[U-Boot] Inconsistency between $filesize and commands which accept numeric params.
It seems there is some inconsistency wrt number base between commands which set $filesize in the env and the commands which might consume them.
e.g.
sun7i# load scsi 0 $fdt_addr_r dtbs/$fdtfile 21639 bytes read in 191 ms (110.4 KiB/s) sun7i# printenv filesize filesize=5487
So filesize is in hex, but without an 0x prefix. But:
sun7i# fdt addr $fdt_addr_r 0x10000 sun7i# fdt set /chosen foo <$filesize> sun7i# fdt print /chosen foo foo = <0x0000156f>
IOW the parameter to fdt set has been interpreted as a decimal.
If $filesize happens to contains digits [a-f] then:
sun7i# load scsi 0 $fdt_addr_r dtbs/sun6i-a31-app4-evb1.dtb 16563 bytes read in 478 ms (33.2 KiB/s) sun7i# printenv filesize filesize=40b3 sun7i# fdt set /chosen foo <$filesize> Sorry, I could not convert "b3>"
Obviously I can hack around this with: sun7i# fdt set /chosen foo <0x$filesize>
But that seems a bit of an odd thing to have to do (not to mention potentially fragile).
There seem to be other commands, e.g. mmc write which interpret their parameters as hex by default, although in that case it does also DTRT with an 0x prefix.
So I'm not sure if the bug is that setenv_hex doesn't include the 0x, or that fdt set interprets things as decimal by default instead of hex. Or maybe there is no bug at all?
Just changing the setenv_hex to include the 0x seemed at first glance like a good idea, but I'm not really sure.
Thanks, Ian.
PS my usecase is to implement the fdt based multiboot protocol which Xen uses in order to load boot-modules, see e.g. http://wiki.xen.org/wiki/Xen_ARM_with_Virtualization_Extensions/Allwinner#Bo... http://wiki.xen.org/wiki/Xen_ARM_with_Virtualization_Extensions/Multiboot (we use something like this on all u-boot based platforms, Allwinner is just an example).
Ian.
Dear Ian,
That would be bugs, then.
This is normal. U-Boot uses hex input base by default. All commands should take hex input; the only inglorious exception is the "sleep" command which takes decimal; numbers as arguments.
That's a bug.
No 0x prefix should be needed anywhere.
The bug is in fdt set, then.
Thanks for pointing out!
On Thu, 2014-10-30 at 16:21 +0100, Wolfgang Denk wrote:
Dear Ian,
That's a bug.
Thanks for pointing me in the right direction. CCing the folks who get_maintainers.pl tells me might be involved with common/cmd_fdt.c
Looks like the function which does this is fdt_parse_prop, which is documented with: /* * Parse the user's input, partially heuristic. Valid formats: * <0x00112233 4 05> - an array of cells. Numbers follow standard * C conventions. * [00 11 22 .. nn] - byte stream * "string" - If the the value doesn't start with "<" or "[", it is * treated as a string. Note that the quotes are * stripped by the parser before we get the string.
which is inconsistent with the "U-Boot uses hex input base by default" mantra.
Ian.
Dear Ian,
That's a bug.
- Parse the user's input, partially heuristic. Valid formats:
- <0x00112233 4 05> - an array of cells. Numbers follow standard
C conventions.
- [00 11 22 .. nn] - byte stream
- "string" - If the the value doesn't start with "<" or "[", it is
Because this is FDT centric and not U-Boot centric, yes? Since <decimal numbers> is a valid thing to do in an entry here. I think the right answer is the more hacky sounding one of when you script using 'fdt set' you need to be mindful of the constraints on input that are imposed upon us by FDT. <hex> is invalid but <0xhex> is what is expected.
Dear Ian,
That's a bug.
C conventions.
I guess?
The 0x prefix hack/trick is what I'm actually doing, but the maintainer of our test system wanted some assurances that u-boot wasn't going to change under our feet if someone fixed a bug.
Sounds like you are saying this is all working as designed, and there is no bug, but I'll let Wolfgang and you thrash that out ;-).
Ian.
Dear Ian,
C conventions.
I guess?
Well, we probably should not use this FDT centric decoding function directly on arguments passed from the U-Boot command line.
I think this is a hack that is bound to break. Today you use $filesize, tomorrow you may find you need to perform some operations on this (say, rounding up in some way), and you may end up with a variable that already contains a "0x" prefix, and your code will fail beause 0x0x... gets misinterpreted.
Tom: this is a bug ;-)
On Tue, Nov 04, 2014 at 09:53:02PM +0100, Wolfgang Denk wrote:
Dear Ian,
C conventions.
I guess?
No, look again at what we're doing. We're not calling a U-Boot function to do U-Boot things. We're calling a U-Boot function to set a DT property. U-Boot needs to obey DT conventions here.
I can see an argument that we could try and make the heuristics smarter to add '0x' to obvious hex strings, but that'll just cause crazier errors when 0x1000 is passed in and seen as 1000 decimal.
Dear Tom,
Well, we are running an U-Boot command. And U-Boot documentation says that we use hex inpout base (with the only unlucky exception of the sleep command). So this _command_ should also assume hex input.
Right. So before calling the fdt code, the U-Boot command should normalize the number.
Hm.... is there a way to determine in advance where we are passing a number as argument [see "common/cmd_fdt.c" lines 260ff] ?
On Tue, Nov 04, 2014 at 10:20:46PM +0100, Wolfgang Denk wrote:
Dear Tom,
... when we can make assumptions about the input, yes.
The problem is that 'fdt set ... <decimal>' is valid and 'fdt set ... <0xhex>' is valid (as it 'fdt set ... string'). What I'm saying is that we should think of it as 'fdt set <input to DT>' and within <input to DT> we assume DT conventions, not U-Boot conventions.
Dear Tom,
Yes, I fully understand what you mean. I just wonder if there is a user-friendly way to prevent such errors.
I think we should at least document this behaviour - both in the help message for this command, and in the manual.
On Tue, Nov 04, 2014 at 11:11:40PM +0100, Wolfgang Denk wrote:
Dear Tom,
I think this is a documentation (readme and command help) only thing.
Ian Campbell
