Re: [PATCH 1/6] clk: actions: Introduce dummy get/set_rate callbacks
On 13/12/2020 09:43, Amit Singh Tomar wrote:
This commit introduces get/set_rate callbacks, these are dummy at the moment, and can be used to get/set clock for various devices based on the clk id.
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com
drivers/clk/owl/clk_owl.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/drivers/clk/owl/clk_owl.c b/drivers/clk/owl/clk_owl.c index 1999c87..c9bc5c2 100644 --- a/drivers/clk/owl/clk_owl.c +++ b/drivers/clk/owl/clk_owl.c @@ -128,6 +128,32 @@ int owl_clk_disable(struct clk *clk) return 0; }
+static ulong owl_clk_get_rate(struct clk *clk) +{
- struct owl_clk_priv *priv = dev_get_priv(clk->dev);
This is a bit premature and leads to compilation warnings.
- ulong rate;
- switch (clk->id) {
- default:
return -ENOENT;
- return rate;
+static ulong owl_clk_set_rate(struct clk *clk, ulong rate) +{
Same here.
Cheers, Andre
- ulong new_rate;
- default:
return -ENOENT;
- return new_rate;
static int owl_clk_probe(struct udevice *dev) { struct owl_clk_priv *priv = dev_get_priv(dev); @@ -145,6 +171,8 @@ static int owl_clk_probe(struct udevice *dev) static const struct clk_ops owl_clk_ops = { .enable = owl_clk_enable, .disable = owl_clk_disable,
- .get_rate = owl_clk_get_rate,
- .set_rate = owl_clk_set_rate,
static const struct udevice_id owl_clk_ids[] = {
Sorry, I should have compile-tested the individual commit as well. I Would fix it in the next version.
Thanks -Amit
Amit Tomer
André Przywara
