[PATCH v2] binman: doc: fix reference tag placement for Logging section
Move BinmanLogging reference tag after section "Signing FIT container with private key in an image" and just before section "Logging". Remove meaningless line with incomplete sentence.
Fixes: 0f40e23fd22 ("binman: add documentation for binman sign option") Signed-off-by: Massimo Pegorer massimo.pegorer+oss@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Changes in v2: - Removed incomplete sentence (confirmed by Simon)
tools/binman/binman.rst | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/tools/binman/binman.rst b/tools/binman/binman.rst index aeea33fddb..020988d955 100644 --- a/tools/binman/binman.rst +++ b/tools/binman/binman.rst @@ -1480,9 +1480,6 @@ as set in stone, so Binman will ensure it doesn't change. Without this feature, repacking an entry might cause it to disobey the original constraints provided when it was created.
- Repacking an image involves - -.. _`BinmanLogging`:
Signing FIT container with private key in an image -------------------------------------------------- @@ -1501,6 +1498,7 @@ If you want to sign and replace FIT container in place:: which will sign FIT container with private key and replace it immediately inside your image.
+.. _`BinmanLogging`:
Logging -------
On Wed, 13 Sept 2023 at 10:16, Massimo Pegorer massimo.pegorer+oss@gmail.com wrote:
Changes in v2:
Massimo Pegorer
