Re: [U-Boot] [PATCH v4 1/5] spi: cadence_spi: Sync DT bindings with Linux
Jason Rush wrote: Adopt the Linux DT bindings. This also fixes an issue with the indaddrtrig register on the Cadence QSPI device being programmed with the wrong value for the socfpga arch.
Changes for v4:
- Rebased
Reviewed-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com
Tested on a socfpga-cyclonev board: Tested-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com
Best regards, Simon
drivers/spi/cadence_qspi.c | 20 ++++++++++++-------- drivers/spi/cadence_qspi.h | 6 +++++- drivers/spi/cadence_qspi_apb.c | 15 ++++----------- 3 files changed, 21 insertions(+), 20 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 9a6e41f..991a716 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -212,7 +212,7 @@ static int cadence_spi_xfer(struct udevice *dev, unsigned int bitlen,
/* Set Chip select */ cadence_qspi_apb_chipselect(base, spi_chip_select(dev),
CONFIG_CQSPI_DECODER);
plat->is_decoded_cs);
if ((flags & SPI_XFER_END) || (flags == 0)) { if (priv->cmd_len == 0) {
@@ -296,7 +296,11 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus)
plat->regbase = (void *)data[0]; plat->ahbbase = (void *)data[2];
- plat->sram_size = fdtdec_get_int(blob, node, "sram-size", 128);
- plat->is_decoded_cs = fdtdec_get_bool(blob, node, "cdns,is-decoded-
cs");
plat->fifo_depth = fdtdec_get_uint(blob, node, "cdns,fifo-depth", 128);
plat->fifo_width = fdtdec_get_uint(blob, node, "cdns,fifo-width", 4);
plat->trigger_address = fdtdec_get_uint(blob, node,
"cdns,trigger-address", 0);
/* All other paramters are embedded in the child node */ subnode = fdt_first_subnode(blob, node);
@@ -310,12 +314,12 @@ static int cadence_spi_ofdata_to_platdata(struct udevice *bus) 500000);
/* Read other parameters from DT */
- plat->page_size = fdtdec_get_int(blob, subnode, "page-size", 256);
- plat->block_size = fdtdec_get_int(blob, subnode, "block-size", 16);
- plat->tshsl_ns = fdtdec_get_int(blob, subnode, "tshsl-ns", 200);
- plat->tsd2d_ns = fdtdec_get_int(blob, subnode, "tsd2d-ns", 255);
- plat->tchsh_ns = fdtdec_get_int(blob, subnode, "tchsh-ns", 20);
- plat->tslch_ns = fdtdec_get_int(blob, subnode, "tslch-ns", 20);
plat->page_size = fdtdec_get_uint(blob, subnode, "page-size", 256);
plat->block_size = fdtdec_get_uint(blob, subnode, "block-size", 16);
plat->tshsl_ns = fdtdec_get_uint(blob, subnode, "cdns,tshsl-ns", 200);
plat->tsd2d_ns = fdtdec_get_uint(blob, subnode, "cdns,tsd2d-ns", 255);
plat->tchsh_ns = fdtdec_get_uint(blob, subnode, "cdns,tchsh-ns", 20);
plat->tslch_ns = fdtdec_get_uint(blob, subnode, "cdns,tslch-ns", 20);
debug("%s: regbase=%p ahbbase=%p max-frequency=%d page-
size=%d\n", __func__, plat->regbase, plat->ahbbase, plat->max_hz, diff --git a/drivers/spi/cadence_qspi.h b/drivers/spi/cadence_qspi.h index d1927a4..8315421 100644 --- a/drivers/spi/cadence_qspi.h +++ b/drivers/spi/cadence_qspi.h @@ -18,14 +18,18 @@ struct cadence_spi_platdata { unsigned int max_hz; void *regbase; void *ahbbase;
bool is_decoded_cs;
u32 fifo_depth;
u32 fifo_width;
u32 trigger_address;
// Flash parameters u32 page_size; u32 block_size; u32 tshsl_ns; u32 tsd2d_ns; u32 tchsh_ns; u32 tslch_ns;
- u32 sram_size;
struct cadence_spi_priv { diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index e02f221..8309ab8 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -37,10 +37,6 @@ #define CQSPI_REG_RETRY 10000 #define CQSPI_POLL_IDLE_RETRY 3
-#define CQSPI_FIFO_WIDTH 4
-#define CQSPI_REG_SRAM_THRESHOLD_WORDS 50
/* Transfer mode */ #define CQSPI_INST_TYPE_SINGLE 0 #define CQSPI_INST_TYPE_DUAL 1 @@ -51,9 +47,6 @@ #define CQSPI_DUMMY_CLKS_PER_BYTE 8 #define CQSPI_DUMMY_BYTES_MAX 4
-#define CQSPI_REG_SRAM_FILL_THRESHOLD \
- ((CQSPI_REG_SRAM_SIZE_WORD / 2) * CQSPI_FIFO_WIDTH)
- Controller's configuration and status register (offset from QSPI_BASE)
****************************************************************************/ @@ -400,7 +393,7 @@ void cadence_qspi_apb_controller_init(struct cadence_spi_platdata *plat) writel(0, plat->regbase + CQSPI_REG_REMAP);
/* Indirect mode configurations */
- writel((plat->sram_size/2), plat->regbase + CQSPI_REG_SRAMPARTITION);
- writel((plat->fifo_depth/2), plat->regbase +
/* Disable all interrupts */ writel(0, plat->regbase + CQSPI_REG_IRQMASK); @@ -560,7 +553,7 @@ int cadence_qspi_apb_indirect_read_setup(struct cadence_spi_platdata *plat, addr_bytes = cmdlen - 1;
/* Setup the indirect trigger address */
- writel((u32)plat->ahbbase,
writel(plat->trigger_address, plat->regbase + CQSPI_REG_INDIRECTTRIGGER);
/* Configure the opcode */
@@ -659,7 +652,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, bytes_to_read = ret;
while (bytes_to_read != 0) {
bytes_to_read *= CQSPI_FIFO_WIDTH;
bytes_to_read *= plat->fifo_width; bytes_to_read = bytes_to_read > remaining ? remaining : bytes_to_read; readsl(plat->ahbbase, bb_rxbuf, bytes_to_read >> 2);
@@ -710,7 +703,7 @@ int cadence_qspi_apb_indirect_write_setup(struct cadence_spi_platdata *plat, return -EINVAL; } /* Setup the indirect trigger address */
-- 2.1.4
Goldschmidt Simon
