[U-Boot] [UBOOT PATCH 0/4] fpga: Moved fpga u-boot headers to the Kconfig
This series of patch moved fpga u-boot headers to the kconfig and enabled in respective defconfig. These are the configs: -CONFIG_FPGA_SPARTAN3 -CONFIG_FPGA_ZYNQPL
Vipul Kumar (4): fpga: Added Kconfig support for FPGA_SPARTAN3 fpga: Added CONFIG_FPGA_SPARTAN3 in the the respective defconfig arm: zynq: fpga: Added Kconfig support for CONFIG_FPGA_ZYNQPL arm: zynq: fpga: Added CONFIG_FPGA_ZYNQPL in the respective defconfig
configs/apf27_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/syzygy_hub_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/x600_defconfig | 1 + configs/zynq_cc108_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm011_x16_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + drivers/fpga/Kconfig | 12 ++++++++++++ include/configs/apf27.h | 1 - include/configs/astro_mcf5373l.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/x600.h | 1 - include/configs/zynq-common.h | 2 -- 27 files changed, 33 insertions(+), 6 deletions(-)
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch added Kconfig support for FPGA_SPARTAN3.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/fpga/Kconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index 6b2c866..ac08bc1 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -45,4 +45,9 @@ config FPGA_ZYNQMPPL Enable FPGA driver for loading bitstream in BIT and BIN format on Xilinx Zynq UltraScale+ (ZynqMP) device.
+config FPGA_SPARTAN3 + bool "Enable Spartan3 FPGA driver" + help + Enable Spartan3 FPGA driver for loading in BIT format. + endmenu -- 2.7.4
After merging 2/4 into this (we should always update the defconfigs in the patch, otherwise we may get build warnings later when bisecting), applied to u-boot/master, thanks!
Hi Tom,
I am collecting these Kconfig patches in this branch (I have rebased it now) http://git.denx.de/?p=u-boot/u-boot-microblaze.git;a=shortlog;h=refs/heads/k...
Do you want to get these patches before 2018.03 tag?
Thanks, Michal
On Thu, Mar 01, 2018 at 08:05:59AM +0100, Michal Simek wrote:
Hi Tom,
If they're size-neutral (or understandably why), yes. I can even give a pull and build, if you don't have a machine you can do that on easily (or don't want to setup a gcompute node or whatever).
Hi Tom,
Ok. They are supposed to be size neutral. I will review that v2 which Vipul sent and will send you pull request when I am done.
Thanks, Michal
This patch added CONFIG_FPGA_SPARTAN3 in the respective defconfig.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- configs/apf27_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/x600_defconfig | 1 + include/configs/apf27.h | 1 - include/configs/astro_mcf5373l.h | 1 - include/configs/mt_ventoux.h | 1 - include/configs/x600.h | 1 - 8 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 00aa7c3..d7437ed 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -34,6 +34,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=mxc_nand.0:1M(u-boot)ro,512K(env),512K(env2),5 CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_SPARTAN3=y CONFIG_MXC_GPIO=y CONFIG_MMC_MXC=y CONFIG_NAND=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index 011dc36..71250af 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -19,4 +19,5 @@ CONFIG_CMD_JFFS2=y CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_SPARTAN3=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 49ddcc6..66dcc03 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -31,6 +31,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1m(u-boot),256k(env1),2 CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_SPARTAN3=y CONFIG_SYS_OMAP24_I2C_SPEED=400000 CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index d1711e0..735c04c 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_SPARTAN3=y CONFIG_SYS_I2C_DW=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/include/configs/apf27.h b/include/configs/apf27.h index d95da27..0bd280c 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -209,7 +209,6 @@ * FPGA */ #define CONFIG_FPGA_COUNT 1 -#define CONFIG_FPGA_SPARTAN3 #define CONFIG_SYS_FPGA_WAIT 250 /* 250 ms */ #define CONFIG_SYS_FPGA_PROG_FEEDBACK #define CONFIG_SYS_FPGA_CHECK_CTRLC diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index f3a8693..70aacda 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -175,7 +175,6 @@ #define CONFIG_SYS_LONGHELP
#define CONFIG_FPGA_COUNT 1 -#define CONFIG_FPGA_SPARTAN3 #define CONFIG_SYS_FPGA_PROG_FEEDBACK #define CONFIG_SYS_FPGA_WAIT 1000
diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index bee8ddd..6cca902 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -33,7 +33,6 @@ /* * FPGA */ -#define CONFIG_FPGA_SPARTAN3 #define CONFIG_SYS_FPGA_PROG_FEEDBACK #define CONFIG_SYS_FPGA_WAIT 10000 #define CONFIG_MAX_FPGA_DEVICES 1 diff --git a/include/configs/x600.h b/include/configs/x600.h index 3f63761..9ada370 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -85,7 +85,6 @@ #define CONFIG_SYS_I2C_RTC_ADDR 0x68
/* FPGA config options */ -#define CONFIG_FPGA_SPARTAN3 #define CONFIG_FPGA_COUNT 1
/* USB EHCI options */ -- 2.7.4
This patch added Kconfig support for CONFIG_FPGA_ZYNQPL.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/fpga/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index ac08bc1..50e9019 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -50,4 +50,11 @@ config FPGA_SPARTAN3 help Enable Spartan3 FPGA driver for loading in BIT format.
+config FPGA_ZYNQPL + bool "Enable Xilinx FPGA for Zynq" + depends on ARCH_ZYNQ + help + Enable FPGA driver for loading bitstream in BIT and BIN format + on Xilinx Zynq devices. + endmenu -- 2.7.4
After merging 4/4 into this (we should always update the defconfigs in the patch, otherwise we may get build warnings later when bisecting), applied to u-boot/master, thanks!
This patch added CONFIG_FPGA_ZYNQPL in the respective defconfig.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- configs/syzygy_hub_defconfig | 1 + configs/topic_miami_defconfig | 1 + configs/topic_miamilite_defconfig | 1 + configs/topic_miamiplus_defconfig | 1 + configs/zynq_cc108_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_z_turn_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm011_x16_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + include/configs/zynq-common.h | 2 -- 18 files changed, 17 insertions(+), 2 deletions(-)
diff --git a/configs/syzygy_hub_defconfig b/configs/syzygy_hub_defconfig index 996ecdb..8f06465 100644 --- a/configs/syzygy_hub_defconfig +++ b/configs/syzygy_hub_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_EMBED=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/topic_miami_defconfig b/configs/topic_miami_defconfig index d5929a1..e8aaee9 100644 --- a/configs/topic_miami_defconfig +++ b/configs/topic_miami_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_EMBED=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/topic_miamilite_defconfig b/configs/topic_miamilite_defconfig index a318e50..3f8681f 100644 --- a/configs/topic_miamilite_defconfig +++ b/configs/topic_miamilite_defconfig @@ -30,6 +30,7 @@ CONFIG_OF_EMBED=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/topic_miamiplus_defconfig b/configs/topic_miamiplus_defconfig index 7281f7b..496c43e 100644 --- a/configs/topic_miamiplus_defconfig +++ b/configs/topic_miamiplus_defconfig @@ -28,6 +28,7 @@ CONFIG_OF_EMBED=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_cc108_defconfig b/configs/zynq_cc108_defconfig index 24e9cfe..3a4de92 100644 --- a/configs/zynq_cc108_defconfig +++ b/configs/zynq_cc108_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index b34520f..94a1a40 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 2f90918..f9ee904 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -29,6 +29,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_z_turn_defconfig b/configs/zynq_z_turn_defconfig index 68a2208..7a51b85 100644 --- a/configs/zynq_z_turn_defconfig +++ b/configs/zynq_z_turn_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 878bc79..c6a7893 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 7b2e072..665b4d3 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -39,6 +39,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index 125f97d..f4279c6 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -31,6 +31,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index de8fe3e..e0d91aa 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_CACHE=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BLK=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_NAND=y diff --git a/configs/zynq_zc770_xm011_x16_defconfig b/configs/zynq_zc770_xm011_x16_defconfig index 1e2c377..c65ac59 100644 --- a/configs/zynq_zc770_xm011_x16_defconfig +++ b/configs/zynq_zc770_xm011_x16_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_CACHE=y CONFIG_OF_EMBED=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_DM_MMC=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 09ae04b..782a359 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -34,6 +34,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BLK=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_MTD_NOR_FLASH=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 36922ff..69d875f 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -33,6 +33,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_BLK=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y # CONFIG_MMC is not set CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 4c1c18b..7ed0128 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -34,6 +34,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 138b249..2a45cee 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -38,6 +38,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y +CONFIG_FPGA_ZYNQPL=y CONFIG_DM_GPIO=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ZYNQ=y diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 2dfac6f..7f81f40 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -276,8 +276,6 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
-/* Enable the PL to be downloaded */ -#define CONFIG_FPGA_ZYNQPL
/* FIT support */ #define CONFIG_IMAGE_FORMAT_LEGACY /* enable also legacy image format */ -- 2.7.4
Applied.
Thanks, Michal
Michal Simek
Vipul Kumar
