[U-Boot] SPL boot with NAND on i.MX6 data abort
Hi all,
I'm currently working on the port of u-boot for our custom boards. Previously we were using u-boot based on v2013.04 without SPL for our boards (we have boards with SD also) and this worked for all of our devices.
As we now have new boards with different (bigger) RAM, I decided to use the newest bootloader (v2015.10) and enable SPL support. This is already working on a board with SD-Card but I'm not getting it to work on the boards with NAND.
When I try to boot, SPL is detecting and loading u-boot but u-boot throws a "data abort" during "ubifs mount". The strange thing for me is that when I disable SPL, the board will boot properly.
Could anyone give me a hint how I could trace this error? I can also provide logs or code snippets if needed!
Best Regards
Markus
Hi Markus,
On 23/09/2015 10:02, Markus Stelzhammer wrote:
Hi all,
u-boot ist also in NAND ? Then SPL has configured correctly the device else u-boot was not loaded.
You can try to follow the data abort and check which addresses are involved. We cannot underestimate that the bug is still present in u-boot, but it appears only together with SPL.
Some initialization done previously in u-boot, is done now by SPL - check your code if there is something missing.
As your board is not mainlined, we cannot help a much with code.
Best regards, Stefano Babic
Hi Stefano,
Today I grabbed a different Hardware with a bigger NAND chip (512 instead of 256MB). At this hardware, SPL is not able to jump to U-Boot. So currently I assume that I might have some problems when flashing.
Would you be so kind to review my header file if I miss something or if there is something completely wrong?! (I attached it) The commands I use to flash are the following:
./kobs-ng init -v -x SPL nandwrite --start=0x11000 --pad /dev/mtd0 u-boot.uim (I also
tried to flash u-boot.bin and u-boot.imx)
The output I get at boot are the following, but then it stucks. .......
spl:board_init_r()
using memory 0x18300000-0x1b500000 for malloc() spl_init() boot device - 4 spl: nand - using hw ecc NAND : 0x01:0xdc erasesize=1 (>>0) writesize=-1 (>>0) oobsize=65535 chipsize=1095216660225 Not support the NAND chips whose oob size is larger then 1024 bytes! 1044479 MiB nand_spl_load_image offset:0x00011000 len:64 page:69632 mkimage signature not found - ih_magic = 0 nand_spl_load_image offset:0x00011000 len:409600 page:69632 Jumping to U-Boot loaded - jumping to U-Boot...image entry point: 0x17800000
On 09/24/2015 11:25 AM, Stefano Babic wrote:
Hi Markus,
Hi all,
Best regards, Markus
Hello Markus,
Am 24.09.2015 um 17:03 schrieb Markus Stelzhammer:
Hi Stefano,
./kobs-ng init -v -x SPL nandwrite --start=0x11000 --pad /dev/mtd0 u-boot.uim (I also tried to flash u-boot.bin
and u-boot.imx)
spl:board_init_r()
From here the values seems bogus to me ... erasesize 1 ?
writesize=-1 (>>0)
negative writesize?
Such a big chip?
Wow ...
I think you have problems with detecting the NAND, maybe wrong bus timings?
bye, Heiko
Hi Markus,
Hi all,
Hi Markus,
On 24/09/2015 17:03, Markus Stelzhammer wrote:
Hi Stefano,
If you are not flashing correctly, SPL does not run. It looks like that your board boots (SPL runs).
(I also tried to flash u-boot.bin and u-boot.imx)
spl:board_init_r()
erasesize = 1 ??
This larger NAND cannot be recognized correctly - it is not a problem by flashing.
You have to investigate why this NAND (even if ONFI) is not recognized, but it is a different problem as the one you reported previously.
Heiko Schocher
Markus Stelzhammer
Stefano Babic
