[U-Boot] [PATCH] cmd_fdt.c: Use %p when printing pointers
When putting pointers into a format string use %p to ensure that they are printed correctly regardless of bitsize. This fixes warnings on sandbox on 64bit systems.
Cc: Joe Hershberger joe.hershberger@ni.com Cc: Gerald Van Baren vanbaren@cideas.com Signed-off-by: Tom Rini trini@ti.com --- common/cmd_fdt.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_fdt.c b/common/cmd_fdt.c index a5e2cfc..f9acfc1 100644 --- a/common/cmd_fdt.c +++ b/common/cmd_fdt.c @@ -375,7 +375,7 @@ int do_fdt (cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) /* Get address */ char buf[11];
- sprintf(buf, "0x%08X", (uint32_t)nodep); + sprintf(buf, "0x%p", nodep); setenv(var, buf); } else if (subcmd[0] == 's') { /* Get size */ @@ -816,7 +816,7 @@ static void print_data(const void *data, int len)
if ((len %4) == 0) { if (len > CONFIG_CMD_FDT_MAX_DUMP) - printf("* 0x%08x [0x%08x]", (unsigned int)data, len); + printf("* 0x%p [0x%08x]", data, len); else { const u32 *p;
@@ -828,7 +828,7 @@ static void print_data(const void *data, int len) } } else { /* anything else... hexdump */ if (len > CONFIG_CMD_FDT_MAX_DUMP) - printf("* 0x%08x [0x%08x]", (unsigned int)data, len); + printf("* 0x%p [0x%08x]", data, len); else { const u8 *s;
Hi Tom,
Thanks! -Joe
Dear Tom Rini,
This may put bogus data ("var=0x(null)") into the environment.
I see two approaches to fix this:
1) Handle this locally, say like that:
char buf[11] = { '0', 0, };
if (nodep) sprintf(buf, "0x%p", nodep); setenv(var, buf);
This is the solution with minimal global impact.
2) Fix the root cause: given that we have valid situations where we may want to dereference a pointer pointing to address 0x0000, I wonder if it would not actually be better (i. e. more correct) to get rid of the
495 static char *pointer(const char *fmt, char *buf, char *end, void *ptr, 496 int field_width, int precision, int flags) 497 { 498 if (!ptr) 499 return string(buf, end, "(null)", field_width, precision, 500 flags);
special handling in "lib/vsprintf.c"
Would anybody shed any tears if we drop this?
Hi Wolfgang,
On Tue, Oct 30, 2012 at 4:59 AM, Wolfgang Denk wd@denx.de wrote:
Dear Tom Rini,
char buf[11] = { '0', 0, }; if (nodep) sprintf(buf, "0x%p", nodep); setenv(var, buf);
I think this solution is not needed. In this particular case, we are always printing the pointer to a member inside the fdt, so even if the image is at 0, no pointer that we are printing will ever be at 0. Therefore this is code that will never run and can be left out.
Getting rid of this would be good in general IMO. I never did understand why printing "(null)" was better than "0".
-Joe
Dear Joe,
In message CANr=Z=bxwwKkpUa_UzegN=E=TuqzeNUDTtZe7fDC+iCU9B6+3g@mail.gmail.com you wrote:
- Handle this locally, say like that:
If we would decide for this variant, such reasoning should be explained in a comment.
I guess for the same reasons we are forced^W encouraged to write NULL instead of 0 .
In the standard C library it certainly makes sense to note specifically if one tries to dereference a NULL pointer, because this is aways a bug.
The %p format of printf() would print a pointer to address null as "(null)". This makes sense in a real OS where a NULL pointer must never be dereferenced, but this is a bootloader, and there are cases where accessing the data at address null makes perfect sense.
Remove the special case in lib/vsprintf.c using "#if 0" with a comment to make clear this was an intentional change and to stop re-adding this code.
Signed-off-by: Wolfgang Denk wd@denx.de --- lib/vsprintf.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/lib/vsprintf.c b/lib/vsprintf.c index d762763..dd13bca 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -495,9 +495,15 @@ static char *ip4_addr_string(char *buf, char *end, u8 *addr, int field_width, static char *pointer(const char *fmt, char *buf, char *end, void *ptr, int field_width, int precision, int flags) { + /* + * Being a boot loader, we explicitly allow pointers to + * (physical) address null. + */ +#if 0 if (!ptr) return string(buf, end, "(null)", field_width, precision, flags); +#endif
#ifdef CONFIG_CMD_NET switch (*fmt) {
Hi Wolfgang,
On Tue, Oct 30, 2012 at 02:23:17PM -0500, Joe Hershberger wrote:
Hi Wolfgang,
Applied to u-boot/master.
Joe Hershberger
