[RESEND PATCH v3] imx8mm_venice: switch to use binman to pack images
Use binman to pack images.
Note that imx8mm_venice supports several boards via multiple DTB's thus in the fit node we must use: - fit,fdt-list = "of-list" - fdt-SEQ - config-SEQ
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- v3: - resent as I forgot to include the uboot list - rebase on top of Marcel's patch: "arm64: dts: imx8mm: use common binman configuration" v2: - rebase on origin/mater - remove ATF_LOAD_ADDR from README as its no longer needed --- arch/arm/mach-imx/imx8m/Kconfig | 1 + board/gateworks/venice/Kconfig | 3 +-- board/gateworks/venice/README | 2 +- board/gateworks/venice/imximage-8mm-lpddr4.cfg | 9 +++++++++ configs/imx8mm_venice_defconfig | 4 ++-- 5 files changed, 14 insertions(+), 5 deletions(-) create mode 100644 board/gateworks/venice/imximage-8mm-lpddr4.cfg
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index d630a73f13ba..d6a869068a3c 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -73,6 +73,7 @@ config TARGET_IMX8MM_ICORE_MX8MM
config TARGET_IMX8MM_VENICE bool "Support Gateworks Venice iMX8M Mini module" + select BINMAN select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 diff --git a/board/gateworks/venice/Kconfig b/board/gateworks/venice/Kconfig index 639bf35d2050..687b94f24dd3 100644 --- a/board/gateworks/venice/Kconfig +++ b/board/gateworks/venice/Kconfig @@ -10,6 +10,5 @@ config SYS_CONFIG_NAME default "imx8mm_venice"
config IMX_CONFIG - default "arch/arm/mach-imx/imx8m/imximage-8mm-lpddr4.cfg" - + default "board/gateworks/venice/imximage-8mm-lpddr4.cfg" endif diff --git a/board/gateworks/venice/README b/board/gateworks/venice/README index 6a0ab1ef10ac..773cc09e8724 100644 --- a/board/gateworks/venice/README +++ b/board/gateworks/venice/README @@ -25,7 +25,7 @@ $ cp firmware-imx-8.9/firmware/ddr/synopsys/lpddr4*.bin . Build U-Boot ============ $ make imx8mm_venice_defconfig -$ make flash.bin CROSS_COMPILE=aarch64-linux-gnu- ATF_LOAD_ADDR=0x920000 +$ make CROSS_COMPILE=aarch64-linux-gnu-
Update eMMC =========== diff --git a/board/gateworks/venice/imximage-8mm-lpddr4.cfg b/board/gateworks/venice/imximage-8mm-lpddr4.cfg new file mode 100644 index 000000000000..ccaa765cb7d4 --- /dev/null +++ b/board/gateworks/venice/imximage-8mm-lpddr4.cfg @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 Gateworks Corporation + */ + +#define __ASSEMBLY__ + +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index c4c75d2a38eb..6f522880d70d 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -25,7 +25,7 @@ CONFIG_SYS_LOAD_ADDR=0x40480000 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set @@ -56,7 +56,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="imx8mm-venice-gw71xx-0x imx8mm-venice-gw72xx-0x imx8mm-venice-gw73xx-0x imx8mm-venice-gw7901 imx8mm-venice-gw7902" +CONFIG_OF_LIST="imx8mm-venice imx8mm-venice-gw71xx-0x imx8mm-venice-gw72xx-0x imx8mm-venice-gw73xx-0x imx8mm-venice-gw7901 imx8mm-venice-gw7902" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y
- fdt-SEQ
- config-SEQ
Tim Harvey
