[U-Boot] [PATCH] board: ti: am57xx: enable input on mmc clock
As per the latest pinmux data available for AM572x EVM, rev A3, input should be enabled on MMC clock lines for MMC2/2/3 for stable operation.
Further, AM572x TRM, SPRUHZ6, Revised June 2016, in section 18.4.6.1.1 "Pad Configuration Registers" states that input should be enabled for MMC 2/3/4 clock lines.
Enable input on MMC1 and MMC3 clock to match the latest pinmux data. Input is already enabled on MMC2 clock for BeagleBoard x15. Further, input is already enabled on all MMCx clocks for other AM57xx boards (AM572x and AM571x IDK).
Tested with HS and UHS SD card on AM572x EVM Rev A3.
Signed-off-by: Sekhar Nori nsekhar@ti.com --- board/ti/am57xx/mux_data.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index 2f5243ee7ad9..42150b0401cf 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -212,7 +212,7 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {MCASP5_FSX, (M3 | PIN_OUTPUT_PULLDOWN)}, /* mcasp5_fsx.uart9_txd */ {MCASP5_AXR0, (M3 | PIN_INPUT_PULLDOWN)}, /* mcasp5_axr0.uart9_ctsn */ {MCASP5_AXR1, (M3 | PIN_OUTPUT_PULLUP)}, /* mcasp5_axr1.uart9_rtsn */ - {MMC1_CLK, (M0 | PIN_OUTPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ @@ -221,7 +221,7 @@ const struct pad_conf_entry core_padconf_array_essential_x15[] = { {MMC1_SDCD, (M14 | PIN_INPUT_PULLUP)}, /* mmc1_sdcd.gpio6_27 */ {GPIO6_10, (M10 | PIN_OUTPUT_PULLDOWN)}, /* gpio6_10.ehrpwm2A */ {GPIO6_11, (M0 | PIN_INPUT_PULLUP)}, /* gpio6_11.gpio6_11 */ - {MMC3_CLK, (M0 | PIN_OUTPUT_PULLUP | MANUAL_MODE)}, /* mmc3_clk.mmc3_clk */ + {MMC3_CLK, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_clk.mmc3_clk */ {MMC3_CMD, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_cmd.mmc3_cmd */ {MMC3_DAT0, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat0.mmc3_dat0 */ {MMC3_DAT1, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* mmc3_dat1.mmc3_dat1 */
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Sekhar Nori nsekhar@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Lokesh Vutla
Sekhar Nori
