[GIT PULL] xilinx patches for v2022.07-rc1
Hi Tom,
please pull these patches to your next branch. CI doesn't show any issue. https://source.denx.de/u-boot/custodians/u-boot-microblaze/-/pipelines/11311
There are couple of enhancements but also new pinctrl driver for supporting Xilinx SOM.
Thanks, Michal
The following changes since commit 6d3c46ed0e230d999c3f20f7fd4f3a88c03b14ca:
Merge https://source.denx.de/u-boot/custodians/u-boot-sunxi (2022-03-05 20:46:55 -0500)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2022.07-rc1
for you to fetch changes up to 0ac03fbab51c72fa978569a831c001c4ddad8e2a:
arm64: zynqmp: Add pinctrl emmc description to SM-K26 (2022-03-16 16:14:34 +0100)
---------------------------------------------------------------- Xilinx changes for v2022.07-rc1
microblaze: - Add support for reserved memory
xilinx: - Update FRU code with MAC reading
zynqmp: - Remove double AMS setting - DT updates (mostly for SOMs) - Add support for zcu106 rev 1.0
zynq: - Update nand binding
nand: - Aligned zynq_nand to upstream DT binding
net: - Add support for ethernet-phy-id
mmc: - Workaround CD in zynq_sdhci driver also for ZynqMP - Add support for dynamic/run-time SD config for SOMs
gpio: - Add driver for slg7xl45106
firmware: - Add support for dynamic SD config
power-domain: - Update zynqmp driver with the latest firmware
video: - Add skeleton driver for DP and DPDMA
i2c: - Fix i2c to work with QEMU
pinctrl: - Add driver for zynqmp pinctrl driver
---------------------------------------------------------------- Ashok Reddy Soma (14): fru: ops: Clear fru table before storing data fru: ops: Return error from checksum if data is all zero's xilinx: common: Optimise updating ethaddr from eeprom fru: ops: Add support to read mac addresses from multirecord dm: pinctrl: Use explicit values for enums mmc: zynq_sdhci: Fix timeout issue mmc: zynq_sdhci: Change granularity of timeout to 1us mmc: zynq_sdhci: Enable card detect workaround for ZynqMP firmware: zynqmp: Add and update firmware enums firmware: zynqmp: Add support for set sd config and is function supported lib: div64: Add support for round up of div64_u64 mmc: zynq_sdhci: Add support for dynamic configuration pinctrl: Increase length of pinmux status buffer pinctrl: zynqmp: Add pinctrl driver
Michael Walle (1): ARM: dts: zynq: add NAND flash controller node
Michal Simek (18): mtd: nand: Update driver to match new DT binding power: zynqmp: Use zynqmp_pmufw_node() from firmware microblaze: Do not place u-boot to reserved memory location arm64: zynqmp: Move usb hub from i2c to usb node arm64: zynqmp: Setup clock for DP and DPDMA arm64: zynqmp: Use assigned-clock-rates for setting up clock in SOM arm64: zynqmp: Switch to ethernet-phy-id in kv260 arm64: zynqmp: Enable DP driver for SOMs arm64: zynqmp: Fix level of gpio reset for usb on kv260 boards video: Add skeleton driver for ZynqMP Display port driver dma: xilinx: Add Display Port DMA driver MAINTAINERS: Remove duplicated entry for ehci-zynq.c net: phy: Add new read ethernet phy id function net: phy: Remove static return type for phy_device_create() net: phy: Add support for ethernet-phy-id with gpio reset cmd: test: pinmux: Do not check all empty spaces arm64: zynqmp: Fix i2c addresses for zynqmp-p-a2197 arm64: zynqmp: Add pinctrl emmc description to SM-K26
Neal Frager (1): arm64: zynqmp: add support for zcu106 rev1.0
Sai Pavan Boddu (3): i2c: i2c-cdns: Start read transaction after write to transfer_size reg i2c: i2c-cdns: Fix write transaction state i2c: i2c-cdns: Prevent early termination of write
T Karthik Reddy (2): Revert "board: zynqmp: Fix for wrong AMS setting by ROM" gpio: slg7xl45106: Add support for slg7xl45106 i2c gpo expander
MAINTAINERS | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/bitmain-antminer-s9.dts | 2 +- arch/arm/dts/zynq-7000.dtsi | 57 +- arch/arm/dts/zynq-zc770-xm011.dts | 2 +- arch/arm/dts/zynqmp-clk-ccf.dtsi | 8 + arch/arm/dts/zynqmp-p-a2197-00-revA.dts | 8 +- arch/arm/dts/zynqmp-sck-kv-g-revA.dts | 12 +- arch/arm/dts/zynqmp-sck-kv-g-revB.dts | 26 +- arch/arm/dts/zynqmp-sm-k26-revA.dts | 25 + arch/arm/dts/zynqmp-zcu106-rev1.0.dts | 16 + arch/microblaze/include/asm/system.h | 2 + board/xilinx/common/board.c | 11 +- board/xilinx/common/fru.h | 21 + board/xilinx/common/fru_ops.c | 49 +- board/xilinx/microblaze-generic/microblaze-generic.c | 21 + board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c | 842 ++++++++++++++++++++ board/xilinx/zynqmp/zynqmp.c | 6 - configs/xilinx_zynqmp_virt_defconfig | 2 +- drivers/core/ofnode.c | 36 + drivers/dma/Kconfig | 7 + drivers/dma/Makefile | 1 + drivers/dma/xilinx_dpdma.c | 43 + drivers/firmware/firmware-zynqmp.c | 51 ++ drivers/gpio/Kconfig | 8 + drivers/gpio/Makefile | 1 + drivers/gpio/gpio_slg7xl45106.c | 115 +++ drivers/i2c/i2c-cdns.c | 18 +- drivers/mmc/zynq_sdhci.c | 110 ++- drivers/mtd/nand/raw/zynq_nand.c | 9 +- drivers/net/phy/Kconfig | 8 + drivers/net/phy/Makefile | 1 + drivers/net/phy/ethernet_id.c | 69 ++ drivers/net/phy/phy.c | 11 +- drivers/pinctrl/Kconfig | 10 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-zynqmp.c | 644 +++++++++++++++ drivers/power/domain/zynqmp-power-domain.c | 29 +- drivers/video/Kconfig | 8 + drivers/video/Makefile | 1 + drivers/video/zynqmp_dpsub.c | 66 ++ include/dm/ofnode.h | 13 + include/dm/pinctrl.h | 50 +- include/linux/math64.h | 3 + include/phy.h | 26 + include/zynqmp_firmware.h | 72 ++ test/cmd/pinmux.c | 8 +- 47 files changed, 2410 insertions(+), 124 deletions(-) create mode 100644 arch/arm/dts/zynqmp-zcu106-rev1.0.dts create mode 100644 board/xilinx/zynqmp/zynqmp-zcu106-rev1.0/psu_init_gpl.c create mode 100644 drivers/dma/xilinx_dpdma.c create mode 100644 drivers/gpio/gpio_slg7xl45106.c create mode 100644 drivers/net/phy/ethernet_id.c create mode 100644 drivers/pinctrl/pinctrl-zynqmp.c create mode 100644 drivers/video/zynqmp_dpsub.c
On Wed, Mar 16, 2022 at 05:42:32PM +0100, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
