[U-Boot] [PATCH] configs: am3517-evm: Setup NAND booting
The NAND offsets for the kernel and U-Boot were missing. This patch sets up the offsets so the AM3517-EVM can boot from NAND when DIP switches S7:1 and S7:4 are to the OFF position
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 3b8e2900eb..41ab3fd373 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -18,6 +18,9 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_MTD_SUPPORT=y CONFIG_SYS_PROMPT="AM3517_EVM # " # CONFIG_CMD_IMI is not set +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_NAND_OFS=0xaa0000 +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 # CONFIG_CMD_EEPROM is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_GPT is not set @@ -37,6 +40,8 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y +CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y +CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y
Adam Ford
