[U-Boot] [PATCH v2 00/99] ram: rk3399: Add LPDDR4 support
This is the v2 set for supporting LPDDR4 with associated features, wrt to previous series[1].
Thanks to - YouMin Chen - Akash Gajjar - Kever Yang for supporting all the help on this work.
On summary this series support - Code warning and fixes - rank detection, this would required to probe single channel sdram configured in NanoPI-NEO4 - LPDDR4 support, tested in Rockpro64 and Rock-PI-4
Changes for v2: - handle LPDDR4 code as part of CONFIG_RAM_RK3399_LPDDR4 - support data_training and set_rate via sdram_rk3399_ops - add proper sys_reg_enc macros - add new patch to rename variable sdram_params with params - fix few commit messages
patch 0001 - 0034: fix code warnings, prints, new macros
patch 0035 - 0052: rank detection, sdram debug code
patch 0053: use DDR3-1800 on NanoPI-NEO4
patch 0054 - 0094: lpddr4 support
patch 0095: enable lpddr4 in Rockpro64
patch 0096: enable lpddr4 in Rock-PI-4
patch 0097: LPDDR4-100 timings
patch 0098: Use LPDDR4-100 on Rockpro64
patch 0099: Use LPDDR4-100 on Rock-PI 4
Size (increased to ~3KiB ): - Puma RK3399 (u-boot-spl-dtb.bin): before: 115644 after: 118744 - NanoPI M4 (u-boot-tpl-dtb.bin) before: 41873 after: 44909
Travis-CI: https://travis-ci.org/openedev/u-boot-amarula/builds/546597944
Repo: https://github.com/openedev/u-boot-amarula/tree/rk3399-lpddr4
[1] https://patchwork.ozlabs.org/cover/1113893/
Any inputs? Jagan.
Jagan Teki (99): ram: rk3399: Fix code warnings ram: rk3399: Add space between string with format specifier ram: rk3399: Add proper spaces in code ram: rk3399: s/sdram_params/params ram: rk3399: Handle data training return types ram: rk3399: Order include files ram: rk3399: Move macro after include files ram: rk3399: Clear PI_175 interrupts in data training ram: rk3399: Use rank mask in ca data training ram: rk3399: Use rank mask in wdql data training ram: rk3399: Add ddrtype enc macro ram: rk3399: Add channel number encoder macro ram: rk3399: Add row_3_4 enc macro ram: rk3399: Add chipinfo macro ram: rk3399: Add rank enc macro ram: rk3399: Add column enc macro ram: rk3399: Add bk enc macro ram: rk3399: Add dbw enc macro ram: rk3399: Add cs0_rw macro ram: rk3399: Add cs1_rw macro ram: rk3399: Add bw enc macro ram: rk3399: Rename sys_reg with sys_reg2 ram: rk3399: Update cs0_row to use sys_reg3 ram: rk3399: Update cs1_row to use sys_reg3 ram: rk3399: Add cs1_col enc macro ram: rk3399: Add ddr version enc macro ram: rk3399: Add ddrtimingC0 ram: rk3399: Add DdrMode ram: rk3399: Handle pctl_cfg return type ram: rk3399: s/tsel_wr_select_n/tsel_wr_select_dq_n ram: rk3399: s/tsel_wr_select_p/tsel_wr_select_dq_p ram: rk3399: s/ca_tsel_wr_select_n/tsel_wr_select_ca_n ram: rk3399: s/ca_tsel_wr_select_p/tsel_wr_select_ca_p ram: rk3399: Order tsel variables ram: rk3399: Add phy pctrl reset support ram: rk3399: Move pwrup_srefresh_exit to dram_info ram: rk3399: Add pctl start support ram: rockchip: rk3399: Add cap_info structure ram: rk3399: s/rk3399_base_params/sdram_base_params ram: rk3399: Move common sdram structures in common header arm: include: rockchip: Move dramtypes to common header arm: include: rockchip: Add DDR4 enum ram: rockchip: Add initial Kconfig debug_uart: Add printdec ram: rockchip: Add debug sdram driver ram: rockchip: debug: Add sdram_print_ddr_info ram: rockchip: debug: Get the cs capacity ram: rk3399: debug: Add sdram_print_stride ram: rk3399: Compute stride for 2 channels ram: rk3399: Compute stride for 1 channel a ram: rk3399: Add rank detection support ram: rk3399: Enable sdram debug functions rockchip: dts: rk3399: nanopi-neo4: Use DDR3-1866 dtsi clk: rockchip: rk3399: Fix check patch warnings and checks clk: rockchip: rk3399: Set 50MHz ddr clock clk: rockchip: rk3399: Set 400MHz ddr clock ram: rk3399: Add spaces in pctl_cfg ram: rk3399: Configure phy IO in ds odt ram: rockchip: Kconfig: Add RK3399 LPDDR4 entry ram: rk3399: Add lpddr4 rank mask for ca training ram: rk3399: Add lpddr4 rank mask for wdql training ram: rk3399: Move mode_sel assignment ram: rk3399: Don't wait for PLL lock in lpddr4 ram: rk3399: Avoid two channel ZQ Cal Start at the same time ram: rk3399: Configure PHY_898, PHY_919 for lpddr4 ram: rk3399: Configure BOOSTP_EN, BOOSTN_EN for lpddr4 ram: rk3399: Configure SLEWP_EN, SLEWN_EN for lpddr4 ram: rk3399: Configure PHY RX_CM_INPUT for lpddr4 ram: rk3399: Map chipselect for lpddr4 ram: rk3399: Configure tsel write ca for lpddr4 ram: rk3399: Don't disable dfi dram clk for lpddr4, rank 1 ram: rk3399: Add IO settings ram: sdram: Configure lpddr4 tsel rd, wr based on IO settings ram: rk3399: Add tsel control clock drive ram: rk3399: Configure soc odt support ram: rk3399: Get lpddr4 tsel_rd_en from io settings ram: rk3399: Update lpddr4 vref based on io settings ram: rk3399: Update lpddr4 mode_sel based on io settings ram: rk3399: Update lpddr4 vref_mode_ac ram: rk3399: Simplify data training first argument ram: rk3399: Handle data training via ops ram: rk3399: Add LPPDR4 mr detection arm: include: rockchip: Add rk3399 pmu file rockchip: rk3399: syscon: Add pmu support rockchip: dts: rk3399: Add u-boot,dm-pre-reloc for pmu ram: rk3399: Add LPPDDR4-400 timings inc ram: rk3399: Add LPPDDR4-800 timings inc ram: rk3399: Add set_rate sdram rk3399 ops ram: rk3399: Add lpddr4 set rate support ram: rk3399: Set lpddr4 dq odt ram: rk3399: Set lpddr4 ca odt ram: rk3399: Set lpddr4 MR3 ram: rk3399: Set lpddr4 MR12 ram: rk3399: Set lpddr4 MR14 configs: rockpro64: Enable LPDDR4 support configs: rock-pi-4: Enable LPDDR4 support rockchip: dts: rk3399: Add LPDDR4-100 timings rockchip: dts: rk3399: rockpro64: Use LPDDR4-100 dtsi rockchip: dts: rk3399: rock-pi-4: Use LPDDR4-100 dtsi
arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 1 + arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi | 1 + arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 1 + arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi | 1537 +++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 4 + .../include/asm/arch-rockchip/pmu_rk3399.h | 72 + arch/arm/include/asm/arch-rockchip/sdram.h | 6 - .../include/asm/arch-rockchip/sdram_common.h | 90 + .../include/asm/arch-rockchip/sdram_rk322x.h | 7 - .../include/asm/arch-rockchip/sdram_rk3399.h | 65 +- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 8 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + drivers/clk/rockchip/clk_rk3399.c | 76 +- drivers/ram/Kconfig | 1 + drivers/ram/rockchip/Kconfig | 33 + drivers/ram/rockchip/Makefile | 3 +- .../ram/rockchip/sdram-rk3399-lpddr4-400.inc | 1570 +++++++++++ .../ram/rockchip/sdram-rk3399-lpddr4-800.inc | 1570 +++++++++++ drivers/ram/rockchip/sdram_debug.c | 147 ++ drivers/ram/rockchip/sdram_rk3399.c | 2289 ++++++++++++++--- include/debug_uart.h | 19 + 22 files changed, 7035 insertions(+), 467 deletions(-) create mode 100644 arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3399.h create mode 100644 drivers/ram/rockchip/Kconfig create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc create mode 100644 drivers/ram/rockchip/sdram_debug.c
Fix checkpatch warninigs on sdram_rk3399.c like - Avoid CamelCase - Unnecessary parentheses - Alignment should match open parenthesis - multiple blank lines - misspelled - spaces preferred around that '>>'
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 48 ++++++++++++++--------------- 1 file changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 52518656c4..541e4a4b1e 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -47,7 +47,7 @@ struct dram_info { #define PRESET_GPIO0_HOLD(n) ((0x1 << (7 + 16)) | ((n) << 7)) #define PRESET_GPIO1_HOLD(n) ((0x1 << (8 + 16)) | ((n) << 8))
-#define PHY_DRV_ODT_Hi_Z 0x0 +#define PHY_DRV_ODT_HI_Z 0x0 #define PHY_DRV_ODT_240 0x1 #define PHY_DRV_ODT_120 0x8 #define PHY_DRV_ODT_80 0x9 @@ -150,7 +150,7 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, ((16 - row) << 24)); /* PI_41 PI_CS_MAP:RW:24:4 */ clrsetbits_le32(&denali_pi[41], 0xf << 24, cs_map << 24); - if ((sdram_ch->rank == 1) && (sdram_params->base.dramtype == DDR3)) + if (sdram_ch->rank == 1 && sdram_params->base.dramtype == DDR3) writel(0x2EC7FFFF, &denali_pi[34]); }
@@ -166,10 +166,10 @@ static void set_ds_odt(const struct chan_info *chan, u32 reg_value;
if (sdram_params->base.dramtype == LPDDR4) { - tsel_rd_select_p = PHY_DRV_ODT_Hi_Z; + tsel_rd_select_p = PHY_DRV_ODT_HI_Z; tsel_wr_select_p = PHY_DRV_ODT_40; ca_tsel_wr_select_p = PHY_DRV_ODT_40; - tsel_idle_select_p = PHY_DRV_ODT_Hi_Z; + tsel_idle_select_p = PHY_DRV_ODT_HI_Z;
tsel_rd_select_n = PHY_DRV_ODT_240; tsel_wr_select_n = PHY_DRV_ODT_40; @@ -181,10 +181,10 @@ static void set_ds_odt(const struct chan_info *chan, ca_tsel_wr_select_p = PHY_DRV_ODT_48; tsel_idle_select_p = PHY_DRV_ODT_240;
- tsel_rd_select_n = PHY_DRV_ODT_Hi_Z; + tsel_rd_select_n = PHY_DRV_ODT_HI_Z; tsel_wr_select_n = PHY_DRV_ODT_34_3; ca_tsel_wr_select_n = PHY_DRV_ODT_48; - tsel_idle_select_n = PHY_DRV_ODT_Hi_Z; + tsel_idle_select_n = PHY_DRV_ODT_HI_Z; } else { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_wr_select_p = PHY_DRV_ODT_34_3; @@ -294,7 +294,7 @@ static void set_ds_odt(const struct chan_info *chan, }
static int phy_io_config(const struct chan_info *chan, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *sdram_params) { u32 *denali_phy = chan->publ->denali_phy; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; @@ -423,7 +423,6 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14);
- /* speed setting */ if (sdram_params->base.ddr_freq < 400) speed = 0x0; @@ -492,7 +491,7 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, setbits_le32(&denali_pi[0], START); setbits_le32(&denali_ctl[0], START);
- /* Wating for phy DLL lock */ + /* Waiting for phy DLL lock */ while (1) { tmp = readl(&denali_phy[920]); tmp1 = readl(&denali_phy[921]); @@ -547,12 +546,12 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, /* PHY_DLL_RST_EN */ clrsetbits_le32(&denali_phy[957], 0x3 << 24, 0x2 << 24);
- /* Wating for PHY and DRAM init complete */ + /* Waiting for PHY and DRAM init complete */ tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { pr_err("DRAM (%s): phy failed to lock within %ld ms\n", - __func__, timeout_ms); + __func__, timeout_ms); return -ETIME; } } while (!(readl(&denali_ctl[203]) & (1 << 3))); @@ -569,7 +568,7 @@ static void select_per_cs_training_index(const struct chan_info *chan, u32 *denali_phy = chan->publ->denali_phy;
/* PHY_84 PHY_PER_CS_TRAINING_EN_0 1bit offset_16 */ - if ((readl(&denali_phy[84])>>16) & 1) { + if ((readl(&denali_phy[84]) >> 16) & 1) { /* * PHY_8/136/264/392 * phy_per_cs_training_index_X 1bit offset_24 @@ -646,7 +645,7 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, if ((((tmp >> 11) & 0x1) == 0x1) && (((tmp >> 13) & 0x1) == 0x1) && (((tmp >> 5) & 0x1) == 0x0) && - (obs_err == 0)) + obs_err == 0) break; else if ((((tmp >> 5) & 0x1) == 0x1) || (obs_err == 1)) @@ -700,7 +699,7 @@ static int data_training_wl(const struct chan_info *chan, u32 channel, if ((((tmp >> 10) & 0x1) == 0x1) && (((tmp >> 13) & 0x1) == 0x1) && (((tmp >> 4) & 0x1) == 0x0) && - (obs_err == 0)) + obs_err == 0) break; else if ((((tmp >> 4) & 0x1) == 0x1) || (obs_err == 1)) @@ -759,7 +758,7 @@ static int data_training_rg(const struct chan_info *chan, u32 channel, if ((((tmp >> 9) & 0x1) == 0x1) && (((tmp >> 13) & 0x1) == 0x1) && (((tmp >> 3) & 0x1) == 0x0) && - (obs_err == 0)) + obs_err == 0) break; else if ((((tmp >> 3) & 0x1) == 0x1) || (obs_err == 1)) @@ -955,8 +954,10 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(channel); sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(channel); sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(channel); - sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(channel); - sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(channel); + sys_reg |= (info->cs0_row - 13) << + SYS_REG_CS0_ROW_SHIFT(channel); + sys_reg |= (info->cs1_row - 13) << + SYS_REG_CS1_ROW_SHIFT(channel); sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel); sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(channel);
@@ -991,7 +992,7 @@ static void dram_all_config(struct dram_info *dram, }
static int switch_to_phy_index1(struct dram_info *dram, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *sdram_params) { u32 channel; u32 *denali_phy; @@ -1026,7 +1027,7 @@ static int switch_to_phy_index1(struct dram_info *dram, denali_phy = dram->chan[channel].publ->denali_phy; clrsetbits_le32(&denali_phy[896], (0x3 << 8) | 1, 1 << 8); ret = data_training(&dram->chan[channel], channel, - sdram_params, PI_FULL_TRAINING); + sdram_params, PI_FULL_TRAINING); if (ret) { debug("index1 training failed\n"); return ret; @@ -1116,8 +1117,8 @@ static int conv_of_platdata(struct udevice *dev) int ret;
ret = regmap_init_mem_platdata(dev, dtplat->reg, - ARRAY_SIZE(dtplat->reg) / 2, - &plat->map); + ARRAY_SIZE(dtplat->reg) / 2, + &plat->map); if (ret) return ret;
@@ -1199,8 +1200,8 @@ static int rk3399_dmc_probe(struct udevice *dev) priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); debug("%s: pmugrf=%p\n", __func__, priv->pmugrf); priv->info.base = CONFIG_SYS_SDRAM_BASE; - priv->info.size = rockchip_sdram_size( - (phys_addr_t)&priv->pmugrf->os_reg2); + priv->info.size = + rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg2); #endif return 0; } @@ -1218,7 +1219,6 @@ static struct ram_ops rk3399_dmc_ops = { .get_info = rk3399_dmc_get_info, };
- static const struct udevice_id rk3399_dmc_ids[] = { { .compatible = "rockchip,rk3399-dmc" }, { }
- Avoid CamelCase
- misspelled
Reviewed-by: Kever Yang Kever.yang@rock-chips.com
Thanks, - Kever
- if (sdram_ch->rank == 1 && sdram_params->base.dramtype == DDR3) writel(0x2EC7FFFF, &denali_pi[34]); }
tsel_wr_select_p = PHY_DRV_ODT_40; ca_tsel_wr_select_p = PHY_DRV_ODT_40;tsel_rd_select_p = PHY_DRV_ODT_HI_Z;
tsel_wr_select_n = PHY_DRV_ODT_34_3; ca_tsel_wr_select_n = PHY_DRV_ODT_48;tsel_rd_select_n = PHY_DRV_ODT_HI_Z;
} else { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_wr_select_p = PHY_DRV_ODT_34_3;tsel_idle_select_n = PHY_DRV_ODT_HI_Z;
{ u32 *denali_phy = chan->publ->denali_phy; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac;const struct rk3399_sdram_params *sdram_params)
- /* Waiting for phy DLL lock */ while (1) { tmp = readl(&denali_phy[920]); tmp1 = readl(&denali_phy[921]);
- /* Waiting for PHY and DRAM init complete */ tmp = get_timer(0); do { if (get_timer(tmp) > timeout_ms) { pr_err("DRAM (%s): phy failed to lock within %ld ms\n",
} } while (!(readl(&denali_ctl[203]) & (1 << 3)));__func__, timeout_ms); return -ETIME;
- if ((readl(&denali_phy[84]) >> 16) & 1) { /*
- PHY_8/136/264/392
- phy_per_cs_training_index_X 1bit offset_24
(obs_err == 0))
(obs_err == 0))
(obs_err == 0))
sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel); sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(channel);SYS_REG_CS1_ROW_SHIFT(channel);
{ u32 channel; u32 *denali_phy;const struct rk3399_sdram_params *sdram_params)
if (ret) { debug("index1 training failed\n"); return ret;sdram_params, PI_FULL_TRAINING);
&plat->map);
if (ret) return ret;&plat->map);
- priv->info.size =
#endif return 0; }rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg2);
Add space between string with format specifier on missing print and debug calls.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 541e4a4b1e..8191ab6176 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1180,7 +1180,7 @@ static int rk3399_dmc_init(struct udevice *dev) } ret = sdram_init(priv, params); if (ret < 0) { - printf("%s DRAM init failed%d\n", __func__, ret); + printf("%s DRAM init failed %d\n", __func__, ret); return ret; }
@@ -1198,7 +1198,7 @@ static int rk3399_dmc_probe(struct udevice *dev) struct dram_info *priv = dev_get_priv(dev);
priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); - debug("%s: pmugrf=%p\n", __func__, priv->pmugrf); + debug("%s: pmugrf = %p\n", __func__, priv->pmugrf); priv->info.base = CONFIG_SYS_SDRAM_BASE; priv->info.size = rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg2);
Add proper spaces in the code of - data training functions - rk3399_dmc_init
No functionality change.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 8191ab6176..b8962d68f2 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -620,8 +620,10 @@ static int data_training_ca(const struct chan_info *chan, u32 channel,
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); + /* PI_100 PI_CALVL_EN:RW:8:2 */ clrsetbits_le32(&denali_pi[100], 0x3 << 8, 0x2 << 8); + /* PI_92 PI_CALVL_REQ:WR:16:1,PI_CALVL_CS:RW:24:2 */ clrsetbits_le32(&denali_pi[92], (0x1 << 16) | (0x3 << 24), @@ -651,9 +653,11 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, (obs_err == 1)) return -EIO; } + /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); } + clrbits_le32(&denali_pi[100], 0x3 << 8);
return 0; @@ -670,8 +674,10 @@ static int data_training_wl(const struct chan_info *chan, u32 channel,
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); + /* PI_60 PI_WRLVL_EN:RW:8:2 */ clrsetbits_le32(&denali_pi[60], 0x3 << 8, 0x2 << 8); + /* PI_59 PI_WRLVL_REQ:WR:8:1,PI_WRLVL_CS:RW:16:2 */ clrsetbits_le32(&denali_pi[59], (0x1 << 8) | (0x3 << 16), @@ -705,6 +711,7 @@ static int data_training_wl(const struct chan_info *chan, u32 channel, (obs_err == 1)) return -EIO; } + /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); } @@ -726,8 +733,10 @@ static int data_training_rg(const struct chan_info *chan, u32 channel,
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); + /* PI_80 PI_RDLVL_GATE_EN:RW:24:2 */ clrsetbits_le32(&denali_pi[80], 0x3 << 24, 0x2 << 24); + /* * PI_74 PI_RDLVL_GATE_REQ:WR:16:1 * PI_RDLVL_CS:RW:24:2 @@ -764,9 +773,11 @@ static int data_training_rg(const struct chan_info *chan, u32 channel, (obs_err == 1)) return -EIO; } + /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); } + clrbits_le32(&denali_pi[80], 0x3 << 24);
return 0; @@ -781,8 +792,10 @@ static int data_training_rl(const struct chan_info *chan, u32 channel,
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); + /* PI_80 PI_RDLVL_EN:RW:16:2 */ clrsetbits_le32(&denali_pi[80], 0x3 << 16, 0x2 << 16); + /* PI_74 PI_RDLVL_REQ:WR:8:1,PI_RDLVL_CS:RW:24:2 */ clrsetbits_le32(&denali_pi[74], (0x1 << 8) | (0x3 << 24), @@ -805,9 +818,11 @@ static int data_training_rl(const struct chan_info *chan, u32 channel, else if (((tmp >> 2) & 0x1) == 0x1) return -EIO; } + /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); } + clrbits_le32(&denali_pi[80], 0x3 << 16);
return 0; @@ -822,13 +837,16 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel,
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); + /* * disable PI_WDQLVL_VREF_EN before wdq leveling? * PI_181 PI_WDQLVL_VREF_EN:RW:8:1 */ clrbits_le32(&denali_pi[181], 0x1 << 8); + /* PI_124 PI_WDQLVL_EN:RW:16:2 */ clrsetbits_le32(&denali_pi[124], 0x3 << 16, 0x2 << 16); + /* PI_121 PI_WDQLVL_REQ:WR:8:1,PI_WDQLVL_CS:RW:16:2 */ clrsetbits_le32(&denali_pi[121], (0x1 << 8) | (0x3 << 16), @@ -845,9 +863,11 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, else if (((tmp >> 6) & 0x1) == 0x1) return -EIO; } + /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); } + clrbits_le32(&denali_pi[124], 0x3 << 16);
return 0; @@ -938,6 +958,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= sdram_params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; sys_reg |= (sdram_params->base.num_channels - 1) << SYS_REG_NUM_CH_SHIFT; + for (channel = 0, idx = 0; (idx < sdram_params->base.num_channels) && (channel < 2); channel++) { @@ -1164,6 +1185,7 @@ static int rk3399_dmc_init(struct udevice *dev) priv->chan[1].publ, priv->chan[1].msch); debug("cru %p, cic %p, grf %p, sgrf %p, pmucru %p\n", priv->cru, priv->cic, priv->pmugrf, priv->pmusgrf, priv->pmucru); + #if CONFIG_IS_ENABLED(OF_PLATDATA) ret = clk_get_by_index_platdata(dev, 0, dtplat->clocks, &priv->ddr_clk); #else @@ -1173,11 +1195,13 @@ static int rk3399_dmc_init(struct udevice *dev) printf("%s clk get failed %d\n", __func__, ret); return ret; } + ret = clk_set_rate(&priv->ddr_clk, params->base.ddr_freq * MHz); if (ret < 0) { printf("%s clk set failed %d\n", __func__, ret); return ret; } + ret = sdram_init(priv, params); if (ret < 0) { printf("%s DRAM init failed %d\n", __func__, ret);
Rename variable name of struct rk3399_sdram_params from sdram_params with params for more code readability.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 160 ++++++++++++++-------------- 1 file changed, 78 insertions(+), 82 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index b8962d68f2..4c09009b7a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -111,10 +111,9 @@ static void phy_dll_bypass_set(struct rk3399_ddr_publ_regs *ddr_publ_regs, }
static void set_memory_map(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { - const struct rk3399_sdram_channel *sdram_ch = - &sdram_params->ch[channel]; + const struct rk3399_sdram_channel *sdram_ch = ¶ms->ch[channel]; u32 *denali_ctl = chan->pctl->denali_ctl; u32 *denali_pi = chan->pi->denali_pi; u32 cs_map; @@ -150,12 +149,12 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, ((16 - row) << 24)); /* PI_41 PI_CS_MAP:RW:24:4 */ clrsetbits_le32(&denali_pi[41], 0xf << 24, cs_map << 24); - if (sdram_ch->rank == 1 && sdram_params->base.dramtype == DDR3) + if (sdram_ch->rank == 1 && params->base.dramtype == DDR3) writel(0x2EC7FFFF, &denali_pi[34]); }
static void set_ds_odt(const struct chan_info *chan, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_phy = chan->publ->denali_phy;
@@ -165,7 +164,7 @@ static void set_ds_odt(const struct chan_info *chan, u32 tsel_idle_select_n, tsel_wr_select_n, tsel_rd_select_n; u32 reg_value;
- if (sdram_params->base.dramtype == LPDDR4) { + if (params->base.dramtype == LPDDR4) { tsel_rd_select_p = PHY_DRV_ODT_HI_Z; tsel_wr_select_p = PHY_DRV_ODT_40; ca_tsel_wr_select_p = PHY_DRV_ODT_40; @@ -175,7 +174,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_wr_select_n = PHY_DRV_ODT_40; ca_tsel_wr_select_n = PHY_DRV_ODT_40; tsel_idle_select_n = PHY_DRV_ODT_240; - } else if (sdram_params->base.dramtype == LPDDR3) { + } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_wr_select_p = PHY_DRV_ODT_34_3; ca_tsel_wr_select_p = PHY_DRV_ODT_48; @@ -197,7 +196,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_n = PHY_DRV_ODT_240; }
- if (sdram_params->base.odt == 1) + if (params->base.odt == 1) tsel_rd_en = 1; else tsel_rd_en = 0; @@ -294,7 +293,7 @@ static void set_ds_odt(const struct chan_info *chan, }
static int phy_io_config(const struct chan_info *chan, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_phy = chan->publ->denali_phy; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; @@ -304,14 +303,14 @@ static int phy_io_config(const struct chan_info *chan, u32 speed;
/* vref setting */ - if (sdram_params->base.dramtype == LPDDR4) { + if (params->base.dramtype == LPDDR4) { /* LPDDR4 */ vref_mode_dq = 0x6; vref_value_dq = 0x1f; vref_mode_ac = 0x6; vref_value_ac = 0x1f; - } else if (sdram_params->base.dramtype == LPDDR3) { - if (sdram_params->base.odt == 1) { + } else if (params->base.dramtype == LPDDR3) { + if (params->base.odt == 1) { vref_mode_dq = 0x5; /* LPDDR3 ODT */ drv_value = (readl(&denali_phy[6]) >> 12) & 0xf; odt_value = (readl(&denali_phy[6]) >> 4) & 0xf; @@ -370,7 +369,7 @@ static int phy_io_config(const struct chan_info *chan, } vref_mode_ac = 0x2; vref_value_ac = 0x1f; - } else if (sdram_params->base.dramtype == DDR3) { + } else if (params->base.dramtype == DDR3) { /* DDR3L */ vref_mode_dq = 0x1; vref_value_dq = 0x1f; @@ -397,11 +396,11 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_915 PHY_PAD_VREF_CTRL_AC 12bits offset_16 */ clrsetbits_le32(&denali_phy[915], 0xfff << 16, reg_value << 16);
- if (sdram_params->base.dramtype == LPDDR4) + if (params->base.dramtype == LPDDR4) mode_sel = 0x6; - else if (sdram_params->base.dramtype == LPDDR3) + else if (params->base.dramtype == LPDDR3) mode_sel = 0x0; - else if (sdram_params->base.dramtype == DDR3) + else if (params->base.dramtype == DDR3) mode_sel = 0x1; else return -EINVAL; @@ -424,11 +423,11 @@ static int phy_io_config(const struct chan_info *chan, clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14);
/* speed setting */ - if (sdram_params->base.ddr_freq < 400) + if (params->base.ddr_freq < 400) speed = 0x0; - else if (sdram_params->base.ddr_freq < 800) + else if (params->base.ddr_freq < 800) speed = 0x1; - else if (sdram_params->base.ddr_freq < 1200) + else if (params->base.ddr_freq < 1200) speed = 0x2; else speed = 0x3; @@ -454,13 +453,13 @@ static int phy_io_config(const struct chan_info *chan, }
static int pctl_cfg(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_ctl = chan->pctl->denali_ctl; u32 *denali_pi = chan->pi->denali_pi; u32 *denali_phy = chan->publ->denali_phy; - const u32 *params_ctl = sdram_params->pctl_regs.denali_ctl; - const u32 *params_phy = sdram_params->phy_regs.denali_phy; + const u32 *params_ctl = params->pctl_regs.denali_ctl; + const u32 *params_phy = params->phy_regs.denali_phy; u32 tmp, tmp1, tmp2; u32 pwrup_srefresh_exit; int ret; @@ -473,14 +472,14 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, copy_to_reg(&denali_ctl[1], ¶ms_ctl[1], sizeof(struct rk3399_ddr_pctl_regs) - 4); writel(params_ctl[0], &denali_ctl[0]); - copy_to_reg(denali_pi, &sdram_params->pi_regs.denali_pi[0], + copy_to_reg(denali_pi, ¶ms->pi_regs.denali_pi[0], sizeof(struct rk3399_ddr_pi_regs)); /* rank count need to set for init */ - set_memory_map(chan, channel, sdram_params); + set_memory_map(chan, channel, params);
- writel(sdram_params->phy_regs.denali_phy[910], &denali_phy[910]); - writel(sdram_params->phy_regs.denali_phy[911], &denali_phy[911]); - writel(sdram_params->phy_regs.denali_phy[912], &denali_phy[912]); + writel(params->phy_regs.denali_phy[910], &denali_phy[910]); + writel(params->phy_regs.denali_phy[911], &denali_phy[911]); + writel(params->phy_regs.denali_phy[912], &denali_phy[912]);
pwrup_srefresh_exit = readl(&denali_ctl[68]) & PWRUP_SREFRESH_EXIT; clrbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT); @@ -511,7 +510,7 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, copy_to_reg(&denali_phy[512], ¶ms_phy[512], (549 - 512 + 1) * 4); copy_to_reg(&denali_phy[640], ¶ms_phy[640], (677 - 640 + 1) * 4); copy_to_reg(&denali_phy[768], ¶ms_phy[768], (805 - 768 + 1) * 4); - set_ds_odt(chan, sdram_params); + set_ds_odt(chan, params);
/* * phy_dqs_tsel_wr_timing_X 8bits DENALI_PHY_84/212/340/468 offset_8 @@ -539,7 +538,7 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, tmp = (readl(&denali_phy[467]) >> 16) & 0xff; clrsetbits_le32(&denali_phy[467], 0xff << 16, (tmp + 0x10) << 16);
- ret = phy_io_config(chan, sdram_params); + ret = phy_io_config(chan, params); if (ret) return ret;
@@ -610,13 +609,13 @@ static void override_write_leveling_value(const struct chan_info *chan) }
static int data_training_ca(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_pi = chan->pi->denali_pi; u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_err = 0; - u32 rank = sdram_params->ch[channel].rank; + u32 rank = params->ch[channel].rank;
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); @@ -664,13 +663,13 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, }
static int data_training_wl(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_pi = chan->pi->denali_pi; u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; - u32 rank = sdram_params->ch[channel].rank; + u32 rank = params->ch[channel].rank;
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); @@ -723,13 +722,13 @@ static int data_training_wl(const struct chan_info *chan, u32 channel, }
static int data_training_rg(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_pi = chan->pi->denali_pi; u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; - u32 rank = sdram_params->ch[channel].rank; + u32 rank = params->ch[channel].rank;
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); @@ -784,11 +783,11 @@ static int data_training_rg(const struct chan_info *chan, u32 channel, }
static int data_training_rl(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_pi = chan->pi->denali_pi; u32 i, tmp; - u32 rank = sdram_params->ch[channel].rank; + u32 rank = params->ch[channel].rank;
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); @@ -829,11 +828,11 @@ static int data_training_rl(const struct chan_info *chan, u32 channel, }
static int data_training_wdql(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 *denali_pi = chan->pi->denali_pi; u32 i, tmp; - u32 rank = sdram_params->ch[channel].rank; + u32 rank = params->ch[channel].rank;
for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i); @@ -874,7 +873,7 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, }
static int data_training(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *sdram_params, + const struct rk3399_sdram_params *params, u32 training_flag) { u32 *denali_phy = chan->publ->denali_phy; @@ -883,14 +882,14 @@ static int data_training(const struct chan_info *chan, u32 channel, setbits_le32(&denali_phy[927], (1 << 22));
if (training_flag == PI_FULL_TRAINING) { - if (sdram_params->base.dramtype == LPDDR4) { + if (params->base.dramtype == LPDDR4) { training_flag = PI_CA_TRAINING | PI_WRITE_LEVELING | PI_READ_GATE_TRAINING | PI_READ_LEVELING | PI_WDQ_LEVELING; - } else if (sdram_params->base.dramtype == LPDDR3) { + } else if (params->base.dramtype == LPDDR3) { training_flag = PI_CA_TRAINING | PI_WRITE_LEVELING | PI_READ_GATE_TRAINING; - } else if (sdram_params->base.dramtype == DDR3) { + } else if (params->base.dramtype == DDR3) { training_flag = PI_WRITE_LEVELING | PI_READ_GATE_TRAINING | PI_READ_LEVELING; @@ -899,23 +898,23 @@ static int data_training(const struct chan_info *chan, u32 channel,
/* ca training(LPDDR4,LPDDR3 support) */ if ((training_flag & PI_CA_TRAINING) == PI_CA_TRAINING) - data_training_ca(chan, channel, sdram_params); + data_training_ca(chan, channel, params);
/* write leveling(LPDDR4,LPDDR3,DDR3 support) */ if ((training_flag & PI_WRITE_LEVELING) == PI_WRITE_LEVELING) - data_training_wl(chan, channel, sdram_params); + data_training_wl(chan, channel, params);
/* read gate training(LPDDR4,LPDDR3,DDR3 support) */ if ((training_flag & PI_READ_GATE_TRAINING) == PI_READ_GATE_TRAINING) - data_training_rg(chan, channel, sdram_params); + data_training_rg(chan, channel, params);
/* read leveling(LPDDR4,LPDDR3,DDR3 support) */ if ((training_flag & PI_READ_LEVELING) == PI_READ_LEVELING) - data_training_rl(chan, channel, sdram_params); + data_training_rl(chan, channel, params);
/* wdq leveling(LPDDR4 support) */ if ((training_flag & PI_WDQ_LEVELING) == PI_WDQ_LEVELING) - data_training_wdql(chan, channel, sdram_params); + data_training_wdql(chan, channel, params);
/* PHY_927 PHY_PAD_DQS_DRIVE RPULL offset_22 */ clrbits_le32(&denali_phy[927], (1 << 22)); @@ -924,7 +923,7 @@ static int data_training(const struct chan_info *chan, u32 channel, }
static void set_ddrconfig(const struct chan_info *chan, - const struct rk3399_sdram_params *sdram_params, + const struct rk3399_sdram_params *params, unsigned char channel, u32 ddrconfig) { /* only need to set ddrconfig */ @@ -932,14 +931,14 @@ static void set_ddrconfig(const struct chan_info *chan, unsigned int cs0_cap = 0; unsigned int cs1_cap = 0;
- cs0_cap = (1 << (sdram_params->ch[channel].cs0_row - + sdram_params->ch[channel].col - + sdram_params->ch[channel].bk - + sdram_params->ch[channel].bw - 20)); - if (sdram_params->ch[channel].rank > 1) - cs1_cap = cs0_cap >> (sdram_params->ch[channel].cs0_row - - sdram_params->ch[channel].cs1_row); - if (sdram_params->ch[channel].row_3_4) { + cs0_cap = (1 << (params->ch[channel].cs0_row + + params->ch[channel].col + + params->ch[channel].bk + + params->ch[channel].bw - 20)); + if (params->ch[channel].rank > 1) + cs1_cap = cs0_cap >> (params->ch[channel].cs0_row + - params->ch[channel].cs1_row); + if (params->ch[channel].row_3_4) { cs0_cap = cs0_cap * 3 / 4; cs1_cap = cs1_cap * 3 / 4; } @@ -950,24 +949,22 @@ static void set_ddrconfig(const struct chan_info *chan, }
static void dram_all_config(struct dram_info *dram, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 sys_reg = 0; unsigned int channel, idx;
- sys_reg |= sdram_params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; - sys_reg |= (sdram_params->base.num_channels - 1) - << SYS_REG_NUM_CH_SHIFT; + sys_reg |= params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; + sys_reg |= (params->base.num_channels - 1) << SYS_REG_NUM_CH_SHIFT;
for (channel = 0, idx = 0; - (idx < sdram_params->base.num_channels) && (channel < 2); + (idx < params->base.num_channels) && (channel < 2); channel++) { - const struct rk3399_sdram_channel *info = - &sdram_params->ch[channel]; + const struct rk3399_sdram_channel *info = ¶ms->ch[channel]; struct rk3399_msch_regs *ddr_msch_regs; const struct rk3399_msch_timings *noc_timing;
- if (sdram_params->ch[channel].col == 0) + if (params->ch[channel].col == 0) continue; idx++; sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(channel); @@ -983,7 +980,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(channel);
ddr_msch_regs = dram->chan[channel].msch; - noc_timing = &sdram_params->ch[channel].noc_timings; + noc_timing = ¶ms->ch[channel].noc_timings; writel(noc_timing->ddrtiminga0, &ddr_msch_regs->ddrtiminga0); writel(noc_timing->ddrtimingb0, @@ -996,14 +993,14 @@ static void dram_all_config(struct dram_info *dram, &ddr_msch_regs->ddrmode);
/* rank 1 memory clock disable (dfi_dram_clk_disable = 1) */ - if (sdram_params->ch[channel].rank == 1) + if (params->ch[channel].rank == 1) setbits_le32(&dram->chan[channel].pctl->denali_ctl[276], 1 << 17); }
writel(sys_reg, &dram->pmugrf->os_reg2); rk_clrsetreg(&dram->pmusgrf->soc_con4, 0x1f << 10, - sdram_params->base.stride << 10); + params->base.stride << 10);
/* reboot hold register set */ writel(PRESET_SGRF_HOLD(0) | PRESET_GPIO0_HOLD(1) | @@ -1013,11 +1010,11 @@ static void dram_all_config(struct dram_info *dram, }
static int switch_to_phy_index1(struct dram_info *dram, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { u32 channel; u32 *denali_phy; - u32 ch_count = sdram_params->base.num_channels; + u32 ch_count = params->base.num_channels; int ret; int i = 0;
@@ -1048,7 +1045,7 @@ static int switch_to_phy_index1(struct dram_info *dram, denali_phy = dram->chan[channel].publ->denali_phy; clrsetbits_le32(&denali_phy[896], (0x3 << 8) | 1, 1 << 8); ret = data_training(&dram->chan[channel], channel, - sdram_params, PI_FULL_TRAINING); + params, PI_FULL_TRAINING); if (ret) { debug("index1 training failed\n"); return ret; @@ -1059,10 +1056,10 @@ static int switch_to_phy_index1(struct dram_info *dram, }
static int sdram_init(struct dram_info *dram, - const struct rk3399_sdram_params *sdram_params) + const struct rk3399_sdram_params *params) { - unsigned char dramtype = sdram_params->base.dramtype; - unsigned int ddr_freq = sdram_params->base.ddr_freq; + unsigned char dramtype = params->base.dramtype; + unsigned int ddr_freq = params->base.ddr_freq; int channel;
debug("Starting SDRAM initialization...\n"); @@ -1080,10 +1077,10 @@ static int sdram_init(struct dram_info *dram,
phy_dll_bypass_set(publ, ddr_freq);
- if (channel >= sdram_params->base.num_channels) + if (channel >= params->base.num_channels) continue;
- if (pctl_cfg(chan, channel, sdram_params) != 0) { + if (pctl_cfg(chan, channel, params) != 0) { printf("pctl_cfg fail, reset\n"); return -EIO; } @@ -1092,17 +1089,16 @@ static int sdram_init(struct dram_info *dram, if (dramtype == LPDDR3) udelay(10);
- if (data_training(chan, channel, - sdram_params, PI_FULL_TRAINING)) { + if (data_training(chan, channel, params, PI_FULL_TRAINING)) { printf("SDRAM initialization failed, reset\n"); return -EIO; }
- set_ddrconfig(chan, sdram_params, channel, - sdram_params->ch[channel].ddrconfig); + set_ddrconfig(chan, params, channel, + params->ch[channel].ddrconfig); } - dram_all_config(dram, sdram_params); - switch_to_phy_index1(dram, sdram_params); + dram_all_config(dram, params); + switch_to_phy_index1(dram, params);
debug("Finish SDRAM initialization...\n"); return 0;
data trainings calls like ca, wl, rg, rl, wdql have proper return types with -EIO and the return type missed to handle in data_training function.
This patch, add proper return type checks along with useful debug statement on each data training calls.
Incidentally this would help to prevent the sdram initialization hang for single channel dram and when the code is trying to initialize second channel with proper return type of relevant data training call might failed.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 50 ++++++++++++++++++++++------- 1 file changed, 38 insertions(+), 12 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 4c09009b7a..e10bcafe32 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -877,6 +877,7 @@ static int data_training(const struct chan_info *chan, u32 channel, u32 training_flag) { u32 *denali_phy = chan->publ->denali_phy; + int ret;
/* PHY_927 PHY_PAD_DQS_DRIVE RPULL offset_22 */ setbits_le32(&denali_phy[927], (1 << 22)); @@ -897,24 +898,49 @@ static int data_training(const struct chan_info *chan, u32 channel, }
/* ca training(LPDDR4,LPDDR3 support) */ - if ((training_flag & PI_CA_TRAINING) == PI_CA_TRAINING) - data_training_ca(chan, channel, params); + if ((training_flag & PI_CA_TRAINING) == PI_CA_TRAINING) { + ret = data_training_ca(chan, channel, params); + if (ret < 0) { + debug("%s: data training ca failed\n", __func__); + return ret; + } + }
/* write leveling(LPDDR4,LPDDR3,DDR3 support) */ - if ((training_flag & PI_WRITE_LEVELING) == PI_WRITE_LEVELING) - data_training_wl(chan, channel, params); + if ((training_flag & PI_WRITE_LEVELING) == PI_WRITE_LEVELING) { + ret = data_training_wl(chan, channel, params); + if (ret < 0) { + debug("%s: data training wl failed\n", __func__); + return ret; + } + }
/* read gate training(LPDDR4,LPDDR3,DDR3 support) */ - if ((training_flag & PI_READ_GATE_TRAINING) == PI_READ_GATE_TRAINING) - data_training_rg(chan, channel, params); + if ((training_flag & PI_READ_GATE_TRAINING) == PI_READ_GATE_TRAINING) { + ret = data_training_rg(chan, channel, params); + if (ret < 0) { + debug("%s: data training rg failed\n", __func__); + return ret; + } + }
/* read leveling(LPDDR4,LPDDR3,DDR3 support) */ - if ((training_flag & PI_READ_LEVELING) == PI_READ_LEVELING) - data_training_rl(chan, channel, params); + if ((training_flag & PI_READ_LEVELING) == PI_READ_LEVELING) { + ret = data_training_rl(chan, channel, params); + if (ret < 0) { + debug("%s: data training rl failed\n", __func__); + return ret; + } + }
/* wdq leveling(LPDDR4 support) */ - if ((training_flag & PI_WDQ_LEVELING) == PI_WDQ_LEVELING) - data_training_wdql(chan, channel, params); + if ((training_flag & PI_WDQ_LEVELING) == PI_WDQ_LEVELING) { + ret = data_training_wdql(chan, channel, params); + if (ret < 0) { + debug("%s: data training wdql failed\n", __func__); + return ret; + } + }
/* PHY_927 PHY_PAD_DQS_DRIVE RPULL offset_22 */ clrbits_le32(&denali_phy[927], (1 << 22)); @@ -1046,7 +1072,7 @@ static int switch_to_phy_index1(struct dram_info *dram, clrsetbits_le32(&denali_phy[896], (0x3 << 8) | 1, 1 << 8); ret = data_training(&dram->chan[channel], channel, params, PI_FULL_TRAINING); - if (ret) { + if (ret < 0) { debug("index1 training failed\n"); return ret; } @@ -1090,7 +1116,7 @@ static int sdram_init(struct dram_info *dram, udelay(10);
if (data_training(chan, channel, params, PI_FULL_TRAINING)) { - printf("SDRAM initialization failed, reset\n"); + printf("%s: data training failed\n", __func__); return -EIO; }
Order include files in ascending order, which would avoid conflicting function definitions/prototypes if any and also for better code readability.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e10bcafe32..e6f52c9f59 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -14,11 +14,11 @@ #include <syscon.h> #include <asm/io.h> #include <asm/arch-rockchip/clock.h> -#include <asm/arch-rockchip/sdram_common.h> -#include <asm/arch-rockchip/sdram_rk3399.h> #include <asm/arch-rockchip/cru_rk3399.h> #include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_rk3399.h> #include <linux/err.h> #include <time.h>
Move the macro definitions after include files for better code readability and to satisfy coding style.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e6f52c9f59..20a3e89c17 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -22,6 +22,19 @@ #include <linux/err.h> #include <time.h>
+#define PRESET_SGRF_HOLD(n) ((0x1 << (6 + 16)) | ((n) << 6)) +#define PRESET_GPIO0_HOLD(n) ((0x1 << (7 + 16)) | ((n) << 7)) +#define PRESET_GPIO1_HOLD(n) ((0x1 << (8 + 16)) | ((n) << 8)) + +#define PHY_DRV_ODT_HI_Z 0x0 +#define PHY_DRV_ODT_240 0x1 +#define PHY_DRV_ODT_120 0x8 +#define PHY_DRV_ODT_80 0x9 +#define PHY_DRV_ODT_60 0xc +#define PHY_DRV_ODT_48 0xd +#define PHY_DRV_ODT_40 0xe +#define PHY_DRV_ODT_34_3 0xf + struct chan_info { struct rk3399_ddr_pctl_regs *pctl; struct rk3399_ddr_pi_regs *pi; @@ -43,19 +56,6 @@ struct dram_info { struct rk3399_pmugrf_regs *pmugrf; };
-#define PRESET_SGRF_HOLD(n) ((0x1 << (6 + 16)) | ((n) << 6)) -#define PRESET_GPIO0_HOLD(n) ((0x1 << (7 + 16)) | ((n) << 7)) -#define PRESET_GPIO1_HOLD(n) ((0x1 << (8 + 16)) | ((n) << 8)) - -#define PHY_DRV_ODT_HI_Z 0x0 -#define PHY_DRV_ODT_240 0x1 -#define PHY_DRV_ODT_120 0x8 -#define PHY_DRV_ODT_80 0x9 -#define PHY_DRV_ODT_60 0xc -#define PHY_DRV_ODT_48 0xd -#define PHY_DRV_ODT_40 0xe -#define PHY_DRV_ODT_34_3 0xf - #if defined(CONFIG_TPL_BUILD) || \ (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD))
Jagan,
Maybe all the patches for clean up only for sdram_rk3399.c, with out code logic
change, can squash into one commit?
Thanks,
- Kever
- struct chan_info { struct rk3399_ddr_pctl_regs *pctl; struct rk3399_ddr_pi_regs *pi;
Clear the PI_175 interrupts before processing actual data training in all relevant calls.
This would help to clear interrupt from previous training.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 20a3e89c17..1898466b4c 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -617,6 +617,9 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, u32 obs_0, obs_1, obs_2, obs_err = 0; u32 rank = params->ch[channel].rank;
+ /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ + writel(0x00003f7c, (&denali_pi[175])); + for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i);
@@ -671,6 +674,9 @@ static int data_training_wl(const struct chan_info *chan, u32 channel, u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; u32 rank = params->ch[channel].rank;
@@ -730,6 +736,9 @@ static int data_training_rg(const struct chan_info *chan, u32 channel, u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; u32 rank = params->ch[channel].rank;
@@ -789,6 +798,9 @@ static int data_training_rl(const struct chan_info *chan, u32 channel, u32 i, tmp; u32 rank = params->ch[channel].rank;
@@ -834,6 +846,9 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, u32 i, tmp; u32 rank = params->ch[channel].rank;
Thanks, - Kever
- /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */
- writel(0x00003f7c, (&denali_pi[175]));
- for (i = 0; i < rank; i++) { select_per_cs_training_index(chan, i);
Add rank_mask based on the rank number, this would keep the ca data training loop based on the desired rank mask value instead of looping for all values.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1898466b4c..76d6440f9a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -616,11 +616,17 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_err = 0; u32 rank = params->ch[channel].rank; + u32 rank_mask;
- for (i = 0; i < rank; i++) { + rank_mask = (rank == 1) ? 0x1 : 0x3; + + for (i = 0; i < 4; i++) { + if (!(rank_mask & (1 << i))) + continue; + select_per_cs_training_index(chan, i);
Add rank_mask based on the rank number, this would keep the wdql data training loop based on the desired rank mask value instead of looping for all values.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 76d6440f9a..32fc7771b3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -851,11 +851,17 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, u32 *denali_pi = chan->pi->denali_pi; u32 i, tmp; u32 rank = params->ch[channel].rank; + u32 rank_mask;
Add simplified and meaningful macro for ddrtype macro.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 1 + drivers/ram/rockchip/sdram_rk3399.c | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 671c318d50..ce1b62982c 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -34,6 +34,7 @@ #define SYS_REG_ROW_3_4_SHIFT(ch) (30 + (ch)) #define SYS_REG_ROW_3_4_MASK 1 #define SYS_REG_CHINFO_SHIFT(ch) (28 + (ch)) +#define SYS_REG_ENC_DDRTYPE(n) ((n) << SYS_REG_DDRTYPE_SHIFT) #define SYS_REG_RANK_SHIFT(ch) (11 + (ch) * 16) #define SYS_REG_RANK_MASK 1 #define SYS_REG_COL_SHIFT(ch) (9 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 32fc7771b3..28178f4ee9 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1007,7 +1007,7 @@ static void dram_all_config(struct dram_info *dram, u32 sys_reg = 0; unsigned int channel, idx;
- sys_reg |= params->base.dramtype << SYS_REG_DDRTYPE_SHIFT; + sys_reg |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); sys_reg |= (params->base.num_channels - 1) << SYS_REG_NUM_CH_SHIFT;
Add simplified and meaningful macro for channel number.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 2 ++ drivers/ram/rockchip/sdram_rk3399.c | 2 +- 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index ce1b62982c..a565f8d045 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -35,6 +35,8 @@ #define SYS_REG_ROW_3_4_MASK 1 #define SYS_REG_CHINFO_SHIFT(ch) (28 + (ch)) #define SYS_REG_ENC_DDRTYPE(n) ((n) << SYS_REG_DDRTYPE_SHIFT) +#define SYS_REG_ENC_NUM_CH(n) (((n) - SYS_REG_NUM_CH_MASK) << \ + SYS_REG_NUM_CH_SHIFT) #define SYS_REG_RANK_SHIFT(ch) (11 + (ch) * 16) #define SYS_REG_RANK_MASK 1 #define SYS_REG_COL_SHIFT(ch) (9 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 28178f4ee9..ad2d03729d 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1008,7 +1008,7 @@ static void dram_all_config(struct dram_info *dram, unsigned int channel, idx;
sys_reg |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); - sys_reg |= (params->base.num_channels - 1) << SYS_REG_NUM_CH_SHIFT; + sys_reg |= SYS_REG_ENC_NUM_CH(params->base.num_channels);
for (channel = 0, idx = 0; (idx < params->base.num_channels) && (channel < 2);
Add simplified and meaningful macro for row_3_4.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index a565f8d045..edb2ee50f4 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -33,6 +33,7 @@ #define SYS_REG_NUM_CH_MASK 1 #define SYS_REG_ROW_3_4_SHIFT(ch) (30 + (ch)) #define SYS_REG_ROW_3_4_MASK 1 +#define SYS_REG_ENC_ROW_3_4(n, ch) ((n) << (30 + (ch))) #define SYS_REG_CHINFO_SHIFT(ch) (28 + (ch)) #define SYS_REG_ENC_DDRTYPE(n) ((n) << SYS_REG_DDRTYPE_SHIFT) #define SYS_REG_ENC_NUM_CH(n) (((n) - SYS_REG_NUM_CH_MASK) << \ diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ad2d03729d..26bbb4208a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1020,7 +1020,7 @@ static void dram_all_config(struct dram_info *dram, if (params->ch[channel].col == 0) continue; idx++; - sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(channel); + sys_reg |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(channel); sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(channel); sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(channel);
Add simplified and meaningful macro for chip info.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index edb2ee50f4..d7d44749de 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -35,6 +35,7 @@ #define SYS_REG_ROW_3_4_MASK 1 #define SYS_REG_ENC_ROW_3_4(n, ch) ((n) << (30 + (ch))) #define SYS_REG_CHINFO_SHIFT(ch) (28 + (ch)) +#define SYS_REG_ENC_CHINFO(ch) (1 << SYS_REG_CHINFO_SHIFT(ch)) #define SYS_REG_ENC_DDRTYPE(n) ((n) << SYS_REG_DDRTYPE_SHIFT) #define SYS_REG_ENC_NUM_CH(n) (((n) - SYS_REG_NUM_CH_MASK) << \ SYS_REG_NUM_CH_SHIFT) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 26bbb4208a..7d071f998b 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1021,7 +1021,7 @@ static void dram_all_config(struct dram_info *dram, continue; idx++; sys_reg |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); - sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(channel); + sys_reg |= SYS_REG_ENC_CHINFO(channel); sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(channel); sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(channel); sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(channel);
Add simplified and meaningful macro for rank.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index d7d44749de..e2173aeeea 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -41,6 +41,8 @@ SYS_REG_NUM_CH_SHIFT) #define SYS_REG_RANK_SHIFT(ch) (11 + (ch) * 16) #define SYS_REG_RANK_MASK 1 +#define SYS_REG_ENC_RANK(n, ch) (((n) - SYS_REG_RANK_MASK) << \ + SYS_REG_RANK_SHIFT(ch)) #define SYS_REG_COL_SHIFT(ch) (9 + (ch) * 16) #define SYS_REG_COL_MASK 3 #define SYS_REG_BK_SHIFT(ch) (8 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 7d071f998b..acc8f17491 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1022,7 +1022,7 @@ static void dram_all_config(struct dram_info *dram, idx++; sys_reg |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); sys_reg |= SYS_REG_ENC_CHINFO(channel); - sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(channel); + sys_reg |= SYS_REG_ENC_RANK(info->rank, channel); sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(channel); sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(channel); sys_reg |= (info->cs0_row - 13) <<
Add simplified and meaningful macro for column.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index e2173aeeea..8cb564960d 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -45,6 +45,7 @@ SYS_REG_RANK_SHIFT(ch)) #define SYS_REG_COL_SHIFT(ch) (9 + (ch) * 16) #define SYS_REG_COL_MASK 3 +#define SYS_REG_ENC_COL(n, ch) (((n) - 9) << SYS_REG_COL_SHIFT(ch)) #define SYS_REG_BK_SHIFT(ch) (8 + (ch) * 16) #define SYS_REG_BK_MASK 1 #define SYS_REG_CS0_ROW_SHIFT(ch) (6 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index acc8f17491..ed2e0f54a2 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1023,7 +1023,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); sys_reg |= SYS_REG_ENC_CHINFO(channel); sys_reg |= SYS_REG_ENC_RANK(info->rank, channel); - sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(channel); + sys_reg |= SYS_REG_ENC_COL(info->col, channel); sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(channel); sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(channel);
Add simplified and meaningful macro for bk.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 8cb564960d..78cca88121 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -48,6 +48,8 @@ #define SYS_REG_ENC_COL(n, ch) (((n) - 9) << SYS_REG_COL_SHIFT(ch)) #define SYS_REG_BK_SHIFT(ch) (8 + (ch) * 16) #define SYS_REG_BK_MASK 1 +#define SYS_REG_ENC_BK(n, ch) (((n) == 3 ? 0 : 1) << \ + SYS_REG_BK_SHIFT(ch)) #define SYS_REG_CS0_ROW_SHIFT(ch) (6 + (ch) * 16) #define SYS_REG_CS0_ROW_MASK 3 #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ed2e0f54a2..77e7f92b5f 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1024,7 +1024,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= SYS_REG_ENC_CHINFO(channel); sys_reg |= SYS_REG_ENC_RANK(info->rank, channel); sys_reg |= SYS_REG_ENC_COL(info->col, channel); - sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(channel); + sys_reg |= SYS_REG_ENC_BK(info->bk, channel); sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(channel); sys_reg |= (info->cs1_row - 13) <<
Add simplified and meaningful macro for dbw.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 78cca88121..72cc9c94cc 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -58,6 +58,7 @@ #define SYS_REG_BW_MASK 3 #define SYS_REG_DBW_SHIFT(ch) ((ch) * 16) #define SYS_REG_DBW_MASK 3 +#define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << SYS_REG_DBW_SHIFT(ch))
/* Get sdram size decode from reg */ size_t rockchip_sdram_size(phys_addr_t reg); diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 77e7f92b5f..1a3285892a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1030,7 +1030,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(channel); sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel); - sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(channel); + sys_reg |= SYS_REG_ENC_DBW(info->dbw, channel);
ddr_msch_regs = dram->chan[channel].msch; noc_timing = ¶ms->ch[channel].noc_timings;
Add simplified and meaningful macro for cs0_rw.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 2 ++ drivers/ram/rockchip/sdram_rk3399.c | 3 +-- 2 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 72cc9c94cc..2b4745acbf 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -52,6 +52,8 @@ SYS_REG_BK_SHIFT(ch)) #define SYS_REG_CS0_ROW_SHIFT(ch) (6 + (ch) * 16) #define SYS_REG_CS0_ROW_MASK 3 +#define SYS_REG_ENC_CS0_ROW(n, ch) (((n) - 13) << \ + SYS_REG_CS0_ROW_SHIFT(ch)) #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) #define SYS_REG_CS1_ROW_MASK 3 #define SYS_REG_BW_SHIFT(ch) (2 + (ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1a3285892a..1907fc9eac 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1025,8 +1025,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= SYS_REG_ENC_RANK(info->rank, channel); sys_reg |= SYS_REG_ENC_COL(info->col, channel); sys_reg |= SYS_REG_ENC_BK(info->bk, channel); - sys_reg |= (info->cs0_row - 13) << - SYS_REG_CS0_ROW_SHIFT(channel); + sys_reg |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(channel); sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel);
Add simplified and meaningful macro for cs1_rw.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 2b4745acbf..bac3efac09 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -56,6 +56,8 @@ SYS_REG_CS0_ROW_SHIFT(ch)) #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) #define SYS_REG_CS1_ROW_MASK 3 +#define SYS_REG_ENC_CS1_ROW(n, ch) (((n) - 13) << \ + SYS_REG_CS1_ROW_SHIFT(ch)) #define SYS_REG_BW_SHIFT(ch) (2 + (ch) * 16) #define SYS_REG_BW_MASK 3 #define SYS_REG_DBW_SHIFT(ch) ((ch) * 16) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1907fc9eac..988672672f 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1026,8 +1026,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= SYS_REG_ENC_COL(info->col, channel); sys_reg |= SYS_REG_ENC_BK(info->bk, channel); sys_reg |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); - sys_reg |= (info->cs1_row - 13) << - SYS_REG_CS1_ROW_SHIFT(channel); + sys_reg |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel); sys_reg |= SYS_REG_ENC_DBW(info->dbw, channel);
Add simplified and meaningful macro for bw.
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index bac3efac09..c2374c0f83 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -60,6 +60,7 @@ SYS_REG_CS1_ROW_SHIFT(ch)) #define SYS_REG_BW_SHIFT(ch) (2 + (ch) * 16) #define SYS_REG_BW_MASK 3 +#define SYS_REG_ENC_BW(n, ch) ((2 >> (n)) << SYS_REG_BW_SHIFT(ch)) #define SYS_REG_DBW_SHIFT(ch) ((ch) * 16) #define SYS_REG_DBW_MASK 3 #define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << SYS_REG_DBW_SHIFT(ch)) diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 988672672f..e8203e4c32 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1027,7 +1027,7 @@ static void dram_all_config(struct dram_info *dram, sys_reg |= SYS_REG_ENC_BK(info->bk, channel); sys_reg |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); sys_reg |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); - sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(channel); + sys_reg |= SYS_REG_ENC_BW(info->bw, channel); sys_reg |= SYS_REG_ENC_DBW(info->dbw, channel);
Use dram config variable name as sys_reg2 instead of sys_reg since the final variable value is to written into a pmugrf register named as sys_reg2.
This reflect the both variable and associated register names are same and also help to add next sys_reg's to add it in future.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e8203e4c32..bb673a862e 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1004,11 +1004,11 @@ static void set_ddrconfig(const struct chan_info *chan, static void dram_all_config(struct dram_info *dram, const struct rk3399_sdram_params *params) { - u32 sys_reg = 0; + u32 sys_reg2 = 0; unsigned int channel, idx;
- sys_reg |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); - sys_reg |= SYS_REG_ENC_NUM_CH(params->base.num_channels); + sys_reg2 |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); + sys_reg2 |= SYS_REG_ENC_NUM_CH(params->base.num_channels);
for (channel = 0, idx = 0; (idx < params->base.num_channels) && (channel < 2); @@ -1020,15 +1020,15 @@ static void dram_all_config(struct dram_info *dram, if (params->ch[channel].col == 0) continue; idx++; - sys_reg |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); - sys_reg |= SYS_REG_ENC_CHINFO(channel); - sys_reg |= SYS_REG_ENC_RANK(info->rank, channel); - sys_reg |= SYS_REG_ENC_COL(info->col, channel); - sys_reg |= SYS_REG_ENC_BK(info->bk, channel); - sys_reg |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); - sys_reg |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); - sys_reg |= SYS_REG_ENC_BW(info->bw, channel); - sys_reg |= SYS_REG_ENC_DBW(info->dbw, channel); + sys_reg2 |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); + sys_reg2 |= SYS_REG_ENC_CHINFO(channel); + sys_reg2 |= SYS_REG_ENC_RANK(info->rank, channel); + sys_reg2 |= SYS_REG_ENC_COL(info->col, channel); + sys_reg2 |= SYS_REG_ENC_BK(info->bk, channel); + sys_reg2 |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); + sys_reg2 |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); + sys_reg2 |= SYS_REG_ENC_BW(info->bw, channel); + sys_reg2 |= SYS_REG_ENC_DBW(info->dbw, channel);
ddr_msch_regs = dram->chan[channel].msch; noc_timing = ¶ms->ch[channel].noc_timings; @@ -1049,7 +1049,7 @@ static void dram_all_config(struct dram_info *dram, 1 << 17); }
- writel(sys_reg, &dram->pmugrf->os_reg2); + writel(sys_reg2, &dram->pmugrf->os_reg2); rk_clrsetreg(&dram->pmusgrf->soc_con4, 0x1f << 10, params->base.stride << 10);
cs0_row can handle the pmu via sys_reg2 and sys_reg3 while configuring the dram instead of just sys_reg2.
So, update cs0_row macro to make use of both sys_reg2, sys_reg3.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 8 ++++++-- drivers/ram/rockchip/sdram_rk3399.c | 4 +++- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index c2374c0f83..4fe7d60daf 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -52,8 +52,6 @@ SYS_REG_BK_SHIFT(ch)) #define SYS_REG_CS0_ROW_SHIFT(ch) (6 + (ch) * 16) #define SYS_REG_CS0_ROW_MASK 3 -#define SYS_REG_ENC_CS0_ROW(n, ch) (((n) - 13) << \ - SYS_REG_CS0_ROW_SHIFT(ch)) #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) #define SYS_REG_CS1_ROW_MASK 3 #define SYS_REG_ENC_CS1_ROW(n, ch) (((n) - 13) << \ @@ -65,6 +63,12 @@ #define SYS_REG_DBW_MASK 3 #define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << SYS_REG_DBW_SHIFT(ch))
+#define SYS_REG_ENC_CS0_ROW(n, os_reg2, os_reg3, ch) do { \ + (os_reg2) |= (((n) - 13) & 0x3) << (6 + 16 * (ch)); \ + (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ + (5 + 2 * (ch)); \ + } while (0) + /* Get sdram size decode from reg */ size_t rockchip_sdram_size(phys_addr_t reg);
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index bb673a862e..40cc31601c 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1005,6 +1005,7 @@ static void dram_all_config(struct dram_info *dram, const struct rk3399_sdram_params *params) { u32 sys_reg2 = 0; + u32 sys_reg3 = 0; unsigned int channel, idx;
sys_reg2 |= SYS_REG_ENC_DDRTYPE(params->base.dramtype); @@ -1025,10 +1026,10 @@ static void dram_all_config(struct dram_info *dram, sys_reg2 |= SYS_REG_ENC_RANK(info->rank, channel); sys_reg2 |= SYS_REG_ENC_COL(info->col, channel); sys_reg2 |= SYS_REG_ENC_BK(info->bk, channel); - sys_reg2 |= SYS_REG_ENC_CS0_ROW(info->cs0_row, channel); sys_reg2 |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); sys_reg2 |= SYS_REG_ENC_BW(info->bw, channel); sys_reg2 |= SYS_REG_ENC_DBW(info->dbw, channel); + SYS_REG_ENC_CS0_ROW(info->cs0_row, sys_reg2, sys_reg3, channel);
ddr_msch_regs = dram->chan[channel].msch; noc_timing = ¶ms->ch[channel].noc_timings; @@ -1050,6 +1051,7 @@ static void dram_all_config(struct dram_info *dram, }
writel(sys_reg2, &dram->pmugrf->os_reg2); + writel(sys_reg3, &dram->pmugrf->os_reg3); rk_clrsetreg(&dram->pmusgrf->soc_con4, 0x1f << 10, params->base.stride << 10);
cs1_row can handle the pmu via sys_reg2 and sys_reg3 while configuring the dram instead of just sys_reg2.
So, update cs1_row macro to make use of both sys_reg2, sys_reg3.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 10 ++++++++-- drivers/ram/rockchip/sdram_rk3399.c | 4 +++- 2 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 4fe7d60daf..7062cb57d9 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -54,8 +54,6 @@ #define SYS_REG_CS0_ROW_MASK 3 #define SYS_REG_CS1_ROW_SHIFT(ch) (4 + (ch) * 16) #define SYS_REG_CS1_ROW_MASK 3 -#define SYS_REG_ENC_CS1_ROW(n, ch) (((n) - 13) << \ - SYS_REG_CS1_ROW_SHIFT(ch)) #define SYS_REG_BW_SHIFT(ch) (2 + (ch) * 16) #define SYS_REG_BW_MASK 3 #define SYS_REG_ENC_BW(n, ch) ((2 >> (n)) << SYS_REG_BW_SHIFT(ch)) @@ -69,6 +67,14 @@ (5 + 2 * (ch)); \ } while (0)
+#define SYS_REG_ENC_CS1_ROW(n, os_reg2, os_reg3, ch) do { \ + (os_reg2) &= (~(0x3 << (4 + 16 * (ch)))); \ + (os_reg3) &= (~(0x1 << (4 + 2 * (ch)))); \ + (os_reg2) |= (((n) - 13) & 0x3) << (4 + 16 * (ch)); \ + (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ + (4 + 2 * (ch)); \ + } while (0) + /* Get sdram size decode from reg */ size_t rockchip_sdram_size(phys_addr_t reg);
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 40cc31601c..21c1c6566a 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1026,10 +1026,12 @@ static void dram_all_config(struct dram_info *dram, sys_reg2 |= SYS_REG_ENC_RANK(info->rank, channel); sys_reg2 |= SYS_REG_ENC_COL(info->col, channel); sys_reg2 |= SYS_REG_ENC_BK(info->bk, channel); - sys_reg2 |= SYS_REG_ENC_CS1_ROW(info->cs1_row, channel); sys_reg2 |= SYS_REG_ENC_BW(info->bw, channel); sys_reg2 |= SYS_REG_ENC_DBW(info->dbw, channel); SYS_REG_ENC_CS0_ROW(info->cs0_row, sys_reg2, sys_reg3, channel); + if (info->cs1_row) + SYS_REG_ENC_CS1_ROW(info->cs1_row, sys_reg2, + sys_reg3, channel);
Add dram config macro for handling cs1 column.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 3 +++ drivers/ram/rockchip/sdram_rk3399.c | 1 + 2 files changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 7062cb57d9..e5145422cc 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -75,6 +75,9 @@ (4 + 2 * (ch)); \ } while (0)
+#define SYS_REG_CS1_COL_SHIFT(ch) (0 + 2 * (ch)) +#define SYS_REG_ENC_CS1_COL(n, ch) (((n) - 9) << SYS_REG_CS1_COL_SHIFT(ch)) + /* Get sdram size decode from reg */ size_t rockchip_sdram_size(phys_addr_t reg);
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 21c1c6566a..14e2afcbc4 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1032,6 +1032,7 @@ static void dram_all_config(struct dram_info *dram, if (info->cs1_row) SYS_REG_ENC_CS1_ROW(info->cs1_row, sys_reg2, sys_reg3, channel); + sys_reg3 |= SYS_REG_ENC_CS1_COL(info->col, channel);
Add dram config macro for handling ddr version number.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 2 ++ drivers/ram/rockchip/sdram_rk3399.c | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index e5145422cc..0eb068dcc0 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -28,6 +28,7 @@ * [1:0] dbw_ch0 */ #define SYS_REG_DDRTYPE_SHIFT 13 +#define DDR_SYS_REG_VERSION 2 #define SYS_REG_DDRTYPE_MASK 7 #define SYS_REG_NUM_CH_SHIFT 12 #define SYS_REG_NUM_CH_MASK 1 @@ -61,6 +62,7 @@ #define SYS_REG_DBW_MASK 3 #define SYS_REG_ENC_DBW(n, ch) ((2 >> (n)) << SYS_REG_DBW_SHIFT(ch))
+#define SYS_REG_ENC_VERSION(n) ((n) << 28) #define SYS_REG_ENC_CS0_ROW(n, os_reg2, os_reg3, ch) do { \ (os_reg2) |= (((n) - 13) & 0x3) << (6 + 16 * (ch)); \ (os_reg3) |= ((((n) - 13) & 0x4) >> 2) << \ diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 14e2afcbc4..a8100749b0 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1032,7 +1032,9 @@ static void dram_all_config(struct dram_info *dram, if (info->cs1_row) SYS_REG_ENC_CS1_ROW(info->cs1_row, sys_reg2, sys_reg3, channel); + sys_reg3 |= SYS_REG_ENC_CS1_COL(info->col, channel); + sys_reg3 |= SYS_REG_ENC_VERSION(DDR_SYS_REG_VERSION);
Add DdrTimingC0 structure with associated bit fields.
These would help to reconfigure sdram capabilities during lpddr4 setup related configs.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-rockchip/sdram_rk3399.h | 12 +++++++++++- drivers/ram/rockchip/sdram_rk3399.c | 2 +- 2 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index c6a260bad8..924eeb3bac 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -26,6 +26,16 @@ struct rk3399_ddr_pi_regs { u32 denali_pi[200]; };
+union noc_ddrtimingc0 { + u32 d32; + struct { + unsigned burstpenalty : 4; + unsigned reserved0 : 4; + unsigned wrtomwr : 6; + unsigned reserved1 : 18; + } b; +}; + struct rk3399_msch_regs { u32 coreid; u32 revisionid; @@ -44,7 +54,7 @@ struct rk3399_msch_regs { struct rk3399_msch_timings { u32 ddrtiminga0; u32 ddrtimingb0; - u32 ddrtimingc0; + union noc_ddrtimingc0 ddrtimingc0; u32 devtodev0; u32 ddrmode; u32 agingx0; diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index a8100749b0..787cdc6b52 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1042,7 +1042,7 @@ static void dram_all_config(struct dram_info *dram, &ddr_msch_regs->ddrtiminga0); writel(noc_timing->ddrtimingb0, &ddr_msch_regs->ddrtimingb0); - writel(noc_timing->ddrtimingc0, + writel(noc_timing->ddrtimingc0.d32, &ddr_msch_regs->ddrtimingc0); writel(noc_timing->devtodev0, &ddr_msch_regs->devtodev0);
Add DdrMode structure with associated bit fields.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../include/asm/arch-rockchip/sdram_rk3399.h | 17 ++++++++++++++++- drivers/ram/rockchip/sdram_rk3399.c | 2 +- 2 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index 924eeb3bac..a191d242f8 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -36,6 +36,21 @@ union noc_ddrtimingc0 { } b; };
+union noc_ddrmode { + u32 d32; + struct { + unsigned autoprecharge : 1; + unsigned bypassfiltering : 1; + unsigned fawbank : 1; + unsigned burstsize : 2; + unsigned mwrsize : 2; + unsigned reserved2 : 1; + unsigned forceorder : 8; + unsigned forceorderstate : 8; + unsigned reserved3 : 8; + } b; +}; + struct rk3399_msch_regs { u32 coreid; u32 revisionid; @@ -56,7 +71,7 @@ struct rk3399_msch_timings { u32 ddrtimingb0; union noc_ddrtimingc0 ddrtimingc0; u32 devtodev0; - u32 ddrmode; + union noc_ddrmode ddrmode; u32 agingx0; };
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 787cdc6b52..dc9229ddf3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1046,7 +1046,7 @@ static void dram_all_config(struct dram_info *dram, &ddr_msch_regs->ddrtimingc0); writel(noc_timing->devtodev0, &ddr_msch_regs->devtodev0); - writel(noc_timing->ddrmode, + writel(noc_timing->ddrmode.d32, &ddr_msch_regs->ddrmode);
Add proper return type handling of pctl_cfg with meaningful print statement.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index dc9229ddf3..d408459daf 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1119,6 +1119,7 @@ static int sdram_init(struct dram_info *dram, unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; int channel; + int ret;
@@ -1138,9 +1139,10 @@ static int sdram_init(struct dram_info *dram, if (channel >= params->base.num_channels) continue;
- if (pctl_cfg(chan, channel, params) != 0) { - printf("pctl_cfg fail, reset\n"); - return -EIO; + ret = pctl_cfg(chan, channel, params); + if (ret < 0) { + printf("%s: pctl config failed\n", __func__); + return ret; }
/* LPDDR2/LPDDR3 need to wait DAI complete, max 10us */
Rename tsel_wr_select_n to tsel_wr_select_dq_n based on the bsp code.
No functionality change.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index d408459daf..1747ae12a3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -161,7 +161,7 @@ static void set_ds_odt(const struct chan_info *chan, u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; u32 tsel_idle_select_p, tsel_wr_select_p, tsel_rd_select_p; u32 ca_tsel_wr_select_p, ca_tsel_wr_select_n; - u32 tsel_idle_select_n, tsel_wr_select_n, tsel_rd_select_n; + u32 tsel_idle_select_n, tsel_wr_select_dq_n, tsel_rd_select_n; u32 reg_value;
if (params->base.dramtype == LPDDR4) { @@ -171,7 +171,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_p = PHY_DRV_ODT_HI_Z;
tsel_rd_select_n = PHY_DRV_ODT_240; - tsel_wr_select_n = PHY_DRV_ODT_40; + tsel_wr_select_dq_n = PHY_DRV_ODT_40; ca_tsel_wr_select_n = PHY_DRV_ODT_40; tsel_idle_select_n = PHY_DRV_ODT_240; } else if (params->base.dramtype == LPDDR3) { @@ -181,7 +181,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_p = PHY_DRV_ODT_240;
tsel_rd_select_n = PHY_DRV_ODT_HI_Z; - tsel_wr_select_n = PHY_DRV_ODT_34_3; + tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; ca_tsel_wr_select_n = PHY_DRV_ODT_48; tsel_idle_select_n = PHY_DRV_ODT_HI_Z; } else { @@ -191,7 +191,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_p = PHY_DRV_ODT_240;
tsel_rd_select_n = PHY_DRV_ODT_240; - tsel_wr_select_n = PHY_DRV_ODT_34_3; + tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; ca_tsel_wr_select_n = PHY_DRV_ODT_34_3; tsel_idle_select_n = PHY_DRV_ODT_240; } @@ -210,7 +210,7 @@ static void set_ds_odt(const struct chan_info *chan, * for write cycles for DQ/DM */ reg_value = tsel_rd_select_n | (tsel_rd_select_p << 0x4) | - (tsel_wr_select_n << 8) | (tsel_wr_select_p << 12) | + (tsel_wr_select_dq_n << 8) | (tsel_wr_select_p << 12) | (tsel_idle_select_n << 16) | (tsel_idle_select_p << 20); clrsetbits_le32(&denali_phy[6], 0xffffff, reg_value); clrsetbits_le32(&denali_phy[134], 0xffffff, reg_value); @@ -250,7 +250,7 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_pad_fdbk_drive 23bit DENALI_PHY_924/925 */ clrsetbits_le32(&denali_phy[924], 0xff, - tsel_wr_select_n | (tsel_wr_select_p << 4)); + tsel_wr_select_dq_n | (tsel_wr_select_p << 4)); clrsetbits_le32(&denali_phy[925], 0xff, tsel_rd_select_n | (tsel_rd_select_p << 4));
Rename tsel_wr_select_p to tsel_wr_select_dq_p based on the bsp code.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1747ae12a3..172703ea86 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -159,14 +159,14 @@ static void set_ds_odt(const struct chan_info *chan, u32 *denali_phy = chan->publ->denali_phy;
u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; - u32 tsel_idle_select_p, tsel_wr_select_p, tsel_rd_select_p; + u32 tsel_idle_select_p, tsel_wr_select_dq_p, tsel_rd_select_p; u32 ca_tsel_wr_select_p, ca_tsel_wr_select_n; u32 tsel_idle_select_n, tsel_wr_select_dq_n, tsel_rd_select_n; u32 reg_value;
if (params->base.dramtype == LPDDR4) { tsel_rd_select_p = PHY_DRV_ODT_HI_Z; - tsel_wr_select_p = PHY_DRV_ODT_40; + tsel_wr_select_dq_p = PHY_DRV_ODT_40; ca_tsel_wr_select_p = PHY_DRV_ODT_40; tsel_idle_select_p = PHY_DRV_ODT_HI_Z;
@@ -176,7 +176,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_n = PHY_DRV_ODT_240; } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; - tsel_wr_select_p = PHY_DRV_ODT_34_3; + tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; ca_tsel_wr_select_p = PHY_DRV_ODT_48; tsel_idle_select_p = PHY_DRV_ODT_240;
@@ -186,7 +186,7 @@ static void set_ds_odt(const struct chan_info *chan, tsel_idle_select_n = PHY_DRV_ODT_HI_Z; } else { tsel_rd_select_p = PHY_DRV_ODT_240; - tsel_wr_select_p = PHY_DRV_ODT_34_3; + tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; ca_tsel_wr_select_p = PHY_DRV_ODT_34_3; tsel_idle_select_p = PHY_DRV_ODT_240;
@@ -210,7 +210,7 @@ static void set_ds_odt(const struct chan_info *chan, * for write cycles for DQ/DM */ reg_value = tsel_rd_select_n | (tsel_rd_select_p << 0x4) | - (tsel_wr_select_dq_n << 8) | (tsel_wr_select_p << 12) | + (tsel_wr_select_dq_n << 8) | (tsel_wr_select_dq_p << 12) | (tsel_idle_select_n << 16) | (tsel_idle_select_p << 20); clrsetbits_le32(&denali_phy[6], 0xffffff, reg_value); clrsetbits_le32(&denali_phy[134], 0xffffff, reg_value); @@ -250,7 +250,7 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_pad_fdbk_drive 23bit DENALI_PHY_924/925 */ clrsetbits_le32(&denali_phy[924], 0xff, - tsel_wr_select_dq_n | (tsel_wr_select_p << 4)); + tsel_wr_select_dq_n | (tsel_wr_select_dq_p << 4)); clrsetbits_le32(&denali_phy[925], 0xff, tsel_rd_select_n | (tsel_rd_select_p << 4));
Rename ca_tsel_wr_select_n to tsel_wr_select_ca_n based on the bsp code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 172703ea86..d54e99278c 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -160,7 +160,7 @@ static void set_ds_odt(const struct chan_info *chan,
u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; u32 tsel_idle_select_p, tsel_wr_select_dq_p, tsel_rd_select_p; - u32 ca_tsel_wr_select_p, ca_tsel_wr_select_n; + u32 ca_tsel_wr_select_p, tsel_wr_select_ca_n; u32 tsel_idle_select_n, tsel_wr_select_dq_n, tsel_rd_select_n; u32 reg_value;
@@ -172,7 +172,7 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_rd_select_n = PHY_DRV_ODT_240; tsel_wr_select_dq_n = PHY_DRV_ODT_40; - ca_tsel_wr_select_n = PHY_DRV_ODT_40; + tsel_wr_select_ca_n = PHY_DRV_ODT_40; tsel_idle_select_n = PHY_DRV_ODT_240; } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; @@ -182,7 +182,7 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_rd_select_n = PHY_DRV_ODT_HI_Z; tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; - ca_tsel_wr_select_n = PHY_DRV_ODT_48; + tsel_wr_select_ca_n = PHY_DRV_ODT_48; tsel_idle_select_n = PHY_DRV_ODT_HI_Z; } else { tsel_rd_select_p = PHY_DRV_ODT_240; @@ -192,7 +192,7 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_rd_select_n = PHY_DRV_ODT_240; tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; - ca_tsel_wr_select_n = PHY_DRV_ODT_34_3; + tsel_wr_select_ca_n = PHY_DRV_ODT_34_3; tsel_idle_select_n = PHY_DRV_ODT_240; }
@@ -228,7 +228,7 @@ static void set_ds_odt(const struct chan_info *chan, clrsetbits_le32(&denali_phy[391], 0xffffff, reg_value);
/* phy_adr_tsel_select_ 8bits DENALI_PHY_544/672/800 offset_0 */ - reg_value = ca_tsel_wr_select_n | (ca_tsel_wr_select_p << 0x4); + reg_value = tsel_wr_select_ca_n | (ca_tsel_wr_select_p << 0x4); clrsetbits_le32(&denali_phy[544], 0xff, reg_value); clrsetbits_le32(&denali_phy[672], 0xff, reg_value); clrsetbits_le32(&denali_phy[800], 0xff, reg_value);
Rename ca_tsel_wr_select_p to tsel_wr_select_ca_p based on the bsp code.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index d54e99278c..78010c707f 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -160,14 +160,14 @@ static void set_ds_odt(const struct chan_info *chan,
u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; u32 tsel_idle_select_p, tsel_wr_select_dq_p, tsel_rd_select_p; - u32 ca_tsel_wr_select_p, tsel_wr_select_ca_n; + u32 tsel_wr_select_ca_p, tsel_wr_select_ca_n; u32 tsel_idle_select_n, tsel_wr_select_dq_n, tsel_rd_select_n; u32 reg_value;
if (params->base.dramtype == LPDDR4) { tsel_rd_select_p = PHY_DRV_ODT_HI_Z; tsel_wr_select_dq_p = PHY_DRV_ODT_40; - ca_tsel_wr_select_p = PHY_DRV_ODT_40; + tsel_wr_select_ca_p = PHY_DRV_ODT_40; tsel_idle_select_p = PHY_DRV_ODT_HI_Z;
tsel_rd_select_n = PHY_DRV_ODT_240; @@ -177,7 +177,7 @@ static void set_ds_odt(const struct chan_info *chan, } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; - ca_tsel_wr_select_p = PHY_DRV_ODT_48; + tsel_wr_select_ca_p = PHY_DRV_ODT_48; tsel_idle_select_p = PHY_DRV_ODT_240;
tsel_rd_select_n = PHY_DRV_ODT_HI_Z; @@ -187,7 +187,7 @@ static void set_ds_odt(const struct chan_info *chan, } else { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; - ca_tsel_wr_select_p = PHY_DRV_ODT_34_3; + tsel_wr_select_ca_p = PHY_DRV_ODT_34_3; tsel_idle_select_p = PHY_DRV_ODT_240;
tsel_rd_select_n = PHY_DRV_ODT_240; @@ -228,7 +228,7 @@ static void set_ds_odt(const struct chan_info *chan, clrsetbits_le32(&denali_phy[391], 0xffffff, reg_value);
/* phy_adr_tsel_select_ 8bits DENALI_PHY_544/672/800 offset_0 */ - reg_value = tsel_wr_select_ca_n | (ca_tsel_wr_select_p << 0x4); + reg_value = tsel_wr_select_ca_n | (tsel_wr_select_ca_p << 0x4); clrsetbits_le32(&denali_phy[544], 0xff, reg_value); clrsetbits_le32(&denali_phy[672], 0xff, reg_value); clrsetbits_le32(&denali_phy[800], 0xff, reg_value);
Order tsel* variable declarations and assignment in proper and meaningful way.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 37 +++++++++++++++++------------ 1 file changed, 22 insertions(+), 15 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 78010c707f..f81ea1bdbf 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -159,41 +159,48 @@ static void set_ds_odt(const struct chan_info *chan, u32 *denali_phy = chan->publ->denali_phy;
u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; - u32 tsel_idle_select_p, tsel_wr_select_dq_p, tsel_rd_select_p; - u32 tsel_wr_select_ca_p, tsel_wr_select_ca_n; - u32 tsel_idle_select_n, tsel_wr_select_dq_n, tsel_rd_select_n; + u32 tsel_idle_select_p, tsel_rd_select_p; + u32 tsel_idle_select_n, tsel_rd_select_n; + u32 tsel_wr_select_dq_p, tsel_wr_select_ca_p; + u32 tsel_wr_select_dq_n, tsel_wr_select_ca_n; u32 reg_value;
if (params->base.dramtype == LPDDR4) { tsel_rd_select_p = PHY_DRV_ODT_HI_Z; - tsel_wr_select_dq_p = PHY_DRV_ODT_40; - tsel_wr_select_ca_p = PHY_DRV_ODT_40; + tsel_rd_select_n = PHY_DRV_ODT_240; + tsel_idle_select_p = PHY_DRV_ODT_HI_Z; + tsel_idle_select_n = PHY_DRV_ODT_240;
- tsel_rd_select_n = PHY_DRV_ODT_240; + tsel_wr_select_dq_p = PHY_DRV_ODT_40; tsel_wr_select_dq_n = PHY_DRV_ODT_40; + + tsel_wr_select_ca_p = PHY_DRV_ODT_40; tsel_wr_select_ca_n = PHY_DRV_ODT_40; - tsel_idle_select_n = PHY_DRV_ODT_240; } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; - tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; - tsel_wr_select_ca_p = PHY_DRV_ODT_48; + tsel_rd_select_n = PHY_DRV_ODT_HI_Z; + tsel_idle_select_p = PHY_DRV_ODT_240; + tsel_idle_select_n = PHY_DRV_ODT_HI_Z;
- tsel_rd_select_n = PHY_DRV_ODT_HI_Z; + tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; + + tsel_wr_select_ca_p = PHY_DRV_ODT_48; tsel_wr_select_ca_n = PHY_DRV_ODT_48; - tsel_idle_select_n = PHY_DRV_ODT_HI_Z; } else { tsel_rd_select_p = PHY_DRV_ODT_240; - tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; - tsel_wr_select_ca_p = PHY_DRV_ODT_34_3; + tsel_rd_select_n = PHY_DRV_ODT_240; + tsel_idle_select_p = PHY_DRV_ODT_240; + tsel_idle_select_n = PHY_DRV_ODT_240;
- tsel_rd_select_n = PHY_DRV_ODT_240; + tsel_wr_select_dq_p = PHY_DRV_ODT_34_3; tsel_wr_select_dq_n = PHY_DRV_ODT_34_3; + + tsel_wr_select_ca_p = PHY_DRV_ODT_34_3; tsel_wr_select_ca_n = PHY_DRV_ODT_34_3; - tsel_idle_select_n = PHY_DRV_ODT_240; }
if (params->base.odt == 1)
Add support for phy pctrl reset support for both channel 0, 1.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index f81ea1bdbf..313a177417 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -35,6 +35,10 @@ #define PHY_DRV_ODT_40 0xe #define PHY_DRV_ODT_34_3 0xf
+#define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ + ((n) << (8 + (ch) * 4))) +#define CRU_SFTRST_DDR_PHY(ch, n) ((0x1 << (9 + 16 + (ch) * 4)) | \ + ((n) << (9 + (ch) * 4))) struct chan_info { struct rk3399_ddr_pctl_regs *pctl; struct rk3399_ddr_pi_regs *pi; @@ -79,6 +83,29 @@ static void copy_to_reg(u32 *dest, const u32 *src, u32 n) } }
+static void rkclk_ddr_reset(struct rk3399_cru *cru, u32 channel, u32 ctl, + u32 phy) +{ + channel &= 0x1; + ctl &= 0x1; + phy &= 0x1; + writel(CRU_SFTRST_DDR_CTRL(channel, ctl) | + CRU_SFTRST_DDR_PHY(channel, phy), + &cru->softrst_con[4]); +} + +static void phy_pctrl_reset(struct rk3399_cru *cru, u32 channel) +{ + rkclk_ddr_reset(cru, channel, 1, 1); + udelay(10); + + rkclk_ddr_reset(cru, channel, 1, 0); + udelay(10); + + rkclk_ddr_reset(cru, channel, 0, 0); + udelay(10); +} + static void phy_dll_bypass_set(struct rk3399_ddr_publ_regs *ddr_publ_regs, u32 freq) { @@ -1125,6 +1152,7 @@ static int sdram_init(struct dram_info *dram, { unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; + struct rk3399_cru *cru = dram->cru; int channel; int ret;
@@ -1141,6 +1169,7 @@ static int sdram_init(struct dram_info *dram, const struct chan_info *chan = &dram->chan[channel]; struct rk3399_ddr_publ_regs *publ = chan->publ;
+ phy_pctrl_reset(cru, channel); phy_dll_bypass_set(publ, ddr_freq);
Add pwrup_srefresh_exit to be part of dram_info so-that the it can help to support pwrup_srefresh_exit in individual channels while starting pctl in future.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 313a177417..1362a5bf2d 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -49,6 +49,7 @@ struct chan_info { struct dram_info { #if defined(CONFIG_TPL_BUILD) || \ (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + u32 pwrup_srefresh_exit; struct chan_info chan[2]; struct clk ddr_clk; struct rk3399_cru *cru; @@ -486,8 +487,8 @@ static int phy_io_config(const struct chan_info *chan, return 0; }
-static int pctl_cfg(const struct chan_info *chan, u32 channel, - const struct rk3399_sdram_params *params) +static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, + u32 channel, const struct rk3399_sdram_params *params) { u32 *denali_ctl = chan->pctl->denali_ctl; u32 *denali_pi = chan->pi->denali_pi; @@ -495,7 +496,6 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, const u32 *params_ctl = params->pctl_regs.denali_ctl; const u32 *params_phy = params->phy_regs.denali_phy; u32 tmp, tmp1, tmp2; - u32 pwrup_srefresh_exit; int ret; const ulong timeout_ms = 200;
@@ -515,7 +515,8 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, writel(params->phy_regs.denali_phy[911], &denali_phy[911]); writel(params->phy_regs.denali_phy[912], &denali_phy[912]);
- pwrup_srefresh_exit = readl(&denali_ctl[68]) & PWRUP_SREFRESH_EXIT; + dram->pwrup_srefresh_exit = readl(&denali_ctl[68]) & + PWRUP_SREFRESH_EXIT; clrbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT);
/* PHY_DLL_RST_EN */ @@ -591,7 +592,7 @@ static int pctl_cfg(const struct chan_info *chan, u32 channel, debug("DRAM (%s): phy locked after %ld ms\n", __func__, get_timer(tmp));
clrsetbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT, - pwrup_srefresh_exit); + dram->pwrup_srefresh_exit); return 0; }
@@ -1175,7 +1176,7 @@ static int sdram_init(struct dram_info *dram, if (channel >= params->base.num_channels) continue;
- ret = pctl_cfg(chan, channel, params); + ret = pctl_cfg(dram, chan, channel, params); if (ret < 0) { printf("%s: pctl config failed\n", __func__); return ret;
Add support for pctl start for both channel 0, 1 control and phy registers.
This would also handle pwrup_srefresh_exit init based on the channel number.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 75 +++++++++++++++++++++-------- 1 file changed, 55 insertions(+), 20 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1362a5bf2d..6c3a2b5453 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -49,10 +49,11 @@ struct chan_info { struct dram_info { #if defined(CONFIG_TPL_BUILD) || \ (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) - u32 pwrup_srefresh_exit; + u32 pwrup_srefresh_exit[2]; struct chan_info chan[2]; struct clk ddr_clk; struct rk3399_cru *cru; + struct rk3399_grf_regs *grf; struct rk3399_pmucru *pmucru; struct rk3399_pmusgrf_regs *pmusgrf; struct rk3399_ddr_cic_regs *cic; @@ -73,6 +74,11 @@ struct rockchip_dmc_plat { struct regmap *map; };
+static void *get_ddrc0_con(struct dram_info *dram, u8 channel) +{ + return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc0_con1; +} + static void copy_to_reg(u32 *dest, const u32 *src, u32 n) { int i; @@ -327,6 +333,48 @@ static void set_ds_odt(const struct chan_info *chan, clrsetbits_le32(&denali_phy[930], 0x1 << 17, reg_value); }
+static void pctl_start(struct dram_info *dram, u8 channel) +{ + const struct chan_info *chan = &dram->chan[channel]; + u32 *denali_ctl = chan->pctl->denali_ctl; + u32 *denali_phy = chan->publ->denali_phy; + u32 *ddrc0_con = get_ddrc0_con(dram, channel); + u32 count = 0; + u32 byte, tmp; + + writel(0x01000000, &ddrc0_con); + + clrsetbits_le32(&denali_phy[957], 0x3 << 24, 0x2 << 24); + + while (!(readl(&denali_ctl[203]) & (1 << 3))) { + if (count > 1000) { + printf("%s: Failed to init pctl for channel %d\n", + __func__, channel); + while (1) + ; + } + + udelay(1); + count++; + } + + writel(0x01000100, &ddrc0_con); + + for (byte = 0; byte < 4; byte++) { + tmp = 0x820; + writel((tmp << 16) | tmp, &denali_phy[53 + (128 * byte)]); + writel((tmp << 16) | tmp, &denali_phy[54 + (128 * byte)]); + writel((tmp << 16) | tmp, &denali_phy[55 + (128 * byte)]); + writel((tmp << 16) | tmp, &denali_phy[56 + (128 * byte)]); + writel((tmp << 16) | tmp, &denali_phy[57 + (128 * byte)]); + + clrsetbits_le32(&denali_phy[58 + (128 * byte)], 0xffff, tmp); + } + + clrsetbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT, + dram->pwrup_srefresh_exit[channel]); +} + static int phy_io_config(const struct chan_info *chan, const struct rk3399_sdram_params *params) { @@ -497,7 +545,6 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, const u32 *params_phy = params->phy_regs.denali_phy; u32 tmp, tmp1, tmp2; int ret; - const ulong timeout_ms = 200;
/* * work around controller bug: @@ -515,8 +562,8 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, writel(params->phy_regs.denali_phy[911], &denali_phy[911]); writel(params->phy_regs.denali_phy[912], &denali_phy[912]);
- dram->pwrup_srefresh_exit = readl(&denali_ctl[68]) & - PWRUP_SREFRESH_EXIT; + dram->pwrup_srefresh_exit[channel] = readl(&denali_ctl[68]) & + PWRUP_SREFRESH_EXIT; clrbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT);
/* PHY_DLL_RST_EN */ @@ -577,22 +624,6 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, if (ret) return ret;
- /* PHY_DLL_RST_EN */ - clrsetbits_le32(&denali_phy[957], 0x3 << 24, 0x2 << 24); - - /* Waiting for PHY and DRAM init complete */ - tmp = get_timer(0); - do { - if (get_timer(tmp) > timeout_ms) { - pr_err("DRAM (%s): phy failed to lock within %ld ms\n", - __func__, timeout_ms); - return -ETIME; - } - } while (!(readl(&denali_ctl[203]) & (1 << 3))); - debug("DRAM (%s): phy locked after %ld ms\n", __func__, get_timer(tmp)); - - clrsetbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT, - dram->pwrup_srefresh_exit); return 0; }
@@ -1182,6 +1213,9 @@ static int sdram_init(struct dram_info *dram, return ret; }
+ /* start to trigger initialization */ + pctl_start(dram, channel); + /* LPDDR2/LPDDR3 need to wait DAI complete, max 10us */ if (dramtype == LPDDR3) udelay(10); @@ -1258,6 +1292,7 @@ static int rk3399_dmc_init(struct udevice *dev) #endif
priv->cic = syscon_get_first_range(ROCKCHIP_SYSCON_CIC); + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); priv->pmusgrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUSGRF); priv->pmucru = rockchip_get_pmucru();
Group common ddr attributes like - rank - col - bk - bw - dbw - row_3_4 - cs0_row - cs1_row - ddrconfig
into a common cap_info structure for more code readability and extend if possible based on the new features.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../include/asm/arch-rockchip/sdram_rk3399.h | 6 +- drivers/ram/rockchip/sdram_rk3399.c | 71 ++++++++++--------- 2 files changed, 41 insertions(+), 36 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index a191d242f8..67044f53e5 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -96,7 +96,7 @@ struct rk3399_ddr_cic_regs { /* DENALI_CTL_274 */ #define MEM_RST_VALID 1
-struct rk3399_sdram_channel { +struct sdram_cap_info { unsigned int rank; /* dram column number, 0 means this channel is invalid */ unsigned int col; @@ -114,6 +114,10 @@ struct rk3399_sdram_channel { unsigned int cs0_row; unsigned int cs1_row; unsigned int ddrconfig; +}; + +struct rk3399_sdram_channel { + struct sdram_cap_info cap_info; struct rk3399_msch_timings noc_timings; };
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 6c3a2b5453..231f69b173 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -155,35 +155,36 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, u32 row;
/* Get row number from ddrconfig setting */ - if (sdram_ch->ddrconfig < 2 || sdram_ch->ddrconfig == 4) + if (sdram_ch->cap_info.ddrconfig < 2 || + sdram_ch->cap_info.ddrconfig == 4) row = 16; - else if (sdram_ch->ddrconfig == 3) + else if (sdram_ch->cap_info.ddrconfig == 3) row = 14; else row = 15;
- cs_map = (sdram_ch->rank > 1) ? 3 : 1; - reduc = (sdram_ch->bw == 2) ? 0 : 1; + cs_map = (sdram_ch->cap_info.rank > 1) ? 3 : 1; + reduc = (sdram_ch->cap_info.bw == 2) ? 0 : 1;
/* Set the dram configuration to ctrl */ - clrsetbits_le32(&denali_ctl[191], 0xF, (12 - sdram_ch->col)); + clrsetbits_le32(&denali_ctl[191], 0xF, (12 - sdram_ch->cap_info.col)); clrsetbits_le32(&denali_ctl[190], (0x3 << 16) | (0x7 << 24), - ((3 - sdram_ch->bk) << 16) | + ((3 - sdram_ch->cap_info.bk) << 16) | ((16 - row) << 24));
clrsetbits_le32(&denali_ctl[196], 0x3 | (1 << 16), cs_map | (reduc << 16));
/* PI_199 PI_COL_DIFF:RW:0:4 */ - clrsetbits_le32(&denali_pi[199], 0xF, (12 - sdram_ch->col)); + clrsetbits_le32(&denali_pi[199], 0xF, (12 - sdram_ch->cap_info.col));
/* PI_155 PI_ROW_DIFF:RW:24:3 PI_BANK_DIFF:RW:16:2 */ clrsetbits_le32(&denali_pi[155], (0x3 << 16) | (0x7 << 24), - ((3 - sdram_ch->bk) << 16) | + ((3 - sdram_ch->cap_info.bk) << 16) | ((16 - row) << 24)); /* PI_41 PI_CS_MAP:RW:24:4 */ clrsetbits_le32(&denali_pi[41], 0xf << 24, cs_map << 24); - if (sdram_ch->rank == 1 && params->base.dramtype == DDR3) + if (sdram_ch->cap_info.rank == 1 && params->base.dramtype == DDR3) writel(0x2EC7FFFF, &denali_pi[34]); }
@@ -681,7 +682,7 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_err = 0; - u32 rank = params->ch[channel].rank; + u32 rank = params->ch[channel].cap_info.rank; u32 rank_mask;
/* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ @@ -744,7 +745,7 @@ static int data_training_wl(const struct chan_info *chan, u32 channel, u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; - u32 rank = params->ch[channel].rank; + u32 rank = params->ch[channel].cap_info.rank;
/* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); @@ -806,7 +807,7 @@ static int data_training_rg(const struct chan_info *chan, u32 channel, u32 *denali_phy = chan->publ->denali_phy; u32 i, tmp; u32 obs_0, obs_1, obs_2, obs_3, obs_err = 0; - u32 rank = params->ch[channel].rank; + u32 rank = params->ch[channel].cap_info.rank;
/* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); @@ -868,7 +869,7 @@ static int data_training_rl(const struct chan_info *chan, u32 channel, { u32 *denali_pi = chan->pi->denali_pi; u32 i, tmp; - u32 rank = params->ch[channel].rank; + u32 rank = params->ch[channel].cap_info.rank;
/* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175])); @@ -916,7 +917,7 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, { u32 *denali_pi = chan->pi->denali_pi; u32 i, tmp; - u32 rank = params->ch[channel].rank; + u32 rank = params->ch[channel].cap_info.rank; u32 rank_mask;
/* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ @@ -1050,14 +1051,14 @@ static void set_ddrconfig(const struct chan_info *chan, unsigned int cs0_cap = 0; unsigned int cs1_cap = 0;
- cs0_cap = (1 << (params->ch[channel].cs0_row - + params->ch[channel].col - + params->ch[channel].bk - + params->ch[channel].bw - 20)); - if (params->ch[channel].rank > 1) - cs1_cap = cs0_cap >> (params->ch[channel].cs0_row - - params->ch[channel].cs1_row); - if (params->ch[channel].row_3_4) { + cs0_cap = (1 << (params->ch[channel].cap_info.cs0_row + + params->ch[channel].cap_info.col + + params->ch[channel].cap_info.bk + + params->ch[channel].cap_info.bw - 20)); + if (params->ch[channel].cap_info.rank > 1) + cs1_cap = cs0_cap >> (params->ch[channel].cap_info.cs0_row + - params->ch[channel].cap_info.cs1_row); + if (params->ch[channel].cap_info.row_3_4) { cs0_cap = cs0_cap * 3 / 4; cs1_cap = cs1_cap * 3 / 4; } @@ -1084,22 +1085,22 @@ static void dram_all_config(struct dram_info *dram, struct rk3399_msch_regs *ddr_msch_regs; const struct rk3399_msch_timings *noc_timing;
- if (params->ch[channel].col == 0) + if (params->ch[channel].cap_info.col == 0) continue; idx++; - sys_reg2 |= SYS_REG_ENC_ROW_3_4(info->row_3_4, channel); + sys_reg2 |= SYS_REG_ENC_ROW_3_4(info->cap_info.row_3_4, channel); sys_reg2 |= SYS_REG_ENC_CHINFO(channel); - sys_reg2 |= SYS_REG_ENC_RANK(info->rank, channel); - sys_reg2 |= SYS_REG_ENC_COL(info->col, channel); - sys_reg2 |= SYS_REG_ENC_BK(info->bk, channel); - sys_reg2 |= SYS_REG_ENC_BW(info->bw, channel); - sys_reg2 |= SYS_REG_ENC_DBW(info->dbw, channel); - SYS_REG_ENC_CS0_ROW(info->cs0_row, sys_reg2, sys_reg3, channel); - if (info->cs1_row) - SYS_REG_ENC_CS1_ROW(info->cs1_row, sys_reg2, + sys_reg2 |= SYS_REG_ENC_RANK(info->cap_info.rank, channel); + sys_reg2 |= SYS_REG_ENC_COL(info->cap_info.col, channel); + sys_reg2 |= SYS_REG_ENC_BK(info->cap_info.bk, channel); + sys_reg2 |= SYS_REG_ENC_BW(info->cap_info.bw, channel); + sys_reg2 |= SYS_REG_ENC_DBW(info->cap_info.dbw, channel); + SYS_REG_ENC_CS0_ROW(info->cap_info.cs0_row, sys_reg2, sys_reg3, channel); + if (info->cap_info.cs1_row) + SYS_REG_ENC_CS1_ROW(info->cap_info.cs1_row, sys_reg2, sys_reg3, channel);
- sys_reg3 |= SYS_REG_ENC_CS1_COL(info->col, channel); + sys_reg3 |= SYS_REG_ENC_CS1_COL(info->cap_info.col, channel); sys_reg3 |= SYS_REG_ENC_VERSION(DDR_SYS_REG_VERSION);
ddr_msch_regs = dram->chan[channel].msch; @@ -1116,7 +1117,7 @@ static void dram_all_config(struct dram_info *dram, &ddr_msch_regs->ddrmode);
/* rank 1 memory clock disable (dfi_dram_clk_disable = 1) */ - if (params->ch[channel].rank == 1) + if (params->ch[channel].cap_info.rank == 1) setbits_le32(&dram->chan[channel].pctl->denali_ctl[276], 1 << 17); } @@ -1226,7 +1227,7 @@ static int sdram_init(struct dram_info *dram, }
set_ddrconfig(chan, params, channel, - params->ch[channel].ddrconfig); + params->ch[channel].cap_info.ddrconfig); } dram_all_config(dram, params); switch_to_phy_index1(dram, params);
Most of the ddr parameters are common in rk3399_base_params structure and which would reuse it in another controller like px30 in future.
So, rename the structure from rk3399_base_params into sdram_base_params.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_rk3399.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index 67044f53e5..fe25446cab 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -121,7 +121,7 @@ struct rk3399_sdram_channel { struct rk3399_msch_timings noc_timings; };
-struct rk3399_base_params { +struct sdram_base_params { unsigned int ddr_freq; unsigned int dramtype; unsigned int num_channels; @@ -131,7 +131,7 @@ struct rk3399_base_params {
struct rk3399_sdram_params { struct rk3399_sdram_channel ch[2]; - struct rk3399_base_params base; + struct sdram_base_params base; struct rk3399_ddr_pctl_regs pctl_regs; struct rk3399_ddr_pi_regs pi_regs; struct rk3399_ddr_publ_regs phy_regs;
Move common sdram structures like sdram_cap_info, sdram_base_params into sdram_common header, this would help to reuse the same from another controllers like px30.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- .../include/asm/arch-rockchip/sdram_common.h | 29 +++++++++++++++++++ .../include/asm/arch-rockchip/sdram_rk3399.h | 28 ------------------ 2 files changed, 29 insertions(+), 28 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 0eb068dcc0..6b75de5b6f 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -5,6 +5,35 @@
#ifndef _ASM_ARCH_SDRAM_COMMON_H #define _ASM_ARCH_SDRAM_COMMON_H + +struct sdram_cap_info { + unsigned int rank; + /* dram column number, 0 means this channel is invalid */ + unsigned int col; + /* dram bank number, 3:8bank, 2:4bank */ + unsigned int bk; + /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ + unsigned int bw; + /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ + unsigned int dbw; + /* + * row_3_4 = 1: 6Gb or 12Gb die + * row_3_4 = 0: normal die, power of 2 + */ + unsigned int row_3_4; + unsigned int cs0_row; + unsigned int cs1_row; + unsigned int ddrconfig; +}; + +struct sdram_base_params { + unsigned int ddr_freq; + unsigned int dramtype; + unsigned int num_channels; + unsigned int stride; + unsigned int odt; +}; + /* * sys_reg bitfield struct * [31] row_3_4_ch1 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index fe25446cab..6258c811f5 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -96,39 +96,11 @@ struct rk3399_ddr_cic_regs { /* DENALI_CTL_274 */ #define MEM_RST_VALID 1
-struct sdram_cap_info { - unsigned int rank; - /* dram column number, 0 means this channel is invalid */ - unsigned int col; - /* dram bank number, 3:8bank, 2:4bank */ - unsigned int bk; - /* channel buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int bw; - /* die buswidth, 2:32bit, 1:16bit, 0:8bit */ - unsigned int dbw; - /* - * row_3_4 = 1: 6Gb or 12Gb die - * row_3_4 = 0: normal die, power of 2 - */ - unsigned int row_3_4; - unsigned int cs0_row; - unsigned int cs1_row; - unsigned int ddrconfig; -}; - struct rk3399_sdram_channel { struct sdram_cap_info cap_info; struct rk3399_msch_timings noc_timings; };
-struct sdram_base_params { - unsigned int ddr_freq; - unsigned int dramtype; - unsigned int num_channels; - unsigned int stride; - unsigned int odt; -}; - struct rk3399_sdram_params { struct rk3399_sdram_channel ch[2]; struct sdram_base_params base;
dramtype enum numbers as common across all dram controllers in rockchip, so move the eneum values in common header.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-rockchip/sdram.h | 6 ------ arch/arm/include/asm/arch-rockchip/sdram_common.h | 8 ++++++++ arch/arm/include/asm/arch-rockchip/sdram_rk322x.h | 7 ------- arch/arm/include/asm/arch-rockchip/sdram_rk3399.h | 8 -------- 4 files changed, 8 insertions(+), 21 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram.h b/arch/arm/include/asm/arch-rockchip/sdram.h index bbe425deb9..9220763fa7 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram.h +++ b/arch/arm/include/asm/arch-rockchip/sdram.h @@ -8,12 +8,6 @@ #ifndef _ASM_ARCH_RK3288_SDRAM_H__ #define _ASM_ARCH_RK3288_SDRAM_H__
-enum { - DDR3 = 3, - LPDDR3 = 6, - UNUSED = 0xFF, -}; - struct rk3288_sdram_channel { /* * bit width in address, eg: diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 6b75de5b6f..09f98bbf46 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -6,6 +6,14 @@ #ifndef _ASM_ARCH_SDRAM_COMMON_H #define _ASM_ARCH_SDRAM_COMMON_H
+enum { + DDR3 = 0x3, + LPDDR2 = 0x5, + LPDDR3 = 0x6, + LPDDR4 = 0x7, + UNUSED = 0xFF +}; + struct sdram_cap_info { unsigned int rank; /* dram column number, 0 means this channel is invalid */ diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h b/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h index d0091a7aaf..336c5d7e8c 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk322x.h @@ -7,13 +7,6 @@
#include <common.h>
-enum { - DDR3 = 3, - LPDDR2 = 5, - LPDDR3 = 6, - UNUSED = 0xFF, -}; - struct rk322x_sdram_channel { /* * bit width in address, eg: diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h index 6258c811f5..dc65ae7924 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_rk3399.h @@ -6,14 +6,6 @@ #ifndef _ASM_ARCH_SDRAM_RK3399_H #define _ASM_ARCH_SDRAM_RK3399_H
-enum { - DDR3 = 0x3, - LPDDR2 = 0x5, - LPDDR3 = 0x6, - LPDDR4 = 0x7, - UNUSED = 0xFF -}; - struct rk3399_ddr_pctl_regs { u32 denali_ctl[332]; };
Add DDR4 enum number in common header.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/include/asm/arch-rockchip/sdram_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 09f98bbf46..c290fd89c9 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -7,6 +7,7 @@ #define _ASM_ARCH_SDRAM_COMMON_H
enum { + DDR4 = 0, DDR3 = 0x3, LPDDR2 = 0x5, LPDDR3 = 0x6,
Right now sdram drivers in rockchip SoC are built based on the SoC configs which may not be an adequate solutions while adding common or debug driver.
So, add meaningful Kconfig options start with rk3399.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/Kconfig | 1 + drivers/ram/rockchip/Kconfig | 17 +++++++++++++++++ drivers/ram/rockchip/Makefile | 2 +- 3 files changed, 19 insertions(+), 1 deletion(-) create mode 100644 drivers/ram/rockchip/Kconfig
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index fbf7d7b20f..568d8f2c6a 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -54,4 +54,5 @@ config K3_AM654_DDRSS config add support for the initialization of the external SDRAM devices connected to DDR subsystem.
+source "drivers/ram/rockchip/Kconfig" source "drivers/ram/stm32mp1/Kconfig" diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig new file mode 100644 index 0000000000..995cb487b8 --- /dev/null +++ b/drivers/ram/rockchip/Kconfig @@ -0,0 +1,17 @@ +config RAM_ROCKCHIP + bool "Ram drivers support for Rockchip SoCs" + depends on RAM && ARCH_ROCKCHIP + default y + help + This enables support for ram drivers Rockchip SoCs. + +if RAM_ROCKCHIP + +config RAM_RK3399 + bool "Ram driver for Rockchip RK3399" + default ROCKCHIP_RK3399 + help + This enables ram drivers support for the platforms based on + Rockchip RK3399 SoC. + +endif # RAM_ROCKCHIP diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 5df196066d..07d4b62a9d 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -9,4 +9,4 @@ obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o obj-$(CONFIG_ROCKCHIP_RK322X) = sdram_rk322x.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o -obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o +obj-$(CONFIG_RAM_RK3399) += sdram_rk3399.o
Add printdec, this would help to print an output a decimalism value.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- include/debug_uart.h | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/include/debug_uart.h b/include/debug_uart.h index 34e8b2fc81..cd70ae1a04 100644 --- a/include/debug_uart.h +++ b/include/debug_uart.h @@ -104,6 +104,13 @@ void printhex4(uint value); */ void printhex8(uint value);
+/** + * printdec() - Output a decimalism value + * + * @value: Value to output + */ +void printdec(uint value); + #ifdef CONFIG_DEBUG_UART_ANNOUNCE #define _DEBUG_UART_ANNOUNCE printascii("<debug_uart> "); #else @@ -170,6 +177,18 @@ void printhex8(uint value); { \ printhex(value, 8); \ } \ +\ + void printdec(uint value) \ + { \ + if (value > 10) { \ + printdec(value / 10); \ + value %= 10; \ + } else if (value == 10) { \ + _debug_uart_putc('1'); \ + value = 0; \ + } \ + _debug_uart_putc('0' + value); \ + } \ \ void debug_uart_init(void) \ { \
Add sdram driver to handle debug across rockchip SoCs.
This would help to improve code debugging feature for sdram drivers in rockchip family, whoever wants to debug the driver should call these core debug code on their respective platform sdram drivers.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../include/asm/arch-rockchip/sdram_common.h | 9 +++++ drivers/ram/rockchip/Kconfig | 9 +++++ drivers/ram/rockchip/Makefile | 1 + drivers/ram/rockchip/sdram_debug.c | 34 +++++++++++++++++++ 4 files changed, 53 insertions(+) create mode 100644 drivers/ram/rockchip/sdram_debug.c
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index c290fd89c9..0cb737d665 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -123,4 +123,13 @@ size_t rockchip_sdram_size(phys_addr_t reg);
/* Called by U-Boot board_init_r for Rockchip SoCs */ int dram_init(void); + +#if !defined(CONFIG_RAM_ROCKCHIP_DEBUG) +inline void sdram_print_dram_type(unsigned char dramtype) +{ +} +#else +void sdram_print_dram_type(unsigned char dramtype); +#endif /* CONFIG_RAM_ROCKCHIP_DEBUG */ + #endif diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index 995cb487b8..151ffb684d 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -7,6 +7,15 @@ config RAM_ROCKCHIP
if RAM_ROCKCHIP
+config RAM_ROCKCHIP_DEBUG + bool "Rockchip ram drivers debugging" + help + This enables debugging ram driver API's for the platforms + based on Rockchip SoCs. + + This is an option for developers to understand the ram drivers + initialization, configurations and etc. + config RAM_RK3399 bool "Ram driver for Rockchip RK3399" default ROCKCHIP_RK3399 diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 07d4b62a9d..feb1f82d00 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -3,6 +3,7 @@ # Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH #
+obj-$(CONFIG_RAM_ROCKCHIP_DEBUG) += sdram_debug.o obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3128) = sdram_rk3128.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c new file mode 100644 index 0000000000..c13e140fa5 --- /dev/null +++ b/drivers/ram/rockchip/sdram_debug.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2019 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +#include <common.h> +#include <debug_uart.h> +#include <asm/arch-rockchip/sdram_common.h> + +void sdram_print_dram_type(unsigned char dramtype) +{ + switch (dramtype) { + case DDR3: + printascii("DDR3"); + break; + case DDR4: + printascii("DDR4"); + break; + case LPDDR2: + printascii("LPDDR2"); + break; + case LPDDR3: + printascii("LPDDR3"); + break; + case LPDDR4: + printascii("LPDDR4"); + break; + default: + printascii("Unknown Device"); + break; + } +}
Add sdram ddr info print support, this would help to observe the sdram base parameters.
Here is sample print on LPDDR4, 50MHz channel 0 BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../include/asm/arch-rockchip/sdram_common.h | 7 ++++ drivers/ram/rockchip/sdram_debug.c | 40 +++++++++++++++++++ 2 files changed, 47 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 0cb737d665..7d1372f033 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -128,8 +128,15 @@ int dram_init(void); inline void sdram_print_dram_type(unsigned char dramtype) { } + +inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ +} #else void sdram_print_dram_type(unsigned char dramtype); +void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base); #endif /* CONFIG_RAM_ROCKCHIP_DEBUG */
#endif diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c index c13e140fa5..69a6f94a73 100644 --- a/drivers/ram/rockchip/sdram_debug.c +++ b/drivers/ram/rockchip/sdram_debug.c @@ -32,3 +32,43 @@ void sdram_print_dram_type(unsigned char dramtype) break; } } + +void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ + u32 bg; + + bg = (cap_info->dbw == 0) ? 2 : 1; + + sdram_print_dram_type(base->dramtype); + + printascii(", "); + printdec(base->ddr_freq); + printascii("MHz\n"); + + printascii("BW="); + printdec(8 << cap_info->bw); + + printascii(" Col="); + printdec(cap_info->col); + + printascii(" Bk="); + printdec(0x1 << cap_info->bk); + if (base->dramtype == DDR4) { + printascii(" BG="); + printdec(1 << bg); + } + + printascii(" CS0 Row="); + printdec(cap_info->cs0_row); + if (cap_info->rank > 1) { + printascii(" CS1 Row="); + printdec(cap_info->cs1_row); + } + + printascii(" CS="); + printdec(cap_info->rank); + + printascii(" Die BW="); + printdec(8 << cap_info->dbw); +}
Add code to get the channel capacity, this would help to print the capacity of specific channel.
Here is sample print on LPDDR4, 50MHz channel 0 BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_debug.c | 46 +++++++++++++++++++++++++++++- 1 file changed, 45 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c index 69a6f94a73..19e9225c12 100644 --- a/drivers/ram/rockchip/sdram_debug.c +++ b/drivers/ram/rockchip/sdram_debug.c @@ -33,10 +33,46 @@ void sdram_print_dram_type(unsigned char dramtype) } }
+/** + * cs = 0, cs0 + * cs = 1, cs1 + * cs => 2, cs0+cs1 + * note: it didn't consider about row_3_4 + */ +u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type) +{ + u32 bg; + u64 cap[2]; + + if (dram_type == DDR4) + /* DDR4 8bit dram BG = 2(4bank groups), + * 16bit dram BG = 1 (2 bank groups) + */ + bg = (cap_info->dbw == 0) ? 2 : 1; + else + bg = 0; + + cap[0] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs0_row); + + if (cap_info->rank == 2) + cap[1] = 1llu << (cap_info->bw + cap_info->col + + bg + cap_info->bk + cap_info->cs1_row); + else + cap[1] = 0; + + if (cs == 0) + return cap[0]; + else if (cs == 1) + return cap[1]; + else + return (cap[0] + cap[1]); +} + void sdram_print_ddr_info(struct sdram_cap_info *cap_info, struct sdram_base_params *base) { - u32 bg; + u32 bg, cap;
@@ -71,4 +107,12 @@ void sdram_print_ddr_info(struct sdram_cap_info *cap_info,
printascii(" Die BW="); printdec(8 << cap_info->dbw); + + cap = sdram_get_cs_cap(cap_info, 3, base->dramtype); + if (cap_info->row_3_4) + cap = cap * 3 / 4; + + printascii(" Size="); + printdec(cap >> 20); + printascii("MB\n"); }
Add code to print the channel stride, this would help to print the stride of associated channel.
Here is sample print on LPDDR4, 50MHz. 256B stride
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../include/asm/arch-rockchip/sdram_common.h | 5 ++++ drivers/ram/rockchip/sdram_debug.c | 29 +++++++++++++++++++ 2 files changed, 34 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 7d1372f033..8027b53636 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -133,10 +133,15 @@ inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, struct sdram_base_params *base) { } + +inline void sdram_print_stride(unsigned int stride) +{ +} #else void sdram_print_dram_type(unsigned char dramtype); void sdram_print_ddr_info(struct sdram_cap_info *cap_info, struct sdram_base_params *base); +void sdram_print_stride(unsigned int stride); #endif /* CONFIG_RAM_ROCKCHIP_DEBUG */
#endif diff --git a/drivers/ram/rockchip/sdram_debug.c b/drivers/ram/rockchip/sdram_debug.c index 19e9225c12..9cf662675b 100644 --- a/drivers/ram/rockchip/sdram_debug.c +++ b/drivers/ram/rockchip/sdram_debug.c @@ -116,3 +116,32 @@ void sdram_print_ddr_info(struct sdram_cap_info *cap_info, printdec(cap >> 20); printascii("MB\n"); } + +void sdram_print_stride(unsigned int stride) +{ + switch (stride) { + case 0xc: + printf("128B stride\n"); + break; + case 5: + case 9: + case 0xd: + case 0x11: + case 0x19: + printf("256B stride\n"); + break; + case 0xa: + case 0xe: + case 0x12: + printf("512B stride\n"); + break; + case 0xf: + printf("4K stride\n"); + break; + case 0x1f: + printf("32MB + 256B stride\n"); + break; + default: + printf("no stride\n"); + } +}
stride value from sdram timings can be computed dynamically based on the determined capacity for the given channel.
Right now these stride values are taken as part of sdram timings via dtsi, but it possible to use same timings dtsi for given frequency even though the configured board sdram do support single channel with different size by dynamically detect the stride value.
Example, NanoPi NEO4 do have DDR3-1866, but with single channel and 1GB size with dynamic stride detection it is possible to use existing rk3399-sdram-ddr3-1866.dtsi whose stride, number of channels and capacity it support is d efferent.
So, add initial support to calculate the stride value for 2 channels sdram, which is available by default on existing boards.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 71 ++++++++++++++++++++++++++++- 1 file changed, 70 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 231f69b173..75df469952 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1180,8 +1180,75 @@ static int switch_to_phy_index1(struct dram_info *dram, return 0; }
+static unsigned char calculate_stride(struct rk3399_sdram_params *params) +{ + unsigned int stride = params->base.stride; + unsigned int channel, chinfo = 0; + unsigned int ch_cap[2] = {0, 0}; + u64 cap; + + for (channel = 0; channel < 2; channel++) { + unsigned int cs0_cap = 0; + unsigned int cs1_cap = 0; + struct sdram_cap_info *cap_info = ¶ms->ch[channel].cap_info; + + if (cap_info->col == 0) + continue; + + cs0_cap = (1 << (cap_info->cs0_row + cap_info->col + + cap_info->bk + cap_info->bw - 20)); + if (cap_info->rank > 1) + cs1_cap = cs0_cap >> (cap_info->cs0_row + - cap_info->cs1_row); + if (cap_info->row_3_4) { + cs0_cap = cs0_cap * 3 / 4; + cs1_cap = cs1_cap * 3 / 4; + } + ch_cap[channel] = cs0_cap + cs1_cap; + chinfo |= 1 << channel; + } + + /* stride calculation for 2 channels, default gstride type is 256B */ + if (ch_cap[0] == ch_cap[1]) { + cap = ch_cap[0] + ch_cap[1]; + switch (cap) { + /* 512MB */ + case 512: + stride = 0; + break; + /* 1GB */ + case 1024: + stride = 0x5; + break; + /* + * 768MB + 768MB same as total 2GB memory + * useful space: 0-768MB 1GB-1792MB + */ + case 1536: + /* 2GB */ + case 2048: + stride = 0x9; + break; + /* 1536MB + 1536MB */ + case 3072: + stride = 0x11; + break; + /* 4GB */ + case 4096: + stride = 0xD; + break; + default: + printf("%s: Unable to calculate stride for ", __func__); + print_size((cap * (1 << 20)), " capacity\n"); + break; + } + } + + return stride; +} + static int sdram_init(struct dram_info *dram, - const struct rk3399_sdram_params *params) + struct rk3399_sdram_params *params) { unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; @@ -1229,6 +1296,8 @@ static int sdram_init(struct dram_info *dram, set_ddrconfig(chan, params, channel, params->ch[channel].cap_info.ddrconfig); } + + params->base.stride = calculate_stride(params); dram_all_config(dram, params); switch_to_phy_index1(dram, params);
Add stride computation for the sdram which support single channel a
This configuration available in NanoPi NEO4 and the same can work with existing rk3399-sdram-ddr3-1866.dtsi
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 75df469952..87eda06055 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1208,6 +1208,10 @@ static unsigned char calculate_stride(struct rk3399_sdram_params *params) chinfo |= 1 << channel; }
+ /* stride calculation for 1 channel */ + if (params->base.num_channels == 1 && chinfo & 1) + return 0x17; /* channel a */ + /* stride calculation for 2 channels, default gstride type is 256B */ if (ch_cap[0] == ch_cap[1]) { cap = ch_cap[0] + ch_cap[1];
Right now the rk3399 sdram driver assume that the board has configured with 2 channels, so any possibility to enable single channel on the same driver will encounter channel #1 data training failure.
Log: U-Boot TPL board init sdram_init: data training failed rk3399_dmc_init DRAM init failed -5
So, add an algorithm that can capable to compute the active or configured rank with associated channel like a) do rank loop to compute the active rank, with associated channel numbers b) then, succeed the data training only for configured channel c) preserve the rank for given channel d) do channel loop for setting the active channel e) if given rank is zero or inactive on the specific channel, clear the timings for the associated channel f) finally, return error if number of channels is zero
Tested in NanoPI-NEO4 since it support single channel sdram configuration.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 110 ++++++++++++++++++++++------ 1 file changed, 86 insertions(+), 24 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 87eda06055..a3acb75dba 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1251,13 +1251,52 @@ static unsigned char calculate_stride(struct rk3399_sdram_params *params) return stride; }
+static void clear_channel_params(struct rk3399_sdram_params *params, u8 channel) +{ + params->ch[channel].cap_info.rank = 0; + params->ch[channel].cap_info.col = 0; + params->ch[channel].cap_info.bk = 0; + params->ch[channel].cap_info.bw = 32; + params->ch[channel].cap_info.dbw = 32; + params->ch[channel].cap_info.row_3_4 = 0; + params->ch[channel].cap_info.cs0_row = 0; + params->ch[channel].cap_info.cs1_row = 0; + params->ch[channel].cap_info.ddrconfig = 0; +} + +static int pctl_init(struct dram_info *dram, struct rk3399_sdram_params *params) +{ + int channel; + int ret; + + for (channel = 0; channel < 2; channel++) { + const struct chan_info *chan = &dram->chan[channel]; + struct rk3399_cru *cru = dram->cru; + struct rk3399_ddr_publ_regs *publ = chan->publ; + + phy_pctrl_reset(cru, channel); + phy_dll_bypass_set(publ, params->base.ddr_freq); + + ret = pctl_cfg(dram, chan, channel, params); + if (ret < 0) { + printf("%s: pctl config failed\n", __func__); + return ret; + } + + /* start to trigger initialization */ + pctl_start(dram, channel); + } + + return 0; +} + static int sdram_init(struct dram_info *dram, struct rk3399_sdram_params *params) { unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; - struct rk3399_cru *cru = dram->cru; - int channel; + u32 training_flag = PI_READ_GATE_TRAINING; + int channel, ch, rank; int ret;
debug("Starting SDRAM initialization...\n"); @@ -1269,36 +1308,59 @@ static int sdram_init(struct dram_info *dram, return -E2BIG; }
- for (channel = 0; channel < 2; channel++) { - const struct chan_info *chan = &dram->chan[channel]; - struct rk3399_ddr_publ_regs *publ = chan->publ; + for (ch = 0; ch < 2; ch++) { + params->ch[ch].cap_info.rank = 2; + for (rank = 2; rank != 0; rank--) { + ret = pctl_init(dram, params); + if (ret < 0) { + printf("%s: pctl init failed\n", __func__); + return ret; + }
- phy_pctrl_reset(cru, channel); - phy_dll_bypass_set(publ, ddr_freq); + /* LPDDR2/LPDDR3 need to wait DAI complete, max 10us */ + if (dramtype == LPDDR3) + udelay(10);
- if (channel >= params->base.num_channels) - continue; + params->ch[ch].cap_info.rank = rank;
- ret = pctl_cfg(dram, chan, channel, params); - if (ret < 0) { - printf("%s: pctl config failed\n", __func__); - return ret; - } + /* + * LPDDR3 CA training msut be trigger before + * other training. + * DDR3 is not have CA training. + */ + if (params->base.dramtype == LPDDR3) + training_flag |= PI_CA_TRAINING;
- /* start to trigger initialization */ - pctl_start(dram, channel); + if (!(data_training(&dram->chan[ch], ch, + params, training_flag))) + break; + } + /* Computed rank with associated channel number */ + params->ch[ch].cap_info.rank = rank; + }
- /* LPDDR2/LPDDR3 need to wait DAI complete, max 10us */ - if (dramtype == LPDDR3) - udelay(10); + params->base.num_channels = 0; + for (channel = 0; channel < 2; channel++) { + const struct chan_info *chan = &dram->chan[channel]; + struct sdram_cap_info *cap_info = ¶ms->ch[channel].cap_info;
- if (data_training(chan, channel, params, PI_FULL_TRAINING)) { - printf("%s: data training failed\n", __func__); - return -EIO; + if (cap_info->rank == 0) { + clear_channel_params(params, channel); + continue; + } else { + params->base.num_channels++; }
- set_ddrconfig(chan, params, channel, - params->ch[channel].cap_info.ddrconfig); + debug("Channel "); + debug(channel ? "1: " : "0: "); + + set_ddrconfig(chan, params, channel, cap_info->ddrconfig); + } + + if (params->base.num_channels == 0) { + printf("%s: ", __func__); + printf(" - %dMHz failed!\n", params->base.ddr_freq); + return -EINVAL; }
This would help to debug the sdram base parameters while debugging existing chip or while supporting new sdram type.
It require explicit enablement of CONFIG_RAM_ROCKCHIP_DEBUG for showing the debug prints.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index a3acb75dba..ae9ba625bd 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1248,6 +1248,8 @@ static unsigned char calculate_stride(struct rk3399_sdram_params *params) } }
+ sdram_print_stride(stride); + return stride; }
@@ -1354,11 +1356,14 @@ static int sdram_init(struct dram_info *dram, debug("Channel "); debug(channel ? "1: " : "0: ");
+ sdram_print_ddr_info(cap_info, ¶ms->base); + set_ddrconfig(chan, params, channel, cap_info->ddrconfig); }
if (params->base.num_channels == 0) { printf("%s: ", __func__); + sdram_print_dram_type(params->base.dramtype); printf(" - %dMHz failed!\n", params->base.ddr_freq); return -EINVAL; }
Use DDR3-1866 2GB ddr timings dtsi for 1GB NanoPi Neo4 board.
Since sdram rk3399 support dynamic stride and rank detection it can able to detect 1GB ddr eventough the timings are meant for dual channel, 2GB size.
Bootchain after and before this change are:
TPL -> SPL -> U-Boot proper
rkbin -> SPL -> U-Boot proper
This certainly fix the second channel data training initialization since we have dynamic rank, stride where second channel capabilities are clear or memset to 0.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi b/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi index 7d22528f49..eb0aca4758 100644 --- a/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi +++ b/arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi @@ -4,3 +4,4 @@ */
#include "rk3399-nanopi4-u-boot.dtsi" +#include "rk3399-sdram-ddr3-1866.dtsi"
- CHECK: spaces preferred around that '*' - CHECK: spaces preferred around that '/' - CHECK: space preferred before that '|' - WARNING: macros should not use a trailing semicolon - CHECK: Unnecessary parentheses around 'fbdiv <= min_fbdiv' - CHECK: Unnecessary parentheses around 'parent->id == SCLK_MAC' - CHECK: Unnecessary parentheses around 'parent->dev == clk->dev' - WARNING: line over 80 characters - CHECK: Prefer kernel type 'u8' over 'uint8_t' - Add proper macro definitions arrangements
Note: there are still line over 80 characters and other warnings but fixing those making code look unreadable, so I kept it as it is.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/clk/rockchip/clk_rk3399.c | 68 ++++++++++++++----------------- 1 file changed, 31 insertions(+), 37 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index aa6a8ad1c9..5d1ad94e85 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -38,8 +38,8 @@ struct pll_div { };
#define RATE_TO_DIV(input_rate, output_rate) \ - ((input_rate) / (output_rate) - 1); -#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + ((input_rate) / (output_rate) - 1) +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1))
#define PLL_DIVISORS(hz, _refdiv, _postdiv1, _postdiv2) {\ .refdiv = _refdiv,\ @@ -53,15 +53,15 @@ static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 2, 2); static const struct pll_div ppll_init_cfg = PLL_DIVISORS(PPLL_HZ, 2, 2, 1); #endif
-static const struct pll_div apll_l_1600_cfg = PLL_DIVISORS(1600*MHz, 3, 1, 1); -static const struct pll_div apll_l_600_cfg = PLL_DIVISORS(600*MHz, 1, 2, 1); +static const struct pll_div apll_l_1600_cfg = PLL_DIVISORS(1600 * MHz, 3, 1, 1); +static const struct pll_div apll_l_600_cfg = PLL_DIVISORS(600 * MHz, 1, 2, 1);
static const struct pll_div *apll_l_cfgs[] = { [APLL_L_1600_MHZ] = &apll_l_1600_cfg, [APLL_L_600_MHZ] = &apll_l_600_cfg, };
-static const struct pll_div apll_b_600_cfg = PLL_DIVISORS(600*MHz, 1, 2, 1); +static const struct pll_div apll_b_600_cfg = PLL_DIVISORS(600 * MHz, 1, 2, 1); static const struct pll_div *apll_b_cfgs[] = { [APLL_B_600_MHZ] = &apll_b_600_cfg, }; @@ -393,7 +393,7 @@ static int pll_para_config(u32 freq_hz, struct pll_div *div) fref_khz = ref_khz / refdiv;
fbdiv = vco_khz / fref_khz; - if ((fbdiv >= max_fbdiv) || (fbdiv <= min_fbdiv)) + if (fbdiv >= max_fbdiv || fbdiv <= min_fbdiv) continue; diff_khz = vco_khz - fbdiv * fref_khz; if (fbdiv + 1 < max_fbdiv && diff_khz > fref_khz / 2) { @@ -409,7 +409,7 @@ static int pll_para_config(u32 freq_hz, struct pll_div *div) div->fbdiv = fbdiv; }
- if (best_diff_khz > 4 * (MHz/KHz)) { + if (best_diff_khz > 4 * (MHz / KHz)) { printf("%s: Failed to match output frequency %u, " "difference is %u Hz,exceed 4MHZ\n", __func__, freq_hz, best_diff_khz * KHz); @@ -489,28 +489,21 @@ void rk3399_configure_cpu_b(struct rk3399_cru *cru, }
#define I2C_CLK_REG_MASK(bus) \ - (I2C_DIV_CON_MASK << \ - CLK_I2C ##bus## _DIV_CON_SHIFT | \ - CLK_I2C_PLL_SEL_MASK << \ - CLK_I2C ##bus## _PLL_SEL_SHIFT) + (I2C_DIV_CON_MASK << CLK_I2C ##bus## _DIV_CON_SHIFT | \ + CLK_I2C_PLL_SEL_MASK << CLK_I2C ##bus## _PLL_SEL_SHIFT)
#define I2C_CLK_REG_VALUE(bus, clk_div) \ - ((clk_div - 1) << \ - CLK_I2C ##bus## _DIV_CON_SHIFT | \ - CLK_I2C_PLL_SEL_GPLL << \ - CLK_I2C ##bus## _PLL_SEL_SHIFT) + ((clk_div - 1) << CLK_I2C ##bus## _DIV_CON_SHIFT | \ + CLK_I2C_PLL_SEL_GPLL << CLK_I2C ##bus## _PLL_SEL_SHIFT)
#define I2C_CLK_DIV_VALUE(con, bus) \ - (con >> CLK_I2C ##bus## _DIV_CON_SHIFT) & \ - I2C_DIV_CON_MASK; + ((con >> CLK_I2C ##bus## _DIV_CON_SHIFT) & I2C_DIV_CON_MASK)
#define I2C_PMUCLK_REG_MASK(bus) \ - (I2C_DIV_CON_MASK << \ - CLK_I2C ##bus## _DIV_CON_SHIFT) + (I2C_DIV_CON_MASK << CLK_I2C ##bus## _DIV_CON_SHIFT)
#define I2C_PMUCLK_REG_VALUE(bus, clk_div) \ - ((clk_div - 1) << \ - CLK_I2C ##bus## _DIV_CON_SHIFT) + ((clk_div - 1) << CLK_I2C ##bus## _DIV_CON_SHIFT)
static ulong rk3399_i2c_get_clk(struct rk3399_cru *cru, ulong clk_id) { @@ -597,9 +590,9 @@ static ulong rk3399_i2c_set_clk(struct rk3399_cru *cru, ulong clk_id, uint hz) */
struct spi_clkreg { - uint8_t reg; /* CLKSEL_CON[reg] register in CRU */ - uint8_t div_shift; - uint8_t sel_shift; + u8 reg; /* CLKSEL_CON[reg] register in CRU */ + u8 div_shift; + u8 sel_shift; };
/* @@ -678,7 +671,7 @@ static ulong rk3399_spi_set_clk(struct rk3399_cru *cru, ulong clk_id, uint hz) static ulong rk3399_vop_set_clk(struct rk3399_cru *cru, ulong clk_id, u32 hz) { struct pll_div vpll_config = {0}; - int aclk_vop = 198*MHz; + int aclk_vop = 198 * MHz; void *aclkreg_addr, *dclkreg_addr; u32 div;
@@ -710,7 +703,7 @@ static ulong rk3399_vop_set_clk(struct rk3399_cru *cru, ulong clk_id, u32 hz) rkclk_set_pll(&cru->vpll_con[0], &vpll_config);
rk_clrsetreg(dclkreg_addr, - DCLK_VOP_DCLK_SEL_MASK | DCLK_VOP_PLL_SEL_MASK| + DCLK_VOP_DCLK_SEL_MASK | DCLK_VOP_PLL_SEL_MASK | DCLK_VOP_DIV_CON_MASK, DCLK_VOP_DCLK_SEL_DIVOUT << DCLK_VOP_DCLK_SEL_SHIFT | DCLK_VOP_PLL_SEL_VPLL << DCLK_VOP_PLL_SEL_SHIFT | @@ -750,7 +743,7 @@ static ulong rk3399_mmc_set_clk(struct rk3399_cru *cru, ulong clk_id, ulong set_rate) { int src_clk_div; - int aclk_emmc = 198*MHz; + int aclk_emmc = 198 * MHz;
switch (clk_id) { case HCLK_SDMMC: @@ -776,7 +769,7 @@ static ulong rk3399_mmc_set_clk(struct rk3399_cru *cru, break; case SCLK_EMMC: /* Select aclk_emmc source from GPLL */ - src_clk_div = DIV_ROUND_UP(GPLL_HZ , aclk_emmc); + src_clk_div = DIV_ROUND_UP(GPLL_HZ, aclk_emmc); assert(src_clk_div - 1 < 32);
rk_clrsetreg(&cru->clksel_con[21], @@ -834,23 +827,23 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru,
/* clk_ddrc == DPLL = 24MHz / refdiv * fbdiv / postdiv1 / postdiv2 */ switch (set_rate) { - case 200*MHz: + case 200 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 1, .fbdiv = 50, .postdiv1 = 6, .postdiv2 = 1}; break; - case 300*MHz: + case 300 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 2, .fbdiv = 100, .postdiv1 = 4, .postdiv2 = 1}; break; - case 666*MHz: + case 666 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 2, .fbdiv = 111, .postdiv1 = 2, .postdiv2 = 1}; break; - case 800*MHz: + case 800 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 1, .fbdiv = 100, .postdiv1 = 3, .postdiv2 = 1}; break; - case 933*MHz: + case 933 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 1, .fbdiv = 116, .postdiv1 = 3, .postdiv2 = 1}; break; @@ -916,7 +909,6 @@ static ulong rk3399_clk_get_rate(struct clk *clk) case SCLK_UART2: case SCLK_UART3: return 24000000; - break; case PCLK_HDMI_CTRL: break; case DCLK_VOP0: @@ -1014,7 +1006,8 @@ static ulong rk3399_clk_set_rate(struct clk *clk, ulong rate) return ret; }
-static int __maybe_unused rk3399_gmac_set_parent(struct clk *clk, struct clk *parent) +static int __maybe_unused rk3399_gmac_set_parent(struct clk *clk, + struct clk *parent) { struct rk3399_clk_priv *priv = dev_get_priv(clk->dev); const char *clock_output_name; @@ -1024,7 +1017,7 @@ static int __maybe_unused rk3399_gmac_set_parent(struct clk *clk, struct clk *pa * If the requested parent is in the same clock-controller and * the id is SCLK_MAC ("clk_gmac"), switch to the internal clock. */ - if ((parent->dev == clk->dev) && (parent->id == SCLK_MAC)) { + if (parent->dev == clk->dev && parent->id == SCLK_MAC) { debug("%s: switching RGMII to SCLK_MAC\n", __func__); rk_clrreg(&priv->cru->clksel_con[19], BIT(4)); return 0; @@ -1049,7 +1042,8 @@ static int __maybe_unused rk3399_gmac_set_parent(struct clk *clk, struct clk *pa return -EINVAL; }
-static int __maybe_unused rk3399_clk_set_parent(struct clk *clk, struct clk *parent) +static int __maybe_unused rk3399_clk_set_parent(struct clk *clk, + struct clk *parent) { switch (clk->id) { case SCLK_RMII_SRC:
Add support for setting 50MHz ddr clock.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/clk/rockchip/clk_rk3399.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 5d1ad94e85..1de21c9f3e 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -827,6 +827,10 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru,
/* clk_ddrc == DPLL = 24MHz / refdiv * fbdiv / postdiv1 / postdiv2 */ switch (set_rate) { + case 50 * MHz: + dpll_cfg = (struct pll_div) + {.refdiv = 1, .fbdiv = 12, .postdiv1 = 3, .postdiv2 = 2}; + break; case 200 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 1, .fbdiv = 50, .postdiv1 = 6, .postdiv2 = 1};
Add support for setting 400MHz ddr clock.
diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index 1de21c9f3e..79007b8682 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -839,6 +839,10 @@ static ulong rk3399_ddr_set_clk(struct rk3399_cru *cru, dpll_cfg = (struct pll_div) {.refdiv = 2, .fbdiv = 100, .postdiv1 = 4, .postdiv2 = 1}; break; + case 400 * MHz: + dpll_cfg = (struct pll_div) + {.refdiv = 1, .fbdiv = 50, .postdiv1 = 3, .postdiv2 = 1}; + break; case 666 * MHz: dpll_cfg = (struct pll_div) {.refdiv = 2, .fbdiv = 111, .postdiv1 = 2, .postdiv2 = 1};
Trivial patch, add proper spaces in pctl_cfg.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ae9ba625bd..d5ff17ad4f 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -554,8 +554,10 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, copy_to_reg(&denali_ctl[1], ¶ms_ctl[1], sizeof(struct rk3399_ddr_pctl_regs) - 4); writel(params_ctl[0], &denali_ctl[0]); + copy_to_reg(denali_pi, ¶ms->pi_regs.denali_pi[0], sizeof(struct rk3399_ddr_pi_regs)); + /* rank count need to set for init */ set_memory_map(chan, channel, params);
Some dramtypes like lpddr4 initialization would required to configure phy IO even after pctl_cfg and after set_ds_odt.
For those cases the set_ds_odt would be an initial call to setup the phy.
To satisfy all the cases, trigger phy IO from set_ds_odt.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 327 ++++++++++++++-------------- 1 file changed, 162 insertions(+), 165 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index d5ff17ad4f..7f01681a01 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -188,6 +188,166 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, writel(0x2EC7FFFF, &denali_pi[34]); }
+static int phy_io_config(const struct chan_info *chan, + const struct rk3399_sdram_params *params) +{ + u32 *denali_phy = chan->publ->denali_phy; + u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; + u32 mode_sel; + u32 reg_value; + u32 drv_value, odt_value; + u32 speed; + + /* vref setting */ + if (params->base.dramtype == LPDDR4) { + /* LPDDR4 */ + vref_mode_dq = 0x6; + vref_value_dq = 0x1f; + vref_mode_ac = 0x6; + vref_value_ac = 0x1f; + } else if (params->base.dramtype == LPDDR3) { + if (params->base.odt == 1) { + vref_mode_dq = 0x5; /* LPDDR3 ODT */ + drv_value = (readl(&denali_phy[6]) >> 12) & 0xf; + odt_value = (readl(&denali_phy[6]) >> 4) & 0xf; + if (drv_value == PHY_DRV_ODT_48) { + switch (odt_value) { + case PHY_DRV_ODT_240: + vref_value_dq = 0x16; + break; + case PHY_DRV_ODT_120: + vref_value_dq = 0x26; + break; + case PHY_DRV_ODT_60: + vref_value_dq = 0x36; + break; + default: + debug("Invalid ODT value.\n"); + return -EINVAL; + } + } else if (drv_value == PHY_DRV_ODT_40) { + switch (odt_value) { + case PHY_DRV_ODT_240: + vref_value_dq = 0x19; + break; + case PHY_DRV_ODT_120: + vref_value_dq = 0x23; + break; + case PHY_DRV_ODT_60: + vref_value_dq = 0x31; + break; + default: + debug("Invalid ODT value.\n"); + return -EINVAL; + } + } else if (drv_value == PHY_DRV_ODT_34_3) { + switch (odt_value) { + case PHY_DRV_ODT_240: + vref_value_dq = 0x17; + break; + case PHY_DRV_ODT_120: + vref_value_dq = 0x20; + break; + case PHY_DRV_ODT_60: + vref_value_dq = 0x2e; + break; + default: + debug("Invalid ODT value.\n"); + return -EINVAL; + } + } else { + debug("Invalid DRV value.\n"); + return -EINVAL; + } + } else { + vref_mode_dq = 0x2; /* LPDDR3 */ + vref_value_dq = 0x1f; + } + vref_mode_ac = 0x2; + vref_value_ac = 0x1f; + } else if (params->base.dramtype == DDR3) { + /* DDR3L */ + vref_mode_dq = 0x1; + vref_value_dq = 0x1f; + vref_mode_ac = 0x1; + vref_value_ac = 0x1f; + } else { + debug("Unknown DRAM type.\n"); + return -EINVAL; + } + + reg_value = (vref_mode_dq << 9) | (0x1 << 8) | vref_value_dq; + + /* PHY_913 PHY_PAD_VREF_CTRL_DQ_0 12bits offset_8 */ + clrsetbits_le32(&denali_phy[913], 0xfff << 8, reg_value << 8); + /* PHY_914 PHY_PAD_VREF_CTRL_DQ_1 12bits offset_0 */ + clrsetbits_le32(&denali_phy[914], 0xfff, reg_value); + /* PHY_914 PHY_PAD_VREF_CTRL_DQ_2 12bits offset_16 */ + clrsetbits_le32(&denali_phy[914], 0xfff << 16, reg_value << 16); + /* PHY_915 PHY_PAD_VREF_CTRL_DQ_3 12bits offset_0 */ + clrsetbits_le32(&denali_phy[915], 0xfff, reg_value); + + reg_value = (vref_mode_ac << 9) | (0x1 << 8) | vref_value_ac; + + /* PHY_915 PHY_PAD_VREF_CTRL_AC 12bits offset_16 */ + clrsetbits_le32(&denali_phy[915], 0xfff << 16, reg_value << 16); + + if (params->base.dramtype == LPDDR4) + mode_sel = 0x6; + else if (params->base.dramtype == LPDDR3) + mode_sel = 0x0; + else if (params->base.dramtype == DDR3) + mode_sel = 0x1; + else + return -EINVAL; + + /* PHY_924 PHY_PAD_FDBK_DRIVE */ + clrsetbits_le32(&denali_phy[924], 0x7 << 15, mode_sel << 15); + /* PHY_926 PHY_PAD_DATA_DRIVE */ + clrsetbits_le32(&denali_phy[926], 0x7 << 6, mode_sel << 6); + /* PHY_927 PHY_PAD_DQS_DRIVE */ + clrsetbits_le32(&denali_phy[927], 0x7 << 6, mode_sel << 6); + /* PHY_928 PHY_PAD_ADDR_DRIVE */ + clrsetbits_le32(&denali_phy[928], 0x7 << 14, mode_sel << 14); + /* PHY_929 PHY_PAD_CLK_DRIVE */ + clrsetbits_le32(&denali_phy[929], 0x7 << 14, mode_sel << 14); + /* PHY_935 PHY_PAD_CKE_DRIVE */ + clrsetbits_le32(&denali_phy[935], 0x7 << 14, mode_sel << 14); + /* PHY_937 PHY_PAD_RST_DRIVE */ + clrsetbits_le32(&denali_phy[937], 0x7 << 14, mode_sel << 14); + /* PHY_939 PHY_PAD_CS_DRIVE */ + clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14); + + /* speed setting */ + if (params->base.ddr_freq < 400) + speed = 0x0; + else if (params->base.ddr_freq < 800) + speed = 0x1; + else if (params->base.ddr_freq < 1200) + speed = 0x2; + else + speed = 0x3; + + /* PHY_924 PHY_PAD_FDBK_DRIVE */ + clrsetbits_le32(&denali_phy[924], 0x3 << 21, speed << 21); + /* PHY_926 PHY_PAD_DATA_DRIVE */ + clrsetbits_le32(&denali_phy[926], 0x3 << 9, speed << 9); + /* PHY_927 PHY_PAD_DQS_DRIVE */ + clrsetbits_le32(&denali_phy[927], 0x3 << 9, speed << 9); + /* PHY_928 PHY_PAD_ADDR_DRIVE */ + clrsetbits_le32(&denali_phy[928], 0x3 << 17, speed << 17); + /* PHY_929 PHY_PAD_CLK_DRIVE */ + clrsetbits_le32(&denali_phy[929], 0x3 << 17, speed << 17); + /* PHY_935 PHY_PAD_CKE_DRIVE */ + clrsetbits_le32(&denali_phy[935], 0x3 << 17, speed << 17); + /* PHY_937 PHY_PAD_RST_DRIVE */ + clrsetbits_le32(&denali_phy[937], 0x3 << 17, speed << 17); + /* PHY_939 PHY_PAD_CS_DRIVE */ + clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17); + + return 0; +} + static void set_ds_odt(const struct chan_info *chan, const struct rk3399_sdram_params *params) { @@ -332,6 +492,8 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_pad_fdbk_term 1bit DENALI_PHY_930 offset_17 */ clrsetbits_le32(&denali_phy[930], 0x1 << 17, reg_value); + + phy_io_config(chan, params); }
static void pctl_start(struct dram_info *dram, u8 channel) @@ -376,166 +538,6 @@ static void pctl_start(struct dram_info *dram, u8 channel) dram->pwrup_srefresh_exit[channel]); }
-static int phy_io_config(const struct chan_info *chan, - const struct rk3399_sdram_params *params) -{ - u32 *denali_phy = chan->publ->denali_phy; - u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; - u32 mode_sel; - u32 reg_value; - u32 drv_value, odt_value; - u32 speed; - - /* vref setting */ - if (params->base.dramtype == LPDDR4) { - /* LPDDR4 */ - vref_mode_dq = 0x6; - vref_value_dq = 0x1f; - vref_mode_ac = 0x6; - vref_value_ac = 0x1f; - } else if (params->base.dramtype == LPDDR3) { - if (params->base.odt == 1) { - vref_mode_dq = 0x5; /* LPDDR3 ODT */ - drv_value = (readl(&denali_phy[6]) >> 12) & 0xf; - odt_value = (readl(&denali_phy[6]) >> 4) & 0xf; - if (drv_value == PHY_DRV_ODT_48) { - switch (odt_value) { - case PHY_DRV_ODT_240: - vref_value_dq = 0x16; - break; - case PHY_DRV_ODT_120: - vref_value_dq = 0x26; - break; - case PHY_DRV_ODT_60: - vref_value_dq = 0x36; - break; - default: - debug("Invalid ODT value.\n"); - return -EINVAL; - } - } else if (drv_value == PHY_DRV_ODT_40) { - switch (odt_value) { - case PHY_DRV_ODT_240: - vref_value_dq = 0x19; - break; - case PHY_DRV_ODT_120: - vref_value_dq = 0x23; - break; - case PHY_DRV_ODT_60: - vref_value_dq = 0x31; - break; - default: - debug("Invalid ODT value.\n"); - return -EINVAL; - } - } else if (drv_value == PHY_DRV_ODT_34_3) { - switch (odt_value) { - case PHY_DRV_ODT_240: - vref_value_dq = 0x17; - break; - case PHY_DRV_ODT_120: - vref_value_dq = 0x20; - break; - case PHY_DRV_ODT_60: - vref_value_dq = 0x2e; - break; - default: - debug("Invalid ODT value.\n"); - return -EINVAL; - } - } else { - debug("Invalid DRV value.\n"); - return -EINVAL; - } - } else { - vref_mode_dq = 0x2; /* LPDDR3 */ - vref_value_dq = 0x1f; - } - vref_mode_ac = 0x2; - vref_value_ac = 0x1f; - } else if (params->base.dramtype == DDR3) { - /* DDR3L */ - vref_mode_dq = 0x1; - vref_value_dq = 0x1f; - vref_mode_ac = 0x1; - vref_value_ac = 0x1f; - } else { - debug("Unknown DRAM type.\n"); - return -EINVAL; - } - - reg_value = (vref_mode_dq << 9) | (0x1 << 8) | vref_value_dq; - - /* PHY_913 PHY_PAD_VREF_CTRL_DQ_0 12bits offset_8 */ - clrsetbits_le32(&denali_phy[913], 0xfff << 8, reg_value << 8); - /* PHY_914 PHY_PAD_VREF_CTRL_DQ_1 12bits offset_0 */ - clrsetbits_le32(&denali_phy[914], 0xfff, reg_value); - /* PHY_914 PHY_PAD_VREF_CTRL_DQ_2 12bits offset_16 */ - clrsetbits_le32(&denali_phy[914], 0xfff << 16, reg_value << 16); - /* PHY_915 PHY_PAD_VREF_CTRL_DQ_3 12bits offset_0 */ - clrsetbits_le32(&denali_phy[915], 0xfff, reg_value); - - reg_value = (vref_mode_ac << 9) | (0x1 << 8) | vref_value_ac; - - /* PHY_915 PHY_PAD_VREF_CTRL_AC 12bits offset_16 */ - clrsetbits_le32(&denali_phy[915], 0xfff << 16, reg_value << 16); - - if (params->base.dramtype == LPDDR4) - mode_sel = 0x6; - else if (params->base.dramtype == LPDDR3) - mode_sel = 0x0; - else if (params->base.dramtype == DDR3) - mode_sel = 0x1; - else - return -EINVAL; - - /* PHY_924 PHY_PAD_FDBK_DRIVE */ - clrsetbits_le32(&denali_phy[924], 0x7 << 15, mode_sel << 15); - /* PHY_926 PHY_PAD_DATA_DRIVE */ - clrsetbits_le32(&denali_phy[926], 0x7 << 6, mode_sel << 6); - /* PHY_927 PHY_PAD_DQS_DRIVE */ - clrsetbits_le32(&denali_phy[927], 0x7 << 6, mode_sel << 6); - /* PHY_928 PHY_PAD_ADDR_DRIVE */ - clrsetbits_le32(&denali_phy[928], 0x7 << 14, mode_sel << 14); - /* PHY_929 PHY_PAD_CLK_DRIVE */ - clrsetbits_le32(&denali_phy[929], 0x7 << 14, mode_sel << 14); - /* PHY_935 PHY_PAD_CKE_DRIVE */ - clrsetbits_le32(&denali_phy[935], 0x7 << 14, mode_sel << 14); - /* PHY_937 PHY_PAD_RST_DRIVE */ - clrsetbits_le32(&denali_phy[937], 0x7 << 14, mode_sel << 14); - /* PHY_939 PHY_PAD_CS_DRIVE */ - clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14); - - /* speed setting */ - if (params->base.ddr_freq < 400) - speed = 0x0; - else if (params->base.ddr_freq < 800) - speed = 0x1; - else if (params->base.ddr_freq < 1200) - speed = 0x2; - else - speed = 0x3; - - /* PHY_924 PHY_PAD_FDBK_DRIVE */ - clrsetbits_le32(&denali_phy[924], 0x3 << 21, speed << 21); - /* PHY_926 PHY_PAD_DATA_DRIVE */ - clrsetbits_le32(&denali_phy[926], 0x3 << 9, speed << 9); - /* PHY_927 PHY_PAD_DQS_DRIVE */ - clrsetbits_le32(&denali_phy[927], 0x3 << 9, speed << 9); - /* PHY_928 PHY_PAD_ADDR_DRIVE */ - clrsetbits_le32(&denali_phy[928], 0x3 << 17, speed << 17); - /* PHY_929 PHY_PAD_CLK_DRIVE */ - clrsetbits_le32(&denali_phy[929], 0x3 << 17, speed << 17); - /* PHY_935 PHY_PAD_CKE_DRIVE */ - clrsetbits_le32(&denali_phy[935], 0x3 << 17, speed << 17); - /* PHY_937 PHY_PAD_RST_DRIVE */ - clrsetbits_le32(&denali_phy[937], 0x3 << 17, speed << 17); - /* PHY_939 PHY_PAD_CS_DRIVE */ - clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17); - - return 0; -} - static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, u32 channel, const struct rk3399_sdram_params *params) { @@ -545,7 +547,6 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, const u32 *params_ctl = params->pctl_regs.denali_ctl; const u32 *params_phy = params->phy_regs.denali_phy; u32 tmp, tmp1, tmp2; - int ret;
/* * work around controller bug: @@ -623,10 +624,6 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, tmp = (readl(&denali_phy[467]) >> 16) & 0xff; clrsetbits_le32(&denali_phy[467], 0xff << 16, (tmp + 0x10) << 16);
- ret = phy_io_config(chan, params); - if (ret) - return ret; - return 0; }
Supporting LPDDR4 code support in RK3399 would increases the size of SPL/TPL.
So add kconfig entry for RK3399 LPDDR4 code so-that the boards have LPDDR4 can enable them via defconfig.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index 151ffb684d..4f274e01b3 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -23,4 +23,11 @@ config RAM_RK3399 This enables ram drivers support for the platforms based on Rockchip RK3399 SoC.
+config RAM_RK3399_LPDDR4 + bool "LPDDR4 support for Rockchip RK3399" + depends on RAM_RK3399 + help + This enables LPDDR4 sdram code support for the platforms based + on Rockchip RK3399 SoC. + endif # RAM_ROCKCHIP
Add rank_mask based on the rank number for lpddr4.
This would keep the ca data training loop based on the desired rank mask value instead of looping for all values.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 7f01681a01..d967a602bc 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -687,7 +687,10 @@ static int data_training_ca(const struct chan_info *chan, u32 channel, /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175]));
- rank_mask = (rank == 1) ? 0x1 : 0x3; + if (params->base.dramtype == LPDDR4) + rank_mask = (rank == 1) ? 0x5 : 0xf; + else + rank_mask = (rank == 1) ? 0x1 : 0x3;
for (i = 0; i < 4; i++) { if (!(rank_mask & (1 << i)))
This would keep the wdql data training loop based on the desired rank mask value instead of looping for all values.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index d967a602bc..935e3c495e 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -925,7 +925,10 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, /* clear interrupt,PI_175 PI_INT_ACK:WR:0:17 */ writel(0x00003f7c, (&denali_pi[175]));
mode_sel assignment is based on dram type.
In phy_io_config, already have vref setting based on the dram type, so move this mode_sel assignment on vref setting area.
No functionality change.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 12 +++--------- 1 file changed, 3 insertions(+), 9 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 935e3c495e..3e7261a950 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -205,6 +205,7 @@ static int phy_io_config(const struct chan_info *chan, vref_value_dq = 0x1f; vref_mode_ac = 0x6; vref_value_ac = 0x1f; + mode_sel = 0x6; } else if (params->base.dramtype == LPDDR3) { if (params->base.odt == 1) { vref_mode_dq = 0x5; /* LPDDR3 ODT */ @@ -265,12 +266,14 @@ static int phy_io_config(const struct chan_info *chan, } vref_mode_ac = 0x2; vref_value_ac = 0x1f; + mode_sel = 0x0; } else if (params->base.dramtype == DDR3) { /* DDR3L */ vref_mode_dq = 0x1; vref_value_dq = 0x1f; vref_mode_ac = 0x1; vref_value_ac = 0x1f; + mode_sel = 0x1; } else { debug("Unknown DRAM type.\n"); return -EINVAL; @@ -292,15 +295,6 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_915 PHY_PAD_VREF_CTRL_AC 12bits offset_16 */ clrsetbits_le32(&denali_phy[915], 0xfff << 16, reg_value << 16);
- if (params->base.dramtype == LPDDR4) - mode_sel = 0x6; - else if (params->base.dramtype == LPDDR3) - mode_sel = 0x0; - else if (params->base.dramtype == DDR3) - mode_sel = 0x1; - else - return -EINVAL; - /* PHY_924 PHY_PAD_FDBK_DRIVE */ clrsetbits_le32(&denali_phy[924], 0x7 << 15, mode_sel << 15); /* PHY_926 PHY_PAD_DATA_DRIVE */
lpddr4 has PLL bypass mode during phy initialization phase, which does all pll configurations.
So no need to wait explicitly during pctl config.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 26 ++++++++++++++++---------- 1 file changed, 16 insertions(+), 10 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 3e7261a950..4d2310cbe6 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -570,16 +570,22 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, setbits_le32(&denali_pi[0], START); setbits_le32(&denali_ctl[0], START);
- /* Waiting for phy DLL lock */ - while (1) { - tmp = readl(&denali_phy[920]); - tmp1 = readl(&denali_phy[921]); - tmp2 = readl(&denali_phy[922]); - if ((((tmp >> 16) & 0x1) == 0x1) && - (((tmp1 >> 16) & 0x1) == 0x1) && - (((tmp1 >> 0) & 0x1) == 0x1) && - (((tmp2 >> 0) & 0x1) == 0x1)) - break; + /** + * LPDDR4 use PLL bypass mode for init + * not need to wait for the PLL to lock + */ + if (params->base.dramtype != LPDDR4) { + /* Waiting for phy DLL lock */ + while (1) { + tmp = readl(&denali_phy[920]); + tmp1 = readl(&denali_phy[921]); + tmp2 = readl(&denali_phy[922]); + if ((((tmp >> 16) & 0x1) == 0x1) && + (((tmp1 >> 16) & 0x1) == 0x1) && + (((tmp1 >> 0) & 0x1) == 0x1) && + (((tmp2 >> 0) & 0x1) == 0x1)) + break; + } }
copy_to_reg(&denali_phy[896], ¶ms_phy[896], (958 - 895) * 4);
It is possible in lpddr4 dram, where both the channels would start at same time with ZQ Cal Start. If it uses ZQ Call start then it will use RZQ.
For example LPDDR4 366 Dual-Die, Quad-Channel Package, RZQ maybe connect to both channel. If ZQ Cal Start at the same time, it will use the same RZQ.
It is not a problem of using RZQ in both the channels, but can not use at the same time.
So, to avoid this, we have an option of dram tINIT3 value for increasing the frequency for channel 1.
This patch increase the available tINIT3 with existing running dram frequency.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 4d2310cbe6..0a5152c710 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -550,6 +550,20 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, sizeof(struct rk3399_ddr_pctl_regs) - 4); writel(params_ctl[0], &denali_ctl[0]);
+ /* + * two channel init at the same time, then ZQ Cal Start + * at the same time, it will use the same RZQ, but cannot + * start at the same time. + * + * So, increase tINIT3 for channel 1, will avoid two + * channel ZQ Cal Start at the same time + */ + if (params->base.dramtype == LPDDR4 && channel == 1) { + tmp = ((params->base.ddr_freq * MHz + 999) / 1000); + tmp1 = readl(&denali_ctl[14]); + writel(tmp + tmp1, &denali_ctl[14]); + } + copy_to_reg(denali_pi, ¶ms->pi_regs.denali_pi[0], sizeof(struct rk3399_ddr_pi_regs));
PHY_898, PHY_919 would require to configure PHY LP4 boot pll control and ca for lpddr4.
So, configure the same in pctl_cfg for LPDDR4.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 0a5152c710..f04819bacb 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -574,6 +574,11 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, writel(params->phy_regs.denali_phy[911], &denali_phy[911]); writel(params->phy_regs.denali_phy[912], &denali_phy[912]);
+ if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + writel(params->phy_regs.denali_phy[898], &denali_phy[898]); + writel(params->phy_regs.denali_phy[919], &denali_phy[919]); + } + dram->pwrup_srefresh_exit[channel] = readl(&denali_ctl[68]) & PWRUP_SREFRESH_EXIT; clrbits_le32(&denali_ctl[68], PWRUP_SREFRESH_EXIT);
Configure BOOSTP_EN, BOOSTN_EN for lpddr4 during phy IO config.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index f04819bacb..1a5546189b 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -35,6 +35,9 @@ #define PHY_DRV_ODT_40 0xe #define PHY_DRV_ODT_34_3 0xf
+#define PHY_BOOSTP_EN 0x1 +#define PHY_BOOSTN_EN 0x1 + #define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ ((n) << (8 + (ch) * 4))) #define CRU_SFTRST_DDR_PHY(ch, n) ((0x1 << (9 + 16 + (ch) * 4)) | \ @@ -312,6 +315,27 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x7 << 14, mode_sel << 14);
+ if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + /* BOOSTP_EN & BOOSTN_EN */ + reg_value = ((PHY_BOOSTP_EN << 4) | PHY_BOOSTN_EN); + /* PHY_925 PHY_PAD_FDBK_DRIVE2 */ + clrsetbits_le32(&denali_phy[925], 0xff << 8, reg_value << 8); + /* PHY_926 PHY_PAD_DATA_DRIVE */ + clrsetbits_le32(&denali_phy[926], 0xff << 12, reg_value << 12); + /* PHY_927 PHY_PAD_DQS_DRIVE */ + clrsetbits_le32(&denali_phy[927], 0xff << 14, reg_value << 14); + /* PHY_928 PHY_PAD_ADDR_DRIVE */ + clrsetbits_le32(&denali_phy[928], 0xff << 20, reg_value << 20); + /* PHY_929 PHY_PAD_CLK_DRIVE */ + clrsetbits_le32(&denali_phy[929], 0xff << 22, reg_value << 22); + /* PHY_935 PHY_PAD_CKE_DRIVE */ + clrsetbits_le32(&denali_phy[935], 0xff << 20, reg_value << 20); + /* PHY_937 PHY_PAD_RST_DRIVE */ + clrsetbits_le32(&denali_phy[937], 0xff << 20, reg_value << 20); + /* PHY_939 PHY_PAD_CS_DRIVE */ + clrsetbits_le32(&denali_phy[939], 0xff << 20, reg_value << 20); + } + /* speed setting */ if (params->base.ddr_freq < 400) speed = 0x0;
Configure SLEWP_EN, SLEWN_EN for lpddr4 during phy IO config.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1a5546189b..1d2c2385f1 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -37,6 +37,8 @@
#define PHY_BOOSTP_EN 0x1 #define PHY_BOOSTN_EN 0x1 +#define PHY_SLEWP_EN 0x1 +#define PHY_SLEWN_EN 0x1
#define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ ((n) << (8 + (ch) * 4))) @@ -334,6 +336,25 @@ static int phy_io_config(const struct chan_info *chan, clrsetbits_le32(&denali_phy[937], 0xff << 20, reg_value << 20); /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0xff << 20, reg_value << 20); + + /* SLEWP_EN & SLEWN_EN */ + reg_value = ((PHY_SLEWP_EN << 3) | PHY_SLEWN_EN); + /* PHY_924 PHY_PAD_FDBK_DRIVE */ + clrsetbits_le32(&denali_phy[924], 0x3f << 8, reg_value << 8); + /* PHY_926 PHY_PAD_DATA_DRIVE */ + clrsetbits_le32(&denali_phy[926], 0x3f, reg_value); + /* PHY_927 PHY_PAD_DQS_DRIVE */ + clrsetbits_le32(&denali_phy[927], 0x3f, reg_value); + /* PHY_928 PHY_PAD_ADDR_DRIVE */ + clrsetbits_le32(&denali_phy[928], 0x3f << 8, reg_value << 8); + /* PHY_929 PHY_PAD_CLK_DRIVE */ + clrsetbits_le32(&denali_phy[929], 0x3f << 8, reg_value << 8); + /* PHY_935 PHY_PAD_CKE_DRIVE */ + clrsetbits_le32(&denali_phy[935], 0x3f << 8, reg_value << 8); + /* PHY_937 PHY_PAD_RST_DRIVE */ + clrsetbits_le32(&denali_phy[937], 0x3f << 8, reg_value << 8); + /* PHY_939 PHY_PAD_CS_DRIVE */ + clrsetbits_le32(&denali_phy[939], 0x3f << 8, reg_value << 8); }
/* speed setting */
Configure PHY RX_CM_INPUT for lpddr4 during phy IO config.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 1d2c2385f1..ae227b958f 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -39,6 +39,7 @@ #define PHY_BOOSTN_EN 0x1 #define PHY_SLEWP_EN 0x1 #define PHY_SLEWN_EN 0x1 +#define PHY_RX_CM_INPUT 0x1
#define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ ((n) << (8 + (ch) * 4))) @@ -384,6 +385,27 @@ static int phy_io_config(const struct chan_info *chan, /* PHY_939 PHY_PAD_CS_DRIVE */ clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17);
+ if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + /* RX_CM_INPUT */ + reg_value = PHY_RX_CM_INPUT; + /* PHY_924 PHY_PAD_FDBK_DRIVE */ + clrsetbits_le32(&denali_phy[924], 0x1 << 14, reg_value << 14); + /* PHY_926 PHY_PAD_DATA_DRIVE */ + clrsetbits_le32(&denali_phy[926], 0x1 << 11, reg_value << 11); + /* PHY_927 PHY_PAD_DQS_DRIVE */ + clrsetbits_le32(&denali_phy[927], 0x1 << 13, reg_value << 13); + /* PHY_928 PHY_PAD_ADDR_DRIVE */ + clrsetbits_le32(&denali_phy[928], 0x1 << 19, reg_value << 19); + /* PHY_929 PHY_PAD_CLK_DRIVE */ + clrsetbits_le32(&denali_phy[929], 0x1 << 21, reg_value << 21); + /* PHY_935 PHY_PAD_CKE_DRIVE */ + clrsetbits_le32(&denali_phy[935], 0x1 << 19, reg_value << 19); + /* PHY_937 PHY_PAD_RST_DRIVE */ + clrsetbits_le32(&denali_phy[937], 0x1 << 19, reg_value << 19); + /* PHY_939 PHY_PAD_CS_DRIVE */ + clrsetbits_le32(&denali_phy[939], 0x1 << 19, reg_value << 19); + } + return 0; }
Assign desired cs_map values for lpddr4 during set memory map.
Initial cs_map values is based on the sdram parameters, so the same will adjusted based dramtype as LPDDR4.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ae227b958f..e03181fbc9 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -188,6 +188,16 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, clrsetbits_le32(&denali_pi[155], (0x3 << 16) | (0x7 << 24), ((3 - sdram_ch->cap_info.bk) << 16) | ((16 - row) << 24)); + + if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + if (cs_map == 1) + cs_map = 0x5; + else if (cs_map == 2) + cs_map = 0xa; + else + cs_map = 0xF; + } + /* PI_41 PI_CS_MAP:RW:24:4 */ clrsetbits_le32(&denali_pi[41], 0xf << 24, cs_map << 24); if (sdram_ch->cap_info.rank == 1 && params->base.dramtype == DDR3)
tsel write ca_p and ca_n values need to write on PHY 544, 672 and 800 to configure ds odt.
Configure the same PHY register for lpddr4 would require a mask value of (300 << 8).
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e03181fbc9..41dd19a9e6 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -502,9 +502,18 @@ static void set_ds_odt(const struct chan_info *chan,
/* phy_adr_tsel_select_ 8bits DENALI_PHY_544/672/800 offset_0 */ reg_value = tsel_wr_select_ca_n | (tsel_wr_select_ca_p << 0x4); - clrsetbits_le32(&denali_phy[544], 0xff, reg_value); - clrsetbits_le32(&denali_phy[672], 0xff, reg_value); - clrsetbits_le32(&denali_phy[800], 0xff, reg_value); + if (IS_ENABLED(CONFIG_RAM_RK3399_LPDDR4)) { + /* LPDDR4 these register read always return 0, so + * can not use clrsetbits_le32(), need to write32 + */ + writel((0x300 << 8) | reg_value, &denali_phy[544]); + writel((0x300 << 8) | reg_value, &denali_phy[672]); + writel((0x300 << 8) | reg_value, &denali_phy[800]); + } else { + clrsetbits_le32(&denali_phy[544], 0xff, reg_value); + clrsetbits_le32(&denali_phy[672], 0xff, reg_value); + clrsetbits_le32(&denali_phy[800], 0xff, reg_value); + }
/* phy_pad_addr_drive 8bits DENALI_PHY_928 offset_0 */ clrsetbits_le32(&denali_phy[928], 0xff, reg_value);
The hardware for LPDDR4 with - CLK0P/N connect to lower 16-bits - CLK1P/N connect to higher 16-bits
and usually dfi dram clk is configured via CLK1P/N, so disabling dfi dram clk will disable the CLK1P/N as well.
So, add patch to not to disable dfi dram clk for lpddr4, with rank 1.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 41dd19a9e6..d1b3aeef47 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1226,8 +1226,18 @@ static void dram_all_config(struct dram_info *dram, writel(noc_timing->ddrmode.d32, &ddr_msch_regs->ddrmode);
- /* rank 1 memory clock disable (dfi_dram_clk_disable = 1) */ - if (params->ch[channel].cap_info.rank == 1) + /** + * rank 1 memory clock disable (dfi_dram_clk_disable = 1) + * + * The hardware for LPDDR4 with + * - CLK0P/N connect to lower 16-bits + * - CLK1P/N connect to higher 16-bits + * + * dfi dram clk is configured via CLK1P/N, so disabling + * dfi dram clk will disable the CLK1P/N as well for lpddr4. + */ + if (params->ch[channel].cap_info.rank == 1 && + params->base.dramtype != LPDDR4) setbits_le32(&dram->chan[channel].pctl->denali_ctl[276], 1 << 17); }
Add IO settings for dram ctl and phy.
IO settings are useful for configuring ctl, phy odt, vref, mr5, mode select and other needed input output operations for lpddr4 or any other dramtype sdram.
Right now, this patch added IO setting for all supported sdram frequencies.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 104 ++++++++++++++++++++++++++++ 1 file changed, 104 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index d1b3aeef47..4de5a208f5 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -80,6 +80,110 @@ struct rockchip_dmc_plat { struct regmap *map; };
+struct io_setting { + u32 mhz; + u32 mr5; + /* dram side */ + u32 dq_odt; + u32 ca_odt; + u32 pdds; + u32 dq_vref; + u32 ca_vref; + /* phy side */ + u32 rd_odt; + u32 wr_dq_drv; + u32 wr_ca_drv; + u32 wr_ckcs_drv; + u32 rd_odt_en; + u32 rd_vref; +} lpddr4_io_setting[] = { + { + 50 * MHz, + 0, + /* dram side */ + 0, /* dq_odt; */ + 0, /* ca_odt; */ + 6, /* pdds; */ + 0x72, /* dq_vref; */ + 0x72, /* ca_vref; */ + /* phy side */ + PHY_DRV_ODT_HI_Z, /* rd_odt; */ + PHY_DRV_ODT_40, /* wr_dq_drv; */ + PHY_DRV_ODT_40, /* wr_ca_drv; */ + PHY_DRV_ODT_40, /* wr_ckcs_drv; */ + 0, /* rd_odt_en;*/ + 41, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + }, + { + 600 * MHz, + 0, + /* dram side */ + 1, /* dq_odt; */ + 0, /* ca_odt; */ + 6, /* pdds; */ + 0x72, /* dq_vref; */ + 0x72, /* ca_vref; */ + /* phy side */ + PHY_DRV_ODT_HI_Z, /* rd_odt; */ + PHY_DRV_ODT_48, /* wr_dq_drv; */ + PHY_DRV_ODT_40, /* wr_ca_drv; */ + PHY_DRV_ODT_40, /* wr_ckcs_drv; */ + 0, /* rd_odt_en; */ + 32, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + }, + { + 800 * MHz, + 0, + /* dram side */ + 1, /* dq_odt; */ + 0, /* ca_odt; */ + 1, /* pdds; */ + 0x72, /* dq_vref; */ + 0x72, /* ca_vref; */ + /* phy side */ + PHY_DRV_ODT_40, /* rd_odt; */ + PHY_DRV_ODT_48, /* wr_dq_drv; */ + PHY_DRV_ODT_40, /* wr_ca_drv; */ + PHY_DRV_ODT_40, /* wr_ckcs_drv; */ + 1, /* rd_odt_en; */ + 17, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + }, + { + 933 * MHz, + 0, + /* dram side */ + 3, /* dq_odt; */ + 0, /* ca_odt; */ + 6, /* pdds; */ + 0x59, /* dq_vref; 32% */ + 0x72, /* ca_vref; */ + /* phy side */ + PHY_DRV_ODT_HI_Z, /* rd_odt; */ + PHY_DRV_ODT_48, /* wr_dq_drv; */ + PHY_DRV_ODT_40, /* wr_ca_drv; */ + PHY_DRV_ODT_40, /* wr_ckcs_drv; */ + 0, /* rd_odt_en; */ + 32, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + }, + { + 1066 * MHz, + 0, + /* dram side */ + 6, /* dq_odt; */ + 0, /* ca_odt; */ + 1, /* pdds; */ + 0x10, /* dq_vref; */ + 0x72, /* ca_vref; */ + /* phy side */ + PHY_DRV_ODT_40, /* rd_odt; */ + PHY_DRV_ODT_60, /* wr_dq_drv; */ + PHY_DRV_ODT_40, /* wr_ca_drv; */ + PHY_DRV_ODT_40, /* wr_ckcs_drv; */ + 1, /* rd_odt_en; */ + 17, /* rd_vref; (unit %, range 3.3% - 48.7%) */ + }, +}; + static void *get_ddrc0_con(struct dram_info *dram, u8 channel) { return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc0_con1;
Now we have IO settings available for all supported sdram frequencies, so retrieve these IO settings and make used for LPDDR4 ds odt configuration.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 42 ++++++++++++++++++++++++----- 1 file changed, 36 insertions(+), 6 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 4de5a208f5..22c1a66185 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -184,6 +184,33 @@ struct io_setting { }, };
+/** + * phy = 0, PHY boot freq + * phy = 1, PHY index 0 + * phy = 2, PHY index 1 + */ +static struct io_setting * +lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) +{ + struct io_setting *io = NULL; + u32 n; + + for (n = 0; n < ARRAY_SIZE(lpddr4_io_setting); n++) { + io = &lpddr4_io_setting[n]; + + if (io->mr5 != 0) { + if (io->mhz >= params->base.ddr_freq && + io->mr5 == mr5) + break; + } else { + if (io->mhz >= params->base.ddr_freq) + break; + } + } + + return io; +} + static void *get_ddrc0_con(struct dram_info *dram, u8 channel) { return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc0_con1; @@ -524,7 +551,7 @@ static int phy_io_config(const struct chan_info *chan, }
static void set_ds_odt(const struct chan_info *chan, - const struct rk3399_sdram_params *params) + const struct rk3399_sdram_params *params, u32 mr5) { u32 *denali_phy = chan->publ->denali_phy;
@@ -533,19 +560,22 @@ static void set_ds_odt(const struct chan_info *chan, u32 tsel_idle_select_n, tsel_rd_select_n; u32 tsel_wr_select_dq_p, tsel_wr_select_ca_p; u32 tsel_wr_select_dq_n, tsel_wr_select_ca_n; + struct io_setting *io = NULL; u32 reg_value;
if (params->base.dramtype == LPDDR4) { + io = lpddr4_get_io_settings(params, mr5); + tsel_rd_select_p = PHY_DRV_ODT_HI_Z; - tsel_rd_select_n = PHY_DRV_ODT_240; + tsel_rd_select_n = io->rd_odt;
tsel_idle_select_p = PHY_DRV_ODT_HI_Z; tsel_idle_select_n = PHY_DRV_ODT_240;
- tsel_wr_select_dq_p = PHY_DRV_ODT_40; + tsel_wr_select_dq_p = io->wr_dq_drv; tsel_wr_select_dq_n = PHY_DRV_ODT_40;
- tsel_wr_select_ca_p = PHY_DRV_ODT_40; + tsel_wr_select_ca_p = io->wr_ca_drv; tsel_wr_select_ca_n = PHY_DRV_ODT_40; } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; @@ -723,7 +753,7 @@ static void pctl_start(struct dram_info *dram, u8 channel) }
static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, - u32 channel, const struct rk3399_sdram_params *params) + u32 channel, struct rk3399_sdram_params *params) { u32 *denali_ctl = chan->pctl->denali_ctl; u32 *denali_pi = chan->pi->denali_pi; @@ -805,7 +835,7 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, copy_to_reg(&denali_phy[512], ¶ms_phy[512], (549 - 512 + 1) * 4); copy_to_reg(&denali_phy[640], ¶ms_phy[640], (677 - 640 + 1) * 4); copy_to_reg(&denali_phy[768], ¶ms_phy[768], (805 - 768 + 1) * 4); - set_ds_odt(chan, params); + set_ds_odt(chan, params, 0);
/* * phy_dqs_tsel_wr_timing_X 8bits DENALI_PHY_84/212/340/468 offset_8
tsel contrl clock drives are required to configure PHY 929, 939 controls drive settings.
Add support for these control clock for all dramtype sdrams.
Thse control clock drives are configure via tsel_ckcs_select_p and tsel_ckcs_select_n variables.
tsel_ckcs_select_n is PHY_DRV_ODT_34_3 value where as tsel_ckcs_select_p is retrived from IO settings for lpddr4 and rest uses PHY_DRV_ODT_34_3.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 16 ++++++++++++++-- 1 file changed, 14 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 22c1a66185..caf8180018 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -560,6 +560,7 @@ static void set_ds_odt(const struct chan_info *chan, u32 tsel_idle_select_n, tsel_rd_select_n; u32 tsel_wr_select_dq_p, tsel_wr_select_ca_p; u32 tsel_wr_select_dq_n, tsel_wr_select_ca_n; + u32 tsel_ckcs_select_p, tsel_ckcs_select_n; struct io_setting *io = NULL; u32 reg_value;
@@ -577,6 +578,9 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_wr_select_ca_p = io->wr_ca_drv; tsel_wr_select_ca_n = PHY_DRV_ODT_40; + + tsel_ckcs_select_p = io->wr_ckcs_drv; + tsel_ckcs_select_n = PHY_DRV_ODT_34_3; } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_rd_select_n = PHY_DRV_ODT_HI_Z; @@ -589,6 +593,9 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_wr_select_ca_p = PHY_DRV_ODT_48; tsel_wr_select_ca_n = PHY_DRV_ODT_48; + + tsel_ckcs_select_p = PHY_DRV_ODT_34_3; + tsel_ckcs_select_n = PHY_DRV_ODT_34_3; } else { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_rd_select_n = PHY_DRV_ODT_240; @@ -601,6 +608,9 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_wr_select_ca_p = PHY_DRV_ODT_34_3; tsel_wr_select_ca_n = PHY_DRV_ODT_34_3; + + tsel_ckcs_select_p = PHY_DRV_ODT_34_3; + tsel_ckcs_select_n = PHY_DRV_ODT_34_3; }
if (params->base.odt == 1) @@ -659,10 +669,12 @@ static void set_ds_odt(const struct chan_info *chan, clrsetbits_le32(&denali_phy[935], 0xff, reg_value);
/* phy_pad_cs_drive 8bits DENALI_PHY_939 offset_0 */ - clrsetbits_le32(&denali_phy[939], 0xff, reg_value); + clrsetbits_le32(&denali_phy[939], 0xff, + tsel_ckcs_select_n | (tsel_ckcs_select_p << 0x4));
/* phy_pad_clk_drive 8bits DENALI_PHY_929 offset_0 */ - clrsetbits_le32(&denali_phy[929], 0xff, reg_value); + clrsetbits_le32(&denali_phy[929], 0xff, + tsel_ckcs_select_n | (tsel_ckcs_select_p << 0x4));
/* phy_pad_fdbk_drive 23bit DENALI_PHY_924/925 */ clrsetbits_le32(&denali_phy[924], 0xff,
CTL 145, 146, 159, 160 registers are used to configure soc odt on rk3399.
These soc odt values are updated from CS0_MR22_VAL and CS1_MR22_VAL and for lpddr4 these values ORed with tsel_rd_select_n.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 49 ++++++++++++++++++++++++++++- 1 file changed, 48 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index caf8180018..5f118fc0c6 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -40,6 +40,8 @@ #define PHY_SLEWP_EN 0x1 #define PHY_SLEWN_EN 0x1 #define PHY_RX_CM_INPUT 0x1 +#define CS0_MR22_VAL 0 +#define CS1_MR22_VAL 3
#define CRU_SFTRST_DDR_CTRL(ch, n) ((0x1 << (8 + 16 + (ch) * 4)) | \ ((n) << (8 + (ch) * 4))) @@ -554,7 +556,7 @@ static void set_ds_odt(const struct chan_info *chan, const struct rk3399_sdram_params *params, u32 mr5) { u32 *denali_phy = chan->publ->denali_phy; - + u32 *denali_ctl = chan->pctl->denali_ctl; u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; u32 tsel_idle_select_p, tsel_rd_select_p; u32 tsel_idle_select_n, tsel_rd_select_n; @@ -562,6 +564,7 @@ static void set_ds_odt(const struct chan_info *chan, u32 tsel_wr_select_dq_n, tsel_wr_select_ca_n; u32 tsel_ckcs_select_p, tsel_ckcs_select_n; struct io_setting *io = NULL; + u32 soc_odt = 0; u32 reg_value;
if (params->base.dramtype == LPDDR4) { @@ -581,6 +584,35 @@ static void set_ds_odt(const struct chan_info *chan,
tsel_ckcs_select_p = io->wr_ckcs_drv; tsel_ckcs_select_n = PHY_DRV_ODT_34_3; + switch (tsel_rd_select_n) { + case PHY_DRV_ODT_240: + soc_odt = 1; + break; + case PHY_DRV_ODT_120: + soc_odt = 2; + break; + case PHY_DRV_ODT_80: + soc_odt = 3; + break; + case PHY_DRV_ODT_60: + soc_odt = 4; + break; + case PHY_DRV_ODT_48: + soc_odt = 5; + break; + case PHY_DRV_ODT_40: + soc_odt = 6; + break; + case PHY_DRV_ODT_34_3: + soc_odt = 6; + printf("%s: Unable to support LPDDR4 MR22 Soc ODT\n", + __func__); + break; + case PHY_DRV_ODT_HI_Z: + default: + soc_odt = 0; + break; + } } else if (params->base.dramtype == LPDDR3) { tsel_rd_select_p = PHY_DRV_ODT_240; tsel_rd_select_n = PHY_DRV_ODT_HI_Z; @@ -621,6 +653,21 @@ static void set_ds_odt(const struct chan_info *chan, tsel_wr_en = 0; tsel_idle_en = 0;
+ /* F0_0 */ + clrsetbits_le32(&denali_ctl[145], 0xFF << 16, + (soc_odt | (CS0_MR22_VAL << 3)) << 16); + /* F2_0, F1_0 */ + clrsetbits_le32(&denali_ctl[146], 0xFF00FF, + ((soc_odt | (CS0_MR22_VAL << 3)) << 16) | + (soc_odt | (CS0_MR22_VAL << 3))); + /* F0_1 */ + clrsetbits_le32(&denali_ctl[159], 0xFF << 16, + (soc_odt | (CS1_MR22_VAL << 3)) << 16); + /* F2_1, F1_1 */ + clrsetbits_le32(&denali_ctl[160], 0xFF00FF, + ((soc_odt | (CS1_MR22_VAL << 3)) << 16) | + (soc_odt | (CS1_MR22_VAL << 3))); + /* * phy_dq_tsel_select_X 24bits DENALI_PHY_6/134/262/390 offset_0 * sets termination values for read/idle cycles and drive strength
For base.odt 1 the lpddr4 tsel_rd_en value is depending on IO settings of rd_odt_en.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 5f118fc0c6..9eddfa7fd7 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -645,10 +645,14 @@ static void set_ds_odt(const struct chan_info *chan, tsel_ckcs_select_n = PHY_DRV_ODT_34_3; }
- if (params->base.odt == 1) + if (params->base.odt == 1) { tsel_rd_en = 1; - else + + if (params->base.dramtype == LPDDR4) + tsel_rd_en = io->rd_odt_en; + } else { tsel_rd_en = 0; + }
The vref_mode_dq, vref_value_dq on lpddr4 value is depending on IO settings of rd_vref.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 19 ++++++++++++++----- 1 file changed, 14 insertions(+), 5 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 9eddfa7fd7..24db601072 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -338,7 +338,7 @@ static void set_memory_map(const struct chan_info *chan, u32 channel, }
static int phy_io_config(const struct chan_info *chan, - const struct rk3399_sdram_params *params) + const struct rk3399_sdram_params *params, u32 mr5) { u32 *denali_phy = chan->publ->denali_phy; u32 vref_mode_dq, vref_value_dq, vref_mode_ac, vref_value_ac; @@ -349,9 +349,18 @@ static int phy_io_config(const struct chan_info *chan,
/* vref setting */ if (params->base.dramtype == LPDDR4) { - /* LPDDR4 */ - vref_mode_dq = 0x6; - vref_value_dq = 0x1f; + struct io_setting *io = lpddr4_get_io_settings(params, mr5); + u32 rd_vref = io->rd_vref * 1000; + + if (rd_vref < 36700) { + /* MODE_LV[2:0] = LPDDR4 (Range 2)*/ + vref_mode_dq = 0x7; + vref_value_dq = (rd_vref - 3300) / 521; + } else { + /* MODE_LV[2:0] = LPDDR4 (Range 1)*/ + vref_mode_dq = 0x6; + vref_value_dq = (rd_vref - 15300) / 521; + } vref_mode_ac = 0x6; vref_value_ac = 0x1f; mode_sel = 0x6; @@ -770,7 +779,7 @@ static void set_ds_odt(const struct chan_info *chan, /* phy_pad_fdbk_term 1bit DENALI_PHY_930 offset_17 */ clrsetbits_le32(&denali_phy[930], 0x1 << 17, reg_value);
- phy_io_config(chan, params); + phy_io_config(chan, params, mr5); }
The mode_sel on lpddr4 value is depending on IO settings of rd_vref.
Add support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 24db601072..0e98079468 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -347,7 +347,7 @@ static int phy_io_config(const struct chan_info *chan, u32 drv_value, odt_value; u32 speed;
- /* vref setting */ + /* vref setting & mode setting */ if (params->base.dramtype == LPDDR4) { struct io_setting *io = lpddr4_get_io_settings(params, mr5); u32 rd_vref = io->rd_vref * 1000; @@ -355,15 +355,18 @@ static int phy_io_config(const struct chan_info *chan, if (rd_vref < 36700) { /* MODE_LV[2:0] = LPDDR4 (Range 2)*/ vref_mode_dq = 0x7; + /* MODE[2:0]= LPDDR4 Range 2(0.4*VDDQ) */ + mode_sel = 0x5; vref_value_dq = (rd_vref - 3300) / 521; } else { /* MODE_LV[2:0] = LPDDR4 (Range 1)*/ vref_mode_dq = 0x6; + /* MODE[2:0]= LPDDR4 Range 1(0.33*VDDQ) */ + mode_sel = 0x4; vref_value_dq = (rd_vref - 15300) / 521; } vref_mode_ac = 0x6; vref_value_ac = 0x1f; - mode_sel = 0x6; } else if (params->base.dramtype == LPDDR3) { if (params->base.odt == 1) { vref_mode_dq = 0x5; /* LPDDR3 ODT */
Update vref_mode_ac for lpddr4 based on VDDQ/3/2=16.8%
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 0e98079468..e3180d0ef2 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -366,7 +366,8 @@ static int phy_io_config(const struct chan_info *chan, vref_value_dq = (rd_vref - 15300) / 521; } vref_mode_ac = 0x6; - vref_value_ac = 0x1f; + /* VDDQ/3/2=16.8% */ + vref_value_ac = 0x3; } else if (params->base.dramtype == LPDDR3) { if (params->base.odt == 1) { vref_mode_dq = 0x5; /* LPDDR3 ODT */
data training is using chan_info as first argument with channel number as second argument instead of that use dram_info as first argument so-that we can get the chan_info at data training definition.
This was the argument handling is meaningful, readable and it would help to add similar data training for lpddr4 in future.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e3180d0ef2..927c7cced3 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1286,10 +1286,11 @@ static int data_training_wdql(const struct chan_info *chan, u32 channel, return 0; }
-static int data_training(const struct chan_info *chan, u32 channel, +static int data_training(struct dram_info *dram, u32 channel, const struct rk3399_sdram_params *params, u32 training_flag) { + struct chan_info *chan = &dram->chan[channel]; u32 *denali_phy = chan->publ->denali_phy; int ret;
@@ -1499,8 +1500,7 @@ static int switch_to_phy_index1(struct dram_info *dram, for (channel = 0; channel < ch_count; channel++) { denali_phy = dram->chan[channel].publ->denali_phy; clrsetbits_le32(&denali_phy[896], (0x3 << 8) | 1, 1 << 8); - ret = data_training(&dram->chan[channel], channel, - params, PI_FULL_TRAINING); + ret = data_training(dram, channel, params, PI_FULL_TRAINING); if (ret < 0) { debug("index1 training failed\n"); return ret; @@ -1663,8 +1663,7 @@ static int sdram_init(struct dram_info *dram, if (params->base.dramtype == LPDDR3) training_flag |= PI_CA_TRAINING;
- if (!(data_training(&dram->chan[ch], ch, - params, training_flag))) + if (!(data_training(dram, ch, params, training_flag))) break; } /* Computed rank with associated channel number */
data training can be even required for lpddr4 and we need to keep the lpddr4 code to compile only for relevant boards which do support lpddr4.
For this requirement, and for code readability handle data training via sdram_rk3399_ops and same will update in future while supporting lpddr4 code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 43 ++++++++++++++++++++++------- 1 file changed, 33 insertions(+), 10 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 927c7cced3..e2b311193d 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -65,11 +65,17 @@ struct dram_info { struct rk3399_pmucru *pmucru; struct rk3399_pmusgrf_regs *pmusgrf; struct rk3399_ddr_cic_regs *cic; + const struct sdram_rk3399_ops *ops; #endif struct ram_info info; struct rk3399_pmugrf_regs *pmugrf; };
+struct sdram_rk3399_ops { + int (*data_training)(struct dram_info *dram, u32 channel, u8 rank, + struct rk3399_sdram_params *sdram); +}; + #if defined(CONFIG_TPL_BUILD) || \ (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD))
@@ -1465,6 +1471,23 @@ static void dram_all_config(struct dram_info *dram, clrsetbits_le32(&dram->cru->glb_rst_con, 0x3, 0x3); }
+static int default_data_training(struct dram_info *dram, u32 channel, u8 rank, + struct rk3399_sdram_params *params) +{ + u8 training_flag = PI_READ_GATE_TRAINING; + + /* + * LPDDR3 CA training msut be trigger before + * other training. + * DDR3 is not have CA training. + */ + + if (params->base.dramtype == LPDDR3) + training_flag |= PI_CA_TRAINING; + + return data_training(dram, channel, params, training_flag); +} + static int switch_to_phy_index1(struct dram_info *dram, const struct rk3399_sdram_params *params) { @@ -1627,7 +1650,6 @@ static int sdram_init(struct dram_info *dram, { unsigned char dramtype = params->base.dramtype; unsigned int ddr_freq = params->base.ddr_freq; - u32 training_flag = PI_READ_GATE_TRAINING; int channel, ch, rank; int ret;
@@ -1655,16 +1677,12 @@ static int sdram_init(struct dram_info *dram,
params->ch[ch].cap_info.rank = rank;
- /* - * LPDDR3 CA training msut be trigger before - * other training. - * DDR3 is not have CA training. - */ - if (params->base.dramtype == LPDDR3) - training_flag |= PI_CA_TRAINING; - - if (!(data_training(dram, ch, params, training_flag))) + ret = dram->ops->data_training(dram, ch, rank, params); + if (!ret) { + debug("%s: data trained for rank %d, ch %d\n", + __func__, rank, ch); break; + } } /* Computed rank with associated channel number */ params->ch[ch].cap_info.rank = rank; @@ -1744,6 +1762,10 @@ static int conv_of_platdata(struct udevice *dev) } #endif
+static const struct sdram_rk3399_ops rk3399_ops = { + .data_training = default_data_training, +}; + static int rk3399_dmc_init(struct udevice *dev) { struct dram_info *priv = dev_get_priv(dev); @@ -1761,6 +1783,7 @@ static int rk3399_dmc_init(struct udevice *dev) return ret; #endif
+ priv->ops = &rk3399_ops; priv->cic = syscon_get_first_range(ROCKCHIP_SYSCON_CIC); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF);
Like data training in other sdram types, mr detection need to taken care for lpddr4 with looped rank and associated channel to make sure the proper configuration held.
Once the mr detection successful for active and configured rank with channel number, the same can later reused during actual LPDDR4 initialization.
So, add code to support for it.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 226 ++++++++++++++++++++++++++++ 1 file changed, 226 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index e2b311193d..cdae6b9e67 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1471,6 +1471,7 @@ static void dram_all_config(struct dram_info *dram, clrsetbits_le32(&dram->cru->glb_rst_con, 0x3, 0x3); }
+#if !defined(CONFIG_RAM_RK3399_LPDDR4) static int default_data_training(struct dram_info *dram, u32 channel, u8 rank, struct rk3399_sdram_params *params) { @@ -1487,6 +1488,7 @@ static int default_data_training(struct dram_info *dram, u32 channel, u8 rank,
return data_training(dram, channel, params, training_flag); } +#endif
static int switch_to_phy_index1(struct dram_info *dram, const struct rk3399_sdram_params *params) @@ -1533,6 +1535,226 @@ static int switch_to_phy_index1(struct dram_info *dram, return 0; }
+#if defined(CONFIG_RAM_RK3399_LPDDR4) +static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) +{ + return ((readl(&pmusgrf->soc_con4) >> 10) & 0x1F); +} + +static void set_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf, u32 stride) +{ + rk_clrsetreg(&pmusgrf->soc_con4, 0x1f << 10, stride << 10); +} + +static void set_cap_relate_config(const struct chan_info *chan, + struct rk3399_sdram_params *params, + unsigned int channel) +{ + u32 *denali_ctl = chan->pctl->denali_ctl; + u32 tmp; + struct rk3399_msch_timings *noc_timing; + + if (params->base.dramtype == LPDDR3) { + tmp = (8 << params->ch[channel].cap_info.bw) / + (8 << params->ch[channel].cap_info.dbw); + + /** + * memdata_ratio + * 1 -> 0, 2 -> 1, 4 -> 2 + */ + clrsetbits_le32(&denali_ctl[197], 0x7, + (tmp >> 1)); + clrsetbits_le32(&denali_ctl[198], 0x7 << 8, + (tmp >> 1) << 8); + } + + noc_timing = ¶ms->ch[channel].noc_timings; + + /* + * noc timing bw relate timing is 32 bit, and real bw is 16bit + * actually noc reg is setting at function dram_all_config + */ + if (params->ch[channel].cap_info.bw == 16 && + noc_timing->ddrmode.b.mwrsize == 2) { + if (noc_timing->ddrmode.b.burstsize) + noc_timing->ddrmode.b.burstsize -= 1; + noc_timing->ddrmode.b.mwrsize -= 1; + noc_timing->ddrtimingc0.b.burstpenalty *= 2; + noc_timing->ddrtimingc0.b.wrtomwr *= 2; + } +} + +static u32 calculate_ddrconfig(struct rk3399_sdram_params *params, u32 channel) +{ + unsigned int cs0_row = params->ch[channel].cap_info.cs0_row; + unsigned int col = params->ch[channel].cap_info.col; + unsigned int bw = params->ch[channel].cap_info.bw; + u16 ddr_cfg_2_rbc[] = { + /* + * [6] highest bit col + * [5:3] max row(14+n) + * [2] insertion row + * [1:0] col(9+n),col, data bus 32bit + * + * highbitcol, max_row, insertion_row, col + */ + ((0 << 6) | (2 << 3) | (0 << 2) | 0), /* 0 */ + ((0 << 6) | (2 << 3) | (0 << 2) | 1), /* 1 */ + ((0 << 6) | (1 << 3) | (0 << 2) | 2), /* 2 */ + ((0 << 6) | (0 << 3) | (0 << 2) | 3), /* 3 */ + ((0 << 6) | (2 << 3) | (1 << 2) | 1), /* 4 */ + ((0 << 6) | (1 << 3) | (1 << 2) | 2), /* 5 */ + ((1 << 6) | (0 << 3) | (0 << 2) | 2), /* 6 */ + ((1 << 6) | (1 << 3) | (0 << 2) | 2), /* 7 */ + }; + u32 i; + + col -= (bw == 2) ? 0 : 1; + col -= 9; + + for (i = 0; i < 4; i++) { + if ((col == (ddr_cfg_2_rbc[i] & 0x3)) && + (cs0_row <= (((ddr_cfg_2_rbc[i] >> 3) & 0x7) + 14))) + break; + } + + if (i >= 4) + i = -EINVAL; + + return i; +} + +/** + * read mr_num mode register + * rank = 1: cs0 + * rank = 2: cs1 + */ +static int read_mr(struct rk3399_ddr_pctl_regs *ddr_pctl_regs, u32 rank, + u32 mr_num, u32 *buf) +{ + s32 timeout = 100; + + writel(((1 << 16) | (((rank == 2) ? 1 : 0) << 8) | mr_num) << 8, + &ddr_pctl_regs->denali_ctl[118]); + + while (0 == (readl(&ddr_pctl_regs->denali_ctl[203]) & + ((1 << 21) | (1 << 12)))) { + udelay(1); + + if (timeout <= 0) { + printf("%s: pctl timeout!\n", __func__); + return -ETIMEDOUT; + } + + timeout--; + } + + if (!(readl(&ddr_pctl_regs->denali_ctl[203]) & (1 << 12))) { + *buf = readl(&ddr_pctl_regs->denali_ctl[119]) & 0xFF; + } else { + printf("%s: read mr failed with 0x%x status\n", __func__, + readl(&ddr_pctl_regs->denali_ctl[17]) & 0x3); + *buf = 0; + } + + setbits_le32(&ddr_pctl_regs->denali_ctl[205], (1 << 21) | (1 << 12)); + + return 0; +} + +static int lpddr4_mr_detect(struct dram_info *dram, u32 channel, u8 rank, + struct rk3399_sdram_params *params) +{ + u64 cs0_cap; + u32 stride; + u32 cs = 0, col = 0, bk = 0, bw = 0, row_3_4 = 0; + u32 cs0_row = 0, cs1_row = 0, ddrconfig = 0; + u32 mr5, mr12, mr14; + struct chan_info *chan = &dram->chan[channel]; + struct rk3399_ddr_pctl_regs *ddr_pctl_regs = chan->pctl; + void __iomem *addr = NULL; + int ret = 0; + u32 val; + + stride = get_ddr_stride(dram->pmusgrf); + + if (params->ch[channel].cap_info.col == 0) { + ret = -EPERM; + goto end; + } + + cs = params->ch[channel].cap_info.rank; + col = params->ch[channel].cap_info.col; + bk = params->ch[channel].cap_info.bk; + bw = params->ch[channel].cap_info.bw; + row_3_4 = params->ch[channel].cap_info.row_3_4; + cs0_row = params->ch[channel].cap_info.cs0_row; + cs1_row = params->ch[channel].cap_info.cs1_row; + ddrconfig = params->ch[channel].cap_info.ddrconfig; + + /* 2GB */ + params->ch[channel].cap_info.rank = 2; + params->ch[channel].cap_info.col = 10; + params->ch[channel].cap_info.bk = 3; + params->ch[channel].cap_info.bw = 2; + params->ch[channel].cap_info.row_3_4 = 0; + params->ch[channel].cap_info.cs0_row = 15; + params->ch[channel].cap_info.cs1_row = 15; + params->ch[channel].cap_info.ddrconfig = 1; + + set_memory_map(chan, channel, params); + params->ch[channel].cap_info.ddrconfig = + calculate_ddrconfig(params, channel); + set_ddrconfig(chan, params, channel, + params->ch[channel].cap_info.ddrconfig); + set_cap_relate_config(chan, params, channel); + + cs0_cap = (1 << (params->ch[channel].cap_info.bw + + params->ch[channel].cap_info.col + + params->ch[channel].cap_info.bk + + params->ch[channel].cap_info.cs0_row)); + + if (params->ch[channel].cap_info.row_3_4) + cs0_cap = cs0_cap * 3 / 4; + + if (channel == 0) + set_ddr_stride(dram->pmusgrf, 0x17); + else + set_ddr_stride(dram->pmusgrf, 0x18); + + /* read and write data to DRAM, avoid be optimized by compiler. */ + if (rank == 1) + addr = (void __iomem *)0x100; + else if (rank == 2) + addr = (void __iomem *)(cs0_cap + 0x100); + + val = readl(addr); + writel(val + 1, addr); + + read_mr(ddr_pctl_regs, rank, 5, &mr5); + read_mr(ddr_pctl_regs, rank, 12, &mr12); + read_mr(ddr_pctl_regs, rank, 14, &mr14); + + if (mr5 == 0 || mr12 != 0x4d || mr14 != 0x4d) { + ret = -EINVAL; + goto end; + } +end: + params->ch[channel].cap_info.rank = cs; + params->ch[channel].cap_info.col = col; + params->ch[channel].cap_info.bk = bk; + params->ch[channel].cap_info.bw = bw; + params->ch[channel].cap_info.row_3_4 = row_3_4; + params->ch[channel].cap_info.cs0_row = cs0_row; + params->ch[channel].cap_info.cs1_row = cs1_row; + params->ch[channel].cap_info.ddrconfig = ddrconfig; + + set_ddr_stride(dram->pmusgrf, stride); + + return ret; +} +#endif /* CONFIG_RAM_RK3399_LPDDR4 */ + static unsigned char calculate_stride(struct rk3399_sdram_params *params) { unsigned int stride = params->base.stride; @@ -1763,7 +1985,11 @@ static int conv_of_platdata(struct udevice *dev) #endif
static const struct sdram_rk3399_ops rk3399_ops = { +#if !defined(CONFIG_RAM_RK3399_LPDDR4) .data_training = default_data_training, +#else + .data_training = lpddr4_mr_detect, +#endif };
Add pmu header file for rk3399 SoC, this will help to configure pmu in sdram driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../include/asm/arch-rockchip/pmu_rk3399.h | 72 +++++++++++++++++++ 1 file changed, 72 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3399.h
diff --git a/arch/arm/include/asm/arch-rockchip/pmu_rk3399.h b/arch/arm/include/asm/arch-rockchip/pmu_rk3399.h new file mode 100644 index 0000000000..f1096dccce --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/pmu_rk3399.h @@ -0,0 +1,72 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2018 Rockchip Electronics Co., Ltd. + * + */ + +#ifndef __SOC_ROCKCHIP_RK3399_PMU_H__ +#define __SOC_ROCKCHIP_RK3399_PMU_H__ + +struct rk3399_pmu_regs { + u32 pmu_wakeup_cfg[5]; + u32 pmu_pwrdn_con; + u32 pmu_pwrdn_st; + u32 pmu_pll_con; + u32 pmu_pwrmode_con; + u32 pmu_sft_con; + u32 pmu_int_con; + u32 pmu_int_st; + u32 pmu_gpio0_pos_int_con; + u32 pmu_gpio0_net_int_con; + u32 pmu_gpio1_pos_int_con; + u32 pmu_gpio1_net_int_con; + u32 pmu_gpio0_pos_int_st; + u32 pmu_gpio0_net_int_st; + u32 pmu_gpio1_pos_int_st; + u32 pmu_gpio1_net_int_st; + u32 pmu_pwrdn_inten; + u32 pmu_pwrdn_status; + u32 pmu_wakeup_status; + u32 pmu_bus_clr; + u32 pmu_bus_idle_req; + u32 pmu_bus_idle_st; + u32 pmu_bus_idle_ack; + u32 pmu_cci500_con; + u32 pmu_adb400_con; + u32 pmu_adb400_st; + u32 pmu_power_st; + u32 pmu_core_pwr_st; + u32 pmu_osc_cnt; + u32 pmu_plllock_cnt; + u32 pmu_pllrst_cnt; + u32 pmu_stable_cnt; + u32 pmu_ddrio_pwron_cnt; + u32 pmu_wakeup_rst_clr_cnt; + u32 pmu_ddr_sref_st; + u32 pmu_scu_l_pwrdn_cnt; + u32 pmu_scu_l_pwrup_cnt; + u32 pmu_scu_b_pwrdn_cnt; + u32 pmu_scu_b_pwrup_cnt; + u32 pmu_gpu_pwrdn_cnt; + u32 pmu_gpu_pwrup_cnt; + u32 pmu_center_pwrdn_cnt; + u32 pmu_center_pwrup_cnt; + u32 pmu_timeout_cnt; + u32 pmu_cpu0apm_con; + u32 pmu_cpu1apm_con; + u32 pmu_cpu2apm_con; + u32 pmu_cpu3apm_con; + u32 pmu_cpu0bpm_con; + u32 pmu_cpu1bpm_con; + u32 pmu_noc_auto_ena; + u32 pmu_pwrdn_con1; + u32 reserved0[0x4]; + u32 pmu_sys_reg_reg0; + u32 pmu_sys_reg_reg1; + u32 pmu_sys_reg_reg2; + u32 pmu_sys_reg_reg3; +}; + +check_member(rk3399_pmu_regs, pmu_sys_reg_reg3, 0xfc); + +#endif /* __SOC_ROCKCHIP_RK3399_PMU_H__ */
Add pmu compatible with relevant U_BOOT_DRIVER for rk3399 via syscon rk3399 driver.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c index a8bb5b11e5..259ca44d68 100644 --- a/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/syscon_rk3399.c @@ -13,6 +13,7 @@ static const struct udevice_id rk3399_syscon_ids[] = { { .compatible = "rockchip,rk3399-pmugrf", .data = ROCKCHIP_SYSCON_PMUGRF }, { .compatible = "rockchip,rk3399-pmusgrf", .data = ROCKCHIP_SYSCON_PMUSGRF }, { .compatible = "rockchip,rk3399-cic", .data = ROCKCHIP_SYSCON_CIC }, + { .compatible = "rockchip,rk3399-pmu", .data = ROCKCHIP_SYSCON_PMU }, { } };
@@ -58,4 +59,11 @@ U_BOOT_DRIVER(rockchip_rk3399_cic) = { .of_match = rk3399_syscon_ids + 3, .bind = rk3399_syscon_bind_of_platdata, }; + +U_BOOT_DRIVER(rockchip_rk3399_pmu) = { + .name = "rockchip_rk3399_pmu", + .id = UCLASS_SYSCON, + .of_match = rk3399_syscon_ids + 4, + .bind = rk3399_syscon_bind_of_platdata, +}; #endif
Add u-boot,dm-pre-reloc property for pmu in rk3399-u-boot.dtsi so-that SPL can access pmu.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/dts/rk3399-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/rk3399-u-boot.dtsi b/arch/arm/dts/rk3399-u-boot.dtsi index 0786c1193a..31942899f6 100644 --- a/arch/arm/dts/rk3399-u-boot.dtsi +++ b/arch/arm/dts/rk3399-u-boot.dtsi @@ -3,6 +3,10 @@ * Copyright (C) 2019 Jagan Teki jagan@amarulasolutions.com */
+&pmu { + u-boot,dm-pre-reloc; +}; + &sdmmc { u-boot,dm-pre-reloc; };
LPDDR4 initialization start with at board selected frequency and then it switches into 400MHz and 800MHz simultaneously to make the proper sequence work on each channel with associated training.
So, add LPDDR4-400 timings inc file in driver area so-that these timings will take during LPDDR4 initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../ram/rockchip/sdram-rk3399-lpddr4-400.inc | 1570 +++++++++++++++++ 1 file changed, 1570 insertions(+) create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc
diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc new file mode 100644 index 0000000000..c50a03d9dd --- /dev/null +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc @@ -0,0 +1,1570 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd. + * (C) Copyright 2019 Amarula Solutions + */ + +{ + { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + }, + { + .ddrtiminga0 = 0x80241d22, + .ddrtimingb0 = 0x15050f08, + .ddrtimingc0 = { + 0x00000602, + }, + .devtodev0 = 0x00002122, + .ddrmode = { + 0x0000004c, + }, + .agingx0 = 0x00000000, + } + }, + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + }, + { + .ddrtiminga0 = 0x80241d22, + .ddrtimingb0 = 0x15050f08, + .ddrtimingc0 = { + 0x00000602, + }, + .devtodev0 = 0x00002122, + .ddrmode = { + 0x0000004c, + }, + .agingx0 = 0x00000000, + } + } + }, + { + .ddr_freq = 400 * MHz, + .dramtype = LPDDR4, + .num_channels = 2, + .stride = 13, + .odt = 1, + }, + { + { + 0x00000b00, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00013880, /* DENALI_CTL_05_DATA */ + 0x000c3500, /* DENALI_CTL_06_DATA */ + 0x00000005, /* DENALI_CTL_07_DATA */ + 0x00000320, /* DENALI_CTL_08_DATA */ + 0x00027100, /* DENALI_CTL_09_DATA */ + 0x00186a00, /* DENALI_CTL_10_DATA */ + 0x00000005, /* DENALI_CTL_11_DATA */ + 0x00000640, /* DENALI_CTL_12_DATA */ + 0x00002710, /* DENALI_CTL_13_DATA */ + 0x000186a0, /* DENALI_CTL_14_DATA */ + 0x00000005, /* DENALI_CTL_15_DATA */ + 0x01000064, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x02020101, /* DENALI_CTL_18_DATA */ + 0x00000102, /* DENALI_CTL_19_DATA */ + 0x00000050, /* DENALI_CTL_20_DATA */ + 0x000000c8, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06140000, /* DENALI_CTL_23_DATA */ + 0x00081c00, /* DENALI_CTL_24_DATA */ + 0x0400040c, /* DENALI_CTL_25_DATA */ + 0x19042008, /* DENALI_CTL_26_DATA */ + 0x10080a11, /* DENALI_CTL_27_DATA */ + 0x22310800, /* DENALI_CTL_28_DATA */ + 0x00200f0a, /* DENALI_CTL_29_DATA */ + 0x0a030704, /* DENALI_CTL_30_DATA */ + 0x08000204, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x04006db0, /* DENALI_CTL_33_DATA */ + 0x0a0a0804, /* DENALI_CTL_34_DATA */ + 0x0600db60, /* DENALI_CTL_35_DATA */ + 0x0a0a0806, /* DENALI_CTL_36_DATA */ + 0x04000db6, /* DENALI_CTL_37_DATA */ + 0x02030404, /* DENALI_CTL_38_DATA */ + 0x0f0a0800, /* DENALI_CTL_39_DATA */ + 0x08040411, /* DENALI_CTL_40_DATA */ + 0x1400640a, /* DENALI_CTL_41_DATA */ + 0x02010a0a, /* DENALI_CTL_42_DATA */ + 0x00010001, /* DENALI_CTL_43_DATA */ + 0x04082012, /* DENALI_CTL_44_DATA */ + 0x00041109, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x06100034, /* DENALI_CTL_48_DATA */ + 0x0c280068, /* DENALI_CTL_49_DATA */ + 0x00bb0007, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00060003, /* DENALI_CTL_52_DATA */ + 0x000a0003, /* DENALI_CTL_53_DATA */ + 0x000a0014, /* DENALI_CTL_54_DATA */ + 0x01000000, /* DENALI_CTL_55_DATA */ + 0x030a0000, /* DENALI_CTL_56_DATA */ + 0x0c000002, /* DENALI_CTL_57_DATA */ + 0x00000103, /* DENALI_CTL_58_DATA */ + 0x0003030a, /* DENALI_CTL_59_DATA */ + 0x00060037, /* DENALI_CTL_60_DATA */ + 0x0003006e, /* DENALI_CTL_61_DATA */ + 0x05050007, /* DENALI_CTL_62_DATA */ + 0x03020605, /* DENALI_CTL_63_DATA */ + 0x06050301, /* DENALI_CTL_64_DATA */ + 0x06020c05, /* DENALI_CTL_65_DATA */ + 0x05050302, /* DENALI_CTL_66_DATA */ + 0x03020305, /* DENALI_CTL_67_DATA */ + 0x00000301, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x18400000, /* DENALI_CTL_82_DATA */ + 0x00000c20, /* DENALI_CTL_83_DATA */ + 0x185030a0, /* DENALI_CTL_84_DATA */ + 0x02ec0000, /* DENALI_CTL_85_DATA */ + 0x00000176, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x06030300, /* DENALI_CTL_92_DATA */ + 0x00030303, /* DENALI_CTL_93_DATA */ + 0x02030200, /* DENALI_CTL_94_DATA */ + 0x00040703, /* DENALI_CTL_95_DATA */ + 0x03020302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x07030203, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00500000, /* DENALI_CTL_122_DATA */ + 0x00640028, /* DENALI_CTL_123_DATA */ + 0x00640404, /* DENALI_CTL_124_DATA */ + 0x005000a0, /* DENALI_CTL_125_DATA */ + 0x060600c8, /* DENALI_CTL_126_DATA */ + 0x000a00c8, /* DENALI_CTL_127_DATA */ + 0x000d0005, /* DENALI_CTL_128_DATA */ + 0x000d0404, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x001400a3, /* DENALI_CTL_133_DATA */ + 0x00e30009, /* DENALI_CTL_134_DATA */ + 0x00120024, /* DENALI_CTL_135_DATA */ + 0x00040063, /* DENALI_CTL_136_DATA */ + 0x00000000, /* DENALI_CTL_137_DATA */ + 0x00310031, /* DENALI_CTL_138_DATA */ + 0x00000031, /* DENALI_CTL_139_DATA */ + 0x004d0000, /* DENALI_CTL_140_DATA */ + 0x004d004d, /* DENALI_CTL_141_DATA */ + 0x004d0000, /* DENALI_CTL_142_DATA */ + 0x004d004d, /* DENALI_CTL_143_DATA */ + 0x00010101, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x001400a3, /* DENALI_CTL_147_DATA */ + 0x00e30009, /* DENALI_CTL_148_DATA */ + 0x00120024, /* DENALI_CTL_149_DATA */ + 0x00040063, /* DENALI_CTL_150_DATA */ + 0x00000000, /* DENALI_CTL_151_DATA */ + 0x00310031, /* DENALI_CTL_152_DATA */ + 0x00000031, /* DENALI_CTL_153_DATA */ + 0x004d0000, /* DENALI_CTL_154_DATA */ + 0x004d004d, /* DENALI_CTL_155_DATA */ + 0x004d0000, /* DENALI_CTL_156_DATA */ + 0x004d004d, /* DENALI_CTL_157_DATA */ + 0x00010101, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x00000000, /* DENALI_CTL_161_DATA */ + 0x00000001, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00020003, /* DENALI_CTL_179_DATA */ + 0x00400100, /* DENALI_CTL_180_DATA */ + 0x000c0190, /* DENALI_CTL_181_DATA */ + 0x01000200, /* DENALI_CTL_182_DATA */ + 0x03200040, /* DENALI_CTL_183_DATA */ + 0x00020018, /* DENALI_CTL_184_DATA */ + 0x00400100, /* DENALI_CTL_185_DATA */ + 0x00080032, /* DENALI_CTL_186_DATA */ + 0x00140000, /* DENALI_CTL_187_DATA */ + 0x00030028, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x02000202, /* DENALI_CTL_190_DATA */ + 0x0b000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00040101, /* DENALI_CTL_197_DATA */ + 0x04010100, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x02010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x00000001, /* DENALI_CTL_212_DATA */ + 0x01010001, /* DENALI_CTL_213_DATA */ + 0x05040001, /* DENALI_CTL_214_DATA */ + 0x040a0703, /* DENALI_CTL_215_DATA */ + 0x02080808, /* DENALI_CTL_216_DATA */ + 0x020e000a, /* DENALI_CTL_217_DATA */ + 0x020f010b, /* DENALI_CTL_218_DATA */ + 0x000d0008, /* DENALI_CTL_219_DATA */ + 0x00080b0a, /* DENALI_CTL_220_DATA */ + 0x03000200, /* DENALI_CTL_221_DATA */ + 0x00000100, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00000028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x1a160000, /* DENALI_CTL_275_DATA */ + 0x08000012, /* DENALI_CTL_276_DATA */ + 0x00000c20, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00000c20, /* DENALI_CTL_282_DATA */ + 0x00007940, /* DENALI_CTL_283_DATA */ + 0x18500409, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00001850, /* DENALI_CTL_289_DATA */ + 0x0000f320, /* DENALI_CTL_290_DATA */ + 0x0176060c, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00000176, /* DENALI_CTL_296_DATA */ + 0x00000e9c, /* DENALI_CTL_297_DATA */ + 0x02020205, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000a001c, /* DENALI_CTL_308_DATA */ + 0x000e0020, /* DENALI_CTL_309_DATA */ + 0x00060018, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x02000000, /* DENALI_CTL_313_DATA */ + 0x00090305, /* DENALI_CTL_314_DATA */ + 0x00050101, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000001, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000b00, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x000002ec, /* DENALI_PI_02_DATA */ + 0x00000176, /* DENALI_PI_03_DATA */ + 0x000030a0, /* DENALI_PI_04_DATA */ + 0x00001850, /* DENALI_PI_05_DATA */ + 0x00001840, /* DENALI_PI_06_DATA */ + 0x01760c20, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00001850, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00000c20, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x01000001, /* DENALI_PI_24_DATA */ + 0x00000000, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x00000000, /* DENALI_PI_27_DATA */ + 0x00000000, /* DENALI_PI_28_DATA */ + 0x00000000, /* DENALI_PI_29_DATA */ + 0x00000000, /* DENALI_PI_30_DATA */ + 0x00000000, /* DENALI_PI_31_DATA */ + 0x00000000, /* DENALI_PI_32_DATA */ + 0x00000000, /* DENALI_PI_33_DATA */ + 0x00000000, /* DENALI_PI_34_DATA */ + 0x00000000, /* DENALI_PI_35_DATA */ + 0x00000000, /* DENALI_PI_36_DATA */ + 0x00000000, /* DENALI_PI_37_DATA */ + 0x00000000, /* DENALI_PI_38_DATA */ + 0x00000000, /* DENALI_PI_39_DATA */ + 0x00000000, /* DENALI_PI_40_DATA */ + 0x0f000101, /* DENALI_PI_41_DATA */ + 0x082b3223, /* DENALI_PI_42_DATA */ + 0x080c0004, /* DENALI_PI_43_DATA */ + 0x00061c00, /* DENALI_PI_44_DATA */ + 0x00000214, /* DENALI_PI_45_DATA */ + 0x00bb0007, /* DENALI_PI_46_DATA */ + 0x0c280068, /* DENALI_PI_47_DATA */ + 0x06100034, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040100, /* DENALI_PI_58_DATA */ + 0x0a000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x0003000f, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x00060002, /* DENALI_PI_66_DATA */ + 0x00010001, /* DENALI_PI_67_DATA */ + 0x00000101, /* DENALI_PI_68_DATA */ + 0x00020001, /* DENALI_PI_69_DATA */ + 0x00080004, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x05030000, /* DENALI_PI_72_DATA */ + 0x070a0404, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x000f0f00, /* DENALI_PI_77_DATA */ + 0x0000001e, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x0c050001, /* DENALI_PI_89_DATA */ + 0x06020009, /* DENALI_PI_90_DATA */ + 0x00010004, /* DENALI_PI_91_DATA */ + 0x00000203, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x170f0000, /* DENALI_PI_94_DATA */ + 0x00060018, /* DENALI_PI_95_DATA */ + 0x000e0020, /* DENALI_PI_96_DATA */ + 0x000a001c, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000d010a, /* DENALI_PI_102_DATA */ + 0x0100c802, /* DENALI_PI_103_DATA */ + 0x010a0064, /* DENALI_PI_104_DATA */ + 0x000e0100, /* DENALI_PI_105_DATA */ + 0x0100000e, /* DENALI_PI_106_DATA */ + 0x00c900c9, /* DENALI_PI_107_DATA */ + 0x00650100, /* DENALI_PI_108_DATA */ + 0x1e1a0065, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x06070605, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x10020100, /* DENALI_PI_116_DATA */ + 0x0003010c, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a0f0000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00010000, /* DENALI_PI_124_DATA */ + 0x00000400, /* DENALI_PI_125_DATA */ + 0x00310000, /* DENALI_PI_126_DATA */ + 0x004d4d00, /* DENALI_PI_127_DATA */ + 0x00120024, /* DENALI_PI_128_DATA */ + 0x4d000031, /* DENALI_PI_129_DATA */ + 0x0000144d, /* DENALI_PI_130_DATA */ + 0x00310009, /* DENALI_PI_131_DATA */ + 0x004d4d00, /* DENALI_PI_132_DATA */ + 0x00000004, /* DENALI_PI_133_DATA */ + 0x4d000031, /* DENALI_PI_134_DATA */ + 0x0000244d, /* DENALI_PI_135_DATA */ + 0x00310012, /* DENALI_PI_136_DATA */ + 0x004d4d00, /* DENALI_PI_137_DATA */ + 0x00090014, /* DENALI_PI_138_DATA */ + 0x4d000031, /* DENALI_PI_139_DATA */ + 0x0004004d, /* DENALI_PI_140_DATA */ + 0x00310000, /* DENALI_PI_141_DATA */ + 0x004d4d00, /* DENALI_PI_142_DATA */ + 0x00120024, /* DENALI_PI_143_DATA */ + 0x4d000031, /* DENALI_PI_144_DATA */ + 0x0000144d, /* DENALI_PI_145_DATA */ + 0x00310009, /* DENALI_PI_146_DATA */ + 0x004d4d00, /* DENALI_PI_147_DATA */ + 0x00000004, /* DENALI_PI_148_DATA */ + 0x4d000031, /* DENALI_PI_149_DATA */ + 0x0000244d, /* DENALI_PI_150_DATA */ + 0x00310012, /* DENALI_PI_151_DATA */ + 0x004d4d00, /* DENALI_PI_152_DATA */ + 0x00090014, /* DENALI_PI_153_DATA */ + 0x4d000031, /* DENALI_PI_154_DATA */ + 0x0200004d, /* DENALI_PI_155_DATA */ + 0x00c8000d, /* DENALI_PI_156_DATA */ + 0x08080064, /* DENALI_PI_157_DATA */ + 0x040a0404, /* DENALI_PI_158_DATA */ + 0x03000d92, /* DENALI_PI_159_DATA */ + 0x010a2001, /* DENALI_PI_160_DATA */ + 0x0f11080a, /* DENALI_PI_161_DATA */ + 0x0000110a, /* DENALI_PI_162_DATA */ + 0x2200d92e, /* DENALI_PI_163_DATA */ + 0x080c2003, /* DENALI_PI_164_DATA */ + 0x0809080a, /* DENALI_PI_165_DATA */ + 0x00000a0a, /* DENALI_PI_166_DATA */ + 0x11006c97, /* DENALI_PI_167_DATA */ + 0x040a2002, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000400, /* DENALI_PI_186_DATA */ + 0x00017600, /* DENALI_PI_187_DATA */ + 0x00000e9c, /* DENALI_PI_188_DATA */ + 0x00001850, /* DENALI_PI_189_DATA */ + 0x0000f320, /* DENALI_PI_190_DATA */ + 0x00000c20, /* DENALI_PI_191_DATA */ + 0x00007940, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004f008, /* DENALI_PHY_01_DATA */ + 0x00020119, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x03665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x04000100, /* DENALI_PHY_09_DATA */ + 0x00000001, /* DENALI_PHY_10_DATA */ + 0x00170180, /* DENALI_PHY_11_DATA */ + 0x00cc0201, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x30000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000000, /* DENALI_PHY_27_DATA */ + 0xfd02fe01, /* DENALI_PHY_28_DATA */ + 0xf708fb04, /* DENALI_PHY_29_DATA */ + 0xdf20ef10, /* DENALI_PHY_30_DATA */ + 0x7f80bf40, /* DENALI_PHY_31_DATA */ + 0x0001aaaa, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x01190080, /* DENALI_PHY_77_DATA */ + 0x00000001, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00000000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0003150, /* DENALI_PHY_84_DATA */ + 0x010000c0, /* DENALI_PHY_85_DATA */ + 0x00100000, /* DENALI_PHY_86_DATA */ + 0x07044204, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c10, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004f008, /* DENALI_PHY_129_DATA */ + 0x00020119, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x03665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x04000100, /* DENALI_PHY_137_DATA */ + 0x00000001, /* DENALI_PHY_138_DATA */ + 0x00170180, /* DENALI_PHY_139_DATA */ + 0x00cc0201, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x30000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000000, /* DENALI_PHY_155_DATA */ + 0xfd02fe01, /* DENALI_PHY_156_DATA */ + 0xf708fb04, /* DENALI_PHY_157_DATA */ + 0xdf20ef10, /* DENALI_PHY_158_DATA */ + 0x7f80bf40, /* DENALI_PHY_159_DATA */ + 0x0000aaaa, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x01190080, /* DENALI_PHY_205_DATA */ + 0x00000001, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00000000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0003150, /* DENALI_PHY_212_DATA */ + 0x010000c0, /* DENALI_PHY_213_DATA */ + 0x00100000, /* DENALI_PHY_214_DATA */ + 0x07044204, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c10, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004f008, /* DENALI_PHY_257_DATA */ + 0x00020119, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x03665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x04000100, /* DENALI_PHY_265_DATA */ + 0x00000001, /* DENALI_PHY_266_DATA */ + 0x00170180, /* DENALI_PHY_267_DATA */ + 0x00cc0201, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x30000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000000, /* DENALI_PHY_283_DATA */ + 0xfd02fe01, /* DENALI_PHY_284_DATA */ + 0xf708fb04, /* DENALI_PHY_285_DATA */ + 0xdf20ef10, /* DENALI_PHY_286_DATA */ + 0x7f80bf40, /* DENALI_PHY_287_DATA */ + 0x0001aaaa, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x01190080, /* DENALI_PHY_333_DATA */ + 0x00000001, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00000000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0003150, /* DENALI_PHY_340_DATA */ + 0x010000c0, /* DENALI_PHY_341_DATA */ + 0x00100000, /* DENALI_PHY_342_DATA */ + 0x07044204, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c10, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004f008, /* DENALI_PHY_385_DATA */ + 0x00020119, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x03665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x04000100, /* DENALI_PHY_393_DATA */ + 0x00000001, /* DENALI_PHY_394_DATA */ + 0x00170180, /* DENALI_PHY_395_DATA */ + 0x00cc0201, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x30000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000000, /* DENALI_PHY_411_DATA */ + 0xfd02fe01, /* DENALI_PHY_412_DATA */ + 0xf708fb04, /* DENALI_PHY_413_DATA */ + 0xdf20ef10, /* DENALI_PHY_414_DATA */ + 0x7f80bf40, /* DENALI_PHY_415_DATA */ + 0x0000aaaa, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x01190080, /* DENALI_PHY_461_DATA */ + 0x00000001, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00000000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0003150, /* DENALI_PHY_468_DATA */ + 0x010000c0, /* DENALI_PHY_469_DATA */ + 0x00100000, /* DENALI_PHY_470_DATA */ + 0x07044204, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c10, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00000000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000002, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00dcba98, /* DENALI_PHY_525_DATA */ + 0x00000000, /* DENALI_PHY_526_DATA */ + 0x00dcba98, /* DENALI_PHY_527_DATA */ + 0x01000000, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x0000002a, /* DENALI_PHY_533_DATA */ + 0x00000015, /* DENALI_PHY_534_DATA */ + 0x00000015, /* DENALI_PHY_535_DATA */ + 0x0000002a, /* DENALI_PHY_536_DATA */ + 0x00000033, /* DENALI_PHY_537_DATA */ + 0x0000000c, /* DENALI_PHY_538_DATA */ + 0x0000000c, /* DENALI_PHY_539_DATA */ + 0x00000033, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x003f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00030055, /* DENALI_PHY_544_DATA */ + 0x03000300, /* DENALI_PHY_545_DATA */ + 0x03000300, /* DENALI_PHY_546_DATA */ + 0x00000300, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00000000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000002, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00000000, /* DENALI_PHY_653_DATA */ + 0x00000000, /* DENALI_PHY_654_DATA */ + 0x00000000, /* DENALI_PHY_655_DATA */ + 0x01000000, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x0000002a, /* DENALI_PHY_661_DATA */ + 0x00000015, /* DENALI_PHY_662_DATA */ + 0x00000015, /* DENALI_PHY_663_DATA */ + 0x0000002a, /* DENALI_PHY_664_DATA */ + 0x00000033, /* DENALI_PHY_665_DATA */ + 0x0000000c, /* DENALI_PHY_666_DATA */ + 0x0000000c, /* DENALI_PHY_667_DATA */ + 0x00000033, /* DENALI_PHY_668_DATA */ + 0x00000000, /* DENALI_PHY_669_DATA */ + 0x00000000, /* DENALI_PHY_670_DATA */ + 0x00000000, /* DENALI_PHY_671_DATA */ + 0x00030055, /* DENALI_PHY_672_DATA */ + 0x03000300, /* DENALI_PHY_673_DATA */ + 0x03000300, /* DENALI_PHY_674_DATA */ + 0x00000300, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00000000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000002, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00000000, /* DENALI_PHY_781_DATA */ + 0x00000000, /* DENALI_PHY_782_DATA */ + 0x00000000, /* DENALI_PHY_783_DATA */ + 0x01000000, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x0000002a, /* DENALI_PHY_789_DATA */ + 0x00000015, /* DENALI_PHY_790_DATA */ + 0x00000015, /* DENALI_PHY_791_DATA */ + 0x0000002a, /* DENALI_PHY_792_DATA */ + 0x00000033, /* DENALI_PHY_793_DATA */ + 0x0000000c, /* DENALI_PHY_794_DATA */ + 0x0000000c, /* DENALI_PHY_795_DATA */ + 0x00000033, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00030055, /* DENALI_PHY_800_DATA */ + 0x03000300, /* DENALI_PHY_801_DATA */ + 0x03000300, /* DENALI_PHY_802_DATA */ + 0x00000300, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000000, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x00000005, /* DENALI_PHY_898_DATA */ + 0x04000f01, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x01010100, /* DENALI_PHY_907_DATA */ + 0x00000600, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x03221302, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x000d1f01, /* DENALI_PHY_913_DATA */ + 0x0d1f0d1f, /* DENALI_PHY_914_DATA */ + 0x0d1f0d1f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x03221302, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x01020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000411, /* DENALI_PHY_924_DATA */ + 0x00000411, /* DENALI_PHY_925_DATA */ + 0x00000040, /* DENALI_PHY_926_DATA */ + 0x00000040, /* DENALI_PHY_927_DATA */ + 0x00000411, /* DENALI_PHY_928_DATA */ + 0x00000411, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000411, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000411, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000411, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x64000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000408, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +},
LPDDR4 initialization start with at board selected frequency and then it switches into 400MHz and 800MHz simultaneously to make the proper sequence work on each channel with associated training.
So, add LPDDR4-800 timings inc file in driver area so-that these timings will take during LPDDR4 initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- .../ram/rockchip/sdram-rk3399-lpddr4-800.inc | 1570 +++++++++++++++++ 1 file changed, 1570 insertions(+) create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc
diff --git a/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc new file mode 100644 index 0000000000..d8ae3359a3 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc @@ -0,0 +1,1570 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd. + * (C) Copyright 2019 Amarula Solutions + */ + +{ + { + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + }, + { + .ddrtiminga0 = 0x80241d22, + .ddrtimingb0 = 0x15050f08, + .ddrtimingc0 = { + 0x00000602, + }, + .devtodev0 = 0x00002122, + .ddrmode = { + 0x0000004c, + }, + .agingx0 = 0x00000000, + } + }, + { + { + .rank = 0x2, + .col = 0xA, + .bk = 0x3, + .bw = 0x2, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0xF, + .cs1_row = 0xF, + .ddrconfig = 1, + }, + { + .ddrtiminga0 = 0x80241d22, + .ddrtimingb0 = 0x15050f08, + .ddrtimingc0 = { + 0x00000602, + }, + .devtodev0 = 0x00002122, + .ddrmode = { + 0x0000004c, + }, + .agingx0 = 0x00000000, + } + } + }, + { + .ddr_freq = 800 * MHz, + .dramtype = LPDDR4, + .num_channels = 2, + .stride = 13, + .odt = 1, + }, + { + { + 0x00000b00, /* DENALI_CTL_00_DATA */ + 0x00000000, /* DENALI_CTL_01_DATA */ + 0x00000000, /* DENALI_CTL_02_DATA */ + 0x00000000, /* DENALI_CTL_03_DATA */ + 0x00000000, /* DENALI_CTL_04_DATA */ + 0x00013880, /* DENALI_CTL_05_DATA */ + 0x000c3500, /* DENALI_CTL_06_DATA */ + 0x00000005, /* DENALI_CTL_07_DATA */ + 0x00000320, /* DENALI_CTL_08_DATA */ + 0x00027100, /* DENALI_CTL_09_DATA */ + 0x00186a00, /* DENALI_CTL_10_DATA */ + 0x00000005, /* DENALI_CTL_11_DATA */ + 0x00000640, /* DENALI_CTL_12_DATA */ + 0x00002710, /* DENALI_CTL_13_DATA */ + 0x000186a0, /* DENALI_CTL_14_DATA */ + 0x00000005, /* DENALI_CTL_15_DATA */ + 0x01000064, /* DENALI_CTL_16_DATA */ + 0x00000000, /* DENALI_CTL_17_DATA */ + 0x02020101, /* DENALI_CTL_18_DATA */ + 0x00000102, /* DENALI_CTL_19_DATA */ + 0x00000050, /* DENALI_CTL_20_DATA */ + 0x000000c8, /* DENALI_CTL_21_DATA */ + 0x00000000, /* DENALI_CTL_22_DATA */ + 0x06140000, /* DENALI_CTL_23_DATA */ + 0x00081c00, /* DENALI_CTL_24_DATA */ + 0x0400040c, /* DENALI_CTL_25_DATA */ + 0x19042008, /* DENALI_CTL_26_DATA */ + 0x10080a11, /* DENALI_CTL_27_DATA */ + 0x22310800, /* DENALI_CTL_28_DATA */ + 0x00200f0a, /* DENALI_CTL_29_DATA */ + 0x0a030704, /* DENALI_CTL_30_DATA */ + 0x08000204, /* DENALI_CTL_31_DATA */ + 0x00000a0a, /* DENALI_CTL_32_DATA */ + 0x04006db0, /* DENALI_CTL_33_DATA */ + 0x0a0a0804, /* DENALI_CTL_34_DATA */ + 0x0600db60, /* DENALI_CTL_35_DATA */ + 0x0a0a0806, /* DENALI_CTL_36_DATA */ + 0x04000db6, /* DENALI_CTL_37_DATA */ + 0x02030404, /* DENALI_CTL_38_DATA */ + 0x0f0a0800, /* DENALI_CTL_39_DATA */ + 0x08040411, /* DENALI_CTL_40_DATA */ + 0x1400640a, /* DENALI_CTL_41_DATA */ + 0x02010a0a, /* DENALI_CTL_42_DATA */ + 0x00010001, /* DENALI_CTL_43_DATA */ + 0x04082012, /* DENALI_CTL_44_DATA */ + 0x00041109, /* DENALI_CTL_45_DATA */ + 0x00000000, /* DENALI_CTL_46_DATA */ + 0x03010000, /* DENALI_CTL_47_DATA */ + 0x06100034, /* DENALI_CTL_48_DATA */ + 0x0c280068, /* DENALI_CTL_49_DATA */ + 0x00bb0007, /* DENALI_CTL_50_DATA */ + 0x00000000, /* DENALI_CTL_51_DATA */ + 0x00060003, /* DENALI_CTL_52_DATA */ + 0x000a0003, /* DENALI_CTL_53_DATA */ + 0x000a0014, /* DENALI_CTL_54_DATA */ + 0x01000000, /* DENALI_CTL_55_DATA */ + 0x030a0000, /* DENALI_CTL_56_DATA */ + 0x0c000002, /* DENALI_CTL_57_DATA */ + 0x00000103, /* DENALI_CTL_58_DATA */ + 0x0003030a, /* DENALI_CTL_59_DATA */ + 0x00060037, /* DENALI_CTL_60_DATA */ + 0x0003006e, /* DENALI_CTL_61_DATA */ + 0x05050007, /* DENALI_CTL_62_DATA */ + 0x03020605, /* DENALI_CTL_63_DATA */ + 0x06050301, /* DENALI_CTL_64_DATA */ + 0x06020c05, /* DENALI_CTL_65_DATA */ + 0x05050302, /* DENALI_CTL_66_DATA */ + 0x03020305, /* DENALI_CTL_67_DATA */ + 0x00000301, /* DENALI_CTL_68_DATA */ + 0x00000301, /* DENALI_CTL_69_DATA */ + 0x00000001, /* DENALI_CTL_70_DATA */ + 0x00000000, /* DENALI_CTL_71_DATA */ + 0x00000000, /* DENALI_CTL_72_DATA */ + 0x01000000, /* DENALI_CTL_73_DATA */ + 0x80104002, /* DENALI_CTL_74_DATA */ + 0x00040003, /* DENALI_CTL_75_DATA */ + 0x00040005, /* DENALI_CTL_76_DATA */ + 0x00030000, /* DENALI_CTL_77_DATA */ + 0x00050004, /* DENALI_CTL_78_DATA */ + 0x00000004, /* DENALI_CTL_79_DATA */ + 0x00040003, /* DENALI_CTL_80_DATA */ + 0x00040005, /* DENALI_CTL_81_DATA */ + 0x18400000, /* DENALI_CTL_82_DATA */ + 0x00000c20, /* DENALI_CTL_83_DATA */ + 0x185030a0, /* DENALI_CTL_84_DATA */ + 0x02ec0000, /* DENALI_CTL_85_DATA */ + 0x00000176, /* DENALI_CTL_86_DATA */ + 0x00000000, /* DENALI_CTL_87_DATA */ + 0x00000000, /* DENALI_CTL_88_DATA */ + 0x00000000, /* DENALI_CTL_89_DATA */ + 0x00000000, /* DENALI_CTL_90_DATA */ + 0x00000000, /* DENALI_CTL_91_DATA */ + 0x06030300, /* DENALI_CTL_92_DATA */ + 0x00030303, /* DENALI_CTL_93_DATA */ + 0x02030200, /* DENALI_CTL_94_DATA */ + 0x00040703, /* DENALI_CTL_95_DATA */ + 0x03020302, /* DENALI_CTL_96_DATA */ + 0x02000407, /* DENALI_CTL_97_DATA */ + 0x07030203, /* DENALI_CTL_98_DATA */ + 0x00030f04, /* DENALI_CTL_99_DATA */ + 0x00070004, /* DENALI_CTL_100_DATA */ + 0x00000000, /* DENALI_CTL_101_DATA */ + 0x00000000, /* DENALI_CTL_102_DATA */ + 0x00000000, /* DENALI_CTL_103_DATA */ + 0x00000000, /* DENALI_CTL_104_DATA */ + 0x00000000, /* DENALI_CTL_105_DATA */ + 0x00000000, /* DENALI_CTL_106_DATA */ + 0x00000000, /* DENALI_CTL_107_DATA */ + 0x00010000, /* DENALI_CTL_108_DATA */ + 0x20040020, /* DENALI_CTL_109_DATA */ + 0x00200400, /* DENALI_CTL_110_DATA */ + 0x01000400, /* DENALI_CTL_111_DATA */ + 0x00000b80, /* DENALI_CTL_112_DATA */ + 0x00000000, /* DENALI_CTL_113_DATA */ + 0x00000001, /* DENALI_CTL_114_DATA */ + 0x00000002, /* DENALI_CTL_115_DATA */ + 0x0000000e, /* DENALI_CTL_116_DATA */ + 0x00000000, /* DENALI_CTL_117_DATA */ + 0x00000000, /* DENALI_CTL_118_DATA */ + 0x00000000, /* DENALI_CTL_119_DATA */ + 0x00000000, /* DENALI_CTL_120_DATA */ + 0x00000000, /* DENALI_CTL_121_DATA */ + 0x00500000, /* DENALI_CTL_122_DATA */ + 0x00640028, /* DENALI_CTL_123_DATA */ + 0x00640404, /* DENALI_CTL_124_DATA */ + 0x005000a0, /* DENALI_CTL_125_DATA */ + 0x060600c8, /* DENALI_CTL_126_DATA */ + 0x000a00c8, /* DENALI_CTL_127_DATA */ + 0x000d0005, /* DENALI_CTL_128_DATA */ + 0x000d0404, /* DENALI_CTL_129_DATA */ + 0x00000000, /* DENALI_CTL_130_DATA */ + 0x00000000, /* DENALI_CTL_131_DATA */ + 0x00000000, /* DENALI_CTL_132_DATA */ + 0x001400a3, /* DENALI_CTL_133_DATA */ + 0x00e30009, /* DENALI_CTL_134_DATA */ + 0x00120024, /* DENALI_CTL_135_DATA */ + 0x00040063, /* DENALI_CTL_136_DATA */ + 0x00000000, /* DENALI_CTL_137_DATA */ + 0x00310031, /* DENALI_CTL_138_DATA */ + 0x00000031, /* DENALI_CTL_139_DATA */ + 0x004d0000, /* DENALI_CTL_140_DATA */ + 0x004d004d, /* DENALI_CTL_141_DATA */ + 0x004d0000, /* DENALI_CTL_142_DATA */ + 0x004d004d, /* DENALI_CTL_143_DATA */ + 0x00010101, /* DENALI_CTL_144_DATA */ + 0x00000000, /* DENALI_CTL_145_DATA */ + 0x00000000, /* DENALI_CTL_146_DATA */ + 0x001400a3, /* DENALI_CTL_147_DATA */ + 0x00e30009, /* DENALI_CTL_148_DATA */ + 0x00120024, /* DENALI_CTL_149_DATA */ + 0x00040063, /* DENALI_CTL_150_DATA */ + 0x00000000, /* DENALI_CTL_151_DATA */ + 0x00310031, /* DENALI_CTL_152_DATA */ + 0x00000031, /* DENALI_CTL_153_DATA */ + 0x004d0000, /* DENALI_CTL_154_DATA */ + 0x004d004d, /* DENALI_CTL_155_DATA */ + 0x004d0000, /* DENALI_CTL_156_DATA */ + 0x004d004d, /* DENALI_CTL_157_DATA */ + 0x00010101, /* DENALI_CTL_158_DATA */ + 0x00000000, /* DENALI_CTL_159_DATA */ + 0x00000000, /* DENALI_CTL_160_DATA */ + 0x00000000, /* DENALI_CTL_161_DATA */ + 0x00000001, /* DENALI_CTL_162_DATA */ + 0x00000000, /* DENALI_CTL_163_DATA */ + 0x18151100, /* DENALI_CTL_164_DATA */ + 0x0000000c, /* DENALI_CTL_165_DATA */ + 0x00000000, /* DENALI_CTL_166_DATA */ + 0x00000000, /* DENALI_CTL_167_DATA */ + 0x00000000, /* DENALI_CTL_168_DATA */ + 0x00000000, /* DENALI_CTL_169_DATA */ + 0x00000000, /* DENALI_CTL_170_DATA */ + 0x00000000, /* DENALI_CTL_171_DATA */ + 0x00000000, /* DENALI_CTL_172_DATA */ + 0x00000000, /* DENALI_CTL_173_DATA */ + 0x00000000, /* DENALI_CTL_174_DATA */ + 0x00000000, /* DENALI_CTL_175_DATA */ + 0x00000000, /* DENALI_CTL_176_DATA */ + 0x00000000, /* DENALI_CTL_177_DATA */ + 0x00000000, /* DENALI_CTL_178_DATA */ + 0x00020003, /* DENALI_CTL_179_DATA */ + 0x00400100, /* DENALI_CTL_180_DATA */ + 0x000c0190, /* DENALI_CTL_181_DATA */ + 0x01000200, /* DENALI_CTL_182_DATA */ + 0x03200040, /* DENALI_CTL_183_DATA */ + 0x00020018, /* DENALI_CTL_184_DATA */ + 0x00400100, /* DENALI_CTL_185_DATA */ + 0x00080032, /* DENALI_CTL_186_DATA */ + 0x00140000, /* DENALI_CTL_187_DATA */ + 0x00030028, /* DENALI_CTL_188_DATA */ + 0x01010100, /* DENALI_CTL_189_DATA */ + 0x02000202, /* DENALI_CTL_190_DATA */ + 0x0b000002, /* DENALI_CTL_191_DATA */ + 0x01000f0f, /* DENALI_CTL_192_DATA */ + 0x00000000, /* DENALI_CTL_193_DATA */ + 0x00000000, /* DENALI_CTL_194_DATA */ + 0x00010003, /* DENALI_CTL_195_DATA */ + 0x00000c03, /* DENALI_CTL_196_DATA */ + 0x00040101, /* DENALI_CTL_197_DATA */ + 0x04010100, /* DENALI_CTL_198_DATA */ + 0x01000000, /* DENALI_CTL_199_DATA */ + 0x02010000, /* DENALI_CTL_200_DATA */ + 0x00000001, /* DENALI_CTL_201_DATA */ + 0x00000000, /* DENALI_CTL_202_DATA */ + 0x00000000, /* DENALI_CTL_203_DATA */ + 0x00000000, /* DENALI_CTL_204_DATA */ + 0x00000000, /* DENALI_CTL_205_DATA */ + 0x00000000, /* DENALI_CTL_206_DATA */ + 0x00000000, /* DENALI_CTL_207_DATA */ + 0x00000000, /* DENALI_CTL_208_DATA */ + 0x00000000, /* DENALI_CTL_209_DATA */ + 0x00000000, /* DENALI_CTL_210_DATA */ + 0x00010000, /* DENALI_CTL_211_DATA */ + 0x00000001, /* DENALI_CTL_212_DATA */ + 0x01010001, /* DENALI_CTL_213_DATA */ + 0x05040001, /* DENALI_CTL_214_DATA */ + 0x040a0703, /* DENALI_CTL_215_DATA */ + 0x02080808, /* DENALI_CTL_216_DATA */ + 0x020e000a, /* DENALI_CTL_217_DATA */ + 0x020f010b, /* DENALI_CTL_218_DATA */ + 0x000d0008, /* DENALI_CTL_219_DATA */ + 0x00080b0a, /* DENALI_CTL_220_DATA */ + 0x03000200, /* DENALI_CTL_221_DATA */ + 0x00000100, /* DENALI_CTL_222_DATA */ + 0x00000000, /* DENALI_CTL_223_DATA */ + 0x00000000, /* DENALI_CTL_224_DATA */ + 0x0d000001, /* DENALI_CTL_225_DATA */ + 0x00000028, /* DENALI_CTL_226_DATA */ + 0x00010000, /* DENALI_CTL_227_DATA */ + 0x00000003, /* DENALI_CTL_228_DATA */ + 0x00000000, /* DENALI_CTL_229_DATA */ + 0x00000000, /* DENALI_CTL_230_DATA */ + 0x00000000, /* DENALI_CTL_231_DATA */ + 0x00000000, /* DENALI_CTL_232_DATA */ + 0x00000000, /* DENALI_CTL_233_DATA */ + 0x00000000, /* DENALI_CTL_234_DATA */ + 0x00000000, /* DENALI_CTL_235_DATA */ + 0x00000000, /* DENALI_CTL_236_DATA */ + 0x00010100, /* DENALI_CTL_237_DATA */ + 0x01000000, /* DENALI_CTL_238_DATA */ + 0x00000001, /* DENALI_CTL_239_DATA */ + 0x00000303, /* DENALI_CTL_240_DATA */ + 0x00000000, /* DENALI_CTL_241_DATA */ + 0x00000000, /* DENALI_CTL_242_DATA */ + 0x00000000, /* DENALI_CTL_243_DATA */ + 0x00000000, /* DENALI_CTL_244_DATA */ + 0x00000000, /* DENALI_CTL_245_DATA */ + 0x00000000, /* DENALI_CTL_246_DATA */ + 0x00000000, /* DENALI_CTL_247_DATA */ + 0x00000000, /* DENALI_CTL_248_DATA */ + 0x00000000, /* DENALI_CTL_249_DATA */ + 0x00000000, /* DENALI_CTL_250_DATA */ + 0x00000000, /* DENALI_CTL_251_DATA */ + 0x00000000, /* DENALI_CTL_252_DATA */ + 0x00000000, /* DENALI_CTL_253_DATA */ + 0x00000000, /* DENALI_CTL_254_DATA */ + 0x00000000, /* DENALI_CTL_255_DATA */ + 0x000556aa, /* DENALI_CTL_256_DATA */ + 0x000aaaaa, /* DENALI_CTL_257_DATA */ + 0x000aa955, /* DENALI_CTL_258_DATA */ + 0x00055555, /* DENALI_CTL_259_DATA */ + 0x000b3133, /* DENALI_CTL_260_DATA */ + 0x0004cd33, /* DENALI_CTL_261_DATA */ + 0x0004cecc, /* DENALI_CTL_262_DATA */ + 0x000b32cc, /* DENALI_CTL_263_DATA */ + 0x00010300, /* DENALI_CTL_264_DATA */ + 0x03000100, /* DENALI_CTL_265_DATA */ + 0x00000000, /* DENALI_CTL_266_DATA */ + 0x00000000, /* DENALI_CTL_267_DATA */ + 0x00000000, /* DENALI_CTL_268_DATA */ + 0x00000000, /* DENALI_CTL_269_DATA */ + 0x00000000, /* DENALI_CTL_270_DATA */ + 0x00000000, /* DENALI_CTL_271_DATA */ + 0x00000000, /* DENALI_CTL_272_DATA */ + 0x00000000, /* DENALI_CTL_273_DATA */ + 0x00ffff00, /* DENALI_CTL_274_DATA */ + 0x1a160000, /* DENALI_CTL_275_DATA */ + 0x08000012, /* DENALI_CTL_276_DATA */ + 0x00000c20, /* DENALI_CTL_277_DATA */ + 0x00000200, /* DENALI_CTL_278_DATA */ + 0x00000200, /* DENALI_CTL_279_DATA */ + 0x00000200, /* DENALI_CTL_280_DATA */ + 0x00000200, /* DENALI_CTL_281_DATA */ + 0x00000c20, /* DENALI_CTL_282_DATA */ + 0x00007940, /* DENALI_CTL_283_DATA */ + 0x18500409, /* DENALI_CTL_284_DATA */ + 0x00000200, /* DENALI_CTL_285_DATA */ + 0x00000200, /* DENALI_CTL_286_DATA */ + 0x00000200, /* DENALI_CTL_287_DATA */ + 0x00000200, /* DENALI_CTL_288_DATA */ + 0x00001850, /* DENALI_CTL_289_DATA */ + 0x0000f320, /* DENALI_CTL_290_DATA */ + 0x0176060c, /* DENALI_CTL_291_DATA */ + 0x00000200, /* DENALI_CTL_292_DATA */ + 0x00000200, /* DENALI_CTL_293_DATA */ + 0x00000200, /* DENALI_CTL_294_DATA */ + 0x00000200, /* DENALI_CTL_295_DATA */ + 0x00000176, /* DENALI_CTL_296_DATA */ + 0x00000e9c, /* DENALI_CTL_297_DATA */ + 0x02020205, /* DENALI_CTL_298_DATA */ + 0x03030202, /* DENALI_CTL_299_DATA */ + 0x00000018, /* DENALI_CTL_300_DATA */ + 0x00000000, /* DENALI_CTL_301_DATA */ + 0x00000000, /* DENALI_CTL_302_DATA */ + 0x00001403, /* DENALI_CTL_303_DATA */ + 0x00000000, /* DENALI_CTL_304_DATA */ + 0x00000000, /* DENALI_CTL_305_DATA */ + 0x00000000, /* DENALI_CTL_306_DATA */ + 0x00030000, /* DENALI_CTL_307_DATA */ + 0x000a001c, /* DENALI_CTL_308_DATA */ + 0x000e0020, /* DENALI_CTL_309_DATA */ + 0x00060018, /* DENALI_CTL_310_DATA */ + 0x00000000, /* DENALI_CTL_311_DATA */ + 0x00000000, /* DENALI_CTL_312_DATA */ + 0x02000000, /* DENALI_CTL_313_DATA */ + 0x00090305, /* DENALI_CTL_314_DATA */ + 0x00050101, /* DENALI_CTL_315_DATA */ + 0x00000000, /* DENALI_CTL_316_DATA */ + 0x00000000, /* DENALI_CTL_317_DATA */ + 0x00000000, /* DENALI_CTL_318_DATA */ + 0x00000000, /* DENALI_CTL_319_DATA */ + 0x00000000, /* DENALI_CTL_320_DATA */ + 0x00000000, /* DENALI_CTL_321_DATA */ + 0x00000000, /* DENALI_CTL_322_DATA */ + 0x00000000, /* DENALI_CTL_323_DATA */ + 0x01000001, /* DENALI_CTL_324_DATA */ + 0x01010101, /* DENALI_CTL_325_DATA */ + 0x01000101, /* DENALI_CTL_326_DATA */ + 0x01000100, /* DENALI_CTL_327_DATA */ + 0x00010001, /* DENALI_CTL_328_DATA */ + 0x00010002, /* DENALI_CTL_329_DATA */ + 0x00020100, /* DENALI_CTL_330_DATA */ + 0x00000002 /* DENALI_CTL_331_DATA */ + } + }, + { + { + 0x00000b00, /* DENALI_PI_00_DATA */ + 0x00000000, /* DENALI_PI_01_DATA */ + 0x000002ec, /* DENALI_PI_02_DATA */ + 0x00000176, /* DENALI_PI_03_DATA */ + 0x000030a0, /* DENALI_PI_04_DATA */ + 0x00001850, /* DENALI_PI_05_DATA */ + 0x00001840, /* DENALI_PI_06_DATA */ + 0x01760c20, /* DENALI_PI_07_DATA */ + 0x00000200, /* DENALI_PI_08_DATA */ + 0x00000200, /* DENALI_PI_09_DATA */ + 0x00000200, /* DENALI_PI_10_DATA */ + 0x00000200, /* DENALI_PI_11_DATA */ + 0x00001850, /* DENALI_PI_12_DATA */ + 0x00000200, /* DENALI_PI_13_DATA */ + 0x00000200, /* DENALI_PI_14_DATA */ + 0x00000200, /* DENALI_PI_15_DATA */ + 0x00000200, /* DENALI_PI_16_DATA */ + 0x00000c20, /* DENALI_PI_17_DATA */ + 0x00000200, /* DENALI_PI_18_DATA */ + 0x00000200, /* DENALI_PI_19_DATA */ + 0x00000200, /* DENALI_PI_20_DATA */ + 0x00000200, /* DENALI_PI_21_DATA */ + 0x00010000, /* DENALI_PI_22_DATA */ + 0x00000007, /* DENALI_PI_23_DATA */ + 0x01000001, /* DENALI_PI_24_DATA */ + 0x00000000, /* DENALI_PI_25_DATA */ + 0x3fffffff, /* DENALI_PI_26_DATA */ + 0x00000000, /* DENALI_PI_27_DATA */ + 0x00000000, /* DENALI_PI_28_DATA */ + 0x00000000, /* DENALI_PI_29_DATA */ + 0x00000000, /* DENALI_PI_30_DATA */ + 0x00000000, /* DENALI_PI_31_DATA */ + 0x00000000, /* DENALI_PI_32_DATA */ + 0x00000000, /* DENALI_PI_33_DATA */ + 0x00000000, /* DENALI_PI_34_DATA */ + 0x00000000, /* DENALI_PI_35_DATA */ + 0x00000000, /* DENALI_PI_36_DATA */ + 0x00000000, /* DENALI_PI_37_DATA */ + 0x00000000, /* DENALI_PI_38_DATA */ + 0x00000000, /* DENALI_PI_39_DATA */ + 0x00000000, /* DENALI_PI_40_DATA */ + 0x0f000101, /* DENALI_PI_41_DATA */ + 0x082b3223, /* DENALI_PI_42_DATA */ + 0x080c0004, /* DENALI_PI_43_DATA */ + 0x00061c00, /* DENALI_PI_44_DATA */ + 0x00000214, /* DENALI_PI_45_DATA */ + 0x00bb0007, /* DENALI_PI_46_DATA */ + 0x0c280068, /* DENALI_PI_47_DATA */ + 0x06100034, /* DENALI_PI_48_DATA */ + 0x00000500, /* DENALI_PI_49_DATA */ + 0x00000000, /* DENALI_PI_50_DATA */ + 0x00000000, /* DENALI_PI_51_DATA */ + 0x00000000, /* DENALI_PI_52_DATA */ + 0x00000000, /* DENALI_PI_53_DATA */ + 0x00000000, /* DENALI_PI_54_DATA */ + 0x00000000, /* DENALI_PI_55_DATA */ + 0x00000000, /* DENALI_PI_56_DATA */ + 0x00000000, /* DENALI_PI_57_DATA */ + 0x04040100, /* DENALI_PI_58_DATA */ + 0x0a000004, /* DENALI_PI_59_DATA */ + 0x00000128, /* DENALI_PI_60_DATA */ + 0x00000000, /* DENALI_PI_61_DATA */ + 0x0003000f, /* DENALI_PI_62_DATA */ + 0x00000018, /* DENALI_PI_63_DATA */ + 0x00000000, /* DENALI_PI_64_DATA */ + 0x00000000, /* DENALI_PI_65_DATA */ + 0x00060002, /* DENALI_PI_66_DATA */ + 0x00010001, /* DENALI_PI_67_DATA */ + 0x00000101, /* DENALI_PI_68_DATA */ + 0x00020001, /* DENALI_PI_69_DATA */ + 0x00080004, /* DENALI_PI_70_DATA */ + 0x00000000, /* DENALI_PI_71_DATA */ + 0x05030000, /* DENALI_PI_72_DATA */ + 0x070a0404, /* DENALI_PI_73_DATA */ + 0x00000000, /* DENALI_PI_74_DATA */ + 0x00000000, /* DENALI_PI_75_DATA */ + 0x00000000, /* DENALI_PI_76_DATA */ + 0x000f0f00, /* DENALI_PI_77_DATA */ + 0x0000001e, /* DENALI_PI_78_DATA */ + 0x00000000, /* DENALI_PI_79_DATA */ + 0x01010300, /* DENALI_PI_80_DATA */ + 0x00000000, /* DENALI_PI_81_DATA */ + 0x00000000, /* DENALI_PI_82_DATA */ + 0x01000000, /* DENALI_PI_83_DATA */ + 0x00000101, /* DENALI_PI_84_DATA */ + 0x55555a5a, /* DENALI_PI_85_DATA */ + 0x55555a5a, /* DENALI_PI_86_DATA */ + 0x55555a5a, /* DENALI_PI_87_DATA */ + 0x55555a5a, /* DENALI_PI_88_DATA */ + 0x0c050001, /* DENALI_PI_89_DATA */ + 0x06020009, /* DENALI_PI_90_DATA */ + 0x00010004, /* DENALI_PI_91_DATA */ + 0x00000203, /* DENALI_PI_92_DATA */ + 0x00030000, /* DENALI_PI_93_DATA */ + 0x170f0000, /* DENALI_PI_94_DATA */ + 0x00060018, /* DENALI_PI_95_DATA */ + 0x000e0020, /* DENALI_PI_96_DATA */ + 0x000a001c, /* DENALI_PI_97_DATA */ + 0x00000000, /* DENALI_PI_98_DATA */ + 0x00000000, /* DENALI_PI_99_DATA */ + 0x00000100, /* DENALI_PI_100_DATA */ + 0x140a0000, /* DENALI_PI_101_DATA */ + 0x000d010a, /* DENALI_PI_102_DATA */ + 0x0100c802, /* DENALI_PI_103_DATA */ + 0x010a0064, /* DENALI_PI_104_DATA */ + 0x000e0100, /* DENALI_PI_105_DATA */ + 0x0100000e, /* DENALI_PI_106_DATA */ + 0x00c900c9, /* DENALI_PI_107_DATA */ + 0x00650100, /* DENALI_PI_108_DATA */ + 0x1e1a0065, /* DENALI_PI_109_DATA */ + 0x10010204, /* DENALI_PI_110_DATA */ + 0x06070605, /* DENALI_PI_111_DATA */ + 0x20000202, /* DENALI_PI_112_DATA */ + 0x00201000, /* DENALI_PI_113_DATA */ + 0x00201000, /* DENALI_PI_114_DATA */ + 0x04041000, /* DENALI_PI_115_DATA */ + 0x10020100, /* DENALI_PI_116_DATA */ + 0x0003010c, /* DENALI_PI_117_DATA */ + 0x004b004a, /* DENALI_PI_118_DATA */ + 0x1a0f0000, /* DENALI_PI_119_DATA */ + 0x0102041e, /* DENALI_PI_120_DATA */ + 0x34000000, /* DENALI_PI_121_DATA */ + 0x00000000, /* DENALI_PI_122_DATA */ + 0x00000000, /* DENALI_PI_123_DATA */ + 0x00010000, /* DENALI_PI_124_DATA */ + 0x00000400, /* DENALI_PI_125_DATA */ + 0x00310000, /* DENALI_PI_126_DATA */ + 0x004d4d00, /* DENALI_PI_127_DATA */ + 0x00120024, /* DENALI_PI_128_DATA */ + 0x4d000031, /* DENALI_PI_129_DATA */ + 0x0000144d, /* DENALI_PI_130_DATA */ + 0x00310009, /* DENALI_PI_131_DATA */ + 0x004d4d00, /* DENALI_PI_132_DATA */ + 0x00000004, /* DENALI_PI_133_DATA */ + 0x4d000031, /* DENALI_PI_134_DATA */ + 0x0000244d, /* DENALI_PI_135_DATA */ + 0x00310012, /* DENALI_PI_136_DATA */ + 0x004d4d00, /* DENALI_PI_137_DATA */ + 0x00090014, /* DENALI_PI_138_DATA */ + 0x4d000031, /* DENALI_PI_139_DATA */ + 0x0004004d, /* DENALI_PI_140_DATA */ + 0x00310000, /* DENALI_PI_141_DATA */ + 0x004d4d00, /* DENALI_PI_142_DATA */ + 0x00120024, /* DENALI_PI_143_DATA */ + 0x4d000031, /* DENALI_PI_144_DATA */ + 0x0000144d, /* DENALI_PI_145_DATA */ + 0x00310009, /* DENALI_PI_146_DATA */ + 0x004d4d00, /* DENALI_PI_147_DATA */ + 0x00000004, /* DENALI_PI_148_DATA */ + 0x4d000031, /* DENALI_PI_149_DATA */ + 0x0000244d, /* DENALI_PI_150_DATA */ + 0x00310012, /* DENALI_PI_151_DATA */ + 0x004d4d00, /* DENALI_PI_152_DATA */ + 0x00090014, /* DENALI_PI_153_DATA */ + 0x4d000031, /* DENALI_PI_154_DATA */ + 0x0200004d, /* DENALI_PI_155_DATA */ + 0x00c8000d, /* DENALI_PI_156_DATA */ + 0x08080064, /* DENALI_PI_157_DATA */ + 0x040a0404, /* DENALI_PI_158_DATA */ + 0x03000d92, /* DENALI_PI_159_DATA */ + 0x010a2001, /* DENALI_PI_160_DATA */ + 0x0f11080a, /* DENALI_PI_161_DATA */ + 0x0000110a, /* DENALI_PI_162_DATA */ + 0x2200d92e, /* DENALI_PI_163_DATA */ + 0x080c2003, /* DENALI_PI_164_DATA */ + 0x0809080a, /* DENALI_PI_165_DATA */ + 0x00000a0a, /* DENALI_PI_166_DATA */ + 0x11006c97, /* DENALI_PI_167_DATA */ + 0x040a2002, /* DENALI_PI_168_DATA */ + 0x0200020a, /* DENALI_PI_169_DATA */ + 0x02000200, /* DENALI_PI_170_DATA */ + 0x02000200, /* DENALI_PI_171_DATA */ + 0x02000200, /* DENALI_PI_172_DATA */ + 0x02000200, /* DENALI_PI_173_DATA */ + 0x00000000, /* DENALI_PI_174_DATA */ + 0x00000000, /* DENALI_PI_175_DATA */ + 0x00000000, /* DENALI_PI_176_DATA */ + 0x00000000, /* DENALI_PI_177_DATA */ + 0x00000000, /* DENALI_PI_178_DATA */ + 0x00000000, /* DENALI_PI_179_DATA */ + 0x00000000, /* DENALI_PI_180_DATA */ + 0x00000000, /* DENALI_PI_181_DATA */ + 0x00000000, /* DENALI_PI_182_DATA */ + 0x00000000, /* DENALI_PI_183_DATA */ + 0x00000000, /* DENALI_PI_184_DATA */ + 0x00000000, /* DENALI_PI_185_DATA */ + 0x01000400, /* DENALI_PI_186_DATA */ + 0x00017600, /* DENALI_PI_187_DATA */ + 0x00000e9c, /* DENALI_PI_188_DATA */ + 0x00001850, /* DENALI_PI_189_DATA */ + 0x0000f320, /* DENALI_PI_190_DATA */ + 0x00000c20, /* DENALI_PI_191_DATA */ + 0x00007940, /* DENALI_PI_192_DATA */ + 0x08000000, /* DENALI_PI_193_DATA */ + 0x00000100, /* DENALI_PI_194_DATA */ + 0x00000000, /* DENALI_PI_195_DATA */ + 0x00000000, /* DENALI_PI_196_DATA */ + 0x00000000, /* DENALI_PI_197_DATA */ + 0x00000000, /* DENALI_PI_198_DATA */ + 0x00000002 /* DENALI_PI_199_DATA */ + } + }, + { + { + 0x76543210, /* DENALI_PHY_00_DATA */ + 0x0004f008, /* DENALI_PHY_01_DATA */ + 0x00020119, /* DENALI_PHY_02_DATA */ + 0x00000000, /* DENALI_PHY_03_DATA */ + 0x00000000, /* DENALI_PHY_04_DATA */ + 0x00010000, /* DENALI_PHY_05_DATA */ + 0x01665555, /* DENALI_PHY_06_DATA */ + 0x03665555, /* DENALI_PHY_07_DATA */ + 0x00010f00, /* DENALI_PHY_08_DATA */ + 0x05010200, /* DENALI_PHY_09_DATA */ + 0x00000002, /* DENALI_PHY_10_DATA */ + 0x00170180, /* DENALI_PHY_11_DATA */ + 0x00cc0201, /* DENALI_PHY_12_DATA */ + 0x00030066, /* DENALI_PHY_13_DATA */ + 0x00000000, /* DENALI_PHY_14_DATA */ + 0x00000000, /* DENALI_PHY_15_DATA */ + 0x00000000, /* DENALI_PHY_16_DATA */ + 0x00000000, /* DENALI_PHY_17_DATA */ + 0x00000000, /* DENALI_PHY_18_DATA */ + 0x00000000, /* DENALI_PHY_19_DATA */ + 0x00000000, /* DENALI_PHY_20_DATA */ + 0x00000000, /* DENALI_PHY_21_DATA */ + 0x04080000, /* DENALI_PHY_22_DATA */ + 0x04080400, /* DENALI_PHY_23_DATA */ + 0x30000000, /* DENALI_PHY_24_DATA */ + 0x0c00c007, /* DENALI_PHY_25_DATA */ + 0x00000100, /* DENALI_PHY_26_DATA */ + 0x00000000, /* DENALI_PHY_27_DATA */ + 0xfd02fe01, /* DENALI_PHY_28_DATA */ + 0xf708fb04, /* DENALI_PHY_29_DATA */ + 0xdf20ef10, /* DENALI_PHY_30_DATA */ + 0x7f80bf40, /* DENALI_PHY_31_DATA */ + 0x0001aaaa, /* DENALI_PHY_32_DATA */ + 0x00000000, /* DENALI_PHY_33_DATA */ + 0x00000000, /* DENALI_PHY_34_DATA */ + 0x00000000, /* DENALI_PHY_35_DATA */ + 0x00000000, /* DENALI_PHY_36_DATA */ + 0x00000000, /* DENALI_PHY_37_DATA */ + 0x00000000, /* DENALI_PHY_38_DATA */ + 0x00000000, /* DENALI_PHY_39_DATA */ + 0x00000000, /* DENALI_PHY_40_DATA */ + 0x00000000, /* DENALI_PHY_41_DATA */ + 0x00000000, /* DENALI_PHY_42_DATA */ + 0x00000000, /* DENALI_PHY_43_DATA */ + 0x00000000, /* DENALI_PHY_44_DATA */ + 0x00000000, /* DENALI_PHY_45_DATA */ + 0x00000000, /* DENALI_PHY_46_DATA */ + 0x00000000, /* DENALI_PHY_47_DATA */ + 0x00000000, /* DENALI_PHY_48_DATA */ + 0x00000000, /* DENALI_PHY_49_DATA */ + 0x00000000, /* DENALI_PHY_50_DATA */ + 0x00000000, /* DENALI_PHY_51_DATA */ + 0x00200000, /* DENALI_PHY_52_DATA */ + 0x00000000, /* DENALI_PHY_53_DATA */ + 0x00000000, /* DENALI_PHY_54_DATA */ + 0x00000000, /* DENALI_PHY_55_DATA */ + 0x00000000, /* DENALI_PHY_56_DATA */ + 0x00000000, /* DENALI_PHY_57_DATA */ + 0x00000000, /* DENALI_PHY_58_DATA */ + 0x02800280, /* DENALI_PHY_59_DATA */ + 0x02800280, /* DENALI_PHY_60_DATA */ + 0x02800280, /* DENALI_PHY_61_DATA */ + 0x02800280, /* DENALI_PHY_62_DATA */ + 0x00000280, /* DENALI_PHY_63_DATA */ + 0x00000000, /* DENALI_PHY_64_DATA */ + 0x00000000, /* DENALI_PHY_65_DATA */ + 0x00000000, /* DENALI_PHY_66_DATA */ + 0x00000000, /* DENALI_PHY_67_DATA */ + 0x00800000, /* DENALI_PHY_68_DATA */ + 0x00800080, /* DENALI_PHY_69_DATA */ + 0x00800080, /* DENALI_PHY_70_DATA */ + 0x00800080, /* DENALI_PHY_71_DATA */ + 0x00800080, /* DENALI_PHY_72_DATA */ + 0x00800080, /* DENALI_PHY_73_DATA */ + 0x00800080, /* DENALI_PHY_74_DATA */ + 0x00800080, /* DENALI_PHY_75_DATA */ + 0x00800080, /* DENALI_PHY_76_DATA */ + 0x01190080, /* DENALI_PHY_77_DATA */ + 0x00000002, /* DENALI_PHY_78_DATA */ + 0x00000000, /* DENALI_PHY_79_DATA */ + 0x00000000, /* DENALI_PHY_80_DATA */ + 0x00000200, /* DENALI_PHY_81_DATA */ + 0x00000000, /* DENALI_PHY_82_DATA */ + 0x51315152, /* DENALI_PHY_83_DATA */ + 0xc0013150, /* DENALI_PHY_84_DATA */ + 0x020000c0, /* DENALI_PHY_85_DATA */ + 0x00100001, /* DENALI_PHY_86_DATA */ + 0x07054204, /* DENALI_PHY_87_DATA */ + 0x000f0c18, /* DENALI_PHY_88_DATA */ + 0x01000140, /* DENALI_PHY_89_DATA */ + 0x00000c10, /* DENALI_PHY_90_DATA */ + 0x00000000, /* DENALI_PHY_91_DATA */ + 0x00000000, /* DENALI_PHY_92_DATA */ + 0x00000000, /* DENALI_PHY_93_DATA */ + 0x00000000, /* DENALI_PHY_94_DATA */ + 0x00000000, /* DENALI_PHY_95_DATA */ + 0x00000000, /* DENALI_PHY_96_DATA */ + 0x00000000, /* DENALI_PHY_97_DATA */ + 0x00000000, /* DENALI_PHY_98_DATA */ + 0x00000000, /* DENALI_PHY_99_DATA */ + 0x00000000, /* DENALI_PHY_100_DATA */ + 0x00000000, /* DENALI_PHY_101_DATA */ + 0x00000000, /* DENALI_PHY_102_DATA */ + 0x00000000, /* DENALI_PHY_103_DATA */ + 0x00000000, /* DENALI_PHY_104_DATA */ + 0x00000000, /* DENALI_PHY_105_DATA */ + 0x00000000, /* DENALI_PHY_106_DATA */ + 0x00000000, /* DENALI_PHY_107_DATA */ + 0x00000000, /* DENALI_PHY_108_DATA */ + 0x00000000, /* DENALI_PHY_109_DATA */ + 0x00000000, /* DENALI_PHY_110_DATA */ + 0x00000000, /* DENALI_PHY_111_DATA */ + 0x00000000, /* DENALI_PHY_112_DATA */ + 0x00000000, /* DENALI_PHY_113_DATA */ + 0x00000000, /* DENALI_PHY_114_DATA */ + 0x00000000, /* DENALI_PHY_115_DATA */ + 0x00000000, /* DENALI_PHY_116_DATA */ + 0x00000000, /* DENALI_PHY_117_DATA */ + 0x00000000, /* DENALI_PHY_118_DATA */ + 0x00000000, /* DENALI_PHY_119_DATA */ + 0x00000000, /* DENALI_PHY_120_DATA */ + 0x00000000, /* DENALI_PHY_121_DATA */ + 0x00000000, /* DENALI_PHY_122_DATA */ + 0x00000000, /* DENALI_PHY_123_DATA */ + 0x00000000, /* DENALI_PHY_124_DATA */ + 0x00000000, /* DENALI_PHY_125_DATA */ + 0x00000000, /* DENALI_PHY_126_DATA */ + 0x00000000, /* DENALI_PHY_127_DATA */ + 0x76543210, /* DENALI_PHY_128_DATA */ + 0x0004f008, /* DENALI_PHY_129_DATA */ + 0x00020119, /* DENALI_PHY_130_DATA */ + 0x00000000, /* DENALI_PHY_131_DATA */ + 0x00000000, /* DENALI_PHY_132_DATA */ + 0x00010000, /* DENALI_PHY_133_DATA */ + 0x01665555, /* DENALI_PHY_134_DATA */ + 0x03665555, /* DENALI_PHY_135_DATA */ + 0x00010f00, /* DENALI_PHY_136_DATA */ + 0x05010200, /* DENALI_PHY_137_DATA */ + 0x00000002, /* DENALI_PHY_138_DATA */ + 0x00170180, /* DENALI_PHY_139_DATA */ + 0x00cc0201, /* DENALI_PHY_140_DATA */ + 0x00030066, /* DENALI_PHY_141_DATA */ + 0x00000000, /* DENALI_PHY_142_DATA */ + 0x00000000, /* DENALI_PHY_143_DATA */ + 0x00000000, /* DENALI_PHY_144_DATA */ + 0x00000000, /* DENALI_PHY_145_DATA */ + 0x00000000, /* DENALI_PHY_146_DATA */ + 0x00000000, /* DENALI_PHY_147_DATA */ + 0x00000000, /* DENALI_PHY_148_DATA */ + 0x00000000, /* DENALI_PHY_149_DATA */ + 0x04080000, /* DENALI_PHY_150_DATA */ + 0x04080400, /* DENALI_PHY_151_DATA */ + 0x30000000, /* DENALI_PHY_152_DATA */ + 0x0c00c007, /* DENALI_PHY_153_DATA */ + 0x00000100, /* DENALI_PHY_154_DATA */ + 0x00000000, /* DENALI_PHY_155_DATA */ + 0xfd02fe01, /* DENALI_PHY_156_DATA */ + 0xf708fb04, /* DENALI_PHY_157_DATA */ + 0xdf20ef10, /* DENALI_PHY_158_DATA */ + 0x7f80bf40, /* DENALI_PHY_159_DATA */ + 0x0000aaaa, /* DENALI_PHY_160_DATA */ + 0x00000000, /* DENALI_PHY_161_DATA */ + 0x00000000, /* DENALI_PHY_162_DATA */ + 0x00000000, /* DENALI_PHY_163_DATA */ + 0x00000000, /* DENALI_PHY_164_DATA */ + 0x00000000, /* DENALI_PHY_165_DATA */ + 0x00000000, /* DENALI_PHY_166_DATA */ + 0x00000000, /* DENALI_PHY_167_DATA */ + 0x00000000, /* DENALI_PHY_168_DATA */ + 0x00000000, /* DENALI_PHY_169_DATA */ + 0x00000000, /* DENALI_PHY_170_DATA */ + 0x00000000, /* DENALI_PHY_171_DATA */ + 0x00000000, /* DENALI_PHY_172_DATA */ + 0x00000000, /* DENALI_PHY_173_DATA */ + 0x00000000, /* DENALI_PHY_174_DATA */ + 0x00000000, /* DENALI_PHY_175_DATA */ + 0x00000000, /* DENALI_PHY_176_DATA */ + 0x00000000, /* DENALI_PHY_177_DATA */ + 0x00000000, /* DENALI_PHY_178_DATA */ + 0x00000000, /* DENALI_PHY_179_DATA */ + 0x00200000, /* DENALI_PHY_180_DATA */ + 0x00000000, /* DENALI_PHY_181_DATA */ + 0x00000000, /* DENALI_PHY_182_DATA */ + 0x00000000, /* DENALI_PHY_183_DATA */ + 0x00000000, /* DENALI_PHY_184_DATA */ + 0x00000000, /* DENALI_PHY_185_DATA */ + 0x00000000, /* DENALI_PHY_186_DATA */ + 0x02800280, /* DENALI_PHY_187_DATA */ + 0x02800280, /* DENALI_PHY_188_DATA */ + 0x02800280, /* DENALI_PHY_189_DATA */ + 0x02800280, /* DENALI_PHY_190_DATA */ + 0x00000280, /* DENALI_PHY_191_DATA */ + 0x00000000, /* DENALI_PHY_192_DATA */ + 0x00000000, /* DENALI_PHY_193_DATA */ + 0x00000000, /* DENALI_PHY_194_DATA */ + 0x00000000, /* DENALI_PHY_195_DATA */ + 0x00800000, /* DENALI_PHY_196_DATA */ + 0x00800080, /* DENALI_PHY_197_DATA */ + 0x00800080, /* DENALI_PHY_198_DATA */ + 0x00800080, /* DENALI_PHY_199_DATA */ + 0x00800080, /* DENALI_PHY_200_DATA */ + 0x00800080, /* DENALI_PHY_201_DATA */ + 0x00800080, /* DENALI_PHY_202_DATA */ + 0x00800080, /* DENALI_PHY_203_DATA */ + 0x00800080, /* DENALI_PHY_204_DATA */ + 0x01190080, /* DENALI_PHY_205_DATA */ + 0x00000002, /* DENALI_PHY_206_DATA */ + 0x00000000, /* DENALI_PHY_207_DATA */ + 0x00000000, /* DENALI_PHY_208_DATA */ + 0x00000200, /* DENALI_PHY_209_DATA */ + 0x00000000, /* DENALI_PHY_210_DATA */ + 0x51315152, /* DENALI_PHY_211_DATA */ + 0xc0013150, /* DENALI_PHY_212_DATA */ + 0x020000c0, /* DENALI_PHY_213_DATA */ + 0x00100001, /* DENALI_PHY_214_DATA */ + 0x07054204, /* DENALI_PHY_215_DATA */ + 0x000f0c18, /* DENALI_PHY_216_DATA */ + 0x01000140, /* DENALI_PHY_217_DATA */ + 0x00000c10, /* DENALI_PHY_218_DATA */ + 0x00000000, /* DENALI_PHY_219_DATA */ + 0x00000000, /* DENALI_PHY_220_DATA */ + 0x00000000, /* DENALI_PHY_221_DATA */ + 0x00000000, /* DENALI_PHY_222_DATA */ + 0x00000000, /* DENALI_PHY_223_DATA */ + 0x00000000, /* DENALI_PHY_224_DATA */ + 0x00000000, /* DENALI_PHY_225_DATA */ + 0x00000000, /* DENALI_PHY_226_DATA */ + 0x00000000, /* DENALI_PHY_227_DATA */ + 0x00000000, /* DENALI_PHY_228_DATA */ + 0x00000000, /* DENALI_PHY_229_DATA */ + 0x00000000, /* DENALI_PHY_230_DATA */ + 0x00000000, /* DENALI_PHY_231_DATA */ + 0x00000000, /* DENALI_PHY_232_DATA */ + 0x00000000, /* DENALI_PHY_233_DATA */ + 0x00000000, /* DENALI_PHY_234_DATA */ + 0x00000000, /* DENALI_PHY_235_DATA */ + 0x00000000, /* DENALI_PHY_236_DATA */ + 0x00000000, /* DENALI_PHY_237_DATA */ + 0x00000000, /* DENALI_PHY_238_DATA */ + 0x00000000, /* DENALI_PHY_239_DATA */ + 0x00000000, /* DENALI_PHY_240_DATA */ + 0x00000000, /* DENALI_PHY_241_DATA */ + 0x00000000, /* DENALI_PHY_242_DATA */ + 0x00000000, /* DENALI_PHY_243_DATA */ + 0x00000000, /* DENALI_PHY_244_DATA */ + 0x00000000, /* DENALI_PHY_245_DATA */ + 0x00000000, /* DENALI_PHY_246_DATA */ + 0x00000000, /* DENALI_PHY_247_DATA */ + 0x00000000, /* DENALI_PHY_248_DATA */ + 0x00000000, /* DENALI_PHY_249_DATA */ + 0x00000000, /* DENALI_PHY_250_DATA */ + 0x00000000, /* DENALI_PHY_251_DATA */ + 0x00000000, /* DENALI_PHY_252_DATA */ + 0x00000000, /* DENALI_PHY_253_DATA */ + 0x00000000, /* DENALI_PHY_254_DATA */ + 0x00000000, /* DENALI_PHY_255_DATA */ + 0x76543210, /* DENALI_PHY_256_DATA */ + 0x0004f008, /* DENALI_PHY_257_DATA */ + 0x00020119, /* DENALI_PHY_258_DATA */ + 0x00000000, /* DENALI_PHY_259_DATA */ + 0x00000000, /* DENALI_PHY_260_DATA */ + 0x00010000, /* DENALI_PHY_261_DATA */ + 0x01665555, /* DENALI_PHY_262_DATA */ + 0x03665555, /* DENALI_PHY_263_DATA */ + 0x00010f00, /* DENALI_PHY_264_DATA */ + 0x05010200, /* DENALI_PHY_265_DATA */ + 0x00000002, /* DENALI_PHY_266_DATA */ + 0x00170180, /* DENALI_PHY_267_DATA */ + 0x00cc0201, /* DENALI_PHY_268_DATA */ + 0x00030066, /* DENALI_PHY_269_DATA */ + 0x00000000, /* DENALI_PHY_270_DATA */ + 0x00000000, /* DENALI_PHY_271_DATA */ + 0x00000000, /* DENALI_PHY_272_DATA */ + 0x00000000, /* DENALI_PHY_273_DATA */ + 0x00000000, /* DENALI_PHY_274_DATA */ + 0x00000000, /* DENALI_PHY_275_DATA */ + 0x00000000, /* DENALI_PHY_276_DATA */ + 0x00000000, /* DENALI_PHY_277_DATA */ + 0x04080000, /* DENALI_PHY_278_DATA */ + 0x04080400, /* DENALI_PHY_279_DATA */ + 0x30000000, /* DENALI_PHY_280_DATA */ + 0x0c00c007, /* DENALI_PHY_281_DATA */ + 0x00000100, /* DENALI_PHY_282_DATA */ + 0x00000000, /* DENALI_PHY_283_DATA */ + 0xfd02fe01, /* DENALI_PHY_284_DATA */ + 0xf708fb04, /* DENALI_PHY_285_DATA */ + 0xdf20ef10, /* DENALI_PHY_286_DATA */ + 0x7f80bf40, /* DENALI_PHY_287_DATA */ + 0x0001aaaa, /* DENALI_PHY_288_DATA */ + 0x00000000, /* DENALI_PHY_289_DATA */ + 0x00000000, /* DENALI_PHY_290_DATA */ + 0x00000000, /* DENALI_PHY_291_DATA */ + 0x00000000, /* DENALI_PHY_292_DATA */ + 0x00000000, /* DENALI_PHY_293_DATA */ + 0x00000000, /* DENALI_PHY_294_DATA */ + 0x00000000, /* DENALI_PHY_295_DATA */ + 0x00000000, /* DENALI_PHY_296_DATA */ + 0x00000000, /* DENALI_PHY_297_DATA */ + 0x00000000, /* DENALI_PHY_298_DATA */ + 0x00000000, /* DENALI_PHY_299_DATA */ + 0x00000000, /* DENALI_PHY_300_DATA */ + 0x00000000, /* DENALI_PHY_301_DATA */ + 0x00000000, /* DENALI_PHY_302_DATA */ + 0x00000000, /* DENALI_PHY_303_DATA */ + 0x00000000, /* DENALI_PHY_304_DATA */ + 0x00000000, /* DENALI_PHY_305_DATA */ + 0x00000000, /* DENALI_PHY_306_DATA */ + 0x00000000, /* DENALI_PHY_307_DATA */ + 0x00200000, /* DENALI_PHY_308_DATA */ + 0x00000000, /* DENALI_PHY_309_DATA */ + 0x00000000, /* DENALI_PHY_310_DATA */ + 0x00000000, /* DENALI_PHY_311_DATA */ + 0x00000000, /* DENALI_PHY_312_DATA */ + 0x00000000, /* DENALI_PHY_313_DATA */ + 0x00000000, /* DENALI_PHY_314_DATA */ + 0x02800280, /* DENALI_PHY_315_DATA */ + 0x02800280, /* DENALI_PHY_316_DATA */ + 0x02800280, /* DENALI_PHY_317_DATA */ + 0x02800280, /* DENALI_PHY_318_DATA */ + 0x00000280, /* DENALI_PHY_319_DATA */ + 0x00000000, /* DENALI_PHY_320_DATA */ + 0x00000000, /* DENALI_PHY_321_DATA */ + 0x00000000, /* DENALI_PHY_322_DATA */ + 0x00000000, /* DENALI_PHY_323_DATA */ + 0x00800000, /* DENALI_PHY_324_DATA */ + 0x00800080, /* DENALI_PHY_325_DATA */ + 0x00800080, /* DENALI_PHY_326_DATA */ + 0x00800080, /* DENALI_PHY_327_DATA */ + 0x00800080, /* DENALI_PHY_328_DATA */ + 0x00800080, /* DENALI_PHY_329_DATA */ + 0x00800080, /* DENALI_PHY_330_DATA */ + 0x00800080, /* DENALI_PHY_331_DATA */ + 0x00800080, /* DENALI_PHY_332_DATA */ + 0x01190080, /* DENALI_PHY_333_DATA */ + 0x00000002, /* DENALI_PHY_334_DATA */ + 0x00000000, /* DENALI_PHY_335_DATA */ + 0x00000000, /* DENALI_PHY_336_DATA */ + 0x00000200, /* DENALI_PHY_337_DATA */ + 0x00000000, /* DENALI_PHY_338_DATA */ + 0x51315152, /* DENALI_PHY_339_DATA */ + 0xc0013150, /* DENALI_PHY_340_DATA */ + 0x020000c0, /* DENALI_PHY_341_DATA */ + 0x00100001, /* DENALI_PHY_342_DATA */ + 0x07054204, /* DENALI_PHY_343_DATA */ + 0x000f0c18, /* DENALI_PHY_344_DATA */ + 0x01000140, /* DENALI_PHY_345_DATA */ + 0x00000c10, /* DENALI_PHY_346_DATA */ + 0x00000000, /* DENALI_PHY_347_DATA */ + 0x00000000, /* DENALI_PHY_348_DATA */ + 0x00000000, /* DENALI_PHY_349_DATA */ + 0x00000000, /* DENALI_PHY_350_DATA */ + 0x00000000, /* DENALI_PHY_351_DATA */ + 0x00000000, /* DENALI_PHY_352_DATA */ + 0x00000000, /* DENALI_PHY_353_DATA */ + 0x00000000, /* DENALI_PHY_354_DATA */ + 0x00000000, /* DENALI_PHY_355_DATA */ + 0x00000000, /* DENALI_PHY_356_DATA */ + 0x00000000, /* DENALI_PHY_357_DATA */ + 0x00000000, /* DENALI_PHY_358_DATA */ + 0x00000000, /* DENALI_PHY_359_DATA */ + 0x00000000, /* DENALI_PHY_360_DATA */ + 0x00000000, /* DENALI_PHY_361_DATA */ + 0x00000000, /* DENALI_PHY_362_DATA */ + 0x00000000, /* DENALI_PHY_363_DATA */ + 0x00000000, /* DENALI_PHY_364_DATA */ + 0x00000000, /* DENALI_PHY_365_DATA */ + 0x00000000, /* DENALI_PHY_366_DATA */ + 0x00000000, /* DENALI_PHY_367_DATA */ + 0x00000000, /* DENALI_PHY_368_DATA */ + 0x00000000, /* DENALI_PHY_369_DATA */ + 0x00000000, /* DENALI_PHY_370_DATA */ + 0x00000000, /* DENALI_PHY_371_DATA */ + 0x00000000, /* DENALI_PHY_372_DATA */ + 0x00000000, /* DENALI_PHY_373_DATA */ + 0x00000000, /* DENALI_PHY_374_DATA */ + 0x00000000, /* DENALI_PHY_375_DATA */ + 0x00000000, /* DENALI_PHY_376_DATA */ + 0x00000000, /* DENALI_PHY_377_DATA */ + 0x00000000, /* DENALI_PHY_378_DATA */ + 0x00000000, /* DENALI_PHY_379_DATA */ + 0x00000000, /* DENALI_PHY_380_DATA */ + 0x00000000, /* DENALI_PHY_381_DATA */ + 0x00000000, /* DENALI_PHY_382_DATA */ + 0x00000000, /* DENALI_PHY_383_DATA */ + 0x76543210, /* DENALI_PHY_384_DATA */ + 0x0004f008, /* DENALI_PHY_385_DATA */ + 0x00020119, /* DENALI_PHY_386_DATA */ + 0x00000000, /* DENALI_PHY_387_DATA */ + 0x00000000, /* DENALI_PHY_388_DATA */ + 0x00010000, /* DENALI_PHY_389_DATA */ + 0x01665555, /* DENALI_PHY_390_DATA */ + 0x03665555, /* DENALI_PHY_391_DATA */ + 0x00010f00, /* DENALI_PHY_392_DATA */ + 0x05010200, /* DENALI_PHY_393_DATA */ + 0x00000002, /* DENALI_PHY_394_DATA */ + 0x00170180, /* DENALI_PHY_395_DATA */ + 0x00cc0201, /* DENALI_PHY_396_DATA */ + 0x00030066, /* DENALI_PHY_397_DATA */ + 0x00000000, /* DENALI_PHY_398_DATA */ + 0x00000000, /* DENALI_PHY_399_DATA */ + 0x00000000, /* DENALI_PHY_400_DATA */ + 0x00000000, /* DENALI_PHY_401_DATA */ + 0x00000000, /* DENALI_PHY_402_DATA */ + 0x00000000, /* DENALI_PHY_403_DATA */ + 0x00000000, /* DENALI_PHY_404_DATA */ + 0x00000000, /* DENALI_PHY_405_DATA */ + 0x04080000, /* DENALI_PHY_406_DATA */ + 0x04080400, /* DENALI_PHY_407_DATA */ + 0x30000000, /* DENALI_PHY_408_DATA */ + 0x0c00c007, /* DENALI_PHY_409_DATA */ + 0x00000100, /* DENALI_PHY_410_DATA */ + 0x00000000, /* DENALI_PHY_411_DATA */ + 0xfd02fe01, /* DENALI_PHY_412_DATA */ + 0xf708fb04, /* DENALI_PHY_413_DATA */ + 0xdf20ef10, /* DENALI_PHY_414_DATA */ + 0x7f80bf40, /* DENALI_PHY_415_DATA */ + 0x0000aaaa, /* DENALI_PHY_416_DATA */ + 0x00000000, /* DENALI_PHY_417_DATA */ + 0x00000000, /* DENALI_PHY_418_DATA */ + 0x00000000, /* DENALI_PHY_419_DATA */ + 0x00000000, /* DENALI_PHY_420_DATA */ + 0x00000000, /* DENALI_PHY_421_DATA */ + 0x00000000, /* DENALI_PHY_422_DATA */ + 0x00000000, /* DENALI_PHY_423_DATA */ + 0x00000000, /* DENALI_PHY_424_DATA */ + 0x00000000, /* DENALI_PHY_425_DATA */ + 0x00000000, /* DENALI_PHY_426_DATA */ + 0x00000000, /* DENALI_PHY_427_DATA */ + 0x00000000, /* DENALI_PHY_428_DATA */ + 0x00000000, /* DENALI_PHY_429_DATA */ + 0x00000000, /* DENALI_PHY_430_DATA */ + 0x00000000, /* DENALI_PHY_431_DATA */ + 0x00000000, /* DENALI_PHY_432_DATA */ + 0x00000000, /* DENALI_PHY_433_DATA */ + 0x00000000, /* DENALI_PHY_434_DATA */ + 0x00000000, /* DENALI_PHY_435_DATA */ + 0x00200000, /* DENALI_PHY_436_DATA */ + 0x00000000, /* DENALI_PHY_437_DATA */ + 0x00000000, /* DENALI_PHY_438_DATA */ + 0x00000000, /* DENALI_PHY_439_DATA */ + 0x00000000, /* DENALI_PHY_440_DATA */ + 0x00000000, /* DENALI_PHY_441_DATA */ + 0x00000000, /* DENALI_PHY_442_DATA */ + 0x02800280, /* DENALI_PHY_443_DATA */ + 0x02800280, /* DENALI_PHY_444_DATA */ + 0x02800280, /* DENALI_PHY_445_DATA */ + 0x02800280, /* DENALI_PHY_446_DATA */ + 0x00000280, /* DENALI_PHY_447_DATA */ + 0x00000000, /* DENALI_PHY_448_DATA */ + 0x00000000, /* DENALI_PHY_449_DATA */ + 0x00000000, /* DENALI_PHY_450_DATA */ + 0x00000000, /* DENALI_PHY_451_DATA */ + 0x00800000, /* DENALI_PHY_452_DATA */ + 0x00800080, /* DENALI_PHY_453_DATA */ + 0x00800080, /* DENALI_PHY_454_DATA */ + 0x00800080, /* DENALI_PHY_455_DATA */ + 0x00800080, /* DENALI_PHY_456_DATA */ + 0x00800080, /* DENALI_PHY_457_DATA */ + 0x00800080, /* DENALI_PHY_458_DATA */ + 0x00800080, /* DENALI_PHY_459_DATA */ + 0x00800080, /* DENALI_PHY_460_DATA */ + 0x01190080, /* DENALI_PHY_461_DATA */ + 0x00000002, /* DENALI_PHY_462_DATA */ + 0x00000000, /* DENALI_PHY_463_DATA */ + 0x00000000, /* DENALI_PHY_464_DATA */ + 0x00000200, /* DENALI_PHY_465_DATA */ + 0x00000000, /* DENALI_PHY_466_DATA */ + 0x51315152, /* DENALI_PHY_467_DATA */ + 0xc0013150, /* DENALI_PHY_468_DATA */ + 0x020000c0, /* DENALI_PHY_469_DATA */ + 0x00100001, /* DENALI_PHY_470_DATA */ + 0x07054204, /* DENALI_PHY_471_DATA */ + 0x000f0c18, /* DENALI_PHY_472_DATA */ + 0x01000140, /* DENALI_PHY_473_DATA */ + 0x00000c10, /* DENALI_PHY_474_DATA */ + 0x00000000, /* DENALI_PHY_475_DATA */ + 0x00000000, /* DENALI_PHY_476_DATA */ + 0x00000000, /* DENALI_PHY_477_DATA */ + 0x00000000, /* DENALI_PHY_478_DATA */ + 0x00000000, /* DENALI_PHY_479_DATA */ + 0x00000000, /* DENALI_PHY_480_DATA */ + 0x00000000, /* DENALI_PHY_481_DATA */ + 0x00000000, /* DENALI_PHY_482_DATA */ + 0x00000000, /* DENALI_PHY_483_DATA */ + 0x00000000, /* DENALI_PHY_484_DATA */ + 0x00000000, /* DENALI_PHY_485_DATA */ + 0x00000000, /* DENALI_PHY_486_DATA */ + 0x00000000, /* DENALI_PHY_487_DATA */ + 0x00000000, /* DENALI_PHY_488_DATA */ + 0x00000000, /* DENALI_PHY_489_DATA */ + 0x00000000, /* DENALI_PHY_490_DATA */ + 0x00000000, /* DENALI_PHY_491_DATA */ + 0x00000000, /* DENALI_PHY_492_DATA */ + 0x00000000, /* DENALI_PHY_493_DATA */ + 0x00000000, /* DENALI_PHY_494_DATA */ + 0x00000000, /* DENALI_PHY_495_DATA */ + 0x00000000, /* DENALI_PHY_496_DATA */ + 0x00000000, /* DENALI_PHY_497_DATA */ + 0x00000000, /* DENALI_PHY_498_DATA */ + 0x00000000, /* DENALI_PHY_499_DATA */ + 0x00000000, /* DENALI_PHY_500_DATA */ + 0x00000000, /* DENALI_PHY_501_DATA */ + 0x00000000, /* DENALI_PHY_502_DATA */ + 0x00000000, /* DENALI_PHY_503_DATA */ + 0x00000000, /* DENALI_PHY_504_DATA */ + 0x00000000, /* DENALI_PHY_505_DATA */ + 0x00000000, /* DENALI_PHY_506_DATA */ + 0x00000000, /* DENALI_PHY_507_DATA */ + 0x00000000, /* DENALI_PHY_508_DATA */ + 0x00000000, /* DENALI_PHY_509_DATA */ + 0x00000000, /* DENALI_PHY_510_DATA */ + 0x00000000, /* DENALI_PHY_511_DATA */ + 0x00000000, /* DENALI_PHY_512_DATA */ + 0x00000000, /* DENALI_PHY_513_DATA */ + 0x00000000, /* DENALI_PHY_514_DATA */ + 0x00000000, /* DENALI_PHY_515_DATA */ + 0x00000000, /* DENALI_PHY_516_DATA */ + 0x00000000, /* DENALI_PHY_517_DATA */ + 0x00000000, /* DENALI_PHY_518_DATA */ + 0x00000002, /* DENALI_PHY_519_DATA */ + 0x00000000, /* DENALI_PHY_520_DATA */ + 0x00000000, /* DENALI_PHY_521_DATA */ + 0x00000000, /* DENALI_PHY_522_DATA */ + 0x00400320, /* DENALI_PHY_523_DATA */ + 0x00000040, /* DENALI_PHY_524_DATA */ + 0x00dcba98, /* DENALI_PHY_525_DATA */ + 0x00000000, /* DENALI_PHY_526_DATA */ + 0x00dcba98, /* DENALI_PHY_527_DATA */ + 0x01000000, /* DENALI_PHY_528_DATA */ + 0x00020003, /* DENALI_PHY_529_DATA */ + 0x00000000, /* DENALI_PHY_530_DATA */ + 0x00000000, /* DENALI_PHY_531_DATA */ + 0x00000000, /* DENALI_PHY_532_DATA */ + 0x0000002a, /* DENALI_PHY_533_DATA */ + 0x00000015, /* DENALI_PHY_534_DATA */ + 0x00000015, /* DENALI_PHY_535_DATA */ + 0x0000002a, /* DENALI_PHY_536_DATA */ + 0x00000033, /* DENALI_PHY_537_DATA */ + 0x0000000c, /* DENALI_PHY_538_DATA */ + 0x0000000c, /* DENALI_PHY_539_DATA */ + 0x00000033, /* DENALI_PHY_540_DATA */ + 0x0a418820, /* DENALI_PHY_541_DATA */ + 0x003f0000, /* DENALI_PHY_542_DATA */ + 0x0000003f, /* DENALI_PHY_543_DATA */ + 0x00030055, /* DENALI_PHY_544_DATA */ + 0x03000300, /* DENALI_PHY_545_DATA */ + 0x03000300, /* DENALI_PHY_546_DATA */ + 0x00000300, /* DENALI_PHY_547_DATA */ + 0x42080010, /* DENALI_PHY_548_DATA */ + 0x00000003, /* DENALI_PHY_549_DATA */ + 0x00000000, /* DENALI_PHY_550_DATA */ + 0x00000000, /* DENALI_PHY_551_DATA */ + 0x00000000, /* DENALI_PHY_552_DATA */ + 0x00000000, /* DENALI_PHY_553_DATA */ + 0x00000000, /* DENALI_PHY_554_DATA */ + 0x00000000, /* DENALI_PHY_555_DATA */ + 0x00000000, /* DENALI_PHY_556_DATA */ + 0x00000000, /* DENALI_PHY_557_DATA */ + 0x00000000, /* DENALI_PHY_558_DATA */ + 0x00000000, /* DENALI_PHY_559_DATA */ + 0x00000000, /* DENALI_PHY_560_DATA */ + 0x00000000, /* DENALI_PHY_561_DATA */ + 0x00000000, /* DENALI_PHY_562_DATA */ + 0x00000000, /* DENALI_PHY_563_DATA */ + 0x00000000, /* DENALI_PHY_564_DATA */ + 0x00000000, /* DENALI_PHY_565_DATA */ + 0x00000000, /* DENALI_PHY_566_DATA */ + 0x00000000, /* DENALI_PHY_567_DATA */ + 0x00000000, /* DENALI_PHY_568_DATA */ + 0x00000000, /* DENALI_PHY_569_DATA */ + 0x00000000, /* DENALI_PHY_570_DATA */ + 0x00000000, /* DENALI_PHY_571_DATA */ + 0x00000000, /* DENALI_PHY_572_DATA */ + 0x00000000, /* DENALI_PHY_573_DATA */ + 0x00000000, /* DENALI_PHY_574_DATA */ + 0x00000000, /* DENALI_PHY_575_DATA */ + 0x00000000, /* DENALI_PHY_576_DATA */ + 0x00000000, /* DENALI_PHY_577_DATA */ + 0x00000000, /* DENALI_PHY_578_DATA */ + 0x00000000, /* DENALI_PHY_579_DATA */ + 0x00000000, /* DENALI_PHY_580_DATA */ + 0x00000000, /* DENALI_PHY_581_DATA */ + 0x00000000, /* DENALI_PHY_582_DATA */ + 0x00000000, /* DENALI_PHY_583_DATA */ + 0x00000000, /* DENALI_PHY_584_DATA */ + 0x00000000, /* DENALI_PHY_585_DATA */ + 0x00000000, /* DENALI_PHY_586_DATA */ + 0x00000000, /* DENALI_PHY_587_DATA */ + 0x00000000, /* DENALI_PHY_588_DATA */ + 0x00000000, /* DENALI_PHY_589_DATA */ + 0x00000000, /* DENALI_PHY_590_DATA */ + 0x00000000, /* DENALI_PHY_591_DATA */ + 0x00000000, /* DENALI_PHY_592_DATA */ + 0x00000000, /* DENALI_PHY_593_DATA */ + 0x00000000, /* DENALI_PHY_594_DATA */ + 0x00000000, /* DENALI_PHY_595_DATA */ + 0x00000000, /* DENALI_PHY_596_DATA */ + 0x00000000, /* DENALI_PHY_597_DATA */ + 0x00000000, /* DENALI_PHY_598_DATA */ + 0x00000000, /* DENALI_PHY_599_DATA */ + 0x00000000, /* DENALI_PHY_600_DATA */ + 0x00000000, /* DENALI_PHY_601_DATA */ + 0x00000000, /* DENALI_PHY_602_DATA */ + 0x00000000, /* DENALI_PHY_603_DATA */ + 0x00000000, /* DENALI_PHY_604_DATA */ + 0x00000000, /* DENALI_PHY_605_DATA */ + 0x00000000, /* DENALI_PHY_606_DATA */ + 0x00000000, /* DENALI_PHY_607_DATA */ + 0x00000000, /* DENALI_PHY_608_DATA */ + 0x00000000, /* DENALI_PHY_609_DATA */ + 0x00000000, /* DENALI_PHY_610_DATA */ + 0x00000000, /* DENALI_PHY_611_DATA */ + 0x00000000, /* DENALI_PHY_612_DATA */ + 0x00000000, /* DENALI_PHY_613_DATA */ + 0x00000000, /* DENALI_PHY_614_DATA */ + 0x00000000, /* DENALI_PHY_615_DATA */ + 0x00000000, /* DENALI_PHY_616_DATA */ + 0x00000000, /* DENALI_PHY_617_DATA */ + 0x00000000, /* DENALI_PHY_618_DATA */ + 0x00000000, /* DENALI_PHY_619_DATA */ + 0x00000000, /* DENALI_PHY_620_DATA */ + 0x00000000, /* DENALI_PHY_621_DATA */ + 0x00000000, /* DENALI_PHY_622_DATA */ + 0x00000000, /* DENALI_PHY_623_DATA */ + 0x00000000, /* DENALI_PHY_624_DATA */ + 0x00000000, /* DENALI_PHY_625_DATA */ + 0x00000000, /* DENALI_PHY_626_DATA */ + 0x00000000, /* DENALI_PHY_627_DATA */ + 0x00000000, /* DENALI_PHY_628_DATA */ + 0x00000000, /* DENALI_PHY_629_DATA */ + 0x00000000, /* DENALI_PHY_630_DATA */ + 0x00000000, /* DENALI_PHY_631_DATA */ + 0x00000000, /* DENALI_PHY_632_DATA */ + 0x00000000, /* DENALI_PHY_633_DATA */ + 0x00000000, /* DENALI_PHY_634_DATA */ + 0x00000000, /* DENALI_PHY_635_DATA */ + 0x00000000, /* DENALI_PHY_636_DATA */ + 0x00000000, /* DENALI_PHY_637_DATA */ + 0x00000000, /* DENALI_PHY_638_DATA */ + 0x00000000, /* DENALI_PHY_639_DATA */ + 0x00000000, /* DENALI_PHY_640_DATA */ + 0x00000000, /* DENALI_PHY_641_DATA */ + 0x00000000, /* DENALI_PHY_642_DATA */ + 0x00000000, /* DENALI_PHY_643_DATA */ + 0x00000000, /* DENALI_PHY_644_DATA */ + 0x00000000, /* DENALI_PHY_645_DATA */ + 0x00000000, /* DENALI_PHY_646_DATA */ + 0x00000002, /* DENALI_PHY_647_DATA */ + 0x00000000, /* DENALI_PHY_648_DATA */ + 0x00000000, /* DENALI_PHY_649_DATA */ + 0x00000000, /* DENALI_PHY_650_DATA */ + 0x00400320, /* DENALI_PHY_651_DATA */ + 0x00000040, /* DENALI_PHY_652_DATA */ + 0x00000000, /* DENALI_PHY_653_DATA */ + 0x00000000, /* DENALI_PHY_654_DATA */ + 0x00000000, /* DENALI_PHY_655_DATA */ + 0x01000000, /* DENALI_PHY_656_DATA */ + 0x00020003, /* DENALI_PHY_657_DATA */ + 0x00000000, /* DENALI_PHY_658_DATA */ + 0x00000000, /* DENALI_PHY_659_DATA */ + 0x00000000, /* DENALI_PHY_660_DATA */ + 0x0000002a, /* DENALI_PHY_661_DATA */ + 0x00000015, /* DENALI_PHY_662_DATA */ + 0x00000015, /* DENALI_PHY_663_DATA */ + 0x0000002a, /* DENALI_PHY_664_DATA */ + 0x00000033, /* DENALI_PHY_665_DATA */ + 0x0000000c, /* DENALI_PHY_666_DATA */ + 0x0000000c, /* DENALI_PHY_667_DATA */ + 0x00000033, /* DENALI_PHY_668_DATA */ + 0x00000000, /* DENALI_PHY_669_DATA */ + 0x00000000, /* DENALI_PHY_670_DATA */ + 0x00000000, /* DENALI_PHY_671_DATA */ + 0x00030055, /* DENALI_PHY_672_DATA */ + 0x03000300, /* DENALI_PHY_673_DATA */ + 0x03000300, /* DENALI_PHY_674_DATA */ + 0x00000300, /* DENALI_PHY_675_DATA */ + 0x42080010, /* DENALI_PHY_676_DATA */ + 0x00000003, /* DENALI_PHY_677_DATA */ + 0x00000000, /* DENALI_PHY_678_DATA */ + 0x00000000, /* DENALI_PHY_679_DATA */ + 0x00000000, /* DENALI_PHY_680_DATA */ + 0x00000000, /* DENALI_PHY_681_DATA */ + 0x00000000, /* DENALI_PHY_682_DATA */ + 0x00000000, /* DENALI_PHY_683_DATA */ + 0x00000000, /* DENALI_PHY_684_DATA */ + 0x00000000, /* DENALI_PHY_685_DATA */ + 0x00000000, /* DENALI_PHY_686_DATA */ + 0x00000000, /* DENALI_PHY_687_DATA */ + 0x00000000, /* DENALI_PHY_688_DATA */ + 0x00000000, /* DENALI_PHY_689_DATA */ + 0x00000000, /* DENALI_PHY_690_DATA */ + 0x00000000, /* DENALI_PHY_691_DATA */ + 0x00000000, /* DENALI_PHY_692_DATA */ + 0x00000000, /* DENALI_PHY_693_DATA */ + 0x00000000, /* DENALI_PHY_694_DATA */ + 0x00000000, /* DENALI_PHY_695_DATA */ + 0x00000000, /* DENALI_PHY_696_DATA */ + 0x00000000, /* DENALI_PHY_697_DATA */ + 0x00000000, /* DENALI_PHY_698_DATA */ + 0x00000000, /* DENALI_PHY_699_DATA */ + 0x00000000, /* DENALI_PHY_700_DATA */ + 0x00000000, /* DENALI_PHY_701_DATA */ + 0x00000000, /* DENALI_PHY_702_DATA */ + 0x00000000, /* DENALI_PHY_703_DATA */ + 0x00000000, /* DENALI_PHY_704_DATA */ + 0x00000000, /* DENALI_PHY_705_DATA */ + 0x00000000, /* DENALI_PHY_706_DATA */ + 0x00000000, /* DENALI_PHY_707_DATA */ + 0x00000000, /* DENALI_PHY_708_DATA */ + 0x00000000, /* DENALI_PHY_709_DATA */ + 0x00000000, /* DENALI_PHY_710_DATA */ + 0x00000000, /* DENALI_PHY_711_DATA */ + 0x00000000, /* DENALI_PHY_712_DATA */ + 0x00000000, /* DENALI_PHY_713_DATA */ + 0x00000000, /* DENALI_PHY_714_DATA */ + 0x00000000, /* DENALI_PHY_715_DATA */ + 0x00000000, /* DENALI_PHY_716_DATA */ + 0x00000000, /* DENALI_PHY_717_DATA */ + 0x00000000, /* DENALI_PHY_718_DATA */ + 0x00000000, /* DENALI_PHY_719_DATA */ + 0x00000000, /* DENALI_PHY_720_DATA */ + 0x00000000, /* DENALI_PHY_721_DATA */ + 0x00000000, /* DENALI_PHY_722_DATA */ + 0x00000000, /* DENALI_PHY_723_DATA */ + 0x00000000, /* DENALI_PHY_724_DATA */ + 0x00000000, /* DENALI_PHY_725_DATA */ + 0x00000000, /* DENALI_PHY_726_DATA */ + 0x00000000, /* DENALI_PHY_727_DATA */ + 0x00000000, /* DENALI_PHY_728_DATA */ + 0x00000000, /* DENALI_PHY_729_DATA */ + 0x00000000, /* DENALI_PHY_730_DATA */ + 0x00000000, /* DENALI_PHY_731_DATA */ + 0x00000000, /* DENALI_PHY_732_DATA */ + 0x00000000, /* DENALI_PHY_733_DATA */ + 0x00000000, /* DENALI_PHY_734_DATA */ + 0x00000000, /* DENALI_PHY_735_DATA */ + 0x00000000, /* DENALI_PHY_736_DATA */ + 0x00000000, /* DENALI_PHY_737_DATA */ + 0x00000000, /* DENALI_PHY_738_DATA */ + 0x00000000, /* DENALI_PHY_739_DATA */ + 0x00000000, /* DENALI_PHY_740_DATA */ + 0x00000000, /* DENALI_PHY_741_DATA */ + 0x00000000, /* DENALI_PHY_742_DATA */ + 0x00000000, /* DENALI_PHY_743_DATA */ + 0x00000000, /* DENALI_PHY_744_DATA */ + 0x00000000, /* DENALI_PHY_745_DATA */ + 0x00000000, /* DENALI_PHY_746_DATA */ + 0x00000000, /* DENALI_PHY_747_DATA */ + 0x00000000, /* DENALI_PHY_748_DATA */ + 0x00000000, /* DENALI_PHY_749_DATA */ + 0x00000000, /* DENALI_PHY_750_DATA */ + 0x00000000, /* DENALI_PHY_751_DATA */ + 0x00000000, /* DENALI_PHY_752_DATA */ + 0x00000000, /* DENALI_PHY_753_DATA */ + 0x00000000, /* DENALI_PHY_754_DATA */ + 0x00000000, /* DENALI_PHY_755_DATA */ + 0x00000000, /* DENALI_PHY_756_DATA */ + 0x00000000, /* DENALI_PHY_757_DATA */ + 0x00000000, /* DENALI_PHY_758_DATA */ + 0x00000000, /* DENALI_PHY_759_DATA */ + 0x00000000, /* DENALI_PHY_760_DATA */ + 0x00000000, /* DENALI_PHY_761_DATA */ + 0x00000000, /* DENALI_PHY_762_DATA */ + 0x00000000, /* DENALI_PHY_763_DATA */ + 0x00000000, /* DENALI_PHY_764_DATA */ + 0x00000000, /* DENALI_PHY_765_DATA */ + 0x00000000, /* DENALI_PHY_766_DATA */ + 0x00000000, /* DENALI_PHY_767_DATA */ + 0x00000000, /* DENALI_PHY_768_DATA */ + 0x00000000, /* DENALI_PHY_769_DATA */ + 0x00000000, /* DENALI_PHY_770_DATA */ + 0x00000000, /* DENALI_PHY_771_DATA */ + 0x00000000, /* DENALI_PHY_772_DATA */ + 0x00000000, /* DENALI_PHY_773_DATA */ + 0x00000000, /* DENALI_PHY_774_DATA */ + 0x00000002, /* DENALI_PHY_775_DATA */ + 0x00000000, /* DENALI_PHY_776_DATA */ + 0x00000000, /* DENALI_PHY_777_DATA */ + 0x00000000, /* DENALI_PHY_778_DATA */ + 0x00400320, /* DENALI_PHY_779_DATA */ + 0x00000040, /* DENALI_PHY_780_DATA */ + 0x00000000, /* DENALI_PHY_781_DATA */ + 0x00000000, /* DENALI_PHY_782_DATA */ + 0x00000000, /* DENALI_PHY_783_DATA */ + 0x01000000, /* DENALI_PHY_784_DATA */ + 0x00020003, /* DENALI_PHY_785_DATA */ + 0x00000000, /* DENALI_PHY_786_DATA */ + 0x00000000, /* DENALI_PHY_787_DATA */ + 0x00000000, /* DENALI_PHY_788_DATA */ + 0x0000002a, /* DENALI_PHY_789_DATA */ + 0x00000015, /* DENALI_PHY_790_DATA */ + 0x00000015, /* DENALI_PHY_791_DATA */ + 0x0000002a, /* DENALI_PHY_792_DATA */ + 0x00000033, /* DENALI_PHY_793_DATA */ + 0x0000000c, /* DENALI_PHY_794_DATA */ + 0x0000000c, /* DENALI_PHY_795_DATA */ + 0x00000033, /* DENALI_PHY_796_DATA */ + 0x1ee6b16a, /* DENALI_PHY_797_DATA */ + 0x10000000, /* DENALI_PHY_798_DATA */ + 0x00000000, /* DENALI_PHY_799_DATA */ + 0x00030055, /* DENALI_PHY_800_DATA */ + 0x03000300, /* DENALI_PHY_801_DATA */ + 0x03000300, /* DENALI_PHY_802_DATA */ + 0x00000300, /* DENALI_PHY_803_DATA */ + 0x42080010, /* DENALI_PHY_804_DATA */ + 0x00000003, /* DENALI_PHY_805_DATA */ + 0x00000000, /* DENALI_PHY_806_DATA */ + 0x00000000, /* DENALI_PHY_807_DATA */ + 0x00000000, /* DENALI_PHY_808_DATA */ + 0x00000000, /* DENALI_PHY_809_DATA */ + 0x00000000, /* DENALI_PHY_810_DATA */ + 0x00000000, /* DENALI_PHY_811_DATA */ + 0x00000000, /* DENALI_PHY_812_DATA */ + 0x00000000, /* DENALI_PHY_813_DATA */ + 0x00000000, /* DENALI_PHY_814_DATA */ + 0x00000000, /* DENALI_PHY_815_DATA */ + 0x00000000, /* DENALI_PHY_816_DATA */ + 0x00000000, /* DENALI_PHY_817_DATA */ + 0x00000000, /* DENALI_PHY_818_DATA */ + 0x00000000, /* DENALI_PHY_819_DATA */ + 0x00000000, /* DENALI_PHY_820_DATA */ + 0x00000000, /* DENALI_PHY_821_DATA */ + 0x00000000, /* DENALI_PHY_822_DATA */ + 0x00000000, /* DENALI_PHY_823_DATA */ + 0x00000000, /* DENALI_PHY_824_DATA */ + 0x00000000, /* DENALI_PHY_825_DATA */ + 0x00000000, /* DENALI_PHY_826_DATA */ + 0x00000000, /* DENALI_PHY_827_DATA */ + 0x00000000, /* DENALI_PHY_828_DATA */ + 0x00000000, /* DENALI_PHY_829_DATA */ + 0x00000000, /* DENALI_PHY_830_DATA */ + 0x00000000, /* DENALI_PHY_831_DATA */ + 0x00000000, /* DENALI_PHY_832_DATA */ + 0x00000000, /* DENALI_PHY_833_DATA */ + 0x00000000, /* DENALI_PHY_834_DATA */ + 0x00000000, /* DENALI_PHY_835_DATA */ + 0x00000000, /* DENALI_PHY_836_DATA */ + 0x00000000, /* DENALI_PHY_837_DATA */ + 0x00000000, /* DENALI_PHY_838_DATA */ + 0x00000000, /* DENALI_PHY_839_DATA */ + 0x00000000, /* DENALI_PHY_840_DATA */ + 0x00000000, /* DENALI_PHY_841_DATA */ + 0x00000000, /* DENALI_PHY_842_DATA */ + 0x00000000, /* DENALI_PHY_843_DATA */ + 0x00000000, /* DENALI_PHY_844_DATA */ + 0x00000000, /* DENALI_PHY_845_DATA */ + 0x00000000, /* DENALI_PHY_846_DATA */ + 0x00000000, /* DENALI_PHY_847_DATA */ + 0x00000000, /* DENALI_PHY_848_DATA */ + 0x00000000, /* DENALI_PHY_849_DATA */ + 0x00000000, /* DENALI_PHY_850_DATA */ + 0x00000000, /* DENALI_PHY_851_DATA */ + 0x00000000, /* DENALI_PHY_852_DATA */ + 0x00000000, /* DENALI_PHY_853_DATA */ + 0x00000000, /* DENALI_PHY_854_DATA */ + 0x00000000, /* DENALI_PHY_855_DATA */ + 0x00000000, /* DENALI_PHY_856_DATA */ + 0x00000000, /* DENALI_PHY_857_DATA */ + 0x00000000, /* DENALI_PHY_858_DATA */ + 0x00000000, /* DENALI_PHY_859_DATA */ + 0x00000000, /* DENALI_PHY_860_DATA */ + 0x00000000, /* DENALI_PHY_861_DATA */ + 0x00000000, /* DENALI_PHY_862_DATA */ + 0x00000000, /* DENALI_PHY_863_DATA */ + 0x00000000, /* DENALI_PHY_864_DATA */ + 0x00000000, /* DENALI_PHY_865_DATA */ + 0x00000000, /* DENALI_PHY_866_DATA */ + 0x00000000, /* DENALI_PHY_867_DATA */ + 0x00000000, /* DENALI_PHY_868_DATA */ + 0x00000000, /* DENALI_PHY_869_DATA */ + 0x00000000, /* DENALI_PHY_870_DATA */ + 0x00000000, /* DENALI_PHY_871_DATA */ + 0x00000000, /* DENALI_PHY_872_DATA */ + 0x00000000, /* DENALI_PHY_873_DATA */ + 0x00000000, /* DENALI_PHY_874_DATA */ + 0x00000000, /* DENALI_PHY_875_DATA */ + 0x00000000, /* DENALI_PHY_876_DATA */ + 0x00000000, /* DENALI_PHY_877_DATA */ + 0x00000000, /* DENALI_PHY_878_DATA */ + 0x00000000, /* DENALI_PHY_879_DATA */ + 0x00000000, /* DENALI_PHY_880_DATA */ + 0x00000000, /* DENALI_PHY_881_DATA */ + 0x00000000, /* DENALI_PHY_882_DATA */ + 0x00000000, /* DENALI_PHY_883_DATA */ + 0x00000000, /* DENALI_PHY_884_DATA */ + 0x00000000, /* DENALI_PHY_885_DATA */ + 0x00000000, /* DENALI_PHY_886_DATA */ + 0x00000000, /* DENALI_PHY_887_DATA */ + 0x00000000, /* DENALI_PHY_888_DATA */ + 0x00000000, /* DENALI_PHY_889_DATA */ + 0x00000000, /* DENALI_PHY_890_DATA */ + 0x00000000, /* DENALI_PHY_891_DATA */ + 0x00000000, /* DENALI_PHY_892_DATA */ + 0x00000000, /* DENALI_PHY_893_DATA */ + 0x00000000, /* DENALI_PHY_894_DATA */ + 0x00000000, /* DENALI_PHY_895_DATA */ + 0x00000000, /* DENALI_PHY_896_DATA */ + 0x00000000, /* DENALI_PHY_897_DATA */ + 0x00000005, /* DENALI_PHY_898_DATA */ + 0x04000f01, /* DENALI_PHY_899_DATA */ + 0x00020040, /* DENALI_PHY_900_DATA */ + 0x00020055, /* DENALI_PHY_901_DATA */ + 0x00000000, /* DENALI_PHY_902_DATA */ + 0x00000000, /* DENALI_PHY_903_DATA */ + 0x00000000, /* DENALI_PHY_904_DATA */ + 0x00000050, /* DENALI_PHY_905_DATA */ + 0x00000000, /* DENALI_PHY_906_DATA */ + 0x01010100, /* DENALI_PHY_907_DATA */ + 0x00000600, /* DENALI_PHY_908_DATA */ + 0x00000000, /* DENALI_PHY_909_DATA */ + 0x00006400, /* DENALI_PHY_910_DATA */ + 0x01221102, /* DENALI_PHY_911_DATA */ + 0x00000000, /* DENALI_PHY_912_DATA */ + 0x000d1f00, /* DENALI_PHY_913_DATA */ + 0x0d1f0d1f, /* DENALI_PHY_914_DATA */ + 0x0d1f0d1f, /* DENALI_PHY_915_DATA */ + 0x00030003, /* DENALI_PHY_916_DATA */ + 0x03000300, /* DENALI_PHY_917_DATA */ + 0x00000300, /* DENALI_PHY_918_DATA */ + 0x01221102, /* DENALI_PHY_919_DATA */ + 0x00000000, /* DENALI_PHY_920_DATA */ + 0x00000000, /* DENALI_PHY_921_DATA */ + 0x03020000, /* DENALI_PHY_922_DATA */ + 0x00000001, /* DENALI_PHY_923_DATA */ + 0x00000411, /* DENALI_PHY_924_DATA */ + 0x00000411, /* DENALI_PHY_925_DATA */ + 0x00000040, /* DENALI_PHY_926_DATA */ + 0x00000040, /* DENALI_PHY_927_DATA */ + 0x00000411, /* DENALI_PHY_928_DATA */ + 0x00000411, /* DENALI_PHY_929_DATA */ + 0x00004410, /* DENALI_PHY_930_DATA */ + 0x00004410, /* DENALI_PHY_931_DATA */ + 0x00004410, /* DENALI_PHY_932_DATA */ + 0x00004410, /* DENALI_PHY_933_DATA */ + 0x00004410, /* DENALI_PHY_934_DATA */ + 0x00000411, /* DENALI_PHY_935_DATA */ + 0x00004410, /* DENALI_PHY_936_DATA */ + 0x00000411, /* DENALI_PHY_937_DATA */ + 0x00004410, /* DENALI_PHY_938_DATA */ + 0x00000411, /* DENALI_PHY_939_DATA */ + 0x00004410, /* DENALI_PHY_940_DATA */ + 0x00000000, /* DENALI_PHY_941_DATA */ + 0x00000000, /* DENALI_PHY_942_DATA */ + 0x00000000, /* DENALI_PHY_943_DATA */ + 0x64000000, /* DENALI_PHY_944_DATA */ + 0x00000000, /* DENALI_PHY_945_DATA */ + 0x00000000, /* DENALI_PHY_946_DATA */ + 0x00000508, /* DENALI_PHY_947_DATA */ + 0x00000000, /* DENALI_PHY_948_DATA */ + 0x00000000, /* DENALI_PHY_949_DATA */ + 0x00000000, /* DENALI_PHY_950_DATA */ + 0x00000000, /* DENALI_PHY_951_DATA */ + 0x00000000, /* DENALI_PHY_952_DATA */ + 0x00000000, /* DENALI_PHY_953_DATA */ + 0xe4000000, /* DENALI_PHY_954_DATA */ + 0x00000000, /* DENALI_PHY_955_DATA */ + 0x00000000, /* DENALI_PHY_956_DATA */ + 0x01010000, /* DENALI_PHY_957_DATA */ + 0x00000000 /* DENALI_PHY_958_DATA */ + } + }, +},
DDR set rate can be even required for lpddr4 and we need to keep the lpddr4 code to compile only for relevant boards which do support lpddr4.
For this requirement, and for code readability handle data training via sdram_rk3399_ops with .set_rate and same will update in future while supporting lpddr4 code.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/ram/rockchip/sdram_rk3399.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index cdae6b9e67..9f5438a0bc 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -74,6 +74,8 @@ struct dram_info { struct sdram_rk3399_ops { int (*data_training)(struct dram_info *dram, u32 channel, u8 rank, struct rk3399_sdram_params *sdram); + int (*set_rate)(struct dram_info *dram, + const struct rk3399_sdram_params *params); };
#if defined(CONFIG_TPL_BUILD) || \ @@ -948,6 +950,7 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, return 0; }
+#if !defined(CONFIG_RAM_RK3399_LPDDR4) static void select_per_cs_training_index(const struct chan_info *chan, u32 rank) { @@ -1368,6 +1371,7 @@ static int data_training(struct dram_info *dram, u32 channel,
return 0; } +#endif
static void set_ddrconfig(const struct chan_info *chan, const struct rk3399_sdram_params *params, @@ -1488,7 +1492,6 @@ static int default_data_training(struct dram_info *dram, u32 channel, u8 rank,
return data_training(dram, channel, params, training_flag); } -#endif
static int switch_to_phy_index1(struct dram_info *dram, const struct rk3399_sdram_params *params) @@ -1535,7 +1538,8 @@ static int switch_to_phy_index1(struct dram_info *dram, return 0; }
-#if defined(CONFIG_RAM_RK3399_LPDDR4) +#else + static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) { return ((readl(&pmusgrf->soc_con4) >> 10) & 0x1F); @@ -1939,7 +1943,7 @@ static int sdram_init(struct dram_info *dram,
params->base.stride = calculate_stride(params); dram_all_config(dram, params); - switch_to_phy_index1(dram, params); + dram->ops->set_rate(dram, params);
debug("Finish SDRAM initialization...\n"); return 0; @@ -1987,6 +1991,7 @@ static int conv_of_platdata(struct udevice *dev) static const struct sdram_rk3399_ops rk3399_ops = { #if !defined(CONFIG_RAM_RK3399_LPDDR4) .data_training = default_data_training, + .set_rate = switch_to_phy_index1, #else .data_training = lpddr4_mr_detect, #endif
Unlike rest of dram type chips, LPDDR4 initialization start with at board selected frequency (say 50MHz) and then it switches into 400MHz and 800MHz simultaneously to make the proper sequence work on each channel with associated training.
Here is sameple log about LPDDR4-100 init sequence in Rockpro64:
Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB 256B stride channel 0 training pass channel 1 training pass change freq to 400 MHz 0, 1 channel 0 training pass channel 1 training pass change freq to 800 MHz 1, 0
This patch add support to this init sequence via lpddr4 set rate by taking sdram timing parameters from 400, 800 .inc files.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 404 +++++++++++++++++++++++++++- 1 file changed, 392 insertions(+), 12 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 9f5438a0bc..07759e8956 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -16,6 +16,7 @@ #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk3399.h> #include <asm/arch-rockchip/grf_rk3399.h> +#include <asm/arch-rockchip/pmu_rk3399.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/sdram_common.h> #include <asm/arch-rockchip/sdram_rk3399.h> @@ -62,6 +63,7 @@ struct dram_info { struct clk ddr_clk; struct rk3399_cru *cru; struct rk3399_grf_regs *grf; + struct rk3399_pmu_regs *pmu; struct rk3399_pmucru *pmucru; struct rk3399_pmusgrf_regs *pmusgrf; struct rk3399_ddr_cic_regs *cic; @@ -75,7 +77,7 @@ struct sdram_rk3399_ops { int (*data_training)(struct dram_info *dram, u32 channel, u8 rank, struct rk3399_sdram_params *sdram); int (*set_rate)(struct dram_info *dram, - const struct rk3399_sdram_params *params); + struct rk3399_sdram_params *params); };
#if defined(CONFIG_TPL_BUILD) || \ @@ -221,6 +223,18 @@ lpddr4_get_io_settings(const struct rk3399_sdram_params *params, u32 mr5) return io; }
+static void *get_denali_phy(const struct chan_info *chan, + struct rk3399_sdram_params *params, bool reg) +{ + return reg ? &chan->publ->denali_phy : ¶ms->phy_regs.denali_phy; +} + +static void *get_denali_ctl(const struct chan_info *chan, + struct rk3399_sdram_params *params, bool reg) +{ + return reg ? &chan->pctl->denali_ctl : ¶ms->pctl_regs.denali_ctl; +} + static void *get_ddrc0_con(struct dram_info *dram, u8 channel) { return (channel == 0) ? &dram->grf->ddrc0_con0 : &dram->grf->ddrc0_con1; @@ -574,10 +588,11 @@ static int phy_io_config(const struct chan_info *chan, }
static void set_ds_odt(const struct chan_info *chan, - const struct rk3399_sdram_params *params, u32 mr5) + struct rk3399_sdram_params *params, + bool ctl_phy_reg, u32 mr5) { - u32 *denali_phy = chan->publ->denali_phy; - u32 *denali_ctl = chan->pctl->denali_ctl; + u32 *denali_phy = get_denali_phy(chan, params, ctl_phy_reg); + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); u32 tsel_idle_en, tsel_wr_en, tsel_rd_en; u32 tsel_idle_select_p, tsel_rd_select_p; u32 tsel_idle_select_n, tsel_rd_select_n; @@ -735,7 +750,8 @@ static void set_ds_odt(const struct chan_info *chan, clrsetbits_le32(&denali_phy[928], 0xff, reg_value);
/* phy_pad_rst_drive 8bits DENALI_PHY_937 offset_0 */ - clrsetbits_le32(&denali_phy[937], 0xff, reg_value); + if (!ctl_phy_reg) + clrsetbits_le32(&denali_phy[937], 0xff, reg_value);
/* phy_pad_cke_drive 8bits DENALI_PHY_935 offset_0 */ clrsetbits_le32(&denali_phy[935], 0xff, reg_value); @@ -919,7 +935,7 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, copy_to_reg(&denali_phy[512], ¶ms_phy[512], (549 - 512 + 1) * 4); copy_to_reg(&denali_phy[640], ¶ms_phy[640], (677 - 640 + 1) * 4); copy_to_reg(&denali_phy[768], ¶ms_phy[768], (805 - 768 + 1) * 4); - set_ds_odt(chan, params, 0); + set_ds_odt(chan, params, true, 0);
/* * phy_dqs_tsel_wr_timing_X 8bits DENALI_PHY_84/212/340/468 offset_8 @@ -950,7 +966,6 @@ static int pctl_cfg(struct dram_info *dram, const struct chan_info *chan, return 0; }
-#if !defined(CONFIG_RAM_RK3399_LPDDR4) static void select_per_cs_training_index(const struct chan_info *chan, u32 rank) { @@ -1308,7 +1323,7 @@ static int data_training(struct dram_info *dram, u32 channel,
if (training_flag == PI_FULL_TRAINING) { if (params->base.dramtype == LPDDR4) { - training_flag = PI_CA_TRAINING | PI_WRITE_LEVELING | + training_flag = PI_WRITE_LEVELING | PI_READ_GATE_TRAINING | PI_READ_LEVELING | PI_WDQ_LEVELING; } else if (params->base.dramtype == LPDDR3) { @@ -1371,7 +1386,6 @@ static int data_training(struct dram_info *dram, u32 channel,
return 0; } -#endif
static void set_ddrconfig(const struct chan_info *chan, const struct rk3399_sdram_params *params, @@ -1494,7 +1508,7 @@ static int default_data_training(struct dram_info *dram, u32 channel, u8 rank, }
static int switch_to_phy_index1(struct dram_info *dram, - const struct rk3399_sdram_params *params) + struct rk3399_sdram_params *params) { u32 channel; u32 *denali_phy; @@ -1540,6 +1554,18 @@ static int switch_to_phy_index1(struct dram_info *dram,
#else
+struct rk3399_sdram_params lpddr4_timings[] = { + #include "sdram-rk3399-lpddr4-400.inc" + #include "sdram-rk3399-lpddr4-800.inc" +}; + +static u32 lpddr4_get_phy(const struct rk3399_sdram_params *params, u32 ctl) +{ + u32 lpddr4_phy[] = {1, 0, 0xb}; + + return lpddr4_phy[ctl]; +} + static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) { return ((readl(&pmusgrf->soc_con4) >> 10) & 0x1F); @@ -1757,6 +1783,358 @@ end:
return ret; } + +static void lpddr4_copy_phy(struct dram_info *dram, + struct rk3399_sdram_params *params, u32 phy, + struct rk3399_sdram_params *timings, + u32 channel) +{ + u32 *denali_phy; + u32 *denali_phy_params; + u32 speed = 0; + u32 mr5; + + denali_phy = dram->chan[channel].publ->denali_phy; + denali_phy_params = timings->phy_regs.denali_phy; + + /* switch index */ + clrsetbits_le32(&denali_phy_params[896], 0x3 << 8, phy << 8); + writel(denali_phy_params[896], &denali_phy[896]); + + /* phy_pll_ctrl_ca, phy_pll_ctrl */ + writel(denali_phy_params[911], &denali_phy[911]); + + /* phy_low_freq_sel */ + clrsetbits_le32(&denali_phy[913], 0x1, + denali_phy_params[913] & 0x1); + + /* phy_grp_slave_delay_x, phy_cslvl_dly_step */ + writel(denali_phy_params[916], &denali_phy[916]); + writel(denali_phy_params[917], &denali_phy[917]); + writel(denali_phy_params[918], &denali_phy[918]); + + /* phy_adrz_sw_wraddr_shift_x */ + writel(denali_phy_params[512], &denali_phy[512]); + clrsetbits_le32(&denali_phy[513], 0xffff, + denali_phy_params[513] & 0xffff); + writel(denali_phy_params[640], &denali_phy[640]); + clrsetbits_le32(&denali_phy[641], 0xffff, + denali_phy_params[641] & 0xffff); + writel(denali_phy_params[768], &denali_phy[768]); + clrsetbits_le32(&denali_phy[769], 0xffff, + denali_phy_params[769] & 0xffff); + + writel(denali_phy_params[544], &denali_phy[544]); + writel(denali_phy_params[545], &denali_phy[545]); + writel(denali_phy_params[546], &denali_phy[546]); + writel(denali_phy_params[547], &denali_phy[547]); + + writel(denali_phy_params[672], &denali_phy[672]); + writel(denali_phy_params[673], &denali_phy[673]); + writel(denali_phy_params[674], &denali_phy[674]); + writel(denali_phy_params[675], &denali_phy[675]); + + writel(denali_phy_params[800], &denali_phy[800]); + writel(denali_phy_params[801], &denali_phy[801]); + writel(denali_phy_params[802], &denali_phy[802]); + writel(denali_phy_params[803], &denali_phy[803]); + + /* + * phy_adr_master_delay_start_x + * phy_adr_master_delay_step_x + * phy_adr_master_delay_wait_x + */ + writel(denali_phy_params[548], &denali_phy[548]); + writel(denali_phy_params[676], &denali_phy[676]); + writel(denali_phy_params[804], &denali_phy[804]); + + /* phy_adr_calvl_dly_step_x */ + writel(denali_phy_params[549], &denali_phy[549]); + writel(denali_phy_params[677], &denali_phy[677]); + writel(denali_phy_params[805], &denali_phy[805]); + + /* + * phy_clk_wrdm_slave_delay_x + * phy_clk_wrdqz_slave_delay_x + * phy_clk_wrdqs_slave_delay_x + */ + copy_to_reg((u32 *)&denali_phy[59], (u32 *)&denali_phy_params[59], + (63 - 58) * 4); + copy_to_reg((u32 *)&denali_phy[187], (u32 *)&denali_phy_params[187], + (191 - 186) * 4); + copy_to_reg((u32 *)&denali_phy[315], (u32 *)&denali_phy_params[315], + (319 - 314) * 4); + copy_to_reg((u32 *)&denali_phy[443], (u32 *)&denali_phy_params[443], + (447 - 442) * 4); + + /* + * phy_dqs_tsel_wr_timing_x 8bits denali_phy_84/212/340/468 offset_8 + * dqs_tsel_wr_end[7:4] add half cycle + * phy_dq_tsel_wr_timing_x 8bits denali_phy_83/211/339/467 offset_8 + * dq_tsel_wr_end[7:4] add half cycle + */ + writel(denali_phy_params[83] + (0x10 << 16), &denali_phy[83]); + writel(denali_phy_params[84] + (0x10 << 8), &denali_phy[84]); + writel(denali_phy_params[85], &denali_phy[85]); + + writel(denali_phy_params[211] + (0x10 << 16), &denali_phy[211]); + writel(denali_phy_params[212] + (0x10 << 8), &denali_phy[212]); + writel(denali_phy_params[213], &denali_phy[213]); + + writel(denali_phy_params[339] + (0x10 << 16), &denali_phy[339]); + writel(denali_phy_params[340] + (0x10 << 8), &denali_phy[340]); + writel(denali_phy_params[341], &denali_phy[341]); + + writel(denali_phy_params[467] + (0x10 << 16), &denali_phy[467]); + writel(denali_phy_params[468] + (0x10 << 8), &denali_phy[468]); + writel(denali_phy_params[469], &denali_phy[469]); + + /* + * phy_gtlvl_resp_wait_cnt_x + * phy_gtlvl_dly_step_x + * phy_wrlvl_resp_wait_cnt_x + * phy_gtlvl_final_step_x + * phy_gtlvl_back_step_x + * phy_rdlvl_dly_step_x + * + * phy_master_delay_step_x + * phy_master_delay_wait_x + * phy_wrlvl_dly_step_x + * phy_rptr_update_x + * phy_wdqlvl_dly_step_x + */ + writel(denali_phy_params[87], &denali_phy[87]); + writel(denali_phy_params[88], &denali_phy[88]); + writel(denali_phy_params[89], &denali_phy[89]); + writel(denali_phy_params[90], &denali_phy[90]); + + writel(denali_phy_params[215], &denali_phy[215]); + writel(denali_phy_params[216], &denali_phy[216]); + writel(denali_phy_params[217], &denali_phy[217]); + writel(denali_phy_params[218], &denali_phy[218]); + + writel(denali_phy_params[343], &denali_phy[343]); + writel(denali_phy_params[344], &denali_phy[344]); + writel(denali_phy_params[345], &denali_phy[345]); + writel(denali_phy_params[346], &denali_phy[346]); + + writel(denali_phy_params[471], &denali_phy[471]); + writel(denali_phy_params[472], &denali_phy[472]); + writel(denali_phy_params[473], &denali_phy[473]); + writel(denali_phy_params[474], &denali_phy[474]); + + /* + * phy_gtlvl_lat_adj_start_x + * phy_gtlvl_rddqs_slv_dly_start_x + * phy_rdlvl_rddqs_dq_slv_dly_start_x + * phy_wdqlvl_dqdm_slv_dly_start_x + */ + writel(denali_phy_params[80], &denali_phy[80]); + writel(denali_phy_params[81], &denali_phy[81]); + + writel(denali_phy_params[208], &denali_phy[208]); + writel(denali_phy_params[209], &denali_phy[209]); + + writel(denali_phy_params[336], &denali_phy[336]); + writel(denali_phy_params[337], &denali_phy[337]); + + writel(denali_phy_params[464], &denali_phy[464]); + writel(denali_phy_params[465], &denali_phy[465]); + + /* + * phy_master_delay_start_x + * phy_sw_master_mode_x + * phy_rddata_en_tsel_dly_x + */ + writel(denali_phy_params[86], &denali_phy[86]); + writel(denali_phy_params[214], &denali_phy[214]); + writel(denali_phy_params[342], &denali_phy[342]); + writel(denali_phy_params[470], &denali_phy[470]); + + /* + * phy_rddqz_slave_delay_x + * phy_rddqs_dqz_fall_slave_delay_x + * phy_rddqs_dqz_rise_slave_delay_x + * phy_rddqs_dm_fall_slave_delay_x + * phy_rddqs_dm_rise_slave_delay_x + * phy_rddqs_gate_slave_delay_x + * phy_wrlvl_delay_early_threshold_x + * phy_write_path_lat_add_x + * phy_rddqs_latency_adjust_x + * phy_wrlvl_delay_period_threshold_x + * phy_wrlvl_early_force_zero_x + */ + copy_to_reg((u32 *)&denali_phy[64], (u32 *)&denali_phy_params[64], + (67 - 63) * 4); + clrsetbits_le32(&denali_phy[68], 0xfffffc00, + denali_phy_params[68] & 0xfffffc00); + copy_to_reg((u32 *)&denali_phy[69], (u32 *)&denali_phy_params[69], + (79 - 68) * 4); + copy_to_reg((u32 *)&denali_phy[192], (u32 *)&denali_phy_params[192], + (195 - 191) * 4); + clrsetbits_le32(&denali_phy[196], 0xfffffc00, + denali_phy_params[196] & 0xfffffc00); + copy_to_reg((u32 *)&denali_phy[197], (u32 *)&denali_phy_params[197], + (207 - 196) * 4); + copy_to_reg((u32 *)&denali_phy[320], (u32 *)&denali_phy_params[320], + (323 - 319) * 4); + clrsetbits_le32(&denali_phy[324], 0xfffffc00, + denali_phy_params[324] & 0xfffffc00); + copy_to_reg((u32 *)&denali_phy[325], (u32 *)&denali_phy_params[325], + (335 - 324) * 4); + + copy_to_reg((u32 *)&denali_phy[448], (u32 *)&denali_phy_params[448], + (451 - 447) * 4); + clrsetbits_le32(&denali_phy[452], 0xfffffc00, + denali_phy_params[452] & 0xfffffc00); + copy_to_reg((u32 *)&denali_phy[453], (u32 *)&denali_phy_params[453], + (463 - 452) * 4); + + /* phy_two_cyc_preamble_x */ + clrsetbits_le32(&denali_phy[7], 0x3 << 24, + denali_phy_params[7] & (0x3 << 24)); + clrsetbits_le32(&denali_phy[135], 0x3 << 24, + denali_phy_params[135] & (0x3 << 24)); + clrsetbits_le32(&denali_phy[263], 0x3 << 24, + denali_phy_params[263] & (0x3 << 24)); + clrsetbits_le32(&denali_phy[391], 0x3 << 24, + denali_phy_params[391] & (0x3 << 24)); + + /* speed */ + if (timings->base.ddr_freq < 400 * MHz) + speed = 0x0; + else if (timings->base.ddr_freq < 800 * MHz) + speed = 0x1; + else if (timings->base.ddr_freq < 1200 * MHz) + speed = 0x2; + + /* phy_924 phy_pad_fdbk_drive */ + clrsetbits_le32(&denali_phy[924], 0x3 << 21, speed << 21); + /* phy_926 phy_pad_data_drive */ + clrsetbits_le32(&denali_phy[926], 0x3 << 9, speed << 9); + /* phy_927 phy_pad_dqs_drive */ + clrsetbits_le32(&denali_phy[927], 0x3 << 9, speed << 9); + /* phy_928 phy_pad_addr_drive */ + clrsetbits_le32(&denali_phy[928], 0x3 << 17, speed << 17); + /* phy_929 phy_pad_clk_drive */ + clrsetbits_le32(&denali_phy[929], 0x3 << 17, speed << 17); + /* phy_935 phy_pad_cke_drive */ + clrsetbits_le32(&denali_phy[935], 0x3 << 17, speed << 17); + /* phy_937 phy_pad_rst_drive */ + clrsetbits_le32(&denali_phy[937], 0x3 << 17, speed << 17); + /* phy_939 phy_pad_cs_drive */ + clrsetbits_le32(&denali_phy[939], 0x3 << 17, speed << 17); + + read_mr(dram->chan[channel].pctl, 1, 5, &mr5); + set_ds_odt(&dram->chan[channel], timings, true, mr5); + + /* + * if phy_sw_master_mode_x not bypass mode, + * clear phy_slice_pwr_rdc_disable. + * note: need use timings, not ddr_publ_regs + */ + if (!((denali_phy_params[86] >> 8) & (1 << 2))) { + clrbits_le32(&denali_phy[10], 1 << 16); + clrbits_le32(&denali_phy[138], 1 << 16); + clrbits_le32(&denali_phy[266], 1 << 16); + clrbits_le32(&denali_phy[394], 1 << 16); + } +} + +static void lpddr4_set_phy(struct dram_info *dram, + struct rk3399_sdram_params *params, u32 phy, + struct rk3399_sdram_params *timings) +{ + u32 channel; + + for (channel = 0; channel < 2; channel++) + lpddr4_copy_phy(dram, params, phy, timings, channel); +} + +static int lpddr4_set_ctl(struct dram_info *dram, + struct rk3399_sdram_params *params, u32 ctl, u32 hz) +{ + u32 channel; + int ret_clk, ret[2]; + + /* cci idle req stall */ + writel(0x70007, &dram->grf->soc_con0); + + /* enable all clk */ + setbits_le32(&dram->pmu->pmu_noc_auto_ena, (0x3 << 7)); + + /* idle */ + setbits_le32(&dram->pmu->pmu_bus_idle_req, (0x3 << 18)); + while ((readl(&dram->pmu->pmu_bus_idle_st) & (0x3 << 18)) + != (0x3 << 18)) + ; + + /* change freq */ + writel((((0x3 << 4) | (1 << 2) | 1) << 16) | + (ctl << 4) | (1 << 2) | 1, &dram->cic->cic_ctrl0); + while (!(readl(&dram->cic->cic_status0) & (1 << 2))) + ; + + ret_clk = clk_set_rate(&dram->ddr_clk, hz); + if (ret_clk < 0) { + printf("%s clk set failed %d\n", __func__, ret_clk); + return ret_clk; + } + + writel(0x20002, &dram->cic->cic_ctrl0); + while (!(readl(&dram->cic->cic_status0) & (1 << 0))) + ; + + /* deidle */ + clrbits_le32(&dram->pmu->pmu_bus_idle_req, (0x3 << 18)); + while (readl(&dram->pmu->pmu_bus_idle_st) & (0x3 << 18)) + ; + + /* clear enable all clk */ + clrbits_le32(&dram->pmu->pmu_noc_auto_ena, (0x3 << 7)); + + /* lpddr4 ctl2 can not do training, all training will fail */ + if (!(params->base.dramtype == LPDDR4 && ctl == 2)) { + for (channel = 0; channel < 2; channel++) { + if (!(params->ch[channel].cap_info.col)) + continue; + ret[channel] = data_training(dram, channel, params, + PI_FULL_TRAINING); + } + for (channel = 0; channel < 2; channel++) { + if (!(params->ch[channel].cap_info.col)) + continue; + if (ret[channel]) + printf("%s: channel %d training failed!\n", + __func__, channel); + else + debug("%s: channel %d training pass\n", + __func__, channel); + } + } + + return 0; +} + +static int lpddr4_set_rate(struct dram_info *dram, + struct rk3399_sdram_params *params) +{ + u32 ctl; + u32 phy; + + for (ctl = 0; ctl < 2; ctl++) { + phy = lpddr4_get_phy(params, ctl); + + lpddr4_set_phy(dram, params, phy, &lpddr4_timings[ctl]); + lpddr4_set_ctl(dram, params, ctl, + lpddr4_timings[ctl].base.ddr_freq); + + debug("%s: change freq to %d mhz %d, %d\n", __func__, + lpddr4_timings[ctl].base.ddr_freq / MHz, ctl, phy); + } + + return 0; +} #endif /* CONFIG_RAM_RK3399_LPDDR4 */
static unsigned char calculate_stride(struct rk3399_sdram_params *params) @@ -1994,6 +2372,7 @@ static const struct sdram_rk3399_ops rk3399_ops = { .set_rate = switch_to_phy_index1, #else .data_training = lpddr4_mr_detect, + .set_rate = lpddr4_set_rate, #endif };
@@ -2017,6 +2396,7 @@ static int rk3399_dmc_init(struct udevice *dev) priv->ops = &rk3399_ops; priv->cic = syscon_get_first_range(ROCKCHIP_SYSCON_CIC); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + priv->pmu = syscon_get_first_range(ROCKCHIP_SYSCON_PMU); priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); priv->pmusgrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUSGRF); priv->pmucru = rockchip_get_pmucru(); @@ -2035,8 +2415,8 @@ static int rk3399_dmc_init(struct udevice *dev) priv->chan[0].publ, priv->chan[0].msch, priv->chan[1].pctl, priv->chan[1].pi, priv->chan[1].publ, priv->chan[1].msch); - debug("cru %p, cic %p, grf %p, sgrf %p, pmucru %p\n", priv->cru, - priv->cic, priv->pmugrf, priv->pmusgrf, priv->pmucru); + debug("cru %p, cic %p, grf %p, sgrf %p, pmucru %p, pmu %p\n", priv->cru, + priv->cic, priv->pmugrf, priv->pmusgrf, priv->pmucru, priv->pmu);
#if CONFIG_IS_ENABLED(OF_PLATDATA) ret = clk_get_by_index_platdata(dev, 0, dtplat->clocks, &priv->ddr_clk);
Set DQ ODT based identified controller in lpddr4 as part of LPDDR set rate initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 82 +++++++++++++++++++++++++++-- 1 file changed, 79 insertions(+), 3 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 07759e8956..ddda6f8ebd 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1559,13 +1559,26 @@ struct rk3399_sdram_params lpddr4_timings[] = { #include "sdram-rk3399-lpddr4-800.inc" };
-static u32 lpddr4_get_phy(const struct rk3399_sdram_params *params, u32 ctl) +static void *get_denali_pi(const struct chan_info *chan, + struct rk3399_sdram_params *params, bool reg) +{ + return reg ? &chan->pi->denali_pi : ¶ms->pi_regs.denali_pi; +} + +static u32 lpddr4_get_phy(struct rk3399_sdram_params *params, u32 ctl) { u32 lpddr4_phy[] = {1, 0, 0xb};
return lpddr4_phy[ctl]; }
+static u32 lpddr4_get_ctl(struct rk3399_sdram_params *params, u32 phy) +{ + u32 lpddr4_ctl[] = {1, 0, 2}; + + return lpddr4_ctl[phy]; +} + static u32 get_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf) { return ((readl(&pmusgrf->soc_con4) >> 10) & 0x1F); @@ -1784,16 +1797,65 @@ end: return ret; }
+static void set_lpddr4_dq_odt(const struct chan_info *chan, + struct rk3399_sdram_params *params, u32 ctl, + bool en, bool ctl_phy_reg, u32 mr5) +{ + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); + u32 *denali_pi = get_denali_pi(chan, params, ctl_phy_reg); + struct io_setting *io; + u32 reg_value; + + if (!en) + return; + + io = lpddr4_get_io_settings(params, mr5); + + reg_value = io->dq_odt; + + switch (ctl) { + case 0: + clrsetbits_le32(&denali_ctl[139], 0x7 << 24, reg_value << 24); + clrsetbits_le32(&denali_ctl[153], 0x7 << 24, reg_value << 24); + + clrsetbits_le32(&denali_pi[132], 0x7 << 0, (reg_value << 0)); + clrsetbits_le32(&denali_pi[139], 0x7 << 16, (reg_value << 16)); + clrsetbits_le32(&denali_pi[147], 0x7 << 0, (reg_value << 0)); + clrsetbits_le32(&denali_pi[154], 0x7 << 16, (reg_value << 16)); + break; + case 1: + clrsetbits_le32(&denali_ctl[140], 0x7 << 0, reg_value << 0); + clrsetbits_le32(&denali_ctl[154], 0x7 << 0, reg_value << 0); + + clrsetbits_le32(&denali_pi[129], 0x7 << 16, (reg_value << 16)); + clrsetbits_le32(&denali_pi[137], 0x7 << 0, (reg_value << 0)); + clrsetbits_le32(&denali_pi[144], 0x7 << 16, (reg_value << 16)); + clrsetbits_le32(&denali_pi[152], 0x7 << 0, (reg_value << 0)); + break; + case 2: + default: + clrsetbits_le32(&denali_ctl[140], 0x7 << 8, (reg_value << 8)); + clrsetbits_le32(&denali_ctl[154], 0x7 << 8, (reg_value << 8)); + + clrsetbits_le32(&denali_pi[127], 0x7 << 0, (reg_value << 0)); + clrsetbits_le32(&denali_pi[134], 0x7 << 16, (reg_value << 16)); + clrsetbits_le32(&denali_pi[142], 0x7 << 0, (reg_value << 0)); + clrsetbits_le32(&denali_pi[149], 0x7 << 16, (reg_value << 16)); + break; + } +} + static void lpddr4_copy_phy(struct dram_info *dram, struct rk3399_sdram_params *params, u32 phy, struct rk3399_sdram_params *timings, u32 channel) { - u32 *denali_phy; + u32 *denali_ctl, *denali_phy; u32 *denali_phy_params; u32 speed = 0; - u32 mr5; + u32 ctl, mr5;
+ denali_ctl = dram->chan[channel].pctl->denali_ctl; denali_phy = dram->chan[channel].publ->denali_phy; denali_phy_params = timings->phy_regs.denali_phy;
@@ -2028,6 +2090,9 @@ static void lpddr4_copy_phy(struct dram_info *dram, read_mr(dram->chan[channel].pctl, 1, 5, &mr5); set_ds_odt(&dram->chan[channel], timings, true, mr5);
+ ctl = lpddr4_get_ctl(timings, phy); + set_lpddr4_dq_odt(&dram->chan[channel], timings, ctl, true, true, mr5); + /* * if phy_sw_master_mode_x not bypass mode, * clear phy_slice_pwr_rdc_disable. @@ -2039,6 +2104,17 @@ static void lpddr4_copy_phy(struct dram_info *dram, clrbits_le32(&denali_phy[266], 1 << 16); clrbits_le32(&denali_phy[394], 1 << 16); } + + /* + * when PHY_PER_CS_TRAINING_EN=1, W2W_DIFFCS_DLY_Fx can't + * smaller than 8 + * NOTE: need use timings, not ddr_publ_regs + */ + if ((denali_phy_params[84] >> 16) & 1) { + if (((readl(&denali_ctl[217 + ctl]) >> 16) & 0x1f) < 8) + clrsetbits_le32(&denali_ctl[217 + ctl], + 0x1f << 16, 8 << 16); + } }
Set CA ODT based identified controller in lpddr4 as part of LPDDR set rate initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 49 +++++++++++++++++++++++++++++ 1 file changed, 49 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index ddda6f8ebd..c5521e730d 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1845,6 +1845,54 @@ static void set_lpddr4_dq_odt(const struct chan_info *chan, } }
+static void set_lpddr4_ca_odt(const struct chan_info *chan, + struct rk3399_sdram_params *params, u32 ctl, + bool en, bool ctl_phy_reg, u32 mr5) +{ + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); + u32 *denali_pi = get_denali_pi(chan, params, ctl_phy_reg); + struct io_setting *io; + u32 reg_value; + + if (!en) + return; + + io = lpddr4_get_io_settings(params, mr5); + + reg_value = io->ca_odt; + + switch (ctl) { + case 0: + clrsetbits_le32(&denali_ctl[139], 0x7 << 28, reg_value << 28); + clrsetbits_le32(&denali_ctl[153], 0x7 << 28, reg_value << 28); + + clrsetbits_le32(&denali_pi[132], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_pi[139], 0x7 << 20, reg_value << 20); + clrsetbits_le32(&denali_pi[147], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_pi[154], 0x7 << 20, reg_value << 20); + break; + case 1: + clrsetbits_le32(&denali_ctl[140], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_ctl[154], 0x7 << 4, reg_value << 4); + + clrsetbits_le32(&denali_pi[129], 0x7 << 20, reg_value << 20); + clrsetbits_le32(&denali_pi[137], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_pi[144], 0x7 << 20, reg_value << 20); + clrsetbits_le32(&denali_pi[152], 0x7 << 4, reg_value << 4); + break; + case 2: + default: + clrsetbits_le32(&denali_ctl[140], 0x7 << 12, (reg_value << 12)); + clrsetbits_le32(&denali_ctl[154], 0x7 << 12, (reg_value << 12)); + + clrsetbits_le32(&denali_pi[127], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_pi[134], 0x7 << 20, reg_value << 20); + clrsetbits_le32(&denali_pi[142], 0x7 << 4, reg_value << 4); + clrsetbits_le32(&denali_pi[149], 0x7 << 20, reg_value << 20); + break; + } +} + static void lpddr4_copy_phy(struct dram_info *dram, struct rk3399_sdram_params *params, u32 phy, struct rk3399_sdram_params *timings, @@ -2092,6 +2140,7 @@ static void lpddr4_copy_phy(struct dram_info *dram,
ctl = lpddr4_get_ctl(timings, phy); set_lpddr4_dq_odt(&dram->chan[channel], timings, ctl, true, true, mr5); + set_lpddr4_ca_odt(&dram->chan[channel], timings, ctl, true, true, mr5);
Set MR3 based identified controller in lpddr4 as part of LPDDR set rate initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 48 +++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c5521e730d..61b886ba68 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1893,6 +1893,53 @@ static void set_lpddr4_ca_odt(const struct chan_info *chan, } }
+static void set_lpddr4_MR3(const struct chan_info *chan, + struct rk3399_sdram_params *params, u32 ctl, + bool ctl_phy_reg, u32 mr5) +{ + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); + u32 *denali_pi = get_denali_pi(chan, params, ctl_phy_reg); + struct io_setting *io; + u32 reg_value; + + io = lpddr4_get_io_settings(params, mr5); + + reg_value = ((io->pdds << 3) | 1); + + switch (ctl) { + case 0: + clrsetbits_le32(&denali_ctl[138], 0xFFFF, reg_value); + clrsetbits_le32(&denali_ctl[152], 0xFFFF, reg_value); + + clrsetbits_le32(&denali_pi[131], 0xFFFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[139], 0xFFFF, reg_value); + clrsetbits_le32(&denali_pi[146], 0xFFFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[154], 0xFFFF, reg_value); + break; + case 1: + clrsetbits_le32(&denali_ctl[138], 0xFFFF << 16, + reg_value << 16); + clrsetbits_le32(&denali_ctl[152], 0xFFFF << 16, + reg_value << 16); + + clrsetbits_le32(&denali_pi[129], 0xFFFF, reg_value); + clrsetbits_le32(&denali_pi[136], 0xFFFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[144], 0xFFFF, reg_value); + clrsetbits_le32(&denali_pi[151], 0xFFFF << 16, reg_value << 16); + break; + case 2: + default: + clrsetbits_le32(&denali_ctl[139], 0xFFFF, reg_value); + clrsetbits_le32(&denali_ctl[153], 0xFFFF, reg_value); + + clrsetbits_le32(&denali_pi[126], 0xFFFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[134], 0xFFFF, reg_value); + clrsetbits_le32(&denali_pi[141], 0xFFFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[149], 0xFFFF, reg_value); + break; + } +} + static void lpddr4_copy_phy(struct dram_info *dram, struct rk3399_sdram_params *params, u32 phy, struct rk3399_sdram_params *timings, @@ -2141,6 +2188,7 @@ static void lpddr4_copy_phy(struct dram_info *dram, ctl = lpddr4_get_ctl(timings, phy); set_lpddr4_dq_odt(&dram->chan[channel], timings, ctl, true, true, mr5); set_lpddr4_ca_odt(&dram->chan[channel], timings, ctl, true, true, mr5); + set_lpddr4_MR3(&dram->chan[channel], timings, ctl, true, mr5);
Set MR12 based identified controller in lpddr4 as part of LPDDR set rate initialization phase.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- drivers/ram/rockchip/sdram_rk3399.c | 50 +++++++++++++++++++++++++++++ 1 file changed, 50 insertions(+)
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 61b886ba68..5c0914f40d 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1940,6 +1940,55 @@ static void set_lpddr4_MR3(const struct chan_info *chan, } }
+static void set_lpddr4_MR12(const struct chan_info *chan, + struct rk3399_sdram_params *params, u32 ctl, + bool ctl_phy_reg, u32 mr5) +{ + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); + u32 *denali_pi = get_denali_pi(chan, params, ctl_phy_reg); + struct io_setting *io; + u32 reg_value; + + io = lpddr4_get_io_settings(params, mr5); + + reg_value = io->ca_vref; + + switch (ctl) { + case 0: + clrsetbits_le32(&denali_ctl[140], 0xFFFF << 16, + reg_value << 16); + clrsetbits_le32(&denali_ctl[154], 0xFFFF << 16, + reg_value << 16); + + clrsetbits_le32(&denali_pi[132], 0xFF << 8, reg_value << 8); + clrsetbits_le32(&denali_pi[139], 0xFF << 24, reg_value << 24); + clrsetbits_le32(&denali_pi[147], 0xFF << 8, reg_value << 8); + clrsetbits_le32(&denali_pi[154], 0xFF << 24, reg_value << 24); + break; + case 1: + clrsetbits_le32(&denali_ctl[141], 0xFFFF, reg_value); + clrsetbits_le32(&denali_ctl[155], 0xFFFF, reg_value); + + clrsetbits_le32(&denali_pi[129], 0xFF << 24, reg_value << 24); + clrsetbits_le32(&denali_pi[137], 0xFF << 8, reg_value << 8); + clrsetbits_le32(&denali_pi[144], 0xFF << 24, reg_value << 24); + clrsetbits_le32(&denali_pi[152], 0xFF << 8, reg_value << 8); + break; + case 2: + default: + clrsetbits_le32(&denali_ctl[141], 0xFFFF << 16, + reg_value << 16); + clrsetbits_le32(&denali_ctl[155], 0xFFFF << 16, + reg_value << 16); + + clrsetbits_le32(&denali_pi[127], 0xFF << 8, reg_value << 8); + clrsetbits_le32(&denali_pi[134], 0xFF << 24, reg_value << 24); + clrsetbits_le32(&denali_pi[142], 0xFF << 8, reg_value << 8); + clrsetbits_le32(&denali_pi[149], 0xFF << 24, reg_value << 24); + break; + } +} + static void lpddr4_copy_phy(struct dram_info *dram, struct rk3399_sdram_params *params, u32 phy, struct rk3399_sdram_params *timings, @@ -2189,6 +2238,7 @@ static void lpddr4_copy_phy(struct dram_info *dram, set_lpddr4_dq_odt(&dram->chan[channel], timings, ctl, true, true, mr5); set_lpddr4_ca_odt(&dram->chan[channel], timings, ctl, true, true, mr5); set_lpddr4_MR3(&dram->chan[channel], timings, ctl, true, mr5); + set_lpddr4_MR12(&dram->chan[channel], timings, ctl, true, mr5);
Set MR14 based identified controller in lpddr4 as part of LPDDR set rate initialization phase.
diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 5c0914f40d..e009113d45 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1989,6 +1989,55 @@ static void set_lpddr4_MR12(const struct chan_info *chan, } }
+static void set_lpddr4_MR14(const struct chan_info *chan, + struct rk3399_sdram_params *params, u32 ctl, + bool ctl_phy_reg, u32 mr5) +{ + u32 *denali_ctl = get_denali_ctl(chan, params, ctl_phy_reg); + u32 *denali_pi = get_denali_pi(chan, params, ctl_phy_reg); + struct io_setting *io; + u32 reg_value; + + io = lpddr4_get_io_settings(params, mr5); + + reg_value = io->dq_vref; + + switch (ctl) { + case 0: + clrsetbits_le32(&denali_ctl[142], 0xFFFF << 16, + reg_value << 16); + clrsetbits_le32(&denali_ctl[156], 0xFFFF << 16, + reg_value << 16); + + clrsetbits_le32(&denali_pi[132], 0xFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[140], 0xFF << 0, reg_value << 0); + clrsetbits_le32(&denali_pi[147], 0xFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[155], 0xFF << 0, reg_value << 0); + break; + case 1: + clrsetbits_le32(&denali_ctl[143], 0xFFFF, reg_value); + clrsetbits_le32(&denali_ctl[157], 0xFFFF, reg_value); + + clrsetbits_le32(&denali_pi[130], 0xFF << 0, reg_value << 0); + clrsetbits_le32(&denali_pi[137], 0xFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[145], 0xFF << 0, reg_value << 0); + clrsetbits_le32(&denali_pi[152], 0xFF << 16, reg_value << 16); + break; + case 2: + default: + clrsetbits_le32(&denali_ctl[143], 0xFFFF << 16, + reg_value << 16); + clrsetbits_le32(&denali_ctl[157], 0xFFFF << 16, + reg_value << 16); + + clrsetbits_le32(&denali_pi[127], 0xFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[135], 0xFF << 0, reg_value << 0); + clrsetbits_le32(&denali_pi[142], 0xFF << 16, reg_value << 16); + clrsetbits_le32(&denali_pi[150], 0xFF << 0, reg_value << 0); + break; + } +} + static void lpddr4_copy_phy(struct dram_info *dram, struct rk3399_sdram_params *params, u32 phy, struct rk3399_sdram_params *timings, @@ -2239,6 +2288,7 @@ static void lpddr4_copy_phy(struct dram_info *dram, set_lpddr4_ca_odt(&dram->chan[channel], timings, ctl, true, true, mr5); set_lpddr4_MR3(&dram->chan[channel], timings, ctl, true, mr5); set_lpddr4_MR12(&dram->chan[channel], timings, ctl, true, mr5); + set_lpddr4_MR14(&dram->chan[channel], timings, ctl, true, mr5);
Due to foot-print issues, we have LPDDR4 code can be marked as CONFIG_RAM_RK3399_LPDDR4.
So, enable it for Rockpro64 board.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rockpro64-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 90bcaedbd2..cb09df6fb7 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-rockpro64" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_TPL=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_RAM_RK3399_LPDDR4=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y
So, enable it for Rock-PI-4 board.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- configs/rock-pi-4-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 32da77aa39..d667cf2124 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4" CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_TPL=y CONFIG_ENV_IS_IN_MMC=y +CONFIG_RAM_RK3399_LPDDR4=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_MMC_DW=y
Add sdram timings for LPDDR4-100 via rk3399-sdram-lpddr4-100.dtsi file. all timings are dumped from rkbin/bin/rk33/rk3399_ddr_800MHz_v1.20.bin
Associated LPDDR4 board -u-boot.dtsi can include this to make these timings available during SPL or TPL stages.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: YouMin Chen cym@rock-chips.com --- arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi | 1537 +++++++++++++++++++++ 1 file changed, 1537 insertions(+) create mode 100644 arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi
diff --git a/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi b/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi new file mode 100644 index 0000000000..4a4414a960 --- /dev/null +++ b/arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi @@ -0,0 +1,1537 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + * (C) Copyright 2019 Amarula Solutions. + * Author: Jagan Teki jagan@amarulasolutions.com + */ + +&dmc { + rockchip,sdram-params = < + 0x2 + 0xa + 0x3 + 0x2 + 0x1 + 0x0 + 0xf + 0xf + 1 + 0x80241d22 + 0x15050f08 + 0x00000602 + 0x00002122 + 0x0000004c + 0x00000000 + 0x2 + 0xa + 0x3 + 0x2 + 0x1 + 0x0 + 0xf + 0xf + 1 + 0x80241d22 + 0x15050f08 + 0x00000602 + 0x00002122 + 0x0000004c + 0x00000000 + 50 + 7 + 2 + 13 + 1 + 0x00000b00 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00013880 + 0x000c3500 + 0x00000005 + 0x00000320 + 0x00027100 + 0x00186a00 + 0x00000005 + 0x00000640 + 0x00002710 + 0x000186a0 + 0x00000005 + 0x01000064 + 0x00000000 + 0x02020101 + 0x00000102 + 0x00000050 + 0x000000c8 + 0x00000000 + 0x06140000 + 0x00081c00 + 0x0400040c + 0x19042008 + 0x10080a11 + 0x22310800 + 0x00200f0a + 0x0a030704 + 0x08000204 + 0x00000a0a + 0x04006db0 + 0x0a0a0804 + 0x0600db60 + 0x0a0a0806 + 0x04000db6 + 0x02030404 + 0x0f0a0800 + 0x08040411 + 0x1400640a + 0x02010a0a + 0x00010001 + 0x04082012 + 0x00041109 + 0x00000000 + 0x03010000 + 0x06100048 + 0x0c280090 + 0x00bb0009 + 0x00000000 + 0x00060005 + 0x000a0005 + 0x000a0014 + 0x01000000 + 0x030a0000 + 0x0c000002 + 0x00000103 + 0x0005030a + 0x00060037 + 0x0005006e + 0x05050007 + 0x03030605 + 0x06050301 + 0x06030c05 + 0x05050302 + 0x03030305 + 0x00000301 + 0x00000301 + 0x00000001 + 0x00000000 + 0x00000000 + 0x01000000 + 0x80104002 + 0x00040003 + 0x00040005 + 0x00030000 + 0x00050004 + 0x00000004 + 0x00040003 + 0x00040005 + 0x18400000 + 0x00000c20 + 0x185030a0 + 0x02ec0000 + 0x00000176 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x06030300 + 0x00030303 + 0x02030200 + 0x00040703 + 0x03020302 + 0x02000407 + 0x07030203 + 0x00030f04 + 0x00070004 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x20040020 + 0x00200400 + 0x01000400 + 0x00000b80 + 0x00000000 + 0x00000001 + 0x00000002 + 0x0000000e + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00500000 + 0x00640028 + 0x00640404 + 0x005000a0 + 0x060600c8 + 0x000a00c8 + 0x000d0005 + 0x000d0404 + 0x00000000 + 0x00000000 + 0x00000000 + 0x001400a3 + 0x00e30009 + 0x00120024 + 0x00040063 + 0x00000000 + 0x00310031 + 0x00000031 + 0x004d0000 + 0x004d004d + 0x004d0000 + 0x004d004d + 0x00010101 + 0x00000000 + 0x00000000 + 0x001400a3 + 0x00e30009 + 0x00120024 + 0x00040063 + 0x00000000 + 0x00310031 + 0x00000031 + 0x004d0000 + 0x004d004d + 0x004d0000 + 0x004d004d + 0x00010101 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000001 + 0x00000000 + 0x18151100 + 0x0000000c + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00020003 + 0x00400100 + 0x000c0190 + 0x01000200 + 0x03200040 + 0x00020018 + 0x00400100 + 0x00080032 + 0x00140000 + 0x00030028 + 0x01010100 + 0x02000202 + 0x0b000002 + 0x01000f0f + 0x00000000 + 0x00000000 + 0x00010003 + 0x00000c03 + 0x00040101 + 0x04010100 + 0x01000000 + 0x02010000 + 0x00000001 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x00000001 + 0x01010001 + 0x05040001 + 0x040a0703 + 0x02080808 + 0x020e000a + 0x020f010b + 0x000d0008 + 0x00080b0a + 0x03000200 + 0x00000100 + 0x00000000 + 0x00000000 + 0x0d000001 + 0x00000028 + 0x00010000 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00010100 + 0x01000000 + 0x00000001 + 0x00000303 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000556aa + 0x000aaaaa + 0x000aa955 + 0x00055555 + 0x000b3133 + 0x0004cd33 + 0x0004cecc + 0x000b32cc + 0x00010300 + 0x03000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00ffff00 + 0x1a160000 + 0x08000012 + 0x00000c20 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000c20 + 0x00007940 + 0x18500409 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x0000f320 + 0x0176060c + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000176 + 0x00000e9c + 0x02020205 + 0x03030202 + 0x00000018 + 0x00000000 + 0x00000000 + 0x00001403 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030000 + 0x000a001c + 0x000e0020 + 0x00060018 + 0x00000000 + 0x00000000 + 0x02000000 + 0x00090305 + 0x00050101 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000001 + 0x01010101 + 0x01000101 + 0x01000100 + 0x00010001 + 0x00010002 + 0x00020100 + 0x00000002 + 0x00000b00 + 0x00000000 + 0x000002ec + 0x00000176 + 0x000030a0 + 0x00001850 + 0x00001840 + 0x01760c20 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00001850 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000c20 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00000200 + 0x00010000 + 0x00000007 + 0x01000001 + 0x00000000 + 0x3fffffff + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0f000101 + 0x082b3223 + 0x080c0004 + 0x00061c00 + 0x00000214 + 0x00bb0009 + 0x0c280090 + 0x06100048 + 0x00000500 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04040100 + 0x0a000004 + 0x00000128 + 0x00000000 + 0x0003000f + 0x00000018 + 0x00000000 + 0x00000000 + 0x00060002 + 0x00010001 + 0x00000101 + 0x00020001 + 0x00080004 + 0x00000000 + 0x05030000 + 0x070a0404 + 0x00000000 + 0x00000000 + 0x00000000 + 0x000f0f00 + 0x0000001e + 0x00000000 + 0x01010300 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00000101 + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x55555a5a + 0x0c050001 + 0x06020009 + 0x00010004 + 0x00000203 + 0x00030000 + 0x170f0000 + 0x00060018 + 0x000e0020 + 0x000a001c + 0x00000000 + 0x00000000 + 0x00000100 + 0x140a0000 + 0x000d010a + 0x0100c802 + 0x010a0064 + 0x000e0100 + 0x0100000e + 0x00c900c9 + 0x00650100 + 0x1e1a0065 + 0x10010204 + 0x06070605 + 0x20000202 + 0x00201000 + 0x00201000 + 0x04041000 + 0x10020100 + 0x0003010c + 0x004b004a + 0x1a0f0000 + 0x0102041e + 0x34000000 + 0x00000000 + 0x00000000 + 0x00010000 + 0x00000400 + 0x00310000 + 0x004d4d00 + 0x00120024 + 0x4d000031 + 0x0000144d + 0x00310009 + 0x004d4d00 + 0x00000004 + 0x4d000031 + 0x0000244d + 0x00310012 + 0x004d4d00 + 0x00090014 + 0x4d000031 + 0x0004004d + 0x00310000 + 0x004d4d00 + 0x00120024 + 0x4d000031 + 0x0000144d + 0x00310009 + 0x004d4d00 + 0x00000004 + 0x4d000031 + 0x0000244d + 0x00310012 + 0x004d4d00 + 0x00090014 + 0x4d000031 + 0x0200004d + 0x00c8000d + 0x08080064 + 0x040a0404 + 0x03000d92 + 0x010a2001 + 0x0f11080a + 0x0000110a + 0x2200d92e + 0x080c2003 + 0x0809080a + 0x00000a0a + 0x11006c97 + 0x040a2002 + 0x0200020a + 0x02000200 + 0x02000200 + 0x02000200 + 0x02000200 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000400 + 0x00017600 + 0x00000e9c + 0x00001850 + 0x0000f320 + 0x00000c20 + 0x00007940 + 0x08000000 + 0x00000100 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x76543210 + 0x0004f008 + 0x00020159 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x03665555 + 0x00010f00 + 0x04000100 + 0x00000000 + 0x00170180 + 0x00cc0201 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x30000000 + 0x0c00c007 + 0x00000100 + 0x00000000 + 0xfd02fe01 + 0xf708fb04 + 0xdf20ef10 + 0x7f80bf40 + 0x0001aaaa + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02800280 + 0x02800280 + 0x02800280 + 0x02800280 + 0x00000280 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01590080 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0003150 + 0x010000c0 + 0x00100c00 + 0x07044204 + 0x000f0c18 + 0x01000140 + 0x00000c10 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004f008 + 0x00020159 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x03665555 + 0x00010f00 + 0x04000100 + 0x00000000 + 0x00170180 + 0x00cc0201 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x30000000 + 0x0c00c007 + 0x00000100 + 0x00000000 + 0xfd02fe01 + 0xf708fb04 + 0xdf20ef10 + 0x7f80bf40 + 0x0000aaaa + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02800280 + 0x02800280 + 0x02800280 + 0x02800280 + 0x00000280 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01590080 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0003150 + 0x010000c0 + 0x00100c00 + 0x07044204 + 0x000f0c18 + 0x01000140 + 0x00000c10 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004f008 + 0x00020159 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x03665555 + 0x00010f00 + 0x04000100 + 0x00000000 + 0x00170180 + 0x00cc0201 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x30000000 + 0x0c00c007 + 0x00000100 + 0x00000000 + 0xfd02fe01 + 0xf708fb04 + 0xdf20ef10 + 0x7f80bf40 + 0x0001aaaa + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02800280 + 0x02800280 + 0x02800280 + 0x02800280 + 0x00000280 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01590080 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0003150 + 0x010000c0 + 0x00100c00 + 0x07044204 + 0x000f0c18 + 0x01000140 + 0x00000c10 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x76543210 + 0x0004f008 + 0x00020159 + 0x00000000 + 0x00000000 + 0x00010000 + 0x01665555 + 0x03665555 + 0x00010f00 + 0x04000100 + 0x00000000 + 0x00170180 + 0x00cc0201 + 0x00030066 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x04080000 + 0x04080400 + 0x30000000 + 0x0c00c007 + 0x00000100 + 0x00000000 + 0xfd02fe01 + 0xf708fb04 + 0xdf20ef10 + 0x7f80bf40 + 0x0000aaaa + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00200000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x02800280 + 0x02800280 + 0x02800280 + 0x02800280 + 0x00000280 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00800000 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x00800080 + 0x01590080 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000200 + 0x00000000 + 0x51315152 + 0xc0003150 + 0x010000c0 + 0x00100c00 + 0x07044204 + 0x000f0c18 + 0x01000140 + 0x00000c10 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00dcba98 + 0x00000000 + 0x00dcba98 + 0x01000000 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0000002a + 0x00000015 + 0x00000015 + 0x0000002a + 0x00000033 + 0x0000000c + 0x0000000c + 0x00000033 + 0x0a418820 + 0x003f0000 + 0x0000003f + 0x00030055 + 0x03000300 + 0x03000300 + 0x000c0300 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0000002a + 0x00000015 + 0x00000015 + 0x0000002a + 0x00000033 + 0x0000000c + 0x0000000c + 0x00000033 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00030055 + 0x03000300 + 0x03000300 + 0x000c0300 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000002 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00400320 + 0x00000040 + 0x00000000 + 0x00000000 + 0x00000000 + 0x01000000 + 0x00020003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x0000002a + 0x00000015 + 0x00000015 + 0x0000002a + 0x00000033 + 0x0000000c + 0x0000000c + 0x00000033 + 0x1ee6b16a + 0x10000000 + 0x00000000 + 0x00030055 + 0x03000300 + 0x03000300 + 0x000c0300 + 0x42080010 + 0x00000003 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000005 + 0x04000f01 + 0x00020040 + 0x00020055 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000050 + 0x00000000 + 0x01010100 + 0x00000600 + 0x00000000 + 0x00006400 + 0x09221902 + 0x00000000 + 0x000d1f01 + 0x0d1f0d1f + 0x0d1f0d1f + 0x00030003 + 0x03000300 + 0x00000300 + 0x09221902 + 0x00000000 + 0x00000000 + 0x01020000 + 0x00000001 + 0x00000411 + 0x00000411 + 0x00000040 + 0x00000040 + 0x00000411 + 0x00000411 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00004410 + 0x00000411 + 0x00004410 + 0x00000411 + 0x00004410 + 0x00000411 + 0x00004410 + 0x00000000 + 0x00000000 + 0x00000000 + 0x64000000 + 0x00000000 + 0x00000000 + 0x00000108 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0x00000000 + 0xe4000000 + 0x00000000 + 0x00000000 + 0x01010000 + 0x00000000 + >; +};
Use LPDDR4-100 sdram timings dtsi for Rockpro64 board.
All these timings are processed during TPL stage of rockpro64 board, bootchain. This make TPL would replace rockchip in house rkbin in current bootchain.
Bootchain after and before this change:
TPL -> SPL -> U-Boot proper
rkbin -> SPL -> U-Boot proper
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi index 7bddc3acdb..dbfa4ba9f8 100644 --- a/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rockpro64-u-boot.dtsi @@ -4,3 +4,4 @@ */
#include "rk3399-u-boot.dtsi" +#include "rk3399-sdram-lpddr4-100.dtsi"
Use LPDDR4-100 sdram timings dtsi for RockPI-4 board.
All these timings are processed during TPL stage of rock-pi-4 board, bootchain. This make TPL would replace rockchip in house rkbin in current bootchain.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi b/arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi index 7bddc3acdb..dbfa4ba9f8 100644 --- a/arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi +++ b/arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi @@ -4,3 +4,4 @@ */
On Mon, Jun 17, 2019 at 12:37 AM Jagan Teki jagan@amarulasolutions.com wrote:
This is the v2 set for supporting LPDDR4 with associated features, wrt to previous series[1].
Thanks to
- YouMin Chen
- Akash Gajjar
- Kever Yang
for supporting all the help on this work.
On summary this series support
- Code warning and fixes
- rank detection, this would required to probe single channel sdram configured in NanoPI-NEO4
- LPDDR4 support, tested in Rockpro64 and Rock-PI-4
Changes for v2:
- handle LPDDR4 code as part of CONFIG_RAM_RK3399_LPDDR4
- support data_training and set_rate via sdram_rk3399_ops
- add proper sys_reg_enc macros
- add new patch to rename variable sdram_params with params
- fix few commit messages
patch 0001 - 0034: fix code warnings, prints, new macros
patch 0035 - 0052: rank detection, sdram debug code
patch 0053: use DDR3-1800 on NanoPI-NEO4
patch 0054 - 0094: lpddr4 support
patch 0095: enable lpddr4 in Rockpro64
patch 0096: enable lpddr4 in Rock-PI-4
patch 0097: LPDDR4-100 timings
patch 0098: Use LPDDR4-100 on Rockpro64
patch 0099: Use LPDDR4-100 on Rock-PI 4
Size (increased to ~3KiB ):
- Puma RK3399 (u-boot-spl-dtb.bin): before: 115644 after: 118744
- NanoPI M4 (u-boot-tpl-dtb.bin) before: 41873 after: 44909
Travis-CI: https://travis-ci.org/openedev/u-boot-amarula/builds/546597944
Repo: https://github.com/openedev/u-boot-amarula/tree/rk3399-lpddr4
[1] https://patchwork.ozlabs.org/cover/1113893/
Any inputs?
Was it absolutely necessary to split these changes into 99 commits? I believe at least some of them can be squashed. Reviewing 99 patches isn't feasible.
Jagan.
Jagan Teki (99): ram: rk3399: Fix code warnings ram: rk3399: Add space between string with format specifier ram: rk3399: Add proper spaces in code ram: rk3399: s/sdram_params/params ram: rk3399: Handle data training return types ram: rk3399: Order include files ram: rk3399: Move macro after include files ram: rk3399: Clear PI_175 interrupts in data training ram: rk3399: Use rank mask in ca data training ram: rk3399: Use rank mask in wdql data training ram: rk3399: Add ddrtype enc macro ram: rk3399: Add channel number encoder macro ram: rk3399: Add row_3_4 enc macro ram: rk3399: Add chipinfo macro ram: rk3399: Add rank enc macro ram: rk3399: Add column enc macro ram: rk3399: Add bk enc macro ram: rk3399: Add dbw enc macro ram: rk3399: Add cs0_rw macro ram: rk3399: Add cs1_rw macro ram: rk3399: Add bw enc macro ram: rk3399: Rename sys_reg with sys_reg2 ram: rk3399: Update cs0_row to use sys_reg3 ram: rk3399: Update cs1_row to use sys_reg3 ram: rk3399: Add cs1_col enc macro ram: rk3399: Add ddr version enc macro ram: rk3399: Add ddrtimingC0 ram: rk3399: Add DdrMode ram: rk3399: Handle pctl_cfg return type ram: rk3399: s/tsel_wr_select_n/tsel_wr_select_dq_n ram: rk3399: s/tsel_wr_select_p/tsel_wr_select_dq_p ram: rk3399: s/ca_tsel_wr_select_n/tsel_wr_select_ca_n ram: rk3399: s/ca_tsel_wr_select_p/tsel_wr_select_ca_p ram: rk3399: Order tsel variables ram: rk3399: Add phy pctrl reset support ram: rk3399: Move pwrup_srefresh_exit to dram_info ram: rk3399: Add pctl start support ram: rockchip: rk3399: Add cap_info structure ram: rk3399: s/rk3399_base_params/sdram_base_params ram: rk3399: Move common sdram structures in common header arm: include: rockchip: Move dramtypes to common header arm: include: rockchip: Add DDR4 enum ram: rockchip: Add initial Kconfig debug_uart: Add printdec ram: rockchip: Add debug sdram driver ram: rockchip: debug: Add sdram_print_ddr_info ram: rockchip: debug: Get the cs capacity ram: rk3399: debug: Add sdram_print_stride ram: rk3399: Compute stride for 2 channels ram: rk3399: Compute stride for 1 channel a ram: rk3399: Add rank detection support ram: rk3399: Enable sdram debug functions rockchip: dts: rk3399: nanopi-neo4: Use DDR3-1866 dtsi clk: rockchip: rk3399: Fix check patch warnings and checks clk: rockchip: rk3399: Set 50MHz ddr clock clk: rockchip: rk3399: Set 400MHz ddr clock ram: rk3399: Add spaces in pctl_cfg ram: rk3399: Configure phy IO in ds odt ram: rockchip: Kconfig: Add RK3399 LPDDR4 entry ram: rk3399: Add lpddr4 rank mask for ca training ram: rk3399: Add lpddr4 rank mask for wdql training ram: rk3399: Move mode_sel assignment ram: rk3399: Don't wait for PLL lock in lpddr4 ram: rk3399: Avoid two channel ZQ Cal Start at the same time ram: rk3399: Configure PHY_898, PHY_919 for lpddr4 ram: rk3399: Configure BOOSTP_EN, BOOSTN_EN for lpddr4 ram: rk3399: Configure SLEWP_EN, SLEWN_EN for lpddr4 ram: rk3399: Configure PHY RX_CM_INPUT for lpddr4 ram: rk3399: Map chipselect for lpddr4 ram: rk3399: Configure tsel write ca for lpddr4 ram: rk3399: Don't disable dfi dram clk for lpddr4, rank 1 ram: rk3399: Add IO settings ram: sdram: Configure lpddr4 tsel rd, wr based on IO settings ram: rk3399: Add tsel control clock drive ram: rk3399: Configure soc odt support ram: rk3399: Get lpddr4 tsel_rd_en from io settings ram: rk3399: Update lpddr4 vref based on io settings ram: rk3399: Update lpddr4 mode_sel based on io settings ram: rk3399: Update lpddr4 vref_mode_ac ram: rk3399: Simplify data training first argument ram: rk3399: Handle data training via ops ram: rk3399: Add LPPDR4 mr detection arm: include: rockchip: Add rk3399 pmu file rockchip: rk3399: syscon: Add pmu support rockchip: dts: rk3399: Add u-boot,dm-pre-reloc for pmu ram: rk3399: Add LPPDDR4-400 timings inc ram: rk3399: Add LPPDDR4-800 timings inc ram: rk3399: Add set_rate sdram rk3399 ops ram: rk3399: Add lpddr4 set rate support ram: rk3399: Set lpddr4 dq odt ram: rk3399: Set lpddr4 ca odt ram: rk3399: Set lpddr4 MR3 ram: rk3399: Set lpddr4 MR12 ram: rk3399: Set lpddr4 MR14 configs: rockpro64: Enable LPDDR4 support configs: rock-pi-4: Enable LPDDR4 support rockchip: dts: rk3399: Add LPDDR4-100 timings rockchip: dts: rk3399: rockpro64: Use LPDDR4-100 dtsi rockchip: dts: rk3399: rock-pi-4: Use LPDDR4-100 dtsi
arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi | 1 + arch/arm/dts/rk3399-rock-pi-4-u-boot.dtsi | 1 + arch/arm/dts/rk3399-rockpro64-u-boot.dtsi | 1 + arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi | 1537 +++++++++++ arch/arm/dts/rk3399-u-boot.dtsi | 4 + .../include/asm/arch-rockchip/pmu_rk3399.h | 72 + arch/arm/include/asm/arch-rockchip/sdram.h | 6 - .../include/asm/arch-rockchip/sdram_common.h | 90 + .../include/asm/arch-rockchip/sdram_rk322x.h | 7 - .../include/asm/arch-rockchip/sdram_rk3399.h | 65 +- arch/arm/mach-rockchip/rk3399/syscon_rk3399.c | 8 + configs/rock-pi-4-rk3399_defconfig | 1 + configs/rockpro64-rk3399_defconfig | 1 + drivers/clk/rockchip/clk_rk3399.c | 76 +- drivers/ram/Kconfig | 1 + drivers/ram/rockchip/Kconfig | 33 + drivers/ram/rockchip/Makefile | 3 +- .../ram/rockchip/sdram-rk3399-lpddr4-400.inc | 1570 +++++++++++ .../ram/rockchip/sdram-rk3399-lpddr4-800.inc | 1570 +++++++++++ drivers/ram/rockchip/sdram_debug.c | 147 ++ drivers/ram/rockchip/sdram_rk3399.c | 2289 ++++++++++++++--- include/debug_uart.h | 19 + 22 files changed, 7035 insertions(+), 467 deletions(-) create mode 100644 arch/arm/dts/rk3399-sdram-lpddr4-100.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/pmu_rk3399.h create mode 100644 drivers/ram/rockchip/Kconfig create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-400.inc create mode 100644 drivers/ram/rockchip/sdram-rk3399-lpddr4-800.inc create mode 100644 drivers/ram/rockchip/sdram_debug.c
-- 2.18.0.321.gffc6fa0e3
Hi Vasily,
Thanks to
- YouMin Chen
- Akash Gajjar
- Kever Yang
Changes for v2:
Any inputs?
Squashed, I'm not sure because the patches were created to satisfy the bisectability and travis-ci, if you find any please feel to comment. About the commit count, I have mentioned in v1, the idea of having many commits in one series to have all lpddr4(-related) changes in one place and also all the commit has incremental approach of supporting rank detection and lpddr4. If require I'm open to sent next versions as multiple series, no problem on that.
Jagan.
Hi Jagan,
Thanks for your hard work. I'm sure everyone in the Rockchip community is excited about finally having this support in U-Boot.
On Tue, 25 Jun 2019 at 12:46, Jagan Teki jagan@amarulasolutions.com wrote: [..]
I strongly agree with Vasily, and I don't think multiple series makes it any better.
What's the reason for having two commits for:
"ram: rk3399: Set lpddr4 MR3" and "ram: rk3399: Set lpddr4 MR12" ?
Or splitting all the "ram: rk3399: Add ... macro" ?
What do you loose if you merge the patches into one?
I must confess I am very surprised, and don't really understand what do you gain with this excessive split. Normally, when we are adding a new feature, we normally don't need many patches, so it's the other way around, really.
Bisectability is about not breaking existing support, but because the feature is new, normally this is easy.
Thanks again! Eze
On Wed, Jun 26, 2019 at 12:12 AM Ezequiel Garcia ezequiel@vanguardiasur.com.ar wrote:
Hi Jagan,
These are individual lpddr4 set rate registers to support, each one is independent on it' own initialization and more over on the whole, it is critical to review.
You mean the patches 13 to 20 same like above each one has it's own meaning. It is not meaningful to squash them all.
Look, like the whole confusion seems to be because of more patches in one series and the cover-letter states that it support lpddr4. I understand it now, will send the relevant changes in next version accordingly, if require I will squash if any.
Jagan.
Jagan,
Hi Jagan,
99 patches is really too much, but I'm not sure how smaller it can be. Reference to kernel document, it suggest not more than 15 at one time: NO!!!! No more huge patch bombs to linux-kernel@vger.kernel.org people! https://lkml.org/lkml/2005/7/11/336 But please note that I don't think split this into different series make any sense. But maybe you can try to squash as much as you can. eg. the update for dram_all_config may able to squash into one patch, and some new MACRO and its reference code may be able to squash. So it depends on how you define about _logical change_. I'm not sure if this have happen in the history of U-Boot mailing list, but I think this big patch set will be complained by many people if this is send to kernel.
I would need to review all the code one by one, and merge them all at one time, so it does not affect much about my review, but for U-Boot patch submit requirement, I'm not sure if any suggestion from other maintainers.
Thanks, - Kever
Jagan.
Linux-rockchip mailing list Linux-rockchip@lists.infradead.org http://lists.infradead.org/mailman/listinfo/linux-rockchip
Hi Kever,
On Thu, Jul 4, 2019 at 3:57 PM Kever Yang kever.yang@rock-chips.com wrote:
Jagan,
Hi Jagan,
Agreed.
NO!!!! No more huge patch bombs to linux-kernel@vger.kernel.org people! <https://lkml.org/lkml/2005/7/11/336> But please note that I don't think split this into different series make any sense. But maybe you can try to squash as much as you can. eg. the update for dram_all_config may able to squash into one patch,
I don't mean to split the lpddr4 changes into multiple series. what I'm trying to say here is this series has patches that support code warnings, rank detection. Since each of them has it own identical features, I'm planning to send them first. and will squash what it require on lpddr4.
Will that be okay for you?
Jagan,
On 07/04/2019 06:54 PM, Jagan Teki wrote:
Hi Kever,
Jagan,
Hi Jagan,
Agreed.
That's OK for me, just need to let people know the patch set dependency.
Thanks, - Kever
From: Jagan Teki jagan@amarulasolutions.com Date: Mon, 17 Jun 2019 13:01:13 +0530
Thanks to
- YouMin Chen
- Akash Gajjar
- Kever Yang
Changes for v2:
Any inputs? Jagan.
Tested on rockpro64 and firefly-rk3399. Both boards work with this diff provided I apply the two "boot-on" regulator diffs that I posted a couple of days ago. A significant improvement for rockpro64 and no regression for firefly-rk3399. So:
Tested-by: Mark Kettenis kettenis@openbsd.org
Jagan Teki jagan@amarulasolutions.com writes:
Sorry for a late follow-up, but I've just tested this series (applied to today's master branch) on Khadas Edge.
With these patches, a device tree copied from Linux -next, and a defconfig essentially the same as the Rock Pi 4 one, this rk3399 board boots fine via U-Boot TPL instead of Rockchip idbloader.
I have the trivial patch which adds the Khadas Edge device tree and defconfig, but presumably I can't usefully post it before your series is merged. Unless you'd like to pick up that patch too as an additional one in the LPDDR4 series?
Best wishes, Chris.
participants (6)
Chris Webb
Ezequiel Garcia
Jagan Teki
Kever Yang
Mark Kettenis
Vasily Khoruzhick
