[U-Boot] [PATCH] MXC: removed warnings from IMX51 ATA driver
Drop warnings due to unused variables.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Marek Vasut marek.vasut@gmail.com --- drivers/block/mxc_ata.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/drivers/block/mxc_ata.c b/drivers/block/mxc_ata.c index 842a633..f22f4f4 100644 --- a/drivers/block/mxc_ata.c +++ b/drivers/block/mxc_ata.c @@ -87,11 +87,8 @@ struct mxc_data_hdd_regs {
/* PIO timing table */ #define NR_PIO_SPECS 5 -static uint16_t pio_t0[NR_PIO_SPECS] = { 600, 383, 240, 180, 120 }; static uint16_t pio_t1[NR_PIO_SPECS] = { 70, 50, 30, 30, 25 }; static uint16_t pio_t2_8[NR_PIO_SPECS] = { 290, 290, 290, 80, 70 }; -static uint16_t pio_t2_16[NR_PIO_SPECS] = { 165, 125, 100, 80, 70 }; -static uint16_t pio_t2i[NR_PIO_SPECS] = { 40, 0, 0, 0, 0 }; static uint16_t pio_t4[NR_PIO_SPECS] = { 30, 20, 15, 10, 10 }; static uint16_t pio_t9[NR_PIO_SPECS] = { 20, 15, 10, 10, 10 }; static uint16_t pio_tA[NR_PIO_SPECS] = { 50, 50, 50, 50, 50 };
Acked-by: Marek Vasut marek.vasut@gmail.com
Stefano Babic
