[U-Boot] Uboot bringing an RTOS instead of linux.
Hi All,
I am currently working on OMAP3530 fromMistral solutions. This is the booting sequence in OMAP3530
The OMAP3530 contains a boot ROM starting at location 0x00000000. When power on, the PC register jumps there. The boot ROM then looks at the sys_boot pins to determine boot order. For NAND booting,
the x-loader is located at offset 0 in NAND. Actually the first two words in NAND are the length of the x-loader and the address in internal RAM to load it. The boot ROM then reads the x-loader from NAND into
internal RAM and jumps to that. The x-loader configures the clocks and SDRAM and then reads u-boot from NAND into SDRAM. After u-boot is in SDRAM, the x-loader jumps to u-boot and u-boot starts to run. If
I don't press any key for 4 seconds uboot brings linux and linux shell comes up.
Instead of linux I need to bring my custom RTOS. As linux, custom RTOS will reside in NAND Flash too.
What is the procedure for bringing an OS from uboot.? As uboot bringing Linux , it needs to bring an RTOS too.
How do I write a script for that? How do I tell uboot to load My custom rtos instead of linux. I need to avoid the loading of linux and bring in my RTOS .
Any help on this is highly appreciated
Thanks
Rahanesh
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments contained in it.
On 20:26 Fri 03 Apr , rahanesh@tataelxsi.co.in wrote:
Hi All,
it will depend on your OS boot requierement but if you can boot it as a elf try bootelf
Best Regards, J.
Dear rahanesh@tataelxsi.co.in,
In message VSNLCHNFE001eleupIh00052ccf@VSNLCHNFE001.VSNLXCHANGE.COM you wrote:
The first step you are supposed to perform is reading the available documentation (README, Manual).
Jean-Christophe PLAGNIOL-VILLARD
