[U-Boot] [PATCH 2/2] arm: a320evb: fixes for relocation support
- add CONFIG_SYS_SDRAM_BASE and CONFIG_SYS_INIT_SP_ADDR - do not update gd->bd in dram_init() because bd is unavailable then
Signed-off-by: Po-Yu Chuang ratbert@faraday-tech.com --- board/faraday/a320evb/a320evb.c | 3 +-- include/configs/a320evb.h | 10 +++++++--- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/board/faraday/a320evb/a320evb.c b/board/faraday/a320evb/a320evb.c index 85b11b9..b9343e4 100644 --- a/board/faraday/a320evb/a320evb.c +++ b/board/faraday/a320evb/a320evb.c @@ -46,8 +46,7 @@ int dram_init(void)
actual_size = get_ram_size((void *)sdram_base, expected_size);
- gd->bd->bi_dram[0].start = sdram_base; - gd->bd->bi_dram[0].size = actual_size; + gd->ram_size = actual_size;
if (expected_size != actual_size) printf("Warning: Only %lu of %lu MiB SDRAM is working\n", diff --git a/include/configs/a320evb.h b/include/configs/a320evb.h index 0284d40..97bf8b9 100644 --- a/include/configs/a320evb.h +++ b/include/configs/a320evb.h @@ -138,15 +138,19 @@ #define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */
+#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ + GENERATED_GBL_DATA_SIZE) + /* * Load address and memory test area should agree with * board/faraday/a320/config.mk. Be careful not to overwrite U-boot itself. */ -#define CONFIG_SYS_LOAD_ADDR 0x12000000 +#define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x2000000)
/* memtest works on 63 MB in DRAM */ -#define CONFIG_SYS_MEMTEST_START 0x10000000 -#define CONFIG_SYS_MEMTEST_END 0x13F00000 +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 0x3F00000)
#define CONFIG_SYS_TEXT_BASE 0
* add CONFIG_SYS_SDRAM_BASE and CONFIG_SYS_INIT_SP_ADDR * do not update gd->bd in dram_init() because bd is unavailable then * move CONFIG_SYS_TEXT_BASE from config.mk to a320evb.h * remove config.mk
Signed-off-by: Po-Yu Chuang ratbert@faraday-tech.com --- v2: rebase remove config.mk
board/faraday/a320evb/a320evb.c | 3 +-- board/faraday/a320evb/config.mk | 35 ----------------------------------- include/configs/a320evb.h | 14 ++++++++++---- 3 files changed, 11 insertions(+), 41 deletions(-) delete mode 100644 board/faraday/a320evb/config.mk
if (expected_size != actual_size) printf("Warning: Only %lu of %lu MiB SDRAM is working\n", diff --git a/board/faraday/a320evb/config.mk b/board/faraday/a320evb/config.mk deleted file mode 100644 index b751d0d..0000000 --- a/board/faraday/a320evb/config.mk +++ /dev/null @@ -1,35 +0,0 @@ -# -# (C) Copyright 2009 Faraday Technology -# Po-Yu Chuang ratbert@faraday-tech.com -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -# Faraday A320 board with FA526/FA626TE/ARM926EJ-S cpus -# -# see http://www.faraday-tech.com/ for more information - -# A320 has 1 bank of 64 MB DRAM -# -# 1000'0000 to 1400'0000 -# -# Linux-Kernel is expected to be at 1000'8000, entry 1000'8000 -# -# we load ourself to 13f8'0000 -# -# download area is 1200'0000 - -CONFIG_SYS_TEXT_BASE = 0x13f80000 diff --git a/include/configs/a320evb.h b/include/configs/a320evb.h index f67cf06..27f137f 100644 --- a/include/configs/a320evb.h +++ b/include/configs/a320evb.h @@ -138,15 +138,21 @@ #define PHYS_SDRAM_1 0x10000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */
/* memtest works on 63 MB in DRAM */ -#define CONFIG_SYS_MEMTEST_START 0x10000000 -#define CONFIG_SYS_MEMTEST_END 0x13F00000 +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + 0x3F00000) + +#define CONFIG_SYS_TEXT_BASE 0
/*----------------------------------------------------------------------- * Static memory controller configuration @@ -215,7 +221,7 @@
/* environments */ #define CONFIG_ENV_IS_IN_FLASH -#define CONFIG_ENV_ADDR 0x00060000 +#define CONFIG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) #define CONFIG_ENV_SIZE 0x20000
#endif /* __CONFIG_H */
- move CONFIG_SYS_TEXT_BASE from config.mk to a320evb.h
- remove config.mk
Signed-off-by: Po-Yu Chuangratbert@faraday-tech.com
diff --git a/board/faraday/a320evb/config.mk b/board/faraday/a320evb/config.mk deleted file mode 100644 index b751d0d..0000000 --- a/board/faraday/a320evb/config.mk +++ /dev/null @@ -1,35 +0,0 @@ -# -# (C) Copyright 2009 Faraday Technology -# Po-Yu Chuangratbert@faraday-tech.com -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -#
- Load address and memory test area should agree with
- board/faraday/a320/config.mk. Be careful not to overwrite U-boot itself.
- Static memory controller configuration
@@ -215,7 +221,7 @@
As this is a fix, applied to u-boot-arm.
Amicalement,
Albert ARIBAUD
Po-Yu Chuang
ratbert.chuang@gmail.com
