[PATCH] net: fsl_mdio: Fix busy flag polling register
NXP's mEMAC reference manual, Chapter 6.5.5 "MDIO Ethernet Management Interface usage", specifies to poll the BSY (0) bit in the CFG (we call it CTL) register to wait until a transaction has finished, not bit 31 in the data register.
In the Linux kernel, this has already been fixed in commit 26eee0210ad7 ("net/fsl: fix a bug in xgmac_mdio").
Signed-off-by: Markus Koch markus@notsyncing.net ---
I only stumbled over this section of code while looking at something else, but I'm surprised this even works the way it is now. Maybe it's luck.
Sadly I have not yet had the chance to test this change on actual hardware, and I'm not sure I will anytime soon, so I'm asking whether there's anyone who could compile and run my code to see whether MDIO transactions work as expected.
Thanks! Markus
drivers/net/fm/memac_phy.c | 2 +- include/fsl_memac.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/fm/memac_phy.c b/drivers/net/fm/memac_phy.c index 72b500a6d1..0af6e83a8f 100644 --- a/drivers/net/fm/memac_phy.c +++ b/drivers/net/fm/memac_phy.c @@ -64,7 +64,7 @@ static int memac_wait_until_done(struct memac_mdio_controller *regs) { unsigned int timeout = MAX_NUM_RETRIES;
- while ((memac_in_32(®s->mdio_data) & MDIO_DATA_BSY) && timeout--) + while ((memac_in_32(®s->mdio_ctl) & MDIO_CTL_BSY) && timeout--) ;
if (!timeout) { diff --git a/include/fsl_memac.h b/include/fsl_memac.h index d067f1511c..d973fc0a5e 100644 --- a/include/fsl_memac.h +++ b/include/fsl_memac.h @@ -246,6 +246,7 @@ struct memac_mdio_controller { #define MDIO_STAT_HOLD_15_CLK (7 << 2) #define MDIO_STAT_NEG (1 << 23)
+#define MDIO_CTL_BSY (1 << 0) #define MDIO_CTL_DEV_ADDR(x) (x & 0x1f) #define MDIO_CTL_PORT_ADDR(x) ((x & 0x1f) << 5) #define MDIO_CTL_PRE_DIS (1 << 10) @@ -254,7 +255,6 @@ struct memac_mdio_controller { #define MDIO_CTL_READ (1 << 15)
#define MDIO_DATA(x) (x & 0xffff) -#define MDIO_DATA_BSY (1 << 31)
struct fsl_enet_mac;
Thanks! Markus
while ((memac_in_32(®s->mdio_ctl) & MDIO_CTL_BSY) && timeout--) ; if (!timeout) {
-- 2.34.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
First of all, the CFG (Configuration) and CTL (Control) are two different registers so the '(we call it CTL)' part of your statement is false.
Indeed, the BSY bit is located in the MDIO_CFG register but that is not accessed through the mdio_ctl field as you used it in your changes. It's instead accessed through the mdio_stat field (the MDIO_CFG is called in some RMs as the Configuration and Status register).
Even the commit that you referenced is using the mdio_stat field.
--- a/drivers/net/ethernet/freescale/xgmac_mdio.c +++ b/drivers/net/ethernet/freescale/xgmac_mdio.c @@ -79,7 +79,7 @@ static int xgmac_wait_until_done(struct device *dev,
/* Wait till the MDIO write is complete */ timeout = TIMEOUT; - while ((ioread32be(®s->mdio_data) & MDIO_DATA_BSY) && timeout) { + while ((ioread32be(®s->mdio_stat) & MDIO_STAT_BSY) && timeout) { cpu_relax(); timeout--; }
Please fix this up in a v2.
Thanks, Ioana
Ioana Ciornei
Markus Koch
Ramon Fried
