[PATCH 1/3] mtd: rawnand: denali-spl: Add missing hardware init
While the Denali NAND is initialized by the BootROM in SPL, there are still a couple of settings which are missing. These can trigger subtle corruption of the data read out of the NAND. Fill these settings in just like they are filled in by the full Denali NAND driver in denali_hw_init().
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_spl.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/mtd/nand/raw/denali_spl.c b/drivers/mtd/nand/raw/denali_spl.c index dbaba3cab2..b8b29812aa 100644 --- a/drivers/mtd/nand/raw/denali_spl.c +++ b/drivers/mtd/nand/raw/denali_spl.c @@ -173,6 +173,13 @@ void nand_init(void) page_size = readl(denali_flash_reg + DEVICE_MAIN_AREA_SIZE); oob_size = readl(denali_flash_reg + DEVICE_SPARE_AREA_SIZE); pages_per_block = readl(denali_flash_reg + PAGES_PER_BLOCK); + + /* Do as denali_hw_init() does. */ + writel(CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES, + denali_flash_reg + SPARE_AREA_SKIP_BYTES); + writel(0x0F, denali_flash_reg + RB_PIN_ENABLED); + writel(CHIP_EN_DONT_CARE__FLAG, denali_flash_reg + CHIP_ENABLE_DONT_CARE); + writel(0xffff, denali_flash_reg + SPARE_AREA_MARKER); }
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst)
The SoCFPGA Gen5 does not have a clock driver yet, let the NAND driver work without a clock driver by falling back to the default frequencies.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_dt.c | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/nand/raw/denali_dt.c b/drivers/mtd/nand/raw/denali_dt.c index 0ce81324b9..2c9e249ab6 100644 --- a/drivers/mtd/nand/raw/denali_dt.c +++ b/drivers/mtd/nand/raw/denali_dt.c @@ -62,7 +62,6 @@ static int denali_dt_probe(struct udevice *dev) { struct denali_nand_info *denali = dev_get_priv(dev); const struct denali_dt_data *data; - struct clk clk, clk_x, clk_ecc; struct resource res; int ret;
@@ -87,11 +86,14 @@ static int denali_dt_probe(struct udevice *dev)
denali->host = devm_ioremap(dev, res.start, resource_size(&res));
+#if CONFIG_IS_ENABLED(CLK) + struct clk clk, clk_x, clk_ecc; + ret = clk_get_by_name(dev, "nand", &clk); if (ret) ret = clk_get_by_index(dev, 0, &clk); if (ret) - return ret; + clk.dev = NULL;
ret = clk_get_by_name(dev, "nand_x", &clk_x); if (ret) @@ -117,10 +119,12 @@ static int denali_dt_probe(struct udevice *dev) return ret; }
- if (clk_x.dev) { + if (clk.dev && clk_x.dev) { denali->clk_rate = clk_get_rate(&clk); denali->clk_x_rate = clk_get_rate(&clk_x); - } else { + } else +#endif + { /* * Hardcode the clock rates for the backward compatibility. * This works for both SOCFPGA and UniPhier.
Why do you need this?
denali_dt_probe() succeeds without CONFIG_CLK, doesn't it?
return ret;
clk.dev = NULL; ret = clk_get_by_name(dev, "nand_x", &clk_x); if (ret)
if (clk_x.dev) {
} else {
} else
-- 2.24.1
No, if you don't have the NAND clock, this fails. This could be reverted once there is DM/DT capable clock driver for SoCFPGA Gen5, until then this is needed.
Oh, sorry, I read the code in a wrong way. But, this ifdef is ugly.
How about this alternative one? http://patchwork.ozlabs.org/patch/1220337/
-- Best Regards Masahiro Yamada
The clock code takes space for no reason in that patch, I prefer this one to keep the size in check.
Legacy kernel versions for SoCFPGA may not implement proper reset handling. Apply the same approach as SoCFPGA reset driver, check environment variable "socfpga_legacy_reset_compat", and if it is set, do not reset the IP before booting Linux. This way, even the older kernel versions can be booted by up to date U-Boot.
Signed-off-by: Marek Vasut marex@denx.de Cc: Masahiro Yamada yamada.masahiro@socionext.com --- drivers/mtd/nand/raw/denali_dt.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/mtd/nand/raw/denali_dt.c b/drivers/mtd/nand/raw/denali_dt.c index 2c9e249ab6..d35f2a3543 100644 --- a/drivers/mtd/nand/raw/denali_dt.c +++ b/drivers/mtd/nand/raw/denali_dt.c @@ -148,6 +148,18 @@ static int denali_dt_remove(struct udevice *dev) { struct denali_nand_info *denali = dev_get_priv(dev);
+#if CONFIG_IS_ENABLED(ARCH_SOCFPGA) + /* + * Legacy kernel versions do not implement proper reset handling on + * SoCFPGA. To let those older kernel versions work, reuse the same + * approach as the SoCFPGA reset driver does -- check environment + * variable socfpga_legacy_reset_compat and avoid resetting the IP + * before booting the kernel if it is set to 1. + */ + if (env_get_ulong("socfpga_legacy_reset_compat", 10, 0)) + return 0; +#endif + return reset_release_bulk(&denali->resets); }
Why don't you simply remove reset_release_bulk() ?
-- 2.24.1
Because once mainline has proper reset handling, this can be used only for legacy kernel versions.
I am suffering for the same problem for the uniphier platform.
The reset driver support for Linux will never be back-ported. So, it will continue to be a problem for Linux v4.19, v5.4, etc.
reset_release_bulk() should go away.
The Denali NAND patches for Linux are currently stuck on your review too.
Once the Linux patches are upstream, we can just reset the NAND controller without problems. And that's the right thing to do, sometimes you don't want NAND to be available in Linux, and then it should be kept in reset.
Huh?
Which patch in Linux is stuck on my review?
The NAND reset in Linux will be available in the future version (if my patch is applied).
The stable kernels are maintained in 6 years.
https://www.kernel.org/category/releases.html
The EOF of Linux 5.4 is set at 2021.12, but following the recent rules, it will be extended to 2026 or so.
Huh?
[PATCH V2] mtd: rawnand: denali_dt: Add support for configuring SPARE_AREA_SKIP_BYTES
Which patch ?
How is this relevant ?
So, for all legacy kernel versions, enable this backward compatibility thingie.
You need this because SOCFPGA SPL resets the nand controller, correct?
https://github.com/u-boot/u-boot/blob/v2020.01/arch/arm/mach-socfpga/spl_gen...
Yes. The driver should init the hardware correctly and fully, which it does not do without this patch.
Masahiro Yamada
