[U-Boot] [PATCH v3] pico-imx7d: Increase the CONFIG_ENV_OFFSET size
U-Boot binary has grown in such a way that it goes beyond the reserved area for the environment variables.
Running "saveenv" causes U-Boot to hang because of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET size.
Also, in order to prevent this same problem in the future, use CONFIG_BOARD_SIZE_LIMIT, which will detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT does not accept math expressions, so declare CONFIG_ENV_OFFSET with its direct value instead.
Signed-off-by: Fabio Estevam festevam@gmail.com --- Changes since v2: - Use CONFIG_BOARD_SIZE_LIMIT (Stefan)
include/configs/pico-imx7d.h | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 2bc42a0..25b1a51 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -134,7 +134,10 @@ /* FLASH and environment organization */ #define CONFIG_ENV_SIZE SZ_8K
-#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#define CONFIG_ENV_OFFSET 786432 +/* Detect overlap between U-Boot image and environment area in build-time */ +#define CONFIG_BOARD_SIZE_LIMIT CONFIG_ENV_OFFSET + #define CONFIG_SYS_FSL_USDHC_NUM 2
#define CONFIG_SYS_MMC_ENV_DEV 0
Fabio Estevam
