[U-Boot] [PATCH] sunxi: rename Bananapi M3 dts file name
The upstream (Linux) device tree file for the Bananapi M3 follows the convention of using the well known brand name, instead of the vendor name, for naming. The file was recently added to upstream in commit 359b5a1e1c2d ("ARM: sun8i: a83t: Add device tree for Sinovoip Bananapi BPI-M3")
Rename the device tree file in U-boot to match.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/dts/Makefile | 4 ++-- .../{sun8i-a83t-sinovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} | 0 configs/Sinovoip_BPI_M3_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-) rename arch/arm/dts/{sun8i-a83t-sinovoip-bpi-m3.dts => sun8i-a83t-bananapi-m3.dts} (100%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 762429c463d1..b7550104c340 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -307,8 +307,8 @@ dtb-$(CONFIG_MACH_SUN8I_A33) += \ sun8i-r16-parrot.dtb dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ - sun8i-a83t-cubietruck-plus.dtb \ - sun8i-a83t-sinovoip-bpi-m3.dtb + sun8i-a83t-bananapi-m3.dtb \ + sun8i-a83t-cubietruck-plus.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h2-plus-orangepi-zero.dtb \ sun8i-h3-bananapi-m2-plus.dtb \ diff --git a/arch/arm/dts/sun8i-a83t-sinovoip-bpi-m3.dts b/arch/arm/dts/sun8i-a83t-bananapi-m3.dts similarity index 100% rename from arch/arm/dts/sun8i-a83t-sinovoip-bpi-m3.dts rename to arch/arm/dts/sun8i-a83t-bananapi-m3.dts diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index c53ade0c9715..b4602d41e3df 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -13,7 +13,7 @@ CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y CONFIG_SATAPWR="PD25" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-bananapi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y CONFIG_SPL=y
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Thanks! Maxime
On Thu, Aug 31, 2017 at 7:35 PM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
Reviewed-by: Jagan Teki jagan@openedev.com
thanks!
Chen-Yu Tsai
Jagan Teki
Maxime Ripard
