[U-Boot] [PATCH-ARM 2/4, v2] Clean-up of s3c24x0 header files
This patch re-formats the arm920t s3c24x0 header files in preparation for changes to add support for the Embest SBC2440-II Board.
The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports
It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patch 1/4 of this series
Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk ---
Changes in v2: removed checkpatch.pl errors moved change log
include/s3c2400.h | 494 ++++---------------------------------------- include/s3c2410.h | 159 ++++----------- include/s3c24x0.h | 605 ++++++----------------------------------------------- 3 files changed, 137 insertions(+), 1121 deletions(-)
diff --git a/include/s3c2400.h b/include/s3c2400.h index 4fdc62e..062259d 100644 --- a/include/s3c2400.h +++ b/include/s3c2400.h @@ -35,12 +35,12 @@ #define S3C24X0_SPI_CHANNELS 1 #define PALETTE (0x14A00400) /* SJS */
-typedef enum { +enum s3c24x0_uarts_nr { S3C24X0_UART0, S3C24X0_UART1, -} S3C24X0_UARTS_NR; +};
-/* S3C2400 device base addresses */ +/*S3C2400 device base addresses */ #define S3C24X0_MEMCTL_BASE 0x14000000 #define S3C24X0_USB_HOST_BASE 0x14200000 #define S3C24X0_INTERRUPT_BASE 0x14400000 @@ -63,492 +63,74 @@ typedef enum { #include <s3c24x0.h>
-static inline S3C24X0_MEMCTL * S3C24X0_GetBase_MEMCTL(void) +static inline struct s3c24x0_memctl *s3c24x0_get_base_memctl(void) { - return (S3C24X0_MEMCTL * const)S3C24X0_MEMCTL_BASE; + return (struct s3c24x0_memctl *)S3C24X0_MEMCTL_BASE; } -static inline S3C24X0_USB_HOST * S3C24X0_GetBase_USB_HOST(void) +static inline struct s3c24x0_usb_host *s3c24x0_get_base_usb_host(void) { - return (S3C24X0_USB_HOST * const)S3C24X0_USB_HOST_BASE; + return (struct s3c24x0_usb_host *)S3C24X0_USB_HOST_BASE; } -static inline S3C24X0_INTERRUPT * S3C24X0_GetBase_INTERRUPT(void) +static inline struct s3c24x0_interrupt *s3c24x0_get_base_interrupt(void) { - return (S3C24X0_INTERRUPT * const)S3C24X0_INTERRUPT_BASE; + return (struct s3c24x0_interrupt *)S3C24X0_INTERRUPT_BASE; } -static inline S3C24X0_DMAS * S3C24X0_GetBase_DMAS(void) +static inline struct s3c24x0_dmas *s3c24x0_get_base_dmas(void) { - return (S3C24X0_DMAS * const)S3C24X0_DMA_BASE; + return (struct s3c24x0_dmas *)S3C24X0_DMA_BASE; } -static inline S3C24X0_CLOCK_POWER * S3C24X0_GetBase_CLOCK_POWER(void) +static inline struct s3c24x0_clock_power *s3c24x0_get_base_clock_power(void) { - return (S3C24X0_CLOCK_POWER * const)S3C24X0_CLOCK_POWER_BASE; + return (struct s3c24x0_clock_power *)S3C24X0_CLOCK_POWER_BASE; } -static inline S3C24X0_LCD * S3C24X0_GetBase_LCD(void) +static inline struct s3c24x0_lcd *s3c24x0_get_base_lcd(void) { - return (S3C24X0_LCD * const)S3C24X0_LCD_BASE; + return (struct s3c24x0_lcd *)S3C24X0_LCD_BASE; } -static inline S3C24X0_UART * S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) +static inline struct s3c24x0_uart + *s3c24x0_get_base_uart(enum s3c24x0_uarts_nr n) { - return (S3C24X0_UART * const)(S3C24X0_UART_BASE + (nr * 0x4000)); + return (struct s3c24x0_uart *)(S3C24X0_UART_BASE + (n * 0x4000)); } -static inline S3C24X0_TIMERS * S3C24X0_GetBase_TIMERS(void) +static inline struct s3c24x0_timers *s3c24x0_get_base_timers(void) { - return (S3C24X0_TIMERS * const)S3C24X0_TIMER_BASE; + return (struct s3c24x0_timers *)S3C24X0_TIMER_BASE; } -static inline S3C24X0_USB_DEVICE * S3C24X0_GetBase_USB_DEVICE(void) +static inline struct s3c24x0_usb_device *s3c24x0_get_base_usb_device(void) { - return (S3C24X0_USB_DEVICE * const)S3C24X0_USB_DEVICE_BASE; + return (struct s3c24x0_usb_device *)S3C24X0_USB_DEVICE_BASE; } -static inline S3C24X0_WATCHDOG * S3C24X0_GetBase_WATCHDOG(void) +static inline struct s3c24x0_watchdog *s3c24x0_get_base_watchdog(void) { - return (S3C24X0_WATCHDOG * const)S3C24X0_WATCHDOG_BASE; + return (struct s3c24x0_watchdog *)S3C24X0_WATCHDOG_BASE; } -static inline S3C24X0_I2C * S3C24X0_GetBase_I2C(void) +static inline struct s3c24x0_i2c *s3c24x0_get_base_i2c(void) { - return (S3C24X0_I2C * const)S3C24X0_I2C_BASE; + return (struct s3c24x0_i2c *)S3C24X0_I2C_BASE; } -static inline S3C24X0_I2S * S3C24X0_GetBase_I2S(void) +static inline struct s3c24x0_i2s *s3c24x0_get_base_i2s(void) { - return (S3C24X0_I2S * const)S3C24X0_I2S_BASE; + return (struct s3c24x0_i2s *)S3C24X0_I2S_BASE; } -static inline S3C24X0_GPIO * S3C24X0_GetBase_GPIO(void) +static inline struct s3c24x0_gpio *s3c24x0_get_base_gpio(void) { - return (S3C24X0_GPIO * const)S3C24X0_GPIO_BASE; + return (struct s3c24x0_gpio *)S3C24X0_GPIO_BASE; } -static inline S3C24X0_RTC * S3C24X0_GetBase_RTC(void) +static inline struct s3c24x0_rtc *s3c24x0_get_base_rtc(void) { - return (S3C24X0_RTC * const)S3C24X0_RTC_BASE; + return (struct s3c24x0_rtc *)S3C24X0_RTC_BASE; } -static inline S3C2400_ADC * S3C2400_GetBase_ADC(void) +static inline struct s3c2400_adc *s3c2400_get_base_adc(void) { - return (S3C2400_ADC * const)S3C24X0_ADC_BASE; + return (struct s3c2400_adc *)S3C24X0_ADC_BASE; } -static inline S3C24X0_SPI * S3C24X0_GetBase_SPI(void) +static inline struct s3c24x0_spi *s3c24x0_get_base_spi(void) { - return (S3C24X0_SPI * const)S3C24X0_SPI_BASE; + return (struct s3c24x0_spi *)S3C24X0_SPI_BASE; } -static inline S3C2400_MMC * S3C2400_GetBase_MMC(void) +static inline struct s3c2400_mmc *s3c2400_get_base_mmc(void) { - return (S3C2400_MMC * const)S3C2400_MMC_BASE; + return (struct s3c2400_mmc *)S3C2400_MMC_BASE; }
-#if 0 -/* Memory control */ -#define rBWSCON (*(volatile unsigned *)0x14000000) -#define rBANKCON0 (*(volatile unsigned *)0x14000004) -#define rBANKCON1 (*(volatile unsigned *)0x14000008) -#define rBANKCON2 (*(volatile unsigned *)0x1400000C) -#define rBANKCON3 (*(volatile unsigned *)0x14000010) -#define rBANKCON4 (*(volatile unsigned *)0x14000014) -#define rBANKCON5 (*(volatile unsigned *)0x14000018) -#define rBANKCON6 (*(volatile unsigned *)0x1400001C) -#define rBANKCON7 (*(volatile unsigned *)0x14000020) -#define rREFRESH (*(volatile unsigned *)0x14000024) -#define rBANKSIZE (*(volatile unsigned *)0x14000028) -#define rMRSRB6 (*(volatile unsigned *)0x1400002C) -#define rMRSRB7 (*(volatile unsigned *)0x14000030) - - -/* INTERRUPT */ -#define rSRCPND (*(volatile unsigned *)0x14400000) -#define rINTMOD (*(volatile unsigned *)0x14400004) -#define rINTMSK (*(volatile unsigned *)0x14400008) -#define rPRIORITY (*(volatile unsigned *)0x1440000C) -#define rINTPND (*(volatile unsigned *)0x14400010) -#define rINTOFFSET (*(volatile unsigned *)0x14400014) - - -/* DMA */ -#define rDISRC0 (*(volatile unsigned *)0x14600000) -#define rDIDST0 (*(volatile unsigned *)0x14600004) -#define rDCON0 (*(volatile unsigned *)0x14600008) -#define rDSTAT0 (*(volatile unsigned *)0x1460000C) -#define rDCSRC0 (*(volatile unsigned *)0x14600010) -#define rDCDST0 (*(volatile unsigned *)0x14600014) -#define rDMASKTRIG0 (*(volatile unsigned *)0x14600018) -#define rDISRC1 (*(volatile unsigned *)0x14600020) -#define rDIDST1 (*(volatile unsigned *)0x14600024) -#define rDCON1 (*(volatile unsigned *)0x14600028) -#define rDSTAT1 (*(volatile unsigned *)0x1460002C) -#define rDCSRC1 (*(volatile unsigned *)0x14600030) -#define rDCDST1 (*(volatile unsigned *)0x14600034) -#define rDMASKTRIG1 (*(volatile unsigned *)0x14600038) -#define rDISRC2 (*(volatile unsigned *)0x14600040) -#define rDIDST2 (*(volatile unsigned *)0x14600044) -#define rDCON2 (*(volatile unsigned *)0x14600048) -#define rDSTAT2 (*(volatile unsigned *)0x1460004C) -#define rDCSRC2 (*(volatile unsigned *)0x14600050) -#define rDCDST2 (*(volatile unsigned *)0x14600054) -#define rDMASKTRIG2 (*(volatile unsigned *)0x14600058) -#define rDISRC3 (*(volatile unsigned *)0x14600060) -#define rDIDST3 (*(volatile unsigned *)0x14600064) -#define rDCON3 (*(volatile unsigned *)0x14600068) -#define rDSTAT3 (*(volatile unsigned *)0x1460006C) -#define rDCSRC3 (*(volatile unsigned *)0x14600070) -#define rDCDST3 (*(volatile unsigned *)0x14600074) -#define rDMASKTRIG3 (*(volatile unsigned *)0x14600078) - - -/* CLOCK & POWER MANAGEMENT */ -#define rLOCKTIME (*(volatile unsigned *)0x14800000) -#define rMPLLCON (*(volatile unsigned *)0x14800004) -#define rUPLLCON (*(volatile unsigned *)0x14800008) -#define rCLKCON (*(volatile unsigned *)0x1480000C) -#define rCLKSLOW (*(volatile unsigned *)0x14800010) -#define rCLKDIVN (*(volatile unsigned *)0x14800014) - - -/* LCD CONTROLLER */ -#define rLCDCON1 (*(volatile unsigned *)0x14A00000) -#define rLCDCON2 (*(volatile unsigned *)0x14A00004) -#define rLCDCON3 (*(volatile unsigned *)0x14A00008) -#define rLCDCON4 (*(volatile unsigned *)0x14A0000C) -#define rLCDCON5 (*(volatile unsigned *)0x14A00010) -#define rLCDSADDR1 (*(volatile unsigned *)0x14A00014) -#define rLCDSADDR2 (*(volatile unsigned *)0x14A00018) -#define rLCDSADDR3 (*(volatile unsigned *)0x14A0001C) -#define rREDLUT (*(volatile unsigned *)0x14A00020) -#define rGREENLUT (*(volatile unsigned *)0x14A00024) -#define rBLUELUT (*(volatile unsigned *)0x14A00028) -#define rDP1_2 (*(volatile unsigned *)0x14A0002C) -#define rDP4_7 (*(volatile unsigned *)0x14A00030) -#define rDP3_5 (*(volatile unsigned *)0x14A00034) -#define rDP2_3 (*(volatile unsigned *)0x14A00038) -#define rDP5_7 (*(volatile unsigned *)0x14A0003c) -#define rDP3_4 (*(volatile unsigned *)0x14A00040) -#define rDP4_5 (*(volatile unsigned *)0x14A00044) -#define rDP6_7 (*(volatile unsigned *)0x14A00048) -#define rDITHMODE (*(volatile unsigned *)0x14A0004C) -#define rTPAL (*(volatile unsigned *)0x14A00050) -#define PALETTE (0x14A00400) /* SJS */ - - -/* UART */ -#define rULCON0 (*(volatile unsigned char *)0x15000000) -#define rUCON0 (*(volatile unsigned short *)0x15000004) -#define rUFCON0 (*(volatile unsigned char *)0x15000008) -#define rUMCON0 (*(volatile unsigned char *)0x1500000C) -#define rUTRSTAT0 (*(volatile unsigned char *)0x15000010) -#define rUERSTAT0 (*(volatile unsigned char *)0x15000014) -#define rUFSTAT0 (*(volatile unsigned short *)0x15000018) -#define rUMSTAT0 (*(volatile unsigned char *)0x1500001C) -#define rUBRDIV0 (*(volatile unsigned short *)0x15000028) - -#define rULCON1 (*(volatile unsigned char *)0x15004000) -#define rUCON1 (*(volatile unsigned short *)0x15004004) -#define rUFCON1 (*(volatile unsigned char *)0x15004008) -#define rUMCON1 (*(volatile unsigned char *)0x1500400C) -#define rUTRSTAT1 (*(volatile unsigned char *)0x15004010) -#define rUERSTAT1 (*(volatile unsigned char *)0x15004014) -#define rUFSTAT1 (*(volatile unsigned short *)0x15004018) -#define rUMSTAT1 (*(volatile unsigned char *)0x1500401C) -#define rUBRDIV1 (*(volatile unsigned short *)0x15004028) - -#ifdef __BIG_ENDIAN -#define rUTXH0 (*(volatile unsigned char *)0x15000023) -#define rURXH0 (*(volatile unsigned char *)0x15000027) -#define rUTXH1 (*(volatile unsigned char *)0x15004023) -#define rURXH1 (*(volatile unsigned char *)0x15004027) - -#define WrUTXH0(ch) (*(volatile unsigned char *)0x15000023)=(unsigned char)(ch) -#define RdURXH0() (*(volatile unsigned char *)0x15000027) -#define WrUTXH1(ch) (*(volatile unsigned char *)0x15004023)=(unsigned char)(ch) -#define RdURXH1() (*(volatile unsigned char *)0x15004027) - -#define UTXH0 (0x15000020+3) /* byte_access address by DMA */ -#define URXH0 (0x15000024+3) -#define UTXH1 (0x15004020+3) -#define URXH1 (0x15004024+3) - -#else /* Little Endian */ -#define rUTXH0 (*(volatile unsigned char *)0x15000020) -#define rURXH0 (*(volatile unsigned char *)0x15000024) -#define rUTXH1 (*(volatile unsigned char *)0x15004020) -#define rURXH1 (*(volatile unsigned char *)0x15004024) - -#define WrUTXH0(ch) (*(volatile unsigned char *)0x15000020)=(unsigned char)(ch) -#define RdURXH0() (*(volatile unsigned char *)0x15000024) -#define WrUTXH1(ch) (*(volatile unsigned char *)0x15004020)=(unsigned char)(ch) -#define RdURXH1() (*(volatile unsigned char *)0x15004024) - -#define UTXH0 (0x15000020) /* byte_access address by DMA */ -#define URXH0 (0x15000024) -#define UTXH1 (0x15004020) -#define URXH1 (0x15004024) -#endif - - -/* PWM TIMER */ -#define rTCFG0 (*(volatile unsigned *)0x15100000) -#define rTCFG1 (*(volatile unsigned *)0x15100004) -#define rTCON (*(volatile unsigned *)0x15100008) -#define rTCNTB0 (*(volatile unsigned *)0x1510000C) -#define rTCMPB0 (*(volatile unsigned *)0x15100010) -#define rTCNTO0 (*(volatile unsigned *)0x15100014) -#define rTCNTB1 (*(volatile unsigned *)0x15100018) -#define rTCMPB1 (*(volatile unsigned *)0x1510001C) -#define rTCNTO1 (*(volatile unsigned *)0x15100020) -#define rTCNTB2 (*(volatile unsigned *)0x15100024) -#define rTCMPB2 (*(volatile unsigned *)0x15100028) -#define rTCNTO2 (*(volatile unsigned *)0x1510002C) -#define rTCNTB3 (*(volatile unsigned *)0x15100030) -#define rTCMPB3 (*(volatile unsigned *)0x15100034) -#define rTCNTO3 (*(volatile unsigned *)0x15100038) -#define rTCNTB4 (*(volatile unsigned *)0x1510003C) -#define rTCNTO4 (*(volatile unsigned *)0x15100040) - - -/* USB DEVICE */ -#define rFUNC_ADDR_REG (*(volatile unsigned *)0x15200140) -#define rPWR_REG (*(volatile unsigned *)0x15200144) -#define rINT_REG (*(volatile unsigned *)0x15200148) -#define rINT_MASK_REG (*(volatile unsigned *)0x1520014C) -#define rFRAME_NUM_REG (*(volatile unsigned *)0x15200150) -#define rRESUME_CON_REG (*(volatile unsigned *)0x15200154) -#define rEP0_CSR (*(volatile unsigned *)0x15200160) -#define rEP0_MAXP (*(volatile unsigned *)0x15200164) -#define rEP0_OUT_CNT (*(volatile unsigned *)0x15200168) -#define rEP0_FIFO (*(volatile unsigned *)0x1520016C) -#define rEP1_IN_CSR (*(volatile unsigned *)0x15200180) -#define rEP1_IN_MAXP (*(volatile unsigned *)0x15200184) -#define rEP1_FIFO (*(volatile unsigned *)0x15200188) -#define rEP2_IN_CSR (*(volatile unsigned *)0x15200190) -#define rEP2_IN_MAXP (*(volatile unsigned *)0x15200194) -#define rEP2_FIFO (*(volatile unsigned *)0x15200198) -#define rEP3_OUT_CSR (*(volatile unsigned *)0x152001A0) -#define rEP3_OUT_MAXP (*(volatile unsigned *)0x152001A4) -#define rEP3_OUT_CNT (*(volatile unsigned *)0x152001A8) -#define rEP3_FIFO (*(volatile unsigned *)0x152001AC) -#define rEP4_OUT_CSR (*(volatile unsigned *)0x152001B0) -#define rEP4_OUT_MAXP (*(volatile unsigned *)0x152001B4) -#define rEP4_OUT_CNT (*(volatile unsigned *)0x152001B8) -#define rEP4_FIFO (*(volatile unsigned *)0x152001BC) -#define rDMA_CON (*(volatile unsigned *)0x152001C0) -#define rDMA_UNIT (*(volatile unsigned *)0x152001C4) -#define rDMA_FIFO (*(volatile unsigned *)0x152001C8) -#define rDMA_TX (*(volatile unsigned *)0x152001CC) -#define rTEST_MODE (*(volatile unsigned *)0x152001F4) -#define rIN_CON_REG (*(volatile unsigned *)0x152001F8) - - -/* WATCH DOG TIMER */ -#define rWTCON (*(volatile unsigned *)0x15300000) -#define rWTDAT (*(volatile unsigned *)0x15300004) -#define rWTCNT (*(volatile unsigned *)0x15300008) - - -/* IIC */ -#define rIICCON (*(volatile unsigned *)0x15400000) -#define rIICSTAT (*(volatile unsigned *)0x15400004) -#define rIICADD (*(volatile unsigned *)0x15400008) -#define rIICDS (*(volatile unsigned *)0x1540000C) - - -/* IIS */ -#define rIISCON (*(volatile unsigned *)0x15508000) -#define rIISMOD (*(volatile unsigned *)0x15508004) -#define rIISPSR (*(volatile unsigned *)0x15508008) -#define rIISFIFCON (*(volatile unsigned *)0x1550800C) - -#ifdef __BIG_ENDIAN -#define IISFIF ((volatile unsigned short *)0x15508012) - -#else /* Little Endian */ -#define IISFIF ((volatile unsigned short *)0x15508010) -#endif - - -/* I/O PORT */ -#define rPACON (*(volatile unsigned *)0x15600000) -#define rPADAT (*(volatile unsigned *)0x15600004) - -#define rPBCON (*(volatile unsigned *)0x15600008) -#define rPBDAT (*(volatile unsigned *)0x1560000C) -#define rPBUP (*(volatile unsigned *)0x15600010) - -#define rPCCON (*(volatile unsigned *)0x15600014) -#define rPCDAT (*(volatile unsigned *)0x15600018) -#define rPCUP (*(volatile unsigned *)0x1560001C) - -#define rPDCON (*(volatile unsigned *)0x15600020) -#define rPDDAT (*(volatile unsigned *)0x15600024) -#define rPDUP (*(volatile unsigned *)0x15600028) - -#define rPECON (*(volatile unsigned *)0x1560002C) -#define rPEDAT (*(volatile unsigned *)0x15600030) -#define rPEUP (*(volatile unsigned *)0x15600034) - -#define rPFCON (*(volatile unsigned *)0x15600038) -#define rPFDAT (*(volatile unsigned *)0x1560003C) -#define rPFUP (*(volatile unsigned *)0x15600040) - -#define rPGCON (*(volatile unsigned *)0x15600044) -#define rPGDAT (*(volatile unsigned *)0x15600048) -#define rPGUP (*(volatile unsigned *)0x1560004C) - -#define rOPENCR (*(volatile unsigned *)0x15600050) -#define rMISCCR (*(volatile unsigned *)0x15600054) -#define rEXTINT (*(volatile unsigned *)0x15600058) - - -/* RTC */ -#ifdef __BIG_ENDIAN -#define rRTCCON (*(volatile unsigned char *)0x15700043) -#define rRTCALM (*(volatile unsigned char *)0x15700053) -#define rALMSEC (*(volatile unsigned char *)0x15700057) -#define rALMMIN (*(volatile unsigned char *)0x1570005B) -#define rALMHOUR (*(volatile unsigned char *)0x1570005F) -#define rALMDAY (*(volatile unsigned char *)0x15700063) -#define rALMMON (*(volatile unsigned char *)0x15700067) -#define rALMYEAR (*(volatile unsigned char *)0x1570006B) -#define rRTCRST (*(volatile unsigned char *)0x1570006F) -#define rBCDSEC (*(volatile unsigned char *)0x15700073) -#define rBCDMIN (*(volatile unsigned char *)0x15700077) -#define rBCDHOUR (*(volatile unsigned char *)0x1570007B) -#define rBCDDAY (*(volatile unsigned char *)0x1570007F) -#define rBCDDATE (*(volatile unsigned char *)0x15700083) -#define rBCDMON (*(volatile unsigned char *)0x15700087) -#define rBCDYEAR (*(volatile unsigned char *)0x1570008B) -#define rTICINT (*(volatile unsigned char *)0x15700047) - -#else /* Little Endian */ -#define rRTCCON (*(volatile unsigned char *)0x15700040) -#define rRTCALM (*(volatile unsigned char *)0x15700050) -#define rALMSEC (*(volatile unsigned char *)0x15700054) -#define rALMMIN (*(volatile unsigned char *)0x15700058) -#define rALMHOUR (*(volatile unsigned char *)0x1570005C) -#define rALMDAY (*(volatile unsigned char *)0x15700060) -#define rALMMON (*(volatile unsigned char *)0x15700064) -#define rALMYEAR (*(volatile unsigned char *)0x15700068) -#define rRTCRST (*(volatile unsigned char *)0x1570006C) -#define rBCDSEC (*(volatile unsigned char *)0x15700070) -#define rBCDMIN (*(volatile unsigned char *)0x15700074) -#define rBCDHOUR (*(volatile unsigned char *)0x15700078) -#define rBCDDAY (*(volatile unsigned char *)0x1570007C) -#define rBCDDATE (*(volatile unsigned char *)0x15700080) -#define rBCDMON (*(volatile unsigned char *)0x15700084) -#define rBCDYEAR (*(volatile unsigned char *)0x15700088) -#define rTICINT (*(volatile unsigned char *)0x15700044) -#endif - - -/* ADC */ -#define rADCCON (*(volatile unsigned *)0x15800000) -#define rADCDAT (*(volatile unsigned *)0x15800004) - - -/* SPI */ -#define rSPCON (*(volatile unsigned *)0x15900000) -#define rSPSTA (*(volatile unsigned *)0x15900004) -#define rSPPIN (*(volatile unsigned *)0x15900008) -#define rSPPRE (*(volatile unsigned *)0x1590000C) -#define rSPTDAT (*(volatile unsigned *)0x15900010) -#define rSPRDAT (*(volatile unsigned *)0x15900014) - - -/* MMC INTERFACE */ -#define rMMCON (*(volatile unsigned *)0x15a00000) -#define rMMCRR (*(volatile unsigned *)0x15a00004) -#define rMMFCON (*(volatile unsigned *)0x15a00008) -#define rMMSTA (*(volatile unsigned *)0x15a0000C) -#define rMMFSTA (*(volatile unsigned *)0x15a00010) -#define rMMPRE (*(volatile unsigned *)0x15a00014) -#define rMMLEN (*(volatile unsigned *)0x15a00018) -#define rMMCR7 (*(volatile unsigned *)0x15a0001C) -#define rMMRSP0 (*(volatile unsigned *)0x15a00020) -#define rMMRSP1 (*(volatile unsigned *)0x15a00024) -#define rMMRSP2 (*(volatile unsigned *)0x15a00028) -#define rMMRSP3 (*(volatile unsigned *)0x15a0002C) -#define rMMCMD0 (*(volatile unsigned *)0x15a00030) -#define rMMCMD1 (*(volatile unsigned *)0x15a00034) -#define rMMCR16 (*(volatile unsigned *)0x15a00038) -#define rMMDAT (*(volatile unsigned *)0x15a0003C) - - -/* ISR */ -#define pISR_RESET (*(unsigned *)(_ISR_STARTADDRESS+0x0)) -#define pISR_UNDEF (*(unsigned *)(_ISR_STARTADDRESS+0x4)) -#define pISR_SWI (*(unsigned *)(_ISR_STARTADDRESS+0x8)) -#define pISR_PABORT (*(unsigned *)(_ISR_STARTADDRESS+0xC)) -#define pISR_DABORT (*(unsigned *)(_ISR_STARTADDRESS+0x10)) -#define pISR_RESERVED (*(unsigned *)(_ISR_STARTADDRESS+0x14)) -#define pISR_IRQ (*(unsigned *)(_ISR_STARTADDRESS+0x18)) -#define pISR_FIQ (*(unsigned *)(_ISR_STARTADDRESS+0x1C)) - -#define pISR_EINT0 (*(unsigned *)(_ISR_STARTADDRESS+0x20)) -#define pISR_EINT1 (*(unsigned *)(_ISR_STARTADDRESS+0x24)) -#define pISR_EINT2 (*(unsigned *)(_ISR_STARTADDRESS+0x28)) -#define pISR_EINT3 (*(unsigned *)(_ISR_STARTADDRESS+0x2C)) -#define pISR_EINT4 (*(unsigned *)(_ISR_STARTADDRESS+0x30)) -#define pISR_EINT5 (*(unsigned *)(_ISR_STARTADDRESS+0x34)) -#define pISR_EINT6 (*(unsigned *)(_ISR_STARTADDRESS+0x38)) -#define pISR_EINT7 (*(unsigned *)(_ISR_STARTADDRESS+0x3C)) -#define pISR_TICK (*(unsigned *)(_ISR_STARTADDRESS+0x40)) -#define pISR_WDT (*(unsigned *)(_ISR_STARTADDRESS+0x44)) -#define pISR_TIMER0 (*(unsigned *)(_ISR_STARTADDRESS+0x48)) -#define pISR_TIMER1 (*(unsigned *)(_ISR_STARTADDRESS+0x4C)) -#define pISR_TIMER2 (*(unsigned *)(_ISR_STARTADDRESS+0x50)) -#define pISR_TIMER3 (*(unsigned *)(_ISR_STARTADDRESS+0x54)) -#define pISR_TIMER4 (*(unsigned *)(_ISR_STARTADDRESS+0x58)) -#define pISR_UERR01 (*(unsigned *)(_ISR_STARTADDRESS+0x5C)) -#define pISR_NOTUSED (*(unsigned *)(_ISR_STARTADDRESS+0x60)) -#define pISR_DMA0 (*(unsigned *)(_ISR_STARTADDRESS+0x64)) -#define pISR_DMA1 (*(unsigned *)(_ISR_STARTADDRESS+0x68)) -#define pISR_DMA2 (*(unsigned *)(_ISR_STARTADDRESS+0x6C)) -#define pISR_DMA3 (*(unsigned *)(_ISR_STARTADDRESS+0x70)) -#define pISR_MMC (*(unsigned *)(_ISR_STARTADDRESS+0x74)) -#define pISR_SPI (*(unsigned *)(_ISR_STARTADDRESS+0x78)) -#define pISR_URXD0 (*(unsigned *)(_ISR_STARTADDRESS+0x7C)) -#define pISR_URXD1 (*(unsigned *)(_ISR_STARTADDRESS+0x80)) -#define pISR_USBD (*(unsigned *)(_ISR_STARTADDRESS+0x84)) -#define pISR_USBH (*(unsigned *)(_ISR_STARTADDRESS+0x88)) -#define pISR_IIC (*(unsigned *)(_ISR_STARTADDRESS+0x8C)) -#define pISR_UTXD0 (*(unsigned *)(_ISR_STARTADDRESS+0x90)) -#define pISR_UTXD1 (*(unsigned *)(_ISR_STARTADDRESS+0x94)) -#define pISR_RTC (*(unsigned *)(_ISR_STARTADDRESS+0x98)) -#define pISR_ADC (*(unsigned *)(_ISR_STARTADDRESS+0xA0)) - - -/* PENDING BIT */ -#define BIT_EINT0 (0x1) -#define BIT_EINT1 (0x1<<1) -#define BIT_EINT2 (0x1<<2) -#define BIT_EINT3 (0x1<<3) -#define BIT_EINT4 (0x1<<4) -#define BIT_EINT5 (0x1<<5) -#define BIT_EINT6 (0x1<<6) -#define BIT_EINT7 (0x1<<7) -#define BIT_TICK (0x1<<8) -#define BIT_WDT (0x1<<9) -#define BIT_TIMER0 (0x1<<10) -#define BIT_TIMER1 (0x1<<11) -#define BIT_TIMER2 (0x1<<12) -#define BIT_TIMER3 (0x1<<13) -#define BIT_TIMER4 (0x1<<14) -#define BIT_UERR01 (0x1<<15) -#define BIT_NOTUSED (0x1<<16) -#define BIT_DMA0 (0x1<<17) -#define BIT_DMA1 (0x1<<18) -#define BIT_DMA2 (0x1<<19) -#define BIT_DMA3 (0x1<<20) -#define BIT_MMC (0x1<<21) -#define BIT_SPI (0x1<<22) -#define BIT_URXD0 (0x1<<23) -#define BIT_URXD1 (0x1<<24) -#define BIT_USBD (0x1<<25) -#define BIT_USBH (0x1<<26) -#define BIT_IIC (0x1<<27) -#define BIT_UTXD0 (0x1<<28) -#define BIT_UTXD1 (0x1<<29) -#define BIT_RTC (0x1<<30) -#define BIT_ADC (0x1<<31) -#define BIT_ALLMSK (0xFFFFFFFF) - -#define ClearPending(bit) {\ - rSRCPND = bit;\ - rINTPND = bit;\ - rINTPND;\ - } -/* Wait until rINTPND is changed for the case that the ISR is very short. */ -#endif #endif /*__S3C2400_H__*/ diff --git a/include/s3c2410.h b/include/s3c2410.h index 87135b4..03b33b4 100644 --- a/include/s3c2410.h +++ b/include/s3c2410.h @@ -38,11 +38,11 @@ #define S3C2410_ECCSIZE 512 #define S3C2410_ECCBYTES 3
-typedef enum { +enum s3c24x0_uarts_nr { S3C24X0_UART0, S3C24X0_UART1, S3C24X0_UART2 -} S3C24X0_UARTS_NR; +};
/* S3C2410 device base addresses */ #define S3C24X0_MEMCTL_BASE 0x48000000 @@ -69,159 +69,78 @@ typedef enum { #include <s3c24x0.h>
-static inline S3C24X0_MEMCTL * S3C24X0_GetBase_MEMCTL(void) +static inline struct s3c24x0_memctl *s3c24x0_get_base_memctl(void) { - return (S3C24X0_MEMCTL * const)S3C24X0_MEMCTL_BASE; + return (struct s3c24x0_memctl *)S3C24X0_MEMCTL_BASE; } -static inline S3C24X0_USB_HOST * S3C24X0_GetBase_USB_HOST(void) +static inline struct s3c24x0_usb_host *s3c24x0_get_base_usb_host(void) { - return (S3C24X0_USB_HOST * const)S3C24X0_USB_HOST_BASE; + return (struct s3c24x0_usb_host *)S3C24X0_USB_HOST_BASE; } -static inline S3C24X0_INTERRUPT * S3C24X0_GetBase_INTERRUPT(void) +static inline struct s3c24x0_interrupt *s3c24x0_get_base_interrupt(void) { - return (S3C24X0_INTERRUPT * const)S3C24X0_INTERRUPT_BASE; + return (struct s3c24x0_interrupt *)S3C24X0_INTERRUPT_BASE; } -static inline S3C24X0_DMAS * S3C24X0_GetBase_DMAS(void) +static inline struct s3c24x0_dmas *s3c24x0_get_base_dmas(void) { - return (S3C24X0_DMAS * const)S3C24X0_DMA_BASE; + return (struct s3c24x0_dmas *)S3C24X0_DMA_BASE; } -static inline S3C24X0_CLOCK_POWER * S3C24X0_GetBase_CLOCK_POWER(void) +static inline struct s3c24x0_clock_power *s3c24x0_get_base_clock_power(void) { - return (S3C24X0_CLOCK_POWER * const)S3C24X0_CLOCK_POWER_BASE; + return (struct s3c24x0_clock_power *)S3C24X0_CLOCK_POWER_BASE; } -static inline S3C24X0_LCD * S3C24X0_GetBase_LCD(void) +static inline struct s3c24x0_lcd *s3c24x0_get_base_lcd(void) { - return (S3C24X0_LCD * const)S3C24X0_LCD_BASE; + return (struct s3c24x0_lcd *)S3C24X0_LCD_BASE; } -static inline S3C2410_NAND * S3C2410_GetBase_NAND(void) +static inline struct s3c2410_nand *s3c2410_get_base_nand(void) { - return (S3C2410_NAND * const)S3C2410_NAND_BASE; + return (struct s3c2410_nand *)S3C2410_NAND_BASE; } -static inline S3C24X0_UART * S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) +static inline struct s3c24x0_uart + *s3c24x0_get_base_uart(enum s3c24x0_uarts_nr n) { - return (S3C24X0_UART * const)(S3C24X0_UART_BASE + (nr * 0x4000)); + return (struct s3c24x0_uart *)(S3C24X0_UART_BASE + (n * 0x4000)); } -static inline S3C24X0_TIMERS * S3C24X0_GetBase_TIMERS(void) +static inline struct s3c24x0_timers *s3c24x0_get_base_timers(void) { - return (S3C24X0_TIMERS * const)S3C24X0_TIMER_BASE; + return (struct s3c24x0_timers *)S3C24X0_TIMER_BASE; } -static inline S3C24X0_USB_DEVICE * S3C24X0_GetBase_USB_DEVICE(void) +static inline struct s3c24x0_usb_device *s3c24x0_get_base_usb_device(void) { - return (S3C24X0_USB_DEVICE * const)S3C24X0_USB_DEVICE_BASE; + return (struct s3c24x0_usb_device *)S3C24X0_USB_DEVICE_BASE; } -static inline S3C24X0_WATCHDOG * S3C24X0_GetBase_WATCHDOG(void) +static inline struct s3c24x0_watchdog *s3c24x0_get_base_watchdog(void) { - return (S3C24X0_WATCHDOG * const)S3C24X0_WATCHDOG_BASE; + return (struct s3c24x0_watchdog *)S3C24X0_WATCHDOG_BASE; } -static inline S3C24X0_I2C * S3C24X0_GetBase_I2C(void) +static inline struct s3c24x0_i2c *s3c24x0_get_base_i2c(void) { - return (S3C24X0_I2C * const)S3C24X0_I2C_BASE; + return (struct s3c24x0_i2c *)S3C24X0_I2C_BASE; } -static inline S3C24X0_I2S * S3C24X0_GetBase_I2S(void) +static inline struct s3c24x0_i2s *s3c24x0_get_base_i2s(void) { - return (S3C24X0_I2S * const)S3C24X0_I2S_BASE; + return (struct s3c24x0_i2s *)S3C24X0_I2S_BASE; } -static inline S3C24X0_GPIO * S3C24X0_GetBase_GPIO(void) +static inline struct s3c24x0_gpio *s3c24x0_get_base_gpio(void) { - return (S3C24X0_GPIO * const)S3C24X0_GPIO_BASE; + return (struct s3c24x0_gpio *)S3C24X0_GPIO_BASE; } -static inline S3C24X0_RTC * S3C24X0_GetBase_RTC(void) +static inline struct s3c24x0_rtc *s3c24x0_get_base_rtc(void) { - return (S3C24X0_RTC * const)S3C24X0_RTC_BASE; + return (struct s3c24x0_rtc *)S3C24X0_RTC_BASE; } -static inline S3C2410_ADC * S3C2410_GetBase_ADC(void) +static inline struct s3c2410_adc *s3c2410_get_base_adc(void) { - return (S3C2410_ADC * const)S3C2410_ADC_BASE; + return (struct s3c2410_adc *)S3C2410_ADC_BASE; } -static inline S3C24X0_SPI * S3C24X0_GetBase_SPI(void) +static inline struct s3c24x0_spi *s3c24x0_get_base_spi(void) { - return (S3C24X0_SPI * const)S3C24X0_SPI_BASE; + return (struct s3c24x0_spi *)S3C24X0_SPI_BASE; } -static inline S3C2410_SDI * S3C2410_GetBase_SDI(void) +static inline struct s3c2410_sdi *s3c2410_get_base_sdi(void) { - return (S3C2410_SDI * const)S3C2410_SDI_BASE; + return (struct s3c2410_sdi *)S3C2410_SDI_BASE; }
- -/* ISR */ -#define pISR_RESET (*(unsigned *)(_ISR_STARTADDRESS+0x0)) -#define pISR_UNDEF (*(unsigned *)(_ISR_STARTADDRESS+0x4)) -#define pISR_SWI (*(unsigned *)(_ISR_STARTADDRESS+0x8)) -#define pISR_PABORT (*(unsigned *)(_ISR_STARTADDRESS+0xC)) -#define pISR_DABORT (*(unsigned *)(_ISR_STARTADDRESS+0x10)) -#define pISR_RESERVED (*(unsigned *)(_ISR_STARTADDRESS+0x14)) -#define pISR_IRQ (*(unsigned *)(_ISR_STARTADDRESS+0x18)) -#define pISR_FIQ (*(unsigned *)(_ISR_STARTADDRESS+0x1C)) - -#define pISR_EINT0 (*(unsigned *)(_ISR_STARTADDRESS+0x20)) -#define pISR_EINT1 (*(unsigned *)(_ISR_STARTADDRESS+0x24)) -#define pISR_EINT2 (*(unsigned *)(_ISR_STARTADDRESS+0x28)) -#define pISR_EINT3 (*(unsigned *)(_ISR_STARTADDRESS+0x2C)) -#define pISR_EINT4_7 (*(unsigned *)(_ISR_STARTADDRESS+0x30)) -#define pISR_EINT8_23 (*(unsigned *)(_ISR_STARTADDRESS+0x34)) -#define pISR_BAT_FLT (*(unsigned *)(_ISR_STARTADDRESS+0x3C)) -#define pISR_TICK (*(unsigned *)(_ISR_STARTADDRESS+0x40)) -#define pISR_WDT (*(unsigned *)(_ISR_STARTADDRESS+0x44)) -#define pISR_TIMER0 (*(unsigned *)(_ISR_STARTADDRESS+0x48)) -#define pISR_TIMER1 (*(unsigned *)(_ISR_STARTADDRESS+0x4C)) -#define pISR_TIMER2 (*(unsigned *)(_ISR_STARTADDRESS+0x50)) -#define pISR_TIMER3 (*(unsigned *)(_ISR_STARTADDRESS+0x54)) -#define pISR_TIMER4 (*(unsigned *)(_ISR_STARTADDRESS+0x58)) -#define pISR_UART2 (*(unsigned *)(_ISR_STARTADDRESS+0x5C)) -#define pISR_NOTUSED (*(unsigned *)(_ISR_STARTADDRESS+0x60)) -#define pISR_DMA0 (*(unsigned *)(_ISR_STARTADDRESS+0x64)) -#define pISR_DMA1 (*(unsigned *)(_ISR_STARTADDRESS+0x68)) -#define pISR_DMA2 (*(unsigned *)(_ISR_STARTADDRESS+0x6C)) -#define pISR_DMA3 (*(unsigned *)(_ISR_STARTADDRESS+0x70)) -#define pISR_SDI (*(unsigned *)(_ISR_STARTADDRESS+0x74)) -#define pISR_SPI0 (*(unsigned *)(_ISR_STARTADDRESS+0x78)) -#define pISR_UART1 (*(unsigned *)(_ISR_STARTADDRESS+0x7C)) -#define pISR_USBD (*(unsigned *)(_ISR_STARTADDRESS+0x84)) -#define pISR_USBH (*(unsigned *)(_ISR_STARTADDRESS+0x88)) -#define pISR_IIC (*(unsigned *)(_ISR_STARTADDRESS+0x8C)) -#define pISR_UART0 (*(unsigned *)(_ISR_STARTADDRESS+0x90)) -#define pISR_SPI1 (*(unsigned *)(_ISR_STARTADDRESS+0x94)) -#define pISR_RTC (*(unsigned *)(_ISR_STARTADDRESS+0x98)) -#define pISR_ADC (*(unsigned *)(_ISR_STARTADDRESS+0xA0)) - - -/* PENDING BIT */ -#define BIT_EINT0 (0x1) -#define BIT_EINT1 (0x1<<1) -#define BIT_EINT2 (0x1<<2) -#define BIT_EINT3 (0x1<<3) -#define BIT_EINT4_7 (0x1<<4) -#define BIT_EINT8_23 (0x1<<5) -#define BIT_BAT_FLT (0x1<<7) -#define BIT_TICK (0x1<<8) -#define BIT_WDT (0x1<<9) -#define BIT_TIMER0 (0x1<<10) -#define BIT_TIMER1 (0x1<<11) -#define BIT_TIMER2 (0x1<<12) -#define BIT_TIMER3 (0x1<<13) -#define BIT_TIMER4 (0x1<<14) -#define BIT_UART2 (0x1<<15) -#define BIT_LCD (0x1<<16) -#define BIT_DMA0 (0x1<<17) -#define BIT_DMA1 (0x1<<18) -#define BIT_DMA2 (0x1<<19) -#define BIT_DMA3 (0x1<<20) -#define BIT_SDI (0x1<<21) -#define BIT_SPI0 (0x1<<22) -#define BIT_UART1 (0x1<<23) -#define BIT_USBD (0x1<<25) -#define BIT_USBH (0x1<<26) -#define BIT_IIC (0x1<<27) -#define BIT_UART0 (0x1<<28) -#define BIT_SPI1 (0x1<<29) -#define BIT_RTC (0x1<<30) -#define BIT_ADC (0x1<<31) -#define BIT_ALLMSK (0xFFFFFFFF) - -#define ClearPending(bit) {\ - rSRCPND = bit;\ - rINTPND = bit;\ - rINTPND;\ - } -/* Wait until rINTPND is changed for the case that the ISR is very short. */ #endif /*__S3C2410_H__*/ diff --git a/include/s3c24x0.h b/include/s3c24x0.h index 4fa8000..56a551a 100644 --- a/include/s3c24x0.h +++ b/include/s3c24x0.h @@ -36,18 +36,18 @@ typedef volatile u16 S3C24X0_REG16; typedef volatile u32 S3C24X0_REG32;
/* Memory controller (see manual chapter 5) */ -typedef struct { +struct s3c24x0_memctl { S3C24X0_REG32 BWSCON; S3C24X0_REG32 BANKCON[8]; S3C24X0_REG32 REFRESH; S3C24X0_REG32 BANKSIZE; S3C24X0_REG32 MRSRB6; S3C24X0_REG32 MRSRB7; -} /*__attribute__((__packed__))*/ S3C24X0_MEMCTL; +};
/* USB HOST (see manual chapter 12) */ -typedef struct { +struct s3c24x0_usb_host { S3C24X0_REG32 HcRevision; S3C24X0_REG32 HcControl; S3C24X0_REG32 HcCommonStatus; @@ -71,11 +71,11 @@ typedef struct { S3C24X0_REG32 HcRhStatus; S3C24X0_REG32 HcRhPortStatus1; S3C24X0_REG32 HcRhPortStatus2; -} /*__attribute__((__packed__))*/ S3C24X0_USB_HOST; +};
/* INTERRUPT (see manual chapter 14) */ -typedef struct { +struct s3c24x0_interrupt { S3C24X0_REG32 SRCPND; S3C24X0_REG32 INTMOD; S3C24X0_REG32 INTMSK; @@ -86,11 +86,11 @@ typedef struct { S3C24X0_REG32 SUBSRCPND; S3C24X0_REG32 INTSUBMSK; #endif -} /*__attribute__((__packed__))*/ S3C24X0_INTERRUPT; +};
/* DMAS (see manual chapter 8) */ -typedef struct { +struct s3c24x0_dma { S3C24X0_REG32 DISRC; #ifdef CONFIG_S3C2410 S3C24X0_REG32 DISRCC; @@ -110,27 +110,27 @@ typedef struct { #ifdef CONFIG_S3C2410 S3C24X0_REG32 res[7]; #endif -} /*__attribute__((__packed__))*/ S3C24X0_DMA; +};
-typedef struct { - S3C24X0_DMA dma[4]; -} /*__attribute__((__packed__))*/ S3C24X0_DMAS; +struct s3c24x0_dmas { + struct s3c24x0_dma dma[4]; +};
/* CLOCK & POWER MANAGEMENT (see S3C2400 manual chapter 6) */ /* (see S3C2410 manual chapter 7) */ -typedef struct { +struct s3c24x0_clock_power { S3C24X0_REG32 LOCKTIME; S3C24X0_REG32 MPLLCON; S3C24X0_REG32 UPLLCON; S3C24X0_REG32 CLKCON; S3C24X0_REG32 CLKSLOW; S3C24X0_REG32 CLKDIVN; -} /*__attribute__((__packed__))*/ S3C24X0_CLOCK_POWER; +};
/* LCD CONTROLLER (see manual chapter 15) */ -typedef struct { +struct s3c24x0_lcd { S3C24X0_REG32 LCDCON1; S3C24X0_REG32 LCDCON2; S3C24X0_REG32 LCDCON3; @@ -151,22 +151,22 @@ typedef struct { S3C24X0_REG32 LCDINTMSK; S3C24X0_REG32 LPCSEL; #endif -} /*__attribute__((__packed__))*/ S3C24X0_LCD; +};
/* NAND FLASH (see S3C2410 manual chapter 6) */ -typedef struct { +struct s3c2410_nand { S3C24X0_REG32 NFCONF; S3C24X0_REG32 NFCMD; S3C24X0_REG32 NFADDR; S3C24X0_REG32 NFDATA; S3C24X0_REG32 NFSTAT; S3C24X0_REG32 NFECC; -} /*__attribute__((__packed__))*/ S3C2410_NAND; +};
/* UART (see manual chapter 11) */ -typedef struct { +struct s3c24x0_uart { S3C24X0_REG32 ULCON; S3C24X0_REG32 UCON; S3C24X0_REG32 UFCON; @@ -187,28 +187,28 @@ typedef struct { S3C24X0_REG8 res2[3]; #endif S3C24X0_REG32 UBRDIV; -} /*__attribute__((__packed__))*/ S3C24X0_UART; +};
/* PWM TIMER (see manual chapter 10) */ -typedef struct { +struct s3c24x0_timer { S3C24X0_REG32 TCNTB; S3C24X0_REG32 TCMPB; S3C24X0_REG32 TCNTO; -} /*__attribute__((__packed__))*/ S3C24X0_TIMER; +};
-typedef struct { - S3C24X0_REG32 TCFG0; - S3C24X0_REG32 TCFG1; - S3C24X0_REG32 TCON; - S3C24X0_TIMER ch[4]; - S3C24X0_REG32 TCNTB4; - S3C24X0_REG32 TCNTO4; -} /*__attribute__((__packed__))*/ S3C24X0_TIMERS; +struct s3c24x0_timers { + S3C24X0_REG32 TCFG0; + S3C24X0_REG32 TCFG1; + S3C24X0_REG32 TCON; + struct s3c24x0_timer ch[4]; + S3C24X0_REG32 TCNTB4; + S3C24X0_REG32 TCNTO4; +};
/* USB DEVICE (see manual chapter 13) */ -typedef struct { +struct s3c24x0_usb_dev_fifos { #ifdef __BIG_ENDIAN S3C24X0_REG8 res[3]; S3C24X0_REG8 EP_FIFO_REG; @@ -216,9 +216,9 @@ typedef struct { S3C24X0_REG8 EP_FIFO_REG; S3C24X0_REG8 res[3]; #endif -} /*__attribute__((__packed__))*/ S3C24X0_USB_DEV_FIFOS; +};
-typedef struct { +struct s3c24x0_usb_dev_dmas { #ifdef __BIG_ENDIAN S3C24X0_REG8 res1[3]; S3C24X0_REG8 EP_DMA_CON; @@ -246,9 +246,9 @@ typedef struct { S3C24X0_REG8 EP_DMA_TTC_H; S3C24X0_REG8 res6[3]; #endif -} /*__attribute__((__packed__))*/ S3C24X0_USB_DEV_DMAS; +};
-typedef struct { +struct s3c24x0_usb_device { #ifdef __BIG_ENDIAN S3C24X0_REG8 res1[3]; S3C24X0_REG8 FUNC_ADDR_REG; @@ -316,30 +316,30 @@ typedef struct { S3C24X0_REG8 OUT_FIFO_CNT2_REG; S3C24X0_REG8 res16[3]; #endif /* __BIG_ENDIAN */ - S3C24X0_USB_DEV_FIFOS fifo[5]; - S3C24X0_USB_DEV_DMAS dma[5]; -} /*__attribute__((__packed__))*/ S3C24X0_USB_DEVICE; + struct s3c24x0_usb_dev_fifos fifo[5]; + struct s3c24x0_usb_dev_dmas dma[5]; +};
/* WATCH DOG TIMER (see manual chapter 18) */ -typedef struct { +struct s3c24x0_watchdog { S3C24X0_REG32 WTCON; S3C24X0_REG32 WTDAT; S3C24X0_REG32 WTCNT; -} /*__attribute__((__packed__))*/ S3C24X0_WATCHDOG; +};
/* IIC (see manual chapter 20) */ -typedef struct { +struct s3c24x0_i2c { S3C24X0_REG32 IICCON; S3C24X0_REG32 IICSTAT; S3C24X0_REG32 IICADD; S3C24X0_REG32 IICDS; -} /*__attribute__((__packed__))*/ S3C24X0_I2C; +};
/* IIS (see manual chapter 21) */ -typedef struct { +struct s3c24x0_i2s { #ifdef __BIG_ENDIAN S3C24X0_REG16 res1; S3C24X0_REG16 IISCON; @@ -363,11 +363,11 @@ typedef struct { S3C24X0_REG16 IISFIFO; S3C24X0_REG16 res5; #endif -} /*__attribute__((__packed__))*/ S3C24X0_I2S; +};
/* I/O PORT (see manual chapter 9) */ -typedef struct { +struct s3c24x0_gpio { #ifdef CONFIG_S3C2400 S3C24X0_REG32 PACON; S3C24X0_REG32 PADAT; @@ -451,11 +451,11 @@ typedef struct { S3C24X0_REG32 GSTATUS3; S3C24X0_REG32 GSTATUS4; #endif -} /*__attribute__((__packed__))*/ S3C24X0_GPIO; +};
/* RTC (see manual chapter 17) */ -typedef struct { +struct s3c24x0_rtc { #ifdef __BIG_ENDIAN S3C24X0_REG8 res1[67]; S3C24X0_REG8 RTCCON; @@ -528,28 +528,28 @@ typedef struct { S3C24X0_REG8 BCDYEAR; S3C24X0_REG8 res17[3]; #endif -} /*__attribute__((__packed__))*/ S3C24X0_RTC; +};
/* ADC (see manual chapter 16) */ -typedef struct { +struct s3c2400_adc { S3C24X0_REG32 ADCCON; S3C24X0_REG32 ADCDAT; -} /*__attribute__((__packed__))*/ S3C2400_ADC; +};
/* ADC (see manual chapter 16) */ -typedef struct { +struct s3c2410_adc { S3C24X0_REG32 ADCCON; S3C24X0_REG32 ADCTSC; S3C24X0_REG32 ADCDLY; S3C24X0_REG32 ADCDAT0; S3C24X0_REG32 ADCDAT1; -} /*__attribute__((__packed__))*/ S3C2410_ADC; +};
/* SPI (see manual chapter 22) */ -typedef struct { +struct s3c24x0_spi_channel { S3C24X0_REG8 SPCON; S3C24X0_REG8 res1[3]; S3C24X0_REG8 SPSTA; @@ -563,15 +563,15 @@ typedef struct { S3C24X0_REG8 SPRDAT; S3C24X0_REG8 res6[3]; S3C24X0_REG8 res7[16]; -} /*__attribute__((__packed__))*/ S3C24X0_SPI_CHANNEL; +};
-typedef struct { - S3C24X0_SPI_CHANNEL ch[S3C24X0_SPI_CHANNELS]; -} /*__attribute__((__packed__))*/ S3C24X0_SPI; +struct s3c24x0_spi { + struct s3c24x0_spi_channel ch[S3C24X0_SPI_CHANNELS]; +};
/* MMC INTERFACE (see S3C2400 manual chapter 19) */ -typedef struct { +struct s3c2400_mmc { #ifdef __BIG_ENDIAN S3C24X0_REG8 res1[3]; S3C24X0_REG8 MMCON; @@ -623,11 +623,11 @@ typedef struct { S3C24X0_REG8 MMDAT; S3C24X0_REG8 res11[3]; #endif -} /*__attribute__((__packed__))*/ S3C2400_MMC; +};
/* SD INTERFACE (see S3C2410 manual chapter 19) */ -typedef struct { +struct s3c2410_sdi { S3C24X0_REG32 SDICON; S3C24X0_REG32 SDIPRE; S3C24X0_REG32 SDICARG; @@ -651,491 +651,6 @@ typedef struct { S3C24X0_REG8 res[3]; #endif S3C24X0_REG32 SDIIMSK; -} /*__attribute__((__packed__))*/ S3C2410_SDI; - - -#if 0 -/* Memory control */ -#define rBWSCON (*(volatile unsigned *)0x48000000) -#define rBANKCON0 (*(volatile unsigned *)0x48000004) -#define rBANKCON1 (*(volatile unsigned *)0x48000008) -#define rBANKCON2 (*(volatile unsigned *)0x4800000C) -#define rBANKCON3 (*(volatile unsigned *)0x48000010) -#define rBANKCON4 (*(volatile unsigned *)0x48000014) -#define rBANKCON5 (*(volatile unsigned *)0x48000018) -#define rBANKCON6 (*(volatile unsigned *)0x4800001C) -#define rBANKCON7 (*(volatile unsigned *)0x48000020) -#define rREFRESH (*(volatile unsigned *)0x48000024) -#define rBANKSIZE (*(volatile unsigned *)0x48000028) -#define rMRSRB6 (*(volatile unsigned *)0x4800002C) -#define rMRSRB7 (*(volatile unsigned *)0x48000030) - - -/* USB HOST */ -#define rHcRevision (*(volatile unsigned *)0x49000000) -#define rHcControl (*(volatile unsigned *)0x49000004) -#define rHcCommonStatus (*(volatile unsigned *)0x49000008) -#define rHcInterruptStatus (*(volatile unsigned *)0x4900000C) -#define rHcInterruptEnable (*(volatile unsigned *)0x49000010) -#define rHcInterruptDisable (*(volatile unsigned *)0x49000014) -#define rHcHCCA (*(volatile unsigned *)0x49000018) -#define rHcPeriodCuttendED (*(volatile unsigned *)0x4900001C) -#define rHcControlHeadED (*(volatile unsigned *)0x49000020) -#define rHcControlCurrentED (*(volatile unsigned *)0x49000024) -#define rHcBulkHeadED (*(volatile unsigned *)0x49000028) -#define rHcBuldCurrentED (*(volatile unsigned *)0x4900002C) -#define rHcDoneHead (*(volatile unsigned *)0x49000030) -#define rHcRmInterval (*(volatile unsigned *)0x49000034) -#define rHcFmRemaining (*(volatile unsigned *)0x49000038) -#define rHcFmNumber (*(volatile unsigned *)0x4900003C) -#define rHcPeriodicStart (*(volatile unsigned *)0x49000040) -#define rHcLSThreshold (*(volatile unsigned *)0x49000044) -#define rHcRhDescriptorA (*(volatile unsigned *)0x49000048) -#define rHcRhDescriptorB (*(volatile unsigned *)0x4900004C) -#define rHcRhStatus (*(volatile unsigned *)0x49000050) -#define rHcRhPortStatus1 (*(volatile unsigned *)0x49000054) -#define rHcRhPortStatus2 (*(volatile unsigned *)0x49000058) - - -/* INTERRUPT */ -#define rSRCPND (*(volatile unsigned *)0x4A000000) -#define rINTMOD (*(volatile unsigned *)0x4A000004) -#define rINTMSK (*(volatile unsigned *)0x4A000008) -#define rPRIORITY (*(volatile unsigned *)0x4A00000C) -#define rINTPND (*(volatile unsigned *)0x4A000010) -#define rINTOFFSET (*(volatile unsigned *)0x4A000014) -#define rSUBSRCPND (*(volatile unsigned *)0x4A000018) -#define rINTSUBMSK (*(volatile unsigned *)0x4A00001C) - - -/* DMA */ -#define rDISRC0 (*(volatile unsigned *)0x4B000000) -#define rDISRCC0 (*(volatile unsigned *)0x4B000004) -#define rDIDST0 (*(volatile unsigned *)0x4B000008) -#define rDIDSTC0 (*(volatile unsigned *)0x4B00000C) -#define rDCON0 (*(volatile unsigned *)0x4B000010) -#define rDSTAT0 (*(volatile unsigned *)0x4B000014) -#define rDCSRC0 (*(volatile unsigned *)0x4B000018) -#define rDCDST0 (*(volatile unsigned *)0x4B00001C) -#define rDMASKTRIG0 (*(volatile unsigned *)0x4B000020) -#define rDISRC1 (*(volatile unsigned *)0x4B000040) -#define rDISRCC1 (*(volatile unsigned *)0x4B000044) -#define rDIDST1 (*(volatile unsigned *)0x4B000048) -#define rDIDSTC1 (*(volatile unsigned *)0x4B00004C) -#define rDCON1 (*(volatile unsigned *)0x4B000050) -#define rDSTAT1 (*(volatile unsigned *)0x4B000054) -#define rDCSRC1 (*(volatile unsigned *)0x4B000058) -#define rDCDST1 (*(volatile unsigned *)0x4B00005C) -#define rDMASKTRIG1 (*(volatile unsigned *)0x4B000060) -#define rDISRC2 (*(volatile unsigned *)0x4B000080) -#define rDISRCC2 (*(volatile unsigned *)0x4B000084) -#define rDIDST2 (*(volatile unsigned *)0x4B000088) -#define rDIDSTC2 (*(volatile unsigned *)0x4B00008C) -#define rDCON2 (*(volatile unsigned *)0x4B000090) -#define rDSTAT2 (*(volatile unsigned *)0x4B000094) -#define rDCSRC2 (*(volatile unsigned *)0x4B000098) -#define rDCDST2 (*(volatile unsigned *)0x4B00009C) -#define rDMASKTRIG2 (*(volatile unsigned *)0x4B0000A0) -#define rDISRC3 (*(volatile unsigned *)0x4B0000C0) -#define rDISRCC3 (*(volatile unsigned *)0x4B0000C4) -#define rDIDST3 (*(volatile unsigned *)0x4B0000C8) -#define rDIDSTC3 (*(volatile unsigned *)0x4B0000CC) -#define rDCON3 (*(volatile unsigned *)0x4B0000D0) -#define rDSTAT3 (*(volatile unsigned *)0x4B0000D4) -#define rDCSRC3 (*(volatile unsigned *)0x4B0000D8) -#define rDCDST3 (*(volatile unsigned *)0x4B0000DC) -#define rDMASKTRIG3 (*(volatile unsigned *)0x4B0000E0) - - -/* CLOCK & POWER MANAGEMENT */ -#define rLOCKTIME (*(volatile unsigned *)0x4C000000) -#define rMPLLCON (*(volatile unsigned *)0x4C000004) -#define rUPLLCON (*(volatile unsigned *)0x4C000008) -#define rCLKCON (*(volatile unsigned *)0x4C00000C) -#define rCLKSLOW (*(volatile unsigned *)0x4C000010) -#define rCLKDIVN (*(volatile unsigned *)0x4C000014) - - -/* LCD CONTROLLER */ -#define rLCDCON1 (*(volatile unsigned *)0x4D000000) -#define rLCDCON2 (*(volatile unsigned *)0x4D000004) -#define rLCDCON3 (*(volatile unsigned *)0x4D000008) -#define rLCDCON4 (*(volatile unsigned *)0x4D00000C) -#define rLCDCON5 (*(volatile unsigned *)0x4D000010) -#define rLCDSADDR1 (*(volatile unsigned *)0x4D000014) -#define rLCDSADDR2 (*(volatile unsigned *)0x4D000018) -#define rLCDSADDR3 (*(volatile unsigned *)0x4D00001C) -#define rREDLUT (*(volatile unsigned *)0x4D000020) -#define rGREENLUT (*(volatile unsigned *)0x4D000024) -#define rBLUELUT (*(volatile unsigned *)0x4D000028) -#define rDITHMODE (*(volatile unsigned *)0x4D00004C) -#define rTPAL (*(volatile unsigned *)0x4D000050) -#define rLCDINTPND (*(volatile unsigned *)0x4D000054) -#define rLCDSRCPND (*(volatile unsigned *)0x4D000058) -#define rLCDINTMSK (*(volatile unsigned *)0x4D00005C) - - -/* NAND FLASH */ -#define rNFCONF (*(volatile unsigned *)0x4E000000) -#define rNFCMD (*(volatile unsigned *)0x4E000004) -#define rNFADDR (*(volatile unsigned *)0x4E000008) -#define rNFDATA (*(volatile unsigned *)0x4E00000C) -#define rNFSTAT (*(volatile unsigned *)0x4E000010) -#define rNFECC (*(volatile unsigned *)0x4E000014) - - -/* UART */ -#define rULCON0 (*(volatile unsigned *)0x50000000) -#define rUCON0 (*(volatile unsigned *)0x50000004) -#define rUFCON0 (*(volatile unsigned *)0x50000008) -#define rUMCON0 (*(volatile unsigned *)0x5000000C) -#define rUTRSTAT0 (*(volatile unsigned *)0x50000010) -#define rUERSTAT0 (*(volatile unsigned *)0x50000014) -#define rUFSTAT0 (*(volatile unsigned *)0x50000018) -#define rUMSTAT0 (*(volatile unsigned *)0x5000001C) -#define rUBRDIV0 (*(volatile unsigned *)0x50000028) - -#define rULCON1 (*(volatile unsigned *)0x50004000) -#define rUCON1 (*(volatile unsigned *)0x50004004) -#define rUFCON1 (*(volatile unsigned *)0x50004008) -#define rUMCON1 (*(volatile unsigned *)0x5000400C) -#define rUTRSTAT1 (*(volatile unsigned *)0x50004010) -#define rUERSTAT1 (*(volatile unsigned *)0x50004014) -#define rUFSTAT1 (*(volatile unsigned *)0x50004018) -#define rUMSTAT1 (*(volatile unsigned *)0x5000401C) -#define rUBRDIV1 (*(volatile unsigned *)0x50004028) - -#define rULCON2 (*(volatile unsigned *)0x50008000) -#define rUCON2 (*(volatile unsigned *)0x50008004) -#define rUFCON2 (*(volatile unsigned *)0x50008008) -#define rUTRSTAT2 (*(volatile unsigned *)0x50008010) -#define rUERSTAT2 (*(volatile unsigned *)0x50008014) -#define rUFSTAT2 (*(volatile unsigned *)0x50008018) -#define rUBRDIV2 (*(volatile unsigned *)0x50008028) - -#ifdef __BIG_ENDIAN -#define rUTXH0 (*(volatile unsigned char *)0x50000023) -#define rURXH0 (*(volatile unsigned char *)0x50000027) -#define rUTXH1 (*(volatile unsigned char *)0x50004023) -#define rURXH1 (*(volatile unsigned char *)0x50004027) -#define rUTXH2 (*(volatile unsigned char *)0x50008023) -#define rURXH2 (*(volatile unsigned char *)0x50008027) - -#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000023)=(unsigned char)(ch) -#define RdURXH0() (*(volatile unsigned char *)0x50000027) -#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004023)=(unsigned char)(ch) -#define RdURXH1() (*(volatile unsigned char *)0x50004027) -#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008023)=(unsigned char)(ch) -#define RdURXH2() (*(volatile unsigned char *)0x50008027) - -#define UTXH0 (0x50000020+3) /* byte_access address by DMA */ -#define URXH0 (0x50000024+3) -#define UTXH1 (0x50004020+3) -#define URXH1 (0x50004024+3) -#define UTXH2 (0x50008020+3) -#define URXH2 (0x50008024+3) - -#else /* Little Endian */ -#define rUTXH0 (*(volatile unsigned char *)0x50000020) -#define rURXH0 (*(volatile unsigned char *)0x50000024) -#define rUTXH1 (*(volatile unsigned char *)0x50004020) -#define rURXH1 (*(volatile unsigned char *)0x50004024) -#define rUTXH2 (*(volatile unsigned char *)0x50008020) -#define rURXH2 (*(volatile unsigned char *)0x50008024) - -#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch) -#define RdURXH0() (*(volatile unsigned char *)0x50000024) -#define WrUTXH1(ch) (*(volatile unsigned char *)0x50004020)=(unsigned char)(ch) -#define RdURXH1() (*(volatile unsigned char *)0x50004024) -#define WrUTXH2(ch) (*(volatile unsigned char *)0x50008020)=(unsigned char)(ch) -#define RdURXH2() (*(volatile unsigned char *)0x50008024) - -#define UTXH0 (0x50000020) /* byte_access address by DMA */ -#define URXH0 (0x50000024) -#define UTXH1 (0x50004020) -#define URXH1 (0x50004024) -#define UTXH2 (0x50008020) -#define URXH2 (0x50008024) -#endif - - -/* PWM TIMER */ -#define rTCFG0 (*(volatile unsigned *)0x51000000) -#define rTCFG1 (*(volatile unsigned *)0x51000004) -#define rTCON (*(volatile unsigned *)0x51000008) -#define rTCNTB0 (*(volatile unsigned *)0x5100000C) -#define rTCMPB0 (*(volatile unsigned *)0x51000010) -#define rTCNTO0 (*(volatile unsigned *)0x51000014) -#define rTCNTB1 (*(volatile unsigned *)0x51000018) -#define rTCMPB1 (*(volatile unsigned *)0x5100001C) -#define rTCNTO1 (*(volatile unsigned *)0x51000020) -#define rTCNTB2 (*(volatile unsigned *)0x51000024) -#define rTCMPB2 (*(volatile unsigned *)0x51000028) -#define rTCNTO2 (*(volatile unsigned *)0x5100002C) -#define rTCNTB3 (*(volatile unsigned *)0x51000030) -#define rTCMPB3 (*(volatile unsigned *)0x51000034) -#define rTCNTO3 (*(volatile unsigned *)0x51000038) -#define rTCNTB4 (*(volatile unsigned *)0x5100003C) -#define rTCNTO4 (*(volatile unsigned *)0x51000040) - - -/* USB DEVICE */ -#ifdef __BIG_ENDIAN -#define rFUNC_ADDR_REG (*(volatile unsigned char *)0x52000143) -#define rPWR_REG (*(volatile unsigned char *)0x52000147) -#define rEP_INT_REG (*(volatile unsigned char *)0x5200014B) -#define rUSB_INT_REG (*(volatile unsigned char *)0x5200015B) -#define rEP_INT_EN_REG (*(volatile unsigned char *)0x5200015F) -#define rUSB_INT_EN_REG (*(volatile unsigned char *)0x5200016F) -#define rFRAME_NUM1_REG (*(volatile unsigned char *)0x52000173) -#define rFRAME_NUM2_REG (*(volatile unsigned char *)0x52000177) -#define rINDEX_REG (*(volatile unsigned char *)0x5200017B) -#define rMAXP_REG (*(volatile unsigned char *)0x52000183) -#define rEP0_CSR (*(volatile unsigned char *)0x52000187) -#define rIN_CSR1_REG (*(volatile unsigned char *)0x52000187) -#define rIN_CSR2_REG (*(volatile unsigned char *)0x5200018B) -#define rOUT_CSR1_REG (*(volatile unsigned char *)0x52000193) -#define rOUT_CSR2_REG (*(volatile unsigned char *)0x52000197) -#define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x5200019B) -#define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019F) -#define rEP0_FIFO (*(volatile unsigned char *)0x520001C3) -#define rEP1_FIFO (*(volatile unsigned char *)0x520001C7) -#define rEP2_FIFO (*(volatile unsigned char *)0x520001CB) -#define rEP3_FIFO (*(volatile unsigned char *)0x520001CF) -#define rEP4_FIFO (*(volatile unsigned char *)0x520001D3) -#define rEP1_DMA_CON (*(volatile unsigned char *)0x52000203) -#define rEP1_DMA_UNIT (*(volatile unsigned char *)0x52000207) -#define rEP1_DMA_FIFO (*(volatile unsigned char *)0x5200020B) -#define rEP1_DMA_TX_LO (*(volatile unsigned char *)0x5200020F) -#define rEP1_DMA_TX_MD (*(volatile unsigned char *)0x52000213) -#define rEP1_DMA_TX_HI (*(volatile unsigned char *)0x52000217) -#define rEP2_DMA_CON (*(volatile unsigned char *)0x5200021B) -#define rEP2_DMA_UNIT (*(volatile unsigned char *)0x5200021F) -#define rEP2_DMA_FIFO (*(volatile unsigned char *)0x52000223) -#define rEP2_DMA_TX_LO (*(volatile unsigned char *)0x52000227) -#define rEP2_DMA_TX_MD (*(volatile unsigned char *)0x5200022B) -#define rEP2_DMA_TX_HI (*(volatile unsigned char *)0x5200022F) -#define rEP3_DMA_CON (*(volatile unsigned char *)0x52000243) -#define rEP3_DMA_UNIT (*(volatile unsigned char *)0x52000247) -#define rEP3_DMA_FIFO (*(volatile unsigned char *)0x5200024B) -#define rEP3_DMA_TX_LO (*(volatile unsigned char *)0x5200024F) -#define rEP3_DMA_TX_MD (*(volatile unsigned char *)0x52000253) -#define rEP3_DMA_TX_HI (*(volatile unsigned char *)0x52000257) -#define rEP4_DMA_CON (*(volatile unsigned char *)0x5200025B) -#define rEP4_DMA_UNIT (*(volatile unsigned char *)0x5200025F) -#define rEP4_DMA_FIFO (*(volatile unsigned char *)0x52000263) -#define rEP4_DMA_TX_LO (*(volatile unsigned char *)0x52000267) -#define rEP4_DMA_TX_MD (*(volatile unsigned char *)0x5200026B) -#define rEP4_DMA_TX_HI (*(volatile unsigned char *)0x5200026F) -#else /* little endian */ -#define rFUNC_ADDR_REG (*(volatile unsigned char *)0x52000140) -#define rPWR_REG (*(volatile unsigned char *)0x52000144) -#define rEP_INT_REG (*(volatile unsigned char *)0x52000148) -#define rUSB_INT_REG (*(volatile unsigned char *)0x52000158) -#define rEP_INT_EN_REG (*(volatile unsigned char *)0x5200015C) -#define rUSB_INT_EN_REG (*(volatile unsigned char *)0x5200016C) -#define rFRAME_NUM1_REG (*(volatile unsigned char *)0x52000170) -#define rFRAME_NUM2_REG (*(volatile unsigned char *)0x52000174) -#define rINDEX_REG (*(volatile unsigned char *)0x52000178) -#define rMAXP_REG (*(volatile unsigned char *)0x52000180) -#define rEP0_CSR (*(volatile unsigned char *)0x52000184) -#define rIN_CSR1_REG (*(volatile unsigned char *)0x52000184) -#define rIN_CSR2_REG (*(volatile unsigned char *)0x52000188) -#define rOUT_CSR1_REG (*(volatile unsigned char *)0x52000190) -#define rOUT_CSR2_REG (*(volatile unsigned char *)0x52000194) -#define rOUT_FIFO_CNT1_REG (*(volatile unsigned char *)0x52000198) -#define rOUT_FIFO_CNT2_REG (*(volatile unsigned char *)0x5200019C) -#define rEP0_FIFO (*(volatile unsigned char *)0x520001C0) -#define rEP1_FIFO (*(volatile unsigned char *)0x520001C4) -#define rEP2_FIFO (*(volatile unsigned char *)0x520001C8) -#define rEP3_FIFO (*(volatile unsigned char *)0x520001CC) -#define rEP4_FIFO (*(volatile unsigned char *)0x520001D0) -#define rEP1_DMA_CON (*(volatile unsigned char *)0x52000200) -#define rEP1_DMA_UNIT (*(volatile unsigned char *)0x52000204) -#define rEP1_DMA_FIFO (*(volatile unsigned char *)0x52000208) -#define rEP1_DMA_TX_LO (*(volatile unsigned char *)0x5200020C) -#define rEP1_DMA_TX_MD (*(volatile unsigned char *)0x52000210) -#define rEP1_DMA_TX_HI (*(volatile unsigned char *)0x52000214) -#define rEP2_DMA_CON (*(volatile unsigned char *)0x52000218) -#define rEP2_DMA_UNIT (*(volatile unsigned char *)0x5200021C) -#define rEP2_DMA_FIFO (*(volatile unsigned char *)0x52000220) -#define rEP2_DMA_TX_LO (*(volatile unsigned char *)0x52000224) -#define rEP2_DMA_TX_MD (*(volatile unsigned char *)0x52000228) -#define rEP2_DMA_TX_HI (*(volatile unsigned char *)0x5200022C) -#define rEP3_DMA_CON (*(volatile unsigned char *)0x52000240) -#define rEP3_DMA_UNIT (*(volatile unsigned char *)0x52000244) -#define rEP3_DMA_FIFO (*(volatile unsigned char *)0x52000248) -#define rEP3_DMA_TX_LO (*(volatile unsigned char *)0x5200024C) -#define rEP3_DMA_TX_MD (*(volatile unsigned char *)0x52000250) -#define rEP3_DMA_TX_HI (*(volatile unsigned char *)0x52000254) -#define rEP4_DMA_CON (*(volatile unsigned char *)0x52000258) -#define rEP4_DMA_UNIT (*(volatile unsigned char *)0x5200025C) -#define rEP4_DMA_FIFO (*(volatile unsigned char *)0x52000260) -#define rEP4_DMA_TX_LO (*(volatile unsigned char *)0x52000264) -#define rEP4_DMA_TX_MD (*(volatile unsigned char *)0x52000268) -#define rEP4_DMA_TX_HI (*(volatile unsigned char *)0x5200026C) -#endif /* __BIG_ENDIAN */ - - -/* WATCH DOG TIMER */ -#define rWTCON (*(volatile unsigned *)0x53000000) -#define rWTDAT (*(volatile unsigned *)0x53000004) -#define rWTCNT (*(volatile unsigned *)0x53000008) - - -/* IIC */ -#define rIICCON (*(volatile unsigned *)0x54000000) -#define rIICSTAT (*(volatile unsigned *)0x54000004) -#define rIICADD (*(volatile unsigned *)0x54000008) -#define rIICDS (*(volatile unsigned *)0x5400000C) - - -/* IIS */ -#define rIISCON (*(volatile unsigned *)0x55000000) -#define rIISMOD (*(volatile unsigned *)0x55000004) -#define rIISPSR (*(volatile unsigned *)0x55000008) -#define rIISFCON (*(volatile unsigned *)0x5500000C) - -#ifdef __BIG_ENDIAN -#define IISFIF ((volatile unsigned short *)0x55000012) -#else /* little endian */ -#define IISFIF ((volatile unsigned short *)0x55000010) -#endif - - -/* I/O PORT */ -#define rGPACON (*(volatile unsigned *)0x56000000) -#define rGPADAT (*(volatile unsigned *)0x56000004) - -#define rGPBCON (*(volatile unsigned *)0x56000010) -#define rGPBDAT (*(volatile unsigned *)0x56000014) -#define rGPBUP (*(volatile unsigned *)0x56000018) - -#define rGPCCON (*(volatile unsigned *)0x56000020) -#define rGPCDAT (*(volatile unsigned *)0x56000024) -#define rGPCUP (*(volatile unsigned *)0x56000028) - -#define rGPDCON (*(volatile unsigned *)0x56000030) -#define rGPDDAT (*(volatile unsigned *)0x56000034) -#define rGPDUP (*(volatile unsigned *)0x56000038) - -#define rGPECON (*(volatile unsigned *)0x56000040) -#define rGPEDAT (*(volatile unsigned *)0x56000044) -#define rGPEUP (*(volatile unsigned *)0x56000048) - -#define rGPFCON (*(volatile unsigned *)0x56000050) -#define rGPFDAT (*(volatile unsigned *)0x56000054) -#define rGPFUP (*(volatile unsigned *)0x56000058) - -#define rGPGCON (*(volatile unsigned *)0x56000060) -#define rGPGDAT (*(volatile unsigned *)0x56000064) -#define rGPGUP (*(volatile unsigned *)0x56000068) - -#define rGPHCON (*(volatile unsigned *)0x56000070) -#define rGPHDAT (*(volatile unsigned *)0x56000074) -#define rGPHUP (*(volatile unsigned *)0x56000078) - -#define rMISCCR (*(volatile unsigned *)0x56000080) -#define rDCLKCON (*(volatile unsigned *)0x56000084) -#define rEXTINT0 (*(volatile unsigned *)0x56000088) -#define rEXTINT1 (*(volatile unsigned *)0x5600008C) -#define rEXTINT2 (*(volatile unsigned *)0x56000090) -#define rEINTFLT0 (*(volatile unsigned *)0x56000094) -#define rEINTFLT1 (*(volatile unsigned *)0x56000098) -#define rEINTFLT2 (*(volatile unsigned *)0x5600009C) -#define rEINTFLT3 (*(volatile unsigned *)0x560000A0) -#define rEINTMASK (*(volatile unsigned *)0x560000A4) -#define rEINTPEND (*(volatile unsigned *)0x560000A8) -#define rGSTATUS0 (*(volatile unsigned *)0x560000AC) -#define rGSTATUS1 (*(volatile unsigned *)0x560000B0) - - -/* RTC */ -#ifdef __BIG_ENDIAN -#define rRTCCON (*(volatile unsigned char *)0x57000043) -#define rTICNT (*(volatile unsigned char *)0x57000047) -#define rRTCALM (*(volatile unsigned char *)0x57000053) -#define rALMSEC (*(volatile unsigned char *)0x57000057) -#define rALMMIN (*(volatile unsigned char *)0x5700005B) -#define rALMHOUR (*(volatile unsigned char *)0x5700005F) -#define rALMDATE (*(volatile unsigned char *)0x57000063) -#define rALMMON (*(volatile unsigned char *)0x57000067) -#define rALMYEAR (*(volatile unsigned char *)0x5700006B) -#define rRTCRST (*(volatile unsigned char *)0x5700006F) -#define rBCDSEC (*(volatile unsigned char *)0x57000073) -#define rBCDMIN (*(volatile unsigned char *)0x57000077) -#define rBCDHOUR (*(volatile unsigned char *)0x5700007B) -#define rBCDDATE (*(volatile unsigned char *)0x5700007F) -#define rBCDDAY (*(volatile unsigned char *)0x57000083) -#define rBCDMON (*(volatile unsigned char *)0x57000087) -#define rBCDYEAR (*(volatile unsigned char *)0x5700008B) -#else /* little endian */ -#define rRTCCON (*(volatile unsigned char *)0x57000040) -#define rTICNT (*(volatile unsigned char *)0x57000044) -#define rRTCALM (*(volatile unsigned char *)0x57000050) -#define rALMSEC (*(volatile unsigned char *)0x57000054) -#define rALMMIN (*(volatile unsigned char *)0x57000058) -#define rALMHOUR (*(volatile unsigned char *)0x5700005C) -#define rALMDATE (*(volatile unsigned char *)0x57000060) -#define rALMMON (*(volatile unsigned char *)0x57000064) -#define rALMYEAR (*(volatile unsigned char *)0x57000068) -#define rRTCRST (*(volatile unsigned char *)0x5700006C) -#define rBCDSEC (*(volatile unsigned char *)0x57000070) -#define rBCDMIN (*(volatile unsigned char *)0x57000074) -#define rBCDHOUR (*(volatile unsigned char *)0x57000078) -#define rBCDDATE (*(volatile unsigned char *)0x5700007C) -#define rBCDDAY (*(volatile unsigned char *)0x57000080) -#define rBCDMON (*(volatile unsigned char *)0x57000084) -#define rBCDYEAR (*(volatile unsigned char *)0x57000088) -#endif - - -/* ADC */ -#define rADCCON (*(volatile unsigned *)0x58000000) -#define rADCTSC (*(volatile unsigned *)0x58000004) -#define rADCDLY (*(volatile unsigned *)0x58000008) -#define rADCDAT0 (*(volatile unsigned *)0x5800000C) -#define rADCDAT1 (*(volatile unsigned *)0x58000010) - - -/* SPI */ -#define rSPCON0 (*(volatile unsigned *)0x59000000) -#define rSPSTA0 (*(volatile unsigned *)0x59000004) -#define rSPPIN0 (*(volatile unsigned *)0x59000008) -#define rSPPRE0 (*(volatile unsigned *)0x5900000C) -#define rSPTDAT0 (*(volatile unsigned *)0x59000010) -#define rSPRDAT0 (*(volatile unsigned *)0x59000014) -#define rSPCON1 (*(volatile unsigned *)0x59000020) -#define rSPSTA1 (*(volatile unsigned *)0x59000024) -#define rSPPIN1 (*(volatile unsigned *)0x59000028) -#define rSPPRE1 (*(volatile unsigned *)0x5900002C) -#define rSPTDAT1 (*(volatile unsigned *)0x59000030) -#define rSPRDAT1 (*(volatile unsigned *)0x59000034) - - -/* SD INTERFACE */ -#define rSDICON (*(volatile unsigned *)0x5A000000) -#define rSDIPRE (*(volatile unsigned *)0x5A000004) -#define rSDICmdArg (*(volatile unsigned *)0x5A000008) -#define rSDICmdCon (*(volatile unsigned *)0x5A00000C) -#define rSDICmdSta (*(volatile unsigned *)0x5A000010) -#define rSDIRSP0 (*(volatile unsigned *)0x5A000014) -#define rSDIRSP1 (*(volatile unsigned *)0x5A000018) -#define rSDIRSP2 (*(volatile unsigned *)0x5A00001C) -#define rSDIRSP3 (*(volatile unsigned *)0x5A000020) -#define rSDIDTimer (*(volatile unsigned *)0x5A000024) -#define rSDIBSize (*(volatile unsigned *)0x5A000028) -#define rSDIDatCon (*(volatile unsigned *)0x5A00002C) -#define rSDIDatCnt (*(volatile unsigned *)0x5A000030) -#define rSDIDatSta (*(volatile unsigned *)0x5A000034) -#define rSDIFSTA (*(volatile unsigned *)0x5A000038) -#ifdef __BIG_ENDIAN -#define rSDIDAT (*(volatile unsigned char *)0x5A00003F) -#else -#define rSDIDAT (*(volatile unsigned char *)0x5A00003C) -#endif -#define rSDIIntMsk (*(volatile unsigned *)0x5A000040) - -#endif +};
#endif /*__S3C24X0_H__*/
Dear kevin.morfitt
2009/10/10 kevin.morfitt@fearnside-systems.co.uk kevin.morfitt@fearnside-systems.co.uk:
This patch re-formats the arm920t s3c24x0 header files in preparation for changes to add support for the Embest SBC2440-II Board.
The changes are as follows:
- re-indent the code using Lindent
- make sure register layouts are defined using a C struct
- replace the upper-case typedef'ed C struct names with lower case
non-typedef'ed ones
- make sure registers are accessed using the proper accessor functions
- run checkpatch.pl and fix any error reports
It assumes the following patch has been applied first:
- [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009
- patch 1/4 of this series
Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found.
Signed-off-by: Kevin Morfitt kevin.morfitt@fearnside-systems.co.uk
Changes in v2: removed checkpatch.pl errors moved change log
include/s3c2400.h | 494 ++++---------------------------------------- include/s3c2410.h | 159 ++++----------- include/s3c24x0.h | 605 ++++++----------------------------------------------- 3 files changed, 137 insertions(+), 1121 deletions(-)
applied to u-boot-samsung
Thanks Minkyu Kang
Minkyu Kang
