[U-Boot] [PATCH v2 0/3] net: phy: allow disabling SmartEEE for Atheros PHYs
Changes in v2: * Removed patch 1/2 (promote phy_{read,write}_mmd_indirect from ti.c to generic code) * Adapted to PHY API changes introduced by Carlo Caione * Cleaned up Atheros PHY driver to remove duplicated code and use macros where possible
Vladimir Oltean (3): net: phy: ar803x: Use phy_read_mmd and phy_write_mmd functions net: phy: ar803x: Address packet drops at low traffic rate due to SmartEEE feature net: phy: ar803x: Use common functions for RGMII internal delays
drivers/net/phy/Kconfig | 21 +++++++++ drivers/net/phy/atheros.c | 110 +++++++++++++++++++++++++++++++--------------- 2 files changed, 95 insertions(+), 36 deletions(-)
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com --- Changes in v2: * Patch added in this version.
drivers/net/phy/atheros.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 3783d15..b4066e3 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -57,11 +57,9 @@ static int ar8035_config(struct phy_device *phydev) { int regval;
- phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x0007); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); - phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); - regval = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); - phy_write(phydev, MDIO_DEVAD_NONE, 0xe, (regval|0x0018)); + /* CLK_25M output clock select: 125 MHz */ + regval = phy_read_mmd(phydev, MDIO_MMD_AN, 0x8016); + phy_write_mmd(phydev, MDIO_MMD_AN, 0x8016, regval | 0x0018);
phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); regval = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e);
On Wed, Jan 23, 2019 at 5:46 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Changes in v2:
- Patch added in this version.
I think I see how the old code accomplished the same thing. It was woefully undocumented. Can you improve on the magic 0x18 number? What about 0x8016? Is that a register whose name you know and can assign a constant?
-- 2.7.4
Changes in v2:
Register MMD7 8016 has no name in the documentation that I can see. It is simply referred to as that. I'd rather keep it like this rather than create confusion by making up a name for it.
-Vladimir
On Thu, Jan 24, 2019 at 6:35 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Changes in v2:
OK
-Vladimir _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
* According to the AR8031 and AR8035 datasheets, smartEEE mode (active by default) makes the PHY enter sleep after a configurable idle time. It does this autonomously, without LPI (Low Power Idle) signals coming from MAC. AR8021 does not appear to support this. * This patch allows disabling the SmartEEE feature of above PHYs. * Tested with ping (default of 1 second interval) over back-to-back RGMII between 2 boards having AR8035 at both ends: - Without SmartEEE: 225 packets transmitted, 145 received, 35% packet loss, time 229334ms - With SmartEEE: 144 packets transmitted, 144 received, 0% packet loss, time 146378ms
Signed-off-by: Vladimir Oltean vladimir.oltean@nxp.com Acked-by: Joe Hershberger joe.hershberger@ni.com --- Changes in v2: * Adapted to use phy_read_mmd and phy_write_mmd functions.
drivers/net/phy/Kconfig | 21 +++++++++++++++++++++ drivers/net/phy/atheros.c | 26 ++++++++++++++++++++++++++ 2 files changed, 47 insertions(+)
diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 3dc0822..6abe8c5 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -94,6 +94,27 @@ config PHY_AQUANTIA_FW_NAME config PHY_ATHEROS bool "Atheros Ethernet PHYs support"
+config PHY_ATHEROS_SMART_EEE + depends on PHY_ATHEROS + default y + tristate "SmartEEE feature for Atheros PHYs" + help + Enables the Atheros SmartEEE feature (not IEEE 802.3az). When 2 PHYs + which support this feature are connected back-to-back, they may + negotiate a low-power sleep mode autonomously, without the Ethernet + controller's knowledge. This setting may cause issues under 2 known + circumstances (both noticed at low traffic rates): + - If the voltage rails on the PHY are unstable, then the PHY can + actually reset as it enters the low power state. This means that + the frames it is supposed to buffer until it wakes up are going + to be dropped instead. + - If 1588/PTP synchronization is the only traffic source over this + PHY, the delays caused by the sleep/wakeup time are going to add + to the synchronization error between the master and the slave. + Default y, which means that the PHY's out-of-reset state is not + changed (SmartEEE active). To work around the issues described + above, change to n. + config PHY_BROADCOM bool "Broadcom Ethernet PHYs support"
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index b4066e3..750c11b 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -5,6 +5,7 @@ * Copyright 2011, 2013 Freescale Semiconductor, Inc. * author Andy Fleming */ +#include <linux/bitops.h> #include <common.h> #include <phy.h>
@@ -17,6 +18,21 @@ #define AR803x_DEBUG_REG_0 0x0 #define AR803x_RGMII_RX_CLK_DLY 0x8000
+#define AR803X_LPI_EN BIT(8) + +static void ar803x_enable_smart_eee(struct phy_device *phydev, bool on) +{ + int regval; + + /* 5.1.11 Smart_eee control3 */ + regval = phy_read_mmd(phydev, MDIO_MMD_PCS, 0x805D); + if (on) + regval |= AR803X_LPI_EN; + else + regval &= ~AR803X_LPI_EN; + phy_write_mmd(phydev, MDIO_MMD_PCS, 0x805D, regval); +} + static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x00, 0x1200); @@ -29,6 +45,11 @@ static int ar8021_config(struct phy_device *phydev)
static int ar8031_config(struct phy_device *phydev) { +#ifdef CONFIG_PHY_ATHEROS_SMART_EEE + ar803x_enable_smart_eee(phydev, true); +#else + ar803x_enable_smart_eee(phydev, false); +#endif if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, @@ -57,6 +78,11 @@ static int ar8035_config(struct phy_device *phydev) { int regval;
+#ifdef CONFIG_PHY_ATHEROS_SMART_EEE + ar803x_enable_smart_eee(phydev, true); +#else + ar803x_enable_smart_eee(phydev, false); +#endif /* CLK_25M output clock select: 125 MHz */ regval = phy_read_mmd(phydev, MDIO_MMD_AN, 0x8016); phy_write_mmd(phydev, MDIO_MMD_AN, 0x8016, regval | 0x0018);
On Wed, Jan 23, 2019 at 5:45 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
- According to the AR8031 and AR8035 datasheets, smartEEE mode (active by default) makes the PHY enter sleep after a configurable idle time. It does this autonomously, without LPI (Low Power Idle) signals coming from MAC. AR8021 does not appear to support this.
- This patch allows disabling the SmartEEE feature of above PHYs.
- Tested with ping (default of 1 second interval) over back-to-back RGMII between 2 boards having AR8035 at both ends:
- Without SmartEEE:
- With SmartEEE:
Changes in v2:
- Adapted to use phy_read_mmd and phy_write_mmd functions.
default y
help
above, change to n.
- Copyright 2011, 2013 Freescale Semiconductor, Inc.
- author Andy Fleming
int regval;
Can you add a #define for this or comment where it comes from / what it means in a data sheet or both?
if (on)
else
+#else
+#else
+#endif /* CLK_25M output clock select: 125 MHz */ regval = phy_read_mmd(phydev, MDIO_MMD_AN, 0x8016); phy_write_mmd(phydev, MDIO_MMD_AN, 0x8016, regval | 0x0018); -- 2.7.4
drivers/net/phy/atheros.c | 76 ++++++++++++++++++++++++++++------------------- 1 file changed, 45 insertions(+), 31 deletions(-)
diff --git a/drivers/net/phy/atheros.c b/drivers/net/phy/atheros.c index 750c11b..9eb40f7 100644 --- a/drivers/net/phy/atheros.c +++ b/drivers/net/phy/atheros.c @@ -13,10 +13,10 @@ #define AR803x_PHY_DEBUG_DATA_REG 0x1e
#define AR803x_DEBUG_REG_5 0x5 -#define AR803x_RGMII_TX_CLK_DLY 0x100 +#define AR803x_RGMII_TX_CLK_DLY BIT(8)
#define AR803x_DEBUG_REG_0 0x0 -#define AR803x_RGMII_RX_CLK_DLY 0x8000 +#define AR803x_RGMII_RX_CLK_DLY BIT(15)
@@ -33,11 +33,40 @@ static void ar803x_enable_smart_eee(struct phy_device *phydev, bool on) phy_write_mmd(phydev, MDIO_MMD_PCS, 0x805D, regval); }
+static void ar803x_enable_rx_delay(struct phy_device *phydev, bool on) +{ + int regval; + + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_0); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + if (on) + regval |= AR803x_RGMII_RX_CLK_DLY; + else + regval &= ~AR803x_RGMII_RX_CLK_DLY; + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); +} + +static void ar803x_enable_tx_delay(struct phy_device *phydev, bool on) +{ + int regval; + + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + if (on) + regval |= AR803x_RGMII_TX_CLK_DLY; + else + regval &= ~AR803x_RGMII_TX_CLK_DLY; + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, regval); +} + static int ar8021_config(struct phy_device *phydev) { phy_write(phydev, MDIO_DEVAD_NONE, 0x00, 0x1200); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x3D47); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, + AR803x_DEBUG_REG_5); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, 0x3D47);
phydev->supported = phydev->drv->features; return 0; @@ -51,20 +80,12 @@ static int ar8031_config(struct phy_device *phydev) ar803x_enable_smart_eee(phydev, false); #endif if (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID || - phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_5); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_TX_CLK_DLY); - } + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + ar803x_enable_tx_delay(phydev, true);
if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID || - phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) { - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, - AR803x_DEBUG_REG_0); - phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, - AR803x_RGMII_RX_CLK_DLY); - } + phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) + ar803x_enable_rx_delay(phydev, true);
@@ -87,25 +108,18 @@ static int ar8035_config(struct phy_device *phydev) regval = phy_read_mmd(phydev, MDIO_MMD_AN, 0x8016); phy_write_mmd(phydev, MDIO_MMD_AN, 0x8016, regval | 0x0018);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); - regval = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); - phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, (regval|0x0100)); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_ADDR_REG, 0x05); + regval = phy_read(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG); + phy_write(phydev, MDIO_DEVAD_NONE, AR803x_PHY_DEBUG_DATA_REG, + regval | 0x0100);
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) { - /* select debug reg 5 */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x5); - /* enable tx delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x0100); - } + (phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID)) + ar803x_enable_tx_delay(phydev, true);
if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) || - (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) { - /* select debug reg 0 */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1D, 0x0); - /* enable rx delay */ - phy_write(phydev, MDIO_DEVAD_NONE, 0x1E, 0x8000); - } + (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID)) + ar803x_enable_rx_delay(phydev, true);
On Wed, Jan 23, 2019 at 5:47 PM Vladimir Oltean vladimir.oltean@nxp.com wrote:
Changes in v2:
int regval;
if (on)
else
int regval;
if (on)
else
While this patch is an improvement on the former state, can we add a comment on the magic number or define a constant?
ar803x_enable_tx_delay(phydev, true); if (phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID ||
ar803x_enable_rx_delay(phydev, true); phydev->supported = phydev->drv->features;
What is 0x5?
regval | 0x0100);
What is 0x100?
ar803x_enable_tx_delay(phydev, true); if ((phydev->interface == PHY_INTERFACE_MODE_RGMII_ID) ||
-- 2.7.4
I have no idea what 0x3D47 is, sorry. I couldn't find any public AR8021 register map either. For the other PHYs in this family, debug register 5 holds TX_CLK_DELAY at bit 8. No idea of the implications of writing the other bits. Will act on the rest of your comments.
-Vladimir
OK, thanks.
Joe Hershberger
Vladimir Oltean
