[U-Boot] [PATCH u-boot-arm/next v2 2/2] OMAP3: igep00x0: add SPL support for IGEP-based boards
This patch adds SPL support for IGEP-based boards.
Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory.
Signed-off-by: Javier Martinez Canillas javier@dowhile0.org ---
Changes since v1:
- Set NAND memory 200 Mhz timings when possible as suggested by Thomas Petazzoni
board/isee/igep0020/config.mk | 33 -------------------- board/isee/igep0020/igep0020.c | 42 +++++++++++++++++++++++++- board/isee/igep0030/config.mk | 33 -------------------- board/isee/igep0030/igep0030.c | 42 +++++++++++++++++++++++++- include/configs/igep00x0.h | 65 ++++++++++++++++++++++++++++++++++++++++ 5 files changed, 147 insertions(+), 68 deletions(-) delete mode 100644 board/isee/igep0020/config.mk delete mode 100644 board/isee/igep0030/config.mk
diff --git a/board/isee/igep0020/config.mk b/board/isee/igep0020/config.mk deleted file mode 100644 index 7964621..0000000 --- a/board/isee/igep0020/config.mk +++ /dev/null @@ -1,33 +0,0 @@ -# -# (C) Copyright 2009 -# ISEE 2007 SL, <www.iseebcn.com> -# -# IGEP0020 uses OMAP3 (ARM-CortexA8) cpu -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# Physical Address: -# 8000'0000 (bank0) -# A000/0000 (bank1) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -# For use with external or internal boots. -CONFIG_SYS_TEXT_BASE = 0x80008000 diff --git a/board/isee/igep0020/igep0020.c b/board/isee/igep0020/igep0020.c index 971e31b..a4d099a 100644 --- a/board/isee/igep0020/igep0020.c +++ b/board/isee/igep0020/igep0020.c @@ -58,6 +58,46 @@ int board_init(void) return 0; }
+#ifdef CONFIG_SPL_BUILD +/* + * Routine: omap_rev_string + * Description: For SPL builds output board rev + */ +void omap_rev_string(void) +{ +} + +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on both banks. + */ +void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, + u32 *mr) +{ + *mr = MICRON_V_MR_165; +#ifdef CONFIG_BOOT_NAND + *mcfg = MICRON_V_MCFG_200(512 << 20); + *ctrla = MICRON_V_ACTIMA_200; + *ctrlb = MICRON_V_ACTIMB_200; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; +#else + if (get_cpu_family() == CPU_OMAP34XX) { + *mcfg = NUMONYX_V_MCFG_165(512 << 20); + *ctrla = NUMONYX_V_ACTIMA_165; + *ctrlb = NUMONYX_V_ACTIMB_165; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + + } else { + *mcfg = NUMONYX_V_MCFG_200(512 << 20); + *ctrla = NUMONYX_V_ACTIMA_200; + *ctrlb = NUMONYX_V_ACTIMB_200; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + } +#endif +} +#endif + /* * Routine: setup_net_chip * Description: Setting up the configuration GPMC registers specific to the @@ -91,7 +131,7 @@ static void setup_net_chip(void) } #endif
-#ifdef CONFIG_GENERIC_MMC +#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) int board_mmc_init(bd_t *bis) { omap_mmc_init(0, 0, 0); diff --git a/board/isee/igep0030/config.mk b/board/isee/igep0030/config.mk deleted file mode 100644 index 059a878..0000000 --- a/board/isee/igep0030/config.mk +++ /dev/null @@ -1,33 +0,0 @@ -# -# (C) Copyright 2009 -# ISEE 2007 SL, <www.iseebcn.com> -# -# IGEP0030 uses OMAP3 (ARM-CortexA8) cpu -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# Physical Address: -# 8000'0000 (bank0) -# A000/0000 (bank1) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -# For use with external or internal boots. -CONFIG_SYS_TEXT_BASE = 0x80008000 diff --git a/board/isee/igep0030/igep0030.c b/board/isee/igep0030/igep0030.c index 653c1b5..4f8b645 100644 --- a/board/isee/igep0030/igep0030.c +++ b/board/isee/igep0030/igep0030.c @@ -45,7 +45,47 @@ int board_init(void) return 0; }
-#ifdef CONFIG_GENERIC_MMC +#ifdef CONFIG_SPL_BUILD +/* + * Routine: omap_rev_string + * Description: For SPL builds output board rev + */ +void omap_rev_string(void) +{ +} + +/* + * Routine: get_board_mem_timings + * Description: If we use SPL then there is no x-loader nor config header + * so we have to setup the DDR timings ourself on both banks. + */ +void get_board_mem_timings(u32 *mcfg, u32 *ctrla, u32 *ctrlb, u32 *rfr_ctrl, + u32 *mr) +{ + *mr = MICRON_V_MR_165; +#ifdef CONFIG_BOOT_NAND + *mcfg = MICRON_V_MCFG_200(512 << 20); + *ctrla = MICRON_V_ACTIMA_200; + *ctrlb = MICRON_V_ACTIMB_200; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; +#else + if (get_cpu_family() == CPU_OMAP34XX) { + *mcfg = NUMONYX_V_MCFG_165(512 << 20); + *ctrla = NUMONYX_V_ACTIMA_165; + *ctrlb = NUMONYX_V_ACTIMB_165; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_165MHz; + + } else { + *mcfg = NUMONYX_V_MCFG_200(512 << 20); + *ctrla = NUMONYX_V_ACTIMA_200; + *ctrlb = NUMONYX_V_ACTIMB_200; + *rfr_ctrl = SDP_3430_SDRC_RFR_CTRL_200MHz; + } +#endif +} +#endif + +#if defined(CONFIG_GENERIC_MMC) && !defined(CONFIG_SPL_BUILD) int board_mmc_init(bd_t *bis) { omap_mmc_init(0, 0, 0); diff --git a/include/configs/igep00x0.h b/include/configs/igep00x0.h index d8e87c3..91e5de6 100644 --- a/include/configs/igep00x0.h +++ b/include/configs/igep00x0.h @@ -287,6 +287,11 @@ #define CONFIG_SMC911X_BASE 0x2C000000 #endif /* (CONFIG_CMD_NET) */
+/* + * Leave it at 0x80008000 to allow booting new u-boot.bin with X-loader + * and older u-boot.bin with the new U-Boot SPL. + */ +#define CONFIG_SYS_TEXT_BASE 0x80008000 #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 #define CONFIG_SYS_INIT_RAM_ADDR 0x4020f800 #define CONFIG_SYS_INIT_RAM_SIZE 0x800 @@ -294,4 +299,64 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
+/* SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_TEXT_BASE 0x40200800 +#define CONFIG_SPL_MAX_SIZE (54 * 1024) +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +/* move malloc and bss high to prevent clashing with the main image */ +#define CONFIG_SYS_SPL_MALLOC_START 0x87000000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x80000 +#define CONFIG_SPL_BSS_START_ADDR 0x87080000 /* end of minimum RAM */ +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +/* MMC boot config */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT + +#define CONFIG_SPL_POWER_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +#ifdef CONFIG_BOOT_ONENAND +#define CONFIG_SPL_ONENAND_SUPPORT + +/* OneNAND boot config */ +#define CONFIG_SYS_ONENAND_U_BOOT_OFFS 0x80000 +#define CONFIG_SYS_ONENAND_PAGE_SIZE 2048 +#define CONFIG_SPL_ONENAND_LOAD_ADDR 0x80000 +#define CONFIG_SPL_ONENAND_LOAD_SIZE \ + (512 * 1024 - CONFIG_SPL_ONENAND_LOAD_ADDR) + +#endif + +#ifdef CONFIG_BOOT_NAND +#define CONFIG_SPL_NAND_SUPPORT + +/* NAND boot config */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT 64 +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ + 10, 11, 12, 13} +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 3 +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 +#endif + #endif /* __IGEP00X0_H */
2012/7/19 Javier Martinez Canillas javier@dowhile0.org:
Changes since v1:
- Routine: omap_rev_string
- Description: For SPL builds output board rev
- Routine: get_board_mem_timings
- Description: If we use SPL then there is no x-loader nor config header
- so we have to setup the DDR timings ourself on both banks.
u32 *mr)
+#else
} else {
+#endif +} +#endif
- Routine: setup_net_chip
- Description: Setting up the configuration GPMC registers specific to the
u32 *mr)
+#else
} else {
+#endif +} +#endif
- Leave it at 0x80008000 to allow booting new u-boot.bin with X-loader
- and older u-boot.bin with the new U-Boot SPL.
10, 11, 12, 13}
1.7.7.6
Hi Javier,
This is latest version ? This don't build because timings for Numonyx at 200MHz are not defined. Maybe I missed a patch ?
Cheers, Enric
On Thu, Jul 19, 2012 at 5:26 PM, Enric Balletbò i Serra eballetbo@gmail.com wrote:
Changes since v1:
u32 *mr)
+#else
} else {
+#endif +} +#endif
u32 *mr)
+#else
} else {
+#endif +} +#endif
10, 11, 12, 13}
1.7.7.6
Hi Javier,
Cheers, Enric
Hi Enric,
Sorry for being so careless!
I forgot to add that change to the patch. I'll send a v3 which has the Numonyx timings at 200Mhz
Best regards, Javier
