[PATCH v1] doc: board: imx8qm-rom7720-a1.rst: convert readme to reST
Convert README to reStructuredText format.
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com --- board/advantech/imx8qm_rom7720_a1/README | 61 ------------------ doc/board/advantech/imx8qm-rom7720-a1.rst | 75 +++++++++++++++++++++++ doc/board/advantech/index.rst | 9 +++ 3 files changed, 84 insertions(+), 61 deletions(-) delete mode 100644 board/advantech/imx8qm_rom7720_a1/README create mode 100644 doc/board/advantech/imx8qm-rom7720-a1.rst create mode 100644 doc/board/advantech/index.rst
diff --git a/board/advantech/imx8qm_rom7720_a1/README b/board/advantech/imx8qm_rom7720_a1/README deleted file mode 100644 index 585fde440d..0000000000 --- a/board/advantech/imx8qm_rom7720_a1/README +++ /dev/null @@ -1,61 +0,0 @@ -U-Boot for the NXP i.MX8QM ROM 7720a1 board - -Quick Start -=========== - -- Build the ARM Trusted firmware binary -- Get scfw_tcm.bin and ahab-container.img -- Get imx-mkimage -- Build U-Boot -- Build imx-mkimage -- Flash the binary into the SD card -- Boot - -Get and Build the ARM Trusted firmware -====================================== - -$ git clone https://source.codeaurora.org/external/imx/imx-atf -$ cd imx-atf/ -$ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga -$ make PLAT=imx8qm bl31 - -Get scfw_tcm.bin and ahab-container.img -============================== - -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-sc-firmware-1.1.bin -$ chmod +x imx-sc-firmware-1.1.bin -$ ./imx-sc-firmware-1.1.bin -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin -$ chmod +x firmware-imx-8.0.bin -$ ./firmware-imx-8.0.bin - -Or use this to avoid running random scripts from the internet, -but note that you must agree to the license the script displays: - -$ dd if=imx-sc-firmware-1.1.bin of=imx-sc-firmware-1.1.tar.bz2 bs=37185 skip=1 -$ tar -xf imx-sc-firmware-1.1.tar.bz2 -$ cp imx-sc-firmware-1.1/mx8qm-val-scfw-tcm.bin $(builddir) - -$ dd if=firmware-imx-8.0.bin of=firmware-imx-8.0.tar.bz2 bs=37180 skip=1 -$ tar -xf firmware-imx-8.0.tar.bz2 -$ cp firmware-imx-8.0/firmware/seco/mx8qm-ahab-container.img $(builddir) - -Build U-Boot -============ - -$ export ATF_LOAD_ADDR=0x80000000 -$ export BL33_LOAD_ADDR=0x80020000 -$ make imx8qm_rom7720_a1_4G_defconfig -$ make u-boot.bin -$ make flash.bin - -Flash the binary into the SD card -================================= - -Burn the flash.bin binary to SD card offset 32KB: - -$ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync - -Boot -==== -Set Boot switch SW2: 1100. diff --git a/doc/board/advantech/imx8qm-rom7720-a1.rst b/doc/board/advantech/imx8qm-rom7720-a1.rst new file mode 100644 index 0000000000..bd4be1dbeb --- /dev/null +++ b/doc/board/advantech/imx8qm-rom7720-a1.rst @@ -0,0 +1,75 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +U-Boot for the NXP i.MX8QM ROM 7720a1 board +=========================================== + +Quick Start +----------- + +- Build the ARM Trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Get imx-mkimage +- Build U-Boot +- Build imx-mkimage +- Flash the binary into the SD card +- Boot + +Get and Build the ARM Trusted firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone https://source.codeaurora.org/external/imx/imx-atf + $ cd imx-atf/ + $ git checkout origin/imx_4.14.78_1.0.0_ga -b imx_4.14.78_1.0.0_ga + $ make PLAT=imx8qm bl31 + +Get scfw_tcm.bin and ahab-container.img +--------------------------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-sc-firmware-1.1.bin + $ chmod +x imx-sc-firmware-1.1.bin + $ ./imx-sc-firmware-1.1.bin + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin + $ chmod +x firmware-imx-8.0.bin + $ ./firmware-imx-8.0.bin + +Or use this to avoid running random scripts from the internet, +but note that you must agree to the license the script displays: + +.. code-block:: bash + + $ dd if=imx-sc-firmware-1.1.bin of=imx-sc-firmware-1.1.tar.bz2 bs=37185 skip=1 + $ tar -xf imx-sc-firmware-1.1.tar.bz2 + $ cp imx-sc-firmware-1.1/mx8qm-val-scfw-tcm.bin $(builddir) + + $ dd if=firmware-imx-8.0.bin of=firmware-imx-8.0.tar.bz2 bs=37180 skip=1 + $ tar -xf firmware-imx-8.0.tar.bz2 + $ cp firmware-imx-8.0/firmware/seco/mx8qm-ahab-container.img $(builddir) + +Build U-Boot +------------ + +.. code-block:: bash + + $ export ATF_LOAD_ADDR=0x80000000 + $ export BL33_LOAD_ADDR=0x80020000 + $ make imx8qm_rom7720_a1_4G_defconfig + $ make u-boot.bin + $ make flash.bin + +Flash the binary into the SD card +--------------------------------- + +Burn the flash.bin binary to SD card offset 32KB: + +.. code-block:: bash + + $ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync + +Boot +---- + +Set Boot switch SW2: 1100. diff --git a/doc/board/advantech/index.rst b/doc/board/advantech/index.rst new file mode 100644 index 0000000000..e9b198c5c3 --- /dev/null +++ b/doc/board/advantech/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Advantech +========= + +.. toctree:: + :maxdepth: 2 + + imx8qm-rom7720-a1.rst
Hi Oliver,
The entry in doc/board/index.rst is missing, I add it myself while merging.
diff --git a/doc/board/index.rst b/doc/board/index.rst index 4b6a996eb1..915f1be8a5 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -7,6 +7,7 @@ Board-specific doc :maxdepth: 2
actions/index + advantech/index AndesTech/index amlogic/index atmel/index
Best regards, Stefano
-Quick Start
-Build U-Boot
-Boot
$ cd imx-atf/
$ make u-boot.bin
$ make flash.bin
- $ sudo dd if=flash.bin of=/dev/sd[x] bs=1k seek=32 conv=fsync
+Boot +----
+.. toctree::
- :maxdepth: 2
- imx8qm-rom7720-a1.rst
Convert README to reStructuredText format. Signed-off-by: Oliver Graute oliver.graute@kococonnector.com
Best regards, Stefano Babic
Oliver Graute
sbabic@denx.de
Stefano Babic
