[U-Boot] [PATCH v2] spl_mmc: allow to load raw image
The function spl_parse_image_header() falls back to a raw image if the U-Boot header is missing and CONFIG_SPL_PANIC_ON_RAW_IMAGE is undefined. While, mmc_load_image_raw_sector() only accepts a U-Boot legacy image or an FIT image, preventing us from loading a raw image.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
Changes in v2: - rebase on commit 41bccb814285 and rephrase git-log according to it
common/spl/spl_mmc.c | 18 ++++-------------- 1 file changed, 4 insertions(+), 14 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index c0e76be..7d3bfc6 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -41,7 +41,6 @@ static int mmc_load_legacy(struct mmc *mmc, ulong sector, return 0; }
-#ifdef CONFIG_SPL_LOAD_FIT static ulong h_spl_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) { @@ -49,7 +48,6 @@ static ulong h_spl_load_read(struct spl_load_info *load, ulong sector,
return mmc->block_dev.block_read(&mmc->block_dev, sector, count, buf); } -#endif
static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) { @@ -68,12 +66,8 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) goto end; }
- switch (image_get_magic(header)) { - case IH_MAGIC: - ret = mmc_load_legacy(mmc, sector, header); - break; -#ifdef CONFIG_SPL_LOAD_FIT - case FDT_MAGIC: { + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && + image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load;
debug("Found FIT\n"); @@ -82,12 +76,8 @@ static int mmc_load_image_raw_sector(struct mmc *mmc, unsigned long sector) load.bl_len = mmc->read_bl_len; load.read = h_spl_load_read; ret = spl_load_simple_fit(&load, sector, header); - break; - } -#endif - default: - puts("bad magic\n"); - return -1; + } else { + ret = mmc_load_legacy(mmc, sector, header); }
end:
2016-03-16 12:10 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
On Tue, Mar 15, 2016 at 10:10 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
I know it's been pushed to the trunk already, but I think we have an issue with at least one OMAP3 board.
Changes in v2:
} -#endif
case IH_MAGIC:
break;
case FDT_MAGIC: {
image_get_magic(header) == FDT_MAGIC) { struct spl_load_info load; debug("Found FIT\n");
break;
-#endif
default:
return -1;
} else {
The following line makes my omap3 board hang.
However if we use "return -1" the board loads u-boot.img properly on the omap3logic board.
end:
1.9.1
Adam Ford
Masahiro Yamada
