[U-Boot] [PATCH 0/4] omap and sniper reboot mode fixes and cleanups
This series unifies the reboot mode interface between omap3 and omap4. It also fixes the reboot to bootloader feature in fastboot.
It is to be applied on top of the previous series: Amazon Kindle Fire (first generation) codename kc1 support series.
This switches reboot mode handling to a string-based interface, that allows more flexibility to set a common interface with the next generations of OMAP devices.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/omap3/boot.c | 14 ++++++++++---- arch/arm/include/asm/arch-omap3/omap.h | 4 ++-- board/lge/sniper/sniper.c | 6 +++--- 3 files changed, 15 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/boot.c b/arch/arm/cpu/armv7/omap3/boot.c index 44d7c30..259c210 100644 --- a/arch/arm/cpu/armv7/omap3/boot.c +++ b/arch/arm/cpu/armv7/omap3/boot.c @@ -57,11 +57,14 @@ u32 omap_sys_boot_device(void) return boot_devices[sys_boot]; }
-char omap_reboot_mode(void) +int omap_reboot_mode(char *mode, unsigned int length) { u32 reboot_mode; char c;
+ if (length < 2) + return -1; + reboot_mode = readl((u32 *)(OMAP34XX_SCRATCHPAD + 4));
c = (reboot_mode >> 24) & 0xff; @@ -74,7 +77,10 @@ char omap_reboot_mode(void)
c = reboot_mode & 0xff;
- return c; + mode[0] = c; + mode[1] = '\0'; + + return 0; }
int omap_reboot_mode_clear(void) @@ -84,11 +90,11 @@ int omap_reboot_mode_clear(void) return 0; }
-int omap_reboot_mode_store(char c) +int omap_reboot_mode_store(char *mode) { u32 reboot_mode;
- reboot_mode = 'B' << 24 | 'M' << 16 | c; + reboot_mode = 'B' << 24 | 'M' << 16 | mode[0];
writel(reboot_mode, (u32 *)(OMAP34XX_SCRATCHPAD + 4));
diff --git a/arch/arm/include/asm/arch-omap3/omap.h b/arch/arm/include/asm/arch-omap3/omap.h index 2c94a81..4044b8d 100644 --- a/arch/arm/include/asm/arch-omap3/omap.h +++ b/arch/arm/include/asm/arch-omap3/omap.h @@ -260,9 +260,9 @@ struct omap_boot_parameters { unsigned int boot_device_descriptor; };
-char omap_reboot_mode(void); +int omap_reboot_mode(char *mode, unsigned int length); int omap_reboot_mode_clear(void); -int omap_reboot_mode_store(char c); +int omap_reboot_mode_store(char *mode); #endif
#endif diff --git a/board/lge/sniper/sniper.c b/board/lge/sniper/sniper.c index f093f97..b2c8e97 100644 --- a/board/lge/sniper/sniper.c +++ b/board/lge/sniper/sniper.c @@ -109,7 +109,7 @@ int misc_init_r(void)
/* Reboot mode */
- reboot_mode[0] = omap_reboot_mode(); + omap_reboot_mode(reboot_mode, sizeof(reboot_mode));
if (keys[0]) reboot_mode[0] = 'r'; @@ -159,12 +159,12 @@ void get_board_serial(struct tag_serialnr *serialnr)
void reset_misc(void) { - omap_reboot_mode_store('u'); + omap_reboot_mode_store("u"); }
int fb_set_reboot_flag(void) { - return omap_reboot_mode_store('b'); + return omap_reboot_mode_store("b"); }
#ifndef CONFIG_SPL_BUILD
Signed-off-by: Paul Kocialkowski contact@paulk.fr Reviewed-by: Tom Rini trini@konsulko.com
This introduces a define for the offset to the reboot reason, rather than hardcoding it.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- arch/arm/cpu/armv7/omap3/boot.c | 8 +++++--- arch/arm/include/asm/arch-omap3/omap.h | 2 ++ 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap3/boot.c b/arch/arm/cpu/armv7/omap3/boot.c index 259c210..64b242b 100644 --- a/arch/arm/cpu/armv7/omap3/boot.c +++ b/arch/arm/cpu/armv7/omap3/boot.c @@ -65,7 +65,8 @@ int omap_reboot_mode(char *mode, unsigned int length) if (length < 2) return -1;
- reboot_mode = readl((u32 *)(OMAP34XX_SCRATCHPAD + 4)); + reboot_mode = readl((u32 *)(OMAP34XX_SCRATCHPAD + + OMAP_REBOOT_REASON_OFFSET));
c = (reboot_mode >> 24) & 0xff; if (c != 'B') @@ -85,7 +86,7 @@ int omap_reboot_mode(char *mode, unsigned int length)
int omap_reboot_mode_clear(void) { - writel(0, (u32 *)(OMAP34XX_SCRATCHPAD + 4)); + writel(0, (u32 *)(OMAP34XX_SCRATCHPAD + OMAP_REBOOT_REASON_OFFSET));
return 0; } @@ -96,7 +97,8 @@ int omap_reboot_mode_store(char *mode)
- writel(reboot_mode, (u32 *)(OMAP34XX_SCRATCHPAD + 4)); + writel(reboot_mode, (u32 *)(OMAP34XX_SCRATCHPAD + + OMAP_REBOOT_REASON_OFFSET));
return 0; } diff --git a/arch/arm/include/asm/arch-omap3/omap.h b/arch/arm/include/asm/arch-omap3/omap.h index 4044b8d..bc0e02a 100644 --- a/arch/arm/include/asm/arch-omap3/omap.h +++ b/arch/arm/include/asm/arch-omap3/omap.h @@ -249,6 +249,8 @@ struct gpio { /* ABB tranxdone mask */ #define OMAP_ABB_MPU_TXDONE_MASK (0x1 << 26)
+#define OMAP_REBOOT_REASON_OFFSET 0x04 + /* Boot parameters */ #ifndef __ASSEMBLY__ struct omap_boot_parameters {
There is no need to set the reboot mode to a particular value prior to reboot, since valid values will have been caught and cleared earlier.
In addition, this breaks the reboot-bootloader fastboot call, by overriding the required value for fastboot.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/lge/sniper/sniper.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/lge/sniper/sniper.c b/board/lge/sniper/sniper.c index b2c8e97..6726866 100644 --- a/board/lge/sniper/sniper.c +++ b/board/lge/sniper/sniper.c @@ -157,11 +157,6 @@ void get_board_serial(struct tag_serialnr *serialnr) omap_die_id_get_board_serial(serialnr); }
-void reset_misc(void) -{ - omap_reboot_mode_store("u"); -} - int fb_set_reboot_flag(void) { return omap_reboot_mode_store("b");
Reboot mode garbage is found on cold reset and might be seen as valid on the next warm reset, thus it has to be cleared on cold reset.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/lge/sniper/sniper.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/lge/sniper/sniper.c b/board/lge/sniper/sniper.c index 6726866..29a7045 100644 --- a/board/lge/sniper/sniper.c +++ b/board/lge/sniper/sniper.c @@ -122,6 +122,9 @@ int misc_init_r(void)
omap_reboot_mode_clear(); } else { + /* Reboot mode garbage may still be valid, so clear it. */ + omap_reboot_mode_clear(); + /* * When not rebooting, valid power on reasons are either the * power button, charger plug or USB plug.
Paul Kocialkowski
