[U-Boot] [PATCH v2] configs: rk3399: add gpt and fs support
To compatible with distro boot, we need to add gpt and fs support, including gpt table and vfat, ext2, ext4 support.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: - remove some re-defined MACRO, comments from Ziyuan Xu
include/configs/rk3399_common.h | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h index a9c9d29..6875308 100644 --- a/include/configs/rk3399_common.h +++ b/include/configs/rk3399_common.h @@ -35,7 +35,11 @@ #define CONFIG_BOUNCE_BUFFER #define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000
+#define CONFIG_SUPPORT_VFAT +#define CONFIG_FS_FAT #define CONFIG_FAT_WRITE +#define CONFIG_FS_EXT4 +#define CONFIG_CMD_PART
/* RAW SD card / eMMC locations. */ #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 256 @@ -60,6 +64,14 @@ "kernel_addr_r=0x02000000\0" \ "ramdisk_addr_r=0x04000000\0"
+#define CONFIG_CMD_GPT +#define CONFIG_RANDOM_UUID +#define CONFIG_PARTITION_UUIDS +#define PARTS_DEFAULT \ + "uuid_disk=${uuid_gpt_disk};" \ + "name=boot,start=16M,size=32M,bootable;" \ + "name=rootfs,size=-,uuid=${uuid_gpt_rootfs};\0" \ + /* First try to boot from SD (index 0), then eMMC (index 1) */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ @@ -67,6 +79,8 @@
#include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + "partitions=" PARTS_DEFAULT \ BOOTENV
#endif
Changes in v2:
Changes in v2:
Applied to u-boot-rockchip, thanks!
Kever Yang
