[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
I am having trouble cloning git repositories. I hope this pull request was generated correctly. I saw "fatal: read error: Connection reset by peer" when creating this pull request.
The following changes since commit d77447fdb122dab290fb1ad184a62456011e6e06:
serial: pl01x: fix PL010 regression (2015-04-21 10:05:42 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to ab10d73d2fc13bd5baf5024e54ad92641d238bdb:
armv8/fsl-lsch3: Implement workaround for I2C erratum A009203 (2015-04-23 16:46:51 -0700)
---------------------------------------------------------------- Alison Wang (2): arm/ls102xa:Add support of conditional workaround implementation as per SoC ver ls102xa: ddr4: Use LPUART as console output to verify DCU driver
Bhupesh Sharma (3): armv8/fsl-lsch3: Add Freescale Debug Server driver fsl-ch3/README: Add description for NOR flash layout (firmware images) armv8/fsl-ch3: Add support to print RCW configuration
J. German Rivera (1): drivers/fsl-mc: Changed MC firmware loading for new boot architecture
Jaiprakash Singh (1): driver/ifc: Add 64KB page support
Minghuan Lian (4): pci/layerscape: remove unnecessary pcie_layerscape.h pci/layerscape: fix link and class issues to support ls2085a drivers/net/e1000.c: Cleanup whitespace armv8: Add SerDes framework for Layerscape Architecture
Nikhil Badola (3): drivers:usb: Add device-tree fixup to identify socs having dual phy drivers:usb:fsl: Add affected SOCs for USB Erratum A007792 drivers:usb: Check if USB Erratum A005697 is applicable on BSC913x
Prabhakar Kushwaha (8): driver/fsl-mc: Add support of MC Flibs driver/ldpaa_eth: Add LDPAA Ethernet driver board/ls2085_common: Increase malloc length driver/fsl_ifc: Add support to finalize CS1, CS3 address binding armv8/ls2085a: Update common header file driver/ldpaa_eth: Update ldpaa ethernet driver driver/ldpaa: Add support of WRIOP static data structure board/ls2085qds: Add support ethernet
Scott Wood (9): nand/fsl_ifc: Increase eccstat[] for IFC 2.0 cmd_mem: Store last address/size/etc as ulong armv8/fsl-lsch3: Set nodes in DVM domain fsl-lsch3: Introduce place for common early SoC init armv8/ls2085a: Add workaround for USB erratum A-008751 armv8/fsl-lsch3: Use correct compatible for serial clock fixup armv8/ls2085aqds: NAND boot support freescale/qixis: Add support for booting from NAND armv8/ls2085ardb: Enable NAND SPL support
Shaohui Xie (1): net/memac_phy: reuse driver for little endian SoCs
Yangbo Lu (1): ls2085a: esdhc: Add esdhc support for ls2085a
Yao Yuan (1): ls1021atwr: add hwconfig setting to do pin mux
York Sun (12): driver/i2c/mxc: Enable I2C bus 3 and 4 drivers/ddr/fsl: Update DDR driver for DDR4 driver/ddr/fsl: Fix driver to support empty first slot driver/ddr/fsl: Add built-in memory test for DDR4 driver driver/ddr/fsl: Add workaround for DDR erratum A008511 armv8/fsl-lsch3: Implement workaround for erratum A008585 armv8/fsl-lsch3: Fix platform clock calculation armv8/ls2085a: Fix generic timer clock source armv8/fsl-lsch3: Update early MMU table armv8/ls2085aqds: Add support of LS2085AQDS platform armv8/ls2085ardb: Add support of LS2085ARDB platform armv8/fsl-lsch3: Implement workaround for I2C erratum A009203
Zhao Qiang (2): QE/DeepSleep: add QE deepsleep support for mpc85xx QE/DeepSleep: add QE deepsleep support for arm
gaurav rana (1): Add bootscript support to esbc_validate.
pankaj chauhan (2): armv8/ls2085a: Add support for reset request net/phy/cortina: Fix compilation warning
README | 13 + arch/arm/Kconfig | 24 + arch/arm/cpu/armv7/ls102xa/clock.c | 4 +- arch/arm/cpu/armv8/fsl-lsch3/Makefile | 2 + arch/arm/cpu/armv8/fsl-lsch3/README | 138 +++ arch/arm/cpu/armv8/fsl-lsch3/cpu.c | 123 ++- arch/arm/cpu/armv8/fsl-lsch3/fdt.c | 9 +- arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c | 115 +++ arch/arm/cpu/armv8/fsl-lsch3/lowlevel.S | 15 + arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c | 117 +++ arch/arm/cpu/armv8/fsl-lsch3/mp.c | 7 + arch/arm/cpu/armv8/fsl-lsch3/mp.h | 1 + arch/arm/cpu/armv8/fsl-lsch3/soc.c | 107 ++ arch/arm/cpu/armv8/fsl-lsch3/speed.c | 11 +- arch/arm/cpu/armv8/generic_timer.c | 11 + arch/arm/cpu/armv8/u-boot-spl.lds | 77 ++ arch/arm/include/asm/arch-fsl-lsch3/config.h | 60 +- arch/arm/include/asm/arch-fsl-lsch3/fsl_serdes.h | 67 ++ arch/arm/include/asm/arch-fsl-lsch3/immap_lsch3.h | 29 + arch/arm/include/asm/arch-fsl-lsch3/soc.h | 8 + arch/arm/include/asm/arch-ls102xa/config.h | 4 - arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 3 + arch/arm/include/asm/fsl_secure_boot.h | 25 + arch/arm/include/asm/pcie_layerscape.h | 13 - arch/arm/lib/crt0_64.S | 7 + arch/powerpc/cpu/mpc85xx/cpu_init_early.c | 8 +- arch/powerpc/cpu/mpc85xx/speed.c | 4 +- arch/powerpc/include/asm/fsl_secure_boot.h | 19 + board/freescale/bsc9132qds/bsc9132qds.c | 4 +- board/freescale/c29xpcie/c29xpcie.c | 4 +- board/freescale/common/arm_sleep.c | 6 + board/freescale/common/cmd_esbc_validate.c | 16 + board/freescale/common/mpc85xx_sleep.c | 8 + board/freescale/common/qixis.c | 31 +- board/freescale/ls1021aqds/MAINTAINERS | 1 + board/freescale/ls1021aqds/ls1021aqds.c | 73 +- board/freescale/ls1021atwr/ls1021atwr.c | 110 ++- board/freescale/ls2085a/ls2085a.c | 43 +- board/freescale/ls2085aqds/Kconfig | 16 + board/freescale/ls2085aqds/MAINTAINERS | 8 + board/freescale/ls2085aqds/Makefile | 9 + board/freescale/ls2085aqds/README | 129 +++ board/freescale/ls2085aqds/ddr.c | 196 ++++ board/freescale/ls2085aqds/ddr.h | 92 ++ board/freescale/ls2085aqds/eth.c | 380 +++++++ board/freescale/ls2085aqds/ls2085aqds.c | 274 ++++++ board/freescale/ls2085aqds/ls2085aqds_qixis.h | 30 + board/freescale/ls2085ardb/Kconfig | 16 + board/freescale/ls2085ardb/MAINTAINERS | 8 + board/freescale/ls2085ardb/Makefile | 8 + board/freescale/ls2085ardb/README | 109 ++ board/freescale/ls2085ardb/ddr.c | 196 ++++ board/freescale/ls2085ardb/ddr.h | 92 ++ board/freescale/ls2085ardb/ls2085ardb.c | 249 +++++ board/freescale/ls2085ardb/ls2085ardb_qixis.h | 20 + board/freescale/p1010rdb/p1010rdb.c | 5 +- board/freescale/p1010rdb/spl.c | 4 +- common/board_r.c | 6 + common/cmd_mem.c | 6 +- common/spl/spl.c | 2 +- common/spl/spl_nand.c | 2 +- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 3 + configs/ls2085aqds_defconfig | 3 + configs/ls2085aqds_nand_defconfig | 4 + configs/ls2085ardb_defconfig | 3 + configs/ls2085ardb_nand_defconfig | 4 + drivers/ddr/fsl/ctrl_regs.c | 77 +- drivers/ddr/fsl/ddr4_dimm_params.c | 3 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 169 +++- drivers/ddr/fsl/interactive.c | 56 +- drivers/ddr/fsl/lc_common_dimm_params.c | 5 +- drivers/ddr/fsl/main.c | 2 +- drivers/ddr/fsl/options.c | 7 +- drivers/ddr/fsl/util.c | 28 +- drivers/i2c/mxc_i2c.c | 17 +- drivers/misc/Makefile | 1 + drivers/misc/fsl_debug_server.c | 246 +++++ drivers/misc/fsl_ifc.c | 21 + drivers/mmc/fsl_esdhc.c | 36 +- drivers/mtd/nand/fsl_ifc_nand.c | 64 +- drivers/mtd/nand/fsl_ifc_spl.c | 25 +- drivers/net/Makefile | 2 + drivers/net/e1000.c | 8 +- drivers/net/fm/eth.c | 2 +- drivers/net/fm/memac.c | 2 +- drivers/net/fm/memac_phy.c | 62 +- drivers/net/fsl-mc/Makefile | 6 +- drivers/net/fsl-mc/dpbp.c | 102 ++ drivers/net/fsl-mc/dpio/Makefile | 9 + drivers/net/fsl-mc/dpio/dpio.c | 102 ++ drivers/net/fsl-mc/dpio/qbman_portal.c | 593 +++++++++++ drivers/net/fsl-mc/dpio/qbman_portal.h | 157 +++ drivers/net/fsl-mc/dpio/qbman_private.h | 169 ++++ drivers/net/fsl-mc/dpio/qbman_sys.h | 290 ++++++ drivers/net/fsl-mc/dpmng.c | 65 +- drivers/net/fsl-mc/dpni.c | 506 ++++++++++ drivers/net/fsl-mc/dprc.c | 283 ++++++ drivers/net/fsl-mc/fsl_dpmng_cmd.h | 32 +- drivers/net/fsl-mc/mc.c | 702 ++++++++++--- drivers/net/fsl-mc/mc_sys.c | 6 +- drivers/net/ldpaa_eth/Makefile | 9 + drivers/net/ldpaa_eth/ldpaa_eth.c | 710 +++++++++++++ drivers/net/ldpaa_eth/ldpaa_eth.h | 149 +++ drivers/net/ldpaa_eth/ldpaa_wriop.c | 146 +++ drivers/net/ldpaa_eth/ls2085a.c | 83 ++ drivers/net/phy/cortina.c | 4 +- drivers/net/vsc9953.c | 2 +- drivers/pci/pcie_layerscape.c | 52 +- drivers/qe/qe.c | 82 ++ drivers/qe/qe.h | 6 + drivers/usb/host/ehci-fsl.c | 16 +- include/config_fsl_secboot.h | 89 ++ include/configs/aristainetos.h | 1 + include/configs/cm_fx6.h | 1 + include/configs/embestmx6boards.h | 1 + include/configs/flea3.h | 1 + include/configs/gw_ventana.h | 1 + include/configs/imx31_phycore.h | 1 + include/configs/ls1021aqds.h | 2 + include/configs/ls1021atwr.h | 1 + include/configs/ls2085a_common.h | 242 ++--- include/configs/ls2085a_emu.h | 65 ++ include/configs/ls2085a_simu.h | 122 +++ include/configs/ls2085aqds.h | 359 +++++++ include/configs/ls2085ardb.h | 305 ++++++ include/configs/m53evk.h | 1 + include/configs/mx35pdk.h | 1 + include/configs/mx53ard.h | 1 + include/configs/mx53evk.h | 1 + include/configs/mx53loco.h | 1 + include/configs/mx53smd.h | 1 + include/configs/mx6qsabreauto.h | 1 + include/configs/mx6sabresd.h | 1 + include/configs/mx6slevk.h | 1 + include/configs/mx6sxsabresd.h | 1 + include/configs/nitrogen6x.h | 1 + include/configs/novena.h | 1 + include/configs/ot1200.h | 1 + include/configs/platinum.h | 1 + include/configs/tbs2910.h | 1 + include/configs/titanium.h | 1 + include/configs/tqma6.h | 1 + include/configs/wandboard.h | 1 + include/configs/woodburn_common.h | 1 + include/fsl-mc/fsl_dpaa_fd.h | 121 +++ include/fsl-mc/fsl_dpbp.h | 143 +++ include/fsl-mc/fsl_dpio.h | 163 +++ include/fsl-mc/fsl_dpmng.h | 113 +-- include/fsl-mc/fsl_dpni.h | 1093 +++++++++++++++++++++ include/fsl-mc/fsl_dprc.h | 659 +++++++++++++ include/fsl-mc/fsl_mc.h | 5 +- include/fsl-mc/fsl_mc_cmd.h | 17 +- include/fsl-mc/fsl_mc_private.h | 50 + include/fsl-mc/fsl_qbman_base.h | 87 ++ include/fsl-mc/fsl_qbman_portal.h | 175 ++++ include/fsl-mc/ldpaa_wriop.h | 70 ++ include/fsl_ddr.h | 4 +- include/fsl_ddr_sdram.h | 3 + include/fsl_debug_server.h | 32 + include/fsl_esdhc.h | 4 + include/fsl_ifc.h | 84 +- {arch/powerpc/include/asm => include}/fsl_memac.h | 0 include/fsl_usb.h | 57 +- include/linux/immap_qe.h | 12 + 164 files changed, 11694 insertions(+), 713 deletions(-) create mode 100644 arch/arm/cpu/armv8/fsl-lsch3/fsl_lsch3_serdes.c create mode 100644 arch/arm/cpu/armv8/fsl-lsch3/ls2085a_serdes.c create mode 100644 arch/arm/cpu/armv8/fsl-lsch3/soc.c create mode 100644 arch/arm/cpu/armv8/u-boot-spl.lds create mode 100644 arch/arm/include/asm/arch-fsl-lsch3/fsl_serdes.h create mode 100644 arch/arm/include/asm/arch-fsl-lsch3/soc.h create mode 100644 arch/arm/include/asm/fsl_secure_boot.h delete mode 100644 arch/arm/include/asm/pcie_layerscape.h create mode 100644 board/freescale/ls2085aqds/Kconfig create mode 100644 board/freescale/ls2085aqds/MAINTAINERS create mode 100644 board/freescale/ls2085aqds/Makefile create mode 100644 board/freescale/ls2085aqds/README create mode 100644 board/freescale/ls2085aqds/ddr.c create mode 100644 board/freescale/ls2085aqds/ddr.h create mode 100644 board/freescale/ls2085aqds/eth.c create mode 100644 board/freescale/ls2085aqds/ls2085aqds.c create mode 100644 board/freescale/ls2085aqds/ls2085aqds_qixis.h create mode 100644 board/freescale/ls2085ardb/Kconfig create mode 100644 board/freescale/ls2085ardb/MAINTAINERS create mode 100644 board/freescale/ls2085ardb/Makefile create mode 100644 board/freescale/ls2085ardb/README create mode 100644 board/freescale/ls2085ardb/ddr.c create mode 100644 board/freescale/ls2085ardb/ddr.h create mode 100644 board/freescale/ls2085ardb/ls2085ardb.c create mode 100644 board/freescale/ls2085ardb/ls2085ardb_qixis.h create mode 100644 configs/ls1021aqds_ddr4_nor_lpuart_defconfig create mode 100644 configs/ls2085aqds_defconfig create mode 100644 configs/ls2085aqds_nand_defconfig create mode 100644 configs/ls2085ardb_defconfig create mode 100644 configs/ls2085ardb_nand_defconfig create mode 100644 drivers/misc/fsl_debug_server.c create mode 100644 drivers/net/fsl-mc/dpbp.c create mode 100644 drivers/net/fsl-mc/dpio/Makefile create mode 100644 drivers/net/fsl-mc/dpio/dpio.c create mode 100644 drivers/net/fsl-mc/dpio/qbman_portal.c create mode 100644 drivers/net/fsl-mc/dpio/qbman_portal.h create mode 100644 drivers/net/fsl-mc/dpio/qbman_private.h create mode 100644 drivers/net/fsl-mc/dpio/qbman_sys.h create mode 100644 drivers/net/fsl-mc/dpni.c create mode 100644 drivers/net/fsl-mc/dprc.c create mode 100644 drivers/net/ldpaa_eth/Makefile create mode 100644 drivers/net/ldpaa_eth/ldpaa_eth.c create mode 100644 drivers/net/ldpaa_eth/ldpaa_eth.h create mode 100644 drivers/net/ldpaa_eth/ldpaa_wriop.c create mode 100644 drivers/net/ldpaa_eth/ls2085a.c create mode 100644 include/config_fsl_secboot.h create mode 100644 include/configs/ls2085aqds.h create mode 100644 include/configs/ls2085ardb.h create mode 100644 include/fsl-mc/fsl_dpaa_fd.h create mode 100644 include/fsl-mc/fsl_dpbp.h create mode 100644 include/fsl-mc/fsl_dpio.h create mode 100644 include/fsl-mc/fsl_dpni.h create mode 100644 include/fsl-mc/fsl_dprc.h create mode 100644 include/fsl-mc/fsl_mc_private.h create mode 100644 include/fsl-mc/fsl_qbman_base.h create mode 100644 include/fsl-mc/fsl_qbman_portal.h create mode 100644 include/fsl-mc/ldpaa_wriop.h create mode 100644 include/fsl_debug_server.h rename {arch/powerpc/include/asm => include}/fsl_memac.h (100%)
Thanks.
York
On Thu, Apr 23, 2015 at 07:17:51PM -0700, York Sun wrote:
Tom,
York Sun
