[U-Boot] [PATCH 1/4 v2] dm: core: Add flags parameter to device_remove()
This patch adds the flags parameter to device_remove() and changes all calls to this function to provide the default value of DM_REMOVE_NORMAL for "normal" device removal.
This is in preparation for the driver specific pre-OS (e.g. DMA cancelling) remove support.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- v2: - Changes DM_FLAG macro as suggested by Simon - Minor comment change as suggested by Simon
arch/x86/cpu/queensbay/tnc.c | 4 ++-- cmd/cros_ec.c | 2 +- cmd/sf.c | 2 +- drivers/block/blk-uclass.c | 2 +- drivers/block/sandbox.c | 2 +- drivers/core/device-remove.c | 9 +++++---- drivers/core/device.c | 2 +- drivers/core/root.c | 2 +- drivers/core/uclass.c | 2 +- drivers/mmc/mmc-uclass.c | 2 +- drivers/mtd/spi/sandbox.c | 2 +- drivers/mtd/spi/sf-uclass.c | 2 +- drivers/spi/spi-uclass.c | 4 ++-- drivers/usb/emul/sandbox_hub.c | 2 +- drivers/usb/host/usb-uclass.c | 4 ++-- include/dm/device-internal.h | 5 +++-- include/dm/device.h | 26 ++++++++++++++++++++++++++ test/dm/bus.c | 8 ++++---- test/dm/core.c | 16 ++++++++-------- test/dm/eth.c | 2 +- test/dm/spi.c | 2 +- 21 files changed, 65 insertions(+), 37 deletions(-)
diff --git a/arch/x86/cpu/queensbay/tnc.c b/arch/x86/cpu/queensbay/tnc.c index f307c622c8..94668a4fda 100644 --- a/arch/x86/cpu/queensbay/tnc.c +++ b/arch/x86/cpu/queensbay/tnc.c @@ -76,13 +76,13 @@ static int __maybe_unused disable_igd(void) * * So the only option we have is to manually remove these two devices. */ - ret = device_remove(igd); + ret = device_remove(igd, DM_REMOVE_NORMAL); if (ret) return ret; ret = device_unbind(igd); if (ret) return ret; - ret = device_remove(sdvo); + ret = device_remove(sdvo, DM_REMOVE_NORMAL); if (ret) return ret; ret = device_unbind(sdvo); diff --git a/cmd/cros_ec.c b/cmd/cros_ec.c index 9d42f870dc..af0b4eee78 100644 --- a/cmd/cros_ec.c +++ b/cmd/cros_ec.c @@ -110,7 +110,7 @@ static int do_cros_ec(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) /* Remove any existing device */ ret = uclass_find_device(UCLASS_CROS_EC, 0, &udev); if (!ret) - device_remove(udev); + device_remove(udev, DM_REMOVE_NORMAL); ret = uclass_get_device(UCLASS_CROS_EC, 0, &udev); if (ret) { printf("Could not init cros_ec device (err %d)\n", ret); diff --git a/cmd/sf.c b/cmd/sf.c index 65b117feee..f971eec781 100644 --- a/cmd/sf.c +++ b/cmd/sf.c @@ -124,7 +124,7 @@ static int do_spi_flash_probe(int argc, char * const argv[]) /* Remove the old device, otherwise probe will just be a nop */ ret = spi_find_bus_and_cs(bus, cs, &bus_dev, &new); if (!ret) { - device_remove(new); + device_remove(new, DM_REMOVE_NORMAL); } flash = NULL; ret = spi_flash_probe_bus_cs(bus, cs, speed, mode, &new); diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 38cb9388da..af3c35f6d0 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -530,7 +530,7 @@ int blk_unbind_all(int if_type) struct blk_desc *desc = dev_get_uclass_platdata(dev);
if (desc->if_type == if_type) { - ret = device_remove(dev); + ret = device_remove(dev, DM_REMOVE_NORMAL); if (ret) return ret; ret = device_unbind(dev); diff --git a/drivers/block/sandbox.c b/drivers/block/sandbox.c index 36c2ff3007..34d1c638bc 100644 --- a/drivers/block/sandbox.c +++ b/drivers/block/sandbox.c @@ -98,7 +98,7 @@ int host_dev_bind(int devnum, char *filename) /* Remove and unbind the old device, if any */ ret = blk_get_device(IF_TYPE_HOST, devnum, &dev); if (ret == 0) { - ret = device_remove(dev); + ret = device_remove(dev, DM_REMOVE_NORMAL); if (ret) return ret; ret = device_unbind(dev); diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index a7f77b4a21..b80bf52320 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -46,9 +46,10 @@ static int device_chld_unbind(struct udevice *dev) /** * device_chld_remove() - Stop all device's children * @dev: The device whose children are to be removed + * @pre_os_remove: Flag, if this functions is called in the pre-OS stage * @return 0 on success, -ve on error */ -static int device_chld_remove(struct udevice *dev) +static int device_chld_remove(struct udevice *dev, uint flags) { struct udevice *pos, *n; int ret; @@ -56,7 +57,7 @@ static int device_chld_remove(struct udevice *dev) assert(dev);
list_for_each_entry_safe(pos, n, &dev->child_head, sibling_node) { - ret = device_remove(pos); + ret = device_remove(pos, flags); if (ret) return ret; } @@ -151,7 +152,7 @@ void device_free(struct udevice *dev) devres_release_probe(dev); }
-int device_remove(struct udevice *dev) +int device_remove(struct udevice *dev, uint flags) { const struct driver *drv; int ret; @@ -169,7 +170,7 @@ int device_remove(struct udevice *dev) if (ret) return ret;
- ret = device_chld_remove(dev); + ret = device_chld_remove(dev, flags); if (ret) goto err;
diff --git a/drivers/core/device.c b/drivers/core/device.c index 70fcfc23e0..e1b0ebffc5 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -378,7 +378,7 @@ int device_probe(struct udevice *dev)
return 0; fail_uclass: - if (device_remove(dev)) { + if (device_remove(dev, DM_REMOVE_NORMAL)) { dm_warn("%s: Device '%s' failed to remove on error path\n", __func__, dev->name); } diff --git a/drivers/core/root.c b/drivers/core/root.c index 175fd3fb25..6dafc6ecfc 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -176,7 +176,7 @@ int dm_init(void)
int dm_uninit(void) { - device_remove(dm_root()); + device_remove(dm_root(), DM_REMOVE_NORMAL); device_unbind(dm_root());
return 0; diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 7de370644d..d94d43a98d 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -116,7 +116,7 @@ int uclass_destroy(struct uclass *uc) while (!list_empty(&uc->dev_head)) { dev = list_first_entry(&uc->dev_head, struct udevice, uclass_node); - ret = device_remove(dev); + ret = device_remove(dev, DM_REMOVE_NORMAL); if (ret) return ret; ret = device_unbind(dev); diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 5bb446bcc2..9c07871d3a 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -232,7 +232,7 @@ int mmc_unbind(struct udevice *dev)
device_find_first_child(dev, &bdev); if (bdev) { - device_remove(bdev); + device_remove(bdev, DM_REMOVE_NORMAL); device_unbind(bdev); }
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 36a50fe3a1..a53f4ebc68 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -595,7 +595,7 @@ void sandbox_sf_unbind_emul(struct sandbox_state *state, int busnum, int cs) struct udevice *dev;
dev = state->spi[busnum][cs].emul; - device_remove(dev); + device_remove(dev, DM_REMOVE_NORMAL); device_unbind(dev); state->spi[busnum][cs].emul = NULL; } diff --git a/drivers/mtd/spi/sf-uclass.c b/drivers/mtd/spi/sf-uclass.c index 19de964e61..83876485fe 100644 --- a/drivers/mtd/spi/sf-uclass.c +++ b/drivers/mtd/spi/sf-uclass.c @@ -46,7 +46,7 @@ struct spi_flash *spi_flash_probe(unsigned int bus, unsigned int cs,
void spi_flash_free(struct spi_flash *flash) { - device_remove(flash->spi->dev); + device_remove(flash->spi->dev, DM_REMOVE_NORMAL); }
int spi_flash_probe_bus_cs(unsigned int busnum, unsigned int cs, diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index ac17da0777..c061c05443 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -343,7 +343,7 @@ err: debug("%s: Error path, created=%d, device '%s'\n", __func__, created, dev->name); if (created) { - device_remove(dev); + device_remove(dev, DM_REMOVE_NORMAL); device_unbind(dev); }
@@ -384,7 +384,7 @@ struct spi_slave *spi_setup_slave(unsigned int busnum, unsigned int cs,
void spi_free_slave(struct spi_slave *slave) { - device_remove(slave->dev); + device_remove(slave->dev, DM_REMOVE_NORMAL); slave->dev = NULL; }
diff --git a/drivers/usb/emul/sandbox_hub.c b/drivers/usb/emul/sandbox_hub.c index c3a8e73389..f0939b19f4 100644 --- a/drivers/usb/emul/sandbox_hub.c +++ b/drivers/usb/emul/sandbox_hub.c @@ -156,7 +156,7 @@ static int clrset_post_state(struct udevice *hub, int port, int clear, int set) } else if (clear & USB_PORT_STAT_POWER) { debug("%s: %s: power off, removed, ret=%d\n", __func__, dev->name, ret); - ret = device_remove(dev); + ret = device_remove(dev, DM_REMOVE_NORMAL); clear |= USB_PORT_STAT_CONNECTION; } } diff --git a/drivers/usb/host/usb-uclass.c b/drivers/usb/host/usb-uclass.c index 5cf1e9a36c..6eded4abad 100644 --- a/drivers/usb/host/usb-uclass.c +++ b/drivers/usb/host/usb-uclass.c @@ -154,7 +154,7 @@ int usb_stop(void) uc_priv = uc->priv;
uclass_foreach_dev(bus, uc) { - ret = device_remove(bus); + ret = device_remove(bus, DM_REMOVE_NORMAL); if (ret && !err) err = ret; } @@ -358,7 +358,7 @@ int usb_setup_ehci_gadget(struct ehci_ctrl **ctlrp) ret = uclass_find_device_by_seq(UCLASS_USB, 0, true, &dev); if (ret) return ret; - ret = device_remove(dev); + ret = device_remove(dev, DM_REMOVE_NORMAL); if (ret) return ret;
diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index 0bf8707493..2cabc87338 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -96,12 +96,13 @@ int device_probe(struct udevice *dev); * children are deactivated first. * * @dev: Pointer to device to remove + * @flags: Flags for selective device removal * @return 0 if OK, -ve on error (an error here is normally a very bad thing) */ #if CONFIG_IS_ENABLED(DM_DEVICE_REMOVE) -int device_remove(struct udevice *dev); +int device_remove(struct udevice *dev, uint flags); #else -static inline int device_remove(struct udevice *dev) { return 0; } +static inline int device_remove(struct udevice *dev, uint flags) { return 0; } #endif
/** diff --git a/include/dm/device.h b/include/dm/device.h index 4e95fb7773..079ec57003 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -46,6 +46,32 @@ struct driver_info;
#define DM_FLAG_OF_PLATDATA (1 << 8)
+/* + * Call driver remove function to stop currently active DMA transfers or + * give DMA buffers back to the HW / controller. This may be needed for + * some drivers to do some final stage cleanup before the OS is called + * (U-Boot exit) + */ +#define DM_FLAG_ACTIVE_DMA (1 << 9) + +/* + * One or multiple of these flags are passed to device_remove() so that + * a selective device removal as specified by the remove-stage and the + * driver flags can be done. + */ +enum { + /* Normal remove, remove all devices */ + DM_REMOVE_NORMAL = 1 << 0, + + /* Remove devices with active DMA */ + DM_REMOVE_ACTIVE_DMA = DM_FLAG_ACTIVE_DMA, + + /* Add more use cases here */ + + /* Remove devices with any active flag */ + DM_REMOVE_ACTIVE_ALL = DM_REMOVE_ACTIVE_DMA, +}; + /** * struct udevice - An instance of a driver * diff --git a/test/dm/bus.c b/test/dm/bus.c index d94dcf7a60..6a2773565e 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -222,7 +222,7 @@ static int test_bus_parent_data(struct unit_test_state *uts) /* Check that it starts at 0 and goes away when device is removed */ parent_data->sum += 5; ut_asserteq(5, parent_data->sum); - device_remove(dev); + device_remove(dev, DM_REMOVE_NORMAL); ut_asserteq_ptr(NULL, dev_get_parent_priv(dev));
/* Check that we can do this twice */ @@ -323,7 +323,7 @@ static int dm_test_bus_parent_ops(struct unit_test_state *uts) continue; parent_data = dev_get_parent_priv(dev); ut_asserteq(FLAG_CHILD_PROBED, parent_data->flag); - ut_assertok(device_remove(dev)); + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_asserteq_ptr(NULL, dev_get_parent_priv(dev)); ut_asserteq_ptr(dms->removed, dev); } @@ -360,7 +360,7 @@ static int test_bus_parent_platdata(struct unit_test_state *uts) plat->count++; ut_asserteq(1, plat->count); device_probe(dev); - device_remove(dev); + device_remove(dev, DM_REMOVE_NORMAL);
ut_asserteq_ptr(plat, dev_get_parent_platdata(dev)); ut_asserteq(1, plat->count); @@ -370,7 +370,7 @@ static int test_bus_parent_platdata(struct unit_test_state *uts) ut_asserteq(3, child_count);
/* Removing the bus should also have no effect (it is still bound) */ - device_remove(bus); + device_remove(bus, DM_REMOVE_NORMAL); for (device_find_first_child(bus, &dev), child_count = 0; dev; device_find_next_child(&dev)) { diff --git a/test/dm/core.c b/test/dm/core.c index 70bf4d0605..07b2419ea4 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -319,7 +319,7 @@ static int dm_test_lifecycle(struct unit_test_state *uts)
/* Now remove device 3 */ ut_asserteq(0, dm_testdrv_op_count[DM_TEST_OP_PRE_REMOVE]); - ut_assertok(device_remove(dev)); + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_asserteq(1, dm_testdrv_op_count[DM_TEST_OP_PRE_REMOVE]);
ut_asserteq(0, dm_testdrv_op_count[DM_TEST_OP_UNBIND]); @@ -352,7 +352,7 @@ static int dm_test_ordering(struct unit_test_state *uts) ut_assert(dev_last);
/* Now remove device 3 */ - ut_assertok(device_remove(dev)); + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_assertok(device_unbind(dev));
/* The device numbering should have shifted down one */ @@ -371,9 +371,9 @@ static int dm_test_ordering(struct unit_test_state *uts) ut_assert(pingret == 102);
/* Remove 3 and 4 */ - ut_assertok(device_remove(dev_penultimate)); + ut_assertok(device_remove(dev_penultimate, DM_REMOVE_NORMAL)); ut_assertok(device_unbind(dev_penultimate)); - ut_assertok(device_remove(dev_last)); + ut_assertok(device_remove(dev_last, DM_REMOVE_NORMAL)); ut_assertok(device_unbind(dev_last));
/* Our device should now be in position 3 */ @@ -381,7 +381,7 @@ static int dm_test_ordering(struct unit_test_state *uts) ut_assert(dev == test_dev);
return 0; @@ -457,7 +457,7 @@ static int dm_test_remove(struct unit_test_state *uts) ut_assert(dev); ut_assertf(dev->flags & DM_FLAG_ACTIVATED, "Driver %d/%s not activated", i, dev->name); - ut_assertok(device_remove(dev)); + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_assertf(!(dev->flags & DM_FLAG_ACTIVATED), "Driver %d/%s should have deactivated", i, dev->name); @@ -611,14 +611,14 @@ static int dm_test_children(struct unit_test_state *uts) ut_asserteq(total, dm_testdrv_op_count[DM_TEST_OP_PROBE]);
/* Remove a top-level child and check that the children are removed */ - ut_assertok(device_remove(top[2])); + ut_assertok(device_remove(top[2], DM_REMOVE_NORMAL)); ut_asserteq(NODE_COUNT + 1, dm_testdrv_op_count[DM_TEST_OP_REMOVE]); dm_testdrv_op_count[DM_TEST_OP_REMOVE] = 0;
/* Try one with grandchildren */ ut_assertok(uclass_get_device(UCLASS_TEST, 5, &dev)); ut_asserteq_ptr(dev, top[5]); - ut_assertok(device_remove(dev)); + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); ut_asserteq(1 + NODE_COUNT * (1 + NODE_COUNT), dm_testdrv_op_count[DM_TEST_OP_REMOVE]);
diff --git a/test/dm/eth.c b/test/dm/eth.c index 6288ae24ab..564ad36916 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -116,7 +116,7 @@ static int dm_test_eth_act(struct unit_test_state *uts) for (i = 0; i < DM_TEST_ETH_NUM; i++) { ut_assertok(uclass_find_device_by_name(UCLASS_ETH, ethname[i], &dev[i])); - ut_assertok(device_remove(dev[i])); + ut_assertok(device_remove(dev[i], DM_REMOVE_NORMAL));
/* Invalidate MAC address */ strcpy(ethaddr[i], getenv(addrname[i])); diff --git a/test/dm/spi.c b/test/dm/spi.c index f52cb733c7..24fa2a48ae 100644 --- a/test/dm/spi.c +++ b/test/dm/spi.c @@ -36,7 +36,7 @@ static int dm_test_spi_find(struct unit_test_state *uts) ut_asserteq(0, uclass_get_device_by_seq(UCLASS_SPI, busnum, &bus)); ut_assertok(spi_cs_info(bus, cs, &info)); of_offset = dev_of_offset(info.dev); - device_remove(info.dev); + device_remove(info.dev, DM_REMOVE_NORMAL); device_unbind(info.dev);
The new function dm_remove_devices_flags() is intented for driver specific last-stage cleanup operations before the OS is started. This patch adds this functionality and hooks it into the common device_remove() function.
Drivers wanting to use this feature for some last-stage removal calls, need to add one of the DM_REMOVE_xx flags to their driver .flags.
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- v2: - Added Simons Reviewed-by
drivers/core/device-remove.c | 15 +++++++++++---- drivers/core/root.c | 7 +++++++ include/dm/root.h | 12 ++++++++++++ 3 files changed, 30 insertions(+), 4 deletions(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index b80bf52320..ca4680f7c2 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -174,7 +174,12 @@ int device_remove(struct udevice *dev, uint flags) if (ret) goto err;
- if (drv->remove) { + /* + * Remove the device if called with the "normal" remove flag set, + * or if the remove flag matches the driver flags + */ + if (drv->remove && + ((flags & DM_REMOVE_NORMAL) || (flags & drv->flags))) { ret = drv->remove(dev); if (ret) goto err_remove; @@ -188,10 +193,12 @@ int device_remove(struct udevice *dev, uint flags) } }
- device_free(dev); + if ((flags & DM_REMOVE_NORMAL) || (flags & drv->flags)) { + device_free(dev);
- dev->seq = -1; - dev->flags &= ~DM_FLAG_ACTIVATED; + dev->seq = -1; + dev->flags &= ~DM_FLAG_ACTIVATED; + }
return ret;
diff --git a/drivers/core/root.c b/drivers/core/root.c index 6dafc6ecfc..4c4642a8a4 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -182,6 +182,13 @@ int dm_uninit(void) return 0; }
+int dm_remove_devices_flags(uint flags) +{ + device_remove(dm_root(), flags); + + return 0; +} + int dm_scan_platdata(bool pre_reloc_only) { int ret; diff --git a/include/dm/root.h b/include/dm/root.h index 3cf730dcee..b13c005c17 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -115,4 +115,16 @@ int dm_init(void); */ int dm_uninit(void);
+/** + * dm_remove_devices_flags - Call remove function of all drivers with + * specific removal flags set to selectively + * remove drivers + * + * All devices with the matching flags set will be removed + * + * @flags: Flags for selective device removal + * @return 0 if OK, -ve on error + */ +int dm_remove_devices_flags(uint flags); + #endif
This patch adds a call to dm_remove_devices_flags() to announce_and_cleanup() so that drivers that have one of the removal flags set (e.g. DM_FLAG_ACTIVE_DMA_REMOVE) in their driver struct, may do some last-stage cleanup before the OS is started.
arch/arm/lib/bootm.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 8125cf023f..426bee6da5 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -14,6 +14,8 @@
#include <common.h> #include <command.h> +#include <dm/device.h> +#include <dm/root.h> #include <image.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> @@ -91,6 +93,13 @@ static void announce_and_cleanup(int fake)
board_quiesce_devices();
+ /* + * Call remove function of all devices with a removal flag set. + * This may be useful for last-stage operations, like cancelling + * of DMA operation or releasing device internal buffers. + */ + dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + cleanup_before_linux(); }
v2:
Applied to u-boot-dm, thanks!
Add a test for the correct device removal. Currently two different ways for device removal are supported:
- Normal device removal via the device_remove() API - Removal via selective device driver flags (DM_FLAG_ACTIVE_DMA)
This new test "remove_active_dma" adds tests cases for those both ways of removal.
Signed-off-by: Stefan Roese sr@denx.de Cc: Simon Glass sjg@chromium.org --- v2: - New patch in patchset
test/dm/core.c | 41 +++++++++++++++++++++++++++++++++++++++++ test/dm/test-driver.c | 1 + 2 files changed, 42 insertions(+)
diff --git a/test/dm/core.c b/test/dm/core.c index 07b2419ea4..ef85e6b79c 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -656,6 +656,47 @@ static int dm_test_pre_reloc(struct unit_test_state *uts) } DM_TEST(dm_test_pre_reloc, 0);
+/* + * Test that removal of devices, either via the "normal" device_remove() + * API or via the device driver selective flag works as expected + */ +static int dm_test_remove_active_dma(struct unit_test_state *uts) +{ + struct dm_test_state *dms = uts->priv; + struct udevice *dev; + + ut_assertok(device_bind_by_name(dms->root, false, &driver_info_manual, + &dev)); + ut_assert(dev); + + /* Probe the device */ + ut_assertok(device_probe(dev)); + + /* Test if device is active right now */ + ut_asserteq(true, device_active(dev)); + + /* Remove the device via selective remove flag */ + dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + + /* Test if device is inactive right now */ + ut_asserteq(false, device_active(dev)); + + /* Probe the device again */ + ut_assertok(device_probe(dev)); + + /* Test if device is active right now */ + ut_asserteq(true, device_active(dev)); + + /* Remove the device via "normal" remove API */ + ut_assertok(device_remove(dev, DM_REMOVE_NORMAL)); + + /* Test if device is inactive right now */ + ut_asserteq(false, device_active(dev)); + + return 0; +} +DM_TEST(dm_test_remove_active_dma, 0); + static int dm_test_uclass_before_ready(struct unit_test_state *uts) { struct uclass *uc; diff --git a/test/dm/test-driver.c b/test/dm/test-driver.c index d10af51147..1a2932e519 100644 --- a/test/dm/test-driver.c +++ b/test/dm/test-driver.c @@ -145,6 +145,7 @@ U_BOOT_DRIVER(test_manual_drv) = { .probe = test_manual_probe, .remove = test_manual_remove, .unbind = test_manual_unbind, + .flags = DM_FLAG_ACTIVE_DMA, };
U_BOOT_DRIVER(test_pre_reloc_drv) = {
Hi Stefan,
v2:
- Test that removal of devices, either via the "normal" device_remove()
- API or via the device driver selective flag works as expected
&dev));
ut_assert(dev);
This doesn't actually test a device not getting removed (due to its flag) I think. Can you add a test for that?
2.12.0
Hi Simon,
v2:
&dev));
ut_assert(dev);
Yes, I forgot to add a test for this "non-removal case". Will add in the next version.
Thanks, Stefan
Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org --- v3: - Add conditional compilation to fix compilation breakage on platforms without DM and DM_DEVICE_REMOVE support. With this change, Travis compiles all targets without any error
drivers/core/device-remove.c | 15 +++++++++++---- drivers/core/root.c | 9 +++++++++ include/dm/root.h | 16 ++++++++++++++++ 3 files changed, 36 insertions(+), 4 deletions(-)
return ret;
diff --git a/drivers/core/root.c b/drivers/core/root.c index 4d2033bfad..deefd00687 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -182,6 +182,15 @@ int dm_uninit(void) return 0; }
+#if CONFIG_IS_ENABLED(DM_DEVICE_REMOVE) +int dm_remove_devices_flags(uint flags) +{ + device_remove(dm_root(), flags); + + return 0; +} +#endif + int dm_scan_platdata(bool pre_reloc_only) { int ret; diff --git a/include/dm/root.h b/include/dm/root.h index 3cf730dcee..058eb98923 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -115,4 +115,20 @@ int dm_init(void); */ int dm_uninit(void);
+#if CONFIG_IS_ENABLED(DM_DEVICE_REMOVE) +/** + * dm_remove_devices_flags - Call remove function of all drivers with + * specific removal flags set to selectively + * remove drivers + * + * All devices with the matching flags set will be removed + * + * @flags: Flags for selective device removal + * @return 0 if OK, -ve on error + */ +int dm_remove_devices_flags(uint flags); +#else +static inline int dm_remove_devices_flags(uint flags) { return 0; } +#endif + #endif
Hi Stefan,
v3:
v2:
if (drv->remove) {
if (drv->remove &&
You are changing the condition here but still call the post_remove() method immediately below. If you decide note to remove the device then I think you should not call that function.
device_free(dev);
device_free(dev);
dev->seq = -1;
dev->seq = -1;
} return ret;
Hi Stefan,
On 25 March 2017 at 19:17, Simon Glass sjg@chromium.org wrote:
Hi Stefan,
v3:
v2:
if (drv->remove) {
if (drv->remove &&
This seems to be comparing different things. The DM_REMOVE_NORMAL flag is not from the same enum as drv->flags, is it?
device_free(dev);
device_free(dev);
dev->seq = -1;
dev->seq = -1;
} return ret;
Hi Simon,
Hi Stefan,
v3:
v2:
if (drv->remove) {
if (drv->remove &&
I have to admit that this comparison above is a bit "vague". I'll make it more explicit in the next patch version.
Thanks, Stefan
v2:
v2:
Stefan Roese
