[PATCH 0/7] rtc: davinci: add driver model support
The series adds driver model support for omap RTC plus some fixes.
Dario Binacchi (7): rtc: davinci: enable compilation for omap architectures rtc: davinci: replace 32bit access with 8bit access rtc: davinci: check BUSY bit before set TC registers rtc: davinci: use unlock/lock mechanism arm: dts: sync rtc node of am335x boards with Linux 5.9-rc7 rtc: davinci: add driver model support rtc: davinci: fix date loaded on reset
arch/arm/dts/am335x-bone-common.dtsi | 5 + arch/arm/dts/am335x-evm.dts | 5 + arch/arm/dts/am335x-evmsk.dts | 5 + arch/arm/dts/am335x-osd335x-common.dtsi | 6 + drivers/rtc/Kconfig | 7 + drivers/rtc/davinci.c | 467 ++++++++++++++++++++++-- 6 files changed, 466 insertions(+), 29 deletions(-)
The Davinci's onchip RTC is also present on TI OMAP1, AM33XX, AM43XX and DRA7XX SOCs. So, let's enable compilation for these architectures too.
Signed-off-by: Dario Binacchi dariobin@libero.it ---
drivers/rtc/Kconfig | 7 +++++++ drivers/rtc/davinci.c | 11 ++++++++--- 2 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index c84a9d2b27..cbdfddb80f 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -188,4 +188,11 @@ config RTC_ABX80X families of ultra-low-power battery- and capacitor-backed real-time clock chips.
+config RTC_DAVINCI + bool "Enable TI OMAP RTC driver" + depends on ARCH_DAVINCI || ARCH_OMAP2PLUS + help + Say "yes" here to support the on chip real time clock + present on TI OMAP1, AM33xx, DA8xx/OMAP-L13x, AM43xx and DRA7xx. + endmenu diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index c446e7a735..8f5f76c9d6 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -9,11 +9,16 @@ #include <rtc.h> #include <asm/io.h> #include <asm/davinci_rtc.h> +#include <asm/arch/hardware.h> #include <linux/delay.h>
+#if !defined(RTC_BASE) && defined(DAVINCI_RTC_BASE) +#define RTC_BASE DAVINCI_RTC_BASE +#endif + int rtc_get(struct rtc_time *tmp) { - struct davinci_rtc *rtc = (struct davinci_rtc *)DAVINCI_RTC_BASE; + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; unsigned long sec, min, hour, mday, wday, mon_cent, year; unsigned long status;
@@ -57,7 +62,7 @@ int rtc_get(struct rtc_time *tmp)
int rtc_set(struct rtc_time *tmp) { - struct davinci_rtc *rtc = (struct davinci_rtc *)DAVINCI_RTC_BASE; + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, @@ -75,7 +80,7 @@ int rtc_set(struct rtc_time *tmp)
void rtc_reset(void) { - struct davinci_rtc *rtc = (struct davinci_rtc *)DAVINCI_RTC_BASE; + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
/* run RTC counter */ writel(0x01, &rtc->ctrl);
Hello! If it is available on AM33XX, do you know if it is also on OMAP3?
+config RTC_DAVINCI
- bool "Enable TI OMAP RTC driver"
- depends on ARCH_DAVINCI || ARCH_OMAP2PLUS
- help
- struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; unsigned long sec, min, hour, mday, wday, mon_cent, year; unsigned long status;
-- 2.17.1
Hi Pali,
I do not think so. I think am335x is omap2 and not omap3. In https://www.ti.com/lit/ug/spruf98y/spruf98y.pdf I don't see any reference to the RTC.
Thanks and regards, Dario
+config RTC_DAVINCI
- help
-- 2.17.1
+config RTC_DAVINCI
I assume you are converting to a Kconfig symbol? Can you keep this as a separate patch and use tools/moveconfig.py?
Thanks and regards, Lokesh
Hi Lokesh,
+config RTC_DAVINCI
The CONFIG_RTC_DAVINCI symbol was only in the Makefile. I ran moveconfig.py and in fact it didn't find it in any configuration header. I'll add the Kconfig symbol in a separate patch.
Thanks and regards Dario Binacchi
Use 32-bit access only where it is needed. Most of the RTC registers contain useful information in the 8 least significant bits, the others are reserved.
drivers/rtc/davinci.c | 32 ++++++++++++++++---------------- 1 file changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index 8f5f76c9d6..99ae31e2a5 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -22,7 +22,7 @@ int rtc_get(struct rtc_time *tmp) unsigned long sec, min, hour, mday, wday, mon_cent, year; unsigned long status;
- status = readl(&rtc->status); + status = readb(&rtc->status); if ((status & RTC_STATE_RUN) != RTC_STATE_RUN) { printf("RTC doesn't run\n"); return -1; @@ -30,13 +30,13 @@ int rtc_get(struct rtc_time *tmp) if ((status & RTC_STATE_BUSY) == RTC_STATE_BUSY) udelay(20);
- sec = readl(&rtc->second); - min = readl(&rtc->minutes); - hour = readl(&rtc->hours); - mday = readl(&rtc->day); - wday = readl(&rtc->dotw); - mon_cent = readl(&rtc->month); - year = readl(&rtc->year); + sec = readb(&rtc->second); + min = readb(&rtc->minutes); + hour = readb(&rtc->hours); + mday = readb(&rtc->day); + wday = readb(&rtc->dotw); + mon_cent = readb(&rtc->month); + year = readb(&rtc->year);
debug("Get RTC year: %02lx mon/cent: %02lx mday: %02lx wday: %02lx " "hr: %02lx min: %02lx sec: %02lx\n", @@ -67,14 +67,14 @@ int rtc_set(struct rtc_time *tmp) debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, tmp->tm_hour, tmp->tm_min, tmp->tm_sec); - writel(bin2bcd(tmp->tm_year % 100), &rtc->year); - writel(bin2bcd(tmp->tm_mon), &rtc->month); + writeb(bin2bcd(tmp->tm_year % 100), &rtc->year); + writeb(bin2bcd(tmp->tm_mon), &rtc->month);
- writel(bin2bcd(tmp->tm_wday), &rtc->dotw); - writel(bin2bcd(tmp->tm_mday), &rtc->day); - writel(bin2bcd(tmp->tm_hour), &rtc->hours); - writel(bin2bcd(tmp->tm_min), &rtc->minutes); - writel(bin2bcd(tmp->tm_sec), &rtc->second); + writeb(bin2bcd(tmp->tm_wday), &rtc->dotw); + writeb(bin2bcd(tmp->tm_mday), &rtc->day); + writeb(bin2bcd(tmp->tm_hour), &rtc->hours); + writeb(bin2bcd(tmp->tm_min), &rtc->minutes); + writeb(bin2bcd(tmp->tm_sec), &rtc->second); return 0; }
@@ -83,5 +83,5 @@ void rtc_reset(void) struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
/* run RTC counter */ - writel(0x01, &rtc->ctrl); + writeb(0x01, &rtc->ctrl); }
To write correct data to the TC registers, the STATUS register must be read until the BUSY bit is equal to zero. Once the BUSY flag is zero, there is a 15 μs access period in which the TC registers can be programmed. The rtc_wait_not_busy() has been inspired by the Kernel.
drivers/rtc/davinci.c | 45 ++++++++++++++++++++++++++++++++++--------- 1 file changed, 36 insertions(+), 9 deletions(-)
diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index 99ae31e2a5..7b8c729f3b 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -16,19 +16,39 @@ #define RTC_BASE DAVINCI_RTC_BASE #endif
-int rtc_get(struct rtc_time *tmp) +static int davinci_rtc_wait_not_busy(struct davinci_rtc *rtc) { - struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; - unsigned long sec, min, hour, mday, wday, mon_cent, year; - unsigned long status; + int count; + u8 status;
status = readb(&rtc->status); if ((status & RTC_STATE_RUN) != RTC_STATE_RUN) { printf("RTC doesn't run\n"); return -1; } - if ((status & RTC_STATE_BUSY) == RTC_STATE_BUSY) - udelay(20); + + /* BUSY may stay active for 1/32768 second (~30 usec) */ + for (count = 0; count < 50; count++) { + if (!(status & RTC_STATE_BUSY)) + break; + + udelay(1); + status = readb(&rtc->status); + } + + /* now we have ~15 usec to read/write various registers */ + return 0; +} + +int rtc_get(struct rtc_time *tmp) +{ + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + unsigned long sec, min, hour, mday, wday, mon_cent, year; + int ret; + + ret = davinci_rtc_wait_not_busy(rtc); + if (ret) + return ret;
sec = readb(&rtc->second); min = readb(&rtc->minutes); @@ -63,10 +83,12 @@ int rtc_get(struct rtc_time *tmp) int rtc_set(struct rtc_time *tmp) { struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + int ret; + + ret = davinci_rtc_wait_not_busy(rtc); + if (ret) + return ret;
- debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", - tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, - tmp->tm_hour, tmp->tm_min, tmp->tm_sec); writeb(bin2bcd(tmp->tm_year % 100), &rtc->year); writeb(bin2bcd(tmp->tm_mon), &rtc->month);
@@ -75,6 +97,11 @@ int rtc_set(struct rtc_time *tmp) writeb(bin2bcd(tmp->tm_hour), &rtc->hours); writeb(bin2bcd(tmp->tm_min), &rtc->minutes); writeb(bin2bcd(tmp->tm_sec), &rtc->second); + + debug("Set DATE: %4d-%02d-%02d (wday=%d) TIME: %2d:%02d:%02d\n", + tmp->tm_year, tmp->tm_mon, tmp->tm_mday, tmp->tm_wday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + return 0; }
The RTC module contains a kicker mechanism to prevent any spurious writes from changing the register values. To set the time, you must first unlock the TC registers, update them and then lock.
drivers/rtc/davinci.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index 7b8c729f3b..82e5eb3b43 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -16,6 +16,18 @@ #define RTC_BASE DAVINCI_RTC_BASE #endif
+static void davinci_rtc_lock(struct davinci_rtc *rtc) +{ + writel(0, &rtc->kick0r); + writel(0, &rtc->kick1r); +} + +static void davinci_rtc_unlock(struct davinci_rtc *rtc) +{ + writel(RTC_KICK0R_WE, &rtc->kick0r); + writel(RTC_KICK1R_WE, &rtc->kick1r); +} + static int davinci_rtc_wait_not_busy(struct davinci_rtc *rtc) { int count; @@ -89,6 +101,7 @@ int rtc_set(struct rtc_time *tmp) if (ret) return ret;
+ davinci_rtc_unlock(rtc); writeb(bin2bcd(tmp->tm_year % 100), &rtc->year); writeb(bin2bcd(tmp->tm_mon), &rtc->month);
@@ -97,6 +110,7 @@ int rtc_set(struct rtc_time *tmp) writeb(bin2bcd(tmp->tm_hour), &rtc->hours); writeb(bin2bcd(tmp->tm_min), &rtc->minutes); writeb(bin2bcd(tmp->tm_sec), &rtc->second); + davinci_rtc_lock(rtc);
There have been some changes to the am335x-<board> DTs related to the rtc node, so let's re-syncs them with Linux.
arch/arm/dts/am335x-bone-common.dtsi | 5 +++++ arch/arm/dts/am335x-evm.dts | 5 +++++ arch/arm/dts/am335x-evmsk.dts | 5 +++++ arch/arm/dts/am335x-osd335x-common.dtsi | 6 ++++++ 4 files changed, 21 insertions(+)
diff --git a/arch/arm/dts/am335x-bone-common.dtsi b/arch/arm/dts/am335x-bone-common.dtsi index 5b8230e281..8dcfac3a5b 100644 --- a/arch/arm/dts/am335x-bone-common.dtsi +++ b/arch/arm/dts/am335x-bone-common.dtsi @@ -398,3 +398,8 @@ &sham { status = "okay"; }; + +&rtc { + clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; + clock-names = "ext-clk", "int-clk"; +}; diff --git a/arch/arm/dts/am335x-evm.dts b/arch/arm/dts/am335x-evm.dts index c4bd1855f2..136f685bc5 100644 --- a/arch/arm/dts/am335x-evm.dts +++ b/arch/arm/dts/am335x-evm.dts @@ -783,3 +783,8 @@ pinctrl-names = "default"; pinctrl-0 = <&dcan1_pins_default>; }; + +&rtc { + clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; + clock-names = "ext-clk", "int-clk"; +}; diff --git a/arch/arm/dts/am335x-evmsk.dts b/arch/arm/dts/am335x-evmsk.dts index c94c33b595..b14bf2ff1b 100644 --- a/arch/arm/dts/am335x-evmsk.dts +++ b/arch/arm/dts/am335x-evmsk.dts @@ -724,3 +724,8 @@ &lcdc { status = "okay"; }; + +&rtc { + clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; + clock-names = "ext-clk", "int-clk"; +}; diff --git a/arch/arm/dts/am335x-osd335x-common.dtsi b/arch/arm/dts/am335x-osd335x-common.dtsi index f8ff473f94..2b55b7d0f9 100644 --- a/arch/arm/dts/am335x-osd335x-common.dtsi +++ b/arch/arm/dts/am335x-osd335x-common.dtsi @@ -122,3 +122,9 @@ &sham { status = "okay"; }; + +&rtc { + clocks = <&clk_32768_ck>, <&clk_24mhz_clkctrl AM3_CLK_24MHZ_CLKDIV32K_CLKCTRL 0>; + clock-names = "ext-clk", "int-clk"; + system-power-controller; +};
Update the driver to support the device tree and the driver model. The read / write helpers in rtc_ops allow access to scratch registers only. The offset parameter is added to the address of the scratch0 register.
drivers/rtc/davinci.c | 373 ++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 363 insertions(+), 10 deletions(-)
diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index 82e5eb3b43..b0a077cba7 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -2,20 +2,20 @@ /* * (C) Copyright 2011 DENX Software Engineering GmbH * Heiko Schocher hs@denx.de + * Copyright (C) 2021 Dario Binacchi dariobin@libero.it */ #include <common.h> #include <command.h> +#include <dm.h> +#include <clk.h> #include <log.h> #include <rtc.h> #include <asm/io.h> #include <asm/davinci_rtc.h> #include <asm/arch/hardware.h> +#include <dm/device_compat.h> #include <linux/delay.h>
-#if !defined(RTC_BASE) && defined(DAVINCI_RTC_BASE) -#define RTC_BASE DAVINCI_RTC_BASE -#endif - static void davinci_rtc_lock(struct davinci_rtc *rtc) { writel(0, &rtc->kick0r); @@ -52,9 +52,8 @@ static int davinci_rtc_wait_not_busy(struct davinci_rtc *rtc) return 0; }
-int rtc_get(struct rtc_time *tmp) +static int davinci_rtc_get(struct davinci_rtc *rtc, struct rtc_time *tmp) { - struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; unsigned long sec, min, hour, mday, wday, mon_cent, year; int ret;
@@ -92,9 +91,8 @@ int rtc_get(struct rtc_time *tmp) return 0; }
-int rtc_set(struct rtc_time *tmp) +static int davinci_rtc_set(struct davinci_rtc *rtc, const struct rtc_time *tmp) { - struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; int ret;
ret = davinci_rtc_wait_not_busy(rtc); @@ -119,10 +117,365 @@ int rtc_set(struct rtc_time *tmp) return 0; }
+static void davinci_rtc_reset(struct davinci_rtc *rtc) +{ + /* run RTC counter */ + writeb(0x01, &rtc->ctrl); +} + +#if !CONFIG_IS_ENABLED(DM_RTC) + +#if !defined(RTC_BASE) && defined(DAVINCI_RTC_BASE) +#define RTC_BASE DAVINCI_RTC_BASE +#endif + +int rtc_get(struct rtc_time *tmp) +{ + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + + return davinci_rtc_get(rtc, tmp); +} + +int rtc_set(struct rtc_time *tmp) +{ + struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE; + + return davinci_rtc_set(rtc, tmp); +} + void rtc_reset(void) { struct davinci_rtc *rtc = (struct davinci_rtc *)RTC_BASE;
- /* run RTC counter */ - writeb(0x01, &rtc->ctrl); + davinci_rtc_reset(rtc); +} + +#else /* CONFIG_DM_RTC */ + +#define OMAP_RTC_CTRL_REG 0x40 +#define OMAP_RTC_STATUS_REG 0x44 +#define OMAP_RTC_INTERRUPTS_REG 0x48 + +#define OMAP_RTC_OSC_REG 0x54 + +#define OMAP_RTC_SCRATCH0_REG 0x60 +#define OMAP_RTC_SCRATCH1_REG 0x64 +#define OMAP_RTC_SCRATCH2_REG 0x68 + +#define OMAP_RTC_KICK0_REG 0x6c +#define OMAP_RTC_KICK1_REG 0x70 + +#define OMAP_RTC_PMIC_REG 0x98 + +/* OMAP_RTC_CTRL_REG bit fields: */ +#define OMAP_RTC_CTRL_SPLIT BIT(7) +#define OMAP_RTC_CTRL_DISABLE BIT(6) +#define OMAP_RTC_CTRL_SET_32_COUNTER BIT(5) +#define OMAP_RTC_CTRL_TEST BIT(4) +#define OMAP_RTC_CTRL_MODE_12_24 BIT(3) +#define OMAP_RTC_CTRL_AUTO_COMP BIT(2) +#define OMAP_RTC_CTRL_ROUND_30S BIT(1) +#define OMAP_RTC_CTRL_STOP BIT(0) + +/* OMAP_RTC_STATUS_REG bit fields */ +#define OMAP_RTC_STATUS_POWER_UP BIT(7) +#define OMAP_RTC_STATUS_ALARM2 BIT(7) +#define OMAP_RTC_STATUS_ALARM BIT(6) +#define OMAP_RTC_STATUS_1D_EVENT BIT(5) +#define OMAP_RTC_STATUS_1H_EVENT BIT(4) +#define OMAP_RTC_STATUS_1M_EVENT BIT(3) +#define OMAP_RTC_STATUS_1S_EVENT BIT(2) +#define OMAP_RTC_STATUS_RUN BIT(1) +#define OMAP_RTC_STATUS_BUSY BIT(0) + +/* OMAP_RTC_OSC_REG bit fields */ +#define OMAP_RTC_OSC_32KCLK_EN BIT(6) +#define OMAP_RTC_OSC_SEL_32KCLK_SRC BIT(3) +#define OMAP_RTC_OSC_OSC32K_GZ_DISABLE BIT(4) + +struct omap_rtc_device_type { + bool has_32kclk_en; + bool has_irqwakeen; + bool has_pmic_mode; + bool has_power_up_reset; +}; + +struct omap_rtc_priv { + fdt_addr_t base; + u8 max_reg; + struct udevice *dev; + struct clk clk; + bool has_ext_clk; + const struct omap_rtc_device_type *type; +}; + +static inline u8 omap_rtc_readb(struct omap_rtc_priv *priv, unsigned int reg) +{ + return readb(priv->base + reg); +} + +static inline u32 omap_rtc_readl(struct omap_rtc_priv *priv, unsigned int reg) +{ + return readl(priv->base + reg); +} + +static inline void omap_rtc_writeb(struct omap_rtc_priv *priv, unsigned int reg, + u8 val) +{ + writeb(val, priv->base + reg); +} + +static inline void omap_rtc_writel(struct omap_rtc_priv *priv, unsigned int reg, + u32 val) +{ + writel(val, priv->base + reg); +} + +static inline void omap_rtc_unlock(struct omap_rtc_priv *priv) +{ + davinci_rtc_unlock((struct davinci_rtc *)priv->base); +} + +static inline void omap_rtc_lock(struct omap_rtc_priv *priv) +{ + davinci_rtc_lock((struct davinci_rtc *)priv->base); +} + +static int omap_rtc_reset(struct udevice *dev) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + + davinci_rtc_reset((struct davinci_rtc *)priv->base); + return 0; +} + +static int omap_rtc_set(struct udevice *dev, const struct rtc_time *tm) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + + return davinci_rtc_set((struct davinci_rtc *)priv->base, tm); } + +static int omap_rtc_get(struct udevice *dev, struct rtc_time *tm) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + + return davinci_rtc_get((struct davinci_rtc *)priv->base, tm); +} + +static int omap_rtc_scratch_read(struct udevice *dev, uint offset, + u8 *buffer, uint len) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + u32 *val = (u32 *)buffer; + unsigned int reg; + int i; + + if (len & 3) + return -EFAULT; + + for (i = 0; i < len / 4; i++) { + reg = OMAP_RTC_SCRATCH0_REG + offset + (i * 4); + if (reg >= OMAP_RTC_KICK0_REG) + return -EFAULT; + + val[i] = omap_rtc_readl(priv, reg); + } + + return 0; +} + +static int omap_rtc_scratch_write(struct udevice *dev, uint offset, + const u8 *buffer, uint len) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + u32 *val = (u32 *)buffer; + unsigned int reg; + int i; + + if (len & 3) + return -EFAULT; + + omap_rtc_unlock(priv); + for (i = 0; i < len / 4; i++) { + reg = OMAP_RTC_SCRATCH0_REG + offset + (i * 4); + if (reg >= OMAP_RTC_KICK0_REG) + return -EFAULT; + + omap_rtc_writel(priv, reg, val[i]); + } + omap_rtc_lock(priv); + + return 0; +} + +static int omap_rtc_remove(struct udevice *dev) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + u8 reg; + + if (priv->clk.dev) + clk_disable(&priv->clk); + + omap_rtc_unlock(priv); + + /* leave rtc running, but disable irqs */ + omap_rtc_writeb(priv, OMAP_RTC_INTERRUPTS_REG, 0); + + if (priv->has_ext_clk) { + reg = omap_rtc_readb(priv, OMAP_RTC_OSC_REG); + reg &= ~OMAP_RTC_OSC_SEL_32KCLK_SRC; + omap_rtc_writeb(priv, OMAP_RTC_OSC_REG, reg); + } + + omap_rtc_lock(priv); + return 0; +} + +static int omap_rtc_probe(struct udevice *dev) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + u8 reg, mask, new_ctrl; + + priv->dev = dev; + priv->type = (struct omap_rtc_device_type *)dev_get_driver_data(dev); + priv->max_reg = OMAP_RTC_PMIC_REG; + + if (!clk_get_by_name(dev, "ext-clk", &priv->clk)) + priv->has_ext_clk = true; + else + clk_get_by_name(dev, "int-clk", &priv->clk); + + if (priv->clk.dev) + clk_enable(&priv->clk); + else + dev_warn(dev, "missing clock\n"); + + omap_rtc_unlock(priv); + + /* + * disable interrupts + * + * NOTE: ALARM2 is not cleared on AM3352 if rtc_write (writeb) is used + */ + omap_rtc_writel(priv, OMAP_RTC_INTERRUPTS_REG, 0); + + if (priv->type->has_32kclk_en) { + reg = omap_rtc_readb(priv, OMAP_RTC_OSC_REG); + omap_rtc_writeb(priv, OMAP_RTC_OSC_REG, + reg | OMAP_RTC_OSC_32KCLK_EN); + } + + /* clear old status */ + reg = omap_rtc_readb(priv, OMAP_RTC_STATUS_REG); + + mask = OMAP_RTC_STATUS_ALARM; + + if (priv->type->has_pmic_mode) + mask |= OMAP_RTC_STATUS_ALARM2; + + if (priv->type->has_power_up_reset) { + mask |= OMAP_RTC_STATUS_POWER_UP; + if (reg & OMAP_RTC_STATUS_POWER_UP) + dev_info(dev, "RTC power up reset detected\n"); + } + + if (reg & mask) + omap_rtc_writeb(priv, OMAP_RTC_STATUS_REG, reg & mask); + + /* On boards with split power, RTC_ON_NOFF won't reset the RTC */ + reg = omap_rtc_readb(priv, OMAP_RTC_CTRL_REG); + if (reg & OMAP_RTC_CTRL_STOP) + dev_info(dev, "already running\n"); + + /* force to 24 hour mode */ + new_ctrl = reg & (OMAP_RTC_CTRL_SPLIT | OMAP_RTC_CTRL_AUTO_COMP); + new_ctrl |= OMAP_RTC_CTRL_STOP; + + /* + * BOARD-SPECIFIC CUSTOMIZATION CAN GO HERE: + * + * - Device wake-up capability setting should come through chip + * init logic. OMAP1 boards should initialize the "wakeup capable" + * flag in the platform device if the board is wired right for + * being woken up by RTC alarm. For OMAP-L138, this capability + * is built into the SoC by the "Deep Sleep" capability. + * + * - Boards wired so RTC_ON_nOFF is used as the reset signal, + * rather than nPWRON_RESET, should forcibly enable split + * power mode. (Some chip errata report that RTC_CTRL_SPLIT + * is write-only, and always reads as zero...) + */ + + if (new_ctrl & OMAP_RTC_CTRL_SPLIT) + dev_info(dev, "split power mode\n"); + + if (reg != new_ctrl) + omap_rtc_writeb(priv, OMAP_RTC_CTRL_REG, new_ctrl); + + /* + * If we have the external clock then switch to it so we can keep + * ticking across suspend. + */ + if (priv->has_ext_clk) { + reg = omap_rtc_readb(priv, OMAP_RTC_OSC_REG); + reg &= ~OMAP_RTC_OSC_OSC32K_GZ_DISABLE; + reg |= OMAP_RTC_OSC_32KCLK_EN | OMAP_RTC_OSC_SEL_32KCLK_SRC; + omap_rtc_writeb(priv, OMAP_RTC_OSC_REG, reg); + } + + omap_rtc_lock(priv); + return 0; +} + +static int omap_rtc_of_to_plat(struct udevice *dev) +{ + struct omap_rtc_priv *priv = dev_get_priv(dev); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) { + dev_err(dev, "invalid address\n"); + return -EINVAL; + } + + dev_dbg(dev, "base=%pa\n", &priv->base); + return 0; +} + +static const struct rtc_ops omap_rtc_ops = { + .get = omap_rtc_get, + .set = omap_rtc_set, + .reset = omap_rtc_reset, + .read = omap_rtc_scratch_read, + .write = omap_rtc_scratch_write, +}; + +static const struct omap_rtc_device_type omap_rtc_am3352_type = { + .has_32kclk_en = true, + .has_irqwakeen = true, + .has_pmic_mode = true, +}; + +static const struct omap_rtc_device_type omap_rtc_da830_type = { + .has_32kclk_en = false, + .has_irqwakeen = false, + .has_pmic_mode = false, +}; + +static const struct udevice_id omap_rtc_ids[] = { + {.compatible = "ti,am3352-rtc", .data = (ulong)&omap_rtc_am3352_type}, + {.compatible = "ti,da830-rtc", .data = (ulong)&omap_rtc_da830_type } +}; + +U_BOOT_DRIVER(omap_rtc) = { + .name = "omap_rtc", + .id = UCLASS_RTC, + .of_match = omap_rtc_ids, + .ops = &omap_rtc_ops, + .of_to_plat = omap_rtc_of_to_plat, + .probe = omap_rtc_probe, + .remove = omap_rtc_remove, + .priv_auto = sizeof(struct omap_rtc_priv), +}; + +#endif /* CONFIG_DM_RTC */
- (C) Copyright 2011 DENX Software Engineering GmbH
- Heiko Schocher hs@denx.de
- Copyright (C) 2021 Dario Binacchi dariobin@libero.it
can we use use consistent naming? omap_rtc_<function>?
Are there any users of non-DM? If not can we just drop the support for non-DM?
On reset, the RTC loads the 2000-01-01 date with a wrong day of the week (Sunday instead of Saturday).
drivers/rtc/davinci.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/rtc/davinci.c b/drivers/rtc/davinci.c index b0a077cba7..88fd56b1ba 100644 --- a/drivers/rtc/davinci.c +++ b/drivers/rtc/davinci.c @@ -335,6 +335,7 @@ static int omap_rtc_remove(struct udevice *dev) static int omap_rtc_probe(struct udevice *dev) { struct omap_rtc_priv *priv = dev_get_priv(dev); + struct rtc_time tm; u8 reg, mask, new_ctrl;
priv->dev = dev; @@ -425,6 +426,15 @@ static int omap_rtc_probe(struct udevice *dev) }
omap_rtc_lock(priv); + + if (omap_rtc_get(dev, &tm)) { + dev_err(dev, "failed to get datetime\n"); + } else if (tm.tm_year == 2000 && tm.tm_mon == 1 && tm.tm_mday == 1 && + tm.tm_wday == 0) { + tm.tm_wday = 6; + omap_rtc_set(dev, &tm); + } + return 0; }
Dario Binacchi
Lokesh Vutla
Pali Rohár
