Re: [U-Boot] [PATCH 2/3] ARM: board: cm_fx6: fixup mtd partitions in the fdt
Hi Igor,
On 06/22/2016 06:02 PM, Igor Grinberg wrote:
Hi Christopher,
On 06/19/2016 06:44 PM, Christopher Spinrath wrote:
The cm-fx6 module has an on-board st,m25p compatible spi flash chip used for u-boot (binary & environment). Overwrite the partitions in the device tree by the partition table provided in the mtdparts environment variable, if it is set.
This allows to specify a kernel independent partitioning in the environment and provides a convient way for the user to adapt the partition table.
Signed-off-by: Christopher Spinrath christopher.spinrath@rwth-aachen.de
board/compulab/cm_fx6/cm_fx6.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index 712057a..81a7ae2 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -12,6 +12,7 @@ #include <dm.h> #include <fsl_esdhc.h> #include <miiphy.h> +#include <mtd_node.h> #include <netdev.h> #include <errno.h> #include <usb.h> @@ -28,6 +29,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <dm/platform_data/serial_mxc.h> +#include <jffs2/load_kernel.h>
Why is this needed?
The MTD_DEV_TYPE_NOR constant is defined in this header. I agree that it is a bit ugly but this header is used for the same purpose in other board files, too (e.g.board/pdm360ng/pdm360ng.c).
#include "common.h" #include "../common/eeprom.h" #include "../common/common.h" @@ -581,6 +583,13 @@ int cm_fx6_setup_ecspi(void) { return 0; }
#ifdef CONFIG_OF_BOARD_SETUP #define USDHC3_PATH "/soc/aips-bus@02100000/usdhc@02198000/"
+#ifdef CONFIG_FDT_FIXUP_PARTITIONS +struct node_info nodes[] = {
- { "st,m25p", MTD_DEV_TYPE_NOR, },
+}; +#endif
int ft_board_setup(void *blob, bd_t *bd) { u32 baseboard_rev; @@ -589,6 +598,8 @@ int ft_board_setup(void *blob, bd_t *bd) char baseboard_name[16]; int err;
- fdt_shrink_to_minimum(blob); /* Make room for new properties */
- /* MAC addr */ if (eth_getenv_enetaddr("ethaddr", enetaddr)) { fdt_find_and_setprop(blob,
@@ -607,7 +618,6 @@ int ft_board_setup(void *blob, bd_t *bd) return 0; /* Assume not an early revision SB-FX6m baseboard */
if (!strncmp("SB-FX6m", baseboard_name, 7) && baseboard_rev <= 120) {
nodeoffset = fdt_path_offset(blob, USDHC3_PATH); fdt_delprop(blob, nodeoffset, "cd-gpios"); fdt_find_and_setprop(blob, USDHC3_PATH, "broken-cd",fdt_shrink_to_minimum(blob); /* Make room for new properties */
@@ -616,6 +626,10 @@ int ft_board_setup(void *blob, bd_t *bd) NULL, 0, 1); }
- fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));
I really dislike the ifdeffery inside functions. Care to introduce a stub for the !CONFIG_FDT_FIXUP_PARTITIONS case in include/fdt_support.h for this one?
Sure. Is the header the correct place for this or should I add a #else case in the .c file?
Cheers, Christopher
} #endif
Hi Christopher,
On 06/22/2016 10:21 PM, Christopher Spinrath wrote:
Hi Igor,
Hi Christopher,
Why is this needed?
I see. I don't feel right to request this in scope of these patches, but if you can take care of that one (even in a follow up patch) - it would be awesome.
IMO, the header file is better for stubbing things out. It does not require you to add .c into compilation. There are also already several examples inside this header.
Igor Grinberg
