[U-Boot] [PATCH v2 08/13] drivers: mmc: add driver for Microchip PIC32 SDHCI controller.
PIC32 architecture has in-built SDHCI controller. This driver implements platform specific glue to use common SDHCI functionality.
Signed-off-by: Andrei Pistirica andrei.pistirica@microchip.com Signed-off-by: Sandeep Sheriker Mallikarjun sandeepsheriker.mallikarjun@microchip.com Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com
Changes in v2: - drop SDHCI shared bus configuration (for shared interrupt-and-clock pins)
drivers/mmc/Kconfig | 6 +++++ drivers/mmc/Makefile | 2 +- drivers/mmc/pic32_sdhci.c | 63 +++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/sdhci.c | 12 +++++++++ 4 files changed, 82 insertions(+), 1 deletion(-) create mode 100644 drivers/mmc/pic32_sdhci.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index ceae7bc..0b6f54b 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -31,4 +31,10 @@ config SH_SDHI help Support for the on-chip SDHI host controller on SuperH/Renesas ARM SoCs platform
+config PIC32_SDHCI + bool "Microchip PIC32 on-chip SDHCI support" + depends on DM_MMC && MACH_PIC32 + help + Support for the on-chip SDHCI support on Microchip PIC32 platforms. + endmenu diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 5d35705..c9c3e3e 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -48,4 +48,4 @@ obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else obj-$(CONFIG_GENERIC_MMC) += mmc_write.o endif - +obj-$(CONFIG_PIC32_SDHCI) += pic32_sdhci.o diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c new file mode 100644 index 0000000..9eb603e --- /dev/null +++ b/drivers/mmc/pic32_sdhci.c @@ -0,0 +1,63 @@ +/* + * Support of SDHCI for Microchip PIC32 SoC. + * + * Copyright (C) 2015 Microchip Technology Inc. + * Andrei Pistirica andrei.pistirica@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm.h> +#include <common.h> +#include <sdhci.h> +#include <asm/errno.h> +#include <mach/pic32.h> + +DECLARE_GLOBAL_DATA_PTR; + +static int pic32_sdhci_probe(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + u32 f_min_max[2]; + int ret; + + ret = fdtdec_get_int_array(gd->fdt_blob, dev->of_offset, + "clock-freq-min-max", f_min_max, 2); + if (ret) { + printf("sdhci: clock-freq-min-max not found\n"); + return ret; + } + + return add_sdhci(host, f_min_max[1], f_min_max[0]); +} + +static int pic32_sdhci_ofdata_to_platdata(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + fdt_addr_t addr; + + addr = dev_get_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + host->name = (char *)dev->name; + host->ioaddr = pic32_ioremap(addr); + host->quirks = SDHCI_QUIRK_NO_HISPD_BIT; + host->bus_width = fdtdec_get_int(gd->fdt_blob, dev->of_offset, + "bus-width", 4); + return 0; +} + +static const struct udevice_id pic32_sdhci_ids[] = { + { .compatible = "microchip,pic32mzda-sdhci" }, + { } +}; + +U_BOOT_DRIVER(pic32_sdhci_drv) = { + .name = "pic32_sdhci", + .id = UCLASS_MMC, + .of_match = pic32_sdhci_ids, + .probe = pic32_sdhci_probe, + .ofdata_to_platdata = pic32_sdhci_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct sdhci_host), +}; diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 02d71b9..f32fe67 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -424,6 +424,18 @@ static void sdhci_set_ios(struct mmc *mmc) if (host->quirks & SDHCI_QUIRK_NO_HISPD_BIT) ctrl &= ~SDHCI_CTRL_HISPD;
+#if defined(CONFIG_PIC32_SDHCI) + /* + * In PIC32MZ[DA] due to h/w bug SDHCI fails detecting card when JTAG + * is not connected. + * To work-around this problem: + * - set Card_Detect_Signal_Selection bit in SDHCI_Host_Control register + * - clear Card_Detect_Test_Level bit in SDHCI_Host_Control register + */ + ctrl |= SDHCI_CTRL_CD_TEST; + ctrl &= ~SDHCI_CTRL_CD_TEST_INS; +#endif + sdhci_writeb(host, ctrl, SDHCI_HOST_CONTROL); }
2016-01-04 15:01 GMT+01:00 Purna Chandra Mandal purna.mandal@microchip.com:
Changes in v2:
+config PIC32_SDHCI
help
- Support of SDHCI for Microchip PIC32 SoC.
- Copyright (C) 2015 Microchip Technology Inc.
- Andrei Pistirica andrei.pistirica@microchip.com
u32 f_min_max[2];
int ret;
if (ret) {
return ret;
fdt_addr_t addr;
return -EINVAL;
"bus-width", 4);
all that code could be moved to pic32_sdhci_probe()
.id = UCLASS_MMC,
* is not connected.
-- 1.8.3.1
Changes in v2:
+config PIC32_SDHCI
help
u32 f_min_max[2];
int ret;
if (ret) {
return ret;
fdt_addr_t addr;
return -EINVAL;
"bus-width", 4);
ack.
.id = UCLASS_MMC,
* is not connected.
-- 1.8.3.1
Daniel Schwierzeck
