[U-Boot] [PATCH] fpga: Fix Spartan III FPGA booting
This patch does some minor fixing of the Xilinx Spartan III FPGA boot code:
- Fixed call order of post configuration callback and success message printing (result of copy-paste?) - remove obsolete comment - minor coding style cleanup
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- drivers/fpga/spartan3.c | 22 +++++++--------------- 1 files changed, 7 insertions(+), 15 deletions(-)
diff --git a/drivers/fpga/spartan3.c b/drivers/fpga/spartan3.c index 9ce41f1..8bb2449 100644 --- a/drivers/fpga/spartan3.c +++ b/drivers/fpga/spartan3.c @@ -281,23 +281,18 @@ static int Spartan3_sp_load (Xilinx_desc * desc, void *buf, size_t bsize) } }
- if (ret_val == FPGA_SUCCESS) { -#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK - puts ("Done.\n"); -#endif - } /* * Run the post configuration function if there is one. */ - if (*fn->post) { + if (*fn->post) (*fn->post) (cookie); - }
- else { #ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK + if (ret_val == FPGA_SUCCESS) + puts ("Done.\n"); + else puts ("Fail.\n"); #endif - }
} else { printf ("%s: NULL Interface function table!\n", __FUNCTION__); @@ -567,17 +562,14 @@ static int Spartan3_ss_load (Xilinx_desc * desc, void *buf, size_t bsize) /* * Run the post configuration function if there is one. */ - if (*fn->post) { + if (*fn->post) (*fn->post) (cookie); - }
#ifdef CONFIG_SYS_FPGA_PROG_FEEDBACK - if (ret_val == FPGA_SUCCESS) { + if (ret_val == FPGA_SUCCESS) puts ("Done.\n"); - } - else { + else puts ("Fail.\n"); - } #endif
} else {
Dear Matthias Fuchs,
Applied, thanks.
Matthias Fuchs
