[U-Boot-Users] RE: -allow_branch_to_undefined on mipsel-linux-as > 2.15
Subject: [U-Boot-Users] -allow_branch_to_undefined on mipsel-linux-as 2.15
I'd like to know if someone are using mipsel-linux-as version greater than 2.15 to compile u-boot. This version of binutils seems not compatible with mipsel-linux-gcc 3.4.3 or newer.
Option "-allow_branch_to_undefined" is still needed on binutils newer than 2.15?
Hello, Rodolfo.
I have been using mipsel-linux-uclibc-gcc 3.4.2 with binutils 2.15.91.0.2, and I have no -allow_branch_to_undefined in this toolchain. I patched cpu/mips/start.S to set up the GOT gp earlier, and used jal instructions to get to memsetup and the other subroutines called there.
I also had to do a runtime calculation of the GOT offset. I don't have a clean patch right now.
I also have a driver for the SMSC LAN911x ethernet interface to contribute.
Tim Braun, Sr. Des. Eng. LibreStream Technologies 200-55 Rothwell Rd. Winnipeg R3P 2M5
I suppose you mean the attached patch... the problem is that even if using that patch I still get:
mipsel-linux-gcc -Wa,-gstabs -D__ASSEMBLY__ -g -Os -D__KERNEL__ -DTEXT_BASE=0xbfc00000 -I/home/giometti/Projects/exadron/wwpc/uboot-mips-exadron/include -fno-builtin -ffreestanding -nostdinc -isystem /usr/local/mipsel/lib/gcc/mipsel-linux/3.4.3/include -pipe -DCONFIG_MIPS -D__MIPS__ -march=4kc -mtune=4kc -mabicalls -c -o cpu/mips/start.o /home/giometti/Projects/exadron/wwpc/uboot-mips-exadron/cpu/mips/start.S /home/giometti/Projects/exadron/wwpc/uboot-mips-exadron/cpu/mips/start.S: Assembler messages: /home/giometti/Projects/exadron/wwpc/uboot-mips-exadron/cpu/mips/start.S:241: Error: can't resolve `_GLOBAL_OFFSET_TABLE_' {*UND* section} - `L11' {.text section} make: *** [cpu/mips/start.o] Error 1
Ciao,
Rodolfo
Rodolfo Giometti
Tim Braun
