[U-Boot] [PATCH v2 0/7] ARM: AM335x: Add support for FIT and various platforms
This series adds support for FIT and various AM335x based platforms
Link to v1: https://www.mail-archive.com/u-boot%40lists.denx.de/msg212314.html
Lokesh Vutla (5): board: am33xx: fit: add support for selecting dtb dynamically ARM: dts: am335x-bone: Enable uart and timer ARM: AM335x: Enable FIT ARM: dts: AM335x-evmsk: Add initial support ARM: dts: AM335x-BBG: Add initial support
Mugunthan V N (1): ARM: dts: am335x: fix cd-gpios definition as per hardware design and dt binding docs
Tom Rini (1): configs: am335x_evm: Switch to env on FAT SD by default
arch/arm/dts/Makefile | 4 +- arch/arm/dts/am335x-bone-common.dtsi | 8 +- arch/arm/dts/am335x-bone.dts | 3 - arch/arm/dts/am335x-bonegreen.dts | 57 +++ arch/arm/dts/am335x-evm.dts | 2 +- arch/arm/dts/am335x-evmsk.dts | 720 +++++++++++++++++++++++++++++++++++ board/ti/am335x/MAINTAINERS | 1 - board/ti/am335x/board.c | 18 + configs/am335x_evm_defconfig | 17 +- configs/am335x_gp_evm_defconfig | 46 --- include/configs/am335x_evm.h | 40 +- include/dt-bindings/pinctrl/omap.h | 37 ++ 12 files changed, 874 insertions(+), 79 deletions(-) create mode 100644 arch/arm/dts/am335x-bonegreen.dts create mode 100644 arch/arm/dts/am335x-evmsk.dts delete mode 100644 configs/am335x_gp_evm_defconfig
FIT allows for a multiple dtb in a single image. SPL needs a way to detect the right dtb to be used. Adding support for the same.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - None
board/ti/am335x/board.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 4330be6..a3d1e2b 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -632,3 +632,17 @@ int board_eth_init(bd_t *bis) #endif
#endif /* CONFIG_DM_ETH */ + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + if (board_is_gp_evm() && !strcmp(name, "am335x-evm")) + return 0; + else if (board_is_bone() && !strcmp(name, "am335x-bone")) + return 0; + else if (board_is_bone_lt() && !strcmp(name, "am335x-boneblack")) + return 0; + else + return -1; +} +#endif
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Allow am335x-bone.dts to be built and enable uart and timer for all beaglebones.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - None
arch/arm/dts/Makefile | 2 +- arch/arm/dts/am335x-bone-common.dtsi | 5 +++++ arch/arm/dts/am335x-bone.dts | 3 --- 3 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ada00c5..0ea7bbe 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,7 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zc1751-xm015-dc1.dtb \ zynqmp-zc1751-xm016-dc2.dtb \ zynqmp-zc1751-xm019-dc5.dtb -dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-evm.dtb +dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb am335x-evm.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb diff --git a/arch/arm/dts/am335x-bone-common.dtsi b/arch/arm/dts/am335x-bone-common.dtsi index fec7834..a00c0cd 100644 --- a/arch/arm/dts/am335x-bone-common.dtsi +++ b/arch/arm/dts/am335x-bone-common.dtsi @@ -13,6 +13,11 @@ }; };
+ chosen { + stdout-path = &uart0; + tick-timer = &timer2; + }; + memory { device_type = "memory"; reg = <0x80000000 0x10000000>; /* 256 MB */ diff --git a/arch/arm/dts/am335x-bone.dts b/arch/arm/dts/am335x-bone.dts index 81441cc..6b84937 100644 --- a/arch/arm/dts/am335x-bone.dts +++ b/arch/arm/dts/am335x-bone.dts @@ -13,9 +13,6 @@ / { model = "TI AM335x BeagleBone"; compatible = "ti,am335x-bone", "ti,am33xx"; - chosen { - stdout-path = &uart0; - }; };
&ldo3_reg {
Use a single defconfig for all AM335x platforms by enabling FIT
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - Removed am335x_evm_nodt_defconfig
board/ti/am335x/MAINTAINERS | 1 - configs/am335x_evm_defconfig | 17 +++++++++------ configs/am335x_gp_evm_defconfig | 46 ----------------------------------------- 3 files changed, 11 insertions(+), 53 deletions(-) delete mode 100644 configs/am335x_gp_evm_defconfig
diff --git a/board/ti/am335x/MAINTAINERS b/board/ti/am335x/MAINTAINERS index 7dc2b83..c99e06d 100644 --- a/board/ti/am335x/MAINTAINERS +++ b/board/ti/am335x/MAINTAINERS @@ -6,7 +6,6 @@ F: include/configs/am335x_evm.h F: configs/am335x_boneblack_defconfig F: configs/am335x_boneblack_vboot_defconfig F: configs/am335x_evm_defconfig -F: configs/am335x_gp_evm_defconfig F: configs/am335x_evm_nor_defconfig F: configs/am335x_evm_norboot_defconfig F: configs/am335x_evm_spiboot_defconfig diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 62f26b5..7be5479 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -1,15 +1,11 @@ CONFIG_ARM=y CONFIG_TARGET_AM335X_EVM=y CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y -CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_ASKENV=y @@ -30,9 +26,14 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y @@ -41,4 +42,8 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_OF_LIBFDT=y +CONFIG_RSA=y +CONFIG_FIT=y +CONFIG_SPL_OF_LIBFDT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack" diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig deleted file mode 100644 index d7f126e..0000000 --- a/configs/am335x_gp_evm_defconfig +++ /dev/null @@ -1,46 +0,0 @@ -CONFIG_ARM=y -CONFIG_TARGET_AM335X_EVM=y -CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" -CONFIG_SPL=y -CONFIG_SPL_STACK_R=y -CONFIG_FIT=y -CONFIG_SYS_EXTRA_OPTIONS="NAND" -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -CONFIG_CMD_ASKENV=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_OF_CONTROL=y -CONFIG_DM_MMC=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_DM_ETH=y -CONFIG_SYS_NS16550=y -CONFIG_TIMER=y -CONFIG_OMAP_TIMER=y -CONFIG_USB=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="Texas Instruments" -CONFIG_G_DNL_VENDOR_NUM=0x0451 -CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_RSA=y
As per mmc device tree binding documentation card detect gpio has to be active low signal. When a hardware is designed with active high card detect, gpio polarity has to be changed with cd-inverted dt property.
In AM335x the card detect gpio is designed as active low gpio. So correcting the dt card detect gpio definition.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- Changes since v1: - None
arch/arm/dts/am335x-bone-common.dtsi | 3 +-- arch/arm/dts/am335x-evm.dts | 2 +- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/am335x-bone-common.dtsi b/arch/arm/dts/am335x-bone-common.dtsi index a00c0cd..40a3c35 100644 --- a/arch/arm/dts/am335x-bone-common.dtsi +++ b/arch/arm/dts/am335x-bone-common.dtsi @@ -388,8 +388,7 @@ bus-width = <0x4>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; - cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; - cd-inverted; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; };
&aes { diff --git a/arch/arm/dts/am335x-evm.dts b/arch/arm/dts/am335x-evm.dts index c0bc2af..a6f20af 100644 --- a/arch/arm/dts/am335x-evm.dts +++ b/arch/arm/dts/am335x-evm.dts @@ -717,7 +717,7 @@ bus-width = <4>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; - cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; };
&mmc3 {
Add initial DTS support for AM335x-evm sk.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/am335x-evmsk.dts | 720 +++++++++++++++++++++++++++++++++++++ board/ti/am335x/board.c | 2 + configs/am335x_evm_defconfig | 2 +- include/dt-bindings/pinctrl/omap.h | 37 ++ 5 files changed, 762 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/am335x-evmsk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0ea7bbe..aa6ebfb 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -89,7 +89,8 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zc1751-xm015-dc1.dtb \ zynqmp-zc1751-xm016-dc2.dtb \ zynqmp-zc1751-xm019-dc5.dtb -dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb am335x-evm.dtb +dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb am335x-evm.dtb \ + am335x-evmsk.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb diff --git a/arch/arm/dts/am335x-evmsk.dts b/arch/arm/dts/am335x-evmsk.dts new file mode 100644 index 0000000..b3e9b61 --- /dev/null +++ b/arch/arm/dts/am335x-evmsk.dts @@ -0,0 +1,720 @@ +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/* + * AM335x Starter Kit + * http://www.ti.com/tool/tmdssk3358 + */ + +/dts-v1/; + +#include "am33xx.dtsi" +#include <dt-bindings/pwm/pwm.h> +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "TI AM335x EVM-SK"; + compatible = "ti,am335x-evmsk", "ti,am33xx"; + + chosen { + stdout-path = &uart0; + tick-timer = &timer2; + }; + + cpus { + cpu@0 { + cpu0-supply = <&vdd1_reg>; + }; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256 MB */ + }; + + vbat: fixedregulator@0 { + compatible = "regulator-fixed"; + regulator-name = "vbat"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-boot-on; + }; + + lis3_reg: fixedregulator@1 { + compatible = "regulator-fixed"; + regulator-name = "lis3_reg"; + regulator-boot-on; + }; + + wl12xx_vmmc: fixedregulator@2 { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_gpio>; + compatible = "regulator-fixed"; + regulator-name = "vwl1271"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio1 29 0>; + startup-delay-us = <70000>; + enable-active-high; + }; + + vtt_fixed: fixedregulator@3 { + compatible = "regulator-fixed"; + regulator-name = "vtt"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + gpio = <&gpio0 7 GPIO_ACTIVE_HIGH>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + }; + + leds { + pinctrl-names = "default"; + pinctrl-0 = <&user_leds_s0>; + + compatible = "gpio-leds"; + + led@1 { + label = "evmsk:green:usr0"; + gpios = <&gpio1 4 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + led@2 { + label = "evmsk:green:usr1"; + gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + led@3 { + label = "evmsk:green:mmc0"; + gpios = <&gpio1 6 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led@4 { + label = "evmsk:green:heartbeat"; + gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + }; + + gpio_buttons: gpio_buttons@0 { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + switch@1 { + label = "button0"; + linux,code = <0x100>; + gpios = <&gpio2 3 GPIO_ACTIVE_HIGH>; + }; + + switch@2 { + label = "button1"; + linux,code = <0x101>; + gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; + }; + + switch@3 { + label = "button2"; + linux,code = <0x102>; + gpios = <&gpio0 30 GPIO_ACTIVE_HIGH>; + wakeup-source; + }; + + switch@4 { + label = "button3"; + linux,code = <0x103>; + gpios = <&gpio2 5 GPIO_ACTIVE_HIGH>; + }; + }; + + backlight { + compatible = "pwm-backlight"; + pwms = <&ecap2 0 50000 PWM_POLARITY_INVERTED>; + brightness-levels = <0 58 61 66 75 90 125 170 255>; + default-brightness-level = <8>; + }; + + sound { + compatible = "simple-audio-card"; + simple-audio-card,name = "AM335x-EVMSK"; + simple-audio-card,widgets = + "Headphone", "Headphone Jack"; + simple-audio-card,routing = + "Headphone Jack", "HPLOUT", + "Headphone Jack", "HPROUT"; + simple-audio-card,format = "dsp_b"; + simple-audio-card,bitclock-master = <&sound_master>; + simple-audio-card,frame-master = <&sound_master>; + simple-audio-card,bitclock-inversion; + + simple-audio-card,cpu { + sound-dai = <&mcasp1>; + }; + + sound_master: simple-audio-card,codec { + sound-dai = <&tlv320aic3106>; + system-clock-frequency = <24000000>; + }; + }; + + panel { + compatible = "ti,tilcdc,panel"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&lcd_pins_default>; + pinctrl-1 = <&lcd_pins_sleep>; + status = "okay"; + panel-info { + ac-bias = <255>; + ac-bias-intrpt = <0>; + dma-burst-sz = <16>; + bpp = <32>; + fdd = <0x80>; + sync-edge = <0>; + sync-ctrl = <1>; + raster-order = <0>; + fifo-th = <0>; + }; + display-timings { + 480x272 { + hactive = <480>; + vactive = <272>; + hback-porch = <43>; + hfront-porch = <8>; + hsync-len = <4>; + vback-porch = <12>; + vfront-porch = <4>; + vsync-len = <10>; + clock-frequency = <9000000>; + hsync-active = <0>; + vsync-active = <0>; + }; + }; + }; +}; + +&am33xx_pinmux { + pinctrl-names = "default"; + pinctrl-0 = <&gpio_keys_s0 &clkout2_pin>; + + lcd_pins_default: lcd_pins_default { + pinctrl-single,pins = < + AM33XX_IOPAD(0x820, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad8.lcd_data23 */ + AM33XX_IOPAD(0x824, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad9.lcd_data22 */ + AM33XX_IOPAD(0x828, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad10.lcd_data21 */ + AM33XX_IOPAD(0x82c, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad11.lcd_data20 */ + AM33XX_IOPAD(0x830, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad12.lcd_data19 */ + AM33XX_IOPAD(0x834, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad13.lcd_data18 */ + AM33XX_IOPAD(0x838, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad14.lcd_data17 */ + AM33XX_IOPAD(0x83c, PIN_OUTPUT | MUX_MODE1) /* gpmc_ad15.lcd_data16 */ + AM33XX_IOPAD(0x8a0, PIN_OUTPUT | MUX_MODE0) /* lcd_data0.lcd_data0 */ + AM33XX_IOPAD(0x8a4, PIN_OUTPUT | MUX_MODE0) /* lcd_data1.lcd_data1 */ + AM33XX_IOPAD(0x8a8, PIN_OUTPUT | MUX_MODE0) /* lcd_data2.lcd_data2 */ + AM33XX_IOPAD(0x8ac, PIN_OUTPUT | MUX_MODE0) /* lcd_data3.lcd_data3 */ + AM33XX_IOPAD(0x8b0, PIN_OUTPUT | MUX_MODE0) /* lcd_data4.lcd_data4 */ + AM33XX_IOPAD(0x8b4, PIN_OUTPUT | MUX_MODE0) /* lcd_data5.lcd_data5 */ + AM33XX_IOPAD(0x8b8, PIN_OUTPUT | MUX_MODE0) /* lcd_data6.lcd_data6 */ + AM33XX_IOPAD(0x8bc, PIN_OUTPUT | MUX_MODE0) /* lcd_data7.lcd_data7 */ + AM33XX_IOPAD(0x8c0, PIN_OUTPUT | MUX_MODE0) /* lcd_data8.lcd_data8 */ + AM33XX_IOPAD(0x8c4, PIN_OUTPUT | MUX_MODE0) /* lcd_data9.lcd_data9 */ + AM33XX_IOPAD(0x8c8, PIN_OUTPUT | MUX_MODE0) /* lcd_data10.lcd_data10 */ + AM33XX_IOPAD(0x8cc, PIN_OUTPUT | MUX_MODE0) /* lcd_data11.lcd_data11 */ + AM33XX_IOPAD(0x8d0, PIN_OUTPUT | MUX_MODE0) /* lcd_data12.lcd_data12 */ + AM33XX_IOPAD(0x8d4, PIN_OUTPUT | MUX_MODE0) /* lcd_data13.lcd_data13 */ + AM33XX_IOPAD(0x8d8, PIN_OUTPUT | MUX_MODE0) /* lcd_data14.lcd_data14 */ + AM33XX_IOPAD(0x8dc, PIN_OUTPUT | MUX_MODE0) /* lcd_data15.lcd_data15 */ + AM33XX_IOPAD(0x8e0, PIN_OUTPUT | MUX_MODE0) /* lcd_vsync.lcd_vsync */ + AM33XX_IOPAD(0x8e4, PIN_OUTPUT | MUX_MODE0) /* lcd_hsync.lcd_hsync */ + AM33XX_IOPAD(0x8e8, PIN_OUTPUT | MUX_MODE0) /* lcd_pclk.lcd_pclk */ + AM33XX_IOPAD(0x8ec, PIN_OUTPUT | MUX_MODE0) /* lcd_ac_bias_en.lcd_ac_bias_en */ + >; + }; + + lcd_pins_sleep: lcd_pins_sleep { + pinctrl-single,pins = < + AM33XX_IOPAD(0x820, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad8.lcd_data23 */ + AM33XX_IOPAD(0x824, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad9.lcd_data22 */ + AM33XX_IOPAD(0x828, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad10.lcd_data21 */ + AM33XX_IOPAD(0x82c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad11.lcd_data20 */ + AM33XX_IOPAD(0x830, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad12.lcd_data19 */ + AM33XX_IOPAD(0x834, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad13.lcd_data18 */ + AM33XX_IOPAD(0x838, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad14.lcd_data17 */ + AM33XX_IOPAD(0x83c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad15.lcd_data16 */ + AM33XX_IOPAD(0x8a0, PULL_DISABLE | MUX_MODE7) /* lcd_data0.lcd_data0 */ + AM33XX_IOPAD(0x8a4, PULL_DISABLE | MUX_MODE7) /* lcd_data1.lcd_data1 */ + AM33XX_IOPAD(0x8a8, PULL_DISABLE | MUX_MODE7) /* lcd_data2.lcd_data2 */ + AM33XX_IOPAD(0x8ac, PULL_DISABLE | MUX_MODE7) /* lcd_data3.lcd_data3 */ + AM33XX_IOPAD(0x8b0, PULL_DISABLE | MUX_MODE7) /* lcd_data4.lcd_data4 */ + AM33XX_IOPAD(0x8b4, PULL_DISABLE | MUX_MODE7) /* lcd_data5.lcd_data5 */ + AM33XX_IOPAD(0x8b8, PULL_DISABLE | MUX_MODE7) /* lcd_data6.lcd_data6 */ + AM33XX_IOPAD(0x8bc, PULL_DISABLE | MUX_MODE7) /* lcd_data7.lcd_data7 */ + AM33XX_IOPAD(0x8c0, PULL_DISABLE | MUX_MODE7) /* lcd_data8.lcd_data8 */ + AM33XX_IOPAD(0x8c4, PULL_DISABLE | MUX_MODE7) /* lcd_data9.lcd_data9 */ + AM33XX_IOPAD(0x8c8, PULL_DISABLE | MUX_MODE7) /* lcd_data10.lcd_data10 */ + AM33XX_IOPAD(0x8cc, PULL_DISABLE | MUX_MODE7) /* lcd_data11.lcd_data11 */ + AM33XX_IOPAD(0x8d0, PULL_DISABLE | MUX_MODE7) /* lcd_data12.lcd_data12 */ + AM33XX_IOPAD(0x8d4, PULL_DISABLE | MUX_MODE7) /* lcd_data13.lcd_data13 */ + AM33XX_IOPAD(0x8d8, PULL_DISABLE | MUX_MODE7) /* lcd_data14.lcd_data14 */ + AM33XX_IOPAD(0x8dc, PULL_DISABLE | MUX_MODE7) /* lcd_data15.lcd_data15 */ + AM33XX_IOPAD(0x8e0, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_vsync.lcd_vsync */ + AM33XX_IOPAD(0x8e4, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_hsync.lcd_hsync */ + AM33XX_IOPAD(0x8e8, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_pclk.lcd_pclk */ + AM33XX_IOPAD(0x8ec, PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_ac_bias_en.lcd_ac_bias_en */ + >; + }; + + + user_leds_s0: user_leds_s0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x810, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */ + AM33XX_IOPAD(0x814, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */ + AM33XX_IOPAD(0x818, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */ + AM33XX_IOPAD(0x81c, PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */ + >; + }; + + gpio_keys_s0: gpio_keys_s0 { + pinctrl-single,pins = < + AM33XX_IOPAD(0x894, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_oen_ren.gpio2_3 */ + AM33XX_IOPAD(0x890, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_advn_ale.gpio2_2 */ + AM33XX_IOPAD(0x870, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wait0.gpio0_30 */ + AM33XX_IOPAD(0x89c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ben0_cle.gpio2_5 */ + >; + }; + + i2c0_pins: pinmux_i2c0_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda */ + AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl */ + >; + }; + + uart0_pins: pinmux_uart0_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */ + AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */ + >; + }; + + clkout2_pin: pinmux_clkout2_pin { + pinctrl-single,pins = < + AM33XX_IOPAD(0x9b4, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* xdma_event_intr1.clkout2 */ + >; + }; + + ecap2_pins: backlight_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x99c, MUX_MODE4) /* mcasp0_ahclkr.ecap2_in_pwm2_out */ + >; + }; + + cpsw_default: cpsw_default { + pinctrl-single,pins = < + /* Slave 1 */ + AM33XX_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_tctl */ + AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rctl */ + AM33XX_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd3.rgmii1_td3 */ + AM33XX_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd2.rgmii1_td2 */ + AM33XX_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_td1 */ + AM33XX_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_td0 */ + AM33XX_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rgmii1_tclk */ + AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rgmii1_rclk */ + AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd3.rgmii1_rd3 */ + AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd2.rgmii1_rd2 */ + AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 */ + AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 */ + + /* Slave 2 */ + AM33XX_IOPAD(0x840, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a0.rgmii2_tctl */ + AM33XX_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a1.rgmii2_rctl */ + AM33XX_IOPAD(0x848, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a2.rgmii2_td3 */ + AM33XX_IOPAD(0x84c, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a3.rgmii2_td2 */ + AM33XX_IOPAD(0x850, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a4.rgmii2_td1 */ + AM33XX_IOPAD(0x854, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a5.rgmii2_td0 */ + AM33XX_IOPAD(0x858, PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* gpmc_a6.rgmii2_tclk */ + AM33XX_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a7.rgmii2_rclk */ + AM33XX_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a8.rgmii2_rd3 */ + AM33XX_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a9.rgmii2_rd2 */ + AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a10.rgmii2_rd1 */ + AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE2) /* gpmc_a11.rgmii2_rd0 */ + >; + }; + + cpsw_sleep: cpsw_sleep { + pinctrl-single,pins = < + /* Slave 1 reset value */ + AM33XX_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7) + + /* Slave 2 reset value*/ + AM33XX_IOPAD(0x840, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x848, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x84c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x850, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE7) + >; + }; + + davinci_mdio_default: davinci_mdio_default { + pinctrl-single,pins = < + /* MDIO */ + AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ + AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ + >; + }; + + davinci_mdio_sleep: davinci_mdio_sleep { + pinctrl-single,pins = < + /* MDIO reset value */ + AM33XX_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) + >; + }; + + mmc1_pins: pinmux_mmc1_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */ + >; + }; + + mcasp1_pins: mcasp1_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx */ + AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx */ + AM33XX_IOPAD(0x908, PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 */ + AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 */ + >; + }; + + mcasp1_pins_sleep: mcasp1_pins_sleep { + pinctrl-single,pins = < + AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x908, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE7) + >; + }; + + mmc2_pins: pinmux_mmc2_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x874, PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_31 */ + AM33XX_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ + AM33XX_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ + AM33XX_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */ + AM33XX_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */ + AM33XX_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */ + AM33XX_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */ + >; + }; + + wl12xx_gpio: pinmux_wl12xx_gpio { + pinctrl-single,pins = < + AM33XX_IOPAD(0x87c, PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_csn0.gpio1_29 */ + >; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + + status = "okay"; + clock-frequency = <400000>; + + tps: tps@2d { + reg = <0x2d>; + }; + + lis331dlh: lis331dlh@18 { + compatible = "st,lis331dlh", "st,lis3lv02d"; + reg = <0x18>; + Vdd-supply = <&lis3_reg>; + Vdd_IO-supply = <&lis3_reg>; + + st,click-single-x; + st,click-single-y; + st,click-single-z; + st,click-thresh-x = <10>; + st,click-thresh-y = <10>; + st,click-thresh-z = <10>; + st,irq1-click; + st,irq2-click; + st,wakeup-x-lo; + st,wakeup-x-hi; + st,wakeup-y-lo; + st,wakeup-y-hi; + st,wakeup-z-lo; + st,wakeup-z-hi; + st,min-limit-x = <120>; + st,min-limit-y = <120>; + st,min-limit-z = <140>; + st,max-limit-x = <550>; + st,max-limit-y = <550>; + st,max-limit-z = <750>; + }; + + tlv320aic3106: tlv320aic3106@1b { + #sound-dai-cells = <0>; + compatible = "ti,tlv320aic3106"; + reg = <0x1b>; + status = "okay"; + + /* Regulators */ + AVDD-supply = <&vaux2_reg>; + IOVDD-supply = <&vaux2_reg>; + DRVDD-supply = <&vaux2_reg>; + DVDD-supply = <&vbat>; + }; +}; + +&usb { + status = "okay"; +}; + +&usb_ctrl_mod { + status = "okay"; +}; + +&usb0_phy { + status = "okay"; +}; + +&usb1_phy { + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&usb1 { + status = "okay"; + dr_mode = "host"; +}; + +&cppi41dma { + status = "okay"; +}; + +&epwmss2 { + status = "okay"; + + ecap2: ecap@48304100 { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&ecap2_pins>; + }; +}; + +#include "tps65910.dtsi" + +&tps { + vcc1-supply = <&vbat>; + vcc2-supply = <&vbat>; + vcc3-supply = <&vbat>; + vcc4-supply = <&vbat>; + vcc5-supply = <&vbat>; + vcc6-supply = <&vbat>; + vcc7-supply = <&vbat>; + vccio-supply = <&vbat>; + + regulators { + vrtc_reg: regulator@0 { + regulator-always-on; + }; + + vio_reg: regulator@1 { + regulator-always-on; + }; + + vdd1_reg: regulator@2 { + /* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */ + regulator-name = "vdd_mpu"; + regulator-min-microvolt = <912500>; + regulator-max-microvolt = <1312500>; + regulator-boot-on; + regulator-always-on; + }; + + vdd2_reg: regulator@3 { + /* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */ + regulator-name = "vdd_core"; + regulator-min-microvolt = <912500>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd3_reg: regulator@4 { + regulator-always-on; + }; + + vdig1_reg: regulator@5 { + regulator-always-on; + }; + + vdig2_reg: regulator@6 { + regulator-always-on; + }; + + vpll_reg: regulator@7 { + regulator-always-on; + }; + + vdac_reg: regulator@8 { + regulator-always-on; + }; + + vaux1_reg: regulator@9 { + regulator-always-on; + }; + + vaux2_reg: regulator@10 { + regulator-always-on; + }; + + vaux33_reg: regulator@11 { + regulator-always-on; + }; + + vmmc_reg: regulator@12 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; +}; + +&mac { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&cpsw_default>; + pinctrl-1 = <&cpsw_sleep>; + dual_emac = <1>; + status = "okay"; +}; + +&davinci_mdio { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&davinci_mdio_default>; + pinctrl-1 = <&davinci_mdio_sleep>; + status = "okay"; +}; + +&cpsw_emac0 { + phy_id = <&davinci_mdio>, <0>; + phy-mode = "rgmii-txid"; + dual_emac_res_vlan = <1>; +}; + +&cpsw_emac1 { + phy_id = <&davinci_mdio>, <1>; + phy-mode = "rgmii-txid"; + dual_emac_res_vlan = <2>; +}; + +&mmc1 { + status = "okay"; + vmmc-supply = <&vmmc_reg>; + bus-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; +}; + +&sham { + status = "okay"; +}; + +&aes { + status = "okay"; +}; + +&gpio0 { + ti,no-reset-on-init; +}; + +&mmc2 { + status = "okay"; + vmmc-supply = <&wl12xx_vmmc>; + ti,non-removable; + bus-width = <4>; + cap-power-off-card; + pinctrl-names = "default"; + pinctrl-0 = <&mmc2_pins>; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1271"; + reg = <2>; + interrupt-parent = <&gpio0>; + interrupts = <31 IRQ_TYPE_LEVEL_HIGH>; /* gpio 31 */ + ref-clock-frequency = <38400000>; + }; +}; + +&mcasp1 { + #sound-dai-cells = <0>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&mcasp1_pins>; + pinctrl-1 = <&mcasp1_pins_sleep>; + + status = "okay"; + + op-mode = <0>; /* MCASP_IIS_MODE */ + tdm-slots = <2>; + /* 4 serializers */ + serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ + 0 0 1 2 + >; + tx-num-evt = <32>; + rx-num-evt = <32>; +}; + +&tscadc { + status = "okay"; + tsc { + ti,wires = <4>; + ti,x-plate-resistance = <200>; + ti,coordinate-readouts = <5>; + ti,wire-config = <0x00 0x11 0x22 0x33>; + }; +}; + +&lcdc { + status = "okay"; +}; diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index a3d1e2b..89b12a5 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -642,6 +642,8 @@ int board_fit_config_name_match(const char *name) return 0; else if (board_is_bone_lt() && !strcmp(name, "am335x-boneblack")) return 0; + else if (board_is_evm_sk() && !strcmp(name, "am335x-evmsk")) + return 0; else return -1; } diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 7be5479..bd04a88 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -46,4 +46,4 @@ CONFIG_RSA=y CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack" +CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk" diff --git a/include/dt-bindings/pinctrl/omap.h b/include/dt-bindings/pinctrl/omap.h index 1dd7636..672a136 100644 --- a/include/dt-bindings/pinctrl/omap.h +++ b/include/dt-bindings/pinctrl/omap.h @@ -53,5 +53,42 @@ #define PIN_OFF_INPUT_PULLDOWN (OFF_EN | OFF_PULL_EN) #define PIN_OFF_WAKEUPENABLE WAKEUP_EN
+/* + * Macros to allow using the absolute physical address instead of the + * padconf registers instead of the offset from padconf base. + */ +#define OMAP_IOPAD_OFFSET(pa, offset) (((pa) & 0xffff) - (offset)) + +#define OMAP2420_CORE_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0030) (val) +#define OMAP2430_CORE_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2030) (val) +#define OMAP3_CORE1_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2030) (val) +#define OMAP3430_CORE2_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x25d8) (val) +#define OMAP3630_CORE2_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x25a0) (val) +#define OMAP3_WKUP_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x2a00) (val) +#define DM814X_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) +#define DM816X_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) +#define AM33XX_IOPAD(pa, val) OMAP_IOPAD_OFFSET((pa), 0x0800) (val) + +/* + * Macros to allow using the offset from the padconf physical address + * instead of the offset from padconf base. + */ +#define OMAP_PADCONF_OFFSET(offset, base_offset) ((offset) - (base_offset)) + +#define OMAP4_IOPAD(offset, val) OMAP_PADCONF_OFFSET((offset), 0x0040) (val) +#define OMAP5_IOPAD(offset, val) OMAP_PADCONF_OFFSET((offset), 0x0040) (val) + +/* + * Define some commonly used pins configured by the boards. + * Note that some boards use alternative pins, so check + * the schematics before using these. + */ +#define OMAP3_UART1_RX 0x152 +#define OMAP3_UART2_RX 0x14a +#define OMAP3_UART3_RX 0x16e +#define OMAP4_UART2_RX 0xdc +#define OMAP4_UART3_RX 0x104 +#define OMAP4_UART4_RX 0x11c + #endif
Add initial DTS support for AM335x-BBG
arch/arm/dts/Makefile | 3 ++- arch/arm/dts/am335x-bonegreen.dts | 57 +++++++++++++++++++++++++++++++++++++++ board/ti/am335x/board.c | 2 ++ configs/am335x_evm_defconfig | 2 +- 4 files changed, 62 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/am335x-bonegreen.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index aa6ebfb..800750b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -90,7 +90,8 @@ dtb-$(CONFIG_ARCH_ZYNQMP) += \ zynqmp-zc1751-xm016-dc2.dtb \ zynqmp-zc1751-xm019-dc5.dtb dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb am335x-evm.dtb \ - am335x-evmsk.dtb + am335x-evmsk.dtb \ + am335x-bonegreen.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb diff --git a/arch/arm/dts/am335x-bonegreen.dts b/arch/arm/dts/am335x-bonegreen.dts new file mode 100644 index 0000000..9c59da9 --- /dev/null +++ b/arch/arm/dts/am335x-bonegreen.dts @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "am33xx.dtsi" +#include "am335x-bone-common.dtsi" + +/ { + model = "TI AM335x BeagleBone Green"; + compatible = "ti,am335x-bone-green", "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; + chosen { + stdout-path = &uart0; + tick-timer = &timer2; + }; +}; + +&ldo3_reg { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; +}; + +&mmc1 { + vmmc-supply = <&vmmcsd_fixed>; +}; + +&mmc2 { + vmmc-supply = <&vmmcsd_fixed>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_pins>; + bus-width = <8>; + status = "okay"; +}; + +&am33xx_pinmux { + uart2_pins: uart2_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x950, PIN_INPUT | MUX_MODE1) /* spi0_sclk.uart2_rxd */ + AM33XX_IOPAD(0x954, PIN_OUTPUT | MUX_MODE1) /* spi0_d0.uart2_txd */ + >; + }; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + status = "okay"; +}; + +&rtc { + system-power-controller; +}; diff --git a/board/ti/am335x/board.c b/board/ti/am335x/board.c index 89b12a5..579b4ef 100644 --- a/board/ti/am335x/board.c +++ b/board/ti/am335x/board.c @@ -644,6 +644,8 @@ int board_fit_config_name_match(const char *name) return 0; else if (board_is_evm_sk() && !strcmp(name, "am335x-evmsk")) return 0; + else if (board_is_bbg1() && !strcmp(name, "am335x-bonegreen")) + return 0; else return -1; } diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index bd04a88..5f917d6 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -46,4 +46,4 @@ CONFIG_RSA=y CONFIG_FIT=y CONFIG_SPL_OF_LIBFDT=y CONFIG_SPL_LOAD_FIT=y -CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk" +CONFIG_OF_LIST="am335x-evm am335x-bone am335x-boneblack am335x-evmsk am335x-bonegreen"
Re-org env sections so that we can fall back to env is in FAT on SD card, for broader board compatibility
Signed-off-by: Tom Rini trini@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- Changes since v1: - None
include/configs/am335x_evm.h | 40 +++++++++++++++++++++------------------- 1 file changed, 21 insertions(+), 19 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 16935a1..dfd00de 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -249,11 +249,6 @@ "8m(NAND.kernel)," \ "-(NAND.file-system)" #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 -#undef CONFIG_ENV_IS_NOWHERE -#define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_OFFSET 0x001c0000 -#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 -#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE /* NAND: SPL related configs */ #ifdef CONFIG_SPL_NAND_SUPPORT #define CONFIG_SPL_NAND_AM33XX_BCH @@ -415,7 +410,6 @@ "128k(u-boot-env2),3464k(kernel)," \ "-(rootfs)" #elif defined(CONFIG_EMMC_BOOT) -#undef CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SPL_ENV_SUPPORT #define CONFIG_SYS_MMC_ENV_DEV 1 @@ -423,6 +417,27 @@ #define CONFIG_ENV_OFFSET 0x0 #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#elif defined(CONFIG_NOR_BOOT) +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ +#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ +#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ +#define MTDIDS_DEFAULT "nor0=physmap-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ + "512k(u-boot)," \ + "128k(u-boot-env1)," \ + "128k(u-boot-env2)," \ + "4m(kernel),-(rootfs)" +#elif defined(CONFIG_ENV_IS_IN_NAND) +#define CONFIG_ENV_OFFSET 0x001c0000 +#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 +#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#elif !defined(CONFIG_ENV_IS_NOWHERE) +/* Not NAND, SPI, NOR or eMMC env, so put ENV in a file on FAT */ +#define CONFIG_ENV_IS_IN_FAT +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_DEVICE_AND_PART "0:1" +#define FAT_ENV_FILE "uboot.env" #endif
/* SPI flash. */ @@ -458,19 +473,6 @@ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_SIZE 0x01000000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -/* Reduce SPL size by removing unlikey targets */ -#ifdef CONFIG_NOR_BOOT -#define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_SECT_SIZE (128 << 10) /* 128 KiB */ -#define CONFIG_ENV_OFFSET (512 << 10) /* 512 KiB */ -#define CONFIG_ENV_OFFSET_REDUND (768 << 10) /* 768 KiB */ -#define MTDIDS_DEFAULT "nor0=physmap-flash.0" -#define MTDPARTS_DEFAULT "mtdparts=physmap-flash.0:" \ - "512k(u-boot)," \ - "128k(u-boot-env1)," \ - "128k(u-boot-env2)," \ - "4m(kernel),-(rootfs)" -#endif #endif /* NOR support */
#endif /* ! __CONFIG_AM335X_EVM_H */
Lokesh Vutla
