[PATCH 0/8] tpm: Various minor fixes and enhancements
This series contains some minor enhancements for the TPM code to make it work with Chromium OS verified boot.
Simon Glass (8): tpm: Export the TPM-version functions tpm: Require a digest source when extending the PCR tpm: Correct the permissions command in TPMv1 tpm: Correct the define-space command in TPMv2 tpm: sandbox: Allow init of TPM in a different phase tpm: Allow reporting the internal state tpm: Implement state command for Cr50 tpm: Allow commiting non-volatile data
cmd/tpm-common.c | 20 ++++++ cmd/tpm-user-utils.h | 2 + cmd/tpm-v1.c | 3 +- cmd/tpm-v2.c | 3 + cmd/tpm_test.c | 5 +- drivers/tpm/cr50_i2c.c | 117 +++++++++++++++++++++++++++++++++ drivers/tpm/tpm-uclass.c | 10 +++ drivers/tpm/tpm2_tis_sandbox.c | 17 ++++- include/tpm-common.h | 20 ++++++ include/tpm-v2.h | 68 +++++++++++++++++++ include/tpm_api.h | 18 ++++- lib/tpm-v1.c | 5 +- lib/tpm-v2.c | 64 ++++++++++++++++-- lib/tpm_api.c | 102 ++++++++++++++-------------- test/dm/Makefile | 1 + test/dm/tpm.c | 34 ++++++++++ 16 files changed, 419 insertions(+), 70 deletions(-) create mode 100644 test/dm/tpm.c
These functions should really be available outside the TPM code, so that other callers can find out which version the TPM is. Rename them to have a tpm_ prefix() and add them to the header file.
include/tpm_api.h | 10 ++++++ lib/tpm_api.c | 92 +++++++++++++++++++++-------------------------- 2 files changed, 51 insertions(+), 51 deletions(-)
diff --git a/include/tpm_api.h b/include/tpm_api.h index ef45b43a8f..11aa14eb79 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -319,4 +319,14 @@ u32 tpm_write_lock(struct udevice *dev, u32 index); */ u32 tpm_resume(struct udevice *dev);
+static inline bool tpm_is_v1(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; +} + +static inline bool tpm_is_v2(struct udevice *dev) +{ + return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; +} + #endif /* __TPM_API_H */ diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 4c662640a9..4ac4612c81 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -11,21 +11,11 @@ #include <tpm-v2.h> #include <tpm_api.h>
-static bool is_tpm1(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V1) && tpm_get_version(dev) == TPM_V1; -} - -static bool is_tpm2(struct udevice *dev) -{ - return IS_ENABLED(CONFIG_TPM_V2) && tpm_get_version(dev) == TPM_V2; -} - u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode) { - if (is_tpm1(dev)) { + if (tpm_is_v1(dev)) { return tpm1_startup(dev, mode); - } else if (is_tpm2(dev)) { + } else if (tpm_is_v2(dev)) { enum tpm2_startup_types type;
switch (mode) { @@ -47,9 +37,9 @@ u32 tpm_startup(struct udevice *dev, enum tpm_startup_type mode)
u32 tpm_resume(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_startup(dev, TPM_ST_STATE); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_startup(dev, TPM2_SU_STATE); else return -ENOSYS; @@ -57,9 +47,9 @@ u32 tpm_resume(struct udevice *dev)
u32 tpm_self_test_full(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_self_test_full(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_YES); else return -ENOSYS; @@ -67,9 +57,9 @@ u32 tpm_self_test_full(struct udevice *dev)
u32 tpm_continue_self_test(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_continue_self_test(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_NO); else return -ENOSYS; @@ -86,7 +76,7 @@ u32 tpm_clear_and_reenable(struct udevice *dev) return ret; }
- if (is_tpm1(dev)) { + if (tpm_is_v1(dev)) { ret = tpm1_physical_enable(dev); if (ret != TPM_SUCCESS) { log_err("TPM: Can't set enabled state\n"); @@ -105,9 +95,9 @@ u32 tpm_clear_and_reenable(struct udevice *dev)
u32 tpm_nv_enable_locking(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_define_space(dev, TPM_NV_INDEX_LOCK, 0, 0); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS; @@ -115,9 +105,9 @@ u32 tpm_nv_enable_locking(struct udevice *dev)
u32 tpm_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_read_value(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_nv_read_value(dev, index, data, count); else return -ENOSYS; @@ -126,9 +116,9 @@ u32 tpm_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) u32 tpm_nv_write_value(struct udevice *dev, u32 index, const void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_nv_write_value(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_nv_write_value(dev, index, data, count); else return -ENOSYS; @@ -141,9 +131,9 @@ u32 tpm_set_global_lock(struct udevice *dev)
u32 tpm_write_lock(struct udevice *dev, u32 index) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return -ENOSYS; - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_write_lock(dev, index); else return -ENOSYS; @@ -152,9 +142,9 @@ u32 tpm_write_lock(struct udevice *dev, u32 index) u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest, void *out_digest) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_extend(dev, index, in_digest, out_digest); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, in_digest, TPM2_DIGEST_LEN); else @@ -163,9 +153,9 @@ u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest,
u32 tpm_pcr_read(struct udevice *dev, u32 index, void *data, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_pcr_read(dev, index, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS; @@ -173,14 +163,14 @@ u32 tpm_pcr_read(struct udevice *dev, u32 index, void *data, size_t count)
u32 tpm_tsc_physical_presence(struct udevice *dev, u16 presence) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_tsc_physical_presence(dev, presence);
/* * Nothing to do on TPM2 for this; use platform hierarchy availability * instead. */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -188,11 +178,11 @@ u32 tpm_tsc_physical_presence(struct udevice *dev, u16 presence)
u32 tpm_finalise_physical_presence(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_finalise_physical_presence(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -200,9 +190,9 @@ u32 tpm_finalise_physical_presence(struct udevice *dev)
u32 tpm_read_pubek(struct udevice *dev, void *data, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_read_pubek(dev, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS; @@ -210,9 +200,9 @@ u32 tpm_read_pubek(struct udevice *dev, void *data, size_t count)
u32 tpm_force_clear(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_force_clear(dev); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_clear(dev, TPM2_RH_PLATFORM, NULL, 0); else return -ENOSYS; @@ -220,11 +210,11 @@ u32 tpm_force_clear(struct udevice *dev)
u32 tpm_physical_enable(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_enable(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -232,11 +222,11 @@ u32 tpm_physical_enable(struct udevice *dev)
u32 tpm_physical_disable(struct udevice *dev) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_disable(dev);
/* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -244,10 +234,10 @@ u32 tpm_physical_disable(struct udevice *dev)
u32 tpm_physical_set_deactivated(struct udevice *dev, u8 state) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_physical_set_deactivated(dev, state); /* Nothing needs to be done with tpm2 */ - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return 0; else return -ENOSYS; @@ -256,9 +246,9 @@ u32 tpm_physical_set_deactivated(struct udevice *dev, u8 state) u32 tpm_get_capability(struct udevice *dev, u32 cap_area, u32 sub_cap, void *cap, size_t count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_capability(dev, cap_area, sub_cap, cap, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return tpm2_get_capability(dev, cap_area, sub_cap, cap, count); else return -ENOSYS; @@ -266,9 +256,9 @@ u32 tpm_get_capability(struct udevice *dev, u32 cap_area, u32 sub_cap,
u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_permissions(dev, index, perm); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS; @@ -276,9 +266,9 @@ u32 tpm_get_permissions(struct udevice *dev, u32 index, u32 *perm)
u32 tpm_get_random(struct udevice *dev, void *data, u32 count) { - if (is_tpm1(dev)) + if (tpm_is_v1(dev)) return tpm1_get_random(dev, data, count); - else if (is_tpm2(dev)) + else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS;
Hi Simon,
Apologies the late reply. I wasn't cc'ed on those and missed them in my mailbox.
- if (tpm_is_v1(dev)) { return tpm1_startup(dev, mode);
switch (mode) {
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_startup(dev, TPM_ST_STATE);
- else if (tpm_is_v2(dev)) return tpm2_startup(dev, TPM2_SU_STATE); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_self_test_full(dev);
- else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_YES); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_continue_self_test(dev);
- else if (tpm_is_v2(dev)) return tpm2_self_test(dev, TPMI_NO); else return -ENOSYS;
- if (tpm_is_v1(dev)) { ret = tpm1_physical_enable(dev); if (ret != TPM_SUCCESS) { log_err("TPM: Can't set enabled state\n");
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_define_space(dev, TPM_NV_INDEX_LOCK, 0, 0);
- else if (tpm_is_v2(dev)) return -ENOSYS; else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_read_value(dev, index, data, count);
- else if (tpm_is_v2(dev)) return tpm2_nv_read_value(dev, index, data, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_nv_write_value(dev, index, data, count);
- else if (tpm_is_v2(dev)) return tpm2_nv_write_value(dev, index, data, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return -ENOSYS;
- else if (tpm_is_v2(dev)) return tpm2_write_lock(dev, index); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_extend(dev, index, in_digest, out_digest);
- else if (tpm_is_v2(dev)) return tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, in_digest, TPM2_DIGEST_LEN); else
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_pcr_read(dev, index, data, count);
- if (is_tpm1(dev))
- Nothing to do on TPM2 for this; use platform hierarchy availability
- instead.
- else if (tpm_is_v2(dev)) return 0; else return -ENOSYS;
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_read_pubek(dev, data, count);
- else if (tpm_is_v2(dev)) return -ENOSYS; /* not implemented yet */ else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_force_clear(dev);
- else if (tpm_is_v2(dev)) return tpm2_clear(dev, TPM2_RH_PLATFORM, NULL, 0); else return -ENOSYS;
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_physical_set_deactivated(dev, state); /* Nothing needs to be done with tpm2 */
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_capability(dev, cap_area, sub_cap, cap, count);
- else if (tpm_is_v2(dev)) return tpm2_get_capability(dev, cap_area, sub_cap, cap, count); else return -ENOSYS;
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_permissions(dev, index, perm);
- if (is_tpm1(dev))
- if (tpm_is_v1(dev)) return tpm1_get_random(dev, data, count);
-- 2.35.1.574.g5d30c73bfb-goog
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
This feature is used for measured boot. It is not currently supported in the TPM drivers, but add it to the API so that code which expects it can signal its request.
cmd/tpm-v1.c | 3 ++- cmd/tpm_test.c | 5 +++-- include/tpm_api.h | 8 +++++--- lib/tpm-v2.c | 2 ++ lib/tpm_api.c | 14 ++++++++++---- 5 files changed, 22 insertions(+), 10 deletions(-)
diff --git a/cmd/tpm-v1.c b/cmd/tpm-v1.c index bf238a9f2e..0869b70775 100644 --- a/cmd/tpm-v1.c +++ b/cmd/tpm-v1.c @@ -131,7 +131,8 @@ static int do_tpm_extend(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_FAILURE; }
- rc = tpm_pcr_extend(dev, index, in_digest, out_digest); + rc = tpm_pcr_extend(dev, index, in_digest, sizeof(in_digest), + out_digest, "test"); if (!rc) { puts("PCR value after execution of the command:\n"); print_byte_string(out_digest, sizeof(out_digest)); diff --git a/cmd/tpm_test.c b/cmd/tpm_test.c index a3ccb12f53..b35eae81dc 100644 --- a/cmd/tpm_test.c +++ b/cmd/tpm_test.c @@ -91,7 +91,8 @@ static int test_early_extend(struct udevice *dev) tpm_init(dev); TPM_CHECK(tpm_startup(dev, TPM_ST_CLEAR)); TPM_CHECK(tpm_continue_self_test(dev)); - TPM_CHECK(tpm_pcr_extend(dev, 1, value_in, value_out)); + TPM_CHECK(tpm_pcr_extend(dev, 1, value_in, sizeof(value_in), value_out, + "test")); printf("done\n"); return 0; } @@ -438,7 +439,7 @@ static int test_timing(struct udevice *dev) 100); TTPM_CHECK(tpm_nv_read_value(dev, INDEX0, (uint8_t *)&x, sizeof(x)), 100); - TTPM_CHECK(tpm_pcr_extend(dev, 0, in, out), 200); + TTPM_CHECK(tpm_pcr_extend(dev, 0, in, sizeof(in), out, "test"), 200); TTPM_CHECK(tpm_set_global_lock(dev), 50); TTPM_CHECK(tpm_tsc_physical_presence(dev, PHYS_PRESENCE), 100); printf("done\n"); diff --git a/include/tpm_api.h b/include/tpm_api.h index 11aa14eb79..3c8e48bc25 100644 --- a/include/tpm_api.h +++ b/include/tpm_api.h @@ -81,14 +81,16 @@ u32 tpm_nv_write_value(struct udevice *dev, u32 index, const void *data, * * @param dev TPM device * @param index index of the PCR - * @param in_digest 160-bit value representing the event to be + * @param in_digest 160/256-bit value representing the event to be * recorded - * @param out_digest 160-bit PCR value after execution of the + * @param size size of digest in bytes + * @param out_digest 160/256-bit PCR value after execution of the * command + * @param name additional info about where the digest comes from * Return: return code of the operation */ u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest, - void *out_digest); + uint size, void *out_digest, const char *name);
/** * Issue a TPM_PCRRead command. diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 1bf627853a..6058f2e1e4 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -157,6 +157,8 @@ u32 tpm2_pcr_extend(struct udevice *dev, u32 index, u32 algorithm, }; int ret;
+ if (!digest) + return -EINVAL; /* * Fill the command structure starting from the first buffer: * - the digest diff --git a/lib/tpm_api.c b/lib/tpm_api.c index 4ac4612c81..a8d3731d3a 100644 --- a/lib/tpm_api.c +++ b/lib/tpm_api.c @@ -140,15 +140,21 @@ u32 tpm_write_lock(struct udevice *dev, u32 index) }
u32 tpm_pcr_extend(struct udevice *dev, u32 index, const void *in_digest, - void *out_digest) + uint size, void *out_digest, const char *name) { - if (tpm_is_v1(dev)) + if (tpm_is_v1(dev)) { + if (size != PCR_DIGEST_LENGTH || !out_digest) + return -EINVAL; return tpm1_extend(dev, index, in_digest, out_digest); - else if (tpm_is_v2(dev)) + } else if (tpm_is_v2(dev)) { + if (size != TPM2_SHA256_DIGEST_SIZE) + return -EINVAL; return tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, in_digest, TPM2_DIGEST_LEN); - else + /* @name is ignored as we do not support measured boot */ + } else { return -ENOSYS; + } }
- rc = tpm_pcr_extend(dev, index, in_digest, sizeof(in_digest),
Where is the output value of an extended PCR needed in measured boot? IMHO this out_digest seems pointless. I'd be happier if we just completely removed it and make the v2 variant look like v1 more.
- TPM_CHECK(tpm_pcr_extend(dev, 1, value_in, sizeof(value_in), value_out,
printf("done\n"); return 0;"test"));
- TTPM_CHECK(tpm_pcr_extend(dev, 0, in, sizeof(in), out, "test"), 200); TTPM_CHECK(tpm_set_global_lock(dev), 50); TTPM_CHECK(tpm_tsc_physical_presence(dev, PHYS_PRESENCE), 100); printf("done\n");
- @param dev TPM device
- @param index index of the PCR
- @param in_digest 160-bit value representing the event to be
- @param in_digest 160/256-bit value representing the event to be
recorded
- @param out_digest 160-bit PCR value after execution of the
- @param size size of digest in bytes
- @param out_digest 160/256-bit PCR value after execution of the
command
- @param name additional info about where the digest comes from
- Return: return code of the operation
void *out_digest);
- Issue a TPM_PCRRead command.
- if (!digest)
/*return -EINVAL;
- Fill the command structure starting from the first buffer:
- the digest
void *out_digest)
return tpm1_extend(dev, index, in_digest, out_digest);return -EINVAL;
- } else if (tpm_is_v2(dev)) {
return -EINVAL;
Why are we limiting this? This is supposed to be dictated by the PCR bank configuration of each hardware
- else
- } else { return -ENOSYS;
Thanks /Ilias
Hi Ilias,
On Tue, 7 Jun 2022 at 02:42, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
(long pause as I forgot about this and only just discovered it was not applied)
It is used by the tpm command to display the digest value.
recorded
command
void *out_digest);
if (!digest)
void *out_digest)
if (tpm_is_v1(dev))
return -EINVAL;
OK I can drop this. Normally we use SHA256 for TPMv2 and I'm not sure we suppose anything else. But we don't have to....
else
The offset here is incorrect. Fix it.
lib/tpm-v1.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/lib/tpm-v1.c b/lib/tpm-v1.c index 22a769c587..d0e3ab1b21 100644 --- a/lib/tpm-v1.c +++ b/lib/tpm-v1.c @@ -456,12 +456,13 @@ u32 tpm1_get_permissions(struct udevice *dev, u32 index, u32 *perm) 0x0, 0x0, 0x0, 0x4, }; const size_t index_offset = 18; - const size_t perm_offset = 60; + const size_t perm_offset = 74; u8 buf[COMMAND_BUFFER_SIZE], response[COMMAND_BUFFER_SIZE]; size_t response_length = sizeof(response); u32 err;
- if (pack_byte_string(buf, sizeof(buf), "d", 0, command, sizeof(command), + if (pack_byte_string(buf, sizeof(buf), "sd", + 0, command, sizeof(command), index_offset, index)) return TPM_LIB_ERROR; err = tpm_sendrecv_command(dev, buf, response, &response_length);
Hi Simon,
- const size_t perm_offset = 74;
This is fine, but I hate all these magic values sprinkled around the TPM APIs. Starting with this patch can we do the right thing and at lease have those in a #define with a names that makes some sense?
- if (pack_byte_string(buf, sizeof(buf), "sd",
return TPM_LIB_ERROR; err = tpm_sendrecv_command(dev, buf, response, &response_length);0, command, sizeof(command), index_offset, index))
Thanks /Ilias
Hi Ilias,
On Tue, 7 Jun 2022 at 02:44, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
Er, isn't this what I am doing? See the const values which have sensible names. It really doesn't make sense to put them in a #define in a distant header file since we don't use these in most commands. There are just local to the function and determined by the format used with pack_byte_string(), etc. (see below).
Thanks /Ilias
Regards, SImon
The message format is incorrect. Fix it.
lib/tpm-v2.c | 18 +++++++++++------- 1 file changed, 11 insertions(+), 7 deletions(-)
diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 6058f2e1e4..fe99b9c863 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -89,14 +89,14 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, * Calculate the offset of the nv_policy piece by adding each of the * chunks below. */ - uint offset = 10 + 8 + 13 + 14; + uint offset = 10 + 4 + 13 + 14; u8 command_v2[COMMAND_BUFFER_SIZE] = { /* header 10 bytes */ tpm_u16(TPM2_ST_SESSIONS), /* TAG */ - tpm_u32(offset + nv_policy_size),/* Length */ + tpm_u32(offset + nv_policy_size + 2),/* Length */ tpm_u32(TPM2_CC_NV_DEFINE_SPACE),/* Command code */
- /* handles 8 bytes */ + /* handles 4 bytes */ tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */
/* session header 13 bytes */ @@ -107,12 +107,15 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, tpm_u16(0), /* auth_size */
/* message 14 bytes + policy */ - tpm_u16(12 + nv_policy_size), /* size */ + tpm_u16(12 + nv_policy_size + 2), /* size */ tpm_u32(space_index), tpm_u16(TPM2_ALG_SHA256), tpm_u32(nv_attributes), tpm_u16(nv_policy_size), - /* nv_policy */ + /* + * nv_policy + * space_size + */ }; int ret;
@@ -120,8 +123,9 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, * Fill the command structure starting from the first buffer: * - the password (if any) */ - ret = pack_byte_string(command_v2, sizeof(command_v2), "s", - offset, nv_policy, nv_policy_size); + ret = pack_byte_string(command_v2, sizeof(command_v2), "sw", + offset, nv_policy, nv_policy_size, + offset + nv_policy_size, space_size); if (ret) return TPM_LIB_ERROR;
Hi Simon,
Thanks for fixing this. On Mon, Feb 28, 2022 at 05:11:21PM -0700, Simon Glass wrote:
- uint offset = 10 + 4 + 13 + 14; u8 command_v2[COMMAND_BUFFER_SIZE] = { /* header 10 bytes */ tpm_u16(TPM2_ST_SESSIONS), /* TAG */
tpm_u32(TPM2_CC_NV_DEFINE_SPACE),/* Command code */tpm_u32(offset + nv_policy_size + 2),/* Length */
tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed *//* handles 4 bytes */
Similar to my comment on the previous patches, please send a version with defines that gets rid of the magic numbers (offset, +2 on nv_policy_size etc)
tpm_u32(space_index), tpm_u16(TPM2_ALG_SHA256), tpm_u32(nv_attributes), tpm_u16(nv_policy_size),tpm_u16(12 + nv_policy_size + 2), /* size */
/* nv_policy */
* nv_policy
* space_size
}; int ret;*/
- ret = pack_byte_string(command_v2, sizeof(command_v2), "sw",
if (ret) return TPM_LIB_ERROR;offset + nv_policy_size, space_size);
Cheers /Ilias
Hi Ilias,
On Tue, 7 Jun 2022 at 02:46, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Simon,
OK I have fixed these, with const int.
/* nv_policy */
* nv_policy
* space_size
*/ }; int ret;
Cheers /Ilias
At present the emulator assumes that the TPM is inited in the same phase where it is used. But in fact SPL may init the TPM, so we don't want to complain when U-Boot proper later uses it. Remove this check.
It might be best to save this information into the device state for the TPM, so that we can make sure the TPM was inited at some point. For now, this seems good enough.
drivers/tpm/tpm2_tis_sandbox.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/tpm/tpm2_tis_sandbox.c b/drivers/tpm/tpm2_tis_sandbox.c index ac6eb14353..c26f5d35ab 100644 --- a/drivers/tpm/tpm2_tis_sandbox.c +++ b/drivers/tpm/tpm2_tis_sandbox.c @@ -366,8 +366,10 @@ static int sandbox_tpm2_check_readyness(struct udevice *dev, int command)
break; default: - if (!tpm->tests_done) - return TPM2_RC_NEEDS_TEST; + /* Skip this, since the startup may have happened in SPL + * if (!tpm->tests_done) + * return TPM2_RC_NEEDS_TEST; + */
break; }
Hi Simon,
break;
default:
This looks reasonable. On top of that the TPM will return 'already initialized' if someone tries to do that after SPL, so we should be safe.
break;
It is useful to read information about the current TPM state, where supported, e.g. for debugging purposes when verified boot fails.
Add support for this to the TPM interface as well as Cr50. Add a simple sandbox test.
cmd/tpm-common.c | 20 ++++++++++++++++++++ cmd/tpm-user-utils.h | 2 ++ cmd/tpm-v2.c | 3 +++ drivers/tpm/tpm-uclass.c | 10 ++++++++++ drivers/tpm/tpm2_tis_sandbox.c | 11 +++++++++++ include/tpm-common.h | 20 ++++++++++++++++++++ test/dm/Makefile | 1 + test/dm/tpm.c | 34 ++++++++++++++++++++++++++++++++++ 8 files changed, 101 insertions(+) create mode 100644 test/dm/tpm.c
diff --git a/cmd/tpm-common.c b/cmd/tpm-common.c index 47adaffd18..d0c63cadf4 100644 --- a/cmd/tpm-common.c +++ b/cmd/tpm-common.c @@ -333,6 +333,26 @@ int do_tpm_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return 0; }
+int do_tpm_report_state(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]) +{ + struct udevice *dev; + char buf[80]; + int rc; + + rc = get_tpm(&dev); + if (rc) + return rc; + rc = tpm_report_state(dev, buf, sizeof(buf)); + if (rc < 0) { + printf("Couldn't get TPM state (%d)\n", rc); + return CMD_RET_FAILURE; + } + printf("%s\n", buf); + + return 0; +} + int do_tpm_init(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { struct udevice *dev; diff --git a/cmd/tpm-user-utils.h b/cmd/tpm-user-utils.h index 358ddff576..de4a934aab 100644 --- a/cmd/tpm-user-utils.h +++ b/cmd/tpm-user-utils.h @@ -21,6 +21,8 @@ int do_tpm_device(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_tpm_init(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); int do_tpm_info(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]); +int do_tpm_report_state(struct cmd_tbl *cmdtp, int flag, int argc, + char *const argv[]); int do_tpm(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]);
#endif /* __TPM_USER_UTILS_H */ diff --git a/cmd/tpm-v2.c b/cmd/tpm-v2.c index 4ea5f9f094..d93b83ada9 100644 --- a/cmd/tpm-v2.c +++ b/cmd/tpm-v2.c @@ -359,6 +359,7 @@ static int do_tpm_pcr_setauthvalue(struct cmd_tbl *cmdtp, int flag, static struct cmd_tbl tpm2_commands[] = { U_BOOT_CMD_MKENT(device, 0, 1, do_tpm_device, "", ""), U_BOOT_CMD_MKENT(info, 0, 1, do_tpm_info, "", ""), + U_BOOT_CMD_MKENT(state, 0, 1, do_tpm_report_state, "", ""), U_BOOT_CMD_MKENT(init, 0, 1, do_tpm_init, "", ""), U_BOOT_CMD_MKENT(startup, 0, 1, do_tpm2_startup, "", ""), U_BOOT_CMD_MKENT(self_test, 0, 1, do_tpm2_self_test, "", ""), @@ -389,6 +390,8 @@ U_BOOT_CMD(tpm2, CONFIG_SYS_MAXARGS, 1, do_tpm, "Issue a TPMv2.x command", " Show all devices or set the specified device\n" "info\n" " Show information about the TPM.\n" +"state\n" +" Show internal state from the TPM (if available)\n" "init\n" " Initialize the software stack. Always the first command to issue.\n" "startup <mode>\n" diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index f67fe1019b..5db3676216 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -45,6 +45,16 @@ int tpm_get_desc(struct udevice *dev, char *buf, int size) return ops->get_desc(dev, buf, size); }
+int tpm_report_state(struct udevice *dev, char *buf, int size) +{ + struct tpm_ops *ops = tpm_get_ops(dev); + + if (!ops->report_state) + return -ENOSYS; + + return ops->report_state(dev, buf, size); +} + /* Returns max number of milliseconds to wait */ static ulong tpm_tis_i2c_calc_ordinal_duration(struct tpm_chip_priv *priv, u32 ordinal) diff --git a/drivers/tpm/tpm2_tis_sandbox.c b/drivers/tpm/tpm2_tis_sandbox.c index c26f5d35ab..dd94bdc31f 100644 --- a/drivers/tpm/tpm2_tis_sandbox.c +++ b/drivers/tpm/tpm2_tis_sandbox.c @@ -795,6 +795,16 @@ static int sandbox_tpm2_get_desc(struct udevice *dev, char *buf, int size) return snprintf(buf, size, "Sandbox TPM2.x"); }
+static int sandbox_tpm2_report_state(struct udevice *dev, char *buf, int size) +{ + struct sandbox_tpm2 *priv = dev_get_priv(dev); + + if (size < 40) + return -ENOSPC; + + return snprintf(buf, size, "init_done=%d", priv->init_done); +} + static int sandbox_tpm2_open(struct udevice *dev) { struct sandbox_tpm2 *tpm = dev_get_priv(dev); @@ -834,6 +844,7 @@ static const struct tpm_ops sandbox_tpm2_ops = { .open = sandbox_tpm2_open, .close = sandbox_tpm2_close, .get_desc = sandbox_tpm2_get_desc, + .report_state = sandbox_tpm2_report_state, .xfer = sandbox_tpm2_xfer, };
diff --git a/include/tpm-common.h b/include/tpm-common.h index a28629e701..b2c5404430 100644 --- a/include/tpm-common.h +++ b/include/tpm-common.h @@ -119,6 +119,16 @@ struct tpm_ops { */ int (*get_desc)(struct udevice *dev, char *buf, int size);
+ /** + * report_state() - Collect information about the current TPM state + * + * @dev: Device to check + * @buf: Buffer to put the string + * @size: Maximum size of buffer + * Return: return code of the operation (0 = success) + */ + int (*report_state)(struct udevice *dev, char *buf, int size); + /** * send() - send data to the TPM * @@ -234,6 +244,16 @@ u32 tpm_clear_and_reenable(struct udevice *dev); */ int tpm_get_desc(struct udevice *dev, char *buf, int size);
+/** + * tpm_report_state() - Collect information about the current TPM state + * + * @dev: Device to check + * @buf: Buffer to put the string + * @size: Maximum size of buffer + * Return: return code of the operation (0 = success) + */ +int tpm_report_state(struct udevice *dev, char *buf, int size); + /** * tpm_xfer() - send data to the TPM and get response * diff --git a/test/dm/Makefile b/test/dm/Makefile index d46552fbf3..47363bdb15 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -104,6 +104,7 @@ obj-$(CONFIG_SYSINFO) += sysinfo.o obj-$(CONFIG_SYSINFO_GPIO) += sysinfo-gpio.o obj-$(CONFIG_TEE) += tee.o obj-$(CONFIG_TIMER) += timer.o +obj-$(CONFIG_TPM_V2) += tpm.o obj-$(CONFIG_DM_USB) += usb.o obj-$(CONFIG_DM_VIDEO) += video.o obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o diff --git a/test/dm/tpm.c b/test/dm/tpm.c new file mode 100644 index 0000000000..0b46f79959 --- /dev/null +++ b/test/dm/tpm.c @@ -0,0 +1,34 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#include <common.h> +#include <dm.h> +#include <tpm_api.h> +#include <dm/test.h> +#include <test/test.h> +#include <test/ut.h> + +/* Basic test of the TPM uclass */ +static int dm_test_tpm(struct unit_test_state *uts) +{ + struct udevice *dev; + char buf[50]; + + /* check probe success */ + ut_assertok(uclass_first_device_err(UCLASS_TPM, &dev)); + ut_assert(tpm_is_v2(dev)); + + ut_assert(tpm_report_state(dev, buf, sizeof(buf))); + ut_asserteq_str("init_done=0", buf); + + ut_assertok(tpm_init(dev)); + + ut_assert(tpm_report_state(dev, buf, sizeof(buf))); + ut_asserteq_str("init_done=1", buf); + + return 0; +} +DM_TEST(dm_test_tpm, UT_TESTF_SCAN_FDT);
Add a vendor-specific TPM2 command for this and implement it for Cr50.
drivers/tpm/cr50_i2c.c | 117 +++++++++++++++++++++++++++++++++++++++++ include/tpm-v2.h | 54 +++++++++++++++++++ lib/tpm-v2.c | 24 +++++++++ 3 files changed, 195 insertions(+)
diff --git a/drivers/tpm/cr50_i2c.c b/drivers/tpm/cr50_i2c.c index f8c3087894..dabf617be0 100644 --- a/drivers/tpm/cr50_i2c.c +++ b/drivers/tpm/cr50_i2c.c @@ -13,11 +13,13 @@ #include <irq.h> #include <log.h> #include <spl.h> +#include <tpm-common.h> #include <tpm-v2.h> #include <acpi/acpigen.h> #include <acpi/acpi_device.h> #include <asm/gpio.h> #include <asm/io.h> +#include <asm/unaligned.h> #include <linux/delay.h> #include <dm/acpi.h>
@@ -54,6 +56,41 @@ struct cr50_priv { bool use_irq; };
+/* + * The below structure represents the body of the response to the 'report tpm + * state' vendor command. + * + * It is transferred over the wire, so it needs to be serialized/deserialized, + * and it is likely to change, so its contents must be versioned. + */ +#define TPM_STATE_VERSION 1 +struct tpm_vendor_state { + u32 version; + /* + * The following three fields are set by the TPM in case of an assert. + * There is no other processing than setting the source code line + * number, error code and the first 4 characters of the function name. + * + * We don't expect this happening, but it is included in the report + * just in case. + */ + u32 fail_line; /* s_failLIne */ + u32 fail_code; /* s_failCode */ + char func_name[4]; /* s_failFunction, limited to 4 chars */ + + /* + * The following two fields are the current time filtered value of the + * 'failed tries' TPM counter, and the maximum allowed value of the + * counter. + * + * failed_tries == max_tries is the definition of the TPM lockout + * condition. + */ + u32 failed_tries; /* gp.failedTries */ + u32 max_tries; /* gp.maxTries */ + /* The below fields are present in version 2 and above */ +}; + /* Wait for interrupt to indicate TPM is ready */ static int cr50_i2c_wait_tpm_ready(struct udevice *dev) { @@ -573,6 +610,85 @@ static int cr50_i2c_get_desc(struct udevice *dev, char *buf, int size) return len; }
+static int stringify_state(char *buf, int len, char *str, size_t max_size) +{ + struct tpm_vendor_state state; + size_t text_size = 0; + + state.version = get_unaligned_be32(buf + + offsetof(struct tpm_vendor_state, version)); + state.fail_line = get_unaligned_be32(buf + + offsetof(struct tpm_vendor_state, fail_line)); + state.fail_code = get_unaligned_be32(buf + + offsetof(struct tpm_vendor_state, fail_code)); + memcpy(state.func_name, + buf + offsetof(struct tpm_vendor_state, func_name), + sizeof(state.func_name)); + state.failed_tries = get_unaligned_be32(buf + + offsetof(struct tpm_vendor_state, failed_tries)); + state.max_tries = get_unaligned_be32(buf + + offsetof(struct tpm_vendor_state, max_tries)); + + text_size += snprintf(str + text_size, max_size - text_size, + "v=%d", state.version); + if (text_size >= max_size) + return -ENOSPC; + + if (state.version > TPM_STATE_VERSION) + text_size += snprintf(str + text_size, + max_size - text_size, + " not fully supported\n"); + if (text_size >= max_size) + return -ENOSPC; + + if (state.version == 0) + return -EINVAL; /* This should never happen */ + + text_size += snprintf(str + text_size, + max_size - text_size, + " failed_tries=%d max_tries=%d\n", + state.failed_tries, state.max_tries); + if (text_size >= max_size) + return -ENOSPC; + + if (state.fail_line) { + /* make sure function name is zero terminated. */ + char func_name[sizeof(state.func_name) + 1]; + + memcpy(func_name, state.func_name, sizeof(state.func_name)); + func_name[sizeof(state.func_name)] = '\0'; + + text_size += snprintf(str + text_size, + max_size - text_size, + "tpm failed: f %s line %d code %d", + func_name, + state.fail_line, + state.fail_code); + if (text_size >= max_size) + return -ENOSPC; + } + + return 0; +} + +static int cr50_i2c_report_state(struct udevice *dev, char *str, int str_max) +{ + char buf[50]; + int buf_size = sizeof(buf); + int ret; + + ret = tpm2_cr50_report_state(dev, buf, &buf_size); + if (ret) + return ret; + + /* TPM responded as expected */ + ret = stringify_state(buf, buf_size, str, str_max); + if (ret) + return ret; + + return 0; +} + static int cr50_i2c_open(struct udevice *dev) { char buf[80]; @@ -730,6 +846,7 @@ struct acpi_ops cr50_acpi_ops = { static const struct tpm_ops cr50_i2c_ops = { .open = cr50_i2c_open, .get_desc = cr50_i2c_get_desc, + .report_state = cr50_i2c_report_state, .send = cr50_i2c_send, .recv = cr50_i2c_recv, .cleanup = cr50_i2c_cleanup, diff --git a/include/tpm-v2.h b/include/tpm-v2.h index e79c90b939..8e90a61622 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -419,6 +419,50 @@ enum { HR_NV_INDEX = TPM_HT_NV_INDEX << HR_SHIFT, };
+/* + * Operations specific to the Cr50 TPM used on Chromium OS and Android devices + * + * FIXME: below is not enough to differentiate between vendors commands + * of numerous devices. However, the current tpm2 APIs aren't very amenable + * to extending generically because the marshaling code is assuming all + * knowledge of all commands. + */ +#define TPM2_CC_VENDOR_BIT_MASK 0x20000000 + +#define TPM2_CR50_VENDOR_COMMAND (TPM2_CC_VENDOR_BIT_MASK | 0) +#define TPM2_CR50_SUB_CMD_IMMEDIATE_RESET 19 +#define TPM2_CR50_SUB_CMD_NVMEM_ENABLE_COMMITS 21 +#define TPM2_CR50_SUB_CMD_REPORT_TPM_STATE 23 +#define TPM2_CR50_SUB_CMD_TURN_UPDATE_ON 24 +#define TPM2_CR50_SUB_CMD_GET_REC_BTN 29 +#define TPM2_CR50_SUB_CMD_TPM_MODE 40 +#define TPM2_CR50_SUB_CMD_GET_BOOT_MODE 52 +#define TPM2_CR50_SUB_CMD_RESET_EC 53 + +/* Cr50 vendor-specific error codes. */ +#define VENDOR_RC_ERR 0x00000500 +enum cr50_vendor_rc { + VENDOR_RC_INTERNAL_ERROR = (VENDOR_RC_ERR | 6), + VENDOR_RC_NO_SUCH_SUBCOMMAND = (VENDOR_RC_ERR | 8), + VENDOR_RC_NO_SUCH_COMMAND = (VENDOR_RC_ERR | 127), +}; + +enum cr50_tpm_mode { + /* + * Default state: TPM is enabled, and may be set to either + * TPM_MODE_ENABLED or TPM_MODE_DISABLED. + */ + TPM_MODE_ENABLED_TENTATIVE = 0, + + /* TPM is enabled, and mode may not be changed. */ + TPM_MODE_ENABLED = 1, + + /* TPM is disabled, and mode may not be changed. */ + TPM_MODE_DISABLED = 2, + + TPM_MODE_INVALID, +}; + /** * Issue a TPM2_Startup command. * @@ -658,4 +702,14 @@ u32 tpm2_disable_platform_hierarchy(struct udevice *dev); u32 tpm2_submit_command(struct udevice *dev, const u8 *sendbuf, u8 *recvbuf, size_t *recv_size);
+/** + * tpm_cr50_report_state() - Report the Cr50 internal state + * + * @dev: TPM device + * @recvbuf: Buffer to save the response to + * @recv_size: Pointer to the size of the response buffer + * Return: result of the operation + */ +u32 tpm2_cr50_report_state(struct udevice *dev, u8 *recvbuf, size_t *recv_size); + #endif /* __TPM_V2_H */ diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index fe99b9c863..bdf019b0f9 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -675,3 +675,27 @@ u32 tpm2_submit_command(struct udevice *dev, const u8 *sendbuf, { return tpm_sendrecv_command(dev, sendbuf, recvbuf, recv_size); } + +u32 tpm2_cr50_report_state(struct udevice *dev, u8 *recvbuf, size_t *recv_size) +{ + u8 command_v2[COMMAND_BUFFER_SIZE] = { + /* header 10 bytes */ + tpm_u16(TPM2_ST_NO_SESSIONS), /* TAG */ + tpm_u32(10 + 2), /* Length */ + tpm_u32(TPM2_CR50_VENDOR_COMMAND), /* Command code */ + + tpm_u16(TPM2_CR50_SUB_CMD_REPORT_TPM_STATE), + }; + int ret; + + ret = tpm_sendrecv_command(dev, command_v2, recvbuf, recv_size); + log_debug("ret=%s, %x\n", dev->name, ret); + if (ret) + return ret; + if (*recv_size < 12) + return -ENODATA; + *recv_size -= 12; + memcpy(recvbuf, recvbuf + 12, *recv_size); + + return 0; +}
- The below structure represents the body of the response to the 'report tpm
- state' vendor command.
- It is transferred over the wire, so it needs to be serialized/deserialized,
- and it is likely to change, so its contents must be versioned.
- u32 version;
* just in case.
- u32 fail_line; /* s_failLIne */
- u32 fail_code; /* s_failCode */
- char func_name[4]; /* s_failFunction, limited to 4 chars */
* counter.
* condition.
- u32 failed_tries; /* gp.failedTries */
- u32 max_tries; /* gp.maxTries */
- /* The below fields are present in version 2 and above */
- struct tpm_vendor_state state;
- size_t text_size = 0;
- state.version = get_unaligned_be32(buf +
- state.fail_line = get_unaligned_be32(buf +
- state.fail_code = get_unaligned_be32(buf +
- memcpy(state.func_name,
- state.failed_tries = get_unaligned_be32(buf +
- state.max_tries = get_unaligned_be32(buf +
- text_size += snprintf(str + text_size, max_size - text_size,
- if (text_size >= max_size)
return -ENOSPC;
- if (state.version > TPM_STATE_VERSION)
return -ENOSPC;
- if (state.version == 0)
return -ENOSPC;
- if (state.fail_line) {
func_name,
state.fail_line,
state.fail_code);
return -ENOSPC;
Is this error state described in the TCG TIS specs ? If so we should plug this into the generic TPM API and the driver should only define cr50_i2c_report_state() etc
- char buf[50];
- int buf_size = sizeof(buf);
- int ret;
- ret = tpm2_cr50_report_state(dev, buf, &buf_size);
- if (ret)
return ret;
- /* TPM responded as expected */
- ret = stringify_state(buf, buf_size, str, str_max);
- if (ret)
return ret;
Thanks /Ilias
Hi Ilias,
On Tue, 7 Jun 2022 at 02:54, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
u32 version;
* just in case.
* counter.
* condition.
return -ENOSPC;
return -ENOSPC;
return -ENOSPC;
func_name,
state.fail_line,
state.fail_code);
return -ENOSPC;
No, this is not in the spec. It is one of the many extensions supported by Cr50.
char buf[50];
int ret;
if (ret)
return ret;
if (ret)
return ret;
Thanks /Ilias
Add an option to tell the TPM to commit non-volatile data immediately it is changed, rather than waiting until later. This is needed in some situations, since if the device reboots it may not write the data.
Add definitions for the rest of the Cr50 commands while we are here.
include/tpm-v2.h | 14 ++++++++++++++ lib/tpm-v2.c | 20 ++++++++++++++++++++ 2 files changed, 34 insertions(+)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 8e90a61622..0a03994740 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -712,4 +712,18 @@ u32 tpm2_submit_command(struct udevice *dev, const u8 *sendbuf, */ u32 tpm2_cr50_report_state(struct udevice *dev, u8 *recvbuf, size_t *recv_size);
+/* + * tpm2_cr50_enable_nvcommits() - Tell Cr50 to commit NV data immediately + * + * For Chromium OS verified boot, we may reboot or reset at different times, + * possibly leaving non-volatile data unwritten by the TPM. + * + * This vendor command is used to indicate that non-volatile data should be + * written to its store immediately. + * + * @dev TPM device + * Return: result of the operation + */ +u32 tpm2_cr50_enable_nvcommits(struct udevice *dev); + #endif /* __TPM_V2_H */ diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index bdf019b0f9..5fcd3649b7 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -699,3 +699,23 @@ u32 tpm2_cr50_report_state(struct udevice *dev, u8 *recvbuf, size_t *recv_size)
return 0; } + +u32 tpm2_cr50_enable_nvcommits(struct udevice *dev) +{ + u8 command_v2[COMMAND_BUFFER_SIZE] = { + /* header 10 bytes */ + tpm_u16(TPM2_ST_NO_SESSIONS), /* TAG */ + tpm_u32(10 + 2), /* Length */ + tpm_u32(TPM2_CR50_VENDOR_COMMAND), /* Command code */ + + tpm_u16(TPM2_CR50_SUB_CMD_NVMEM_ENABLE_COMMITS), + }; + int ret; + + ret = tpm_sendrecv_command(dev, command_v2, NULL, NULL); + log_debug("ret=%s, %x\n", dev->name, ret); + if (ret) + return ret; + + return 0; +}
Ilias Apalodimas
