal space base / memory map (ISB/IMM). When changing the size, we had to move the IMM to a lower address (.ie at least a sector below 0xfc000000).
Best regards, Frank
Hi All,
I did it. :)
I am now able to detect the flash. So now I can run the uboot commnads i.e flinfo to check the flash information. For this I make use of ST fixup code for M29W128GH in which I changed the codition for chekcing chipwidth.
To detect the flash I used chipwidth 16 Bits and Portwidth 8 Bits.
But now I am getting the problem in erasing on flash. I gave the erase command to erase the sector but then the sector is not getting erased and I am getting the message as flash erased. Same is for chip erase command. See the log below
DRAM: 2 MB Top of RAM usable for U-Boot at: 00200000 Reserving 177k for U-Boot at: 001d3000 Reserving 1040k for malloc() at: 000cf000 Reserving 128 Bytes for Board Info at: 000cef80 Reserving 56 Bytes for Global Data at: 000cef48 Stack Pointer at: 000cef28 New Stack Pointer is: 000cef28 Now running in RAM - U-Boot at: 001d3000 FLASH: flash detect cfi fwc addr fc000000 cmd ff ff 8bit x 8 bit fwc addr fc000000 cmd f0 f0 8bit x 8 bit total bank size in bytes 0 number of erase units 0 combined device & manufacturer code 65535 maximum block erase timeout 0 maximum write timeout 0 manufacturer_id 0 the width of the port 1 the width of the chip 1 fwc addr fc000055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fc000010 is= ff 51 is= cmd 52(R) addr fc000011 is= ff 52 is= cmd 59(Y) addr fc000012 is= ff 59 fwc addr fc000555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr fc000010 is= ff 51 is= cmd 52(R) addr fc000011 is= ff 52 is= cmd 59(Y) addr fc000012 is= ff 59 fwc addr fc000000 cmd ff ff00 16bit x 8 bit fwc addr fc000000 cmd f0 f000 16bit x 8 bit total bank size in bytes 0 number of erase units 0 combined device & manufacturer code 65535 maximum block erase timeout 0 maximum write timeout 0 manufacturer_id 0 the width of the port 2 the width of the chip 1 *fwc addr fc0000aa cmd 98 9800 16bit x 8 bit* is= cmd 51(Q) addr fc000020 is= 5100 5100 device interface is 2 *found port 2 chip 1 port 16 bits chip 8 bits 00 : 51 52 59 02 00 40 00 00 00 00 00 27 36 00 00 06 **QRY..@.....'6*<QRY..@.....'6> *... 10 : 06 09 13 03 05 03 02 1a 02 00 06 00 01 ff 01 00 ................ 20 : 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 ...............* fwc addr fc000000 cmd f0 f000 16bit x 8 bit fwc addr fc001554 cmd aa aa00 16bit x 8 bit fwc addr fc000aaa cmd 55 5500 16bit x 8 bit fwc addr fc001554 cmd 90 9000 16bit x 8 bit fwc addr fc000000 cmd f0 f000 16bit x 8 bit fwc addr fc0000aa cmd 98 9800 16bit x 8 bit manufacturer is 2 manufacturer id is 0xff device id is 0xff device id2 is 0x0 cfi version is 0x3133 *size_ratio 1 port 16 bits chip 8 bits *found 1 erase regions erase region 0: 0x020001ff erase_region_count = 512 erase_region_size = 131072 fwc addr fc000000 cmd f0 f0 8bit x 8 bit flash_protect ON: from 0xFFFC0000 to 0xFFFE89FF protect on 510 protect on 511 flash_protect ON: from 0xFFFA0000 to 0xFFFBFFFF protect on 509 *64 MB* *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial U-Boot relocated to 001d3000 Install interrupt vector 1 Install interrupt vector 0 Install interrupt vector 3 Install interrupt vector 2 ### main_loop entered: bootdelay=5 ### main_loop: bootcmd="bootm 0xffdc0000 0xff8c0000 0xff200000" Hit any key to stop autoboot: 5 0 U-Boot $ flinfo Bank # 1: CFI conformant FLASH (8 x 8) Size: 64 MB in 512 Sectors AMD Standard command set, Manufacturer ID: 0xFF, Device ID: 0xFF Erase timeout: 4096 ms, write timeout: 1 ms Buffer write timeout: 3 ms, buffer size: 64 bytes Sector Start Addresses: FC000000 E FC020000 E FC040000 E FC060000 E FC080000 E FC0A0000 E FC0C0000 E FC0E0000 E FC100000 E FC120000 E FC140000 E FC160000 E FC180000 E FC1A0000 E FC1C0000 E FC1E0000 E FC200000 E FC220000 E FC240000 E FC260000 E FC280000 E FC2A0000 E FC2C0000 E FC2E0000 E FC300000 E FC320000 E FC340000 E FC360000 E FC380000 E FC3A0000 E FC3C0000 E FC3E0000 E FC400000 E FC420000 E FC440000 E FC460000 E FC480000 E FC4A0000 E FC4C0000 E FC4E0000 E FC500000 E FC520000 E FC540000 E FC560000 E FC580000 E FC5A0000 E FC5C0000 E FC5E0000 E FC600000 E FC620000 E FC640000 E FC660000 E FC680000 E FC6A0000 E FC6C0000 E FC6E0000 E FC700000 E FC720000 E FC740000 E FC760000 E FC780000 E FC7A0000 E FC7C0000 FC7E0000 FC800000 E FC820000 E FC840000 E FC860000 E FC880000 E FC8A0000 E FC8C0000 E FC8E0000 E FC900000 E FC920000 E FC940000 E FC960000 E FC980000 E FC9A0000 E FC9C0000 E FC9E0000 E FCA00000 E FCA20000 E FCA40000 E FCA60000 E FCA80000 E FCAA0000 E FCAC0000 E FCAE0000 E FCB00000 E FCB20000 E FCB40000 E FCB60000 E FCB80000 E FCBA0000 E FCBC0000 E FCBE0000 E FCC00000 E FCC20000 E FCC40000 E FCC60000 E FCC80000 E FCCA0000 E FCCC0000 E FCCE0000 E FCD00000 E FCD20000 E FCD40000 E FCD60000 E FCD80000 E FCDA0000 E FCDC0000 E FCDE0000 E FCE00000 E FCE20000 E FCE40000 E FCE60000 E FCE80000 E FCEA0000 E FCEC0000 E FCEE0000 E FCF00000 E FCF20000 E FCF40000 E FCF60000 E FCF80000 E FCFA0000 E FCFC0000 FCFE0000 FD000000 E FD020000 E FD040000 E FD060000 E FD080000 E FD0A0000 E FD0C0000 E FD0E0000 E FD100000 E FD120000 E FD140000 E FD160000 E FD180000 E FD1A0000 E FD1C0000 E FD1E0000 E FD200000 E FD220000 E FD240000 E FD260000 E FD280000 E FD2A0000 E FD2C0000 E FD2E0000 E FD300000 E FD320000 E FD340000 E FD360000 E FD380000 E FD3A0000 E FD3C0000 E FD3E0000 E FD400000 E FD420000 E FD440000 E FD460000 E FD480000 E FD4A0000 E FD4C0000 E FD4E0000 E FD500000 E FD520000 E FD540000 E FD560000 E FD580000 E FD5A0000 E FD5C0000 E FD5E0000 E FD600000 E FD620000 E FD640000 E FD660000 E FD680000 E FD6A0000 E FD6C0000 E FD6E0000 E FD700000 E FD720000 E FD740000 E FD760000 E FD780000 E FD7A0000 E FD7C0000 FD7E0000 FD800000 E FD820000 E FD840000 E FD860000 E FD880000 E FD8A0000 E FD8C0000 E FD8E0000 E FD900000 E FD920000 E FD940000 E FD960000 E FD980000 E FD9A0000 E FD9C0000 E FD9E0000 E FDA00000 E FDA20000 E FDA40000 E FDA60000 E FDA80000 E FDAA0000 E FDAC0000 E FDAE0000 E FDB00000 E FDB20000 E FDB40000 E FDB60000 E FDB80000 E FDBA0000 E FDBC0000 E FDBE0000 E FDC00000 E FDC20000 E FDC40000 E FDC60000 E FDC80000 E FDCA0000 E FDCC0000 E FDCE0000 E FDD00000 E FDD20000 E FDD40000 E FDD60000 E FDD80000 E FDDA0000 E FDDC0000 E FDDE0000 E FDE00000 E FDE20000 E FDE40000 E FDE60000 E FDE80000 E FDEA0000 E FDEC0000 E FDEE0000 E FDF00000 E FDF20000 E FDF40000 E FDF60000 E FDF80000 E FDFA0000 E FDFC0000 FDFE0000 FE000000 E FE020000 E FE040000 E FE060000 E FE080000 E FE0A0000 E FE0C0000 E FE0E0000 E FE100000 E FE120000 E FE140000 E FE160000 E FE180000 E FE1A0000 E FE1C0000 E FE1E0000 E FE200000 E FE220000 E FE240000 E FE260000 E FE280000 E FE2A0000 E FE2C0000 E FE2E0000 E FE300000 E FE320000 E FE340000 E FE360000 E FE380000 E FE3A0000 E FE3C0000 E FE3E0000 E FE400000 E FE420000 E FE440000 E FE460000 E FE480000 E FE4A0000 E FE4C0000 E FE4E0000 E FE500000 E FE520000 E FE540000 E FE560000 E FE580000 E FE5A0000 E FE5C0000 E FE5E0000 E FE600000 E FE620000 E FE640000 E FE660000 E FE680000 E FE6A0000 E FE6C0000 E FE6E0000 E FE700000 E FE720000 E FE740000 E FE760000 E FE780000 E FE7A0000 E FE7C0000 FE7E0000 FE800000 E FE820000 E FE840000 E FE860000 E FE880000 E FE8A0000 E FE8C0000 E FE8E0000 E FE900000 E FE920000 E FE940000 E FE960000 E FE980000 E FE9A0000 E FE9C0000 E FE9E0000 E FEA00000 E FEA20000 E FEA40000 E FEA60000 E FEA80000 E FEAA0000 E FEAC0000 E FEAE0000 E FEB00000 E FEB20000 E FEB40000 E FEB60000 E FEB80000 E FEBA0000 E FEBC0000 E FEBE0000 E FEC00000 E FEC20000 E FEC40000 E FEC60000 E FEC80000 E FECA0000 E FECC0000 E FECE0000 E FED00000 E FED20000 E FED40000 E FED60000 E FED80000 E FEDA0000 E FEDC0000 E FEDE0000 E FEE00000 E FEE20000 E FEE40000 E FEE60000 E FEE80000 E FEEA0000 E FEEC0000 E FEEE0000 E FEF00000 E FEF20000 E FEF40000 E FEF60000 E FEF80000 E FEFA0000 E FEFC0000 FEFE0000 FF000000 E FF020000 E FF040000 E FF060000 E FF080000 E FF0A0000 E FF0C0000 E FF0E0000 E FF100000 E FF120000 E FF140000 E FF160000 E FF180000 E FF1A0000 E FF1C0000 E FF1E0000 E FF200000 E FF220000 E FF240000 E FF260000 E FF280000 E FF2A0000 E FF2C0000 E FF2E0000 E FF300000 E FF320000 E FF340000 E FF360000 E FF380000 E FF3A0000 E FF3C0000 E FF3E0000 E FF400000 E FF420000 E FF440000 E FF460000 E FF480000 E FF4A0000 E FF4C0000 E FF4E0000 E FF500000 E FF520000 E FF540000 E FF560000 E FF580000 E FF5A0000 E FF5C0000 E FF5E0000 E FF600000 E FF620000 E FF640000 E FF660000 E FF680000 E FF6A0000 E FF6C0000 E FF6E0000 E FF700000 E FF720000 E FF740000 E FF760000 E FF780000 E FF7A0000 E FF7C0000 FF7E0000 FF800000 E FF820000 E FF840000 E FF860000 E FF880000 E FF8A0000 E FF8C0000 E FF8E0000 E FF900000 E FF920000 E FF940000 E FF960000 E FF980000 E FF9A0000 E FF9C0000 E FF9E0000 E FFA00000 E FFA20000 E FFA40000 E FFA60000 E FFA80000 E FFAA0000 E FFAC0000 E FFAE0000 E FFB00000 E FFB20000 E FFB40000 E FFB60000 E FFB80000 E FFBA0000 E FFBC0000 E FFBE0000 E FFC00000 E FFC20000 E FFC40000 E FFC60000 E FFC80000 E FFCA0000 E FFCC0000 E FFCE0000 E FFD00000 E FFD20000 E FFD40000 E FFD60000 E FFD80000 E FFDA0000 E FFDC0000 E FFDE0000 E FFE00000 E FFE20000 E FFE40000 E FFE60000 E FFE80000 E FFEA0000 E FFEC0000 E FFEE0000 E FFF00000 E FFF20000 E FFF40000 E FFF60000 E FFF80000 E FFFA0000 E RO FFFC0000 RO FFFE0000 RO
U-Boot $ *saveenv* Saving Environment to Flash... copy old content: sect_addr: FFFA0000 env_addr: FFFA0000 offset: 00000000 Protect off FFFA0000 ... FFFBFFFF Un-Protecting sectors 509..509 in bank 1 Un-Protected 1 sectors *Erasing Flash...Erase Flash from 0xfffa0000 to 0xfffbffff in Bank # 1* fwc addr fffa0aaa cmd aa aa 8bit x 8 bit fwc addr fffa0555 cmd 55 55 8bit x 8 bit fwc addr fffa0aaa cmd 80 80 8bit x 8 bit fwc addr fffa0aaa cmd aa aa 8bit x 8 bit fwc addr fffa0555 cmd 55 55 8bit x 8 bit fwc addr fffa0000 cmd 30 30 8bit x 8 bit *flash_is_busy: 0 . done* *Erased 1 sectors Writing to Flash... Flash not Erased* Protecting sectors 509..509 in bank 1 Protected 1 sectors U-Boot $
Also, even by using BDI 3000 Debugger, I am not able to erase the flash by giving the proper CFI erase command.
mmb 0xfc000000 0xf0 mmb 0xfc000aaa 0xaa mmb 0xfc000555 0x55 mmb 0xfc000aaa 0x80 mmb 0xfc000aaa 0xaa mmb 0xfc000555 0x55 mmb 0xff7c0000 0x30
But the data is still present.
What may be the reason that flash in not getting erased using U-boot as well as BDI debugger?
On Mon, Apr 12, 2010 at 10:45 PM, Frank Svendsbøe <frank.svendsboe@gmail.com
Best regards, Frank
On Tuesday 13 April 2010 08:31:59 prakash bedge wrote:
I did it. :)
Good. But what did you change to make it work?
Are you not using the mainline version of cfi_flash.c? If not, which "fixup code" are you referring to (link)?
Just checking to be sure: Are you using the Spansion chip in byte (8bit) or word (16bit) mode? All configurations I have used till now use the word mode with this chip.
And you really use 8 bit portwidth to access this chip in your SoC?
<snip>
U-Boot $ *saveenv* Saving Environment to Flash... copy old content: sect_addr: FFFA0000 env_addr: FFFA0000 offset: 00000000 Protect off FFFA0000 ... FFFBFFFF Un-Protecting sectors 509..509 in bank 1 Un-Protected 1 sectors *Erasing Flash...Erase Flash from 0xfffa0000 to 0xfffbffff in Bank # 1* fwc addr fffa0aaa cmd aa aa 8bit x 8 bit fwc addr fffa0555 cmd 55 55 8bit x 8 bit fwc addr fffa0aaa cmd 80 80 8bit x 8 bit fwc addr fffa0aaa cmd aa aa 8bit x 8 bit fwc addr fffa0555 cmd 55 55 8bit x 8 bit fwc addr fffa0000 cmd 30 30 8bit x 8 bit *flash_is_busy: 0 done* *Erased 1 sectors Writing to Flash... Flash not Erased* Protecting sectors 509..509 in bank 1 Protected 1 sectors U-Boot $
Hard to tell. Perhaps still a problem of a misconfigured external bus? Perhaps a problem of incorrect unlocking addresses (byte vs. word address)?
How did you program the U-Boot image into FLASH? Via the BDI3000 "prog" command? Is this working correctly?
Cheers, Stefan
Hi Stefan,
"fixup
I am using U-Boot 2009.08 version. I used the fixup for M29W128GH chip from the patch you suggested earlier. In that code, I changed the condition to check chipwidth and it works.
But I have a concern now, as it works with by changing chipwidth to 16Bit or portwidth to 16Bit. This is making me a little bit confuse. if(info->chipwidth == FLASH_CFI_16BIT) info->portwidth = FLASH_CFI_8BIT;
if(info->chipwidth == FLASH_CFI_8BIT) info->portwidth = FLASH_CFI_16BIT;
Can you please tell what is chipwidth and portwidth and how we can find that?
Also I am not getting the correct manufacturer and device ids.
From the flash control register I can see that my device is 16 Bit.It
reprsent a bit set 1 saying it is a 16 bit device. Now is this flash chipwidth or flash portwidth?
To my flash chip 16 data lines and 26 address lines are connected.
address)? Does it mean that unlocking addresses are not correct? Supoose if chip is in word mode then what should be the portwidth and chipwidth? What will be the ublocking address then?
I am using an utilty to erase flash and to load uboot image and it is working fine, only that it copies data at multple locations.
Thanks & regards, Prakash On Tue, Apr 13, 2010 at 2:04 PM, Stefan Roese sr@denx.de wrote:
I did it. :)
i.e
I
See
the log below
<snip>
00000000
by
Cheers, Stefan
Hi Prakash,
This version is outdated. I suggest to switch to current code.
You shouldn't need any additional code to support the Spansion S29GL chips. Please use the latest code from mainline U-Boot.
chipwidth: Width of the NOR FLASH chip, meaning count of data lines actively used.
portwidth: Width of the external bus (data lines).
From the flash control register I can see that my device is 16 Bit.It reprsent a bit set 1 saying it is a 16 bit device. Now is this flash chipwidth or flash portwidth?
chipwidth.
So you have chipwidth *and* portwidth of 16! This is the most common use case. Again, please use the mainline CFI driver and give it another try.
What kind of "utility"? Don't you use the BDI3000 for FLASH programming? This mirroring might a a result of an incorrect EBC setup.
Cheers, Stefan
Hi Stefan,
Does the latest code supports S29GL512P chip, since I am not seeing any instance of this chip in 2010.03 uboot code.
case. But when flash is getting detected it shows the chipwidth is 8 and portwidth is 16. If you see the logs in earlier mail it is like *found port 2 chip 1 port 16 bits chip 8 bits. *Is it correct or wrong?
I can not use the current code as we have to use the present code for some reason. I believe the uboot code 2009.08, I am using, must also support the S29GL512P chip.
I replaced the cfi_flash.c with the new cfi_flash.c file from latest uboot version 2010.03 and done relevant changes. But still I didn't get the postive result. Is there anything else that I have to check, or by using only cfi_flash.c and cfi_flash.h from 2010.03 uboot code CFI flash driver will work?
I can not use the latest code but I want the CFI support for S29GL512P. Can you please tell that, what I need to do to make the CFI driver works for the S29GL512P chip?
We have customized utility to flash the binary. Using BDI3000 I tried to erase the flash but it didn't work. I followed the CFI erase command seuence but it fails to erase the flash. BDI3000>md 0xfe7c0000 fe7c0000 : 27051956 552d426f 6f742032 3030392e '..VU-Boot 2009. fe7c0010 : 30382028 41707220 31342032 30313020 08 (Apr 14 2010 fe7c0020 : 2d203130 3a30313a 32392900 00000000 - 10:01:29)..... fe7c0030 : 00000000 00000000 00000000 00000000 ................ fe7c0040 : 00000000 00000000 00000000 00000000 ................ fe7c0050 : 00000000 00000000 00000000 00000000 ................ fe7c0060 : 00000000 00000000 00000000 00000000 ................ fe7c0070 : 00000000 00000000 00000000 00000000 ................ fe7c0080 : 00000000 00000000 00000000 00000000 ................ fe7c0090 : 00000000 00000000 00000000 00000000 ................ fe7c00a0 : 00000000 00000000 00000000 00000000 ................ fe7c00b0 : 00000000 00000000 00000000 00000000 ................ fe7c00c0 : 00000000 00000000 00000000 00000000 ................ fe7c00d0 : 00000000 00000000 00000000 00000000 ................ fe7c00e0 : 00000000 00000000 00000000 00000000 ................ fe7c00f0 : 00000000 00000000 00000000 00000000 ................ *BDI3000>mmb 0xfc000000 0xf0 BDI3000>mmb 0xfc000aaa 0xaa BDI3000>mmb 0xfc000555 0x55 BDI3000>mmb 0xfc000aaa 0x80 BDI3000>mmb 0xfc000aaa 0xaa BDI3000>mmb 0xfc000555 0x55 BDI3000>mmb 0xfe7c0000 0x30 *BDI3000>mmb 0xfc000000 0xf0 BDI3000>md 0xfe7c0000 -- *sector data is not erased *fe7c0000 : 30051956 552d426f 6f742032 3030392e 0..VU-Boot 2009. fe7c0010 : 30382028 41707220 31342032 30313020 08 (Apr 14 2010 fe7c0020 : 2d203130 3a30313a 32392900 00000000 - 10:01:29)..... fe7c0030 : 00000000 00000000 00000000 00000000 ................ fe7c0040 : 00000000 00000000 00000000 00000000 ................ fe7c0050 : 00000000 00000000 00000000 00000000 ................ fe7c0060 : 00000000 00000000 00000000 00000000 ................ fe7c0070 : 00000000 00000000 00000000 00000000 ................ fe7c0080 : 00000000 00000000 00000000 00000000 ................ fe7c0090 : 00000000 00000000 00000000 00000000 ................ fe7c00a0 : 00000000 00000000 00000000 00000000 ................ fe7c00b0 : 00000000 00000000 00000000 00000000 ................ fe7c00c0 : 00000000 00000000 00000000 00000000 ................ fe7c00d0 : 00000000 00000000 00000000 00000000 ................ fe7c00e0 : 00000000 00000000 00000000 00000000 ................ fe7c00f0 : 00000000 00000000 00000000 00000000 ................ BDI3000>mmb 0xfc000000 0xf0 BDI3000>mmb 0xfc0000aa 0x98 BDI3000>md 0xfc000020 fc000020 : 51005200 59000200 00004000 00000000 Q.R.Y.....@..... fc000030 : 00000000 00002700 36000000 00000600 ......'.6....... fc000040 : 06000900 13000300 05000300 02001a00 ................ fc000050 : 02000000 06000000 0100ff00 01000000 ................ fc000060 : 02000000 00000000 00000000 00000000 ................ fc000070 : 00000000 00000000 0000ffff ffffffff ................ fc000080 : 50005200 49003100 33001400 02000100 P.R.I.1.3....... fc000090 : 00000800 00000000 0200b500 c5000400 ................ fc0000a0 : 0100ffff ffffffff ffffffff ffffffff ................ fc0000b0 : ffffffff ffffffff ffffffff ffffffff ................ fc0000c0 : ffffffff ffffffff ffffffff ffffffff ................ fc0000d0 : ffffffff ffffffff ffffffff ffffffff ................ fc0000e0 : ffffffff ffffffff ffffffff ffffffff ................ fc0000f0 : ffffffff ffffffff ffffffff ffffffff ................ fc000100 : 00000000 00000000 00000000 00000000 ................ fc000110 : 00000000 00000000 00000000 00000000 ................ BDI3000>mmb 0xfc000000 0xf0
What does it mean? In BDI3000 I am using chiptype MIRRORX16 and BUSWIDTH 16.
BDI parameter [FLASH] ; user flash at 0xFC000000, S29GL512P (16M x 8) CHIPTYPE MIRRORX16 ;Flash type (Flash M29W128GH is of MIRRORX8 Flash Type) CHIPSIZE 0x4000000 ;The size of one flash chip in bytes BUSWIDTH 16 ;The width of the flash memory bus in bits (8 | 16 | 32) ERASE 0xFC000000 0x20000 512 ;erase sector 512 of flash (S29GL512P)
On Tue, Apr 13, 2010 at 5:46 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
chipwidth.
Cheers, Stefan
But when flash is getting detected it shows the chipwidth is 8 and portwidth is 16. If you see the logs in earlier mail it is like found port 2 chip 1 port 16 bits chip 8 bits. Is it correct or wrong?
Check the nBYTE pin on the Spansion flash. For 16bit operation, it should be connected to 3.3V.
We used the S29GL512P on 2009.08 too, so the problem is probably not related to wrong version of U-Boot. Your BDI configuration is the same we use, except for the ERASE command.
With an uninitialized memory controller, the CS0 is probably visible at address 0x0. So the ERASE should be ERASE 0x0 0x20000 512
Regards, Frank
Hi Prakash,
Yes. We have told you multiple times, that this chip is supported. You can't find it in the source though, since no code was needed to specifically support this chip. But its working!
Yes. 2009.08 already supported this chip. But you seem to be using a special patch for this driver, which might afflict this.
Which changes? No changes to this driver are needed to support this chip!!!
See above.
Still not clear to me, what this "utility" is.
So the BDI FLASH commands ("erase", "prog" etc) don't work?
You are using byte access. You should be using word (16bit) access instead! And the word unlock addresses.
Cheers, Stefan
I removed the changes as you suggested and now it is working without modifying the code.
Only thing is that I had to add a flag *CONFIG_SYS_WRITE_SWAPPED_DATA* and it works.
But here I am getting the error in erasing the sector as well in saveenv.
U-Boot $ *saveenv*
fwc addr fffa0aaa cmd aa aa00 16bit x 16 bit
fwc addr fffa0554 cmd 55 5500 16bit x 16 bit
fwc addr fffa0aaa cmd 80 8000 16bit x 16 bit
fwc addr fffa0000 cmd 30 3000 16bit x 16 bit
*flash_is_busy: 0*
. done
Erased 1 sectors
*Writing to Flash... Flash not Erased*
Protected 1 sectors
Here the data is not erase but the last erase sector command data is displayed instead of environment parameters.
U-Boot $ md 0xfffa0000
fffa0000: 3000ffff ffffffff ffffffff ffffffff 0...............
fffa0010: ffffffff ffffffff ffffffff ffffffff ................
I tired to program the word and erase the sector but here again erase failed.
U-Boot $ mw.w 0xfdfa0000 0xfc00
U-Boot $ mw.w 0xfdfa0aaa 0xaa00
U-Boot $ mw.w 0xfdfa0554 0x5500
U-Boot $ mw.w 0xfdfa0aaa 0xa000
U-Boot $ mw.w 0xfdfa0000 0x3132
U-Boot $ md.w 0xfdfa0000
fdfa0000: 3132 ffff ffff ffff ffff ffff ffff ffff 12..............
fdfa0010: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0020: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0030: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0040: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0050: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0060: ffff ffff ffff ffff ffff ffff ffff ffff ................
fdfa0070: ffff ffff ffff ffff ffff ffff ffff ffff ................
U-Boot $ erase 0xfdfa0000 +0x20000
Erase Flash from 0xfdfa0000 to 0xfdfbffff in Bank # 1
fwc addr fdfa0aaa cmd aa aa00 16bit x 16 bit
fwc addr fdfa0554 cmd 55 5500 16bit x 16 bit
fwc addr fdfa0aaa cmd 80 8000 16bit x 16 bit
fwc addr fdfa0000 cmd 30 3000 16bit x 16 bit
flash_is_busy: 0
. done
Erased 1 sectors
fdfa0000: *3000* ffff ffff ffff ffff ffff ffff ffff 0...............
But, when I program the 0xfcfa0000 address and tried to erase the sector then I am able to erase the sector.
U-Boot $ mw.w 0xfcfa0000 0xfc00
U-Boot $ mw.w 0xfcfa0aaa 0xaa00
U-Boot $ mw.w 0xfcfa0554 0x5500
U-Boot $ mw.w 0xfcfa0aaa 0xa000
U-Boot *$ mw.w 0xfcfa0000 0x3132*
U-Boot $ md.w 0xfcfa0000
fcfa0000: *3132* ffff ffff ffff ffff ffff ffff ffff 12..............
fcfa0010: ffff ffff ffff ffff ffff ffff ffff ffff ................
U-Boot $ *erase 0xfcfa0000 0x20000*
Erase Flash from 0xfcfa0000 to 0xfcfbffff in Bank # 1
fwc addr fcfa0aaa cmd aa aa00 16bit x 16 bit
fwc addr fcfa0554 cmd 55 5500 16bit x 16 bit
fwc addr fcfa0aaa cmd 80 8000 16bit x 16 bit
fwc addr fcfa0000 cmd 30 3000 16bit x 16 bit
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 0
. done
Erased 1 sectors
U-Boot $ md 0xfcfa0000
*fcfa0000: ffffffff ffffffff* ffffffff ffffffff ................
fcfa0010: ffffffff ffffffff ffffffff ffffffff ................
fcfa0020: ffff ffff ffff ffff ffff ffff ffff ffff ................
fcfa0030: ffff ffff ffff ffff ffff ffff ffff ffff ................
I am able to erase 128 sector from flash base i.e. I am able to erase the flash from flash base 0xfc000000 upto 16 MB size.
But I am not able to erase the remaining 384 sectors from 0xFD000000 onwards.
My current flash settings
* FLASH related
#define CONFIG_SYS_FLASH_BASE 0xfc000000 /* start of FLASH */
#define CONFIG_ENV_IS_IN_FLASH 1
#define CONFIG_SYS_WRITE_SWAPPED_DATA
#define CONFIG_SYS_FLASH_CFI_WIDTH (FLASH_CFI_16BIT)
#define CONFIG_SYS_FLASH_ERASE_TOUT 300000 /* Timeout for Flash Erase (in ms) */
#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */
#define CONFIG_SYS_MONITOR_BASE 0xFFFC0000 /* Start of U-Boot */
#define CONFIG_SYS_MONITOR_LEN 256
But when I give the “erase all” command then the complete flash gets erased. I am little bit confused by this abnormal behavior.
Is there something in code needs to check or there be an issue with chip address bus?
Regards,
Prakash
On Wed, Apr 14, 2010 at 5:35 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
use
some
the
S29GL512P chip.
uboot
See above.
programming?
Cheers, Stefan
Hi All,
At last all is done. There were plattform specific changes in the board.
Now I am able to run the CFI driver for flash chip S29GL512P.
Thanks for your help so far.
Regards, Prakash
U-Boot $ *saveenv*
*flash_is_busy: 0*
. done
Erased 1 sectors
Protected 1 sectors
flash_is_busy: 0
. done
Erased 1 sectors
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 1
flash_is_busy: 0
. done
Erased 1 sectors
- FLASH related
Regards,
Prakash
Hi Prakash,
use
some
the
S29GL512P chip.
uboot
driver
will work?
See above.
programming?
Cheers, Stefan
Hi Prakash,
This is a custom PPC4xx version, correct? Which external bus controller is used here? The EBC from IBM as on the AMCC 4xx versions? You need to check your SoC documentation for this.
Right. Most likely you just need to tune the chip select timing registers. And of course the size of the CS. No idea how this is done for your external bus controller though.
BTW: You might also need to configure a bigger TLB entry for the FLASH now that you use a bigger FLASH chip.
Yes. As most AMCC eval boards do.
Cheers, Stefan
Hi Stefan,
And of course the size of the CS. What mean by size of CS? Which file I should check for timing register for S29GL512P?
now that you use a bigger FLASH chip. Does uboot support one single TLB entry for 64MB size. At pesent I have configured 4 TLB entries, each 16MB.
On Fri, Apr 9, 2010 at 7:05 PM, Stefan Roese sr@denx.de wrote:
Hi Prakash,
using?
with
it
Cheers, Stefan
IIRC, then you have a custom PPC440 SoC. I have no idea which external bus controller (EBC) is used on your SoC. Is it the one also used on the AppliedMicro (AMCC) PPC4xx? Then you need to change the CONFIG_SYS_EBC_PBxCR / CONFIG_SYS_EBC_PBxAP defines. Take a look at the users manual for details. If you have a different EBC then I can't really help you here. Your SoC documentation should have all details you need.
Looking into the PPC440 users manual makes it clear. 64MByte as TLB size is not available. You need to define 4 16MB entries for this.
Cheers, Stefan
Stefan Roese <sr <at> denx.de> writes:
Hi Prakash,
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office <at> denx.de
Hi Stefan,
I am Balaji. am using IMX6 base custom board. In my board am using S29GL01G NOR Flash to srore u-boot and kernel. I understand from the data sheet this NOR Flash is CFI based on. So i have added Configurations for CFI Flash driver.
Currently am loading the U-boot into DDR3 and able to excute U-boot test commands. When i put flinfo , am getting "missing or unknow flash type" and while loading the u-boot it is printing as " Unknown flash on BANK 1 - Size - 0MB". So am not sure what am missing here or i have to add anything extra in teh config file. Please request you to check and provide your suggestion.
Thanks, Balaji S
Dear Balaji,
On 10.03.2012 11:47, Balaji Sivakumar wrote:
Stefan Roese<sr<at> denx.de> writes:
Hi Prakash,
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk& Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office<at> denx.de
Hi Stefan,
Just to be sure: Do you use the mainline U-Boot (u-boot.imx) or the old Freescale one?
This thread talks about S29GL512P. You talk about S29GL01G?
Can you send us your flash/CFI configuration from the config file?
Which CONFIG_SYS_FLASH_BASE do you use?
Best regards
Dirk
Dear Balaji Sivakumar,
Thi sis of course only part of the configuration that is needed.
For example, you must also set up the memory controller and memory map as needed for your board.
Hi Prakash,
I can confirm the S29GL512P is working with U-Boot (and Linux). No special work has been done to make it work. Use chiptype MIRRORX16, if you're using a BDI3000 JTAG to flash U-Boot.
Good luck Frank
Hi Frank,
Why I should use MIRRORX16 in BDI3000 config file?
Can you please tell which boards support the S29GL512P NOR flash?
Regards, Prakash Bedge On Fri, Apr 9, 2010 at 1:18 PM, Frank Svendsbøe frank.svendsboe@gmail.comwrote:
Hi Prakash,
Good luck Frank
On Fri, Apr 9, 2010 at 10:07 AM, prakash bedge prakash.bedge@gmail.com wrote:
Hi Frank,
According to the different flash algorithms described in the BDI manual, this was the closest we found, and it works. What chiptype do you use today?
None yet I think. We'll commit a patch soon which supports the Siemens Digital Powerline Modem (DPM).
Our U-Boot/Linux hardware is based on Analogue & Micros Adder Module, but modified a bit (different flash and SDRAM, contains an FPGA, an AVR and a TI DSP).
Best regards, Frank
Regards, Prakash Bedge On Fri, Apr 9, 2010 at 1:18 PM, Frank Svendsbøe frank.svendsboe@gmail.com wrote:
Hi Prakash,
Good luck Frank
participants (6)
Balaji Sivakumar
Dirk Behme
Frank Svendsbøe
prakash bedge
Stefan Roese
