[U-Boot] [PATCH v1 0/2] Add support for new SoC APM82XXX
APM8XXXX is Applied Micro Circuits Corporations naming convention for new line of SoCs.
V1: * Squash some of the patches. * add space between "||" and "". * Add spaces around operators. * Unsigned int to u32. * Add empty line which was removed. * remove warning "unused variable" in cpu_init.c * Remove "All rights reserved" phrase from headers. * Add empty line which was removed. * Move EBC definititions to bluestone_config.h file * Remove reconfigure_EBC() function. * Remove unused CONFIG_SDRAM16BIT_OFFSET. * Remove unused CONFIG_SDRAM_INFO_EEPROM_ADDR. * Add empty lines in bluestone.c file. * Replacing AC_R | AC_W | AC_X with AC_RWX. * Remove changes to main Makefile * Remove NAND references from config file. * Squash some of the patches. * Remove top Makefile change.
Tirumala Marri (2): Add CPU and other peripheral support APM82xxx: Add bluestone board support
MAINTAINERS | 3 + MAKEALL | 1 + arch/powerpc/cpu/ppc4xx/cpu.c | 35 ++++++- arch/powerpc/cpu/ppc4xx/cpu_init.c | 8 +- arch/powerpc/cpu/ppc4xx/speed.c | 85 +++++++++++++++- arch/powerpc/cpu/ppc4xx/start.S | 10 ++- arch/powerpc/include/asm/ppc4xx-ebc.h | 4 + arch/powerpc/include/asm/ppc4xx-isram.h | 8 +- arch/powerpc/include/asm/ppc4xx-sdram.h | 25 ++++- arch/powerpc/include/asm/ppc4xx-uic.h | 5 +- arch/powerpc/include/asm/processor.h | 1 + board/amcc/bluestone/Makefile | 52 +++++++++ board/amcc/bluestone/bluestone.c | 162 ++++++++++++++++++++++++++++ board/amcc/bluestone/config.mk | 40 +++++++ board/amcc/bluestone/init.S | 55 ++++++++++ boards.cfg | 1 + include/configs/bluestone.h | 175 +++++++++++++++++++++++++++++++ include/ppc440.h | 57 ++++++++++- include/ppc4xx.h | 7 +- 19 files changed, 709 insertions(+), 25 deletions(-) create mode 100644 board/amcc/bluestone/Makefile create mode 100644 board/amcc/bluestone/bluestone.c create mode 100644 board/amcc/bluestone/config.mk create mode 100644 board/amcc/bluestone/init.S create mode 100644 include/configs/bluestone.h
tmarriļ¼ apm.com
