[U-Boot] [PATCH] itest: Add bitwise and operator
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- common/cmd_itest.c | 4 ++++ doc/README.commands.itest | 10 +++++++++- 2 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/common/cmd_itest.c b/common/cmd_itest.c index 2c8e5d0..0629b09 100644 --- a/common/cmd_itest.c +++ b/common/cmd_itest.c @@ -38,6 +38,7 @@ #define GT 3 #define LE 4 #define GE 5 +#define AND 6
struct op_tbl_s { char *op; /* operator string */ @@ -60,6 +61,8 @@ static const op_tbl_t op_table [] = { { ">=" , GE }, { "-le", LE }, { "<=" , LE }, + { "-and", AND }, + { "&" , AND }, };
static long evalexp(char *s, int w) @@ -126,6 +129,7 @@ static int arithcomp (char *s, char *t, int op, int w) case GT: return (l > r); case LE: return (l <= r); case GE: return (l >= r); + case AND: return (l & r); } return (0); } diff --git a/doc/README.commands.itest b/doc/README.commands.itest index 5e0fe86..0058155 100644 --- a/doc/README.commands.itest +++ b/doc/README.commands.itest @@ -2,7 +2,7 @@ A slow day today so here is a revised itest command with provisional support for comparing strings as well :-))
Now table driven to allow the operators --eq, -ne, -lt, -gt, -le, -ge, ==, !=, <>, <, >, <=, >= +-eq, -ne, -lt, -gt, -le, -ge, -and, ==, !=, <>, <, >, <=, >=, &
Uses the expected command modifier for integer compares of width 1, 2 or 4 bytes of .b, .w, .l and the new modifer of .s for a string compare. @@ -14,3 +14,11 @@ if itest.l *40000 == 12345678 then; .... if itest.w *40000 != 1234 then; .... if itest.b *40000 >= 12 then; .... if itest.s *40000 -eq hello then; .... + +Note that "&" (-and) operator only operates on integers and +that the '&' will need to be quoted. + +e.g.: + if itest.l 0x80 '&' *0x020D8044 then; ... +or + if itest.l 0x80 -and *0x020D8044 then; ...
Dear Eric Nelson,
In message 1367606863-14846-1-git-send-email-eric.nelson@boundarydevices.com you wrote:
It does not make much sense to me to add AND, when you not also add OR (and eventually XOR).
Also, now the help message is no longer correct - it says:
189 U_BOOT_CMD( 190 itest, 4, 0, do_itest, 191 "return true/false on integer compare", 192 "[.b, .w, .l, .s] [*]value1 <op> [*]value2" 193 );
but we no longer compare...
Hm, re-reading this I think this is the wrong approach. This stuff does not belong into the "itest" command which really is for comparing, and NOT for operations on the arguments.
If you need operations, then please use "setexpr" - which already has all of this, and more.
Hi Wolfgang,
On 05/03/2013 12:08 PM, Wolfgang Denk wrote:
Dear Eric Nelson,
I only needed to test a bit.
As always, thanks for the guidance.
I hadn't noticed that setexpr supported indirection.
In case this helps someone else, I was looking for a way to detect Android "recovery" mode, which is flagged by bit seven in the SRC_GPR10 register (address 0x020d8044).
And setexpr can be used like so:
U-Boot > md.l 0x020d8044 020d8044: 00000080 .... U-Boot > setexpr rval *0x020D8044 & 0x80 U-Boot > print rval rval=80 U-Boot > setexpr rval *0x020D8044 & 0x40 U-Boot > print rval rval=0
Regards,
Eric
Eric Nelson
