[PATCH 1/1] doc: fatinfo man-page
Provide a man-page for the fatinfo command.
The .rst file was lost in patch 15d9694600fe ("doc: fatinfo man-page").
Fixes: 15d9694600fe ("doc: fatinfo man-page") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/usage/fatinfo.rst | 51 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+) create mode 100644 doc/usage/fatinfo.rst
diff --git a/doc/usage/fatinfo.rst b/doc/usage/fatinfo.rst new file mode 100644 index 0000000000..af2eba4344 --- /dev/null +++ b/doc/usage/fatinfo.rst @@ -0,0 +1,51 @@ +.. SPDX-License-Identifier: GPL-2.0+: + +fatinfo command +=============== + +Synopsis +-------- + +:: + + fatinfo <interface> <dev[:part]> + +Description +----------- + +The fatinfo command displays information about a FAT partition. + +interface + interface for accessing the block device (mmc, sata, scsi, usb, ....) + +dev + device number + +part + partition number, defaults to 1 + +Example +------- + +Here is the output for a partition on a 32 GB SD-Card: + +:: + + => fatinfo mmc 0:1 + Interface: MMC + Device 0: Vendor: Man 00001b Snr 97560602 Rev: 13.8 Prod: EB1QT0 + Type: Removable Hard Disk + Capacity: 30528.0 MB = 29.8 GB (62521344 x 512) + Filesystem: FAT32 "MYDISK " + => + +Configuration +------------- + +The fatinfo command is only available if CONFIG_CMD_FAT=y. + +Return value +------------ + +The return value $? is set to 0 (true) if the partition is a FAT partition. +Otherwise it is set to 1 (false). -- 2.30.2
