[U-Boot] [PATCH 0/3] Fastboot MBR and generic partition support
This set extends the Fastboot implementation from GPT-only to any partition support. Further it adds a special target "mbr" (configurable) to write the DOS MBR.
Petr Kulhavy (3): disk: part: implement generic function part_get_info_by_name() fastboot: add support for writing MBR disk: part: refactor generic name creation for DOS and ISO
README | 7 +++++ common/fb_mmc.c | 44 +++++++++++++++++++++++------ disk/part.c | 58 +++++++++++++++++++++++++++++++++++++ disk/part_amiga.c | 1 + disk/part_dos.c | 52 +++++++++++++++------------------- disk/part_efi.c | 20 +------------ disk/part_iso.c | 26 ++--------------- disk/part_mac.c | 1 + doc/README.android-fastboot | 38 +++++++++++++++++++++++++ include/part.h | 69 +++++++++++++++++++++++++++++++++++++-------- 10 files changed, 224 insertions(+), 92 deletions(-)
So far partition search by name has been supported only on the EFI partition table. This patch extends the search to all partition tables.
Rename part_get_info_efi_by_name() to part_get_info_by_name(), move it from part_efi.c into part.c and make it a generic function which traverses all part drivers and searches all partitions (in the order given by the linked list).
For this a new variable struct part_driver.max_entries is added, which limits the number of partitions searched. For EFI this was GPT_ENTRY_NUMBERS. Similarly the limit is defined for DOS, ISO, MAC and AMIGA partition tables.
Signed-off-by: Petr Kulhavy brain@jikos.cz --- common/fb_mmc.c | 4 ++-- disk/part.c | 26 ++++++++++++++++++++++++++ disk/part_amiga.c | 1 + disk/part_dos.c | 1 + disk/part_efi.c | 20 +------------------- disk/part_iso.c | 1 + disk/part_mac.c | 1 + include/part.h | 32 ++++++++++++++++++++------------ 8 files changed, 53 insertions(+), 33 deletions(-)
diff --git a/common/fb_mmc.c b/common/fb_mmc.c index 8d0524d..a0a4a83 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -27,7 +27,7 @@ static int part_get_info_efi_by_name_or_alias(struct blk_desc *dev_desc, { int ret;
- ret = part_get_info_efi_by_name(dev_desc, name, info); + ret = part_get_info_by_name(dev_desc, name, info); if (ret) { /* strlen("fastboot_partition_alias_") + 32(part_name) + 1 */ char env_alias_name[25 + 32 + 1]; @@ -38,7 +38,7 @@ static int part_get_info_efi_by_name_or_alias(struct blk_desc *dev_desc, strncat(env_alias_name, name, 32); aliased_part_name = getenv(env_alias_name); if (aliased_part_name != NULL) - ret = part_get_info_efi_by_name(dev_desc, + ret = part_get_info_by_name(dev_desc, aliased_part_name, info); } return ret; diff --git a/disk/part.c b/disk/part.c index 6a1c02d..8317e80 100644 --- a/disk/part.c +++ b/disk/part.c @@ -615,3 +615,29 @@ cleanup: free(dup_str); return ret; } + +int part_get_info_by_name(struct blk_desc *dev_desc, const char *name, + disk_partition_t *info) +{ + struct part_driver *first_drv = + ll_entry_start(struct part_driver, part_driver); + const int n_drvs = ll_entry_count(struct part_driver, part_driver); + struct part_driver *part_drv; + + for (part_drv = first_drv; part_drv != first_drv + n_drvs; part_drv++) { + int ret; + int i; + for (i = 1; i < part_drv->max_entries; i++) { + ret = part_drv->get_info(dev_desc, i, info); + if (ret != 0) { + /* no more entries in table */ + break; + } + if (strcmp(name, (const char *)info->name) == 0) { + /* matched */ + return 0; + } + } + } + return -1; +} diff --git a/disk/part_amiga.c b/disk/part_amiga.c index d4316b8..25fe56c 100644 --- a/disk/part_amiga.c +++ b/disk/part_amiga.c @@ -381,6 +381,7 @@ static void part_print_amiga(struct blk_desc *dev_desc) U_BOOT_PART_TYPE(amiga) = { .name = "AMIGA", .part_type = PART_TYPE_AMIGA, + .max_entries = AMIGA_ENTRY_NUMBERS, .get_info = part_get_info_amiga, .print = part_print_amiga, .test = part_test_amiga, diff --git a/disk/part_dos.c b/disk/part_dos.c index 511917a..8226601 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -300,6 +300,7 @@ int part_get_info_dos(struct blk_desc *dev_desc, int part, U_BOOT_PART_TYPE(dos) = { .name = "DOS", .part_type = PART_TYPE_DOS, + .max_entries = DOS_ENTRY_NUMBERS, .get_info = part_get_info_ptr(part_get_info_dos), .print = part_print_ptr(part_print_dos), .test = part_test_dos, diff --git a/disk/part_efi.c b/disk/part_efi.c index 8d67c09..1924338 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -296,25 +296,6 @@ int part_get_info_efi(struct blk_desc *dev_desc, int part, return 0; }
-int part_get_info_efi_by_name(struct blk_desc *dev_desc, - const char *name, disk_partition_t *info) -{ - int ret; - int i; - for (i = 1; i < GPT_ENTRY_NUMBERS; i++) { - ret = part_get_info_efi(dev_desc, i, info); - if (ret != 0) { - /* no more entries in table */ - return -1; - } - if (strcmp(name, (const char *)info->name) == 0) { - /* matched */ - return 0; - } - } - return -2; -} - static int part_test_efi(struct blk_desc *dev_desc) { ALLOC_CACHE_ALIGN_BUFFER_PAD(legacy_mbr, legacymbr, 1, dev_desc->blksz); @@ -958,6 +939,7 @@ static int is_pte_valid(gpt_entry * pte) U_BOOT_PART_TYPE(a_efi) = { .name = "EFI", .part_type = PART_TYPE_EFI, + .max_entries = GPT_ENTRY_NUMBERS, .get_info = part_get_info_ptr(part_get_info_efi), .print = part_print_ptr(part_print_efi), .test = part_test_efi, diff --git a/disk/part_iso.c b/disk/part_iso.c index f9a741d..78fc97e 100644 --- a/disk/part_iso.c +++ b/disk/part_iso.c @@ -257,6 +257,7 @@ static int part_test_iso(struct blk_desc *dev_desc) U_BOOT_PART_TYPE(iso) = { .name = "ISO", .part_type = PART_TYPE_ISO, + .max_entries = ISO_ENTRY_NUMBERS, .get_info = part_get_info_iso, .print = part_print_iso, .test = part_test_iso, diff --git a/disk/part_mac.c b/disk/part_mac.c index 3952b8d..b6c082e 100644 --- a/disk/part_mac.c +++ b/disk/part_mac.c @@ -239,6 +239,7 @@ static int part_get_info_mac(struct blk_desc *dev_desc, int part, U_BOOT_PART_TYPE(mac) = { .name = "MAC", .part_type = PART_TYPE_MAC, + .max_entries = MAC_ENTRY_NUMBERS, .get_info = part_get_info_mac, .print = part_print_mac, .test = part_test_mac, diff --git a/include/part.h b/include/part.h index 226b5be..bd8fd49 100644 --- a/include/part.h +++ b/include/part.h @@ -28,6 +28,11 @@ struct block_drvr { #define PART_TYPE_AMIGA 0x04 #define PART_TYPE_EFI 0x05
+/* maximum number of partition entries supported by search */ +#define DOS_ENTRY_NUMBERS 8 +#define ISO_ENTRY_NUMBERS 64 +#define MAC_ENTRY_NUMBERS 64 +#define AMIGA_ENTRY_NUMBERS 8 /* * Type string for U-Boot bootable partitions */ @@ -146,6 +151,20 @@ int blk_get_device_by_str(const char *ifname, const char *dev_str, int blk_get_device_part_str(const char *ifname, const char *dev_part_str, struct blk_desc **dev_desc, disk_partition_t *info, int allow_whole_dev); + +/** + * part_get_info_by_name() - Search for a partition by name + * among all available registered partitions + * + * @param dev_desc - block device descriptor + * @param gpt_name - the specified table entry name + * @param info - returns the disk partition info + * + * @return - '0' on match, '-1' on no match, otherwise error + */ +int part_get_info_by_name(struct blk_desc *dev_desc, + const char *name, disk_partition_t *info); + extern const struct block_drvr block_drvr[]; #else static inline struct blk_desc *blk_get_dev(const char *ifname, int dev) @@ -189,6 +208,7 @@ static inline int blk_get_device_part_str(const char *ifname, struct part_driver { const char *name; int part_type; + const int max_entries; /* maximum number of entries to search */
/** * get_info() - Get information about a partition @@ -225,18 +245,6 @@ struct part_driver { #include <part_efi.h> /* disk/part_efi.c */ /** - * part_get_info_efi_by_name() - Find the specified GPT partition table entry - * - * @param dev_desc - block device descriptor - * @param gpt_name - the specified table entry name - * @param info - returns the disk partition info - * - * @return - '0' on match, '-1' on no match, otherwise error - */ -int part_get_info_efi_by_name(struct blk_desc *dev_desc, - const char *name, disk_partition_t *info); - -/** * write_gpt_table() - Write the GUID Partition Table to disk * * @param dev_desc - block device descriptor
Add special target "mbr" (otherwise configurable via CONFIG_FASTBOOT_MBR_NAME) to write MBR partition table. Partitions are now searched using the generic function which finds any partiiton by name. For MBR the partition names hda1, sda1, etc. are used.
Signed-off-by: Petr Kulhavy brain@jikos.cz --- README | 7 +++++++ common/fb_mmc.c | 40 ++++++++++++++++++++++++++++++++++------ disk/part_dos.c | 20 ++++++++++++++++++++ doc/README.android-fastboot | 37 +++++++++++++++++++++++++++++++++++++ include/part.h | 23 +++++++++++++++++++++++ 5 files changed, 121 insertions(+), 6 deletions(-)
diff --git a/README b/README index 30d7ee3..f6ef8b8 100644 --- a/README +++ b/README @@ -1682,6 +1682,13 @@ The following options need to be configured: "fastboot flash" command line matches this value. Default is GPT_ENTRY_NAME (currently "gpt") if undefined.
+ CONFIG_FASTBOOT_MBR_NAME + The fastboot "flash" command supports writing the downloaded + image to DOS MBR. + This occurs when the "partition name" specified on the + "fastboot flash" command line matches this value. + If not defined the default value "mbr" is used. + - Journaling Flash filesystem support: CONFIG_JFFS2_NAND, CONFIG_JFFS2_NAND_OFF, CONFIG_JFFS2_NAND_SIZE, CONFIG_JFFS2_NAND_DEV diff --git a/common/fb_mmc.c b/common/fb_mmc.c index a0a4a83..4bc68a7 100644 --- a/common/fb_mmc.c +++ b/common/fb_mmc.c @@ -14,15 +14,20 @@ #include <mmc.h> #include <div64.h>
-#ifndef CONFIG_FASTBOOT_GPT_NAME +#if defined(CONFIG_EFI_PARTITION) && !defined(CONFIG_FASTBOOT_GPT_NAME) #define CONFIG_FASTBOOT_GPT_NAME GPT_ENTRY_NAME #endif
+ +#if defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_FASTBOOT_MBR_NAME) +#define CONFIG_FASTBOOT_MBR_NAME "mbr" +#endif + struct fb_mmc_sparse { struct blk_desc *dev_desc; };
-static int part_get_info_efi_by_name_or_alias(struct blk_desc *dev_desc, +static int part_get_info_by_name_or_alias(struct blk_desc *dev_desc, const char *name, disk_partition_t *info) { int ret; @@ -103,6 +108,7 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, return; }
+#ifdef CONFIG_EFI_PARTITION if (strcmp(cmd, CONFIG_FASTBOOT_GPT_NAME) == 0) { printf("%s: updating MBR, Primary and Backup GPT(s)\n", __func__); @@ -114,14 +120,36 @@ void fb_mmc_flash_write(const char *cmd, void *download_buffer, } if (write_mbr_and_gpt_partitions(dev_desc, download_buffer)) { printf("%s: writing GPT partitions failed\n", __func__); - fastboot_fail( - "writing GPT partitions failed"); + fastboot_fail("writing GPT partitions failed"); return; } printf("........ success\n"); fastboot_okay(""); return; - } else if (part_get_info_efi_by_name_or_alias(dev_desc, cmd, &info)) { + } +#endif + +#ifdef CONFIG_DOS_PARTITION + if (strcmp(cmd, CONFIG_FASTBOOT_MBR_NAME) == 0) { + printf("%s: updating MBR\n", __func__); + if (is_valid_dos_buf(download_buffer)) { + printf("%s: invalid MBR - refusing to write to flash\n", + __func__); + fastboot_fail("invalid MBR partition"); + return; + } + if (write_mbr_partition(dev_desc, download_buffer)) { + printf("%s: writing MBR partition failed\n", __func__); + fastboot_fail("writing MBR partition failed"); + return; + } + printf("........ success\n"); + fastboot_okay(""); + return; + } +#endif + + if (part_get_info_by_name_or_alias(dev_desc, cmd, &info)) { error("cannot find partition: '%s'\n", cmd); fastboot_fail("cannot find partition"); return; @@ -172,7 +200,7 @@ void fb_mmc_erase(const char *cmd) return; }
- ret = part_get_info_efi_by_name_or_alias(dev_desc, cmd, &info); + ret = part_get_info_by_name_or_alias(dev_desc, cmd, &info); if (ret) { error("cannot find partition: '%s'", cmd); fastboot_fail("cannot find partition"); diff --git a/disk/part_dos.c b/disk/part_dos.c index 8226601..8e6aae5 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -297,6 +297,26 @@ int part_get_info_dos(struct blk_desc *dev_desc, int part, return part_get_info_extended(dev_desc, 0, 0, 1, part, info, 0); }
+int is_valid_dos_buf(void *buf) +{ + return test_block_type(buf) == DOS_MBR ? 0 : -1; +} + +int write_mbr_partition(struct blk_desc *dev_desc, void *buf) +{ + if (is_valid_dos_buf(buf)) + return -1; + + /* write MBR */ + if (blk_dwrite(dev_desc, 0, 1, buf) != 1) { + printf("%s: failed writing '%s' (1 blks at 0x0)\n", + __func__, "MBR"); + return 1; + } + + return 0; +} + U_BOOT_PART_TYPE(dos) = { .name = "DOS", .part_type = PART_TYPE_DOS, diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index ce12bc5..dea7066 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -59,6 +59,43 @@ To define a partition alias add an environment variable similar to: fastboot_partition_alias_<alias partition name>=<actual partition name> Example: fastboot_partition_alias_boot=LNX
+Partition Names +=============== +The Fastboot implementation in U-boot allows to write images into disk +partitions (currently on eMMC). Target partitions are referred on the host +computer by their names. + +For GPT/EFI the respective partition name is used. + +For MBR the partitions are referred by generic names according to the +following schema: + + <device type> <device index letter> <partition index> + +Example: hda3, sdb1, usbda1 + +The device type is as follows: + + * IDE, ATAPI and SATA disks: hd + * SCSI disks: sd + * USB media: usbd + * Disk on chip: docd + * other: xx + +The device index starts from 'a' and refers to the interface (e.g. USB +controller, SD/MMC controller) or disk index. The partition index starts +from 1 and describes the partition number on the particular device. + +Writing Partition Table +======================= +Fastboot also allows to write the partition table to the media. This can be +done by writing the respective partition table image to a special target +"gpt" or "mbr". These names can be customized by defining the following +configuration options: + +CONFIG_FASTBOOT_GPT_NAME +CONFIG_FASTBOOT_MBR_NAME + In Action ========= Enter into fastboot by executing the fastboot command in u-boot and you diff --git a/include/part.h b/include/part.h index bd8fd49..b17c219 100644 --- a/include/part.h +++ b/include/part.h @@ -351,4 +351,27 @@ int gpt_verify_partitions(struct blk_desc *dev_desc, gpt_header *gpt_head, gpt_entry **gpt_pte); #endif
+#ifdef CONFIG_DOS_PARTITION +/** + * is_valid_dos_buf() - Ensure that a DOS MBR image is valid + * + * @param buf - buffer which contains the MBR + * + * @return - '0' on success, otherwise error + */ +int is_valid_dos_buf(void *buf); + +/** + * write_mbr_partition() - write DOS MBR + * + * @param dev_desc - block device descriptor + * @param buf - buffer which contains the MBR + * + * @return - '0' on success, otherwise error + */ +int write_mbr_partition(struct blk_desc *dev_desc, void *buf); + +#endif + + #endif /* _PART_H */
In both DOS and ISO partition tables the same code to create partition name like "hda1" was repeated.
Code moved to into a new function part_set_generic_name() in part.c and optimized. Added recognition of MMC and SD types, name is like "mmcsda1".
Signed-off-by: Petr Kulhavy brain@jikos.cz --- disk/part.c | 32 ++++++++++++++++++++++++++++++++ disk/part_dos.c | 31 ++----------------------------- disk/part_iso.c | 25 +------------------------ doc/README.android-fastboot | 1 + include/part.h | 14 ++++++++++++++ 5 files changed, 50 insertions(+), 53 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 8317e80..9f51a07 100644 --- a/disk/part.c +++ b/disk/part.c @@ -641,3 +641,35 @@ int part_get_info_by_name(struct blk_desc *dev_desc, const char *name, } return -1; } + +void part_set_generic_name(const struct blk_desc *dev_desc, + int part_num, char *name) +{ + char *devtype; + + switch (dev_desc->if_type) { + case IF_TYPE_IDE: + case IF_TYPE_SATA: + case IF_TYPE_ATAPI: + devtype = "hd"; + break; + case IF_TYPE_SCSI: + devtype = "sd"; + break; + case IF_TYPE_USB: + devtype = "usbd"; + break; + case IF_TYPE_DOC: + devtype = "docd"; + break; + case IF_TYPE_MMC: + case IF_TYPE_SD: + devtype = "mmcsd"; + break; + default: + devtype = "xx"; + break; + } + + sprintf(name, "%s%c%d", devtype, 'a' + dev_desc->devnum, part_num); +} diff --git a/disk/part_dos.c b/disk/part_dos.c index 8e6aae5..ed78334 100644 --- a/disk/part_dos.c +++ b/disk/part_dos.c @@ -209,35 +209,8 @@ static int part_get_info_extended(struct blk_desc *dev_desc, info->start = (lbaint_t)(ext_part_sector + le32_to_int(pt->start4)); info->size = (lbaint_t)le32_to_int(pt->size4); - switch(dev_desc->if_type) { - case IF_TYPE_IDE: - case IF_TYPE_SATA: - case IF_TYPE_ATAPI: - sprintf((char *)info->name, "hd%c%d", - 'a' + dev_desc->devnum, - part_num); - break; - case IF_TYPE_SCSI: - sprintf((char *)info->name, "sd%c%d", - 'a' + dev_desc->devnum, - part_num); - break; - case IF_TYPE_USB: - sprintf((char *)info->name, "usbd%c%d", - 'a' + dev_desc->devnum, - part_num); - break; - case IF_TYPE_DOC: - sprintf((char *)info->name, "docd%c%d", - 'a' + dev_desc->devnum, - part_num); - break; - default: - sprintf((char *)info->name, "xx%c%d", - 'a' + dev_desc->devnum, - part_num); - break; - } + part_set_generic_name(dev_desc, part_num, + (char *)info->name); /* sprintf(info->type, "%d, pt->sys_ind); */ strcpy((char *)info->type, "U-Boot"); info->bootable = is_bootable(pt); diff --git a/disk/part_iso.c b/disk/part_iso.c index 78fc97e..bb8ed65 100644 --- a/disk/part_iso.c +++ b/disk/part_iso.c @@ -137,30 +137,7 @@ int part_get_info_iso_verb(struct blk_desc *dev_desc, int part_num, entry_num=1; offset=0x20; strcpy((char *)info->type, "U-Boot"); - switch(dev_desc->if_type) { - case IF_TYPE_IDE: - case IF_TYPE_SATA: - case IF_TYPE_ATAPI: - sprintf ((char *)info->name, "hd%c%d", - 'a' + dev_desc->devnum, part_num); - break; - case IF_TYPE_SCSI: - sprintf ((char *)info->name, "sd%c%d", - 'a' + dev_desc->devnum, part_num); - break; - case IF_TYPE_USB: - sprintf ((char *)info->name, "usbd%c%d", - 'a' + dev_desc->devnum, part_num); - break; - case IF_TYPE_DOC: - sprintf ((char *)info->name, "docd%c%d", - 'a' + dev_desc->devnum, part_num); - break; - default: - sprintf ((char *)info->name, "xx%c%d", - 'a' + dev_desc->devnum, part_num); - break; - } + part_set_generic_name(dev_desc, part_num, (char *)info->name); /* the bootcatalog (including validation Entry) is limited to 2048Bytes * (63 boot entries + validation entry) */ while(offset<2048) { diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index dea7066..b8afa15 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -79,6 +79,7 @@ The device type is as follows: * IDE, ATAPI and SATA disks: hd * SCSI disks: sd * USB media: usbd + * MMC and SD cards: mmcsd * Disk on chip: docd * other: xx
diff --git a/include/part.h b/include/part.h index b17c219..0979005 100644 --- a/include/part.h +++ b/include/part.h @@ -165,6 +165,20 @@ int blk_get_device_part_str(const char *ifname, const char *dev_part_str, int part_get_info_by_name(struct blk_desc *dev_desc, const char *name, disk_partition_t *info);
+/** + * part_set_generic_name() - create generic partition like hda1 or sdb2 + * + * Helper function for partition tables, which don't hold partition names + * (DOS, ISO). Generates partition name out of the device type and partition + * number. + * + * @dev_desc: pointer to the block device + * @part_num: partition number for which the name is generated + * @name: buffer where the name is written + */ +void part_set_generic_name(const struct blk_desc *dev_desc, + int part_num, char *name); + extern const struct block_drvr block_drvr[]; #else static inline struct blk_desc *blk_get_dev(const char *ifname, int dev)
Can you please do a follow up patch where you move both CONFIG_FASTBOOT_GPT_NAME and CONFIG_FASTBOOT_MBR_NAME in to cmd/fastboot/Kconfig ? And then clean up the code since a name will always be set. Thanks!
Petr Kulhavy
