[PATCH v2 1/1] Kconfig: clean up skipping low-level initialization
Put all entries for skipping low-level initialization into a sub-menu. Use different titles for main U-Boot, SPL, TPL.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org --- v2: adjust the placement of the words SPL and TPL in the titles --- arch/Kconfig | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 102956d24c..112dcfe00f 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -381,9 +381,11 @@ config SYS_IMMR Address for the Internal Memory-Mapped Registers (IMMR) window used to configure the features of many Freescale / NXP SoCs.
-config SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" +menu "Skipping low level initialization functions" depends on ARM || MIPS || RISCV + +config SKIP_LOWLEVEL_INIT + bool "Skip calls to certain low level initialization functions" help If enabled, then certain low level initializations (like setting up the memory controller) are omitted and/or U-Boot does not relocate @@ -393,8 +395,8 @@ config SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config SPL_SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" - depends on SPL && (ARM || MIPS || RISCV) + bool "Skip calls to certain low level initialization functions in SPL" + depends on SPL help If enabled, then certain low level initializations (like setting up the memory controller) are omitted and/or U-Boot does not relocate @@ -404,7 +406,7 @@ config SPL_SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config TPL_SKIP_LOWLEVEL_INIT - bool "Skip the calls to certain low level initialization functions" + bool "Skip calls to certain low level initialization functions in TPL" depends on SPL && ARM help If enabled, then certain low level initializations (like setting up @@ -415,7 +417,7 @@ config TPL_SKIP_LOWLEVEL_INIT debugger which performs these initializations itself.
config SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool "Skip call to lowlevel_init during early boot ONLY" depends on ARM help This allows just the call to lowlevel_init() to be skipped. The @@ -423,7 +425,7 @@ config SKIP_LOWLEVEL_INIT_ONLY performed.
config SPL_SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool "Skip call to lowlevel_init during early SPL boot ONLY" depends on SPL && ARM help This allows just the call to lowlevel_init() to be skipped. The @@ -431,13 +433,15 @@ config SPL_SKIP_LOWLEVEL_INIT_ONLY performed.
config TPL_SKIP_LOWLEVEL_INIT_ONLY - bool "Skip the call to lowlevel_init during early boot ONLY" + bool "Skip call to lowlevel_init during early TPL boot ONLY" depends on TPL && ARM help This allows just the call to lowlevel_init() to be skipped. The normal CP15 init (such as enabling the instruction cache) is still performed.
+endmenu + config SYS_HAS_NONCACHED_MEMORY bool "Enable reserving a non-cached memory area for drivers" depends on (ARM || MIPS) && (RTL8169 || MEDIATEK_ETH)
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
