Re: [DNX#2006040142000026] [U-Boot-Users] [PATCH] include top config.mk only [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000026] was created:
<snip>
Friedrich Lobenstock wrote:
Hi Wolfgang!
During compiling I just spotted the fact that gccincdir := $(shell $(CC) -print-file-name=include) in the top config.mk does execute "gcc -print-file-name=include" instead of "m68k-elf-gcc ..." which I would expect as i compile for m68k. I think that this does not make much difference as the includes should mostly be the same, but for the sake of completeness I want to bring the attached patch to your attention.
Bump & resubmit...
This particular issue broke cross-compilation for all of our ARM-based projects following a repository sync yesterday.
The attached patch was generated against a 2005.11.29 CVS pull.
CHANGELOG:
- Patch by Cory Tusar, 30 Nov 2005:
- Original patch by Friedrich Lobenstock, 01 Jun 2005: CROSS_COMPILE is referenced in the top 'config.mk' file, therefore we need to include it in the main Makefile only after CROSS_COMPILE has been defined.
-Cory
-- Cory T. Tusar Embedded Systems Engineer Videon Central, Inc. 2171 Sandy Drive State College, PA 16801 (814) 235-1111 x316 (814) 235-1118 fax
"Debugging is twice as hard as writing the code in the first place. Therefore, if you write the code as cleverly as possible, you are, by definition, not smart enough to debug it." --Brian W. Kernighan
</snip>
Your U-Boot support team
DENX Support System
