[PATCH v3 0/6] Add rt-thread art-pi board support
These patches aim to adds u-boot support on art-pi board.
the board resources: - stm32h750xbh6 128k flash, 1024k sram - 32MiB sdram - 16MiB spi flash - 8MiB qspi flash - onboard wifi, bt, fm
the detail board information can be found at: https://art-pi.gitee.io/website/
--- changes in v3: two mirror changes in [PATCH v3 2/6], others same to version 2 - remove "for STMicroelectronics." from arch/arm/dts/stm32h750-pinctrl.dtsi - correct misspelling parameters you can found detail patch v2 information at link: https://patchwork.ozlabs.org/project/uboot/list/?series=236009
changes in v2: - fix wrong author/date in previous submit - sync with kernel device tree files - add st,stm32h750-pinctrl in doc and pinctrl driver
*** BLURB HERE ***
dillon min (6): ARM: dts: stm32: split sdram pin & timing parameter into specific board dts ARM: dts: stm32: Add RT-Thread art-pi board support board: Add rt-thread art-pi board support ram: stm32: fix strsep failed on read only memory dt-bindings: pinctrl: stm32: Add st,stm32h750-pinctrl for stm32h750 soc pinctrl: stm32: Add st,stm32h750-pinctrl compatible string
arch/arm/dts/Makefile | 3 +- arch/arm/dts/stm32h7-pinctrl.dtsi | 340 +++++++++++++++++++++ arch/arm/dts/stm32h7-u-boot.dtsi | 100 +----- arch/arm/dts/stm32h743-pinctrl.dtsi | 307 +------------------ arch/arm/dts/stm32h743.dtsi | 168 +++++++++- arch/arm/dts/stm32h743i-disco-u-boot.dtsi | 98 ++++++ arch/arm/dts/stm32h743i-eval-u-boot.dtsi | 98 ++++++ arch/arm/dts/stm32h750-pinctrl.dtsi | 11 + arch/arm/dts/stm32h750.dtsi | 5 + arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi | 81 +++++ arch/arm/dts/stm32h750i-art-pi.dts | 188 ++++++++++++ arch/arm/mach-stm32/stm32h7/Kconfig | 4 + board/st/stm32h750-art-pi/Kconfig | 19 ++ board/st/stm32h750-art-pi/MAINTAINERS | 7 + board/st/stm32h750-art-pi/Makefile | 6 + board/st/stm32h750-art-pi/stm32h750-art-pi.c | 58 ++++ configs/stm32h750-art-pi_defconfig | 51 ++++ .../pinctrl/st,stm32-pinctrl.txt | 1 + drivers/pinctrl/pinctrl_stm32.c | 1 + drivers/ram/stm32_sdram.c | 3 + include/configs/stm32h750-art-pi.h | 48 +++ include/dt-bindings/memory/stm32-sdram.h | 2 + 22 files changed, 1198 insertions(+), 401 deletions(-) create mode 100644 arch/arm/dts/stm32h7-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h750-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h750.dtsi create mode 100644 arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi create mode 100644 arch/arm/dts/stm32h750i-art-pi.dts create mode 100644 board/st/stm32h750-art-pi/Kconfig create mode 100644 board/st/stm32h750-art-pi/MAINTAINERS create mode 100644 board/st/stm32h750-art-pi/Makefile create mode 100644 board/st/stm32h750-art-pi/stm32h750-art-pi.c create mode 100644 configs/stm32h750-art-pi_defconfig create mode 100644 include/configs/stm32h750-art-pi.h
As different boards has their own sdram hw connection, mount different sdram modules, so move sdram timing parameter and pin configuration to their board device tree.
Signed-off-by: dillon min dillon.minfei@gmail.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com --- v3: no changes
arch/arm/dts/stm32h7-u-boot.dtsi | 100 ++---------------------------- arch/arm/dts/stm32h743i-disco-u-boot.dtsi | 98 +++++++++++++++++++++++++++++ arch/arm/dts/stm32h743i-eval-u-boot.dtsi | 98 +++++++++++++++++++++++++++++ 3 files changed, 201 insertions(+), 95 deletions(-)
diff --git a/arch/arm/dts/stm32h7-u-boot.dtsi b/arch/arm/dts/stm32h7-u-boot.dtsi index 54dd406..84dc765 100644 --- a/arch/arm/dts/stm32h7-u-boot.dtsi +++ b/arch/arm/dts/stm32h7-u-boot.dtsi @@ -20,6 +20,7 @@ gpio9 = &gpioj; gpio10 = &gpiok; mmc0 = &sdmmc1; + pinctrl0 = &pinctrl; };
soc { @@ -36,30 +37,6 @@ pinctrl-0 = <&fmc_pins>; pinctrl-names = "default"; status = "okay"; - - /* - * Memory configuration from sdram datasheet IS42S32800G-6BLI - * first bank is bank@0 - * second bank is bank@1 - */ - bank1: bank@1 { - st,sdram-control = /bits/ 8 <NO_COL_9 - NO_ROW_12 - MWIDTH_32 - BANKS_4 - CAS_2 - SDCLK_3 - RD_BURST_EN - RD_PIPE_DL_0>; - st,sdram-timing = /bits/ 8 <TMRD_1 - TXSR_1 - TRAS_1 - TRC_6 - TRP_2 - TWR_1 - TRCD_1>; - st,sdram-refcount = <1539>; - }; }; }; }; @@ -136,77 +113,6 @@ compatible = "st,stm32-gpio"; };
-&pinctrl { - fmc_pins: fmc@0 { - pins { - pinmux = <STM32_PINMUX('D', 0, AF12)>, - <STM32_PINMUX('D', 1, AF12)>, - <STM32_PINMUX('D', 8, AF12)>, - <STM32_PINMUX('D', 9, AF12)>, - <STM32_PINMUX('D',10, AF12)>, - <STM32_PINMUX('D',14, AF12)>, - <STM32_PINMUX('D',15, AF12)>, - - <STM32_PINMUX('E', 0, AF12)>, - <STM32_PINMUX('E', 1, AF12)>, - <STM32_PINMUX('E', 7, AF12)>, - <STM32_PINMUX('E', 8, AF12)>, - <STM32_PINMUX('E', 9, AF12)>, - <STM32_PINMUX('E',10, AF12)>, - <STM32_PINMUX('E',11, AF12)>, - <STM32_PINMUX('E',12, AF12)>, - <STM32_PINMUX('E',13, AF12)>, - <STM32_PINMUX('E',14, AF12)>, - <STM32_PINMUX('E',15, AF12)>, - - <STM32_PINMUX('F', 0, AF12)>, - <STM32_PINMUX('F', 1, AF12)>, - <STM32_PINMUX('F', 2, AF12)>, - <STM32_PINMUX('F', 3, AF12)>, - <STM32_PINMUX('F', 4, AF12)>, - <STM32_PINMUX('F', 5, AF12)>, - <STM32_PINMUX('F',11, AF12)>, - <STM32_PINMUX('F',12, AF12)>, - <STM32_PINMUX('F',13, AF12)>, - <STM32_PINMUX('F',14, AF12)>, - <STM32_PINMUX('F',15, AF12)>, - - <STM32_PINMUX('G', 0, AF12)>, - <STM32_PINMUX('G', 1, AF12)>, - <STM32_PINMUX('G', 2, AF12)>, - <STM32_PINMUX('G', 4, AF12)>, - <STM32_PINMUX('G', 5, AF12)>, - <STM32_PINMUX('G', 8, AF12)>, - <STM32_PINMUX('G',15, AF12)>, - - <STM32_PINMUX('H', 5, AF12)>, - <STM32_PINMUX('H', 6, AF12)>, - <STM32_PINMUX('H', 7, AF12)>, - <STM32_PINMUX('H', 8, AF12)>, - <STM32_PINMUX('H', 9, AF12)>, - <STM32_PINMUX('H',10, AF12)>, - <STM32_PINMUX('H',11, AF12)>, - <STM32_PINMUX('H',12, AF12)>, - <STM32_PINMUX('H',13, AF12)>, - <STM32_PINMUX('H',14, AF12)>, - <STM32_PINMUX('H',15, AF12)>, - - <STM32_PINMUX('I', 0, AF12)>, - <STM32_PINMUX('I', 1, AF12)>, - <STM32_PINMUX('I', 2, AF12)>, - <STM32_PINMUX('I', 3, AF12)>, - <STM32_PINMUX('I', 4, AF12)>, - <STM32_PINMUX('I', 5, AF12)>, - <STM32_PINMUX('I', 6, AF12)>, - <STM32_PINMUX('I', 7, AF12)>, - <STM32_PINMUX('I', 9, AF12)>, - <STM32_PINMUX('I',10, AF12)>; - - slew-rate = <3>; - }; - }; -}; - &pwrcfg { u-boot,dm-pre-reloc; }; @@ -222,3 +128,7 @@ &timer5 { u-boot,dm-pre-reloc; }; + +&pinctrl { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/stm32h743i-disco-u-boot.dtsi b/arch/arm/dts/stm32h743i-disco-u-boot.dtsi index 5965afc..02e28c6 100644 --- a/arch/arm/dts/stm32h743i-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32h743i-disco-u-boot.dtsi @@ -1,3 +1,101 @@ // SPDX-License-Identifier: GPL-2.0+
#include <stm32h7-u-boot.dtsi> + +&fmc { + + /* + * Memory configuration from sdram datasheet IS42S32800G-6BLI + * first bank is bank@0 + * second bank is bank@1 + */ + bank1: bank@1 { + st,sdram-control = /bits/ 8 <NO_COL_9 + NO_ROW_12 + MWIDTH_32 + BANKS_4 + CAS_2 + SDCLK_3 + RD_BURST_EN + RD_PIPE_DL_0>; + st,sdram-timing = /bits/ 8 <TMRD_1 + TXSR_1 + TRAS_1 + TRC_6 + TRP_2 + TWR_1 + TRCD_1>; + st,sdram-refcount = <1539>; + }; +}; + +&pinctrl { + fmc_pins: fmc@0 { + pins { + pinmux = <STM32_PINMUX('D', 0, AF12)>, + <STM32_PINMUX('D', 1, AF12)>, + <STM32_PINMUX('D', 8, AF12)>, + <STM32_PINMUX('D', 9, AF12)>, + <STM32_PINMUX('D',10, AF12)>, + <STM32_PINMUX('D',14, AF12)>, + <STM32_PINMUX('D',15, AF12)>, + + <STM32_PINMUX('E', 0, AF12)>, + <STM32_PINMUX('E', 1, AF12)>, + <STM32_PINMUX('E', 7, AF12)>, + <STM32_PINMUX('E', 8, AF12)>, + <STM32_PINMUX('E', 9, AF12)>, + <STM32_PINMUX('E',10, AF12)>, + <STM32_PINMUX('E',11, AF12)>, + <STM32_PINMUX('E',12, AF12)>, + <STM32_PINMUX('E',13, AF12)>, + <STM32_PINMUX('E',14, AF12)>, + <STM32_PINMUX('E',15, AF12)>, + + <STM32_PINMUX('F', 0, AF12)>, + <STM32_PINMUX('F', 1, AF12)>, + <STM32_PINMUX('F', 2, AF12)>, + <STM32_PINMUX('F', 3, AF12)>, + <STM32_PINMUX('F', 4, AF12)>, + <STM32_PINMUX('F', 5, AF12)>, + <STM32_PINMUX('F',11, AF12)>, + <STM32_PINMUX('F',12, AF12)>, + <STM32_PINMUX('F',13, AF12)>, + <STM32_PINMUX('F',14, AF12)>, + <STM32_PINMUX('F',15, AF12)>, + + <STM32_PINMUX('G', 0, AF12)>, + <STM32_PINMUX('G', 1, AF12)>, + <STM32_PINMUX('G', 2, AF12)>, + <STM32_PINMUX('G', 4, AF12)>, + <STM32_PINMUX('G', 5, AF12)>, + <STM32_PINMUX('G', 8, AF12)>, + <STM32_PINMUX('G',15, AF12)>, + + <STM32_PINMUX('H', 5, AF12)>, + <STM32_PINMUX('H', 6, AF12)>, + <STM32_PINMUX('H', 7, AF12)>, + <STM32_PINMUX('H', 8, AF12)>, + <STM32_PINMUX('H', 9, AF12)>, + <STM32_PINMUX('H',10, AF12)>, + <STM32_PINMUX('H',11, AF12)>, + <STM32_PINMUX('H',12, AF12)>, + <STM32_PINMUX('H',13, AF12)>, + <STM32_PINMUX('H',14, AF12)>, + <STM32_PINMUX('H',15, AF12)>, + + <STM32_PINMUX('I', 0, AF12)>, + <STM32_PINMUX('I', 1, AF12)>, + <STM32_PINMUX('I', 2, AF12)>, + <STM32_PINMUX('I', 3, AF12)>, + <STM32_PINMUX('I', 4, AF12)>, + <STM32_PINMUX('I', 5, AF12)>, + <STM32_PINMUX('I', 6, AF12)>, + <STM32_PINMUX('I', 7, AF12)>, + <STM32_PINMUX('I', 9, AF12)>, + <STM32_PINMUX('I',10, AF12)>; + + slew-rate = <3>; + }; + }; +}; diff --git a/arch/arm/dts/stm32h743i-eval-u-boot.dtsi b/arch/arm/dts/stm32h743i-eval-u-boot.dtsi index 5965afc..02e28c6 100644 --- a/arch/arm/dts/stm32h743i-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32h743i-eval-u-boot.dtsi @@ -1,3 +1,101 @@ // SPDX-License-Identifier: GPL-2.0+
All these files are add for support rt-thread art-pi board
Add following changes to sync with kernel device tree files: - add stm32h7-pinctrl.dtsi to include pin defines for all stm32h743/50 boards - add stm32h7(5/3)0-pinctrl.dtsi - move gpio(a..k) register defines to stm32h743.dtsi, sync with kernel - introduce stm32h750i-art-pi-u-boot.dtsi for sdram parameters, fmc pins
Signed-off-by: dillon min dillon.minfei@gmail.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com --- v3: - remove "for STMicroelectronics." from arch/arm/dts/stm32h750-pinctrl.dtsi - correct misspelling parameters
arch/arm/dts/Makefile | 3 +- arch/arm/dts/stm32h7-pinctrl.dtsi | 340 +++++++++++++++++++++++++++++ arch/arm/dts/stm32h743-pinctrl.dtsi | 307 +------------------------- arch/arm/dts/stm32h743.dtsi | 168 +++++++++++++- arch/arm/dts/stm32h750-pinctrl.dtsi | 11 + arch/arm/dts/stm32h750.dtsi | 5 + arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi | 81 +++++++ arch/arm/dts/stm32h750i-art-pi.dts | 188 ++++++++++++++++ include/dt-bindings/memory/stm32-sdram.h | 2 + 9 files changed, 799 insertions(+), 306 deletions(-) create mode 100644 arch/arm/dts/stm32h7-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h750-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32h750.dtsi create mode 100644 arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi create mode 100644 arch/arm/dts/stm32h750i-art-pi.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c671082..0f54801 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -454,7 +454,8 @@ dtb-$(CONFIG_STM32F7) += stm32f746-disco.dtb \ stm32f769-disco.dtb \ stm32746g-eval.dtb dtb-$(CONFIG_STM32H7) += stm32h743i-disco.dtb \ - stm32h743i-eval.dtb + stm32h743i-eval.dtb \ + stm32h750i-art-pi.dtb
dtb-$(CONFIG_MACH_SUN4I) += \ sun4i-a10-a1000.dtb \ diff --git a/arch/arm/dts/stm32h7-pinctrl.dtsi b/arch/arm/dts/stm32h7-pinctrl.dtsi new file mode 100644 index 0000000..ebfd165 --- /dev/null +++ b/arch/arm/dts/stm32h7-pinctrl.dtsi @@ -0,0 +1,340 @@ +/* + * Copyright 2017 - Alexandre Torgue alexandre.torgue@st.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include <dt-bindings/pinctrl/stm32-pinfunc.h> + +&pinctrl { + + gpioa: gpio@58020000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@58020400 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@58020800 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@58020c00 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@58021000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@58021400 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 80 16>; + }; + + gpiog: gpio@58021800 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 96 16>; + }; + + gpioh: gpio@58021c00 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 112 16>; + }; + + gpioi: gpio@58022000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 128 16>; + }; + + gpioj: gpio@58022400 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 144 16>; + }; + + gpiok: gpio@58022800 { + status = "okay"; + ngpios = <8>; + gpio-ranges = <&pinctrl 0 160 8>; + }; + + i2c1_pins_a: i2c1-0 { + pins { + pinmux = <STM32_PINMUX('B', 6, AF4)>, /* I2C1_SCL */ + <STM32_PINMUX('B', 7, AF4)>; /* I2C1_SDA */ + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + + ethernet_rmii: rmii-0 { + pins { + pinmux = <STM32_PINMUX('G', 11, AF11)>, + <STM32_PINMUX('G', 13, AF11)>, + <STM32_PINMUX('G', 12, AF11)>, + <STM32_PINMUX('C', 4, AF11)>, + <STM32_PINMUX('C', 5, AF11)>, + <STM32_PINMUX('A', 7, AF11)>, + <STM32_PINMUX('C', 1, AF11)>, + <STM32_PINMUX('A', 2, AF11)>, + <STM32_PINMUX('A', 1, AF11)>; + slew-rate = <2>; + }; + }; + + sdmmc1_b4_pins_a: sdmmc1-b4-0 { + pins { + pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, AF12)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ + slew-rate = <3>; + drive-push-pull; + bias-disable; + }; + }; + + sdmmc1_b4_od_pins_a: sdmmc1-b4-od-0 { + pins1 { + pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, AF12)>; /* SDMMC1_CK */ + slew-rate = <3>; + drive-push-pull; + bias-disable; + }; + pins2{ + pinmux = <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ + slew-rate = <3>; + drive-open-drain; + bias-disable; + }; + }; + + sdmmc1_b4_sleep_pins_a: sdmmc1-b4-sleep-0 { + pins { + pinmux = <STM32_PINMUX('C', 8, ANALOG)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, ANALOG)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, ANALOG)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, ANALOG)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, ANALOG)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 2, ANALOG)>; /* SDMMC1_CMD */ + }; + }; + + sdmmc2_b4_pins_a: sdmmc2-b4-0 { + pins { + pinmux = <STM32_PINMUX('B', 14, AF9)>, /* SDMMC1_D0 */ + <STM32_PINMUX('B', 15, AF9)>, /* SDMMC1_D1 */ + <STM32_PINMUX('B', 3, AF9)>, /* SDMMC1_D2 */ + <STM32_PINMUX('B', 4, AF9)>, /* SDMMC1_D3 */ + <STM32_PINMUX('D', 6, AF11)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 7, AF11)>; /* SDMMC1_CMD */ + slew-rate = <3>; + drive-push-pull; + bias-disable; + }; + }; + + sdmmc2_b4_od_pins_a: sdmmc2-b4-od-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 14, AF9)>, /* SDMMC2_D0 */ + <STM32_PINMUX('B', 15, AF9)>, /* SDMMC1_D1 */ + <STM32_PINMUX('B', 3, AF9)>, /* SDMMC1_D2 */ + <STM32_PINMUX('B', 4, AF9)>, /* SDMMC1_D3 */ + <STM32_PINMUX('D', 6, AF11)>; /* SDMMC1_CK */ + slew-rate = <3>; + drive-push-pull; + bias-disable; + }; + pins2{ + pinmux = <STM32_PINMUX('D', 7, AF11)>; /* SDMMC1_CMD */ + slew-rate = <3>; + drive-open-drain; + bias-disable; + }; + }; + + sdmmc2_b4_sleep_pins_a: sdmmc2-b4-sleep-0 { + pins { + pinmux = <STM32_PINMUX('B', 14, ANALOG)>, /* SDMMC1_D0 */ + <STM32_PINMUX('B', 15, ANALOG)>, /* SDMMC1_D1 */ + <STM32_PINMUX('B', 3, ANALOG)>, /* SDMMC1_D2 */ + <STM32_PINMUX('B', 4, ANALOG)>, /* SDMMC1_D3 */ + <STM32_PINMUX('D', 6, ANALOG)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 7, ANALOG)>; /* SDMMC1_CMD */ + }; + }; + + sdmmc1_dir_pins_a: sdmmc1-dir-0 { + pins1 { + pinmux = <STM32_PINMUX('C', 6, AF8)>, /* SDMMC1_D0DIR */ + <STM32_PINMUX('C', 7, AF8)>, /* SDMMC1_D123DIR */ + <STM32_PINMUX('B', 9, AF7)>; /* SDMMC1_CDIR */ + slew-rate = <3>; + drive-push-pull; + bias-pull-up; + }; + pins2{ + pinmux = <STM32_PINMUX('B', 8, AF7)>; /* SDMMC1_CKIN */ + bias-pull-up; + }; + }; + + sdmmc1_dir_sleep_pins_a: sdmmc1-dir-sleep-0 { + pins { + pinmux = <STM32_PINMUX('C', 6, ANALOG)>, /* SDMMC1_D0DIR */ + <STM32_PINMUX('C', 7, ANALOG)>, /* SDMMC1_D123DIR */ + <STM32_PINMUX('B', 9, ANALOG)>, /* SDMMC1_CDIR */ + <STM32_PINMUX('B', 8, ANALOG)>; /* SDMMC1_CKIN */ + }; + }; + + usart1_pins: usart1-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 14, AF4)>; /* USART1_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('B', 15, AF4)>; /* USART1_RX */ + bias-disable; + }; + }; + + usart2_pins: usart2-0 { + pins1 { + pinmux = <STM32_PINMUX('D', 5, AF7)>; /* USART2_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('D', 6, AF7)>; /* USART2_RX */ + bias-disable; + }; + }; + + usart3_pins: usart3-0 { + pins1 { + pinmux = <STM32_PINMUX('B', 10, AF7)>, /* USART3_TX */ + <STM32_PINMUX('D', 12, AF7)>; /* USART3_RTS_DE */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('B', 11, AF7)>, /* USART3_RX */ + <STM32_PINMUX('D', 11, AF7)>; /* USART3_CTS_NSS */ + bias-disable; + }; + }; + + uart4_pins: uart4-0 { + pins1 { + pinmux = <STM32_PINMUX('A', 0, AF8)>; /* UART4_TX */ + bias-disable; + drive-push-pull; + slew-rate = <0>; + }; + pins2 { + pinmux = <STM32_PINMUX('I', 9, AF8)>; /* UART4_RX */ + bias-disable; + }; + }; + + usbotg_hs_pins_a: usbotg-hs-0 { + pins { + pinmux = <STM32_PINMUX('H', 4, AF10)>, /* ULPI_NXT */ + <STM32_PINMUX('I', 11, AF10)>, /* ULPI_DIR> */ + <STM32_PINMUX('C', 0, AF10)>, /* ULPI_STP> */ + <STM32_PINMUX('A', 5, AF10)>, /* ULPI_CK> */ + <STM32_PINMUX('A', 3, AF10)>, /* ULPI_D0> */ + <STM32_PINMUX('B', 0, AF10)>, /* ULPI_D1> */ + <STM32_PINMUX('B', 1, AF10)>, /* ULPI_D2> */ + <STM32_PINMUX('B', 10, AF10)>, /* ULPI_D3> */ + <STM32_PINMUX('B', 11, AF10)>, /* ULPI_D4> */ + <STM32_PINMUX('B', 12, AF10)>, /* ULPI_D5> */ + <STM32_PINMUX('B', 13, AF10)>, /* ULPI_D6> */ + <STM32_PINMUX('B', 5, AF10)>; /* ULPI_D7> */ + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + }; + + spi1_pins: spi1-0 { + pins1 { + pinmux = <STM32_PINMUX('A', 5, AF5)>, + /* SPI1_CLK */ + <STM32_PINMUX('B', 5, AF5)>; + /* SPI1_MOSI */ + bias-disable; + drive-push-pull; + slew-rate = <2>; + }; + pins2 { + pinmux = <STM32_PINMUX('G', 9, AF5)>; + /* SPI1_MISO */ + bias-disable; + }; + }; +}; diff --git a/arch/arm/dts/stm32h743-pinctrl.dtsi b/arch/arm/dts/stm32h743-pinctrl.dtsi index 141083f..6b1e115 100644 --- a/arch/arm/dts/stm32h743-pinctrl.dtsi +++ b/arch/arm/dts/stm32h743-pinctrl.dtsi @@ -1,306 +1,11 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) /* - * Copyright 2017 - Alexandre Torgue alexandre.torgue@st.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. + * Copyright (C) STMicroelectronics 2017 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com for STMicroelectronics. */
-#include <dt-bindings/pinctrl/stm32-pinfunc.h> +#include "stm32h7-pinctrl.dtsi"
-/ { - soc { - pinctrl: pin-controller { - #address-cells = <1>; - #size-cells = <1>; - compatible = "st,stm32h743-pinctrl"; - ranges = <0 0x58020000 0x3000>; - interrupt-parent = <&exti>; - st,syscfg = <&syscfg 0x8>; - pins-are-numbered; - - gpioa: gpio@58020000 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x0 0x400>; - clocks = <&rcc GPIOA_CK>; - st,bank-name = "GPIOA"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpiob: gpio@58020400 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x400 0x400>; - clocks = <&rcc GPIOB_CK>; - st,bank-name = "GPIOB"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpioc: gpio@58020800 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x800 0x400>; - clocks = <&rcc GPIOC_CK>; - st,bank-name = "GPIOC"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpiod: gpio@58020c00 { - gpio-controller; - #gpio-cells = <2>; - reg = <0xc00 0x400>; - clocks = <&rcc GPIOD_CK>; - st,bank-name = "GPIOD"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpioe: gpio@58021000 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x1000 0x400>; - clocks = <&rcc GPIOE_CK>; - st,bank-name = "GPIOE"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpiof: gpio@58021400 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x1400 0x400>; - clocks = <&rcc GPIOF_CK>; - st,bank-name = "GPIOF"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpiog: gpio@58021800 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x1800 0x400>; - clocks = <&rcc GPIOG_CK>; - st,bank-name = "GPIOG"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpioh: gpio@58021c00 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x1c00 0x400>; - clocks = <&rcc GPIOH_CK>; - st,bank-name = "GPIOH"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpioi: gpio@58022000 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x2000 0x400>; - clocks = <&rcc GPIOI_CK>; - st,bank-name = "GPIOI"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpioj: gpio@58022400 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x2400 0x400>; - clocks = <&rcc GPIOJ_CK>; - st,bank-name = "GPIOJ"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpiok: gpio@58022800 { - gpio-controller; - #gpio-cells = <2>; - reg = <0x2800 0x400>; - clocks = <&rcc GPIOK_CK>; - st,bank-name = "GPIOK"; - interrupt-controller; - #interrupt-cells = <2>; - }; - - i2c1_pins_a: i2c1-0 { - pins { - pinmux = <STM32_PINMUX('B', 6, AF4)>, /* I2C1_SCL */ - <STM32_PINMUX('B', 7, AF4)>; /* I2C1_SDA */ - bias-disable; - drive-open-drain; - slew-rate = <0>; - }; - }; - - ethernet_rmii: rmii-0 { - pins { - pinmux = <STM32_PINMUX('G', 11, AF11)>, - <STM32_PINMUX('G', 13, AF11)>, - <STM32_PINMUX('G', 12, AF11)>, - <STM32_PINMUX('C', 4, AF11)>, - <STM32_PINMUX('C', 5, AF11)>, - <STM32_PINMUX('A', 7, AF11)>, - <STM32_PINMUX('C', 1, AF11)>, - <STM32_PINMUX('A', 2, AF11)>, - <STM32_PINMUX('A', 1, AF11)>; - slew-rate = <2>; - }; - }; - - sdmmc1_b4_pins_a: sdmmc1-b4-0 { - pins { - pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ - <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ - <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ - <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ - <STM32_PINMUX('C', 12, AF12)>, /* SDMMC1_CK */ - <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ - slew-rate = <3>; - drive-push-pull; - bias-disable; - }; - }; - - sdmmc1_b4_od_pins_a: sdmmc1-b4-od-0 { - pins1 { - pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ - <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ - <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ - <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ - <STM32_PINMUX('C', 12, AF12)>; /* SDMMC1_CK */ - slew-rate = <3>; - drive-push-pull; - bias-disable; - }; - pins2{ - pinmux = <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ - slew-rate = <3>; - drive-open-drain; - bias-disable; - }; - }; - - sdmmc1_b4_sleep_pins_a: sdmmc1-b4-sleep-0 { - pins { - pinmux = <STM32_PINMUX('C', 8, ANALOG)>, /* SDMMC1_D0 */ - <STM32_PINMUX('C', 9, ANALOG)>, /* SDMMC1_D1 */ - <STM32_PINMUX('C', 10, ANALOG)>, /* SDMMC1_D2 */ - <STM32_PINMUX('C', 11, ANALOG)>, /* SDMMC1_D3 */ - <STM32_PINMUX('C', 12, ANALOG)>, /* SDMMC1_CK */ - <STM32_PINMUX('D', 2, ANALOG)>; /* SDMMC1_CMD */ - }; - }; - - sdmmc1_dir_pins_a: sdmmc1-dir-0 { - pins1 { - pinmux = <STM32_PINMUX('C', 6, AF8)>, /* SDMMC1_D0DIR */ - <STM32_PINMUX('C', 7, AF8)>, /* SDMMC1_D123DIR */ - <STM32_PINMUX('B', 9, AF7)>; /* SDMMC1_CDIR */ - slew-rate = <3>; - drive-push-pull; - bias-pull-up; - }; - pins2{ - pinmux = <STM32_PINMUX('B', 8, AF7)>; /* SDMMC1_CKIN */ - bias-pull-up; - }; - }; - - sdmmc1_dir_sleep_pins_a: sdmmc1-dir-sleep-0 { - pins { - pinmux = <STM32_PINMUX('C', 6, ANALOG)>, /* SDMMC1_D0DIR */ - <STM32_PINMUX('C', 7, ANALOG)>, /* SDMMC1_D123DIR */ - <STM32_PINMUX('B', 9, ANALOG)>, /* SDMMC1_CDIR */ - <STM32_PINMUX('B', 8, ANALOG)>; /* SDMMC1_CKIN */ - }; - }; - - usart1_pins: usart1-0 { - pins1 { - pinmux = <STM32_PINMUX('B', 14, AF4)>; /* USART1_TX */ - bias-disable; - drive-push-pull; - slew-rate = <0>; - }; - pins2 { - pinmux = <STM32_PINMUX('B', 15, AF4)>; /* USART1_RX */ - bias-disable; - }; - }; - - usart2_pins: usart2-0 { - pins1 { - pinmux = <STM32_PINMUX('D', 5, AF7)>; /* USART2_TX */ - bias-disable; - drive-push-pull; - slew-rate = <0>; - }; - pins2 { - pinmux = <STM32_PINMUX('D', 6, AF7)>; /* USART2_RX */ - bias-disable; - }; - }; - - usbotg_hs_pins_a: usbotg-hs-0 { - pins { - pinmux = <STM32_PINMUX('H', 4, AF10)>, /* ULPI_NXT */ - <STM32_PINMUX('I', 11, AF10)>, /* ULPI_DIR> */ - <STM32_PINMUX('C', 0, AF10)>, /* ULPI_STP> */ - <STM32_PINMUX('A', 5, AF10)>, /* ULPI_CK> */ - <STM32_PINMUX('A', 3, AF10)>, /* ULPI_D0> */ - <STM32_PINMUX('B', 0, AF10)>, /* ULPI_D1> */ - <STM32_PINMUX('B', 1, AF10)>, /* ULPI_D2> */ - <STM32_PINMUX('B', 10, AF10)>, /* ULPI_D3> */ - <STM32_PINMUX('B', 11, AF10)>, /* ULPI_D4> */ - <STM32_PINMUX('B', 12, AF10)>, /* ULPI_D5> */ - <STM32_PINMUX('B', 13, AF10)>, /* ULPI_D6> */ - <STM32_PINMUX('B', 5, AF10)>; /* ULPI_D7> */ - bias-disable; - drive-push-pull; - slew-rate = <2>; - }; - }; - }; - }; +&pinctrl{ + compatible = "st,stm32h743-pinctrl"; }; diff --git a/arch/arm/dts/stm32h743.dtsi b/arch/arm/dts/stm32h743.dtsi index e4e4723..4b4c0b0 100644 --- a/arch/arm/dts/stm32h743.dtsi +++ b/arch/arm/dts/stm32h743.dtsi @@ -99,6 +99,22 @@ clocks = <&rcc USART2_CK>; };
+ usart3: serial@40004800 { + compatible = "st,stm32h7-uart"; + reg = <0x40004800 0x400>; + interrupts = <39>; + status = "disabled"; + clocks = <&rcc USART3_CK>; + }; + + uart4: serial@40004c00 { + compatible = "st,stm32h7-uart"; + reg = <0x40004c00 0x400>; + interrupts = <52>; + status = "disabled"; + clocks = <&rcc UART4_CK>; + }; + i2c1: i2c@40005400 { compatible = "st,stm32f7-i2c"; #address-cells = <1>; @@ -123,7 +139,7 @@ status = "disabled"; };
- i2c3: i2c@40005C00 { + i2c3: i2c@40005c00 { compatible = "st,stm32f7-i2c"; #address-cells = <1>; #size-cells = <0>; @@ -238,7 +254,7 @@
dmamux1: dma-router@40020800 { compatible = "st,stm32h7-dmamux"; - reg = <0x40020800 0x1c>; + reg = <0x40020800 0x40>; #dma-cells = <3>; dma-channels = <16>; dma-requests = <128>; @@ -318,7 +334,7 @@ dma-requests = <32>; };
- sdmmc1: sdmmc@52007000 { + sdmmc1: mmc@52007000 { compatible = "arm,pl18x", "arm,primecell"; arm,primecell-periphid = <0x10153180>; reg = <0x52007000 0x1000>; @@ -332,6 +348,20 @@ max-frequency = <120000000>; };
+ sdmmc2: mmc@48022400 { + compatible = "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x10153180>; + reg = <0x48022400 0x400>; + interrupts = <124>; + interrupt-names = "cmd_irq"; + clocks = <&rcc SDMMC2_CK>; + clock-names = "apb_pclk"; + resets = <&rcc STM32H7_AHB2_RESET(SDMMC2)>; + cap-sd-highspeed; + cap-mmc-highspeed; + max-frequency = <120000000>; + }; + exti: interrupt-controller@58000000 { compatible = "st,stm32h7-exti"; interrupt-controller; @@ -356,7 +386,7 @@ status = "disabled"; };
- i2c4: i2c@58001C00 { + i2c4: i2c@58001c00 { compatible = "st,stm32f7-i2c"; #address-cells = <1>; #size-cells = <0>; @@ -519,6 +549,136 @@ snps,pbl = <8>; status = "disabled"; }; + + pinctrl: pin-controller@58020000 { + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x58020000 0x3000>; + interrupt-parent = <&exti>; + st,syscfg = <&syscfg 0x8>; + pins-are-numbered; + + gpioa: gpio@58020000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x0 0x400>; + clocks = <&rcc GPIOA_CK>; + st,bank-name = "GPIOA"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpiob: gpio@58020400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x400 0x400>; + clocks = <&rcc GPIOB_CK>; + st,bank-name = "GPIOB"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpioc: gpio@58020800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x800 0x400>; + clocks = <&rcc GPIOC_CK>; + st,bank-name = "GPIOC"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpiod: gpio@58020c00 { + gpio-controller; + #gpio-cells = <2>; + reg = <0xc00 0x400>; + clocks = <&rcc GPIOD_CK>; + st,bank-name = "GPIOD"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpioe: gpio@58021000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1000 0x400>; + clocks = <&rcc GPIOE_CK>; + st,bank-name = "GPIOE"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpiof: gpio@58021400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1400 0x400>; + clocks = <&rcc GPIOF_CK>; + st,bank-name = "GPIOF"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpiog: gpio@58021800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1800 0x400>; + clocks = <&rcc GPIOG_CK>; + st,bank-name = "GPIOG"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpioh: gpio@58021c00 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x1c00 0x400>; + clocks = <&rcc GPIOH_CK>; + st,bank-name = "GPIOH"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpioi: gpio@58022000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2000 0x400>; + clocks = <&rcc GPIOI_CK>; + st,bank-name = "GPIOI"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpioj: gpio@58022400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2400 0x400>; + clocks = <&rcc GPIOJ_CK>; + st,bank-name = "GPIOJ"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + + gpiok: gpio@58022800 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x2800 0x400>; + clocks = <&rcc GPIOK_CK>; + st,bank-name = "GPIOK"; + interrupt-controller; + #interrupt-cells = <2>; + status = "disabled"; + }; + }; }; };
diff --git a/arch/arm/dts/stm32h750-pinctrl.dtsi b/arch/arm/dts/stm32h750-pinctrl.dtsi new file mode 100644 index 0000000..57b7ebe --- /dev/null +++ b/arch/arm/dts/stm32h750-pinctrl.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2021 - All Rights Reserved + * Author: Dillon Min dillon.minfei@gmail.com + */ + +#include "stm32h7-pinctrl.dtsi" + +&pinctrl{ + compatible = "st,stm32h750-pinctrl"; +}; diff --git a/arch/arm/dts/stm32h750.dtsi b/arch/arm/dts/stm32h750.dtsi new file mode 100644 index 0000000..99533f3 --- /dev/null +++ b/arch/arm/dts/stm32h750.dtsi @@ -0,0 +1,5 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* Copyright (C) STMicroelectronics 2021 - All Rights Reserved */ + +#include "stm32h743.dtsi" + diff --git a/arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi b/arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi new file mode 100644 index 0000000..326a553 --- /dev/null +++ b/arch/arm/dts/stm32h750i-art-pi-u-boot.dtsi @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <stm32h7-u-boot.dtsi> + +&fmc { + /* + * Memory configuration from sdram datasheet W9825G6KH + * first bank is bank@0 + * second bank is bank@1 + */ + bank1: bank@0 { + st,sdram-control = /bits/ 8 <NO_COL_9 + NO_ROW_13 + MWIDTH_16 + BANKS_4 + CAS_2 + SDCLK_3 + RD_BURST_EN + RD_PIPE_DL_0>; + st,sdram-timing = /bits/ 8 <TMRD_2 + TXSR_6 + TRAS_6 + TRC_6 + TRP_2 + TWR_2 + TRCD_2>; + st,sdram-refcount = <677>; + }; +}; + +&pinctrl { + fmc_pins: fmc@0 { + pins { + pinmux = <STM32_PINMUX('D', 0, AF12)>, + <STM32_PINMUX('D', 1, AF12)>, + <STM32_PINMUX('D', 8, AF12)>, + <STM32_PINMUX('D', 9, AF12)>, + <STM32_PINMUX('D',10, AF12)>, + <STM32_PINMUX('D',14, AF12)>, + <STM32_PINMUX('D',15, AF12)>, + + <STM32_PINMUX('E', 0, AF12)>, + <STM32_PINMUX('E', 1, AF12)>, + <STM32_PINMUX('E', 7, AF12)>, + <STM32_PINMUX('E', 8, AF12)>, + <STM32_PINMUX('E', 9, AF12)>, + <STM32_PINMUX('E',10, AF12)>, + <STM32_PINMUX('E',11, AF12)>, + <STM32_PINMUX('E',12, AF12)>, + <STM32_PINMUX('E',13, AF12)>, + <STM32_PINMUX('E',14, AF12)>, + <STM32_PINMUX('E',15, AF12)>, + + <STM32_PINMUX('F', 0, AF12)>, + <STM32_PINMUX('F', 1, AF12)>, + <STM32_PINMUX('F', 2, AF12)>, + <STM32_PINMUX('F', 3, AF12)>, + <STM32_PINMUX('F', 4, AF12)>, + <STM32_PINMUX('F', 5, AF12)>, + <STM32_PINMUX('F',11, AF12)>, + <STM32_PINMUX('F',12, AF12)>, + <STM32_PINMUX('F',13, AF12)>, + <STM32_PINMUX('F',14, AF12)>, + <STM32_PINMUX('F',15, AF12)>, + + <STM32_PINMUX('G', 0, AF12)>, + <STM32_PINMUX('G', 1, AF12)>, + <STM32_PINMUX('G', 2, AF12)>, + <STM32_PINMUX('G', 4, AF12)>, + <STM32_PINMUX('G', 5, AF12)>, + <STM32_PINMUX('G', 8, AF12)>, + <STM32_PINMUX('G',15, AF12)>, + + <STM32_PINMUX('H', 5, AF12)>, + <STM32_PINMUX('C', 2, AF12)>, + <STM32_PINMUX('C', 3, AF12)>; + + slew-rate = <3>; + }; + }; +}; diff --git a/arch/arm/dts/stm32h750i-art-pi.dts b/arch/arm/dts/stm32h750i-art-pi.dts new file mode 100644 index 0000000..dd81198 --- /dev/null +++ b/arch/arm/dts/stm32h750i-art-pi.dts @@ -0,0 +1,188 @@ +// SPDX-License-Identifier: GPL-2.0+ OR X11 +/* + * Copyright 2021 - Dillon Min dillon.minfei@gmail.com + * + */ + +/dts-v1/; +#include "stm32h750.dtsi" +#include "stm32h750-pinctrl.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "RT-Thread STM32H750i-ART-PI board"; + compatible = "st,stm32h750i-art-pi", "st,stm32h750"; + + chosen { + bootargs = "root=/dev/ram"; + stdout-path = "serial0:2000000n8"; + }; + + memory@c0000000 { + device_type = "memory"; + reg = <0xc0000000 0x2000000>; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + linux,cma { + compatible = "shared-dma-pool"; + no-map; + size = <0x100000>; + linux,dma-default; + }; + }; + + aliases { + serial0 = &uart4; + serial1 = &usart3; + }; + + leds { + compatible = "gpio-leds"; + led-red { + gpios = <&gpioi 8 0>; + }; + led-green { + gpios = <&gpioc 15 0>; + linux,default-trigger = "heartbeat"; + }; + }; + + v3v3: regulator-v3v3 { + compatible = "regulator-fixed"; + regulator-name = "v3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + wlan_pwr: regulator-wlan { + compatible = "regulator-fixed"; + + regulator-name = "wl-reg"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + gpios = <&gpioc 13 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; +}; + +&clk_hse { + clock-frequency = <25000000>; +}; + +&dma1 { + status = "okay"; +}; + +&dma2 { + status = "okay"; +}; + +&mac { + status = "disabled"; + pinctrl-0 = <ðernet_rmii>; + pinctrl-names = "default"; + phy-mode = "rmii"; + phy-handle = <&phy0>; + + mdio0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "snps,dwmac-mdio"; + phy0: ethernet-phy@0 { + reg = <0>; + }; + }; +}; + +&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc1_b4_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>; + broken-cd; + st,neg-edge; + bus-width = <4>; + vmmc-supply = <&v3v3>; + status = "okay"; +}; + +&sdmmc2 { + pinctrl-names = "default", "opendrain", "sleep"; + pinctrl-0 = <&sdmmc2_b4_pins_a>; + pinctrl-1 = <&sdmmc2_b4_od_pins_a>; + pinctrl-2 = <&sdmmc2_b4_sleep_pins_a>; + broken-cd; + non-removable; + st,neg-edge; + bus-width = <4>; + vmmc-supply = <&wlan_pwr>; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + brcmf: bcrmf@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + }; +}; + +&spi1 { + status = "okay"; + pinctrl-0 = <&spi1_pins>; + pinctrl-names = "default"; + cs-gpios = <&gpioa 4 GPIO_ACTIVE_LOW>; + dmas = <&dmamux1 37 0x400 0x05>, + <&dmamux1 38 0x400 0x05>; + dma-names = "rx", "tx"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "winbond,w25q128", "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <80000000>; + + partition@0 { + label = "root filesystem"; + reg = <0 0x1000000>; + }; + }; +}; + +&usart2 { + pinctrl-0 = <&usart2_pins>; + pinctrl-names = "default"; + status = "disabled"; +}; + +&usart3 { + pinctrl-names = "default"; + pinctrl-0 = <&usart3_pins>; + dmas = <&dmamux1 45 0x400 0x05>, + <&dmamux1 46 0x400 0x05>; + dma-names = "rx", "tx"; + st,hw-flow-ctrl; + status = "okay"; + + bluetooth { + compatible = "brcm,bcm43438-bt"; + host-wakeup-gpios = <&gpioc 0 GPIO_ACTIVE_HIGH>; + device-wakeup-gpios = <&gpioi 10 GPIO_ACTIVE_HIGH>; + shutdown-gpios = <&gpioi 11 GPIO_ACTIVE_HIGH>; + max-speed = <115200>; + }; +}; + +&uart4 { + pinctrl-0 = <&uart4_pins>; + pinctrl-names = "default"; + status = "okay"; +}; diff --git a/include/dt-bindings/memory/stm32-sdram.h b/include/dt-bindings/memory/stm32-sdram.h index ab91d2b..90ef2e1 100644 --- a/include/dt-bindings/memory/stm32-sdram.h +++ b/include/dt-bindings/memory/stm32-sdram.h @@ -34,8 +34,10 @@ #define TXSR_1 (1 - 1) #define TXSR_6 (6 - 1) #define TXSR_7 (7 - 1) +#define TXSR_8 (8 - 1) #define TRAS_1 (1 - 1) #define TRAS_4 (4 - 1) +#define TRAS_6 (6 - 1) #define TRC_6 (6 - 1) #define TWR_1 (1 - 1) #define TWR_2 (2 - 1)
This patch adds support for rt-thread art-pi board.
for more information about art-pi, please goto: https://art-pi.gitee.io/website/
Signed-off-by: dillon min dillon.minfei@gmail.com --- v3: no changes
arch/arm/mach-stm32/stm32h7/Kconfig | 4 ++ board/st/stm32h750-art-pi/Kconfig | 19 +++++++++ board/st/stm32h750-art-pi/MAINTAINERS | 7 ++++ board/st/stm32h750-art-pi/Makefile | 6 +++ board/st/stm32h750-art-pi/stm32h750-art-pi.c | 58 ++++++++++++++++++++++++++++ configs/stm32h750-art-pi_defconfig | 51 ++++++++++++++++++++++++ include/configs/stm32h750-art-pi.h | 48 +++++++++++++++++++++++ 7 files changed, 193 insertions(+) create mode 100644 board/st/stm32h750-art-pi/Kconfig create mode 100644 board/st/stm32h750-art-pi/MAINTAINERS create mode 100644 board/st/stm32h750-art-pi/Makefile create mode 100644 board/st/stm32h750-art-pi/stm32h750-art-pi.c create mode 100644 configs/stm32h750-art-pi_defconfig create mode 100644 include/configs/stm32h750-art-pi.h
diff --git a/arch/arm/mach-stm32/stm32h7/Kconfig b/arch/arm/mach-stm32/stm32h7/Kconfig index 55e6217..70233a4 100644 --- a/arch/arm/mach-stm32/stm32h7/Kconfig +++ b/arch/arm/mach-stm32/stm32h7/Kconfig @@ -6,7 +6,11 @@ config TARGET_STM32H743_DISCO config TARGET_STM32H743_EVAL bool "STM32H743 Evaluation board"
+config TARGET_STM32H750_ART_PI + bool "STM32H750 ART Pi board" + source "board/st/stm32h743-eval/Kconfig" source "board/st/stm32h743-disco/Kconfig" +source "board/st/stm32h750-art-pi/Kconfig"
endif diff --git a/board/st/stm32h750-art-pi/Kconfig b/board/st/stm32h750-art-pi/Kconfig new file mode 100644 index 0000000..c31b984 --- /dev/null +++ b/board/st/stm32h750-art-pi/Kconfig @@ -0,0 +1,19 @@ +if TARGET_STM32H750_ART_PI + +config SYS_BOARD + string + default "stm32h750-art-pi" + +config SYS_VENDOR + string + default "st" + +config SYS_SOC + string + default "stm32h7" + +config SYS_CONFIG_NAME + string + default "stm32h750-art-pi" + +endif diff --git a/board/st/stm32h750-art-pi/MAINTAINERS b/board/st/stm32h750-art-pi/MAINTAINERS new file mode 100644 index 0000000..9578833 --- /dev/null +++ b/board/st/stm32h750-art-pi/MAINTAINERS @@ -0,0 +1,7 @@ +STM32H750 ART PI BOARD +M: Dillon Min dillon.minfei@gmail.com +S: Maintained +F: board/st/stm32h750-art-pi +F: include/configs/stm32h750-art-pi.h +F: configs/stm32h750-art-pi_defconfig +F: arch/arm/dts/stm32h7* diff --git a/board/st/stm32h750-art-pi/Makefile b/board/st/stm32h750-art-pi/Makefile new file mode 100644 index 0000000..a06de87 --- /dev/null +++ b/board/st/stm32h750-art-pi/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2021, RT-Thread - All Rights Reserved +# Author(s): Dillon Min, dillon.minfei@gmail.com for RT-Thread. + +obj-y := stm32h750-art-pi.o diff --git a/board/st/stm32h750-art-pi/stm32h750-art-pi.c b/board/st/stm32h750-art-pi/stm32h750-art-pi.c new file mode 100644 index 0000000..c374dd3 --- /dev/null +++ b/board/st/stm32h750-art-pi/stm32h750-art-pi.c @@ -0,0 +1,58 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2021, STMicroelectronics - All Rights Reserved + * Author(s): Dillon Min dillon.minfei@gmail.com for STMicroelectronics. + */ + +#include <common.h> +#include <dm.h> +#include <init.h> +#include <log.h> +#include <asm/global_data.h> + +DECLARE_GLOBAL_DATA_PTR; + +int dram_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return ret; + } + + if (fdtdec_setup_mem_size_base() != 0) + ret = -EINVAL; + + return ret; +} + +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + + return 0; +} + +int board_early_init_f(void) +{ + return 0; +} + +u32 get_board_rev(void) +{ + return 0; +} + +int board_late_init(void) +{ + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = gd->bd->bi_dram[0].start + 0x100; + return 0; +} diff --git a/configs/stm32h750-art-pi_defconfig b/configs/stm32h750-art-pi_defconfig new file mode 100644 index 0000000..a5c4cd7 --- /dev/null +++ b/configs/stm32h750-art-pi_defconfig @@ -0,0 +1,51 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32=y +CONFIG_SYS_TEXT_BASE=0x90000000 +CONFIG_SYS_MALLOC_F_LEN=0xF00 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_STM32H7=y +CONFIG_TARGET_STM32H750_ART_PI=y +CONFIG_DEFAULT_DEVICE_TREE="stm32h750i-art-pi" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTDELAY=3 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +# CONFIG_USE_BOOTCOMMAND is not set +CONFIG_DEFAULT_FDT_FILE="stm32h750i-art-pi" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +# CONFIG_NET is not set +CONFIG_DM_MMC=y +CONFIG_STM32_SDMMC2=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_BAUDRATE=2000000 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttySTM0,2000000 root=/dev/ram rdinit=/linuxrc loglevel=8" +CONFIG_BOOTCOMMAND="bootm 90080000" +CONFIG_REQUIRE_SERIAL_CONSOLE=y +CONFIG_SERIAL_PRESENT=y +CONFIG_DM_SERIAL=y +CONFIG_STM32_SERIAL=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x0 +CONFIG_FIT_ENABLE_SHA256_SUPPORT=y +CONFIG_FIT_FULL_CHECK=y +CONFIG_FIT_PRINT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_USE_BOOTCOMMAND=y +CONFIG_DM_DMA=y diff --git a/include/configs/stm32h750-art-pi.h b/include/configs/stm32h750-art-pi.h new file mode 100644 index 0000000..43dc79a --- /dev/null +++ b/include/configs/stm32h750-art-pi.h @@ -0,0 +1,48 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2021, STMicroelectronics - All Rights Reserved + * Author(s): Dillon Min dillon.minfei@gmail.com for STMicroelectronics. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <config.h> +#include <linux/sizes.h> + +/* For booting Linux, use the first 16MB of memory */ +#define CONFIG_SYS_BOOTMAPSZ (SZ_16M + SZ_8M) + +#define CONFIG_SYS_FLASH_BASE 0x90000000 +#define CONFIG_SYS_INIT_SP_ADDR 0x24040000 + +/* + * Configuration of the external SDRAM memory + */ +#define CONFIG_SYS_LOAD_ADDR 0xC1800000 +#define CONFIG_LOADADDR 0xC1800000 + +#define CONFIG_SYS_HZ_CLOCK 1000000 + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) + +#include <config_distro_bootcmd.h> +#define CONFIG_EXTRA_ENV_SETTINGS \ + "kernel_addr_r=0xC0008000\0" \ + "fdtfile=stm32h750i-art-pi.dtb\0" \ + "fdt_addr_r=0xC0408000\0" \ + "scriptaddr=0xC0418000\0" \ + "pxefile_addr_r=0xC0428000\0" \ + "ramdisk_addr_r=0xC0438000\0" \ + BOOTENV + +#endif /* __CONFIG_H */
strsep will change data from original memory address, in case the memory is in non-sdram/sram place, will run into a bug(hang at SDRAM: )
just add a temporary array to store bank_name[] to fix this bug.
Fixes: f303aaf ("ram: stm32: add second SDRAM bank management") Signed-off-by: dillon min dillon.minfei@gmail.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com --- v3: no changes
drivers/ram/stm32_sdram.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/ram/stm32_sdram.c b/drivers/ram/stm32_sdram.c index 540ad85..da27677 100644 --- a/drivers/ram/stm32_sdram.c +++ b/drivers/ram/stm32_sdram.c @@ -268,6 +268,7 @@ static int stm32_fmc_of_to_plat(struct udevice *dev) u32 swp_fmc; ofnode bank_node; char *bank_name; + char _bank_name[128] = {0}; u8 bank = 0; int ret;
@@ -300,6 +301,8 @@ static int stm32_fmc_of_to_plat(struct udevice *dev) dev_for_each_subnode(bank_node, dev) { /* extract the bank index from DT */ bank_name = (char *)ofnode_get_name(bank_node); + strcpy(_bank_name, bank_name); + bank_name = _bank_name; strsep(&bank_name, "@"); if (!bank_name) { pr_err("missing sdram bank index");
one remark below
v3: no changes
- char _bank_name[128] = {0}; u8 bank = 0; int ret;
strcpy/strncpy usage is to be avoided. Instead use strlcpy()
Thanks
strsep(&bank_name, "@"); if (!bank_name) { pr_err("missing sdram bank index");bank_name = _bank_name;
On Wed, Mar 31, 2021 at 5:09 PM Patrice CHOTARD patrice.chotard@foss.st.com wrote:
one remark below
v3: no changes
Agree, will add to next submission. thanks.
Thanks
This patch add st,stm32h750-pinctrl for stm32h750 soc
doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt index 0016925..472539c 100644 --- a/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt @@ -13,6 +13,7 @@ Required properies: "st,stm32f746-pinctrl" "st,stm32f769-pinctrl" "st,stm32h743-pinctrl" + "st,stm32h750-pinctrl" "st,stm32mp157-pinctrl" "st,stm32mp157-z-pinctrl" - #address-cells: The value of this property must be 1
Due to DT kernel synchronisation, add new pinctrl compatible string for stm32h750.
drivers/pinctrl/pinctrl_stm32.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index 6c98538..c5279c4 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -491,6 +491,7 @@ static const struct udevice_id stm32_pinctrl_ids[] = { { .compatible = "st,stm32f746-pinctrl" }, { .compatible = "st,stm32f769-pinctrl" }, { .compatible = "st,stm32h743-pinctrl" }, + { .compatible = "st,stm32h750-pinctrl" }, { .compatible = "st,stm32mp157-pinctrl" }, { .compatible = "st,stm32mp157-z-pinctrl" }, { }
Hi Dillon
I discussed with Alexandre Torque about the pinctrl rework you did on kernel side for stm32h750. When the kernel series will be fully accepted on kernel side, you can resubmit the equivalent on u-boot side.
Nevertheless, there is one issue i didn't spot on previous review regarding patch 4 "ram: stm32: fix strsep failed on read only memory"
Patrice
- 32MiB sdram
- 16MiB spi flash
- 8MiB qspi flash
changes in v2:
*** BLURB HERE ***
Hi Patrice,
Thanks for the reply,
On Wed, Mar 31, 2021 at 5:05 PM Patrice CHOTARD patrice.chotard@foss.st.com wrote:
Hi Dillon
Agree, I loop you to the kernel mailing list , just let you know the status of device tree review on kernel side, i'll hold u-boot's patch submission, until kernel's patch is fully accepted.
Nevertheless, there is one issue I didn't spot on previous review regarding patch 4 "ram: stm32: fix strsep failed on read only memory"
Okay, i'm going to rework that patch, thanks.
Patrice
- 32MiB sdram
- 16MiB spi flash
- 8MiB qspi flash
changes in v2:
*** BLURB HERE ***
dillon min
Patrice CHOTARD
