[U-Boot] [PATCH 1/3] serial: sh: Add support R8A7790
This adds the preset value to register, and setup of baudrate.
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- drivers/serial/serial_sh.c | 1 + drivers/serial/serial_sh.h | 13 +++++++++++++ 2 files changed, 14 insertions(+)
diff --git a/drivers/serial/serial_sh.c b/drivers/serial/serial_sh.c index 67cc0dc..0826d59 100644 --- a/drivers/serial/serial_sh.c +++ b/drivers/serial/serial_sh.c @@ -1,5 +1,6 @@ /* * SuperH SCIF device driver. + * Copyright (C) 2013 Renesas Electronics Corporation * Copyright (C) 2007,2008,2010 Nobuhiro Iwamatsu * Copyright (C) 2002 - 2008 Paul Mundt * diff --git a/drivers/serial/serial_sh.h b/drivers/serial/serial_sh.h index 7e38a3f..a6558af 100644 --- a/drivers/serial/serial_sh.h +++ b/drivers/serial/serial_sh.h @@ -224,6 +224,9 @@ struct uart_port { # define SCSPTR3 0xffc60020 /* 16 bit SCIF */ # define SCIF_ORER 0x0001 /* Overrun error bit */ # define SCSCR_INIT(port) 0x38 /* TIE=0,RIE=0,TE=1,RE=1,REIE=1 */ +#elif defined(CONFIG_R8A7790) +# define SCIF_ORER 0x0001 +# define SCSCR_INIT(port) 0x32 /* TIE=0,RIE=0,TE=1,RE=1,REIE=0, */ #else # error CPU subtype not defined #endif @@ -298,6 +301,9 @@ struct uart_port { /* SH7763 SCIF2 support */ # define SCIF2_RFDC_MASK 0x001f # define SCIF2_TXROOM_MAX 16 +#elif defined(CONFIG_R8A7790) +# define SCIF_ERRORS (SCIF_PER | SCIF_FER | SCIF_ER | SCIF_BRK) +# define SCIF_RFDC_MASK 0x003f #else # define SCIF_ERRORS (SCIF_PER | SCIF_FER | SCIF_ER | SCIF_BRK) # define SCIF_RFDC_MASK 0x001f @@ -579,6 +585,10 @@ SCIF_FNS(SCSPTR, 0, 0, 0, 0) #else SCIF_FNS(SCSPTR, 0, 0, 0x20, 16) #endif +#if defined(CONFIG_R8A7790) +SCIF_FNS(DL, 0, 0, 0x30, 16) +SCIF_FNS(CKS, 0, 0, 0x34, 16) +#endif SCIF_FNS(SCLSR, 0, 0, 0x24, 16) #endif #endif @@ -720,6 +730,9 @@ static inline int scbrr_calc(struct uart_port port, int bps, int clk) #define SCBRR_VALUE(bps, clk) scbrr_calc(sh_sci, bps, clk) #elif defined(__H8300H__) || defined(__H8300S__) #define SCBRR_VALUE(bps, clk) (((clk*1000/32)/bps)-1) +#elif defined(CONFIG_R8A7790) +#define SCBRR DL +#define SCBRR_VALUE(bps, clk) (clk / bps / 16) #else /* Generic SH */ #define SCBRR_VALUE(bps, clk) ((clk+16*bps)/(32*bps)-1) #endif
Renesas R8A7790 is CPU with Cortex-A7 and A15. This supports the basic register definition and GPIO and framework of PFC.
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Ryo Kataoka ryo.kataoka.wt@renesas.com Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/cpu/armv7/rmobile/Makefile | 7 +- arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c | 22 + arch/arm/cpu/armv7/rmobile/cpu_info.c | 5 + arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S | 60 + arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c | 3231 ++++++++++++++++++++++ arch/arm/include/asm/arch-rmobile/gpio.h | 3 + arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h | 387 +++ arch/arm/include/asm/arch-rmobile/r8a7790.h | 598 ++++ arch/arm/include/asm/arch-rmobile/rmobile.h | 2 + 9 files changed, 4314 insertions(+), 1 deletion(-) create mode 100644 arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c create mode 100644 arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S create mode 100644 arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c create mode 100644 arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h create mode 100644 arch/arm/include/asm/arch-rmobile/r8a7790.h
diff --git a/arch/arm/cpu/armv7/rmobile/Makefile b/arch/arm/cpu/armv7/rmobile/Makefile index 3168e97..50bfc39 100644 --- a/arch/arm/cpu/armv7/rmobile/Makefile +++ b/arch/arm/cpu/armv7/rmobile/Makefile @@ -9,12 +9,17 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(SOC).o
-SOBJS = lowlevel_init.o COBJS-y += cpu_info.o COBJS-y += emac.o
+SOBJS-$(CONFIG_R8A7740) += lowlevel_init.o +SOBJS-$(CONFIG_SH73A0) += lowlevel_init.o +SOBJS-$(CONFIG_R8A7790) += lowlevel_init_ca15.o +SOBJS = $(SOBJS-y) + COBJS-$(CONFIG_DISPLAY_BOARDINFO) += board.o COBJS-$(CONFIG_GLOBAL_TIMER) += timer.o +COBJS-$(CONFIG_R8A7790) += cpu_info-r8a7790.o pfc-r8a7790.o COBJS-$(CONFIG_R8A7740) += cpu_info-r8a7740.o COBJS-$(CONFIG_R8A7740) += pfc-r8a7740.o COBJS-$(CONFIG_SH73A0) += cpu_info-sh73a0.o diff --git a/arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c b/arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c new file mode 100644 index 0000000..7232e23 --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c @@ -0,0 +1,22 @@ +/* + * arch/arm/cpu/armv7/rmobile/cpu_info-r8a7790.c + * This file is r8a7790 processor support. + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ +#include <common.h> +#include <asm/io.h> + +#define PRR 0xFF000044 + +u32 rmobile_get_cpu_type(void) +{ + return (readl(PRR) & 0x00007F00) >> 8; +} + +u32 rmobile_get_cpu_rev_integer(void) +{ + return (readl(PRR) & 0x000000F0) >> 4; +} diff --git a/arch/arm/cpu/armv7/rmobile/cpu_info.c b/arch/arm/cpu/armv7/rmobile/cpu_info.c index 07a33fb..6bd3c2e 100644 --- a/arch/arm/cpu/armv7/rmobile/cpu_info.c +++ b/arch/arm/cpu/armv7/rmobile/cpu_info.c @@ -58,6 +58,11 @@ int print_cpuinfo(void) rmobile_get_cpu_rev_fraction()); break;
+ case 0x45: + printf("CPU: Renesas Electronics R8A7790 rev %d\n", + rmobile_get_cpu_rev_integer()); + break; + default: printf("CPU: Renesas Electronics CPU rev %d.%d\n", rmobile_get_cpu_rev_integer(), diff --git a/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S b/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S new file mode 100644 index 0000000..e07cc80 --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S @@ -0,0 +1,60 @@ +/* + * arch/arm/cpu/armv7/rmobile/lowlevel_init_ca15.S + * This file is lager low level initialize. + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <config.h> +#include <linux/linkage.h> + +ENTRY(lowlevel_init) + mrc p15, 0, r4, c0, c0, 5 /* mpidr */ + orr r4, r4, r4, lsr #6 + and r4, r4, #7 /* id 0-3 = ca15.0,1,2,3 */ + + b do_lowlevel_init + + .pool + +/* + * CPU ID #1-#3 come here + */ + .align 4 +do_cpu_waiting: + ldr r1, =0xe6180000 /* sysc */ +1: ldr r0, [r1, #0x20] /* sbar */ + tst r0, r0 + beq 1b + bx r0 + +/* + * Only CPU ID #0 comes here + */ + .align 4 +do_lowlevel_init: + /* surpress wfe if ca15 */ + tst r4, #4 + mrceq p15, 0, r0, c1, c0, 1 /* actlr */ + orreq r0, r0, #(1<<7) + mcreq p15, 0, r0, c1, c0, 1 + /* and set l2 latency */ + mrceq p15, 1, r0, c9, c0, 2 /* l2ctlr */ + orreq r0, r0, #0x00000800 + orreq r0, r0, #0x00000003 + mcreq p15, 1, r0, c9, c0, 2 + + ldr r3, =(CONFIG_SYS_INIT_SP_ADDR) + sub sp, r3, #4 + str lr, [sp] + + /* initialize system */ + bl s_init + + ldr lr, [sp] + mov pc, lr + nop +ENDPROC(lowlevel_init) + .ltorg diff --git a/arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c b/arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c new file mode 100644 index 0000000..afb4a2e --- /dev/null +++ b/arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c @@ -0,0 +1,3231 @@ +/* + * arch/arm/cpu/armv7/rmobile/pfc-r8a7790.c + * This file is r8a7790 processor support - PFC hardware block. + * + * Copy from linux-kernel:drivers/pinctrl/sh-pfc/pfc-r8a7790.c + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Magnus Damm + * Copyright (C) 2012 Renesas Solutions Corp. + * Copyright (C) 2012 Kuninori Morimoto kuninori.morimoto.gx@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <sh_pfc.h> +#include <asm/gpio.h> + +#define CPU_32_PORT(fn, pfx, sfx) \ + PORT_10(fn, pfx, sfx), PORT_10(fn, pfx##1, sfx), \ + PORT_10(fn, pfx##2, sfx), PORT_1(fn, pfx##30, sfx), \ + PORT_1(fn, pfx##31, sfx) + +#define CPU_32_PORT1(fn, pfx, sfx) \ + PORT_10(fn, pfx, sfx), PORT_10(fn, pfx##1, sfx), \ + PORT_10(fn, pfx##2, sfx) + +#define CPU_32_PORT2(fn, pfx, sfx) \ + PORT_10(fn, pfx, sfx), PORT_10(fn, pfx##1, sfx), \ + PORT_10(fn, pfx##2, sfx) + +/* GP_0_0_DATA -> GP_5_31_DATA (except for GP1[30],GP1[31],GP2[30],GP2[31]) */ +#define CPU_ALL_PORT(fn, pfx, sfx) \ + CPU_32_PORT(fn, pfx##_0_, sfx), \ + CPU_32_PORT1(fn, pfx##_1_, sfx), \ + CPU_32_PORT2(fn, pfx##_2_, sfx), \ + CPU_32_PORT(fn, pfx##_3_, sfx), \ + CPU_32_PORT(fn, pfx##_4_, sfx), \ + CPU_32_PORT(fn, pfx##_5_, sfx) \ + +#define _GP_GPIO(pfx, sfx) PINMUX_GPIO(GPIO_GP##pfx, GP##pfx##_DATA) +#define _GP_DATA(pfx, sfx) PINMUX_DATA(GP##pfx##_DATA, GP##pfx##_FN, \ + GP##pfx##_IN, GP##pfx##_OUT) + +#define _GP_INOUTSEL(pfx, sfx) GP##pfx##_IN, GP##pfx##_OUT +#define _GP_INDT(pfx, sfx) GP##pfx##_DATA + +#define GP_ALL(str) CPU_ALL_PORT(_PORT_ALL, GP, str) +#define PINMUX_GPIO_GP_ALL() CPU_ALL_PORT(_GP_GPIO, , unused) +#define PINMUX_DATA_GP_ALL() CPU_ALL_PORT(_GP_DATA, , unused) + + +#define PORT_10_REV(fn, pfx, sfx) \ + PORT_1(fn, pfx##9, sfx), PORT_1(fn, pfx##8, sfx), \ + PORT_1(fn, pfx##7, sfx), PORT_1(fn, pfx##6, sfx), \ + PORT_1(fn, pfx##5, sfx), PORT_1(fn, pfx##4, sfx), \ + PORT_1(fn, pfx##3, sfx), PORT_1(fn, pfx##2, sfx), \ + PORT_1(fn, pfx##1, sfx), PORT_1(fn, pfx##0, sfx) + +#define CPU_32_PORT_REV(fn, pfx, sfx) \ + PORT_1(fn, pfx##31, sfx), PORT_1(fn, pfx##30, sfx), \ + PORT_10_REV(fn, pfx##2, sfx), PORT_10_REV(fn, pfx##1, sfx), \ + PORT_10_REV(fn, pfx, sfx) + +#define GP_INOUTSEL(bank) CPU_32_PORT_REV(_GP_INOUTSEL, _##bank##_, unused) +#define GP_INDT(bank) CPU_32_PORT_REV(_GP_INDT, _##bank##_, unused) + +#define PINMUX_IPSR_DATA(ipsr, fn) PINMUX_DATA(fn##_MARK, FN_##ipsr, FN_##fn) +#define PINMUX_IPSR_MODSEL_DATA(ipsr, fn, ms) PINMUX_DATA(fn##_MARK, FN_##ms, \ + FN_##ipsr, FN_##fn) + +enum { + PINMUX_RESERVED = 0, + + PINMUX_DATA_BEGIN, + GP_ALL(DATA), + PINMUX_DATA_END, + + PINMUX_INPUT_BEGIN, + GP_ALL(IN), + PINMUX_INPUT_END, + + PINMUX_OUTPUT_BEGIN, + GP_ALL(OUT), + PINMUX_OUTPUT_END, + + PINMUX_FUNCTION_BEGIN, + GP_ALL(FN), + + /* GPSR0 */ + FN_IP0_2_0, FN_IP0_5_3, FN_IP0_8_6, FN_IP0_11_9, FN_IP0_15_12, + FN_IP0_19_16, FN_IP0_22_20, FN_IP0_26_23, FN_IP0_30_27, + FN_IP1_3_0, FN_IP1_7_4, FN_IP1_11_8, FN_IP1_14_12, + FN_IP1_17_15, FN_IP1_21_18, FN_IP1_25_22, FN_IP1_27_26, + FN_IP1_29_28, FN_IP2_2_0, FN_IP2_5_3, FN_IP2_8_6, FN_IP2_11_9, + FN_IP2_14_12, FN_IP2_17_15, FN_IP2_21_18, FN_IP2_25_22, + FN_IP2_28_26, FN_IP3_3_0, FN_IP3_7_4, FN_IP3_11_8, + FN_IP3_14_12, FN_IP3_17_15, + + /* GPSR1 */ + FN_IP3_19_18, FN_IP3_22_20, FN_IP3_25_23, FN_IP3_28_26, + FN_IP3_31_29, FN_IP4_2_0, FN_IP4_5_3, FN_IP4_8_6, FN_IP4_11_9, + FN_IP4_14_12, FN_IP4_17_15, FN_IP4_20_18, FN_IP4_23_21, + FN_IP4_26_24, FN_IP4_29_27, FN_IP5_2_0, FN_IP5_5_3, FN_IP5_9_6, + FN_IP5_12_10, FN_IP5_14_13, FN_IP5_17_15, FN_IP5_20_18, + FN_IP5_23_21, FN_IP5_26_24, FN_IP5_29_27, FN_IP6_2_0, + FN_IP6_5_3, FN_IP6_8_6, FN_IP6_10_9, FN_IP6_13_11, + + /* GPSR2 */ + FN_IP7_28_27, FN_IP7_30_29, FN_IP8_1_0, FN_IP8_3_2, FN_IP8_5_4, + FN_IP8_7_6, FN_IP8_9_8, FN_IP8_11_10, FN_IP8_13_12, FN_IP8_15_14, + FN_IP8_17_16, FN_IP8_19_18, FN_IP8_21_20, FN_IP8_23_22, + FN_IP8_25_24, FN_IP8_26, FN_IP8_27, FN_VI1_DATA7_VI1_B7, + FN_IP6_16_14, FN_IP6_19_17, FN_IP6_22_20, FN_IP6_25_23, + FN_IP6_28_26, FN_IP6_31_29, FN_IP7_2_0, FN_IP7_5_3, FN_IP7_7_6, + FN_IP7_9_8, FN_IP7_12_10, FN_IP7_15_13, + + /* GPSR3 */ + FN_IP8_28, FN_IP8_30_29, FN_IP9_1_0, FN_IP9_3_2, FN_IP9_5_4, + FN_IP9_7_6, FN_IP9_11_8, FN_IP9_15_12, FN_IP9_17_16, FN_IP9_19_18, + FN_IP9_21_20, FN_IP9_23_22, FN_IP9_25_24, FN_IP9_27_26, + FN_IP9_31_28, FN_IP10_3_0, FN_IP10_6_4, FN_IP10_10_7, FN_IP10_14_11, + FN_IP10_18_15, FN_IP10_22_19, FN_IP10_25_23, FN_IP10_29_26, + FN_IP11_3_0, FN_IP11_4, FN_IP11_6_5, FN_IP11_8_7, FN_IP11_10_9, + FN_IP11_12_11, FN_IP11_14_13, FN_IP11_17_15, FN_IP11_21_18, + + /* GPSR4 */ + FN_IP11_23_22, FN_IP11_26_24, FN_IP11_29_27, FN_IP11_31_30, + FN_IP12_1_0, FN_IP12_3_2, FN_IP12_5_4, FN_IP12_7_6, FN_IP12_10_8, + FN_IP12_13_11, FN_IP12_16_14, FN_IP12_19_17, FN_IP12_22_20, + FN_IP12_24_23, FN_IP12_27_25, FN_IP12_30_28, FN_IP13_2_0, + FN_IP13_6_3, FN_IP13_9_7, FN_IP13_12_10, FN_IP13_15_13, + FN_IP13_18_16, FN_IP13_22_19, FN_IP13_25_23, FN_IP13_28_26, + FN_IP13_30_29, FN_IP14_2_0, FN_IP14_5_3, FN_IP14_8_6, FN_IP14_11_9, + FN_IP14_15_12, FN_IP14_18_16, + + /* GPSR5 */ + FN_IP14_21_19, FN_IP14_24_22, FN_IP14_27_25, FN_IP14_30_28, + FN_IP15_2_0, FN_IP15_5_3, FN_IP15_8_6, FN_IP15_11_9, FN_IP15_13_12, + FN_IP15_15_14, FN_IP15_17_16, FN_IP15_19_18, FN_IP15_22_20, + FN_IP15_25_23, FN_IP15_27_26, FN_IP15_29_28, FN_IP16_2_0, + FN_IP16_5_3, FN_USB0_PWEN, FN_USB0_OVC_VBUS, FN_IP16_6, FN_IP16_7, + FN_USB2_PWEN, FN_USB2_OVC, FN_AVS1, FN_AVS2, FN_DU_DOTCLKIN0, + FN_IP7_26_25, FN_DU_DOTCLKIN2, FN_IP7_18_16, FN_IP7_21_19, FN_IP7_24_22, + + /* IPSR0 */ + FN_D0, FN_MSIOF3_SCK_B, FN_VI3_DATA0, FN_VI0_G4, FN_VI0_G4_B, + FN_D1, FN_MSIOF3_SYNC_B, FN_VI3_DATA1, FN_VI0_G5, + FN_VI0_G5_B, FN_D2, FN_MSIOF3_RXD_B, FN_VI3_DATA2, + FN_VI0_G6, FN_VI0_G6_B, FN_D3, FN_MSIOF3_TXD_B, + FN_VI3_DATA3, FN_VI0_G7, FN_VI0_G7_B, FN_D4, + FN_SCIFB1_RXD_F, FN_SCIFB0_RXD_C, FN_VI3_DATA4, + FN_VI0_R0, FN_VI0_R0_B, FN_RX0_B, FN_D5, + FN_SCIFB1_TXD_F, FN_SCIFB0_TXD_C, FN_VI3_DATA5, + FN_VI0_R1, FN_VI0_R1_B, FN_TX0_B, FN_D6, + FN_SCL2_C, FN_VI3_DATA6, FN_VI0_R2, FN_VI0_R2_B, + FN_SCL2_CIS_C, FN_D7, FN_AD_DI_B, FN_SDA2_C, + FN_VI3_DATA7, FN_VI0_R3, FN_VI0_R3_B, FN_SDA2_CIS_C, + FN_D8, FN_SCIFA1_SCK_C, FN_AVB_TXD0, FN_MII_TXD0, + FN_VI0_G0, FN_VI0_G0_B, FN_VI2_DATA0_VI2_B0, + + /* IPSR1 */ + FN_D9, FN_SCIFA1_RXD_C, FN_AVB_TXD1, FN_MII_TXD1, + FN_VI0_G1, FN_VI0_G1_B, FN_VI2_DATA1_VI2_B1, FN_D10, + FN_SCIFA1_TXD_C, FN_AVB_TXD2, FN_MII_TXD2, + FN_VI0_G2, FN_VI0_G2_B, FN_VI2_DATA2_VI2_B2, FN_D11, + FN_SCIFA1_CTS_N_C, FN_AVB_TXD3, FN_MII_TXD3, + FN_VI0_G3, FN_VI0_G3_B, FN_VI2_DATA3_VI2_B3, + FN_D12, FN_SCIFA1_RTS_N_C, FN_AVB_TXD4, + FN_VI0_HSYNC_N, FN_VI0_HSYNC_N_B, FN_VI2_DATA4_VI2_B4, + FN_D13, FN_AVB_TXD5, FN_VI0_VSYNC_N, + FN_VI0_VSYNC_N_B, FN_VI2_DATA5_VI2_B5, FN_D14, + FN_SCIFB1_RXD_C, FN_AVB_TXD6, FN_RX1_B, + FN_VI0_CLKENB, FN_VI0_CLKENB_B, FN_VI2_DATA6_VI2_B6, + FN_D15, FN_SCIFB1_TXD_C, FN_AVB_TXD7, FN_TX1_B, + FN_VI0_FIELD, FN_VI0_FIELD_B, FN_VI2_DATA7_VI2_B7, + FN_A0, FN_PWM3, FN_A1, FN_PWM4, + + /* IPSR2 */ + FN_A2, FN_PWM5, FN_MSIOF1_SS1_B, FN_A3, + FN_PWM6, FN_MSIOF1_SS2_B, FN_A4, FN_MSIOF1_TXD_B, + FN_TPU0TO0, FN_A5, FN_SCIFA1_TXD_B, FN_TPU0TO1, + FN_A6, FN_SCIFA1_RTS_N_B, FN_TPU0TO2, FN_A7, + FN_SCIFA1_SCK_B, FN_AUDIO_CLKOUT_B, FN_TPU0TO3, + FN_A8, FN_SCIFA1_RXD_B, FN_SSI_SCK5_B, FN_VI0_R4, + FN_VI0_R4_B, FN_SCIFB2_RXD_C, FN_VI2_DATA0_VI2_B0_B, + FN_A9, FN_SCIFA1_CTS_N_B, FN_SSI_WS5_B, FN_VI0_R5, + FN_VI0_R5_B, FN_SCIFB2_TXD_C, FN_VI2_DATA1_VI2_B1_B, + FN_A10, FN_SSI_SDATA5_B, FN_MSIOF2_SYNC, FN_VI0_R6, + FN_VI0_R6_B, FN_VI2_DATA2_VI2_B2_B, + + /* IPSR3 */ + FN_A11, FN_SCIFB2_CTS_N_B, FN_MSIOF2_SCK, FN_VI1_R0, + FN_VI1_R0_B, FN_VI2_G0, FN_VI2_DATA3_VI2_B3_B, + FN_A12, FN_SCIFB2_RXD_B, FN_MSIOF2_TXD, FN_VI1_R1, + FN_VI1_R1_B, FN_VI2_G1, FN_VI2_DATA4_VI2_B4_B, + FN_A13, FN_SCIFB2_RTS_N_B, FN_EX_WAIT2, + FN_MSIOF2_RXD, FN_VI1_R2, FN_VI1_R2_B, FN_VI2_G2, + FN_VI2_DATA5_VI2_B5_B, FN_A14, FN_SCIFB2_TXD_B, + FN_ATACS11_N, FN_MSIOF2_SS1, FN_A15, FN_SCIFB2_SCK_B, + FN_ATARD1_N, FN_MSIOF2_SS2, FN_A16, FN_ATAWR1_N, + FN_A17, FN_AD_DO_B, FN_ATADIR1_N, FN_A18, + FN_AD_CLK_B, FN_ATAG1_N, FN_A19, FN_AD_NCS_N_B, + FN_ATACS01_N, FN_EX_WAIT0_B, FN_A20, FN_SPCLK, + FN_VI1_R3, FN_VI1_R3_B, FN_VI2_G4, + + /* IPSR4 */ + FN_A21, FN_MOSI_IO0, FN_VI1_R4, FN_VI1_R4_B, FN_VI2_G5, + FN_A22, FN_MISO_IO1, FN_VI1_R5, FN_VI1_R5_B, + FN_VI2_G6, FN_A23, FN_IO2, FN_VI1_G7, + FN_VI1_G7_B, FN_VI2_G7, FN_A24, FN_IO3, + FN_VI1_R7, FN_VI1_R7_B, FN_VI2_CLKENB, + FN_VI2_CLKENB_B, FN_A25, FN_SSL, FN_VI1_G6, + FN_VI1_G6_B, FN_VI2_FIELD, FN_VI2_FIELD_B, FN_CS0_N, + FN_VI1_R6, FN_VI1_R6_B, FN_VI2_G3, FN_MSIOF0_SS2_B, + FN_CS1_N_A26, FN_SPEEDIN, FN_VI0_R7, FN_VI0_R7_B, + FN_VI2_CLK, FN_VI2_CLK_B, FN_EX_CS0_N, FN_HRX1_B, + FN_VI1_G5, FN_VI1_G5_B, FN_VI2_R0, FN_HTX0_B, + FN_MSIOF0_SS1_B, FN_EX_CS1_N, FN_GPS_CLK, + FN_HCTS1_N_B, FN_VI1_FIELD, FN_VI1_FIELD_B, + FN_VI2_R1, FN_EX_CS2_N, FN_GPS_SIGN, FN_HRTS1_N_B, + FN_VI3_CLKENB, FN_VI1_G0, FN_VI1_G0_B, FN_VI2_R2, + + /* IPSR5 */ + FN_EX_CS3_N, FN_GPS_MAG, FN_VI3_FIELD, FN_VI1_G1, FN_VI1_G1_B, + FN_VI2_R3, FN_EX_CS4_N, FN_MSIOF1_SCK_B, FN_VI3_HSYNC_N, + FN_VI2_HSYNC_N, FN_SCL1, FN_VI2_HSYNC_N_B, + FN_INTC_EN0_N, FN_SCL1_CIS, FN_EX_CS5_N, FN_CAN0_RX, + FN_MSIOF1_RXD_B, FN_VI3_VSYNC_N, FN_VI1_G2, + FN_VI1_G2_B, FN_VI2_R4, FN_SDA1, FN_INTC_EN1_N, + FN_SDA1_CIS, FN_BS_N, FN_IETX, FN_HTX1_B, + FN_CAN1_TX, FN_DRACK0, FN_IETX_C, FN_RD_N, + FN_CAN0_TX, FN_SCIFA0_SCK_B, FN_RD_WR_N, FN_VI1_G3, + FN_VI1_G3_B, FN_VI2_R5, FN_SCIFA0_RXD_B, + FN_INTC_IRQ4_N, FN_WE0_N, FN_IECLK, FN_CAN_CLK, + FN_VI2_VSYNC_N, FN_SCIFA0_TXD_B, FN_VI2_VSYNC_N_B, + FN_WE1_N, FN_IERX, FN_CAN1_RX, FN_VI1_G4, + FN_VI1_G4_B, FN_VI2_R6, FN_SCIFA0_CTS_N_B, + FN_IERX_C, FN_EX_WAIT0, FN_IRQ3, FN_INTC_IRQ3_N, + FN_VI3_CLK, FN_SCIFA0_RTS_N_B, FN_HRX0_B, + FN_MSIOF0_SCK_B, FN_DREQ0_N, FN_VI1_HSYNC_N, + FN_VI1_HSYNC_N_B, FN_VI2_R7, FN_SSI_SCK78_C, + FN_SSI_WS78_B, + + /* IPSR6 */ + FN_DACK0, FN_IRQ0, FN_INTC_IRQ0_N, FN_SSI_SCK6_B, + FN_VI1_VSYNC_N, FN_VI1_VSYNC_N_B, FN_SSI_WS78_C, + FN_DREQ1_N, FN_VI1_CLKENB, FN_VI1_CLKENB_B, + FN_SSI_SDATA7_C, FN_SSI_SCK78_B, FN_DACK1, FN_IRQ1, + FN_INTC_IRQ1_N, FN_SSI_WS6_B, FN_SSI_SDATA8_C, + FN_DREQ2_N, FN_HSCK1_B, FN_HCTS0_N_B, + FN_MSIOF0_TXD_B, FN_DACK2, FN_IRQ2, FN_INTC_IRQ2_N, + FN_SSI_SDATA6_B, FN_HRTS0_N_B, FN_MSIOF0_RXD_B, + FN_ETH_CRS_DV, FN_RMII_CRS_DV, FN_STP_ISCLK_0_B, + FN_TS_SDEN0_D, FN_GLO_Q0_C, FN_SCL2_E, + FN_SCL2_CIS_E, FN_ETH_RX_ER, FN_RMII_RX_ER, + FN_STP_ISD_0_B, FN_TS_SPSYNC0_D, FN_GLO_Q1_C, + FN_SDA2_E, FN_SDA2_CIS_E, FN_ETH_RXD0, FN_RMII_RXD0, + FN_STP_ISEN_0_B, FN_TS_SDAT0_D, FN_GLO_I0_C, + FN_SCIFB1_SCK_G, FN_SCK1_E, FN_ETH_RXD1, + FN_RMII_RXD1, FN_HRX0_E, FN_STP_ISSYNC_0_B, + FN_TS_SCK0_D, FN_GLO_I1_C, FN_SCIFB1_RXD_G, + FN_RX1_E, FN_ETH_LINK, FN_RMII_LINK, FN_HTX0_E, + FN_STP_IVCXO27_0_B, FN_SCIFB1_TXD_G, FN_TX1_E, + FN_ETH_REF_CLK, FN_RMII_REF_CLK, FN_HCTS0_N_E, + FN_STP_IVCXO27_1_B, FN_HRX0_F, + + /* IPSR7 */ + FN_ETH_MDIO, FN_RMII_MDIO, FN_HRTS0_N_E, + FN_SIM0_D_C, FN_HCTS0_N_F, FN_ETH_TXD1, + FN_RMII_TXD1, FN_HTX0_F, FN_BPFCLK_G, FN_RDS_CLK_F, + FN_ETH_TX_EN, FN_RMII_TX_EN, FN_SIM0_CLK_C, + FN_HRTS0_N_F, FN_ETH_MAGIC, FN_RMII_MAGIC, + FN_SIM0_RST_C, FN_ETH_TXD0, FN_RMII_TXD0, + FN_STP_ISCLK_1_B, FN_TS_SDEN1_C, FN_GLO_SCLK_C, + FN_ETH_MDC, FN_RMII_MDC, FN_STP_ISD_1_B, + FN_TS_SPSYNC1_C, FN_GLO_SDATA_C, FN_PWM0, + FN_SCIFA2_SCK_C, FN_STP_ISEN_1_B, FN_TS_SDAT1_C, + FN_GLO_SS_C, FN_PWM1, FN_SCIFA2_TXD_C, + FN_STP_ISSYNC_1_B, FN_TS_SCK1_C, FN_GLO_RFON_C, + FN_PCMOE_N, FN_PWM2, FN_PWMFSW0, FN_SCIFA2_RXD_C, + FN_PCMWE_N, FN_IECLK_C, FN_DU1_DOTCLKIN, + FN_AUDIO_CLKC, FN_AUDIO_CLKOUT_C, FN_VI0_CLK, + FN_ATACS00_N, FN_AVB_RXD1, FN_MII_RXD1, + FN_VI0_DATA0_VI0_B0, FN_ATACS10_N, FN_AVB_RXD2, + FN_MII_RXD2, + + /* IPSR8 */ + FN_VI0_DATA1_VI0_B1, FN_ATARD0_N, FN_AVB_RXD3, + FN_MII_RXD3, FN_VI0_DATA2_VI0_B2, FN_ATAWR0_N, + FN_AVB_RXD4, FN_VI0_DATA3_VI0_B3, FN_ATADIR0_N, + FN_AVB_RXD5, FN_VI0_DATA4_VI0_B4, FN_ATAG0_N, + FN_AVB_RXD6, FN_VI0_DATA5_VI0_B5, FN_EX_WAIT1, + FN_AVB_RXD7, FN_VI0_DATA6_VI0_B6, FN_AVB_RX_ER, + FN_MII_RX_ER, FN_VI0_DATA7_VI0_B7, FN_AVB_RX_CLK, + FN_MII_RX_CLK, FN_VI1_CLK, FN_AVB_RX_DV, + FN_MII_RX_DV, FN_VI1_DATA0_VI1_B0, FN_SCIFA1_SCK_D, + FN_AVB_CRS, FN_MII_CRS, FN_VI1_DATA1_VI1_B1, + FN_SCIFA1_RXD_D, FN_AVB_MDC, FN_MII_MDC, + FN_VI1_DATA2_VI1_B2, FN_SCIFA1_TXD_D, FN_AVB_MDIO, + FN_MII_MDIO, FN_VI1_DATA3_VI1_B3, FN_SCIFA1_CTS_N_D, + FN_AVB_GTX_CLK, FN_VI1_DATA4_VI1_B4, FN_SCIFA1_RTS_N_D, + FN_AVB_MAGIC, FN_MII_MAGIC, FN_VI1_DATA5_VI1_B5, + FN_AVB_PHY_INT, FN_VI1_DATA6_VI1_B6, FN_AVB_GTXREFCLK, + FN_SD0_CLK, FN_VI1_DATA0_VI1_B0_B, FN_SD0_CMD, + FN_SCIFB1_SCK_B, FN_VI1_DATA1_VI1_B1_B, + + /* IPSR9 */ + FN_SD0_DAT0, FN_SCIFB1_RXD_B, FN_VI1_DATA2_VI1_B2_B, + FN_SD0_DAT1, FN_SCIFB1_TXD_B, FN_VI1_DATA3_VI1_B3_B, + FN_SD0_DAT2, FN_SCIFB1_CTS_N_B, FN_VI1_DATA4_VI1_B4_B, + FN_SD0_DAT3, FN_SCIFB1_RTS_N_B, FN_VI1_DATA5_VI1_B5_B, + FN_SD0_CD, FN_MMC0_D6, FN_TS_SDEN0_B, FN_USB0_EXTP, + FN_GLO_SCLK, FN_VI1_DATA6_VI1_B6_B, FN_SCL1_B, + FN_SCL1_CIS_B, FN_VI2_DATA6_VI2_B6_B, FN_SD0_WP, + FN_MMC0_D7, FN_TS_SPSYNC0_B, FN_USB0_IDIN, + FN_GLO_SDATA, FN_VI1_DATA7_VI1_B7_B, FN_SDA1_B, + FN_SDA1_CIS_B, FN_VI2_DATA7_VI2_B7_B, FN_SD1_CLK, + FN_AVB_TX_EN, FN_MII_TX_EN, FN_SD1_CMD, + FN_AVB_TX_ER, FN_MII_TX_ER, FN_SCIFB0_SCK_B, + FN_SD1_DAT0, FN_AVB_TX_CLK, FN_MII_TX_CLK, + FN_SCIFB0_RXD_B, FN_SD1_DAT1, FN_AVB_LINK, + FN_MII_LINK, FN_SCIFB0_TXD_B, FN_SD1_DAT2, + FN_AVB_COL, FN_MII_COL, FN_SCIFB0_CTS_N_B, + FN_SD1_DAT3, FN_AVB_RXD0, FN_MII_RXD0, + FN_SCIFB0_RTS_N_B, FN_SD1_CD, FN_MMC1_D6, + FN_TS_SDEN1, FN_USB1_EXTP, FN_GLO_SS, FN_VI0_CLK_B, + FN_SCL2_D, FN_SCL2_CIS_D, FN_SIM0_CLK_B, + FN_VI3_CLK_B, + + /* IPSR10 */ + FN_SD1_WP, FN_MMC1_D7, FN_TS_SPSYNC1, FN_USB1_IDIN, + FN_GLO_RFON, FN_VI1_CLK_B, FN_SDA2_D, FN_SDA2_CIS_D, + FN_SIM0_D_B, FN_SD2_CLK, FN_MMC0_CLK, FN_SIM0_CLK, + FN_VI0_DATA0_VI0_B0_B, FN_TS_SDEN0_C, FN_GLO_SCLK_B, + FN_VI3_DATA0_B, FN_SD2_CMD, FN_MMC0_CMD, FN_SIM0_D, + FN_VI0_DATA1_VI0_B1_B, FN_SCIFB1_SCK_E, FN_SCK1_D, + FN_TS_SPSYNC0_C, FN_GLO_SDATA_B, FN_VI3_DATA1_B, + FN_SD2_DAT0, FN_MMC0_D0, FN_FMCLK_B, + FN_VI0_DATA2_VI0_B2_B, FN_SCIFB1_RXD_E, FN_RX1_D, + FN_TS_SDAT0_C, FN_GLO_SS_B, FN_VI3_DATA2_B, + FN_SD2_DAT1, FN_MMC0_D1, FN_FMIN_B, FN_RDS_DATA, + FN_VI0_DATA3_VI0_B3_B, FN_SCIFB1_TXD_E, FN_TX1_D, + FN_TS_SCK0_C, FN_GLO_RFON_B, FN_VI3_DATA3_B, + FN_SD2_DAT2, FN_MMC0_D2, FN_BPFCLK_B, FN_RDS_CLK, + FN_VI0_DATA4_VI0_B4_B, FN_HRX0_D, FN_TS_SDEN1_B, + FN_GLO_Q0_B, FN_VI3_DATA4_B, FN_SD2_DAT3, + FN_MMC0_D3, FN_SIM0_RST, FN_VI0_DATA5_VI0_B5_B, + FN_HTX0_D, FN_TS_SPSYNC1_B, FN_GLO_Q1_B, + FN_VI3_DATA5_B, FN_SD2_CD, FN_MMC0_D4, + FN_TS_SDAT0_B, FN_USB2_EXTP, FN_GLO_I0, + FN_VI0_DATA6_VI0_B6_B, FN_HCTS0_N_D, FN_TS_SDAT1_B, + FN_GLO_I0_B, FN_VI3_DATA6_B, + + /* IPSR11 */ + FN_SD2_WP, FN_MMC0_D5, FN_TS_SCK0_B, FN_USB2_IDIN, + FN_GLO_I1, FN_VI0_DATA7_VI0_B7_B, FN_HRTS0_N_D, + FN_TS_SCK1_B, FN_GLO_I1_B, FN_VI3_DATA7_B, + FN_SD3_CLK, FN_MMC1_CLK, FN_SD3_CMD, FN_MMC1_CMD, + FN_MTS_N, FN_SD3_DAT0, FN_MMC1_D0, FN_STM_N, + FN_SD3_DAT1, FN_MMC1_D1, FN_MDATA, FN_SD3_DAT2, + FN_MMC1_D2, FN_SDATA, FN_SD3_DAT3, FN_MMC1_D3, + FN_SCKZ, FN_SD3_CD, FN_MMC1_D4, FN_TS_SDAT1, + FN_VSP, FN_GLO_Q0, FN_SIM0_RST_B, FN_SD3_WP, + FN_MMC1_D5, FN_TS_SCK1, FN_GLO_Q1, FN_FMIN_C, + FN_RDS_DATA_B, FN_FMIN_E, FN_RDS_DATA_D, FN_FMIN_F, + FN_RDS_DATA_E, FN_MLB_CLK, FN_SCL2_B, FN_SCL2_CIS_B, + FN_MLB_SIG, FN_SCIFB1_RXD_D, FN_RX1_C, FN_SDA2_B, + FN_SDA2_CIS_B, FN_MLB_DAT, FN_SPV_EVEN, + FN_SCIFB1_TXD_D, FN_TX1_C, FN_BPFCLK_C, + FN_RDS_CLK_B, FN_SSI_SCK0129, FN_CAN_CLK_B, + FN_MOUT0, + + /* IPSR12 */ + FN_SSI_WS0129, FN_CAN0_TX_B, FN_MOUT1, + FN_SSI_SDATA0, FN_CAN0_RX_B, FN_MOUT2, + FN_SSI_SDATA1, FN_CAN1_TX_B, FN_MOUT5, + FN_SSI_SDATA2, FN_CAN1_RX_B, FN_SSI_SCK1, FN_MOUT6, + FN_SSI_SCK34, FN_STP_OPWM_0, FN_SCIFB0_SCK, + FN_MSIOF1_SCK, FN_CAN_DEBUG_HW_TRIGGER, FN_SSI_WS34, + FN_STP_IVCXO27_0, FN_SCIFB0_RXD, FN_MSIOF1_SYNC, + FN_CAN_STEP0, FN_SSI_SDATA3, FN_STP_ISCLK_0, + FN_SCIFB0_TXD, FN_MSIOF1_SS1, FN_CAN_TXCLK, + FN_SSI_SCK4, FN_STP_ISD_0, FN_SCIFB0_CTS_N, + FN_MSIOF1_SS2, FN_SSI_SCK5_C, FN_CAN_DEBUGOUT0, + FN_SSI_WS4, FN_STP_ISEN_0, FN_SCIFB0_RTS_N, + FN_MSIOF1_TXD, FN_SSI_WS5_C, FN_CAN_DEBUGOUT1, + FN_SSI_SDATA4, FN_STP_ISSYNC_0, FN_MSIOF1_RXD, + FN_CAN_DEBUGOUT2, FN_SSI_SCK5, FN_SCIFB1_SCK, + FN_IERX_B, FN_DU2_EXHSYNC_DU2_HSYNC, FN_QSTH_QHS, + FN_CAN_DEBUGOUT3, FN_SSI_WS5, FN_SCIFB1_RXD, + FN_IECLK_B, FN_DU2_EXVSYNC_DU2_VSYNC, FN_QSTB_QHE, + FN_CAN_DEBUGOUT4, + + /* IPSR13 */ + FN_SSI_SDATA5, FN_SCIFB1_TXD, FN_IETX_B, FN_DU2_DR2, + FN_LCDOUT2, FN_CAN_DEBUGOUT5, FN_SSI_SCK6, + FN_SCIFB1_CTS_N, FN_BPFCLK_D, FN_RDS_CLK_C, + FN_DU2_DR3, FN_LCDOUT3, FN_CAN_DEBUGOUT6, + FN_BPFCLK_F, FN_RDS_CLK_E, FN_SSI_WS6, + FN_SCIFB1_RTS_N, FN_CAN0_TX_D, FN_DU2_DR4, + FN_LCDOUT4, FN_CAN_DEBUGOUT7, FN_SSI_SDATA6, + FN_FMIN_D, FN_RDS_DATA_C, FN_DU2_DR5, FN_LCDOUT5, + FN_CAN_DEBUGOUT8, FN_SSI_SCK78, FN_STP_IVCXO27_1, + FN_SCK1, FN_SCIFA1_SCK, FN_DU2_DR6, FN_LCDOUT6, + FN_CAN_DEBUGOUT9, FN_SSI_WS78, FN_STP_ISCLK_1, + FN_SCIFB2_SCK, FN_SCIFA2_CTS_N, FN_DU2_DR7, + FN_LCDOUT7, FN_CAN_DEBUGOUT10, FN_SSI_SDATA7, + FN_STP_ISD_1, FN_SCIFB2_RXD, FN_SCIFA2_RTS_N, + FN_TCLK2, FN_QSTVA_QVS, FN_CAN_DEBUGOUT11, + FN_BPFCLK_E, FN_RDS_CLK_D, FN_SSI_SDATA7_B, + FN_FMIN_G, FN_RDS_DATA_F, FN_SSI_SDATA8, + FN_STP_ISEN_1, FN_SCIFB2_TXD, FN_CAN0_TX_C, + FN_CAN_DEBUGOUT12, FN_SSI_SDATA8_B, FN_SSI_SDATA9, + FN_STP_ISSYNC_1, FN_SCIFB2_CTS_N, FN_SSI_WS1, + FN_SSI_SDATA5_C, FN_CAN_DEBUGOUT13, FN_AUDIO_CLKA, + FN_SCIFB2_RTS_N, FN_CAN_DEBUGOUT14, + + /* IPSR14 */ + FN_AUDIO_CLKB, FN_SCIF_CLK, FN_CAN0_RX_D, + FN_DVC_MUTE, FN_CAN0_RX_C, FN_CAN_DEBUGOUT15, + FN_REMOCON, FN_SCIFA0_SCK, FN_HSCK1, FN_SCK0, + FN_MSIOF3_SS2, FN_DU2_DG2, FN_LCDOUT10, FN_SDA1_C, + FN_SDA1_CIS_C, FN_SCIFA0_RXD, FN_HRX1, FN_RX0, + FN_DU2_DR0, FN_LCDOUT0, FN_SCIFA0_TXD, FN_HTX1, + FN_TX0, FN_DU2_DR1, FN_LCDOUT1, FN_SCIFA0_CTS_N, + FN_HCTS1_N, FN_CTS0_N, FN_MSIOF3_SYNC, FN_DU2_DG3, + FN_LCDOUT11, FN_PWM0_B, FN_SCL1_C, FN_SCL1_CIS_C, + FN_SCIFA0_RTS_N, FN_HRTS1_N, FN_RTS0_N_TANS, + FN_MSIOF3_SS1, FN_DU2_DG0, FN_LCDOUT8, FN_PWM1_B, + FN_SCIFA1_RXD, FN_AD_DI, FN_RX1, + FN_DU2_EXODDF_DU2_ODDF_DISP_CDE, FN_QCPV_QDE, + FN_SCIFA1_TXD, FN_AD_DO, FN_TX1, FN_DU2_DG1, + FN_LCDOUT9, FN_SCIFA1_CTS_N, FN_AD_CLK, + FN_CTS1_N, FN_MSIOF3_RXD, FN_DU0_DOTCLKOUT, FN_QCLK, + FN_SCIFA1_RTS_N, FN_AD_NCS_N, FN_RTS1_N_TANS, + FN_MSIOF3_TXD, FN_DU1_DOTCLKOUT, FN_QSTVB_QVE, + FN_HRTS0_N_C, + + /* IPSR15 */ + FN_SCIFA2_SCK, FN_FMCLK, FN_MSIOF3_SCK, FN_DU2_DG7, + FN_LCDOUT15, FN_SCIF_CLK_B, FN_SCIFA2_RXD, FN_FMIN, + FN_DU2_DB0, FN_LCDOUT16, FN_SCL2, FN_SCL2_CIS, + FN_SCIFA2_TXD, FN_BPFCLK, FN_DU2_DB1, FN_LCDOUT17, + FN_SDA2, FN_SDA2_CIS, FN_HSCK0, FN_TS_SDEN0, + FN_DU2_DG4, FN_LCDOUT12, FN_HCTS0_N_C, FN_HRX0, + FN_DU2_DB2, FN_LCDOUT18, FN_HTX0, FN_DU2_DB3, + FN_LCDOUT19, FN_HCTS0_N, FN_SSI_SCK9, FN_DU2_DB4, + FN_LCDOUT20, FN_HRTS0_N, FN_SSI_WS9, FN_DU2_DB5, + FN_LCDOUT21, FN_MSIOF0_SCK, FN_TS_SDAT0, FN_ADICLK, + FN_DU2_DB6, FN_LCDOUT22, FN_MSIOF0_SYNC, FN_TS_SCK0, + FN_SSI_SCK2, FN_ADIDATA, FN_DU2_DB7, FN_LCDOUT23, + FN_SCIFA2_RXD_B, FN_MSIOF0_SS1, FN_ADICHS0, + FN_DU2_DG5, FN_LCDOUT13, FN_MSIOF0_TXD, FN_ADICHS1, + FN_DU2_DG6, FN_LCDOUT14, + + /* IPSR16 */ + FN_MSIOF0_SS2, FN_AUDIO_CLKOUT, FN_ADICHS2, + FN_DU2_DISP, FN_QPOLA, FN_HTX0_C, FN_SCIFA2_TXD_B, + FN_MSIOF0_RXD, FN_TS_SPSYNC0, FN_SSI_WS2, + FN_ADICS_SAMP, FN_DU2_CDE, FN_QPOLB, FN_HRX0_C, + FN_USB1_PWEN, FN_AUDIO_CLKOUT_D, FN_USB1_OVC, + FN_TCLK1_B, + + FN_SEL_SCIF1_0, FN_SEL_SCIF1_1, FN_SEL_SCIF1_2, FN_SEL_SCIF1_3, + FN_SEL_SCIF1_4, + FN_SEL_SCIFB_0, FN_SEL_SCIFB_1, FN_SEL_SCIFB_2, + FN_SEL_SCIFB2_0, FN_SEL_SCIFB2_1, FN_SEL_SCIFB2_2, + FN_SEL_SCIFB1_0, FN_SEL_SCIFB1_1, FN_SEL_SCIFB1_2, FN_SEL_SCIFB1_3, + FN_SEL_SCIFB1_4, + FN_SEL_SCIFB1_5, FN_SEL_SCIFB1_6, + FN_SEL_SCIFA1_0, FN_SEL_SCIFA1_1, FN_SEL_SCIFA1_2, FN_SEL_SCIFA1_3, + FN_SEL_SCIF0_0, FN_SEL_SCIF0_1, + FN_SEL_SCFA_0, FN_SEL_SCFA_1, + FN_SEL_SOF1_0, FN_SEL_SOF1_1, + FN_SEL_SSI7_0, FN_SEL_SSI7_1, FN_SEL_SSI7_2, + FN_SEL_SSI6_0, FN_SEL_SSI6_1, + FN_SEL_SSI5_0, FN_SEL_SSI5_1, FN_SEL_SSI5_2, + FN_SEL_VI3_0, FN_SEL_VI3_1, + FN_SEL_VI2_0, FN_SEL_VI2_1, + FN_SEL_VI1_0, FN_SEL_VI1_1, + FN_SEL_VI0_0, FN_SEL_VI0_1, + FN_SEL_TSIF1_0, FN_SEL_TSIF1_1, FN_SEL_TSIF1_2, + FN_SEL_LBS_0, FN_SEL_LBS_1, + FN_SEL_TSIF0_0, FN_SEL_TSIF0_1, FN_SEL_TSIF0_2, FN_SEL_TSIF0_3, + FN_SEL_SOF3_0, FN_SEL_SOF3_1, + FN_SEL_SOF0_0, FN_SEL_SOF0_1, + + FN_SEL_TMU1_0, FN_SEL_TMU1_1, + FN_SEL_HSCIF1_0, FN_SEL_HSCIF1_1, + FN_SEL_SCIFCLK_0, FN_SEL_SCIFCLK_1, + FN_SEL_CAN0_0, FN_SEL_CAN0_1, FN_SEL_CAN0_2, FN_SEL_CAN0_3, + FN_SEL_CANCLK_0, FN_SEL_CANCLK_1, + FN_SEL_SCIFA2_0, FN_SEL_SCIFA2_1, FN_SEL_SCIFA2_2, + FN_SEL_CAN1_0, FN_SEL_CAN1_1, + FN_SEL_ADI_0, FN_SEL_ADI_1, + FN_SEL_SSP_0, FN_SEL_SSP_1, + FN_SEL_FM_0, FN_SEL_FM_1, FN_SEL_FM_2, FN_SEL_FM_3, + FN_SEL_FM_4, FN_SEL_FM_5, FN_SEL_FM_6, + FN_SEL_HSCIF0_0, FN_SEL_HSCIF0_1, FN_SEL_HSCIF0_2, FN_SEL_HSCIF0_3, + FN_SEL_HSCIF0_4, FN_SEL_HSCIF0_5, + FN_SEL_GPS_0, FN_SEL_GPS_1, FN_SEL_GPS_2, + FN_SEL_RDS_0, FN_SEL_RDS_1, FN_SEL_RDS_2, + FN_SEL_RDS_3, FN_SEL_RDS_4, FN_SEL_RDS_5, + FN_SEL_SIM_0, FN_SEL_SIM_1, FN_SEL_SIM_2, + FN_SEL_SSI8_0, FN_SEL_SSI8_1, FN_SEL_SSI8_2, + + FN_SEL_IICDVFS_0, FN_SEL_IICDVFS_1, + FN_SEL_IIC0_0, FN_SEL_IIC0_1, + FN_SEL_IEB_0, FN_SEL_IEB_1, FN_SEL_IEB_2, + FN_SEL_IIC2_0, FN_SEL_IIC2_1, FN_SEL_IIC2_2, FN_SEL_IIC2_3, + FN_SEL_IIC2_4, + FN_SEL_IIC1_0, FN_SEL_IIC1_1, FN_SEL_IIC1_2, + FN_SEL_I2C2_0, FN_SEL_I2C2_1, FN_SEL_I2C2_2, FN_SEL_I2C2_3, + FN_SEL_I2C2_4, + FN_SEL_I2C1_0, FN_SEL_I2C1_1, FN_SEL_I2C1_2, + PINMUX_FUNCTION_END, + + PINMUX_MARK_BEGIN, + + VI1_DATA7_VI1_B7_MARK, + + USB0_PWEN_MARK, USB0_OVC_VBUS_MARK, + USB2_PWEN_MARK, USB2_OVC_MARK, AVS1_MARK, AVS2_MARK, + DU_DOTCLKIN0_MARK, DU_DOTCLKIN2_MARK, + + D0_MARK, MSIOF3_SCK_B_MARK, VI3_DATA0_MARK, VI0_G4_MARK, VI0_G4_B_MARK, + D1_MARK, MSIOF3_SYNC_B_MARK, VI3_DATA1_MARK, VI0_G5_MARK, + VI0_G5_B_MARK, D2_MARK, MSIOF3_RXD_B_MARK, VI3_DATA2_MARK, + VI0_G6_MARK, VI0_G6_B_MARK, D3_MARK, MSIOF3_TXD_B_MARK, + VI3_DATA3_MARK, VI0_G7_MARK, VI0_G7_B_MARK, D4_MARK, + SCIFB1_RXD_F_MARK, SCIFB0_RXD_C_MARK, VI3_DATA4_MARK, + VI0_R0_MARK, VI0_R0_B_MARK, RX0_B_MARK, D5_MARK, + SCIFB1_TXD_F_MARK, SCIFB0_TXD_C_MARK, VI3_DATA5_MARK, + VI0_R1_MARK, VI0_R1_B_MARK, TX0_B_MARK, D6_MARK, + SCL2_C_MARK, VI3_DATA6_MARK, VI0_R2_MARK, VI0_R2_B_MARK, + SCL2_CIS_C_MARK, D7_MARK, AD_DI_B_MARK, SDA2_C_MARK, + VI3_DATA7_MARK, VI0_R3_MARK, VI0_R3_B_MARK, SDA2_CIS_C_MARK, + D8_MARK, SCIFA1_SCK_C_MARK, AVB_TXD0_MARK, MII_TXD0_MARK, + VI0_G0_MARK, VI0_G0_B_MARK, VI2_DATA0_VI2_B0_MARK, + + D9_MARK, SCIFA1_RXD_C_MARK, AVB_TXD1_MARK, MII_TXD1_MARK, + VI0_G1_MARK, VI0_G1_B_MARK, VI2_DATA1_VI2_B1_MARK, D10_MARK, + SCIFA1_TXD_C_MARK, AVB_TXD2_MARK, MII_TXD2_MARK, + VI0_G2_MARK, VI0_G2_B_MARK, VI2_DATA2_VI2_B2_MARK, D11_MARK, + SCIFA1_CTS_N_C_MARK, AVB_TXD3_MARK, MII_TXD3_MARK, + VI0_G3_MARK, VI0_G3_B_MARK, VI2_DATA3_VI2_B3_MARK, + D12_MARK, SCIFA1_RTS_N_C_MARK, AVB_TXD4_MARK, + VI0_HSYNC_N_MARK, VI0_HSYNC_N_B_MARK, VI2_DATA4_VI2_B4_MARK, + D13_MARK, AVB_TXD5_MARK, VI0_VSYNC_N_MARK, + VI0_VSYNC_N_B_MARK, VI2_DATA5_VI2_B5_MARK, D14_MARK, + SCIFB1_RXD_C_MARK, AVB_TXD6_MARK, RX1_B_MARK, + VI0_CLKENB_MARK, VI0_CLKENB_B_MARK, VI2_DATA6_VI2_B6_MARK, + D15_MARK, SCIFB1_TXD_C_MARK, AVB_TXD7_MARK, TX1_B_MARK, + VI0_FIELD_MARK, VI0_FIELD_B_MARK, VI2_DATA7_VI2_B7_MARK, + A0_MARK, PWM3_MARK, A1_MARK, PWM4_MARK, + + A2_MARK, PWM5_MARK, MSIOF1_SS1_B_MARK, A3_MARK, + PWM6_MARK, MSIOF1_SS2_B_MARK, A4_MARK, MSIOF1_TXD_B_MARK, + TPU0TO0_MARK, A5_MARK, SCIFA1_TXD_B_MARK, TPU0TO1_MARK, + A6_MARK, SCIFA1_RTS_N_B_MARK, TPU0TO2_MARK, A7_MARK, + SCIFA1_SCK_B_MARK, AUDIO_CLKOUT_B_MARK, TPU0TO3_MARK, + A8_MARK, SCIFA1_RXD_B_MARK, SSI_SCK5_B_MARK, VI0_R4_MARK, + VI0_R4_B_MARK, SCIFB2_RXD_C_MARK, VI2_DATA0_VI2_B0_B_MARK, + A9_MARK, SCIFA1_CTS_N_B_MARK, SSI_WS5_B_MARK, VI0_R5_MARK, + VI0_R5_B_MARK, SCIFB2_TXD_C_MARK, VI2_DATA1_VI2_B1_B_MARK, + A10_MARK, SSI_SDATA5_B_MARK, MSIOF2_SYNC_MARK, VI0_R6_MARK, + VI0_R6_B_MARK, VI2_DATA2_VI2_B2_B_MARK, + + A11_MARK, SCIFB2_CTS_N_B_MARK, MSIOF2_SCK_MARK, VI1_R0_MARK, + VI1_R0_B_MARK, VI2_G0_MARK, VI2_DATA3_VI2_B3_B_MARK, + A12_MARK, SCIFB2_RXD_B_MARK, MSIOF2_TXD_MARK, VI1_R1_MARK, + VI1_R1_B_MARK, VI2_G1_MARK, VI2_DATA4_VI2_B4_B_MARK, + A13_MARK, SCIFB2_RTS_N_B_MARK, EX_WAIT2_MARK, + MSIOF2_RXD_MARK, VI1_R2_MARK, VI1_R2_B_MARK, VI2_G2_MARK, + VI2_DATA5_VI2_B5_B_MARK, A14_MARK, SCIFB2_TXD_B_MARK, + ATACS11_N_MARK, MSIOF2_SS1_MARK, A15_MARK, SCIFB2_SCK_B_MARK, + ATARD1_N_MARK, MSIOF2_SS2_MARK, A16_MARK, ATAWR1_N_MARK, + A17_MARK, AD_DO_B_MARK, ATADIR1_N_MARK, A18_MARK, + AD_CLK_B_MARK, ATAG1_N_MARK, A19_MARK, AD_NCS_N_B_MARK, + ATACS01_N_MARK, EX_WAIT0_B_MARK, A20_MARK, SPCLK_MARK, + VI1_R3_MARK, VI1_R3_B_MARK, VI2_G4_MARK, + + A21_MARK, MOSI_IO0_MARK, VI1_R4_MARK, VI1_R4_B_MARK, VI2_G5_MARK, + A22_MARK, MISO_IO1_MARK, VI1_R5_MARK, VI1_R5_B_MARK, + VI2_G6_MARK, A23_MARK, IO2_MARK, VI1_G7_MARK, + VI1_G7_B_MARK, VI2_G7_MARK, A24_MARK, IO3_MARK, + VI1_R7_MARK, VI1_R7_B_MARK, VI2_CLKENB_MARK, + VI2_CLKENB_B_MARK, A25_MARK, SSL_MARK, VI1_G6_MARK, + VI1_G6_B_MARK, VI2_FIELD_MARK, VI2_FIELD_B_MARK, CS0_N_MARK, + VI1_R6_MARK, VI1_R6_B_MARK, VI2_G3_MARK, MSIOF0_SS2_B_MARK, + CS1_N_A26_MARK, SPEEDIN_MARK, VI0_R7_MARK, VI0_R7_B_MARK, + VI2_CLK_MARK, VI2_CLK_B_MARK, EX_CS0_N_MARK, HRX1_B_MARK, + VI1_G5_MARK, VI1_G5_B_MARK, VI2_R0_MARK, HTX0_B_MARK, + MSIOF0_SS1_B_MARK, EX_CS1_N_MARK, GPS_CLK_MARK, + HCTS1_N_B_MARK, VI1_FIELD_MARK, VI1_FIELD_B_MARK, + VI2_R1_MARK, EX_CS2_N_MARK, GPS_SIGN_MARK, HRTS1_N_B_MARK, + VI3_CLKENB_MARK, VI1_G0_MARK, VI1_G0_B_MARK, VI2_R2_MARK, + + EX_CS3_N_MARK, GPS_MAG_MARK, VI3_FIELD_MARK, + VI1_G1_MARK, VI1_G1_B_MARK, VI2_R3_MARK, + EX_CS4_N_MARK, MSIOF1_SCK_B_MARK, VI3_HSYNC_N_MARK, + VI2_HSYNC_N_MARK, SCL1_MARK, VI2_HSYNC_N_B_MARK, + INTC_EN0_N_MARK, SCL1_CIS_MARK, EX_CS5_N_MARK, CAN0_RX_MARK, + MSIOF1_RXD_B_MARK, VI3_VSYNC_N_MARK, VI1_G2_MARK, + VI1_G2_B_MARK, VI2_R4_MARK, SDA1_MARK, INTC_EN1_N_MARK, + SDA1_CIS_MARK, BS_N_MARK, IETX_MARK, HTX1_B_MARK, + CAN1_TX_MARK, DRACK0_MARK, IETX_C_MARK, RD_N_MARK, + CAN0_TX_MARK, SCIFA0_SCK_B_MARK, RD_WR_N_MARK, VI1_G3_MARK, + VI1_G3_B_MARK, VI2_R5_MARK, SCIFA0_RXD_B_MARK, + INTC_IRQ4_N_MARK, WE0_N_MARK, IECLK_MARK, CAN_CLK_MARK, + VI2_VSYNC_N_MARK, SCIFA0_TXD_B_MARK, VI2_VSYNC_N_B_MARK, + WE1_N_MARK, IERX_MARK, CAN1_RX_MARK, VI1_G4_MARK, + VI1_G4_B_MARK, VI2_R6_MARK, SCIFA0_CTS_N_B_MARK, + IERX_C_MARK, EX_WAIT0_MARK, IRQ3_MARK, INTC_IRQ3_N_MARK, + VI3_CLK_MARK, SCIFA0_RTS_N_B_MARK, HRX0_B_MARK, + MSIOF0_SCK_B_MARK, DREQ0_N_MARK, VI1_HSYNC_N_MARK, + VI1_HSYNC_N_B_MARK, VI2_R7_MARK, SSI_SCK78_C_MARK, + SSI_WS78_B_MARK, + + DACK0_MARK, IRQ0_MARK, INTC_IRQ0_N_MARK, SSI_SCK6_B_MARK, + VI1_VSYNC_N_MARK, VI1_VSYNC_N_B_MARK, SSI_WS78_C_MARK, + DREQ1_N_MARK, VI1_CLKENB_MARK, VI1_CLKENB_B_MARK, + SSI_SDATA7_C_MARK, SSI_SCK78_B_MARK, DACK1_MARK, IRQ1_MARK, + INTC_IRQ1_N_MARK, SSI_WS6_B_MARK, SSI_SDATA8_C_MARK, + DREQ2_N_MARK, HSCK1_B_MARK, HCTS0_N_B_MARK, + MSIOF0_TXD_B_MARK, DACK2_MARK, IRQ2_MARK, INTC_IRQ2_N_MARK, + SSI_SDATA6_B_MARK, HRTS0_N_B_MARK, MSIOF0_RXD_B_MARK, + ETH_CRS_DV_MARK, RMII_CRS_DV_MARK, STP_ISCLK_0_B_MARK, + TS_SDEN0_D_MARK, GLO_Q0_C_MARK, SCL2_E_MARK, + SCL2_CIS_E_MARK, ETH_RX_ER_MARK, RMII_RX_ER_MARK, + STP_ISD_0_B_MARK, TS_SPSYNC0_D_MARK, GLO_Q1_C_MARK, + SDA2_E_MARK, SDA2_CIS_E_MARK, ETH_RXD0_MARK, RMII_RXD0_MARK, + STP_ISEN_0_B_MARK, TS_SDAT0_D_MARK, GLO_I0_C_MARK, + SCIFB1_SCK_G_MARK, SCK1_E_MARK, ETH_RXD1_MARK, + RMII_RXD1_MARK, HRX0_E_MARK, STP_ISSYNC_0_B_MARK, + TS_SCK0_D_MARK, GLO_I1_C_MARK, SCIFB1_RXD_G_MARK, + RX1_E_MARK, ETH_LINK_MARK, RMII_LINK_MARK, HTX0_E_MARK, + STP_IVCXO27_0_B_MARK, SCIFB1_TXD_G_MARK, TX1_E_MARK, + ETH_REF_CLK_MARK, RMII_REF_CLK_MARK, HCTS0_N_E_MARK, + STP_IVCXO27_1_B_MARK, HRX0_F_MARK, + + ETH_MDIO_MARK, RMII_MDIO_MARK, HRTS0_N_E_MARK, + SIM0_D_C_MARK, HCTS0_N_F_MARK, ETH_TXD1_MARK, + RMII_TXD1_MARK, HTX0_F_MARK, BPFCLK_G_MARK, RDS_CLK_F_MARK, + ETH_TX_EN_MARK, RMII_TX_EN_MARK, SIM0_CLK_C_MARK, + HRTS0_N_F_MARK, ETH_MAGIC_MARK, RMII_MAGIC_MARK, + SIM0_RST_C_MARK, ETH_TXD0_MARK, RMII_TXD0_MARK, + STP_ISCLK_1_B_MARK, TS_SDEN1_C_MARK, GLO_SCLK_C_MARK, + ETH_MDC_MARK, RMII_MDC_MARK, STP_ISD_1_B_MARK, + TS_SPSYNC1_C_MARK, GLO_SDATA_C_MARK, PWM0_MARK, + SCIFA2_SCK_C_MARK, STP_ISEN_1_B_MARK, TS_SDAT1_C_MARK, + GLO_SS_C_MARK, PWM1_MARK, SCIFA2_TXD_C_MARK, + STP_ISSYNC_1_B_MARK, TS_SCK1_C_MARK, GLO_RFON_C_MARK, + PCMOE_N_MARK, PWM2_MARK, PWMFSW0_MARK, SCIFA2_RXD_C_MARK, + PCMWE_N_MARK, IECLK_C_MARK, DU1_DOTCLKIN_MARK, + AUDIO_CLKC_MARK, AUDIO_CLKOUT_C_MARK, VI0_CLK_MARK, + ATACS00_N_MARK, AVB_RXD1_MARK, MII_RXD1_MARK, + VI0_DATA0_VI0_B0_MARK, ATACS10_N_MARK, AVB_RXD2_MARK, + MII_RXD2_MARK, + + VI0_DATA1_VI0_B1_MARK, ATARD0_N_MARK, AVB_RXD3_MARK, + MII_RXD3_MARK, VI0_DATA2_VI0_B2_MARK, ATAWR0_N_MARK, + AVB_RXD4_MARK, VI0_DATA3_VI0_B3_MARK, ATADIR0_N_MARK, + AVB_RXD5_MARK, VI0_DATA4_VI0_B4_MARK, ATAG0_N_MARK, + AVB_RXD6_MARK, VI0_DATA5_VI0_B5_MARK, EX_WAIT1_MARK, + AVB_RXD7_MARK, VI0_DATA6_VI0_B6_MARK, AVB_RX_ER_MARK, + MII_RX_ER_MARK, VI0_DATA7_VI0_B7_MARK, AVB_RX_CLK_MARK, + MII_RX_CLK_MARK, VI1_CLK_MARK, AVB_RX_DV_MARK, + MII_RX_DV_MARK, VI1_DATA0_VI1_B0_MARK, SCIFA1_SCK_D_MARK, + AVB_CRS_MARK, MII_CRS_MARK, VI1_DATA1_VI1_B1_MARK, + SCIFA1_RXD_D_MARK, AVB_MDC_MARK, MII_MDC_MARK, + VI1_DATA2_VI1_B2_MARK, SCIFA1_TXD_D_MARK, AVB_MDIO_MARK, + MII_MDIO_MARK, VI1_DATA3_VI1_B3_MARK, SCIFA1_CTS_N_D_MARK, + AVB_GTX_CLK_MARK, VI1_DATA4_VI1_B4_MARK, SCIFA1_RTS_N_D_MARK, + AVB_MAGIC_MARK, MII_MAGIC_MARK, VI1_DATA5_VI1_B5_MARK, + AVB_PHY_INT_MARK, VI1_DATA6_VI1_B6_MARK, AVB_GTXREFCLK_MARK, + SD0_CLK_MARK, VI1_DATA0_VI1_B0_B_MARK, SD0_CMD_MARK, + SCIFB1_SCK_B_MARK, VI1_DATA1_VI1_B1_B_MARK, + + SD0_DAT0_MARK, SCIFB1_RXD_B_MARK, VI1_DATA2_VI1_B2_B_MARK, + SD0_DAT1_MARK, SCIFB1_TXD_B_MARK, VI1_DATA3_VI1_B3_B_MARK, + SD0_DAT2_MARK, SCIFB1_CTS_N_B_MARK, VI1_DATA4_VI1_B4_B_MARK, + SD0_DAT3_MARK, SCIFB1_RTS_N_B_MARK, VI1_DATA5_VI1_B5_B_MARK, + SD0_CD_MARK, MMC0_D6_MARK, TS_SDEN0_B_MARK, USB0_EXTP_MARK, + GLO_SCLK_MARK, VI1_DATA6_VI1_B6_B_MARK, SCL1_B_MARK, + SCL1_CIS_B_MARK, VI2_DATA6_VI2_B6_B_MARK, SD0_WP_MARK, + MMC0_D7_MARK, TS_SPSYNC0_B_MARK, USB0_IDIN_MARK, + GLO_SDATA_MARK, VI1_DATA7_VI1_B7_B_MARK, SDA1_B_MARK, + SDA1_CIS_B_MARK, VI2_DATA7_VI2_B7_B_MARK, SD1_CLK_MARK, + AVB_TX_EN_MARK, MII_TX_EN_MARK, SD1_CMD_MARK, + AVB_TX_ER_MARK, MII_TX_ER_MARK, SCIFB0_SCK_B_MARK, + SD1_DAT0_MARK, AVB_TX_CLK_MARK, MII_TX_CLK_MARK, + SCIFB0_RXD_B_MARK, SD1_DAT1_MARK, AVB_LINK_MARK, + MII_LINK_MARK, SCIFB0_TXD_B_MARK, SD1_DAT2_MARK, + AVB_COL_MARK, MII_COL_MARK, SCIFB0_CTS_N_B_MARK, + SD1_DAT3_MARK, AVB_RXD0_MARK, MII_RXD0_MARK, + SCIFB0_RTS_N_B_MARK, SD1_CD_MARK, MMC1_D6_MARK, + TS_SDEN1_MARK, USB1_EXTP_MARK, GLO_SS_MARK, VI0_CLK_B_MARK, + SCL2_D_MARK, SCL2_CIS_D_MARK, SIM0_CLK_B_MARK, + VI3_CLK_B_MARK, + + SD1_WP_MARK, MMC1_D7_MARK, TS_SPSYNC1_MARK, USB1_IDIN_MARK, + GLO_RFON_MARK, VI1_CLK_B_MARK, SDA2_D_MARK, SDA2_CIS_D_MARK, + SIM0_D_B_MARK, SD2_CLK_MARK, MMC0_CLK_MARK, SIM0_CLK_MARK, + VI0_DATA0_VI0_B0_B_MARK, TS_SDEN0_C_MARK, GLO_SCLK_B_MARK, + VI3_DATA0_B_MARK, SD2_CMD_MARK, MMC0_CMD_MARK, SIM0_D_MARK, + VI0_DATA1_VI0_B1_B_MARK, SCIFB1_SCK_E_MARK, SCK1_D_MARK, + TS_SPSYNC0_C_MARK, GLO_SDATA_B_MARK, VI3_DATA1_B_MARK, + SD2_DAT0_MARK, MMC0_D0_MARK, FMCLK_B_MARK, + VI0_DATA2_VI0_B2_B_MARK, SCIFB1_RXD_E_MARK, RX1_D_MARK, + TS_SDAT0_C_MARK, GLO_SS_B_MARK, VI3_DATA2_B_MARK, + SD2_DAT1_MARK, MMC0_D1_MARK, FMIN_B_MARK, RDS_DATA_MARK, + VI0_DATA3_VI0_B3_B_MARK, SCIFB1_TXD_E_MARK, TX1_D_MARK, + TS_SCK0_C_MARK, GLO_RFON_B_MARK, VI3_DATA3_B_MARK, + SD2_DAT2_MARK, MMC0_D2_MARK, BPFCLK_B_MARK, RDS_CLK_MARK, + VI0_DATA4_VI0_B4_B_MARK, HRX0_D_MARK, TS_SDEN1_B_MARK, + GLO_Q0_B_MARK, VI3_DATA4_B_MARK, SD2_DAT3_MARK, + MMC0_D3_MARK, SIM0_RST_MARK, VI0_DATA5_VI0_B5_B_MARK, + HTX0_D_MARK, TS_SPSYNC1_B_MARK, GLO_Q1_B_MARK, + VI3_DATA5_B_MARK, SD2_CD_MARK, MMC0_D4_MARK, + TS_SDAT0_B_MARK, USB2_EXTP_MARK, GLO_I0_MARK, + VI0_DATA6_VI0_B6_B_MARK, HCTS0_N_D_MARK, TS_SDAT1_B_MARK, + GLO_I0_B_MARK, VI3_DATA6_B_MARK, + + SD2_WP_MARK, MMC0_D5_MARK, TS_SCK0_B_MARK, USB2_IDIN_MARK, + GLO_I1_MARK, VI0_DATA7_VI0_B7_B_MARK, HRTS0_N_D_MARK, + TS_SCK1_B_MARK, GLO_I1_B_MARK, VI3_DATA7_B_MARK, + SD3_CLK_MARK, MMC1_CLK_MARK, SD3_CMD_MARK, MMC1_CMD_MARK, + MTS_N_MARK, SD3_DAT0_MARK, MMC1_D0_MARK, STM_N_MARK, + SD3_DAT1_MARK, MMC1_D1_MARK, MDATA_MARK, SD3_DAT2_MARK, + MMC1_D2_MARK, SDATA_MARK, SD3_DAT3_MARK, MMC1_D3_MARK, + SCKZ_MARK, SD3_CD_MARK, MMC1_D4_MARK, TS_SDAT1_MARK, + VSP_MARK, GLO_Q0_MARK, SIM0_RST_B_MARK, SD3_WP_MARK, + MMC1_D5_MARK, TS_SCK1_MARK, GLO_Q1_MARK, FMIN_C_MARK, + RDS_DATA_B_MARK, FMIN_E_MARK, RDS_DATA_D_MARK, FMIN_F_MARK, + RDS_DATA_E_MARK, MLB_CLK_MARK, SCL2_B_MARK, SCL2_CIS_B_MARK, + MLB_SIG_MARK, SCIFB1_RXD_D_MARK, RX1_C_MARK, SDA2_B_MARK, + SDA2_CIS_B_MARK, MLB_DAT_MARK, SPV_EVEN_MARK, + SCIFB1_TXD_D_MARK, TX1_C_MARK, BPFCLK_C_MARK, + RDS_CLK_B_MARK, SSI_SCK0129_MARK, CAN_CLK_B_MARK, + MOUT0_MARK, + + SSI_WS0129_MARK, CAN0_TX_B_MARK, MOUT1_MARK, + SSI_SDATA0_MARK, CAN0_RX_B_MARK, MOUT2_MARK, + SSI_SDATA1_MARK, CAN1_TX_B_MARK, MOUT5_MARK, + SSI_SDATA2_MARK, CAN1_RX_B_MARK, SSI_SCK1_MARK, MOUT6_MARK, + SSI_SCK34_MARK, STP_OPWM_0_MARK, SCIFB0_SCK_MARK, + MSIOF1_SCK_MARK, CAN_DEBUG_HW_TRIGGER_MARK, SSI_WS34_MARK, + STP_IVCXO27_0_MARK, SCIFB0_RXD_MARK, MSIOF1_SYNC_MARK, + CAN_STEP0_MARK, SSI_SDATA3_MARK, STP_ISCLK_0_MARK, + SCIFB0_TXD_MARK, MSIOF1_SS1_MARK, CAN_TXCLK_MARK, + SSI_SCK4_MARK, STP_ISD_0_MARK, SCIFB0_CTS_N_MARK, + MSIOF1_SS2_MARK, SSI_SCK5_C_MARK, CAN_DEBUGOUT0_MARK, + SSI_WS4_MARK, STP_ISEN_0_MARK, SCIFB0_RTS_N_MARK, + MSIOF1_TXD_MARK, SSI_WS5_C_MARK, CAN_DEBUGOUT1_MARK, + SSI_SDATA4_MARK, STP_ISSYNC_0_MARK, MSIOF1_RXD_MARK, + CAN_DEBUGOUT2_MARK, SSI_SCK5_MARK, SCIFB1_SCK_MARK, + IERX_B_MARK, DU2_EXHSYNC_DU2_HSYNC_MARK, QSTH_QHS_MARK, + CAN_DEBUGOUT3_MARK, SSI_WS5_MARK, SCIFB1_RXD_MARK, + IECLK_B_MARK, DU2_EXVSYNC_DU2_VSYNC_MARK, QSTB_QHE_MARK, + CAN_DEBUGOUT4_MARK, + + SSI_SDATA5_MARK, SCIFB1_TXD_MARK, IETX_B_MARK, DU2_DR2_MARK, + LCDOUT2_MARK, CAN_DEBUGOUT5_MARK, SSI_SCK6_MARK, + SCIFB1_CTS_N_MARK, BPFCLK_D_MARK, RDS_CLK_C_MARK, + DU2_DR3_MARK, LCDOUT3_MARK, CAN_DEBUGOUT6_MARK, + BPFCLK_F_MARK, RDS_CLK_E_MARK, SSI_WS6_MARK, + SCIFB1_RTS_N_MARK, CAN0_TX_D_MARK, DU2_DR4_MARK, + LCDOUT4_MARK, CAN_DEBUGOUT7_MARK, SSI_SDATA6_MARK, + FMIN_D_MARK, RDS_DATA_C_MARK, DU2_DR5_MARK, LCDOUT5_MARK, + CAN_DEBUGOUT8_MARK, SSI_SCK78_MARK, STP_IVCXO27_1_MARK, + SCK1_MARK, SCIFA1_SCK_MARK, DU2_DR6_MARK, LCDOUT6_MARK, + CAN_DEBUGOUT9_MARK, SSI_WS78_MARK, STP_ISCLK_1_MARK, + SCIFB2_SCK_MARK, SCIFA2_CTS_N_MARK, DU2_DR7_MARK, + LCDOUT7_MARK, CAN_DEBUGOUT10_MARK, SSI_SDATA7_MARK, + STP_ISD_1_MARK, SCIFB2_RXD_MARK, SCIFA2_RTS_N_MARK, + TCLK2_MARK, QSTVA_QVS_MARK, CAN_DEBUGOUT11_MARK, + BPFCLK_E_MARK, RDS_CLK_D_MARK, SSI_SDATA7_B_MARK, + FMIN_G_MARK, RDS_DATA_F_MARK, SSI_SDATA8_MARK, + STP_ISEN_1_MARK, SCIFB2_TXD_MARK, CAN0_TX_C_MARK, + CAN_DEBUGOUT12_MARK, SSI_SDATA8_B_MARK, SSI_SDATA9_MARK, + STP_ISSYNC_1_MARK, SCIFB2_CTS_N_MARK, SSI_WS1_MARK, + SSI_SDATA5_C_MARK, CAN_DEBUGOUT13_MARK, AUDIO_CLKA_MARK, + SCIFB2_RTS_N_MARK, CAN_DEBUGOUT14_MARK, + + AUDIO_CLKB_MARK, SCIF_CLK_MARK, CAN0_RX_D_MARK, + DVC_MUTE_MARK, CAN0_RX_C_MARK, CAN_DEBUGOUT15_MARK, + REMOCON_MARK, SCIFA0_SCK_MARK, HSCK1_MARK, SCK0_MARK, + MSIOF3_SS2_MARK, DU2_DG2_MARK, LCDOUT10_MARK, SDA1_C_MARK, + SDA1_CIS_C_MARK, SCIFA0_RXD_MARK, HRX1_MARK, RX0_MARK, + DU2_DR0_MARK, LCDOUT0_MARK, SCIFA0_TXD_MARK, HTX1_MARK, + TX0_MARK, DU2_DR1_MARK, LCDOUT1_MARK, SCIFA0_CTS_N_MARK, + HCTS1_N_MARK, CTS0_N_MARK, MSIOF3_SYNC_MARK, DU2_DG3_MARK, + LCDOUT11_MARK, PWM0_B_MARK, SCL1_C_MARK, SCL1_CIS_C_MARK, + SCIFA0_RTS_N_MARK, HRTS1_N_MARK, RTS0_N_TANS_MARK, + MSIOF3_SS1_MARK, DU2_DG0_MARK, LCDOUT8_MARK, PWM1_B_MARK, + SCIFA1_RXD_MARK, AD_DI_MARK, RX1_MARK, + DU2_EXODDF_DU2_ODDF_DISP_CDE_MARK, QCPV_QDE_MARK, + SCIFA1_TXD_MARK, AD_DO_MARK, TX1_MARK, DU2_DG1_MARK, + LCDOUT9_MARK, SCIFA1_CTS_N_MARK, AD_CLK_MARK, + CTS1_N_MARK, MSIOF3_RXD_MARK, DU0_DOTCLKOUT_MARK, QCLK_MARK, + SCIFA1_RTS_N_MARK, AD_NCS_N_MARK, RTS1_N_TANS_MARK, + MSIOF3_TXD_MARK, DU1_DOTCLKOUT_MARK, QSTVB_QVE_MARK, + HRTS0_N_C_MARK, + + SCIFA2_SCK_MARK, FMCLK_MARK, MSIOF3_SCK_MARK, DU2_DG7_MARK, + LCDOUT15_MARK, SCIF_CLK_B_MARK, SCIFA2_RXD_MARK, FMIN_MARK, + DU2_DB0_MARK, LCDOUT16_MARK, SCL2_MARK, SCL2_CIS_MARK, + SCIFA2_TXD_MARK, BPFCLK_MARK, DU2_DB1_MARK, LCDOUT17_MARK, + SDA2_MARK, SDA2_CIS_MARK, HSCK0_MARK, TS_SDEN0_MARK, + DU2_DG4_MARK, LCDOUT12_MARK, HCTS0_N_C_MARK, HRX0_MARK, + DU2_DB2_MARK, LCDOUT18_MARK, HTX0_MARK, DU2_DB3_MARK, + LCDOUT19_MARK, HCTS0_N_MARK, SSI_SCK9_MARK, DU2_DB4_MARK, + LCDOUT20_MARK, HRTS0_N_MARK, SSI_WS9_MARK, DU2_DB5_MARK, + LCDOUT21_MARK, MSIOF0_SCK_MARK, TS_SDAT0_MARK, ADICLK_MARK, + DU2_DB6_MARK, LCDOUT22_MARK, MSIOF0_SYNC_MARK, TS_SCK0_MARK, + SSI_SCK2_MARK, ADIDATA_MARK, DU2_DB7_MARK, LCDOUT23_MARK, + SCIFA2_RXD_B_MARK, MSIOF0_SS1_MARK, ADICHS0_MARK, + DU2_DG5_MARK, LCDOUT13_MARK, MSIOF0_TXD_MARK, ADICHS1_MARK, + DU2_DG6_MARK, LCDOUT14_MARK, + + MSIOF0_SS2_MARK, AUDIO_CLKOUT_MARK, ADICHS2_MARK, + DU2_DISP_MARK, QPOLA_MARK, HTX0_C_MARK, SCIFA2_TXD_B_MARK, + MSIOF0_RXD_MARK, TS_SPSYNC0_MARK, SSI_WS2_MARK, + ADICS_SAMP_MARK, DU2_CDE_MARK, QPOLB_MARK, HRX0_C_MARK, + USB1_PWEN_MARK, AUDIO_CLKOUT_D_MARK, USB1_OVC_MARK, + TCLK1_B_MARK, + PINMUX_MARK_END, +}; + +static pinmux_enum_t pinmux_data[] = { + PINMUX_DATA_GP_ALL(), /* PINMUX_DATA(GP_M_N_DATA, GP_M_N_FN...), */ + + PINMUX_DATA(VI1_DATA7_VI1_B7_MARK, FN_VI1_DATA7_VI1_B7), + PINMUX_DATA(USB0_PWEN_MARK, FN_USB0_PWEN), + PINMUX_DATA(USB0_OVC_VBUS_MARK, FN_USB0_OVC_VBUS), + PINMUX_DATA(USB2_PWEN_MARK, FN_USB2_PWEN), + PINMUX_DATA(USB2_OVC_MARK, FN_USB2_OVC), + PINMUX_DATA(AVS1_MARK, FN_AVS1), + PINMUX_DATA(AVS2_MARK, FN_AVS2), + PINMUX_DATA(DU_DOTCLKIN0_MARK, FN_DU_DOTCLKIN0), + PINMUX_DATA(DU_DOTCLKIN2_MARK, FN_DU_DOTCLKIN2), + + PINMUX_IPSR_DATA(IP0_2_0, D0), + PINMUX_IPSR_MODSEL_DATA(IP0_2_0, MSIOF3_SCK_B, SEL_SOF3_1), + PINMUX_IPSR_MODSEL_DATA(IP0_2_0, VI3_DATA0, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_2_0, VI0_G4, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_2_0, VI0_G4_B, SEL_VI0_1), + PINMUX_IPSR_DATA(IP0_5_3, D1), + PINMUX_IPSR_MODSEL_DATA(IP0_5_3, MSIOF3_SYNC_B, SEL_SOF3_1), + PINMUX_IPSR_MODSEL_DATA(IP0_5_3, VI3_DATA1, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_5_3, VI0_G5, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_5_3, VI0_G5_B, SEL_VI0_1), + PINMUX_IPSR_DATA(IP0_8_6, D2), + PINMUX_IPSR_MODSEL_DATA(IP0_8_6, MSIOF3_RXD_B, SEL_SOF3_1), + PINMUX_IPSR_MODSEL_DATA(IP0_8_6, VI3_DATA2, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_8_6, VI0_G6, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_8_6, VI0_G6_B, SEL_VI0_1), + PINMUX_IPSR_DATA(IP0_11_9, D3), + PINMUX_IPSR_MODSEL_DATA(IP0_11_9, MSIOF3_TXD_B, SEL_SOF3_1), + PINMUX_IPSR_MODSEL_DATA(IP0_11_9, VI3_DATA3, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_11_9, VI0_G7, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_11_9, VI0_G7_B, SEL_VI0_1), + PINMUX_IPSR_DATA(IP0_15_12, D4), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, SCIFB1_RXD_F, SEL_SCIFB1_5), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, SCIFB0_RXD_C, SEL_SCIFB_2), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, VI3_DATA4, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, VI0_R0, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, VI0_R0_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP0_15_12, RX0_B, SEL_SCIF0_1), + PINMUX_IPSR_DATA(IP0_19_16, D5), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, SCIFB1_TXD_F, SEL_SCIFB1_5), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, SCIFB0_TXD_C, SEL_SCIFB_2), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, VI3_DATA5, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, VI0_R1, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, VI0_R1_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP0_19_16, TX0_B, SEL_SCIF0_1), + PINMUX_IPSR_DATA(IP0_22_20, D6), + PINMUX_IPSR_MODSEL_DATA(IP0_22_20, SCL2_C, SEL_IIC2_2), + PINMUX_IPSR_MODSEL_DATA(IP0_22_20, VI3_DATA6, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_22_20, VI0_R2, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_22_20, VI0_R2_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP0_22_20, SCL2_CIS_C, SEL_I2C2_2), + PINMUX_IPSR_DATA(IP0_26_23, D7), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, AD_DI_B, SEL_ADI_1), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, SDA2_C, SEL_IIC2_2), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, VI3_DATA7, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, VI0_R3, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, VI0_R3_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP0_26_23, SDA2_CIS_C, SEL_I2C2_2), + PINMUX_IPSR_DATA(IP0_30_27, D8), + PINMUX_IPSR_MODSEL_DATA(IP0_30_27, SCIFA1_SCK_C, SEL_SCIFA1_2), + PINMUX_IPSR_DATA(IP0_30_27, AVB_TXD0), + PINMUX_IPSR_DATA(IP0_30_27, MII_TXD0), + PINMUX_IPSR_MODSEL_DATA(IP0_30_27, VI0_G0, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP0_30_27, VI0_G0_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP0_30_27, VI2_DATA0_VI2_B0, SEL_VI2_0), + + PINMUX_IPSR_DATA(IP1_3_0, D9), + PINMUX_IPSR_MODSEL_DATA(IP1_3_0, SCIFA1_RXD_C, SEL_SCIFA1_2), + PINMUX_IPSR_DATA(IP1_3_0, AVB_TXD1), + PINMUX_IPSR_DATA(IP1_3_0, MII_TXD1), + PINMUX_IPSR_MODSEL_DATA(IP1_3_0, VI0_G1, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_3_0, VI0_G1_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_3_0, VI2_DATA1_VI2_B1, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_7_4, D10), + PINMUX_IPSR_MODSEL_DATA(IP1_7_4, SCIFA1_TXD_C, SEL_SCIFA1_2), + PINMUX_IPSR_DATA(IP1_7_4, AVB_TXD2), + PINMUX_IPSR_DATA(IP1_7_4, MII_TXD2), + PINMUX_IPSR_MODSEL_DATA(IP1_7_4, VI0_G2, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_7_4, VI0_G2_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_7_4, VI2_DATA2_VI2_B2, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_11_8, D11), + PINMUX_IPSR_MODSEL_DATA(IP1_11_8, SCIFA1_CTS_N_C, SEL_SCIFA1_2), + PINMUX_IPSR_DATA(IP1_11_8, AVB_TXD3), + PINMUX_IPSR_DATA(IP1_11_8, MII_TXD3), + PINMUX_IPSR_MODSEL_DATA(IP1_11_8, VI0_G3, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_11_8, VI0_G3_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_11_8, VI2_DATA3_VI2_B3, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_14_12, D12), + PINMUX_IPSR_MODSEL_DATA(IP1_14_12, SCIFA1_RTS_N_C, SEL_SCIFA1_2), + PINMUX_IPSR_DATA(IP1_14_12, AVB_TXD4), + PINMUX_IPSR_MODSEL_DATA(IP1_14_12, VI0_HSYNC_N, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_14_12, VI0_HSYNC_N_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_14_12, VI2_DATA4_VI2_B4, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_17_15, D13), + PINMUX_IPSR_MODSEL_DATA(IP1_17_15, AVB_TXD5, SEL_SCIFA1_2), + PINMUX_IPSR_MODSEL_DATA(IP1_17_15, VI0_VSYNC_N, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_17_15, VI0_VSYNC_N_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_17_15, VI2_DATA5_VI2_B5, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_21_18, D14), + PINMUX_IPSR_MODSEL_DATA(IP1_21_18, SCIFB1_RXD_C, SEL_SCIFB1_2), + PINMUX_IPSR_DATA(IP1_21_18, AVB_TXD6), + PINMUX_IPSR_MODSEL_DATA(IP1_21_18, RX1_B, SEL_SCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP1_21_18, VI0_CLKENB, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_21_18, VI0_CLKENB_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_21_18, VI2_DATA6_VI2_B6, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_25_22, D15), + PINMUX_IPSR_MODSEL_DATA(IP1_25_22, SCIFB1_TXD_C, SEL_SCIFB1_2), + PINMUX_IPSR_DATA(IP1_25_22, AVB_TXD7), + PINMUX_IPSR_MODSEL_DATA(IP1_25_22, TX1_B, SEL_SCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP1_25_22, VI0_FIELD, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP1_25_22, VI0_FIELD_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP1_25_22, VI2_DATA7_VI2_B7, SEL_VI2_0), + PINMUX_IPSR_DATA(IP1_27_26, A0), + PINMUX_IPSR_DATA(IP1_27_26, PWM3), + PINMUX_IPSR_DATA(IP1_29_28, A1), + PINMUX_IPSR_DATA(IP1_29_28, PWM4), + + PINMUX_IPSR_DATA(IP2_2_0, A2), + PINMUX_IPSR_DATA(IP2_2_0, PWM5), + PINMUX_IPSR_MODSEL_DATA(IP2_2_0, MSIOF1_SS1_B, SEL_SOF1_1), + PINMUX_IPSR_DATA(IP2_5_3, A3), + PINMUX_IPSR_DATA(IP2_5_3, PWM6), + PINMUX_IPSR_MODSEL_DATA(IP2_5_3, MSIOF1_SS2_B, SEL_SOF1_1), + PINMUX_IPSR_DATA(IP2_8_6, A4), + PINMUX_IPSR_MODSEL_DATA(IP2_8_6, MSIOF1_TXD_B, SEL_SOF1_1), + PINMUX_IPSR_DATA(IP2_8_6, TPU0TO0), + PINMUX_IPSR_DATA(IP2_11_9, A5), + PINMUX_IPSR_MODSEL_DATA(IP2_11_9, SCIFA1_TXD_B, SEL_SCIFA1_1), + PINMUX_IPSR_DATA(IP2_11_9, TPU0TO1), + PINMUX_IPSR_DATA(IP2_14_12, A6), + PINMUX_IPSR_MODSEL_DATA(IP2_14_12, SCIFA1_RTS_N_B, SEL_SCIFA1_1), + PINMUX_IPSR_DATA(IP2_14_12, TPU0TO2), + PINMUX_IPSR_DATA(IP2_17_15, A7), + PINMUX_IPSR_MODSEL_DATA(IP2_17_15, SCIFA1_SCK_B, SEL_SCIFA1_1), + PINMUX_IPSR_DATA(IP2_17_15, AUDIO_CLKOUT_B), + PINMUX_IPSR_DATA(IP2_17_15, TPU0TO3), + PINMUX_IPSR_DATA(IP2_21_18, A8), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, SCIFA1_RXD_B, SEL_SCIFA1_1), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, SSI_SCK5_B, SEL_SSI5_1), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, VI0_R4, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, VI0_R4_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, SCIFB2_RXD_C, SEL_SCIFB2_2), + PINMUX_IPSR_MODSEL_DATA(IP2_21_18, VI2_DATA0_VI2_B0_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP2_25_22, A9), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, SCIFA1_CTS_N_B, SEL_SCIFA1_1), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, SSI_WS5_B, SEL_SSI5_1), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, VI0_R5, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, VI0_R5_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, SCIFB2_TXD_C, SEL_SCIFB2_2), + PINMUX_IPSR_MODSEL_DATA(IP2_25_22, VI2_DATA1_VI2_B1_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP2_28_26, A10), + PINMUX_IPSR_MODSEL_DATA(IP2_28_26, SSI_SDATA5_B, SEL_SSI5_1), + PINMUX_IPSR_DATA(IP2_28_26, MSIOF2_SYNC), + PINMUX_IPSR_MODSEL_DATA(IP2_28_26, VI0_R6, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP2_28_26, VI0_R6_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP2_28_26, VI2_DATA2_VI2_B2_B, SEL_VI2_1), + + PINMUX_IPSR_DATA(IP3_3_0, A11), + PINMUX_IPSR_MODSEL_DATA(IP3_3_0, SCIFB2_CTS_N_B, SEL_SCIFB2_1), + PINMUX_IPSR_DATA(IP3_3_0, MSIOF2_SCK), + PINMUX_IPSR_MODSEL_DATA(IP3_3_0, VI1_R0, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP3_3_0, VI1_R0_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP3_3_0, VI2_G0), + PINMUX_IPSR_DATA(IP3_3_0, VI2_DATA3_VI2_B3_B), + PINMUX_IPSR_DATA(IP3_7_4, A12), + PINMUX_IPSR_MODSEL_DATA(IP3_7_4, SCIFB2_RXD_B, SEL_SCIFB2_1), + PINMUX_IPSR_DATA(IP3_7_4, MSIOF2_TXD), + PINMUX_IPSR_MODSEL_DATA(IP3_7_4, VI1_R1, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP3_7_4, VI1_R1_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP3_7_4, VI2_G1), + PINMUX_IPSR_DATA(IP3_7_4, VI2_DATA4_VI2_B4_B), + PINMUX_IPSR_DATA(IP3_11_8, A13), + PINMUX_IPSR_MODSEL_DATA(IP3_11_8, SCIFB2_RTS_N_B, SEL_SCIFB2_1), + PINMUX_IPSR_DATA(IP3_11_8, EX_WAIT2), + PINMUX_IPSR_DATA(IP3_11_8, MSIOF2_RXD), + PINMUX_IPSR_MODSEL_DATA(IP3_11_8, VI1_R2, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP3_11_8, VI1_R2_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP3_11_8, VI2_G2), + PINMUX_IPSR_MODSEL_DATA(IP3_11_8, VI2_DATA5_VI2_B5_B, SEL_VI2_0), + PINMUX_IPSR_DATA(IP3_14_12, A14), + PINMUX_IPSR_MODSEL_DATA(IP3_14_12, SCIFB2_TXD_B, SEL_SCIFB2_1), + PINMUX_IPSR_DATA(IP3_14_12, ATACS11_N), + PINMUX_IPSR_DATA(IP3_14_12, MSIOF2_SS1), + PINMUX_IPSR_DATA(IP3_17_15, A15), + PINMUX_IPSR_MODSEL_DATA(IP3_17_15, SCIFB2_SCK_B, SEL_SCIFB2_1), + PINMUX_IPSR_DATA(IP3_17_15, ATARD1_N), + PINMUX_IPSR_DATA(IP3_17_15, MSIOF2_SS2), + PINMUX_IPSR_DATA(IP3_19_18, A16), + PINMUX_IPSR_DATA(IP3_19_18, ATAWR1_N), + PINMUX_IPSR_DATA(IP3_22_20, A17), + PINMUX_IPSR_MODSEL_DATA(IP3_22_20, AD_DO_B, SEL_ADI_1), + PINMUX_IPSR_DATA(IP3_22_20, ATADIR1_N), + PINMUX_IPSR_DATA(IP3_25_23, A18), + PINMUX_IPSR_MODSEL_DATA(IP3_25_23, AD_CLK_B, SEL_ADI_1), + PINMUX_IPSR_DATA(IP3_25_23, ATAG1_N), + PINMUX_IPSR_DATA(IP3_28_26, A19), + PINMUX_IPSR_MODSEL_DATA(IP3_28_26, AD_NCS_N_B, SEL_ADI_1), + PINMUX_IPSR_DATA(IP3_28_26, ATACS01_N), + PINMUX_IPSR_MODSEL_DATA(IP3_28_26, EX_WAIT0_B, SEL_LBS_1), + PINMUX_IPSR_DATA(IP3_31_29, A20), + PINMUX_IPSR_DATA(IP3_31_29, SPCLK), + PINMUX_IPSR_MODSEL_DATA(IP3_31_29, VI1_R3, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP3_31_29, VI1_R3_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP3_31_29, VI2_G4), + + PINMUX_IPSR_DATA(IP4_2_0, A21), + PINMUX_IPSR_DATA(IP4_2_0, MOSI_IO0), + PINMUX_IPSR_MODSEL_DATA(IP4_2_0, VI1_R4, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_2_0, VI1_R4_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_2_0, VI2_G5), + PINMUX_IPSR_DATA(IP4_5_3, A22), + PINMUX_IPSR_DATA(IP4_5_3, MISO_IO1), + PINMUX_IPSR_MODSEL_DATA(IP4_5_3, VI1_R5, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_5_3, VI1_R5_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_5_3, VI2_G6), + PINMUX_IPSR_DATA(IP4_8_6, A23), + PINMUX_IPSR_DATA(IP4_8_6, IO2), + PINMUX_IPSR_MODSEL_DATA(IP4_8_6, VI1_G7, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_8_6, VI1_G7_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_8_6, VI2_G7), + PINMUX_IPSR_DATA(IP4_11_9, A24), + PINMUX_IPSR_DATA(IP4_11_9, IO3), + PINMUX_IPSR_MODSEL_DATA(IP4_11_9, VI1_R7, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_11_9, VI1_R7_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP4_11_9, VI2_CLKENB, SEL_VI2_0), + PINMUX_IPSR_MODSEL_DATA(IP4_11_9, VI2_CLKENB_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP4_14_12, A25), + PINMUX_IPSR_DATA(IP4_14_12, SSL), + PINMUX_IPSR_MODSEL_DATA(IP4_14_12, VI1_G6, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_14_12, VI1_G6_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP4_14_12, VI2_FIELD, SEL_VI2_0), + PINMUX_IPSR_MODSEL_DATA(IP4_14_12, VI2_FIELD_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP4_17_15, CS0_N), + PINMUX_IPSR_MODSEL_DATA(IP4_17_15, VI1_R6, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_17_15, VI1_R6_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_17_15, VI2_G3), + PINMUX_IPSR_MODSEL_DATA(IP4_17_15, MSIOF0_SS2_B, SEL_SOF0_1), + PINMUX_IPSR_DATA(IP4_20_18, CS1_N_A26), + PINMUX_IPSR_DATA(IP4_20_18, SPEEDIN), + PINMUX_IPSR_MODSEL_DATA(IP4_20_18, VI0_R7, SEL_VI0_0), + PINMUX_IPSR_MODSEL_DATA(IP4_20_18, VI0_R7_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP4_20_18, VI2_CLK, SEL_VI2_0), + PINMUX_IPSR_MODSEL_DATA(IP4_20_18, VI2_CLK_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP4_23_21, EX_CS0_N), + PINMUX_IPSR_MODSEL_DATA(IP4_23_21, HRX1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP4_23_21, VI1_G5, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_23_21, VI1_G5_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_23_21, VI2_R0), + PINMUX_IPSR_MODSEL_DATA(IP4_23_21, HTX0_B, SEL_HSCIF0_1), + PINMUX_IPSR_MODSEL_DATA(IP4_23_21, MSIOF0_SS1_B, SEL_SOF0_1), + PINMUX_IPSR_DATA(IP4_26_24, EX_CS1_N), + PINMUX_IPSR_DATA(IP4_26_24, GPS_CLK), + PINMUX_IPSR_MODSEL_DATA(IP4_26_24, HCTS1_N_B, SEL_HSCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP4_26_24, VI1_FIELD, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_26_24, VI1_FIELD_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_26_24, VI2_R1), + PINMUX_IPSR_DATA(IP4_29_27, EX_CS2_N), + PINMUX_IPSR_DATA(IP4_29_27, GPS_SIGN), + PINMUX_IPSR_MODSEL_DATA(IP4_29_27, HRTS1_N_B, SEL_HSCIF1_1), + PINMUX_IPSR_DATA(IP4_29_27, VI3_CLKENB), + PINMUX_IPSR_MODSEL_DATA(IP4_29_27, VI1_G0, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP4_29_27, VI1_G0_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP4_29_27, VI2_R2), + + PINMUX_IPSR_DATA(IP5_2_0, EX_CS3_N), + PINMUX_IPSR_DATA(IP5_2_0, GPS_MAG), + PINMUX_IPSR_DATA(IP5_2_0, VI3_FIELD), + PINMUX_IPSR_MODSEL_DATA(IP5_2_0, VI1_G1, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_2_0, VI1_G1_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP5_2_0, VI2_R3), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, EX_CS4_N, SEL_I2C1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, MSIOF1_SCK_B, SEL_SOF1_1), + PINMUX_IPSR_DATA(IP5_5_3, VI3_HSYNC_N), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, VI2_HSYNC_N, SEL_VI2_0), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, SCL1, SEL_IIC1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, VI2_HSYNC_N_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP5_5_3, INTC_EN0_N), + PINMUX_IPSR_MODSEL_DATA(IP5_5_3, SCL1_CIS, SEL_I2C1_0), + PINMUX_IPSR_DATA(IP5_9_6, EX_CS5_N), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, CAN0_RX, SEL_CAN0_0), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, MSIOF1_RXD_B, SEL_SOF1_1), + PINMUX_IPSR_DATA(IP5_9_6, VI3_VSYNC_N), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, VI1_G2, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, VI1_G2_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP5_9_6, VI2_R4), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, SDA1, SEL_IIC1_0), + PINMUX_IPSR_DATA(IP5_9_6, INTC_EN1_N), + PINMUX_IPSR_MODSEL_DATA(IP5_9_6, SDA1_CIS, SEL_I2C1_0), + PINMUX_IPSR_DATA(IP5_12_10, BS_N), + PINMUX_IPSR_MODSEL_DATA(IP5_12_10, IETX, SEL_IEB_0), + PINMUX_IPSR_MODSEL_DATA(IP5_12_10, HTX1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP5_12_10, CAN1_TX, SEL_CAN1_0), + PINMUX_IPSR_DATA(IP5_12_10, DRACK0), + PINMUX_IPSR_MODSEL_DATA(IP5_12_10, IETX_C, SEL_IEB_2), + PINMUX_IPSR_DATA(IP5_14_13, RD_N), + PINMUX_IPSR_MODSEL_DATA(IP5_14_13, CAN0_TX, SEL_CAN0_0), + PINMUX_IPSR_MODSEL_DATA(IP5_14_13, SCIFA0_SCK_B, SEL_SCFA_1), + PINMUX_IPSR_DATA(IP5_17_15, RD_WR_N), + PINMUX_IPSR_MODSEL_DATA(IP5_17_15, VI1_G3, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_17_15, VI1_G3_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP5_17_15, VI2_R5), + PINMUX_IPSR_MODSEL_DATA(IP5_17_15, SCIFA0_RXD_B, SEL_SCFA_1), + PINMUX_IPSR_DATA(IP5_17_15, INTC_IRQ4_N), + PINMUX_IPSR_DATA(IP5_20_18, WE0_N), + PINMUX_IPSR_MODSEL_DATA(IP5_20_18, IECLK, SEL_IEB_0), + PINMUX_IPSR_MODSEL_DATA(IP5_20_18, CAN_CLK, SEL_CANCLK_0), + PINMUX_IPSR_MODSEL_DATA(IP5_20_18, VI2_VSYNC_N, SEL_VI2_0), + PINMUX_IPSR_MODSEL_DATA(IP5_20_18, SCIFA0_TXD_B, SEL_SCFA_1), + PINMUX_IPSR_MODSEL_DATA(IP5_20_18, VI2_VSYNC_N_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP5_23_21, WE1_N), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, IERX, SEL_IEB_0), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, CAN1_RX, SEL_CAN1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, VI1_G4, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, VI1_G4_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP5_23_21, VI2_R6), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, SCIFA0_CTS_N_B, SEL_SCFA_1), + PINMUX_IPSR_MODSEL_DATA(IP5_23_21, IERX_C, SEL_IEB_2), + PINMUX_IPSR_DATA(IP5_26_24, EX_WAIT0), + PINMUX_IPSR_DATA(IP5_26_24, IRQ3), + PINMUX_IPSR_DATA(IP5_26_24, INTC_IRQ3_N), + PINMUX_IPSR_MODSEL_DATA(IP5_26_24, VI3_CLK, SEL_VI3_0), + PINMUX_IPSR_MODSEL_DATA(IP5_26_24, SCIFA0_RTS_N_B, SEL_SCFA_1), + PINMUX_IPSR_MODSEL_DATA(IP5_26_24, HRX0_B, SEL_HSCIF0_1), + PINMUX_IPSR_MODSEL_DATA(IP5_26_24, MSIOF0_SCK_B, SEL_SOF0_1), + PINMUX_IPSR_DATA(IP5_29_27, DREQ0_N), + PINMUX_IPSR_MODSEL_DATA(IP5_29_27, VI1_HSYNC_N, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP5_29_27, VI1_HSYNC_N_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP5_29_27, VI2_R7), + PINMUX_IPSR_MODSEL_DATA(IP5_29_27, SSI_SCK78_C, SEL_SSI7_2), + PINMUX_IPSR_MODSEL_DATA(IP5_29_27, SSI_WS78_B, SEL_SSI7_1), + + PINMUX_IPSR_DATA(IP6_2_0, DACK0), + PINMUX_IPSR_DATA(IP6_2_0, IRQ0), + PINMUX_IPSR_DATA(IP6_2_0, INTC_IRQ0_N), + PINMUX_IPSR_MODSEL_DATA(IP6_2_0, SSI_SCK6_B, SEL_SSI6_1), + PINMUX_IPSR_MODSEL_DATA(IP6_2_0, VI1_VSYNC_N, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP6_2_0, VI1_VSYNC_N_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP6_2_0, SSI_WS78_C, SEL_SSI7_2), + PINMUX_IPSR_DATA(IP6_5_3, DREQ1_N), + PINMUX_IPSR_MODSEL_DATA(IP6_5_3, VI1_CLKENB, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP6_5_3, VI1_CLKENB_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP6_5_3, SSI_SDATA7_C, SEL_SSI7_2), + PINMUX_IPSR_MODSEL_DATA(IP6_5_3, SSI_SCK78_B, SEL_SSI7_1), + PINMUX_IPSR_DATA(IP6_8_6, DACK1), + PINMUX_IPSR_DATA(IP6_8_6, IRQ1), + PINMUX_IPSR_DATA(IP6_8_6, INTC_IRQ1_N), + PINMUX_IPSR_MODSEL_DATA(IP6_8_6, SSI_WS6_B, SEL_SSI6_1), + PINMUX_IPSR_MODSEL_DATA(IP6_8_6, SSI_SDATA8_C, SEL_SSI8_2), + PINMUX_IPSR_DATA(IP6_10_9, DREQ2_N), + PINMUX_IPSR_MODSEL_DATA(IP6_10_9, HSCK1_B, SEL_HSCIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP6_10_9, HCTS0_N_B, SEL_HSCIF0_1), + PINMUX_IPSR_MODSEL_DATA(IP6_10_9, MSIOF0_TXD_B, SEL_SOF0_1), + PINMUX_IPSR_DATA(IP6_13_11, DACK2), + PINMUX_IPSR_DATA(IP6_13_11, IRQ2), + PINMUX_IPSR_DATA(IP6_13_11, INTC_IRQ2_N), + PINMUX_IPSR_MODSEL_DATA(IP6_13_11, SSI_SDATA6_B, SEL_SSI6_1), + PINMUX_IPSR_MODSEL_DATA(IP6_13_11, HRTS0_N_B, SEL_HSCIF0_1), + PINMUX_IPSR_MODSEL_DATA(IP6_13_11, MSIOF0_RXD_B, SEL_SOF0_1), + PINMUX_IPSR_DATA(IP6_16_14, ETH_CRS_DV), + PINMUX_IPSR_DATA(IP6_16_14, RMII_CRS_DV), + PINMUX_IPSR_MODSEL_DATA(IP6_16_14, STP_ISCLK_0_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_16_14, TS_SDEN0_D, SEL_TSIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP6_16_14, GLO_Q0_C, SEL_GPS_2), + PINMUX_IPSR_MODSEL_DATA(IP6_16_14, SCL2_E, SEL_IIC2_4), + PINMUX_IPSR_MODSEL_DATA(IP6_16_14, SCL2_CIS_E, SEL_I2C2_4), + PINMUX_IPSR_DATA(IP6_19_17, ETH_RX_ER), + PINMUX_IPSR_DATA(IP6_19_17, RMII_RX_ER), + PINMUX_IPSR_MODSEL_DATA(IP6_19_17, STP_ISD_0_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_19_17, TS_SPSYNC0_D, SEL_TSIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP6_19_17, GLO_Q1_C, SEL_GPS_2), + PINMUX_IPSR_MODSEL_DATA(IP6_19_17, SDA2_E, SEL_IIC2_4), + PINMUX_IPSR_MODSEL_DATA(IP6_19_17, SDA2_CIS_E, SEL_I2C2_4), + PINMUX_IPSR_DATA(IP6_22_20, ETH_RXD0), + PINMUX_IPSR_DATA(IP6_22_20, RMII_RXD0), + PINMUX_IPSR_MODSEL_DATA(IP6_22_20, STP_ISEN_0_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_22_20, TS_SDAT0_D, SEL_TSIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP6_22_20, GLO_I0_C, SEL_GPS_2), + PINMUX_IPSR_MODSEL_DATA(IP6_22_20, SCIFB1_SCK_G, SEL_SCIFB1_6), + PINMUX_IPSR_MODSEL_DATA(IP6_22_20, SCK1_E, SEL_SCIF1_4), + PINMUX_IPSR_DATA(IP6_25_23, ETH_RXD1), + PINMUX_IPSR_DATA(IP6_25_23, RMII_RXD1), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, HRX0_E, SEL_HSCIF0_4), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, STP_ISSYNC_0_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, TS_SCK0_D, SEL_TSIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, GLO_I1_C, SEL_GPS_2), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, SCIFB1_RXD_G, SEL_SCIFB1_6), + PINMUX_IPSR_MODSEL_DATA(IP6_25_23, RX1_E, SEL_SCIF1_4), + PINMUX_IPSR_DATA(IP6_28_26, ETH_LINK), + PINMUX_IPSR_DATA(IP6_28_26, RMII_LINK), + PINMUX_IPSR_MODSEL_DATA(IP6_28_26, HTX0_E, SEL_HSCIF0_4), + PINMUX_IPSR_MODSEL_DATA(IP6_28_26, STP_IVCXO27_0_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_28_26, SCIFB1_TXD_G, SEL_SCIFB1_6), + PINMUX_IPSR_MODSEL_DATA(IP6_28_26, TX1_E, SEL_SCIF1_4), + PINMUX_IPSR_DATA(IP6_31_29, ETH_REF_CLK), + PINMUX_IPSR_DATA(IP6_31_29, RMII_REF_CLK), + PINMUX_IPSR_MODSEL_DATA(IP6_31_29, HCTS0_N_E, SEL_HSCIF0_4), + PINMUX_IPSR_MODSEL_DATA(IP6_31_29, STP_IVCXO27_1_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP6_31_29, HRX0_F, SEL_HSCIF0_5), + + PINMUX_IPSR_DATA(IP7_2_0, ETH_MDIO), + PINMUX_IPSR_DATA(IP7_2_0, RMII_MDIO), + PINMUX_IPSR_MODSEL_DATA(IP7_2_0, HRTS0_N_E, SEL_HSCIF0_4), + PINMUX_IPSR_MODSEL_DATA(IP7_2_0, SIM0_D_C, SEL_SIM_2), + PINMUX_IPSR_MODSEL_DATA(IP7_2_0, HCTS0_N_F, SEL_HSCIF0_5), + PINMUX_IPSR_DATA(IP7_5_3, ETH_TXD1), + PINMUX_IPSR_DATA(IP7_5_3, RMII_TXD1), + PINMUX_IPSR_MODSEL_DATA(IP7_5_3, HTX0_F, SEL_HSCIF0_4), + PINMUX_IPSR_MODSEL_DATA(IP7_5_3, BPFCLK_G, SEL_SIM_2), + PINMUX_IPSR_MODSEL_DATA(IP7_5_3, RDS_CLK_F, SEL_HSCIF0_5), + PINMUX_IPSR_DATA(IP7_7_6, ETH_TX_EN), + PINMUX_IPSR_DATA(IP7_7_6, RMII_TX_EN), + PINMUX_IPSR_MODSEL_DATA(IP7_7_6, SIM0_CLK_C, SEL_SIM_2), + PINMUX_IPSR_MODSEL_DATA(IP7_7_6, HRTS0_N_F, SEL_HSCIF0_5), + PINMUX_IPSR_DATA(IP7_9_8, ETH_MAGIC), + PINMUX_IPSR_DATA(IP7_9_8, RMII_MAGIC), + PINMUX_IPSR_MODSEL_DATA(IP7_9_8, SIM0_RST_C, SEL_SIM_2), + PINMUX_IPSR_DATA(IP7_12_10, ETH_TXD0), + PINMUX_IPSR_DATA(IP7_12_10, RMII_TXD0), + PINMUX_IPSR_MODSEL_DATA(IP7_12_10, STP_ISCLK_1_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP7_12_10, TS_SDEN1_C, SEL_TSIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP7_12_10, GLO_SCLK_C, SEL_GPS_2), + PINMUX_IPSR_DATA(IP7_15_13, ETH_MDC), + PINMUX_IPSR_DATA(IP7_15_13, RMII_MDC), + PINMUX_IPSR_MODSEL_DATA(IP7_15_13, STP_ISD_1_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP7_15_13, TS_SPSYNC1_C, SEL_TSIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP7_15_13, GLO_SDATA_C, SEL_GPS_2), + PINMUX_IPSR_DATA(IP7_18_16, PWM0), + PINMUX_IPSR_MODSEL_DATA(IP7_18_16, SCIFA2_SCK_C, SEL_SCIFA2_2), + PINMUX_IPSR_MODSEL_DATA(IP7_18_16, STP_ISEN_1_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP7_18_16, TS_SDAT1_C, SEL_TSIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP7_18_16, GLO_SS_C, SEL_GPS_2), + PINMUX_IPSR_DATA(IP7_21_19, PWM1), + PINMUX_IPSR_MODSEL_DATA(IP7_21_19, SCIFA2_TXD_C, SEL_SCIFA2_2), + PINMUX_IPSR_MODSEL_DATA(IP7_21_19, STP_ISSYNC_1_B, SEL_SSP_1), + PINMUX_IPSR_MODSEL_DATA(IP7_21_19, TS_SCK1_C, SEL_TSIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP7_21_19, GLO_RFON_C, SEL_GPS_2), + PINMUX_IPSR_DATA(IP7_21_19, PCMOE_N), + PINMUX_IPSR_DATA(IP7_24_22, PWM2), + PINMUX_IPSR_DATA(IP7_24_22, PWMFSW0), + PINMUX_IPSR_MODSEL_DATA(IP7_24_22, SCIFA2_RXD_C, SEL_SCIFA2_2), + PINMUX_IPSR_DATA(IP7_24_22, PCMWE_N), + PINMUX_IPSR_MODSEL_DATA(IP7_24_22, IECLK_C, SEL_IEB_2), + PINMUX_IPSR_DATA(IP7_26_25, DU1_DOTCLKIN), + PINMUX_IPSR_DATA(IP7_26_25, AUDIO_CLKC), + PINMUX_IPSR_DATA(IP7_26_25, AUDIO_CLKOUT_C), + PINMUX_IPSR_MODSEL_DATA(IP7_28_27, VI0_CLK, SEL_VI0_0), + PINMUX_IPSR_DATA(IP7_28_27, ATACS00_N), + PINMUX_IPSR_DATA(IP7_28_27, AVB_RXD1), + PINMUX_IPSR_DATA(IP7_28_27, MII_RXD1), + PINMUX_IPSR_MODSEL_DATA(IP7_30_29, VI0_DATA0_VI0_B0, SEL_VI0_0), + PINMUX_IPSR_DATA(IP7_30_29, ATACS10_N), + PINMUX_IPSR_DATA(IP7_30_29, AVB_RXD2), + PINMUX_IPSR_DATA(IP7_30_29, MII_RXD2), + + PINMUX_IPSR_MODSEL_DATA(IP8_1_0, VI0_DATA1_VI0_B1, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_1_0, ATARD0_N), + PINMUX_IPSR_DATA(IP8_1_0, AVB_RXD3), + PINMUX_IPSR_DATA(IP8_1_0, MII_RXD3), + PINMUX_IPSR_MODSEL_DATA(IP8_3_2, VI0_DATA2_VI0_B2, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_3_2, ATAWR0_N), + PINMUX_IPSR_DATA(IP8_3_2, AVB_RXD4), + PINMUX_IPSR_MODSEL_DATA(IP8_5_4, VI0_DATA3_VI0_B3, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_5_4, ATADIR0_N), + PINMUX_IPSR_DATA(IP8_5_4, AVB_RXD5), + PINMUX_IPSR_MODSEL_DATA(IP8_7_6, VI0_DATA4_VI0_B4, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_7_6, ATAG0_N), + PINMUX_IPSR_DATA(IP8_7_6, AVB_RXD6), + PINMUX_IPSR_MODSEL_DATA(IP8_9_8, VI0_DATA5_VI0_B5, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_9_8, EX_WAIT1), + PINMUX_IPSR_DATA(IP8_9_8, AVB_RXD7), + PINMUX_IPSR_MODSEL_DATA(IP8_11_10, VI0_DATA6_VI0_B6, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_11_10, AVB_RX_ER), + PINMUX_IPSR_DATA(IP8_11_10, MII_RX_ER), + PINMUX_IPSR_MODSEL_DATA(IP8_13_12, VI0_DATA7_VI0_B7, SEL_VI0_0), + PINMUX_IPSR_DATA(IP8_13_12, AVB_RX_CLK), + PINMUX_IPSR_DATA(IP8_13_12, MII_RX_CLK), + PINMUX_IPSR_MODSEL_DATA(IP8_15_14, VI1_CLK, SEL_VI1_0), + PINMUX_IPSR_DATA(IP8_15_14, AVB_RX_DV), + PINMUX_IPSR_DATA(IP8_15_14, MII_RX_DV), + PINMUX_IPSR_MODSEL_DATA(IP8_17_16, VI1_DATA0_VI1_B0, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_17_16, SCIFA1_SCK_D, SEL_SCIFA1_3), + PINMUX_IPSR_DATA(IP8_17_16, AVB_CRS), + PINMUX_IPSR_DATA(IP8_17_16, MII_CRS), + PINMUX_IPSR_MODSEL_DATA(IP8_19_18, VI1_DATA1_VI1_B1, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_19_18, SCIFA1_RXD_D, SEL_SCIFA1_3), + PINMUX_IPSR_DATA(IP8_19_18, AVB_MDC), + PINMUX_IPSR_DATA(IP8_19_18, MII_MDC), + PINMUX_IPSR_MODSEL_DATA(IP8_21_20, VI1_DATA2_VI1_B2, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_21_20, SCIFA1_TXD_D, SEL_SCIFA1_3), + PINMUX_IPSR_DATA(IP8_21_20, AVB_MDIO), + PINMUX_IPSR_DATA(IP8_21_20, MII_MDIO), + PINMUX_IPSR_MODSEL_DATA(IP8_23_22, VI1_DATA3_VI1_B3, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_23_22, SCIFA1_CTS_N_D, SEL_SCIFA1_3), + PINMUX_IPSR_DATA(IP8_23_22, AVB_GTX_CLK), + PINMUX_IPSR_MODSEL_DATA(IP8_25_24, VI1_DATA4_VI1_B4, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_25_24, SCIFA1_RTS_N_D, SEL_SCIFA1_3), + PINMUX_IPSR_DATA(IP8_25_24, AVB_MAGIC), + PINMUX_IPSR_DATA(IP8_25_24, MII_MAGIC), + PINMUX_IPSR_MODSEL_DATA(IP8_26, VI1_DATA5_VI1_B5, SEL_VI1_0), + PINMUX_IPSR_MODSEL_DATA(IP8_26, AVB_PHY_INT, SEL_SCIFA1_3), + PINMUX_IPSR_MODSEL_DATA(IP8_27, VI1_DATA6_VI1_B6, SEL_VI1_0), + PINMUX_IPSR_DATA(IP8_27, AVB_GTXREFCLK), + PINMUX_IPSR_DATA(IP8_28, SD0_CLK), + PINMUX_IPSR_MODSEL_DATA(IP8_28, VI1_DATA0_VI1_B0_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP8_30_29, SD0_CMD), + PINMUX_IPSR_MODSEL_DATA(IP8_30_29, SCIFB1_SCK_B, SEL_SCIFB1_1), + PINMUX_IPSR_MODSEL_DATA(IP8_30_29, VI1_DATA1_VI1_B1_B, SEL_VI1_1), + + PINMUX_IPSR_DATA(IP9_1_0, SD0_DAT0), + PINMUX_IPSR_MODSEL_DATA(IP9_1_0, SCIFB1_RXD_B, SEL_SCIFB1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_1_0, VI1_DATA2_VI1_B2_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP9_3_2, SD0_DAT1), + PINMUX_IPSR_MODSEL_DATA(IP9_3_2, SCIFB1_TXD_B, SEL_SCIFB1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_3_2, VI1_DATA3_VI1_B3_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP9_5_4, SD0_DAT2), + PINMUX_IPSR_MODSEL_DATA(IP9_5_4, SCIFB1_CTS_N_B, SEL_SCIFB1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_5_4, VI1_DATA4_VI1_B4_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP9_7_6, SD0_DAT3), + PINMUX_IPSR_MODSEL_DATA(IP9_7_6, SCIFB1_RTS_N_B, SEL_SCIFB1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_7_6, VI1_DATA5_VI1_B5_B, SEL_VI1_1), + PINMUX_IPSR_DATA(IP9_11_8, SD0_CD), + PINMUX_IPSR_DATA(IP9_11_8, MMC0_D6), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, TS_SDEN0_B, SEL_TSIF0_1), + PINMUX_IPSR_DATA(IP9_11_8, USB0_EXTP), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, GLO_SCLK, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, VI1_DATA6_VI1_B6_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, SCL1_B, SEL_IIC1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, SCL1_CIS_B, SEL_I2C1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_11_8, VI2_DATA6_VI2_B6_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP9_15_12, SD0_WP), + PINMUX_IPSR_DATA(IP9_15_12, MMC0_D7), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, TS_SPSYNC0_B, SEL_TSIF0_1), + PINMUX_IPSR_DATA(IP9_15_12, USB0_IDIN), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, GLO_SDATA, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, VI1_DATA7_VI1_B7_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, SDA1_B, SEL_IIC1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, SDA1_CIS_B, SEL_I2C1_1), + PINMUX_IPSR_MODSEL_DATA(IP9_15_12, VI2_DATA7_VI2_B7_B, SEL_VI2_1), + PINMUX_IPSR_DATA(IP9_17_16, SD1_CLK), + PINMUX_IPSR_DATA(IP9_17_16, AVB_TX_EN), + PINMUX_IPSR_DATA(IP9_17_16, MII_TX_EN), + PINMUX_IPSR_DATA(IP9_19_18, SD1_CMD), + PINMUX_IPSR_DATA(IP9_19_18, AVB_TX_ER), + PINMUX_IPSR_DATA(IP9_19_18, MII_TX_ER), + PINMUX_IPSR_MODSEL_DATA(IP9_19_18, SCIFB0_SCK_B, SEL_SCIFB_1), + PINMUX_IPSR_DATA(IP9_21_20, SD1_DAT0), + PINMUX_IPSR_DATA(IP9_21_20, AVB_TX_CLK), + PINMUX_IPSR_DATA(IP9_21_20, MII_TX_CLK), + PINMUX_IPSR_MODSEL_DATA(IP9_21_20, SCIFB0_RXD_B, SEL_SCIFB_1), + PINMUX_IPSR_DATA(IP9_23_22, SD1_DAT1), + PINMUX_IPSR_DATA(IP9_23_22, AVB_LINK), + PINMUX_IPSR_DATA(IP9_23_22, MII_LINK), + PINMUX_IPSR_MODSEL_DATA(IP9_23_22, SCIFB0_TXD_B, SEL_SCIFB_1), + PINMUX_IPSR_DATA(IP9_25_24, SD1_DAT2), + PINMUX_IPSR_DATA(IP9_25_24, AVB_COL), + PINMUX_IPSR_DATA(IP9_25_24, MII_COL), + PINMUX_IPSR_MODSEL_DATA(IP9_25_24, SCIFB0_CTS_N_B, SEL_SCIFB_1), + PINMUX_IPSR_DATA(IP9_27_26, SD1_DAT3), + PINMUX_IPSR_DATA(IP9_27_26, AVB_RXD0), + PINMUX_IPSR_DATA(IP9_27_26, MII_RXD0), + PINMUX_IPSR_MODSEL_DATA(IP9_27_26, SCIFB0_RTS_N_B, SEL_SCIFB_1), + PINMUX_IPSR_DATA(IP9_31_28, SD1_CD), + PINMUX_IPSR_DATA(IP9_31_28, MMC1_D6), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, TS_SDEN1, SEL_TSIF1_0), + PINMUX_IPSR_DATA(IP9_31_28, USB1_EXTP), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, GLO_SS, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, VI0_CLK_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, SCL2_D, SEL_IIC2_3), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, SCL2_CIS_D, SEL_I2C2_3), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, SIM0_CLK_B, SEL_SIM_1), + PINMUX_IPSR_MODSEL_DATA(IP9_31_28, VI3_CLK_B, SEL_VI3_1), + + PINMUX_IPSR_DATA(IP10_3_0, SD1_WP), + PINMUX_IPSR_DATA(IP10_3_0, MMC1_D7), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, TS_SPSYNC1, SEL_TSIF1_0), + PINMUX_IPSR_DATA(IP10_3_0, USB1_IDIN), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, GLO_RFON, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, VI1_CLK_B, SEL_VI1_1), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, SDA2_D, SEL_IIC2_3), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, SDA2_CIS_D, SEL_I2C2_3), + PINMUX_IPSR_MODSEL_DATA(IP10_3_0, SIM0_D_B, SEL_SIM_1), + PINMUX_IPSR_DATA(IP10_6_4, SD2_CLK), + PINMUX_IPSR_DATA(IP10_6_4, MMC0_CLK), + PINMUX_IPSR_MODSEL_DATA(IP10_6_4, SIM0_CLK, SEL_SIM_0), + PINMUX_IPSR_MODSEL_DATA(IP10_6_4, VI0_DATA0_VI0_B0_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_6_4, TS_SDEN0_C, SEL_TSIF0_2), + PINMUX_IPSR_MODSEL_DATA(IP10_6_4, GLO_SCLK_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_6_4, VI3_DATA0_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_10_7, SD2_CMD), + PINMUX_IPSR_DATA(IP10_10_7, MMC0_CMD), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, SIM0_D, SEL_SIM_0), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, VI0_DATA1_VI0_B1_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, SCIFB1_SCK_E, SEL_SCIFB1_4), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, SCK1_D, SEL_SCIF1_3), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, TS_SPSYNC0_C, SEL_TSIF0_2), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, GLO_SDATA_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_10_7, VI3_DATA1_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_14_11, SD2_DAT0), + PINMUX_IPSR_DATA(IP10_14_11, MMC0_D0), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, FMCLK_B, SEL_FM_1), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, VI0_DATA2_VI0_B2_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, SCIFB1_RXD_E, SEL_SCIFB1_4), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, RX1_D, SEL_SCIF1_3), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, TS_SDAT0_C, SEL_TSIF0_2), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, GLO_SS_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_14_11, VI3_DATA2_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_18_15, SD2_DAT1), + PINMUX_IPSR_DATA(IP10_18_15, MMC0_D1), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, FMIN_B, SEL_FM_1), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, RDS_DATA, SEL_RDS_0), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, VI0_DATA3_VI0_B3_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, SCIFB1_TXD_E, SEL_SCIFB1_4), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, TX1_D, SEL_SCIF1_3), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, TS_SCK0_C, SEL_TSIF0_2), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, GLO_RFON_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_18_15, VI3_DATA3_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_22_19, SD2_DAT2), + PINMUX_IPSR_DATA(IP10_22_19, MMC0_D2), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, BPFCLK_B, SEL_FM_1), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, RDS_CLK, SEL_RDS_0), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, VI0_DATA4_VI0_B4_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, HRX0_D, SEL_HSCIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, TS_SDEN1_B, SEL_TSIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, GLO_Q0_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_22_19, VI3_DATA4_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_25_23, SD2_DAT3), + PINMUX_IPSR_DATA(IP10_25_23, MMC0_D3), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, SIM0_RST, SEL_SIM_0), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, VI0_DATA5_VI0_B5_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, HTX0_D, SEL_HSCIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, TS_SPSYNC1_B, SEL_TSIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, GLO_Q1_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_25_23, VI3_DATA5_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP10_29_26, SD2_CD), + PINMUX_IPSR_DATA(IP10_29_26, MMC0_D4), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, TS_SDAT0_B, SEL_TSIF0_1), + PINMUX_IPSR_DATA(IP10_29_26, USB2_EXTP), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, GLO_I0, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, VI0_DATA6_VI0_B6_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, HCTS0_N_D, SEL_HSCIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, TS_SDAT1_B, SEL_TSIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, GLO_I0_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP10_29_26, VI3_DATA6_B, SEL_VI3_1), + + PINMUX_IPSR_DATA(IP11_3_0, SD2_WP), + PINMUX_IPSR_DATA(IP11_3_0, MMC0_D5), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, TS_SCK0_B, SEL_TSIF0_1), + PINMUX_IPSR_DATA(IP11_3_0, USB2_IDIN), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, GLO_I1, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, VI0_DATA7_VI0_B7_B, SEL_VI0_1), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, HRTS0_N_D, SEL_HSCIF0_3), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, TS_SCK1_B, SEL_TSIF1_1), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, GLO_I1_B, SEL_GPS_1), + PINMUX_IPSR_MODSEL_DATA(IP11_3_0, VI3_DATA7_B, SEL_VI3_1), + PINMUX_IPSR_DATA(IP11_4, SD3_CLK), + PINMUX_IPSR_DATA(IP11_4, MMC1_CLK), + PINMUX_IPSR_DATA(IP11_6_5, SD3_CMD), + PINMUX_IPSR_DATA(IP11_6_5, MMC1_CMD), + PINMUX_IPSR_DATA(IP11_6_5, MTS_N), + PINMUX_IPSR_DATA(IP11_8_7, SD3_DAT0), + PINMUX_IPSR_DATA(IP11_8_7, MMC1_D0), + PINMUX_IPSR_DATA(IP11_8_7, STM_N), + PINMUX_IPSR_DATA(IP11_10_9, SD3_DAT1), + PINMUX_IPSR_DATA(IP11_10_9, MMC1_D1), + PINMUX_IPSR_DATA(IP11_10_9, MDATA), + PINMUX_IPSR_DATA(IP11_12_11, SD3_DAT2), + PINMUX_IPSR_DATA(IP11_12_11, MMC1_D2), + PINMUX_IPSR_DATA(IP11_12_11, SDATA), + PINMUX_IPSR_DATA(IP11_14_13, SD3_DAT3), + PINMUX_IPSR_DATA(IP11_14_13, MMC1_D3), + PINMUX_IPSR_DATA(IP11_14_13, SCKZ), + PINMUX_IPSR_DATA(IP11_17_15, SD3_CD), + PINMUX_IPSR_DATA(IP11_17_15, MMC1_D4), + PINMUX_IPSR_MODSEL_DATA(IP11_17_15, TS_SDAT1, SEL_TSIF1_0), + PINMUX_IPSR_DATA(IP11_17_15, VSP), + PINMUX_IPSR_MODSEL_DATA(IP11_17_15, GLO_Q0, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP11_17_15, SIM0_RST_B, SEL_SIM_1), + PINMUX_IPSR_DATA(IP11_21_18, SD3_WP), + PINMUX_IPSR_DATA(IP11_21_18, MMC1_D5), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, TS_SCK1, SEL_TSIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, GLO_Q1, SEL_GPS_0), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, FMIN_C, SEL_FM_2), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, RDS_DATA_B, SEL_RDS_1), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, FMIN_E, SEL_FM_4), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, RDS_DATA_D, SEL_RDS_3), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, FMIN_F, SEL_FM_5), + PINMUX_IPSR_MODSEL_DATA(IP11_21_18, RDS_DATA_E, SEL_RDS_4), + PINMUX_IPSR_DATA(IP11_23_22, MLB_CLK), + PINMUX_IPSR_MODSEL_DATA(IP11_23_22, SCL2_B, SEL_IIC2_1), + PINMUX_IPSR_MODSEL_DATA(IP11_23_22, SCL2_CIS_B, SEL_I2C2_1), + PINMUX_IPSR_DATA(IP11_26_24, MLB_SIG), + PINMUX_IPSR_MODSEL_DATA(IP11_26_24, SCIFB1_RXD_D, SEL_SCIFB1_3), + PINMUX_IPSR_MODSEL_DATA(IP11_26_24, RX1_C, SEL_SCIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP11_26_24, SDA2_B, SEL_IIC2_1), + PINMUX_IPSR_MODSEL_DATA(IP11_26_24, SDA2_CIS_B, SEL_I2C2_1), + PINMUX_IPSR_DATA(IP11_29_27, MLB_DAT), + PINMUX_IPSR_DATA(IP11_29_27, SPV_EVEN), + PINMUX_IPSR_MODSEL_DATA(IP11_29_27, SCIFB1_TXD_D, SEL_SCIFB1_3), + PINMUX_IPSR_MODSEL_DATA(IP11_29_27, TX1_C, SEL_SCIF1_2), + PINMUX_IPSR_MODSEL_DATA(IP11_29_27, BPFCLK_C, SEL_FM_2), + PINMUX_IPSR_MODSEL_DATA(IP11_29_27, RDS_CLK_B, SEL_RDS_1), + PINMUX_IPSR_DATA(IP11_31_30, SSI_SCK0129), + PINMUX_IPSR_MODSEL_DATA(IP11_31_30, CAN_CLK_B, SEL_CANCLK_1), + PINMUX_IPSR_DATA(IP11_31_30, MOUT0), + + PINMUX_IPSR_DATA(IP12_1_0, SSI_WS0129), + PINMUX_IPSR_MODSEL_DATA(IP12_1_0, CAN0_TX_B, SEL_CAN0_1), + PINMUX_IPSR_DATA(IP12_1_0, MOUT1), + PINMUX_IPSR_DATA(IP12_3_2, SSI_SDATA0), + PINMUX_IPSR_MODSEL_DATA(IP12_3_2, CAN0_RX_B, SEL_CAN0_1), + PINMUX_IPSR_DATA(IP12_3_2, MOUT2), + PINMUX_IPSR_DATA(IP12_5_4, SSI_SDATA1), + PINMUX_IPSR_MODSEL_DATA(IP12_5_4, CAN1_TX_B, SEL_CAN1_1), + PINMUX_IPSR_DATA(IP12_5_4, MOUT5), + PINMUX_IPSR_DATA(IP12_7_6, SSI_SDATA2), + PINMUX_IPSR_MODSEL_DATA(IP12_7_6, CAN1_RX_B, SEL_CAN1_1), + PINMUX_IPSR_MODSEL_DATA(IP12_7_6, CAN1_TX_B, SEL_CAN1_1), + PINMUX_IPSR_DATA(IP12_7_6, MOUT6), + PINMUX_IPSR_DATA(IP12_10_8, SSI_SCK34), + PINMUX_IPSR_DATA(IP12_10_8, STP_OPWM_0), + PINMUX_IPSR_MODSEL_DATA(IP12_10_8, SCIFB0_SCK, SEL_SCIFB_0), + PINMUX_IPSR_MODSEL_DATA(IP12_10_8, MSIOF1_SCK, SEL_SOF1_0), + PINMUX_IPSR_DATA(IP12_10_8, CAN_DEBUG_HW_TRIGGER), + PINMUX_IPSR_DATA(IP12_13_11, SSI_WS34), + PINMUX_IPSR_MODSEL_DATA(IP12_13_11, STP_IVCXO27_0, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP12_13_11, SCIFB0_RXD, SEL_SCIFB_0), + PINMUX_IPSR_DATA(IP12_13_11, MSIOF1_SYNC), + PINMUX_IPSR_DATA(IP12_13_11, CAN_STEP0), + PINMUX_IPSR_DATA(IP12_16_14, SSI_SDATA3), + PINMUX_IPSR_MODSEL_DATA(IP12_16_14, STP_ISCLK_0, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP12_16_14, SCIFB0_TXD, SEL_SCIFB_0), + PINMUX_IPSR_MODSEL_DATA(IP12_16_14, MSIOF1_SS1, SEL_SOF1_0), + PINMUX_IPSR_DATA(IP12_16_14, CAN_TXCLK), + PINMUX_IPSR_DATA(IP12_19_17, SSI_SCK4), + PINMUX_IPSR_MODSEL_DATA(IP12_19_17, STP_ISD_0, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP12_19_17, SCIFB0_CTS_N, SEL_SCIFB_0), + PINMUX_IPSR_MODSEL_DATA(IP12_19_17, MSIOF1_SS2, SEL_SOF1_0), + PINMUX_IPSR_MODSEL_DATA(IP12_19_17, SSI_SCK5_C, SEL_SSI5_2), + PINMUX_IPSR_DATA(IP12_19_17, CAN_DEBUGOUT0), + PINMUX_IPSR_DATA(IP12_22_20, SSI_WS4), + PINMUX_IPSR_MODSEL_DATA(IP12_22_20, STP_ISEN_0, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP12_22_20, SCIFB0_RTS_N, SEL_SCIFB_0), + PINMUX_IPSR_MODSEL_DATA(IP12_22_20, MSIOF1_TXD, SEL_SOF1_0), + PINMUX_IPSR_MODSEL_DATA(IP12_22_20, SSI_WS5_C, SEL_SSI5_2), + PINMUX_IPSR_DATA(IP12_22_20, CAN_DEBUGOUT1), + PINMUX_IPSR_DATA(IP12_24_23, SSI_SDATA4), + PINMUX_IPSR_MODSEL_DATA(IP12_24_23, STP_ISSYNC_0, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP12_24_23, MSIOF1_RXD, SEL_SOF1_0), + PINMUX_IPSR_DATA(IP12_24_23, CAN_DEBUGOUT2), + PINMUX_IPSR_MODSEL_DATA(IP12_27_25, SSI_SCK5, SEL_SSI5_0), + PINMUX_IPSR_MODSEL_DATA(IP12_27_25, SCIFB1_SCK, SEL_SCIFB1_0), + PINMUX_IPSR_MODSEL_DATA(IP12_27_25, IERX_B, SEL_IEB_1), + PINMUX_IPSR_DATA(IP12_27_25, DU2_EXHSYNC_DU2_HSYNC), + PINMUX_IPSR_DATA(IP12_27_25, QSTH_QHS), + PINMUX_IPSR_DATA(IP12_27_25, CAN_DEBUGOUT3), + PINMUX_IPSR_MODSEL_DATA(IP12_30_28, SSI_WS5, SEL_SSI5_0), + PINMUX_IPSR_MODSEL_DATA(IP12_30_28, SCIFB1_RXD, SEL_SCIFB1_0), + PINMUX_IPSR_MODSEL_DATA(IP12_30_28, IECLK_B, SEL_IEB_1), + PINMUX_IPSR_DATA(IP12_30_28, DU2_EXVSYNC_DU2_VSYNC), + PINMUX_IPSR_DATA(IP12_30_28, QSTB_QHE), + PINMUX_IPSR_DATA(IP12_30_28, CAN_DEBUGOUT4), + + PINMUX_IPSR_MODSEL_DATA(IP13_2_0, SSI_SDATA5, SEL_SSI5_0), + PINMUX_IPSR_MODSEL_DATA(IP13_2_0, SCIFB1_TXD, SEL_SCIFB1_0), + PINMUX_IPSR_MODSEL_DATA(IP13_2_0, IETX_B, SEL_IEB_1), + PINMUX_IPSR_DATA(IP13_2_0, DU2_DR2), + PINMUX_IPSR_DATA(IP13_2_0, LCDOUT2), + PINMUX_IPSR_DATA(IP13_2_0, CAN_DEBUGOUT5), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, SSI_SCK6, SEL_SSI6_0), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, SCIFB1_CTS_N, SEL_SCIFB1_0), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, BPFCLK_D, SEL_FM_3), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, RDS_CLK_C, SEL_RDS_2), + PINMUX_IPSR_DATA(IP13_6_3, DU2_DR3), + PINMUX_IPSR_DATA(IP13_6_3, LCDOUT3), + PINMUX_IPSR_DATA(IP13_6_3, CAN_DEBUGOUT6), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, BPFCLK_F, SEL_FM_5), + PINMUX_IPSR_MODSEL_DATA(IP13_6_3, RDS_CLK_E, SEL_RDS_4), + PINMUX_IPSR_MODSEL_DATA(IP13_9_7, SSI_WS6, SEL_SSI6_0), + PINMUX_IPSR_MODSEL_DATA(IP13_9_7, SCIFB1_RTS_N, SEL_SCIFB1_0), + PINMUX_IPSR_MODSEL_DATA(IP13_9_7, CAN0_TX_D, SEL_CAN0_3), + PINMUX_IPSR_DATA(IP13_9_7, DU2_DR4), + PINMUX_IPSR_DATA(IP13_9_7, LCDOUT4), + PINMUX_IPSR_DATA(IP13_9_7, CAN_DEBUGOUT7), + PINMUX_IPSR_MODSEL_DATA(IP13_12_10, SSI_SDATA6, SEL_SSI6_0), + PINMUX_IPSR_MODSEL_DATA(IP13_12_10, FMIN_D, SEL_FM_3), + PINMUX_IPSR_MODSEL_DATA(IP13_12_10, RDS_DATA_C, SEL_RDS_2), + PINMUX_IPSR_DATA(IP13_12_10, DU2_DR5), + PINMUX_IPSR_DATA(IP13_12_10, LCDOUT5), + PINMUX_IPSR_DATA(IP13_12_10, CAN_DEBUGOUT8), + PINMUX_IPSR_MODSEL_DATA(IP13_15_13, SSI_SCK78, SEL_SSI7_0), + PINMUX_IPSR_MODSEL_DATA(IP13_15_13, STP_IVCXO27_1, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP13_15_13, SCK1, SEL_SCIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP13_15_13, SCIFA1_SCK, SEL_SCIFA1_0), + PINMUX_IPSR_DATA(IP13_15_13, DU2_DR6), + PINMUX_IPSR_DATA(IP13_15_13, LCDOUT6), + PINMUX_IPSR_DATA(IP13_15_13, CAN_DEBUGOUT9), + PINMUX_IPSR_MODSEL_DATA(IP13_18_16, SSI_WS78, SEL_SSI7_0), + PINMUX_IPSR_MODSEL_DATA(IP13_18_16, STP_ISCLK_1, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP13_18_16, SCIFB2_SCK, SEL_SCIFB2_0), + PINMUX_IPSR_DATA(IP13_18_16, SCIFA2_CTS_N), + PINMUX_IPSR_DATA(IP13_18_16, DU2_DR7), + PINMUX_IPSR_DATA(IP13_18_16, LCDOUT7), + PINMUX_IPSR_DATA(IP13_18_16, CAN_DEBUGOUT10), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, SSI_SDATA7, SEL_SSI7_0), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, STP_ISD_1, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, SCIFB2_RXD, SEL_SCIFB2_0), + PINMUX_IPSR_DATA(IP13_22_19, SCIFA2_RTS_N), + PINMUX_IPSR_DATA(IP13_22_19, TCLK2), + PINMUX_IPSR_DATA(IP13_22_19, QSTVA_QVS), + PINMUX_IPSR_DATA(IP13_22_19, CAN_DEBUGOUT11), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, BPFCLK_E, SEL_FM_4), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, RDS_CLK_D, SEL_RDS_3), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, SSI_SDATA7_B, SEL_SSI7_1), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, FMIN_G, SEL_FM_6), + PINMUX_IPSR_MODSEL_DATA(IP13_22_19, RDS_DATA_F, SEL_RDS_5), + PINMUX_IPSR_MODSEL_DATA(IP13_25_23, SSI_SDATA8, SEL_SSI8_0), + PINMUX_IPSR_MODSEL_DATA(IP13_25_23, STP_ISEN_1, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP13_25_23, SCIFB2_TXD, SEL_SCIFB2_0), + PINMUX_IPSR_MODSEL_DATA(IP13_25_23, CAN0_TX_C, SEL_CAN0_2), + PINMUX_IPSR_DATA(IP13_25_23, CAN_DEBUGOUT12), + PINMUX_IPSR_MODSEL_DATA(IP13_25_23, SSI_SDATA8_B, SEL_SSI8_1), + PINMUX_IPSR_DATA(IP13_28_26, SSI_SDATA9), + PINMUX_IPSR_MODSEL_DATA(IP13_28_26, STP_ISSYNC_1, SEL_SSP_0), + PINMUX_IPSR_MODSEL_DATA(IP13_28_26, SCIFB2_CTS_N, SEL_SCIFB2_0), + PINMUX_IPSR_DATA(IP13_28_26, SSI_WS1), + PINMUX_IPSR_MODSEL_DATA(IP13_28_26, SSI_SDATA5_C, SEL_SSI5_2), + PINMUX_IPSR_DATA(IP13_28_26, CAN_DEBUGOUT13), + PINMUX_IPSR_DATA(IP13_30_29, AUDIO_CLKA), + PINMUX_IPSR_MODSEL_DATA(IP13_30_29, SCIFB2_RTS_N, SEL_SCIFB2_0), + PINMUX_IPSR_DATA(IP13_30_29, CAN_DEBUGOUT14), + + PINMUX_IPSR_DATA(IP14_2_0, AUDIO_CLKB), + PINMUX_IPSR_MODSEL_DATA(IP14_2_0, SCIF_CLK, SEL_SCIFCLK_0), + PINMUX_IPSR_MODSEL_DATA(IP14_2_0, CAN0_RX_D, SEL_CAN0_3), + PINMUX_IPSR_DATA(IP14_2_0, DVC_MUTE), + PINMUX_IPSR_MODSEL_DATA(IP14_2_0, CAN0_RX_C, SEL_CAN0_2), + PINMUX_IPSR_DATA(IP14_2_0, CAN_DEBUGOUT15), + PINMUX_IPSR_DATA(IP14_2_0, REMOCON), + PINMUX_IPSR_MODSEL_DATA(IP14_5_3, SCIFA0_SCK, SEL_SCFA_0), + PINMUX_IPSR_MODSEL_DATA(IP14_5_3, HSCK1, SEL_HSCIF1_0), + PINMUX_IPSR_DATA(IP14_5_3, SCK0), + PINMUX_IPSR_DATA(IP14_5_3, MSIOF3_SS2), + PINMUX_IPSR_DATA(IP14_5_3, DU2_DG2), + PINMUX_IPSR_DATA(IP14_5_3, LCDOUT10), + PINMUX_IPSR_MODSEL_DATA(IP14_5_3, SDA1_C, SEL_IIC1_2), + PINMUX_IPSR_MODSEL_DATA(IP14_5_3, SDA1_CIS_C, SEL_I2C1_2), + PINMUX_IPSR_MODSEL_DATA(IP14_8_6, SCIFA0_RXD, SEL_SCFA_0), + PINMUX_IPSR_MODSEL_DATA(IP14_8_6, HRX1, SEL_HSCIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_8_6, RX0, SEL_SCIF0_0), + PINMUX_IPSR_DATA(IP14_8_6, DU2_DR0), + PINMUX_IPSR_DATA(IP14_8_6, LCDOUT0), + PINMUX_IPSR_MODSEL_DATA(IP14_11_9, SCIFA0_TXD, SEL_SCFA_0), + PINMUX_IPSR_MODSEL_DATA(IP14_11_9, HTX1, SEL_HSCIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_11_9, TX0, SEL_SCIF0_0), + PINMUX_IPSR_DATA(IP14_11_9, DU2_DR1), + PINMUX_IPSR_DATA(IP14_11_9, LCDOUT1), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, SCIFA0_CTS_N, SEL_SCFA_0), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, HCTS1_N, SEL_HSCIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, CTS0_N, SEL_SCIF0_0), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, MSIOF3_SYNC, SEL_SOF3_0), + PINMUX_IPSR_DATA(IP14_15_12, DU2_DG3), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, LCDOUT11, SEL_HSCIF1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, PWM0_B, SEL_SCIF0_0), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, SCL1_C, SEL_IIC1_2), + PINMUX_IPSR_MODSEL_DATA(IP14_15_12, SCL1_CIS_C, SEL_I2C1_2), + PINMUX_IPSR_MODSEL_DATA(IP14_18_16, SCIFA0_RTS_N, SEL_SCFA_0), + PINMUX_IPSR_MODSEL_DATA(IP14_18_16, HRTS1_N, SEL_HSCIF1_0), + PINMUX_IPSR_DATA(IP14_18_16, RTS0_N_TANS), + PINMUX_IPSR_DATA(IP14_18_16, MSIOF3_SS1), + PINMUX_IPSR_DATA(IP14_18_16, DU2_DG0), + PINMUX_IPSR_DATA(IP14_18_16, LCDOUT8), + PINMUX_IPSR_DATA(IP14_18_16, PWM1_B), + PINMUX_IPSR_MODSEL_DATA(IP14_21_19, SCIFA1_RXD, SEL_SCIFA1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_21_19, AD_DI, SEL_ADI_0), + PINMUX_IPSR_MODSEL_DATA(IP14_21_19, RX1, SEL_SCIF1_0), + PINMUX_IPSR_DATA(IP14_21_19, DU2_EXODDF_DU2_ODDF_DISP_CDE), + PINMUX_IPSR_DATA(IP14_21_19, QCPV_QDE), + PINMUX_IPSR_MODSEL_DATA(IP14_24_22, SCIFA1_TXD, SEL_SCIFA1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_24_22, AD_DO, SEL_ADI_0), + PINMUX_IPSR_MODSEL_DATA(IP14_24_22, TX1, SEL_SCIF1_0), + PINMUX_IPSR_DATA(IP14_24_22, DU2_DG1), + PINMUX_IPSR_DATA(IP14_24_22, LCDOUT9), + PINMUX_IPSR_MODSEL_DATA(IP14_27_25, SCIFA1_CTS_N, SEL_SCIFA1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_27_25, AD_CLK, SEL_ADI_0), + PINMUX_IPSR_DATA(IP14_27_25, CTS1_N), + PINMUX_IPSR_MODSEL_DATA(IP14_27_25, MSIOF3_RXD, SEL_SOF3_0), + PINMUX_IPSR_DATA(IP14_27_25, DU0_DOTCLKOUT), + PINMUX_IPSR_DATA(IP14_27_25, QCLK), + PINMUX_IPSR_MODSEL_DATA(IP14_30_28, SCIFA1_RTS_N, SEL_SCIFA1_0), + PINMUX_IPSR_MODSEL_DATA(IP14_30_28, AD_NCS_N, SEL_ADI_0), + PINMUX_IPSR_DATA(IP14_30_28, RTS1_N_TANS), + PINMUX_IPSR_MODSEL_DATA(IP14_30_28, MSIOF3_TXD, SEL_SOF3_0), + PINMUX_IPSR_DATA(IP14_30_28, DU1_DOTCLKOUT), + PINMUX_IPSR_DATA(IP14_30_28, QSTVB_QVE), + PINMUX_IPSR_MODSEL_DATA(IP14_30_28, HRTS0_N_C, SEL_HSCIF0_2), + + PINMUX_IPSR_MODSEL_DATA(IP15_2_0, SCIFA2_SCK, SEL_SCIFA2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_2_0, FMCLK, SEL_FM_0), + PINMUX_IPSR_MODSEL_DATA(IP15_2_0, MSIOF3_SCK, SEL_SOF3_0), + PINMUX_IPSR_DATA(IP15_2_0, DU2_DG7), + PINMUX_IPSR_DATA(IP15_2_0, LCDOUT15), + PINMUX_IPSR_MODSEL_DATA(IP15_2_0, SCIF_CLK_B, SEL_SCIFCLK_0), + PINMUX_IPSR_MODSEL_DATA(IP15_5_3, SCIFA2_RXD, SEL_SCIFA2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_5_3, FMIN, SEL_FM_0), + PINMUX_IPSR_DATA(IP15_5_3, DU2_DB0), + PINMUX_IPSR_DATA(IP15_5_3, LCDOUT16), + PINMUX_IPSR_MODSEL_DATA(IP15_5_3, SCL2, SEL_IIC2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_5_3, SCL2_CIS, SEL_I2C2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_8_6, SCIFA2_TXD, SEL_SCIFA2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_8_6, BPFCLK, SEL_FM_0), + PINMUX_IPSR_DATA(IP15_8_6, DU2_DB1), + PINMUX_IPSR_DATA(IP15_8_6, LCDOUT17), + PINMUX_IPSR_MODSEL_DATA(IP15_8_6, SDA2, SEL_IIC2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_8_6, SDA2_CIS, SEL_I2C2_0), + PINMUX_IPSR_DATA(IP15_11_9, HSCK0), + PINMUX_IPSR_MODSEL_DATA(IP15_11_9, TS_SDEN0, SEL_TSIF0_0), + PINMUX_IPSR_DATA(IP15_11_9, DU2_DG4), + PINMUX_IPSR_DATA(IP15_11_9, LCDOUT12), + PINMUX_IPSR_MODSEL_DATA(IP15_11_9, HCTS0_N_C, SEL_IIC2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_11_9, SDA2_CIS, SEL_I2C2_0), + PINMUX_IPSR_MODSEL_DATA(IP15_13_12, HRX0, SEL_HSCIF0_0), + PINMUX_IPSR_DATA(IP15_13_12, DU2_DB2), + PINMUX_IPSR_DATA(IP15_13_12, LCDOUT18), + PINMUX_IPSR_MODSEL_DATA(IP15_15_14, HTX0, SEL_HSCIF0_0), + PINMUX_IPSR_DATA(IP15_15_14, DU2_DB3), + PINMUX_IPSR_DATA(IP15_15_14, LCDOUT19), + PINMUX_IPSR_MODSEL_DATA(IP15_17_16, HCTS0_N, SEL_HSCIF0_0), + PINMUX_IPSR_DATA(IP15_17_16, SSI_SCK9), + PINMUX_IPSR_DATA(IP15_17_16, DU2_DB4), + PINMUX_IPSR_DATA(IP15_17_16, LCDOUT20), + PINMUX_IPSR_MODSEL_DATA(IP15_19_18, HRTS0_N, SEL_HSCIF0_0), + PINMUX_IPSR_DATA(IP15_19_18, SSI_WS9), + PINMUX_IPSR_DATA(IP15_19_18, DU2_DB5), + PINMUX_IPSR_DATA(IP15_19_18, LCDOUT21), + PINMUX_IPSR_MODSEL_DATA(IP15_22_20, MSIOF0_SCK, SEL_SOF0_0), + PINMUX_IPSR_MODSEL_DATA(IP15_22_20, TS_SDAT0, SEL_TSIF0_0), + PINMUX_IPSR_DATA(IP15_22_20, ADICLK), + PINMUX_IPSR_DATA(IP15_22_20, DU2_DB6), + PINMUX_IPSR_DATA(IP15_22_20, LCDOUT22), + PINMUX_IPSR_DATA(IP15_25_23, MSIOF0_SYNC), + PINMUX_IPSR_MODSEL_DATA(IP15_25_23, TS_SCK0, SEL_TSIF0_0), + PINMUX_IPSR_DATA(IP15_25_23, SSI_SCK2), + PINMUX_IPSR_DATA(IP15_25_23, ADIDATA), + PINMUX_IPSR_DATA(IP15_25_23, DU2_DB7), + PINMUX_IPSR_DATA(IP15_25_23, LCDOUT23), + PINMUX_IPSR_MODSEL_DATA(IP15_25_23, SCIFA2_RXD_B, SEL_SCIFA2_1), + PINMUX_IPSR_MODSEL_DATA(IP15_27_26, MSIOF0_SS1, SEL_SOF0_0), + PINMUX_IPSR_DATA(IP15_27_26, ADICHS0), + PINMUX_IPSR_DATA(IP15_27_26, DU2_DG5), + PINMUX_IPSR_DATA(IP15_27_26, LCDOUT13), + PINMUX_IPSR_MODSEL_DATA(IP15_29_28, MSIOF0_TXD, SEL_SOF0_0), + PINMUX_IPSR_DATA(IP15_29_28, ADICHS1), + PINMUX_IPSR_DATA(IP15_29_28, DU2_DG6), + PINMUX_IPSR_DATA(IP15_29_28, LCDOUT14), + + PINMUX_IPSR_MODSEL_DATA(IP16_2_0, MSIOF0_SS2, SEL_SOF0_0), + PINMUX_IPSR_DATA(IP16_2_0, AUDIO_CLKOUT), + PINMUX_IPSR_DATA(IP16_2_0, ADICHS2), + PINMUX_IPSR_DATA(IP16_2_0, DU2_DISP), + PINMUX_IPSR_DATA(IP16_2_0, QPOLA), + PINMUX_IPSR_MODSEL_DATA(IP16_2_0, HTX0_C, SEL_HSCIF0_2), + PINMUX_IPSR_MODSEL_DATA(IP16_2_0, SCIFA2_TXD_B, SEL_SCIFA2_1), + PINMUX_IPSR_MODSEL_DATA(IP16_5_3, MSIOF0_RXD, SEL_SOF0_0), + PINMUX_IPSR_MODSEL_DATA(IP16_5_3, TS_SPSYNC0, SEL_TSIF0_0), + PINMUX_IPSR_DATA(IP16_5_3, SSI_WS2), + PINMUX_IPSR_DATA(IP16_5_3, ADICS_SAMP), + PINMUX_IPSR_DATA(IP16_5_3, DU2_CDE), + PINMUX_IPSR_DATA(IP16_5_3, QPOLB), + PINMUX_IPSR_MODSEL_DATA(IP16_5_3, HRX0_C, SEL_HSCIF0_2), + PINMUX_IPSR_DATA(IP16_6, USB1_PWEN), + PINMUX_IPSR_DATA(IP16_6, AUDIO_CLKOUT_D), + PINMUX_IPSR_DATA(IP16_7, USB1_OVC), + PINMUX_IPSR_MODSEL_DATA(IP16_7, TCLK1_B, SEL_TMU1_1), +}; + +static struct pinmux_gpio pinmux_gpios[] = { + PINMUX_GPIO_GP_ALL(), + + GPIO_FN(VI1_DATA7_VI1_B7), GPIO_FN(USB0_PWEN), GPIO_FN(USB0_OVC_VBUS), + GPIO_FN(USB2_PWEN), GPIO_FN(USB2_OVC), GPIO_FN(AVS1), GPIO_FN(AVS2), + GPIO_FN(DU_DOTCLKIN0), GPIO_FN(DU_DOTCLKIN2), + + /*IPSR0*/ + GPIO_FN(D1), GPIO_FN(MSIOF3_SYNC_B), GPIO_FN(VI3_DATA1), + GPIO_FN(VI0_G5), GPIO_FN(VI0_G5_B), GPIO_FN(D2), GPIO_FN(MSIOF3_RXD_B), + GPIO_FN(VI3_DATA2), GPIO_FN(VI0_G6), GPIO_FN(VI0_G6_B), GPIO_FN(D3), + GPIO_FN(MSIOF3_TXD_B), GPIO_FN(VI3_DATA3), GPIO_FN(VI0_G7), + GPIO_FN(VI0_G7_B), GPIO_FN(D4), GPIO_FN(SCIFB1_RXD_F), + GPIO_FN(SCIFB0_RXD_C), GPIO_FN(VI3_DATA4), GPIO_FN(VI0_R0), + GPIO_FN(VI0_R0_B), GPIO_FN(RX0_B), GPIO_FN(D5), GPIO_FN(SCIFB1_TXD_F), + GPIO_FN(SCIFB0_TXD_C), GPIO_FN(VI3_DATA5), GPIO_FN(VI0_R1), + GPIO_FN(VI0_R1_B), GPIO_FN(TX0_B), GPIO_FN(D6), GPIO_FN(SCL2_C), + GPIO_FN(VI3_DATA6), GPIO_FN(VI0_R2), GPIO_FN(VI0_R2_B), + GPIO_FN(SCL2_CIS_C), GPIO_FN(D7), GPIO_FN(AD_DI_B), GPIO_FN(SDA2_C), + GPIO_FN(VI3_DATA7), GPIO_FN(VI0_R3), GPIO_FN(VI0_R3_B), + GPIO_FN(SDA2_CIS_C), GPIO_FN(D8), GPIO_FN(SCIFA1_SCK_C), + GPIO_FN(AVB_TXD0), GPIO_FN(MII_TXD0), GPIO_FN(VI0_G0), + GPIO_FN(VI0_G0_B), GPIO_FN(VI2_DATA0_VI2_B0), + + /*IPSR1*/ + GPIO_FN(D9), GPIO_FN(SCIFA1_RXD_C), GPIO_FN(AVB_TXD1), + GPIO_FN(MII_TXD1), GPIO_FN(VI0_G1), GPIO_FN(VI0_G1_B), + GPIO_FN(VI2_DATA1_VI2_B1), GPIO_FN(D10), GPIO_FN(SCIFA1_TXD_C), + GPIO_FN(AVB_TXD2), GPIO_FN(MII_TXD2), GPIO_FN(VI0_G2), + GPIO_FN(VI0_G2_B), GPIO_FN(VI2_DATA2_VI2_B2), GPIO_FN(D11), + GPIO_FN(SCIFA1_CTS_N_C), GPIO_FN(AVB_TXD3), GPIO_FN(MII_TXD3), + GPIO_FN(VI0_G3), GPIO_FN(VI0_G3_B), GPIO_FN(VI2_DATA3_VI2_B3), + GPIO_FN(D12), GPIO_FN(SCIFA1_RTS_N_C), GPIO_FN(AVB_TXD4), + GPIO_FN(VI0_HSYNC_N), GPIO_FN(VI0_HSYNC_N_B), GPIO_FN(VI2_DATA4_VI2_B4), + GPIO_FN(D13), GPIO_FN(AVB_TXD5), GPIO_FN(VI0_VSYNC_N), + GPIO_FN(VI0_VSYNC_N_B), GPIO_FN(VI2_DATA5_VI2_B5), GPIO_FN(D14), + GPIO_FN(SCIFB1_RXD_C), GPIO_FN(AVB_TXD6), GPIO_FN(RX1_B), + GPIO_FN(VI0_CLKENB), GPIO_FN(VI0_CLKENB_B), GPIO_FN(VI2_DATA6_VI2_B6), + GPIO_FN(D15), GPIO_FN(SCIFB1_TXD_C), GPIO_FN(AVB_TXD7), GPIO_FN(TX1_B), + GPIO_FN(VI0_FIELD), GPIO_FN(VI0_FIELD_B), GPIO_FN(VI2_DATA7_VI2_B7), + GPIO_FN(A0), GPIO_FN(PWM3), GPIO_FN(A1), GPIO_FN(PWM4), + + /*IPSR2*/ + GPIO_FN(A2), GPIO_FN(PWM5), GPIO_FN(MSIOF1_SS1_B), GPIO_FN(A3), + GPIO_FN(PWM6), GPIO_FN(MSIOF1_SS2_B), GPIO_FN(A4), + GPIO_FN(MSIOF1_TXD_B), GPIO_FN(TPU0TO0), GPIO_FN(A5), + GPIO_FN(SCIFA1_TXD_B), GPIO_FN(TPU0TO1), GPIO_FN(A6), + GPIO_FN(SCIFA1_RTS_N_B), GPIO_FN(TPU0TO2), GPIO_FN(A7), + GPIO_FN(SCIFA1_SCK_B), GPIO_FN(AUDIO_CLKOUT_B), GPIO_FN(TPU0TO3), + GPIO_FN(A8), GPIO_FN(SCIFA1_RXD_B), GPIO_FN(SSI_SCK5_B), + GPIO_FN(VI0_R4), GPIO_FN(VI0_R4_B), GPIO_FN(SCIFB2_RXD_C), + GPIO_FN(VI2_DATA0_VI2_B0_B), GPIO_FN(A9), GPIO_FN(SCIFA1_CTS_N_B), + GPIO_FN(SSI_WS5_B), GPIO_FN(VI0_R5), GPIO_FN(VI0_R5_B), + GPIO_FN(SCIFB2_TXD_C), GPIO_FN(VI2_DATA1_VI2_B1_B), GPIO_FN(A10), + GPIO_FN(SSI_SDATA5_B), GPIO_FN(MSIOF2_SYNC), GPIO_FN(VI0_R6), + GPIO_FN(VI0_R6_B), GPIO_FN(VI2_DATA2_VI2_B2_B), + + /*IPSR3*/ + GPIO_FN(A11), GPIO_FN(SCIFB2_CTS_N_B), GPIO_FN(MSIOF2_SCK), + GPIO_FN(VI1_R0), GPIO_FN(VI1_R0_B), GPIO_FN(VI2_G0), + GPIO_FN(VI2_DATA3_VI2_B3_B), GPIO_FN(A12), GPIO_FN(SCIFB2_RXD_B), + GPIO_FN(MSIOF2_TXD), GPIO_FN(VI1_R1), GPIO_FN(VI1_R1_B), + GPIO_FN(VI2_G1), GPIO_FN(VI2_DATA4_VI2_B4_B), GPIO_FN(A13), + GPIO_FN(SCIFB2_RTS_N_B), GPIO_FN(EX_WAIT2), GPIO_FN(MSIOF2_RXD), + GPIO_FN(VI1_R2), GPIO_FN(VI1_R2_B), GPIO_FN(VI2_G2), + GPIO_FN(VI2_DATA5_VI2_B5_B), GPIO_FN(A14), GPIO_FN(SCIFB2_TXD_B), + GPIO_FN(ATACS11_N), GPIO_FN(MSIOF2_SS1), GPIO_FN(A15), + GPIO_FN(SCIFB2_SCK_B), GPIO_FN(ATARD1_N), GPIO_FN(MSIOF2_SS2), + GPIO_FN(A16), GPIO_FN(ATAWR1_N), GPIO_FN(A17), GPIO_FN(AD_DO_B), + GPIO_FN(ATADIR1_N), GPIO_FN(A18), GPIO_FN(AD_CLK_B), GPIO_FN(ATAG1_N), + GPIO_FN(A19), GPIO_FN(AD_NCS_N_B), GPIO_FN(ATACS01_N), + GPIO_FN(EX_WAIT0_B), GPIO_FN(A20), GPIO_FN(SPCLK), GPIO_FN(VI1_R3), + GPIO_FN(VI1_R3_B), GPIO_FN(VI2_G4), + + /*IPSR4*/ + GPIO_FN(A21), GPIO_FN(MOSI_IO0), GPIO_FN(VI1_R4), GPIO_FN(VI1_R4_B), + GPIO_FN(VI2_G5), GPIO_FN(A22), GPIO_FN(MISO_IO1), GPIO_FN(VI1_R5), + GPIO_FN(VI1_R5_B), GPIO_FN(VI2_G6), GPIO_FN(A23), GPIO_FN(IO2), + GPIO_FN(VI1_G7), GPIO_FN(VI1_G7_B), GPIO_FN(VI2_G7), GPIO_FN(A24), + GPIO_FN(IO3), GPIO_FN(VI1_R7), GPIO_FN(VI1_R7_B), GPIO_FN(VI2_CLKENB), + GPIO_FN(VI2_CLKENB_B), GPIO_FN(A25), GPIO_FN(SSL), GPIO_FN(VI1_G6), + GPIO_FN(VI1_G6_B), GPIO_FN(VI2_FIELD), GPIO_FN(VI2_FIELD_B), + GPIO_FN(CS0_N), GPIO_FN(VI1_R6), GPIO_FN(VI1_R6_B), GPIO_FN(VI2_G3), + GPIO_FN(MSIOF0_SS2_B), GPIO_FN(CS1_N_A26), GPIO_FN(SPEEDIN), + GPIO_FN(VI0_R7), GPIO_FN(VI0_R7_B), GPIO_FN(VI2_CLK), + GPIO_FN(VI2_CLK_B), GPIO_FN(EX_CS0_N), GPIO_FN(HRX1_B), + GPIO_FN(VI1_G5), GPIO_FN(VI1_G5_B), GPIO_FN(VI2_R0), GPIO_FN(HTX0_B), + GPIO_FN(MSIOF0_SS1_B), GPIO_FN(EX_CS1_N), GPIO_FN(GPS_CLK), + GPIO_FN(HCTS1_N_B), GPIO_FN(VI1_FIELD), GPIO_FN(VI1_FIELD_B), + GPIO_FN(VI2_R1), GPIO_FN(EX_CS2_N), GPIO_FN(GPS_SIGN), + GPIO_FN(HRTS1_N_B), GPIO_FN(VI3_CLKENB), GPIO_FN(VI1_G0), + GPIO_FN(VI1_G0_B), GPIO_FN(VI2_R2), + + /*IPSR5*/ + GPIO_FN(EX_CS3_N), GPIO_FN(GPS_MAG), GPIO_FN(VI3_FIELD), + GPIO_FN(VI1_G1), GPIO_FN(VI1_G1_B), GPIO_FN(VI2_R3), GPIO_FN(EX_CS4_N), + GPIO_FN(MSIOF1_SCK_B), GPIO_FN(VI3_HSYNC_N), GPIO_FN(VI2_HSYNC_N), + GPIO_FN(SCL1), GPIO_FN(VI2_HSYNC_N_B), GPIO_FN(INTC_EN0_N), + GPIO_FN(SCL1_CIS), GPIO_FN(EX_CS5_N), GPIO_FN(CAN0_RX), + GPIO_FN(MSIOF1_RXD_B), GPIO_FN(VI3_VSYNC_N), GPIO_FN(VI1_G2), + GPIO_FN(VI1_G2_B), GPIO_FN(VI2_R4), GPIO_FN(SDA1), GPIO_FN(INTC_EN1_N), + GPIO_FN(SDA1_CIS), GPIO_FN(BS_N), GPIO_FN(IETX), GPIO_FN(HTX1_B), + GPIO_FN(CAN1_TX), GPIO_FN(DRACK0), GPIO_FN(IETX_C), GPIO_FN(RD_N), + GPIO_FN(CAN0_TX), GPIO_FN(SCIFA0_SCK_B), GPIO_FN(RD_WR_N), + GPIO_FN(VI1_G3), GPIO_FN(VI1_G3_B), GPIO_FN(VI2_R5), + GPIO_FN(SCIFA0_RXD_B), GPIO_FN(INTC_IRQ4_N), GPIO_FN(WE0_N), + GPIO_FN(IECLK), GPIO_FN(CAN_CLK), GPIO_FN(VI2_VSYNC_N), + GPIO_FN(SCIFA0_TXD_B), GPIO_FN(VI2_VSYNC_N_B), GPIO_FN(WE1_N), + GPIO_FN(IERX), GPIO_FN(CAN1_RX), GPIO_FN(VI1_G4), GPIO_FN(VI1_G4_B), + GPIO_FN(VI2_R6), GPIO_FN(SCIFA0_CTS_N_B), GPIO_FN(IERX_C), + GPIO_FN(EX_WAIT0), GPIO_FN(IRQ3), GPIO_FN(INTC_IRQ3_N), + GPIO_FN(VI3_CLK), GPIO_FN(SCIFA0_RTS_N_B), GPIO_FN(HRX0_B), + GPIO_FN(MSIOF0_SCK_B), GPIO_FN(DREQ0_N), GPIO_FN(VI1_HSYNC_N), + GPIO_FN(VI1_HSYNC_N_B), GPIO_FN(VI2_R7), GPIO_FN(SSI_SCK78_C), + GPIO_FN(SSI_WS78_B), + + /*IPSR6*/ + GPIO_FN(DACK0), GPIO_FN(IRQ0), GPIO_FN(INTC_IRQ0_N), + GPIO_FN(SSI_SCK6_B), GPIO_FN(VI1_VSYNC_N), GPIO_FN(VI1_VSYNC_N_B), + GPIO_FN(SSI_WS78_C), GPIO_FN(DREQ1_N), GPIO_FN(VI1_CLKENB), + GPIO_FN(VI1_CLKENB_B), GPIO_FN(SSI_SDATA7_C), GPIO_FN(SSI_SCK78_B), + GPIO_FN(DACK1), GPIO_FN(IRQ1), GPIO_FN(INTC_IRQ1_N), GPIO_FN(SSI_WS6_B), + GPIO_FN(SSI_SDATA8_C), GPIO_FN(DREQ2_N), GPIO_FN(HSCK1_B), + GPIO_FN(HCTS0_N_B), GPIO_FN(MSIOF0_TXD_B), GPIO_FN(DACK2), + GPIO_FN(IRQ2), GPIO_FN(INTC_IRQ2_N), GPIO_FN(SSI_SDATA6_B), + GPIO_FN(HRTS0_N_B), GPIO_FN(MSIOF0_RXD_B), GPIO_FN(ETH_CRS_DV), + GPIO_FN(RMII_CRS_DV), GPIO_FN(STP_ISCLK_0_B), GPIO_FN(TS_SDEN0_D), + GPIO_FN(GLO_Q0_C), GPIO_FN(SCL2_E), GPIO_FN(SCL2_CIS_E), + GPIO_FN(ETH_RX_ER), GPIO_FN(RMII_RX_ER), GPIO_FN(STP_ISD_0_B), + GPIO_FN(TS_SPSYNC0_D), GPIO_FN(GLO_Q1_C), GPIO_FN(SDA2_E), + GPIO_FN(SDA2_CIS_E), GPIO_FN(ETH_RXD0), GPIO_FN(RMII_RXD0), + GPIO_FN(STP_ISEN_0_B), GPIO_FN(TS_SDAT0_D), GPIO_FN(GLO_I0_C), + GPIO_FN(SCIFB1_SCK_G), GPIO_FN(SCK1_E), GPIO_FN(ETH_RXD1), + GPIO_FN(RMII_RXD1), GPIO_FN(HRX0_E), GPIO_FN(STP_ISSYNC_0_B), + GPIO_FN(TS_SCK0_D), GPIO_FN(GLO_I1_C), GPIO_FN(SCIFB1_RXD_G), + GPIO_FN(RX1_E), GPIO_FN(ETH_LINK), GPIO_FN(RMII_LINK), GPIO_FN(HTX0_E), + GPIO_FN(STP_IVCXO27_0_B), GPIO_FN(SCIFB1_TXD_G), GPIO_FN(TX1_E), + GPIO_FN(ETH_REF_CLK), GPIO_FN(RMII_REF_CLK), GPIO_FN(HCTS0_N_E), + GPIO_FN(STP_IVCXO27_1_B), GPIO_FN(HRX0_F), + + /*IPSR7*/ + GPIO_FN(ETH_MDIO), GPIO_FN(RMII_MDIO), GPIO_FN(HRTS0_N_E), + GPIO_FN(SIM0_D_C), GPIO_FN(HCTS0_N_F), GPIO_FN(ETH_TXD1), + GPIO_FN(RMII_TXD1), GPIO_FN(HTX0_F), GPIO_FN(BPFCLK_G), + GPIO_FN(RDS_CLK_F), GPIO_FN(ETH_TX_EN), GPIO_FN(RMII_TX_EN), + GPIO_FN(SIM0_CLK_C), GPIO_FN(HRTS0_N_F), GPIO_FN(ETH_MAGIC), + GPIO_FN(RMII_MAGIC), GPIO_FN(SIM0_RST_C), GPIO_FN(ETH_TXD0), + GPIO_FN(RMII_TXD0), GPIO_FN(STP_ISCLK_1_B), GPIO_FN(TS_SDEN1_C), + GPIO_FN(GLO_SCLK_C), GPIO_FN(ETH_MDC), GPIO_FN(RMII_MDC), + GPIO_FN(STP_ISD_1_B), GPIO_FN(TS_SPSYNC1_C), GPIO_FN(GLO_SDATA_C), + GPIO_FN(PWM0), GPIO_FN(SCIFA2_SCK_C), GPIO_FN(STP_ISEN_1_B), + GPIO_FN(TS_SDAT1_C), GPIO_FN(GLO_SS_C), GPIO_FN(PWM1), + GPIO_FN(SCIFA2_TXD_C), GPIO_FN(STP_ISSYNC_1_B), GPIO_FN(TS_SCK1_C), + GPIO_FN(GLO_RFON_C), GPIO_FN(PCMOE_N), GPIO_FN(PWM2), GPIO_FN(PWMFSW0), + GPIO_FN(SCIFA2_RXD_C), GPIO_FN(PCMWE_N), GPIO_FN(IECLK_C), + GPIO_FN(DU1_DOTCLKIN), GPIO_FN(AUDIO_CLKC), GPIO_FN(AUDIO_CLKOUT_C), + GPIO_FN(VI0_CLK), GPIO_FN(ATACS00_N), GPIO_FN(AVB_RXD1), + GPIO_FN(MII_RXD1), GPIO_FN(VI0_DATA0_VI0_B0), GPIO_FN(ATACS10_N), + GPIO_FN(AVB_RXD2), GPIO_FN(MII_RXD2), + + /*IPSR8*/ + GPIO_FN(VI0_DATA1_VI0_B1), GPIO_FN(ATARD0_N), GPIO_FN(AVB_RXD3), + GPIO_FN(MII_RXD3), GPIO_FN(VI0_DATA2_VI0_B2), GPIO_FN(ATAWR0_N), + GPIO_FN(AVB_RXD4), GPIO_FN(VI0_DATA3_VI0_B3), GPIO_FN(ATADIR0_N), + GPIO_FN(AVB_RXD5), GPIO_FN(VI0_DATA4_VI0_B4), GPIO_FN(ATAG0_N), + GPIO_FN(AVB_RXD6), GPIO_FN(VI0_DATA5_VI0_B5), GPIO_FN(EX_WAIT1), + GPIO_FN(AVB_RXD7), GPIO_FN(VI0_DATA6_VI0_B6), GPIO_FN(AVB_RX_ER), + GPIO_FN(MII_RX_ER), GPIO_FN(VI0_DATA7_VI0_B7), GPIO_FN(AVB_RX_CLK), + GPIO_FN(MII_RX_CLK), GPIO_FN(VI1_CLK), GPIO_FN(AVB_RX_DV), + GPIO_FN(MII_RX_DV), GPIO_FN(VI1_DATA0_VI1_B0), GPIO_FN(SCIFA1_SCK_D), + GPIO_FN(AVB_CRS), GPIO_FN(MII_CRS), GPIO_FN(VI1_DATA1_VI1_B1), + GPIO_FN(SCIFA1_RXD_D), GPIO_FN(AVB_MDC), GPIO_FN(MII_MDC), + GPIO_FN(VI1_DATA2_VI1_B2), GPIO_FN(SCIFA1_TXD_D), GPIO_FN(AVB_MDIO), + GPIO_FN(MII_MDIO), GPIO_FN(VI1_DATA3_VI1_B3), GPIO_FN(SCIFA1_CTS_N_D), + GPIO_FN(AVB_GTX_CLK), GPIO_FN(VI1_DATA4_VI1_B4), + GPIO_FN(SCIFA1_RTS_N_D), GPIO_FN(AVB_MAGIC), GPIO_FN(MII_MAGIC), + GPIO_FN(VI1_DATA5_VI1_B5), GPIO_FN(AVB_PHY_INT), + GPIO_FN(VI1_DATA6_VI1_B6), GPIO_FN(AVB_GTXREFCLK), + GPIO_FN(SD0_CLK), GPIO_FN(VI1_DATA0_VI1_B0_B), GPIO_FN(SD0_CMD), + GPIO_FN(SCIFB1_SCK_B), GPIO_FN(VI1_DATA1_VI1_B1_B), + + /*IPSR9*/ + GPIO_FN(SD0_DAT0), GPIO_FN(SCIFB1_RXD_B), GPIO_FN(VI1_DATA2_VI1_B2_B), + GPIO_FN(SD0_DAT1), GPIO_FN(SCIFB1_TXD_B), GPIO_FN(VI1_DATA3_VI1_B3_B), + GPIO_FN(SD0_DAT2), GPIO_FN(SCIFB1_CTS_N_B), GPIO_FN(VI1_DATA4_VI1_B4_B), + GPIO_FN(SD0_DAT3), GPIO_FN(SCIFB1_RTS_N_B), GPIO_FN(VI1_DATA5_VI1_B5_B), + GPIO_FN(SD0_CD), GPIO_FN(MMC0_D6), GPIO_FN(TS_SDEN0_B), + GPIO_FN(USB0_EXTP), GPIO_FN(GLO_SCLK), GPIO_FN(VI1_DATA6_VI1_B6_B), + GPIO_FN(SCL1_B), GPIO_FN(SCL1_CIS_B), GPIO_FN(VI2_DATA6_VI2_B6_B), + GPIO_FN(SD0_WP), GPIO_FN(MMC0_D7), GPIO_FN(TS_SPSYNC0_B), + GPIO_FN(USB0_IDIN), GPIO_FN(GLO_SDATA), GPIO_FN(VI1_DATA7_VI1_B7_B), + GPIO_FN(SDA1_B), GPIO_FN(SDA1_CIS_B), GPIO_FN(VI2_DATA7_VI2_B7_B), + GPIO_FN(SD1_CLK), GPIO_FN(AVB_TX_EN), GPIO_FN(MII_TX_EN), + GPIO_FN(SD1_CMD), GPIO_FN(AVB_TX_ER), GPIO_FN(MII_TX_ER), + GPIO_FN(SCIFB0_SCK_B), GPIO_FN(SD1_DAT0), GPIO_FN(AVB_TX_CLK), + GPIO_FN(MII_TX_CLK), GPIO_FN(SCIFB0_RXD_B), GPIO_FN(SD1_DAT1), + GPIO_FN(AVB_LINK), GPIO_FN(MII_LINK), GPIO_FN(SCIFB0_TXD_B), + GPIO_FN(SD1_DAT2), GPIO_FN(AVB_COL), GPIO_FN(MII_COL), + GPIO_FN(SCIFB0_CTS_N_B), GPIO_FN(SD1_DAT3), GPIO_FN(AVB_RXD0), + GPIO_FN(MII_RXD0), GPIO_FN(SCIFB0_RTS_N_B), GPIO_FN(SD1_CD), + GPIO_FN(MMC1_D6), GPIO_FN(TS_SDEN1), GPIO_FN(USB1_EXTP), + GPIO_FN(GLO_SS), GPIO_FN(VI0_CLK_B), GPIO_FN(SCL2_D), + GPIO_FN(SCL2_CIS_D), GPIO_FN(SIM0_CLK_B), GPIO_FN(VI3_CLK_B), + + /*IPSR10*/ + GPIO_FN(SD1_WP), GPIO_FN(MMC1_D7), GPIO_FN(TS_SPSYNC1), + GPIO_FN(USB1_IDIN), GPIO_FN(GLO_RFON), GPIO_FN(VI1_CLK_B), + GPIO_FN(SDA2_D), GPIO_FN(SDA2_CIS_D), GPIO_FN(SIM0_D_B), + GPIO_FN(SD2_CLK), GPIO_FN(MMC0_CLK), GPIO_FN(SIM0_CLK), + GPIO_FN(VI0_DATA0_VI0_B0_B), GPIO_FN(TS_SDEN0_C), GPIO_FN(GLO_SCLK_B), + GPIO_FN(VI3_DATA0_B), GPIO_FN(SD2_CMD), GPIO_FN(MMC0_CMD), + GPIO_FN(SIM0_D), GPIO_FN(VI0_DATA1_VI0_B1_B), GPIO_FN(SCIFB1_SCK_E), + GPIO_FN(SCK1_D), GPIO_FN(TS_SPSYNC0_C), GPIO_FN(GLO_SDATA_B), + GPIO_FN(VI3_DATA1_B), GPIO_FN(SD2_DAT0), GPIO_FN(MMC0_D0), + GPIO_FN(FMCLK_B), GPIO_FN(VI0_DATA2_VI0_B2_B), GPIO_FN(SCIFB1_RXD_E), + GPIO_FN(RX1_D), GPIO_FN(TS_SDAT0_C), GPIO_FN(GLO_SS_B), + GPIO_FN(VI3_DATA2_B), GPIO_FN(SD2_DAT1), GPIO_FN(MMC0_D1), + GPIO_FN(FMIN_B), GPIO_FN(RDS_DATA), GPIO_FN(VI0_DATA3_VI0_B3_B), + GPIO_FN(SCIFB1_TXD_E), GPIO_FN(TX1_D), GPIO_FN(TS_SCK0_C), + GPIO_FN(GLO_RFON_B), GPIO_FN(VI3_DATA3_B), GPIO_FN(SD2_DAT2), + GPIO_FN(MMC0_D2), GPIO_FN(BPFCLK_B), GPIO_FN(RDS_CLK), + GPIO_FN(VI0_DATA4_VI0_B4_B), GPIO_FN(HRX0_D), GPIO_FN(TS_SDEN1_B), + GPIO_FN(GLO_Q0_B), GPIO_FN(VI3_DATA4_B), GPIO_FN(SD2_DAT3), + GPIO_FN(MMC0_D3), GPIO_FN(SIM0_RST), GPIO_FN(VI0_DATA5_VI0_B5_B), + GPIO_FN(HTX0_D), GPIO_FN(TS_SPSYNC1_B), GPIO_FN(GLO_Q1_B), + GPIO_FN(VI3_DATA5_B), GPIO_FN(SD2_CD), GPIO_FN(MMC0_D4), + GPIO_FN(TS_SDAT0_B), GPIO_FN(USB2_EXTP), GPIO_FN(GLO_I0), + GPIO_FN(VI0_DATA6_VI0_B6_B), GPIO_FN(HCTS0_N_D), GPIO_FN(TS_SDAT1_B), + GPIO_FN(GLO_I0_B), GPIO_FN(VI3_DATA6_B), + + /*IPSR11*/ + GPIO_FN(SD2_WP), GPIO_FN(MMC0_D5), GPIO_FN(TS_SCK0_B), + GPIO_FN(USB2_IDIN), GPIO_FN(GLO_I1), GPIO_FN(VI0_DATA7_VI0_B7_B), + GPIO_FN(HRTS0_N_D), GPIO_FN(TS_SCK1_B), GPIO_FN(GLO_I1_B), + GPIO_FN(VI3_DATA7_B), GPIO_FN(SD3_CLK), GPIO_FN(MMC1_CLK), + GPIO_FN(SD3_CMD), GPIO_FN(MMC1_CMD), GPIO_FN(MTS_N), GPIO_FN(SD3_DAT0), + GPIO_FN(MMC1_D0), GPIO_FN(STM_N), GPIO_FN(SD3_DAT1), GPIO_FN(MMC1_D1), + GPIO_FN(MDATA), GPIO_FN(SD3_DAT2), GPIO_FN(MMC1_D2), GPIO_FN(SDATA), + GPIO_FN(SD3_DAT3), GPIO_FN(MMC1_D3), GPIO_FN(SCKZ), GPIO_FN(SD3_CD), + GPIO_FN(MMC1_D4), GPIO_FN(TS_SDAT1), GPIO_FN(VSP), GPIO_FN(GLO_Q0), + GPIO_FN(SIM0_RST_B), GPIO_FN(SD3_WP), GPIO_FN(MMC1_D5), + GPIO_FN(TS_SCK1), GPIO_FN(GLO_Q1), GPIO_FN(FMIN_C), GPIO_FN(RDS_DATA_B), + GPIO_FN(FMIN_E), GPIO_FN(RDS_DATA_D), GPIO_FN(FMIN_F), + GPIO_FN(RDS_DATA_E), GPIO_FN(MLB_CLK), GPIO_FN(SCL2_B), + GPIO_FN(SCL2_CIS_B), GPIO_FN(MLB_SIG), GPIO_FN(SCIFB1_RXD_D), + GPIO_FN(RX1_C), GPIO_FN(SDA2_B), GPIO_FN(SDA2_CIS_B), GPIO_FN(MLB_DAT), + GPIO_FN(SPV_EVEN), GPIO_FN(SCIFB1_TXD_D), GPIO_FN(TX1_C), + GPIO_FN(BPFCLK_C), GPIO_FN(RDS_CLK_B), GPIO_FN(SSI_SCK0129), + GPIO_FN(CAN_CLK_B), GPIO_FN(MOUT0), + + /*IPSR12*/ + GPIO_FN(SSI_WS0129), GPIO_FN(CAN0_TX_B), GPIO_FN(MOUT1), + GPIO_FN(SSI_SDATA0), GPIO_FN(CAN0_RX_B), GPIO_FN(MOUT2), + GPIO_FN(SSI_SDATA1), GPIO_FN(CAN1_TX_B), GPIO_FN(MOUT5), + GPIO_FN(SSI_SDATA2), GPIO_FN(CAN1_RX_B), GPIO_FN(SSI_SCK1), + GPIO_FN(MOUT6), GPIO_FN(SSI_SCK34), GPIO_FN(STP_OPWM_0), + GPIO_FN(SCIFB0_SCK), GPIO_FN(MSIOF1_SCK), GPIO_FN(CAN_DEBUG_HW_TRIGGER), + GPIO_FN(SSI_WS34), GPIO_FN(STP_IVCXO27_0), GPIO_FN(SCIFB0_RXD), + GPIO_FN(MSIOF1_SYNC), GPIO_FN(CAN_STEP0), GPIO_FN(SSI_SDATA3), + GPIO_FN(STP_ISCLK_0), GPIO_FN(SCIFB0_TXD), GPIO_FN(MSIOF1_SS1), + GPIO_FN(CAN_TXCLK), GPIO_FN(SSI_SCK4), GPIO_FN(STP_ISD_0), + GPIO_FN(SCIFB0_CTS_N), GPIO_FN(MSIOF1_SS2), GPIO_FN(SSI_SCK5_C), + GPIO_FN(CAN_DEBUGOUT0), GPIO_FN(SSI_WS4), GPIO_FN(STP_ISEN_0), + GPIO_FN(SCIFB0_RTS_N), GPIO_FN(MSIOF1_TXD), GPIO_FN(SSI_WS5_C), + GPIO_FN(CAN_DEBUGOUT1), GPIO_FN(SSI_SDATA4), GPIO_FN(STP_ISSYNC_0), + GPIO_FN(MSIOF1_RXD), GPIO_FN(CAN_DEBUGOUT2), GPIO_FN(SSI_SCK5), + GPIO_FN(SCIFB1_SCK), GPIO_FN(IERX_B), GPIO_FN(DU2_EXHSYNC_DU2_HSYNC), + GPIO_FN(QSTH_QHS), GPIO_FN(CAN_DEBUGOUT3), GPIO_FN(SSI_WS5), + GPIO_FN(SCIFB1_RXD), GPIO_FN(IECLK_B), GPIO_FN(DU2_EXVSYNC_DU2_VSYNC), + GPIO_FN(QSTB_QHE), GPIO_FN(CAN_DEBUGOUT4), + + /*IPSR13*/ + GPIO_FN(SSI_SDATA5), GPIO_FN(SCIFB1_TXD), GPIO_FN(IETX_B), + GPIO_FN(DU2_DR2), GPIO_FN(LCDOUT2), GPIO_FN(CAN_DEBUGOUT5), + GPIO_FN(SSI_SCK6), GPIO_FN(SCIFB1_CTS_N), GPIO_FN(BPFCLK_D), + GPIO_FN(RDS_CLK_C), GPIO_FN(DU2_DR3), GPIO_FN(LCDOUT3), + GPIO_FN(CAN_DEBUGOUT6), GPIO_FN(BPFCLK_F), GPIO_FN(RDS_CLK_E), + GPIO_FN(SSI_WS6), GPIO_FN(SCIFB1_RTS_N), GPIO_FN(CAN0_TX_D), + GPIO_FN(DU2_DR4), GPIO_FN(LCDOUT4), GPIO_FN(CAN_DEBUGOUT7), + GPIO_FN(SSI_SDATA6), GPIO_FN(FMIN_D), GPIO_FN(RDS_DATA_C), + GPIO_FN(DU2_DR5), GPIO_FN(LCDOUT5), GPIO_FN(CAN_DEBUGOUT8), + GPIO_FN(SSI_SCK78), GPIO_FN(STP_IVCXO27_1), GPIO_FN(SCK1), + GPIO_FN(SCIFA1_SCK), GPIO_FN(DU2_DR6), GPIO_FN(LCDOUT6), + GPIO_FN(CAN_DEBUGOUT9), GPIO_FN(SSI_WS78), GPIO_FN(STP_ISCLK_1), + GPIO_FN(SCIFB2_SCK), GPIO_FN(SCIFA2_CTS_N), GPIO_FN(DU2_DR7), + GPIO_FN(LCDOUT7), GPIO_FN(CAN_DEBUGOUT10), GPIO_FN(SSI_SDATA7), + GPIO_FN(STP_ISD_1), GPIO_FN(SCIFB2_RXD), GPIO_FN(SCIFA2_RTS_N), + GPIO_FN(TCLK2), GPIO_FN(QSTVA_QVS), GPIO_FN(CAN_DEBUGOUT11), + GPIO_FN(BPFCLK_E), GPIO_FN(RDS_CLK_D), GPIO_FN(SSI_SDATA7_B), + GPIO_FN(FMIN_G), GPIO_FN(RDS_DATA_F), GPIO_FN(SSI_SDATA8), + GPIO_FN(STP_ISEN_1), GPIO_FN(SCIFB2_TXD), GPIO_FN(CAN0_TX_C), + GPIO_FN(CAN_DEBUGOUT12), GPIO_FN(SSI_SDATA8_B), GPIO_FN(SSI_SDATA9), + GPIO_FN(STP_ISSYNC_1), GPIO_FN(SCIFB2_CTS_N), GPIO_FN(SSI_WS1), + GPIO_FN(SSI_SDATA5_C), GPIO_FN(CAN_DEBUGOUT13), GPIO_FN(AUDIO_CLKA), + GPIO_FN(SCIFB2_RTS_N), GPIO_FN(CAN_DEBUGOUT14), + + /*IPSR14*/ + GPIO_FN(AUDIO_CLKB), GPIO_FN(SCIF_CLK), GPIO_FN(CAN0_RX_D), + GPIO_FN(DVC_MUTE), GPIO_FN(CAN0_RX_C), GPIO_FN(CAN_DEBUGOUT15), + GPIO_FN(REMOCON), GPIO_FN(SCIFA0_SCK), GPIO_FN(HSCK1), GPIO_FN(SCK0), + GPIO_FN(MSIOF3_SS2), GPIO_FN(DU2_DG2), GPIO_FN(LCDOUT10), + GPIO_FN(SDA1_C), GPIO_FN(SDA1_CIS_C), GPIO_FN(SCIFA0_RXD), + GPIO_FN(HRX1), GPIO_FN(RX0), GPIO_FN(DU2_DR0), GPIO_FN(LCDOUT0), + GPIO_FN(SCIFA0_TXD), GPIO_FN(HTX1), GPIO_FN(TX0), GPIO_FN(DU2_DR1), + GPIO_FN(LCDOUT1), GPIO_FN(SCIFA0_CTS_N), GPIO_FN(HCTS1_N), + GPIO_FN(CTS0_N), GPIO_FN(MSIOF3_SYNC), GPIO_FN(DU2_DG3), + GPIO_FN(LCDOUT11), GPIO_FN(PWM0_B), GPIO_FN(SCL1_C), + GPIO_FN(SCL1_CIS_C), GPIO_FN(SCIFA0_RTS_N), GPIO_FN(HRTS1_N), + GPIO_FN(RTS0_N_TANS), GPIO_FN(MSIOF3_SS1), GPIO_FN(DU2_DG0), + GPIO_FN(LCDOUT8), GPIO_FN(PWM1_B), GPIO_FN(SCIFA1_RXD), GPIO_FN(AD_DI), + GPIO_FN(RX1), GPIO_FN(DU2_EXODDF_DU2_ODDF_DISP_CDE), GPIO_FN(QCPV_QDE), + GPIO_FN(SCIFA1_TXD), GPIO_FN(AD_DO), GPIO_FN(TX1), GPIO_FN(DU2_DG1), + GPIO_FN(LCDOUT9), GPIO_FN(SCIFA1_CTS_N), GPIO_FN(AD_CLK), + GPIO_FN(CTS1_N), GPIO_FN(MSIOF3_RXD), GPIO_FN(DU0_DOTCLKOUT), + GPIO_FN(QCLK), GPIO_FN(SCIFA1_RTS_N), GPIO_FN(AD_NCS_N), + GPIO_FN(RTS1_N_TANS), GPIO_FN(MSIOF3_TXD), GPIO_FN(DU1_DOTCLKOUT), + GPIO_FN(QSTVB_QVE), GPIO_FN(HRTS0_N_C), + + /*IPSR15*/ + GPIO_FN(SCIFA2_SCK), GPIO_FN(FMCLK), GPIO_FN(MSIOF3_SCK), + GPIO_FN(DU2_DG7), GPIO_FN(LCDOUT15), GPIO_FN(SCIF_CLK_B), + GPIO_FN(SCIFA2_RXD), GPIO_FN(FMIN), GPIO_FN(DU2_DB0), + GPIO_FN(LCDOUT16), GPIO_FN(SCL2), GPIO_FN(SCL2_CIS), + GPIO_FN(SCIFA2_TXD), GPIO_FN(BPFCLK), GPIO_FN(DU2_DB1), + GPIO_FN(LCDOUT17), GPIO_FN(SDA2), GPIO_FN(SDA2_CIS), GPIO_FN(HSCK0), + GPIO_FN(TS_SDEN0), GPIO_FN(DU2_DG4), GPIO_FN(LCDOUT12), + GPIO_FN(HCTS0_N_C), GPIO_FN(HRX0), GPIO_FN(DU2_DB2), GPIO_FN(LCDOUT18), + GPIO_FN(HTX0), GPIO_FN(DU2_DB3), GPIO_FN(LCDOUT19), GPIO_FN(HCTS0_N), + GPIO_FN(SSI_SCK9), GPIO_FN(DU2_DB4), GPIO_FN(LCDOUT20), + GPIO_FN(HRTS0_N), GPIO_FN(SSI_WS9), GPIO_FN(DU2_DB5), + GPIO_FN(LCDOUT21), GPIO_FN(MSIOF0_SCK), GPIO_FN(TS_SDAT0), + GPIO_FN(ADICLK), GPIO_FN(DU2_DB6), GPIO_FN(LCDOUT22), + GPIO_FN(MSIOF0_SYNC), GPIO_FN(TS_SCK0), GPIO_FN(SSI_SCK2), + GPIO_FN(ADIDATA), GPIO_FN(DU2_DB7), GPIO_FN(LCDOUT23), + GPIO_FN(SCIFA2_RXD_B), GPIO_FN(MSIOF0_SS1), GPIO_FN(ADICHS0), + GPIO_FN(DU2_DG5), GPIO_FN(LCDOUT13), GPIO_FN(MSIOF0_TXD), + GPIO_FN(ADICHS1), GPIO_FN(DU2_DG6), GPIO_FN(LCDOUT14), + + /*IPSR16*/ + GPIO_FN(MSIOF0_SS2), GPIO_FN(AUDIO_CLKOUT), GPIO_FN(ADICHS2), + GPIO_FN(DU2_DISP), GPIO_FN(QPOLA), GPIO_FN(HTX0_C), + GPIO_FN(SCIFA2_TXD_B), GPIO_FN(MSIOF0_RXD), GPIO_FN(TS_SPSYNC0), + GPIO_FN(SSI_WS2), GPIO_FN(ADICS_SAMP), GPIO_FN(DU2_CDE), + GPIO_FN(QPOLB), GPIO_FN(HRX0_C), GPIO_FN(USB1_PWEN), + GPIO_FN(AUDIO_CLKOUT_D), GPIO_FN(USB1_OVC), GPIO_FN(TCLK1_B), +}; + +static struct pinmux_cfg_reg pinmux_config_regs[] = { + { PINMUX_CFG_REG("GPSR0", 0xE6060004, 32, 1) { + GP_0_31_FN, FN_IP3_17_15, + GP_0_30_FN, FN_IP3_14_12, + GP_0_29_FN, FN_IP3_11_8, + GP_0_28_FN, FN_IP3_7_4, + GP_0_27_FN, FN_IP3_3_0, + GP_0_26_FN, FN_IP2_28_26, + GP_0_25_FN, FN_IP2_25_22, + GP_0_24_FN, FN_IP2_21_18, + GP_0_23_FN, FN_IP2_17_15, + GP_0_22_FN, FN_IP2_14_12, + GP_0_21_FN, FN_IP2_11_9, + GP_0_20_FN, FN_IP2_8_6, + GP_0_19_FN, FN_IP2_5_3, + GP_0_18_FN, FN_IP2_2_0, + GP_0_17_FN, FN_IP1_29_28, + GP_0_16_FN, FN_IP1_27_26, + GP_0_15_FN, FN_IP1_25_22, + GP_0_14_FN, FN_IP1_21_18, + GP_0_13_FN, FN_IP1_17_15, + GP_0_12_FN, FN_IP1_14_12, + GP_0_11_FN, FN_IP1_11_8, + GP_0_10_FN, FN_IP1_7_4, + GP_0_9_FN, FN_IP1_3_0, + GP_0_8_FN, FN_IP0_30_27, + GP_0_7_FN, FN_IP0_26_23, + GP_0_6_FN, FN_IP0_22_20, + GP_0_5_FN, FN_IP0_19_16, + GP_0_4_FN, FN_IP0_15_12, + GP_0_3_FN, FN_IP0_11_9, + GP_0_2_FN, FN_IP0_8_6, + GP_0_1_FN, FN_IP0_5_3, + GP_0_0_FN, FN_IP0_2_0 } + }, + { PINMUX_CFG_REG("GPSR1", 0xE6060008, 32, 1) { + 0, 0, + 0, 0, + GP_1_29_FN, FN_IP6_13_11, + GP_1_28_FN, FN_IP6_10_9, + GP_1_27_FN, FN_IP6_8_6, + GP_1_26_FN, FN_IP6_5_3, + GP_1_25_FN, FN_IP6_2_0, + GP_1_24_FN, FN_IP5_29_27, + GP_1_23_FN, FN_IP5_26_24, + GP_1_22_FN, FN_IP5_23_21, + GP_1_21_FN, FN_IP5_20_18, + GP_1_20_FN, FN_IP5_17_15, + GP_1_19_FN, FN_IP5_14_13, + GP_1_18_FN, FN_IP5_12_10, + GP_1_17_FN, FN_IP5_9_6, + GP_1_16_FN, FN_IP5_5_3, + GP_1_15_FN, FN_IP5_2_0, + GP_1_14_FN, FN_IP4_29_27, + GP_1_13_FN, FN_IP4_26_24, + GP_1_12_FN, FN_IP4_23_21, + GP_1_11_FN, FN_IP4_20_18, + GP_1_10_FN, FN_IP4_17_15, + GP_1_9_FN, FN_IP4_14_12, + GP_1_8_FN, FN_IP4_11_9, + GP_1_7_FN, FN_IP4_8_6, + GP_1_6_FN, FN_IP4_5_3, + GP_1_5_FN, FN_IP4_2_0, + GP_1_4_FN, FN_IP3_31_29, + GP_1_3_FN, FN_IP3_28_26, + GP_1_2_FN, FN_IP3_25_23, + GP_1_1_FN, FN_IP3_22_20, + GP_1_0_FN, FN_IP3_19_18, } + }, + { PINMUX_CFG_REG("GPSR2", 0xE606000C, 32, 1) { + 0, 0, + 0, 0, + GP_2_29_FN, FN_IP7_15_13, + GP_2_28_FN, FN_IP7_12_10, + GP_2_27_FN, FN_IP7_9_8, + GP_2_26_FN, FN_IP7_7_6, + GP_2_25_FN, FN_IP7_5_3, + GP_2_24_FN, FN_IP7_2_0, + GP_2_23_FN, FN_IP6_31_29, + GP_2_22_FN, FN_IP6_28_26, + GP_2_21_FN, FN_IP6_25_23, + GP_2_20_FN, FN_IP6_22_20, + GP_2_19_FN, FN_IP6_19_17, + GP_2_18_FN, FN_IP6_16_14, + GP_2_17_FN, FN_VI1_DATA7_VI1_B7, + GP_2_16_FN, FN_IP8_27, + GP_2_15_FN, FN_IP8_26, + GP_2_14_FN, FN_IP8_25_24, + GP_2_13_FN, FN_IP8_23_22, + GP_2_12_FN, FN_IP8_21_20, + GP_2_11_FN, FN_IP8_19_18, + GP_2_10_FN, FN_IP8_17_16, + GP_2_9_FN, FN_IP8_15_14, + GP_2_8_FN, FN_IP8_13_12, + GP_2_7_FN, FN_IP8_11_10, + GP_2_6_FN, FN_IP8_9_8, + GP_2_5_FN, FN_IP8_7_6, + GP_2_4_FN, FN_IP8_5_4, + GP_2_3_FN, FN_IP8_3_2, + GP_2_2_FN, FN_IP8_1_0, + GP_2_1_FN, FN_IP7_30_29, + GP_2_0_FN, FN_IP7_28_27 } + }, + { PINMUX_CFG_REG("GPSR3", 0xE6060010, 32, 1) { + GP_3_31_FN, FN_IP11_21_18, + GP_3_30_FN, FN_IP11_17_15, + GP_3_29_FN, FN_IP11_14_13, + GP_3_28_FN, FN_IP11_12_11, + GP_3_27_FN, FN_IP11_10_9, + GP_3_26_FN, FN_IP11_8_7, + GP_3_25_FN, FN_IP11_6_5, + GP_3_24_FN, FN_IP11_4, + GP_3_23_FN, FN_IP11_3_0, + GP_3_22_FN, FN_IP10_29_26, + GP_3_21_FN, FN_IP10_25_23, + GP_3_20_FN, FN_IP10_22_19, + GP_3_19_FN, FN_IP10_18_15, + GP_3_18_FN, FN_IP10_14_11, + GP_3_17_FN, FN_IP10_10_7, + GP_3_16_FN, FN_IP10_6_4, + GP_3_15_FN, FN_IP10_3_0, + GP_3_14_FN, FN_IP9_31_28, + GP_3_13_FN, FN_IP9_27_26, + GP_3_12_FN, FN_IP9_25_24, + GP_3_11_FN, FN_IP9_23_22, + GP_3_10_FN, FN_IP9_21_20, + GP_3_9_FN, FN_IP9_19_18, + GP_3_8_FN, FN_IP9_17_16, + GP_3_7_FN, FN_IP9_15_12, + GP_3_6_FN, FN_IP9_11_8, + GP_3_5_FN, FN_IP9_7_6, + GP_3_4_FN, FN_IP9_5_4, + GP_3_3_FN, FN_IP9_3_2, + GP_3_2_FN, FN_IP9_1_0, + GP_3_1_FN, FN_IP8_30_29, + GP_3_0_FN, FN_IP8_28 } + }, + { PINMUX_CFG_REG("GPSR4", 0xE6060014, 32, 1) { + GP_4_31_FN, FN_IP14_18_16, + GP_4_30_FN, FN_IP14_15_12, + GP_4_29_FN, FN_IP14_11_9, + GP_4_28_FN, FN_IP14_8_6, + GP_4_27_FN, FN_IP14_5_3, + GP_4_26_FN, FN_IP14_2_0, + GP_4_25_FN, FN_IP13_30_29, + GP_4_24_FN, FN_IP13_28_26, + GP_4_23_FN, FN_IP13_25_23, + GP_4_22_FN, FN_IP13_22_19, + GP_4_21_FN, FN_IP13_18_16, + GP_4_20_FN, FN_IP13_15_13, + GP_4_19_FN, FN_IP13_12_10, + GP_4_18_FN, FN_IP13_9_7, + GP_4_17_FN, FN_IP13_6_3, + GP_4_16_FN, FN_IP13_2_0, + GP_4_15_FN, FN_IP12_30_28, + GP_4_14_FN, FN_IP12_27_25, + GP_4_13_FN, FN_IP12_24_23, + GP_4_12_FN, FN_IP12_22_20, + GP_4_11_FN, FN_IP12_19_17, + GP_4_10_FN, FN_IP12_16_14, + GP_4_9_FN, FN_IP12_13_11, + GP_4_8_FN, FN_IP12_10_8, + GP_4_7_FN, FN_IP12_7_6, + GP_4_6_FN, FN_IP12_5_4, + GP_4_5_FN, FN_IP12_3_2, + GP_4_4_FN, FN_IP12_1_0, + GP_4_3_FN, FN_IP11_31_30, + GP_4_2_FN, FN_IP11_29_27, + GP_4_1_FN, FN_IP11_26_24, + GP_4_0_FN, FN_IP11_23_22 } + }, + { PINMUX_CFG_REG("GPSR5", 0xE6060018, 32, 1) { + GP_5_31_FN, FN_IP7_24_22, + GP_5_30_FN, FN_IP7_21_19, + GP_5_29_FN, FN_IP7_18_16, + GP_5_28_FN, FN_DU_DOTCLKIN2, + GP_5_27_FN, FN_IP7_26_25, + GP_5_26_FN, FN_DU_DOTCLKIN0, + GP_5_25_FN, FN_AVS2, + GP_5_24_FN, FN_AVS1, + GP_5_23_FN, FN_USB2_OVC, + GP_5_22_FN, FN_USB2_PWEN, + GP_5_21_FN, FN_IP16_7, + GP_5_20_FN, FN_IP16_6, + GP_5_19_FN, FN_USB0_OVC_VBUS, + GP_5_18_FN, FN_USB0_PWEN, + GP_5_17_FN, FN_IP16_5_3, + GP_5_16_FN, FN_IP16_2_0, + GP_5_15_FN, FN_IP15_29_28, + GP_5_14_FN, FN_IP15_27_26, + GP_5_13_FN, FN_IP15_25_23, + GP_5_12_FN, FN_IP15_22_20, + GP_5_11_FN, FN_IP15_19_18, + GP_5_10_FN, FN_IP15_17_16, + GP_5_9_FN, FN_IP15_15_14, + GP_5_8_FN, FN_IP15_13_12, + GP_5_7_FN, FN_IP15_11_9, + GP_5_6_FN, FN_IP15_8_6, + GP_5_5_FN, FN_IP15_5_3, + GP_5_4_FN, FN_IP15_2_0, + GP_5_3_FN, FN_IP14_30_28, + GP_5_2_FN, FN_IP14_27_25, + GP_5_1_FN, FN_IP14_24_22, + GP_5_0_FN, FN_IP14_21_19 } + }, + { PINMUX_CFG_REG_VAR("IPSR0", 0xE6060020, 32, + 1, 4, 4, 3, 4, 4, 3, 3, 3, 3) { + /* IP0_31 [1] */ + 0, 0, + /* IP0_30_27 [4] */ + FN_D8, FN_SCIFA1_SCK_C, FN_AVB_TXD0, FN_MII_TXD0, + FN_VI0_G0, FN_VI0_G0_B, FN_VI2_DATA0_VI2_B0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP0_26_23 [4] */ + FN_D7, FN_AD_DI_B, FN_SDA2_C, + FN_VI3_DATA7, FN_VI0_R3, FN_VI0_R3_B, FN_SDA2_CIS_C, + 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP0_22_20 [3] */ + FN_D6, FN_SCL2_C, FN_VI3_DATA6, FN_VI0_R2, FN_VI0_R2_B, + FN_SCL2_CIS_C, 0, 0, + /* IP0_19_16 [4] */ + FN_D5, FN_SCIFB1_TXD_F, FN_SCIFB0_TXD_C, FN_VI3_DATA5, + FN_VI0_R1, FN_VI0_R1_B, FN_TX0_B, + 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP0_15_12 [4] */ + FN_D4, FN_SCIFB1_RXD_F, FN_SCIFB0_RXD_C, FN_VI3_DATA4, + FN_VI0_R0, FN_VI0_R0_B, FN_RX0_B, + 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP0_11_9 [3] */ + FN_D3, FN_MSIOF3_TXD_B, FN_VI3_DATA3, FN_VI0_G7, FN_VI0_G7_B, + 0, 0, 0, + /* IP0_8_6 [3] */ + FN_D2, FN_MSIOF3_RXD_B, FN_VI3_DATA2, FN_VI0_G6, FN_VI0_G6_B, + 0, 0, 0, + /* IP0_5_3 [3] */ + FN_D1, FN_MSIOF3_SYNC_B, FN_VI3_DATA1, FN_VI0_G5, FN_VI0_G5_B, + 0, 0, 0, + /* IP0_2_0 [3] */ + FN_D0, FN_MSIOF3_SCK_B, FN_VI3_DATA0, FN_VI0_G4, FN_VI0_G4_B, + 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR1", 0xE6060024, 32, + 2, 2, 2, 4, 4, 3, 3, 4, 4, 4) {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} + }, + { PINMUX_CFG_REG_VAR("IPSR2", 0xE6060028, 32, + 3, 3, 4, 4, 3, 3, 3, 3, 3, 3) { + /* IP2_31_29 [3] */ + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP2_28_26 [3] */ + FN_A10, FN_SSI_SDATA5_B, FN_MSIOF2_SYNC, FN_VI0_R6, + FN_VI0_R6_B, FN_VI2_DATA2_VI2_B2_B, 0, 0, + /* IP2_25_22 [4] */ + FN_A9, FN_SCIFA1_CTS_N_B, FN_SSI_WS5_B, FN_VI0_R5, + FN_VI0_R5_B, FN_SCIFB2_TXD_C, 0, FN_VI2_DATA1_VI2_B1_B, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP2_21_18 [4] */ + FN_A8, FN_SCIFA1_RXD_B, FN_SSI_SCK5_B, FN_VI0_R4, + FN_VI0_R4_B, FN_SCIFB2_RXD_C, 0, FN_VI2_DATA0_VI2_B0_B, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP2_17_15 [3] */ + FN_A7, FN_SCIFA1_SCK_B, FN_AUDIO_CLKOUT_B, FN_TPU0TO3, + 0, 0, 0, 0, + /* IP2_14_12 [3] */ + FN_A6, FN_SCIFA1_RTS_N_B, FN_TPU0TO2, 0, 0, 0, 0, 0, + /* IP2_11_9 [3] */ + FN_A5, FN_SCIFA1_TXD_B, FN_TPU0TO1, 0, 0, 0, 0, 0, + /* IP2_8_6 [3] */ + FN_A4, FN_MSIOF1_TXD_B, FN_TPU0TO0, 0, 0, 0, 0, 0, + /* IP2_5_3 [3] */ + FN_A3, FN_PWM6, FN_MSIOF1_SS2_B, 0, 0, 0, 0, 0, + /* IP2_2_0 [3] */ + FN_A2, FN_PWM5, FN_MSIOF1_SS1_B, 0, 0, 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR3", 0xE606002C, 32, + 3, 3, 3, 3, 2, 3, 3, 4, 4, 4) { + /* IP3_31_29 [3] */ + FN_A20, FN_SPCLK, FN_VI1_R3, FN_VI1_R3_B, FN_VI2_G4, + 0, 0, 0, + /* IP3_28_26 [3] */ + FN_A19, FN_AD_NCS_N_B, FN_ATACS01_N, FN_EX_WAIT0_B, + 0, 0, 0, 0, + /* IP3_25_23 [3] */ + FN_A18, FN_AD_CLK_B, FN_ATAG1_N, 0, 0, 0, 0, 0, + /* IP3_22_20 [3] */ + FN_A17, FN_AD_DO_B, FN_ATADIR1_N, 0, 0, 0, 0, 0, + /* IP3_19_18 [2] */ + FN_A16, FN_ATAWR1_N, 0, 0, + /* IP3_17_15 [3] */ + FN_A15, FN_SCIFB2_SCK_B, FN_ATARD1_N, FN_MSIOF2_SS2, + 0, 0, 0, 0, + /* IP3_14_12 [3] */ + FN_A14, FN_SCIFB2_TXD_B, FN_ATACS11_N, FN_MSIOF2_SS1, + 0, 0, 0, 0, + /* IP3_11_8 [4] */ + FN_A13, FN_SCIFB2_RTS_N_B, FN_EX_WAIT2, + FN_MSIOF2_RXD, FN_VI1_R2, FN_VI1_R2_B, FN_VI2_G2, + FN_VI2_DATA5_VI2_B5_B, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP3_7_4 [4] */ + FN_A12, FN_SCIFB2_RXD_B, FN_MSIOF2_TXD, FN_VI1_R1, + FN_VI1_R1_B, FN_VI2_G1, FN_VI2_DATA4_VI2_B4_B, + 0, 0, 0, 0, 0, 0, 0, 0, 0, + /* IP3_3_0 [4] */ + FN_A11, FN_SCIFB2_CTS_N_B, FN_MSIOF2_SCK, FN_VI1_R0, + FN_VI1_R0_B, FN_VI2_G0, FN_VI2_DATA3_VI2_B3_B, 0, + 0, 0, 0, 0, 0, 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR4", 0xE6060030, 32, + 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3) { + /* IP4_31_30 [2] */ + 0, 0, 0, 0, + /* IP4_29_27 [3] */ + FN_EX_CS2_N, FN_GPS_SIGN, FN_HRTS1_N_B, + FN_VI3_CLKENB, FN_VI1_G0, FN_VI1_G0_B, FN_VI2_R2, 0, + /* IP4_26_24 [3] */ + FN_EX_CS1_N, FN_GPS_CLK, FN_HCTS1_N_B, FN_VI1_FIELD, + FN_VI1_FIELD_B, FN_VI2_R1, 0, 0, + /* IP4_23_21 [3] */ + FN_EX_CS0_N, FN_HRX1_B, FN_VI1_G5, FN_VI1_G5_B, FN_VI2_R0, + FN_HTX0_B, FN_MSIOF0_SS1_B, 0, + /* IP4_20_18 [3] */ + FN_CS1_N_A26, FN_SPEEDIN, FN_VI0_R7, FN_VI0_R7_B, + FN_VI2_CLK, FN_VI2_CLK_B, 0, 0, + /* IP4_17_15 [3] */ + FN_CS0_N, FN_VI1_R6, FN_VI1_R6_B, FN_VI2_G3, FN_MSIOF0_SS2_B, + 0, 0, 0, + /* IP4_14_12 [3] */ + FN_A25, FN_SSL, FN_VI1_G6, FN_VI1_G6_B, FN_VI2_FIELD, + FN_VI2_FIELD_B, 0, 0, + /* IP4_11_9 [3] */ + FN_A24, FN_IO3, FN_VI1_R7, FN_VI1_R7_B, FN_VI2_CLKENB, + FN_VI2_CLKENB_B, 0, 0, + /* IP4_8_6 [3] */ + FN_A23, FN_IO2, FN_VI1_G7, FN_VI1_G7_B, FN_VI2_G7, 0, 0, 0, + /* IP4_5_3 [3] */ + FN_A22, FN_MISO_IO1, FN_VI1_R5, FN_VI1_R5_B, FN_VI2_G6, 0, 0, 0, + /* IP4_2_0 [3] */ + FN_A21, FN_MOSI_IO0, FN_VI1_R4, FN_VI1_R4_B, FN_VI2_G5, 0, 0, 0, + } + }, + { PINMUX_CFG_REG_VAR("IPSR5", 0xE6060034, 32, + 2, 3, 3, 3, 3, 3, 2, 3, 4, 3, 3) { + /* IP5_31_30 [2] */ + 0, 0, 0, 0, + /* IP5_29_27 [3] */ + FN_DREQ0_N, FN_VI1_HSYNC_N, FN_VI1_HSYNC_N_B, FN_VI2_R7, + FN_SSI_SCK78_C, FN_SSI_WS78_B, 0, 0, + /* IP5_26_24 [3] */ + FN_EX_WAIT0, FN_IRQ3, FN_INTC_IRQ3_N, + FN_VI3_CLK, FN_SCIFA0_RTS_N_B, FN_HRX0_B, + FN_MSIOF0_SCK_B, 0, + /* IP5_23_21 [3] */ + FN_WE1_N, FN_IERX, FN_CAN1_RX, FN_VI1_G4, + FN_VI1_G4_B, FN_VI2_R6, FN_SCIFA0_CTS_N_B, + FN_IERX_C, 0, + /* IP5_20_18 [3] */ + FN_WE0_N, FN_IECLK, FN_CAN_CLK, + FN_VI2_VSYNC_N, FN_SCIFA0_TXD_B, FN_VI2_VSYNC_N_B, 0, 0, + /* IP5_17_15 [3] */ + FN_RD_WR_N, FN_VI1_G3, FN_VI1_G3_B, FN_VI2_R5, FN_SCIFA0_RXD_B, + FN_INTC_IRQ4_N, 0, 0, + /* IP5_14_13 [2] */ + FN_RD_N, FN_CAN0_TX, FN_SCIFA0_SCK_B, 0, + /* IP5_12_10 [3] */ + FN_BS_N, FN_IETX, FN_HTX1_B, FN_CAN1_TX, FN_DRACK0, FN_IETX_C, + 0, 0, + /* IP5_9_6 [4] */ + FN_EX_CS5_N, FN_CAN0_RX, FN_MSIOF1_RXD_B, FN_VI3_VSYNC_N, + FN_VI1_G2, FN_VI1_G2_B, FN_VI2_R4, FN_SDA1, FN_INTC_EN1_N, + FN_SDA1_CIS, 0, 0, 0, 0, 0, 0, + /* IP5_5_3 [3] */ + FN_EX_CS4_N, FN_MSIOF1_SCK_B, FN_VI3_HSYNC_N, + FN_VI2_HSYNC_N, FN_SCL1, FN_VI2_HSYNC_N_B, + FN_INTC_EN0_N, FN_SCL1_CIS, + /* IP5_2_0 [3] */ + FN_EX_CS3_N, FN_GPS_MAG, FN_VI3_FIELD, FN_VI1_G1, FN_VI1_G1_B, + FN_VI2_R3, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR6", 0xE6060038, 32, + 3, 3, 3, 3, 3, 3, 3, 2, 3, 3, 3) { + /* IP6_31_29 [3] */ + FN_ETH_REF_CLK, FN_RMII_REF_CLK, FN_HCTS0_N_E, + FN_STP_IVCXO27_1_B, FN_HRX0_F, 0, 0, 0, + /* IP6_28_26 [3] */ + FN_ETH_LINK, FN_RMII_LINK, FN_HTX0_E, + FN_STP_IVCXO27_0_B, FN_SCIFB1_TXD_G, FN_TX1_E, 0, 0, + /* IP6_25_23 [3] */ + FN_ETH_RXD1, FN_RMII_RXD1, FN_HRX0_E, FN_STP_ISSYNC_0_B, + FN_TS_SCK0_D, FN_GLO_I1_C, FN_SCIFB1_RXD_G, FN_RX1_E, + /* IP6_22_20 [3] */ + FN_ETH_RXD0, FN_RMII_RXD0, FN_STP_ISEN_0_B, FN_TS_SDAT0_D, + FN_GLO_I0_C, FN_SCIFB1_SCK_G, FN_SCK1_E, 0, + /* IP6_19_17 [3] */ + FN_ETH_RX_ER, FN_RMII_RX_ER, FN_STP_ISD_0_B, + FN_TS_SPSYNC0_D, FN_GLO_Q1_C, FN_SDA2_E, FN_SDA2_CIS_E, 0, + /* IP6_16_14 [3] */ + FN_ETH_CRS_DV, FN_RMII_CRS_DV, FN_STP_ISCLK_0_B, + FN_TS_SDEN0_D, FN_GLO_Q0_C, FN_SCL2_E, + FN_SCL2_CIS_E, 0, + /* IP6_13_11 [3] */ + FN_DACK2, FN_IRQ2, FN_INTC_IRQ2_N, + FN_SSI_SDATA6_B, FN_HRTS0_N_B, FN_MSIOF0_RXD_B, 0, 0, + /* IP6_10_9 [2] */ + FN_DREQ2_N, FN_HSCK1_B, FN_HCTS0_N_B, FN_MSIOF0_TXD_B, + /* IP6_8_6 [3] */ + FN_DACK1, FN_IRQ1, FN_INTC_IRQ1_N, FN_SSI_WS6_B, + FN_SSI_SDATA8_C, 0, 0, 0, + /* IP6_5_3 [3] */ + FN_DREQ1_N, FN_VI1_CLKENB, FN_VI1_CLKENB_B, + FN_SSI_SDATA7_C, FN_SSI_SCK78_B, 0, 0, 0, + /* IP6_2_0 [3] */ + FN_DACK0, FN_IRQ0, FN_INTC_IRQ0_N, FN_SSI_SCK6_B, + FN_VI1_VSYNC_N, FN_VI1_VSYNC_N_B, FN_SSI_WS78_C, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR7", 0xE606003C, 32, + 1, 2, 2, 2, 3, 3, 3, 3, 3, 2, 2, 3, 3) { + /* IP7_31 [1] */ + 0, 0, + /* IP7_30_29 [2] */ + FN_VI0_DATA0_VI0_B0, FN_ATACS10_N, FN_AVB_RXD2, + FN_MII_RXD2, + /* IP7_28_27 [2] */ + FN_VI0_CLK, FN_ATACS00_N, FN_AVB_RXD1, FN_MII_RXD1, + /* IP7_26_25 [2] */ + FN_DU1_DOTCLKIN, FN_AUDIO_CLKC, FN_AUDIO_CLKOUT_C, 0, + /* IP7_24_22 [3] */ + FN_PWM2, FN_PWMFSW0, FN_SCIFA2_RXD_C, FN_PCMWE_N, FN_IECLK_C, + 0, 0, 0, + /* IP7_21_19 [3] */ + FN_PWM1, FN_SCIFA2_TXD_C, FN_STP_ISSYNC_1_B, FN_TS_SCK1_C, + FN_GLO_RFON_C, FN_PCMOE_N, 0, 0, + /* IP7_18_16 [3] */ + FN_PWM0, FN_SCIFA2_SCK_C, FN_STP_ISEN_1_B, FN_TS_SDAT1_C, + FN_GLO_SS_C, 0, 0, 0, + /* IP7_15_13 [3] */ + FN_ETH_MDC, FN_RMII_MDC, FN_STP_ISD_1_B, + FN_TS_SPSYNC1_C, FN_GLO_SDATA_C, 0, 0, 0, + /* IP7_12_10 [3] */ + FN_ETH_TXD0, FN_RMII_TXD0, FN_STP_ISCLK_1_B, FN_TS_SDEN1_C, + FN_GLO_SCLK_C, 0, 0, 0, + /* IP7_9_8 [2] */ + FN_ETH_MAGIC, FN_RMII_MAGIC, FN_SIM0_RST_C, 0, + /* IP7_7_6 [2] */ + FN_ETH_TX_EN, FN_RMII_TX_EN, FN_SIM0_CLK_C, FN_HRTS0_N_F, + /* IP7_5_3 [3] */ + FN_ETH_TXD1, FN_RMII_TXD1, FN_HTX0_F, FN_BPFCLK_G, FN_RDS_CLK_F, + 0, 0, 0, + /* IP7_2_0 [3] */ + FN_ETH_MDIO, FN_RMII_MDIO, FN_HRTS0_N_E, + FN_SIM0_D_C, FN_HCTS0_N_F, 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR8", 0xE6060040, 32, + 1, 2, 1, 1, 1, 2, 2, 2, 2, 2, 2, + 2, 2, 2, 2, 2, 2, 2) { + /* IP8_31 [1] */ + 0, 0, + /* IP8_30_29 [2] */ + FN_SD0_CMD, FN_SCIFB1_SCK_B, FN_VI1_DATA1_VI1_B1_B, 0, + /* IP8_28 [1] */ + FN_SD0_CLK, FN_VI1_DATA0_VI1_B0_B, + /* IP8_27 [1] */ + FN_VI1_DATA6_VI1_B6, FN_AVB_GTXREFCLK, + /* IP8_26 [1] */ + FN_VI1_DATA5_VI1_B5, FN_AVB_PHY_INT, + /* IP8_25_24 [2] */ + FN_VI1_DATA4_VI1_B4, FN_SCIFA1_RTS_N_D, + FN_AVB_MAGIC, FN_MII_MAGIC, + /* IP8_23_22 [2] */ + FN_VI1_DATA3_VI1_B3, FN_SCIFA1_CTS_N_D, FN_AVB_GTX_CLK, 0, + /* IP8_21_20 [2] */ + FN_VI1_DATA2_VI1_B2, FN_SCIFA1_TXD_D, FN_AVB_MDIO, + FN_MII_MDIO, + /* IP8_19_18 [2] */ + FN_VI1_DATA1_VI1_B1, FN_SCIFA1_RXD_D, FN_AVB_MDC, FN_MII_MDC, + /* IP8_17_16 [2] */ + FN_VI1_DATA0_VI1_B0, FN_SCIFA1_SCK_D, FN_AVB_CRS, FN_MII_CRS, + /* IP8_15_14 [2] */ + FN_VI1_CLK, FN_AVB_RX_DV, FN_MII_RX_DV, 0, + /* IP8_13_12 [2] */ + FN_VI0_DATA7_VI0_B7, FN_AVB_RX_CLK, FN_MII_RX_CLK, 0, + /* IP8_11_10 [2] */ + FN_VI0_DATA6_VI0_B6, FN_AVB_RX_ER, FN_MII_RX_ER, 0, + /* IP8_9_8 [2] */ + FN_VI0_DATA5_VI0_B5, FN_EX_WAIT1, FN_AVB_RXD7, 0, + /* IP8_7_6 [2] */ + FN_VI0_DATA4_VI0_B4, FN_ATAG0_N, FN_AVB_RXD6, 0, + /* IP8_5_4 [2] */ + FN_VI0_DATA3_VI0_B3, FN_ATADIR0_N, FN_AVB_RXD5, 0, + /* IP8_3_2 [2] */ + FN_VI0_DATA2_VI0_B2, FN_ATAWR0_N, FN_AVB_RXD4, 0, + /* IP8_1_0 [2] */ + FN_VI0_DATA1_VI0_B1, FN_ATARD0_N, FN_AVB_RXD3, FN_MII_RXD3, } + }, + { PINMUX_CFG_REG_VAR("IPSR9", 0xE6060044, 32, + 4, 2, 2, 2, 2, 2, 2, 4, 4, 2, 2, 2, 2) { + /* IP9_31_28 [4] */ + FN_SD1_CD, FN_MMC1_D6, FN_TS_SDEN1, FN_USB1_EXTP, + FN_GLO_SS, FN_VI0_CLK_B, FN_SCL2_D, FN_SCL2_CIS_D, + FN_SIM0_CLK_B, FN_VI3_CLK_B, 0, 0, 0, 0, 0, 0, + /* IP9_27_26 [2] */ + FN_SD1_DAT3, FN_AVB_RXD0, FN_MII_RXD0, FN_SCIFB0_RTS_N_B, + /* IP9_25_24 [2] */ + FN_SD1_DAT2, FN_AVB_COL, FN_MII_COL, FN_SCIFB0_CTS_N_B, + /* IP9_23_22 [2] */ + FN_SD1_DAT1, FN_AVB_LINK, FN_MII_LINK, FN_SCIFB0_TXD_B, + /* IP9_21_20 [2] */ + FN_SD1_DAT0, FN_AVB_TX_CLK, FN_MII_TX_CLK, FN_SCIFB0_RXD_B, + /* IP9_19_18 [2] */ + FN_SD1_CMD, FN_AVB_TX_ER, FN_MII_TX_ER, FN_SCIFB0_SCK_B, + /* IP9_17_16 [2] */ + FN_SD1_CLK, FN_AVB_TX_EN, FN_MII_TX_EN, 0, + /* IP9_15_12 [4] */ + FN_SD0_WP, FN_MMC0_D7, FN_TS_SPSYNC0_B, FN_USB0_IDIN, + FN_GLO_SDATA, FN_VI1_DATA7_VI1_B7_B, FN_SDA1_B, + FN_SDA1_CIS_B, FN_VI2_DATA7_VI2_B7_B, 0, 0, 0, 0, 0, 0, 0, + /* IP9_11_8 [4] */ + FN_SD0_CD, FN_MMC0_D6, FN_TS_SDEN0_B, FN_USB0_EXTP, + FN_GLO_SCLK, FN_VI1_DATA6_VI1_B6_B, FN_SCL1_B, + FN_SCL1_CIS_B, FN_VI2_DATA6_VI2_B6_B, 0, 0, 0, 0, 0, 0, 0, + /* IP9_7_6 [2] */ + FN_SD0_DAT3, FN_SCIFB1_RTS_N_B, FN_VI1_DATA5_VI1_B5_B, 0, + /* IP9_5_4 [2] */ + FN_SD0_DAT2, FN_SCIFB1_CTS_N_B, FN_VI1_DATA4_VI1_B4_B, 0, + /* IP9_3_2 [2] */ + FN_SD0_DAT1, FN_SCIFB1_TXD_B, FN_VI1_DATA3_VI1_B3_B, 0, + /* IP9_1_0 [2] */ + FN_SD0_DAT0, FN_SCIFB1_RXD_B, FN_VI1_DATA2_VI1_B2_B, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR10", 0xE6060048, 32, + 2, 4, 3, 4, 4, 4, 4, 3, 4) { + /* IP10_31_30 [2] */ + 0, 0, 0, 0, + /* IP10_29_26 [4] */ + FN_SD2_CD, FN_MMC0_D4, FN_TS_SDAT0_B, FN_USB2_EXTP, FN_GLO_I0, + FN_VI0_DATA6_VI0_B6_B, FN_HCTS0_N_D, FN_TS_SDAT1_B, + FN_GLO_I0_B, FN_VI3_DATA6_B, 0, 0, 0, 0, 0, 0, + /* IP10_25_23 [3] */ + FN_SD2_DAT3, FN_MMC0_D3, FN_SIM0_RST, FN_VI0_DATA5_VI0_B5_B, + FN_HTX0_D, FN_TS_SPSYNC1_B, FN_GLO_Q1_B, FN_VI3_DATA5_B, + /* IP10_22_19 [4] */ + FN_SD2_DAT2, FN_MMC0_D2, FN_BPFCLK_B, FN_RDS_CLK, + FN_VI0_DATA4_VI0_B4_B, FN_HRX0_D, FN_TS_SDEN1_B, + FN_GLO_Q0_B, FN_VI3_DATA4_B, 0, 0, 0, 0, 0, 0, 0, + /* IP10_18_15 [4] */ + FN_SD2_DAT1, FN_MMC0_D1, FN_FMIN_B, FN_RDS_DATA, + FN_VI0_DATA3_VI0_B3_B, FN_SCIFB1_TXD_E, FN_TX1_D, + FN_TS_SCK0_C, FN_GLO_RFON_B, FN_VI3_DATA3_B, + 0, 0, 0, 0, 0, 0, + /* IP10_14_11 [4] */ + FN_SD2_DAT0, FN_MMC0_D0, FN_FMCLK_B, + FN_VI0_DATA2_VI0_B2_B, FN_SCIFB1_RXD_E, FN_RX1_D, + FN_TS_SDAT0_C, FN_GLO_SS_B, FN_VI3_DATA2_B, + 0, 0, 0, 0, 0, 0, 0, + /* IP10_10_7 [4] */ + FN_SD2_CMD, FN_MMC0_CMD, FN_SIM0_D, + FN_VI0_DATA1_VI0_B1_B, FN_SCIFB1_SCK_E, FN_SCK1_D, + FN_TS_SPSYNC0_C, FN_GLO_SDATA_B, FN_VI3_DATA1_B, + 0, 0, 0, 0, 0, 0, 0, + /* IP10_6_4 [3] */ + FN_SD2_CLK, FN_MMC0_CLK, FN_SIM0_CLK, + FN_VI0_DATA0_VI0_B0_B, FN_TS_SDEN0_C, FN_GLO_SCLK_B, + FN_VI3_DATA0_B, 0, + /* IP10_3_0 [4] */ + FN_SD1_WP, FN_MMC1_D7, FN_TS_SPSYNC1, FN_USB1_IDIN, + FN_GLO_RFON, FN_VI1_CLK_B, FN_SDA2_D, FN_SDA2_CIS_D, + FN_SIM0_D_B, 0, 0, 0, 0, 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR11", 0xE606004C, 32, + 2, 3, 3, 3, 3, 3, 3, 3, 3, 3, 3) { + /* IP11_31_30 [2] */ + FN_SSI_SCK0129, FN_CAN_CLK_B, FN_MOUT0, 0, + /* IP11_29_27 [3] */ + FN_MLB_DAT, FN_SPV_EVEN, FN_SCIFB1_TXD_D, FN_TX1_C, FN_BPFCLK_C, + FN_RDS_CLK_B, 0, 0, + /* IP11_26_24 [3] */ + FN_MLB_SIG, FN_SCIFB1_RXD_D, FN_RX1_C, FN_SDA2_B, FN_SDA2_CIS_B, + 0, 0, 0, + /* IP11_23_22 [2] */ + FN_MLB_CLK, FN_SCL2_B, FN_SCL2_CIS_B, 0, + /* IP11_21_18 [4] */ + FN_SD3_WP, FN_MMC1_D5, FN_TS_SCK1, FN_GLO_Q1, FN_FMIN_C, + FN_RDS_DATA_B, FN_FMIN_E, FN_RDS_DATA_D, FN_FMIN_F, + FN_RDS_DATA_E, 0, 0, 0, 0, 0, 0, + /* IP11_17_15 [3] */ + FN_SD3_CD, FN_MMC1_D4, FN_TS_SDAT1, + FN_VSP, FN_GLO_Q0, FN_SIM0_RST_B, 0, 0, + /* IP11_14_13 [2] */ + FN_SD3_DAT3, FN_MMC1_D3, FN_SCKZ, 0, + /* IP11_12_11 [2] */ + FN_SD3_DAT2, FN_MMC1_D2, FN_SDATA, 0, + /* IP11_10_9 [2] */ + FN_SD3_DAT1, FN_MMC1_D1, FN_MDATA, 0, + /* IP11_8_7 [2] */ + FN_SD3_DAT0, FN_MMC1_D0, FN_STM_N, 0, + /* IP11_6_5 [2] */ + FN_SD3_CMD, FN_MMC1_CMD, FN_MTS_N, 0, + /* IP11_4 [1] */ + FN_SD3_CLK, FN_MMC1_CLK, + /* IP11_3_0 [4] */ + FN_SD2_WP, FN_MMC0_D5, FN_TS_SCK0_B, FN_USB2_IDIN, + FN_GLO_I1, FN_VI0_DATA7_VI0_B7_B, FN_HRTS0_N_D, + FN_TS_SCK1_B, FN_GLO_I1_B, FN_VI3_DATA7_B, 0, 0, 0, 0, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR12", 0xE6060050, 32, + 1, 3, 3, 2, 3, 3, 3, 3, 3, 2, 2, 2, 2) { + /* IP12_31 [1] */ + 0, 0, + /* IP12_30_28 [3] */ + FN_SSI_WS5, FN_SCIFB1_RXD, FN_IECLK_B, + FN_DU2_EXVSYNC_DU2_VSYNC, FN_QSTB_QHE, + FN_CAN_DEBUGOUT4, 0, 0, + /* IP12_27_25 [3] */ + FN_SSI_SCK5, FN_SCIFB1_SCK, + FN_IERX_B, FN_DU2_EXHSYNC_DU2_HSYNC, FN_QSTH_QHS, + FN_CAN_DEBUGOUT3, 0, 0, + /* IP12_24_23 [2] */ + FN_SSI_SDATA4, FN_STP_ISSYNC_0, FN_MSIOF1_RXD, + FN_CAN_DEBUGOUT2, + /* IP12_22_20 [3] */ + FN_SSI_WS4, FN_STP_ISEN_0, FN_SCIFB0_RTS_N, + FN_MSIOF1_TXD, FN_SSI_WS5_C, FN_CAN_DEBUGOUT1, 0, 0, + /* IP12_19_17 [3] */ + FN_SSI_SCK4, FN_STP_ISD_0, FN_SCIFB0_CTS_N, + FN_MSIOF1_SS2, FN_SSI_SCK5_C, FN_CAN_DEBUGOUT0, 0, 0, + /* IP12_16_14 [3] */ + FN_SSI_SDATA3, FN_STP_ISCLK_0, + FN_SCIFB0_TXD, FN_MSIOF1_SS1, FN_CAN_TXCLK, 0, 0, 0, + /* IP12_13_11 [3] */ + FN_SSI_WS34, FN_STP_IVCXO27_0, FN_SCIFB0_RXD, FN_MSIOF1_SYNC, + FN_CAN_STEP0, 0, 0, 0, + /* IP12_10_8 [3] */ + FN_SSI_SCK34, FN_STP_OPWM_0, FN_SCIFB0_SCK, + FN_MSIOF1_SCK, FN_CAN_DEBUG_HW_TRIGGER, 0, 0, 0, + /* IP12_7_6 [2] */ + FN_SSI_SDATA2, FN_CAN1_RX_B, FN_SSI_SCK1, FN_MOUT6, + /* IP12_5_4 [2] */ + FN_SSI_SDATA1, FN_CAN1_TX_B, FN_MOUT5, 0, + /* IP12_3_2 [2] */ + FN_SSI_SDATA0, FN_CAN0_RX_B, FN_MOUT2, 0, + /* IP12_1_0 [2] */ + FN_SSI_WS0129, FN_CAN0_TX_B, FN_MOUT1, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR13", 0xE6060054, 32, + 1, 2, 3, 3, 4, 3, 3, 3, 3, 4, 3) { + /* IP13_31 [1] */ + 0, 0, + /* IP13_30_29 [2] */ + FN_AUDIO_CLKA, FN_SCIFB2_RTS_N, FN_CAN_DEBUGOUT14, 0, + /* IP13_28_26 [3] */ + FN_SSI_SDATA9, FN_STP_ISSYNC_1, FN_SCIFB2_CTS_N, FN_SSI_WS1, + FN_SSI_SDATA5_C, FN_CAN_DEBUGOUT13, 0, 0, + /* IP13_25_23 [3] */ + FN_SSI_SDATA8, FN_STP_ISEN_1, FN_SCIFB2_TXD, FN_CAN0_TX_C, + FN_CAN_DEBUGOUT12, FN_SSI_SDATA8_B, 0, 0, + /* IP13_22_19 [4] */ + FN_SSI_SDATA7, FN_STP_ISD_1, FN_SCIFB2_RXD, FN_SCIFA2_RTS_N, + FN_TCLK2, FN_QSTVA_QVS, FN_CAN_DEBUGOUT11, FN_BPFCLK_E, + FN_RDS_CLK_D, FN_SSI_SDATA7_B, FN_FMIN_G, FN_RDS_DATA_F, + 0, 0, 0, 0, + /* IP13_18_16 [3] */ + FN_SSI_WS78, FN_STP_ISCLK_1, FN_SCIFB2_SCK, FN_SCIFA2_CTS_N, + FN_DU2_DR7, FN_LCDOUT7, FN_CAN_DEBUGOUT10, 0, + /* IP13_15_13 [3] */ + FN_SSI_SCK78, FN_STP_IVCXO27_1, FN_SCK1, FN_SCIFA1_SCK, + FN_DU2_DR6, FN_LCDOUT6, FN_CAN_DEBUGOUT9, 0, + /* IP13_12_10 [3] */ + FN_SSI_SDATA6, FN_FMIN_D, FN_RDS_DATA_C, FN_DU2_DR5, FN_LCDOUT5, + FN_CAN_DEBUGOUT8, 0, 0, + /* IP13_9_7 [3] */ + FN_SSI_WS6, FN_SCIFB1_RTS_N, FN_CAN0_TX_D, FN_DU2_DR4, + FN_LCDOUT4, FN_CAN_DEBUGOUT7, 0, 0, + /* IP13_6_3 [4] */ + FN_SSI_SCK6, FN_SCIFB1_CTS_N, FN_BPFCLK_D, FN_RDS_CLK_C, + FN_DU2_DR3, FN_LCDOUT3, FN_CAN_DEBUGOUT6, + FN_BPFCLK_F, FN_RDS_CLK_E, 0, 0, 0, 0, 0, 0, 0, + /* IP13_2_0 [3] */ + FN_SSI_SDATA5, FN_SCIFB1_TXD, FN_IETX_B, FN_DU2_DR2, + FN_LCDOUT2, FN_CAN_DEBUGOUT5, 0, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR14", 0xE6060058, 32, + 1, 3, 3, 3, 3, 3, 4, 3, 3, 3, 3) { + /* IP14_30 [1] */ + 0, 0, + /* IP14_30_28 [3] */ + FN_SCIFA1_RTS_N, FN_AD_NCS_N, FN_RTS1_N_TANS, + FN_MSIOF3_TXD, FN_DU1_DOTCLKOUT, FN_QSTVB_QVE, + FN_HRTS0_N_C, 0, + /* IP14_27_25 [3] */ + FN_SCIFA1_CTS_N, FN_AD_CLK, FN_CTS1_N, FN_MSIOF3_RXD, + FN_DU0_DOTCLKOUT, FN_QCLK, 0, 0, + /* IP14_24_22 [3] */ + FN_SCIFA1_TXD, FN_AD_DO, FN_TX1, FN_DU2_DG1, + FN_LCDOUT9, 0, 0, 0, + /* IP14_21_19 [3] */ + FN_SCIFA1_RXD, FN_AD_DI, FN_RX1, + FN_DU2_EXODDF_DU2_ODDF_DISP_CDE, FN_QCPV_QDE, 0, 0, 0, + /* IP14_18_16 [3] */ + FN_SCIFA0_RTS_N, FN_HRTS1_N, FN_RTS0_N_TANS, + FN_MSIOF3_SS1, FN_DU2_DG0, FN_LCDOUT8, FN_PWM1_B, 0, + /* IP14_15_12 [4] */ + FN_SCIFA0_CTS_N, FN_HCTS1_N, FN_CTS0_N, FN_MSIOF3_SYNC, + FN_DU2_DG3, FN_LCDOUT11, FN_PWM0_B, FN_SCL1_C, FN_SCL1_CIS_C, + 0, 0, 0, 0, 0, 0, 0, + /* IP14_11_9 [3] */ + FN_SCIFA0_TXD, FN_HTX1, FN_TX0, FN_DU2_DR1, FN_LCDOUT1, + 0, 0, 0, + /* IP14_8_6 [3] */ + FN_SCIFA0_RXD, FN_HRX1, FN_RX0, FN_DU2_DR0, FN_LCDOUT0, + 0, 0, 0, + /* IP14_5_3 [3] */ + FN_SCIFA0_SCK, FN_HSCK1, FN_SCK0, FN_MSIOF3_SS2, FN_DU2_DG2, + FN_LCDOUT10, FN_SDA1_C, FN_SDA1_CIS_C, + /* IP14_2_0 [3] */ + FN_AUDIO_CLKB, FN_SCIF_CLK, FN_CAN0_RX_D, + FN_DVC_MUTE, FN_CAN0_RX_C, FN_CAN_DEBUGOUT15, + FN_REMOCON, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR15", 0xE606005C, 32, + 2, 2, 2, 3, 3, 2, 2, 2, 2, 3, 3, 3, 3) { + /* IP15_31_30 [2] */ + 0, 0, 0, 0, + /* IP15_29_28 [2] */ + FN_MSIOF0_TXD, FN_ADICHS1, FN_DU2_DG6, FN_LCDOUT14, + /* IP15_27_26 [2] */ + FN_MSIOF0_SS1, FN_ADICHS0, FN_DU2_DG5, FN_LCDOUT13, + /* IP15_25_23 [3] */ + FN_MSIOF0_SYNC, FN_TS_SCK0, FN_SSI_SCK2, FN_ADIDATA, + FN_DU2_DB7, FN_LCDOUT23, FN_SCIFA2_RXD_B, 0, + /* IP15_22_20 [3] */ + FN_MSIOF0_SCK, FN_TS_SDAT0, FN_ADICLK, + FN_DU2_DB6, FN_LCDOUT22, 0, 0, 0, + /* IP15_19_18 [2] */ + FN_HRTS0_N, FN_SSI_WS9, FN_DU2_DB5, FN_LCDOUT21, + /* IP15_17_16 [2] */ + FN_HCTS0_N, FN_SSI_SCK9, FN_DU2_DB4, FN_LCDOUT20, + /* IP15_15_14 [2] */ + FN_HTX0, FN_DU2_DB3, FN_LCDOUT19, 0, + /* IP15_13_12 [2] */ + FN_HRX0, FN_DU2_DB2, FN_LCDOUT18, 0, + /* IP15_11_9 [3] */ + FN_HSCK0, FN_TS_SDEN0, FN_DU2_DG4, FN_LCDOUT12, FN_HCTS0_N_C, + 0, 0, 0, + /* IP15_8_6 [3] */ + FN_SCIFA2_TXD, FN_BPFCLK, 0, FN_DU2_DB1, FN_LCDOUT17, + FN_SDA2, FN_SDA2_CIS, 0, + /* IP15_5_3 [3] */ + FN_SCIFA2_RXD, FN_FMIN, 0, FN_DU2_DB0, FN_LCDOUT16, + FN_SCL2, FN_SCL2_CIS, 0, + /* IP15_2_0 [3] */ + FN_SCIFA2_SCK, FN_FMCLK, 0, FN_MSIOF3_SCK, FN_DU2_DG7, + FN_LCDOUT15, FN_SCIF_CLK_B, 0, } + }, + { PINMUX_CFG_REG_VAR("IPSR16", 0xE6060160, 32, + 4, 4, 4, 4, 4, 4, 1, 1, 3, 3) { + /* IP16_31_28 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_27_24 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_23_20 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_19_16 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_15_12 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_11_8 [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* IP16_7 [1] */ + FN_USB1_OVC, FN_TCLK1_B, + /* IP16_6 [1] */ + FN_USB1_PWEN, FN_AUDIO_CLKOUT_D, + /* IP16_5_3 [3] */ + FN_MSIOF0_RXD, FN_TS_SPSYNC0, FN_SSI_WS2, + FN_ADICS_SAMP, FN_DU2_CDE, FN_QPOLB, FN_HRX0_C, 0, + /* IP16_2_0 [3] */ + FN_MSIOF0_SS2, FN_AUDIO_CLKOUT, FN_ADICHS2, + FN_DU2_DISP, FN_QPOLA, FN_HTX0_C, FN_SCIFA2_TXD_B, 0, } + }, + { PINMUX_CFG_REG_VAR("MOD_SEL", 0xE6060090, 32, + 3, 2, 2, 3, 2, 1, 1, 1, 2, 1, + 2, 1, 1, 1, 1, 2, 1, 1, 2, 1, 1) { + /* SEL_SCIF1 [3] */ + FN_SEL_SCIF1_0, FN_SEL_SCIF1_1, FN_SEL_SCIF1_2, FN_SEL_SCIF1_3, + FN_SEL_SCIF1_4, 0, 0, 0, + /* SEL_SCIFB [2] */ + FN_SEL_SCIFB_0, FN_SEL_SCIFB_1, FN_SEL_SCIFB_2, 0, + /* SEL_SCIFB2 [2] */ + FN_SEL_SCIFB2_0, FN_SEL_SCIFB2_1, FN_SEL_SCIFB2_2, 0, + /* SEL_SCIFB1 [3] */ + FN_SEL_SCIFB1_0, FN_SEL_SCIFB1_1, FN_SEL_SCIFB1_2, + FN_SEL_SCIFB1_3, FN_SEL_SCIFB1_4, FN_SEL_SCIFB1_5, + FN_SEL_SCIFB1_6, 0, + /* SEL_SCIFA1 [2] */ + FN_SEL_SCIFA1_0, FN_SEL_SCIFA1_1, FN_SEL_SCIFA1_2, + FN_SEL_SCIFA1_3, + /* SEL_SCIF0 [1] */ + FN_SEL_SCIF0_0, FN_SEL_SCIF0_1, + /* SEL_SCIFA [1] */ + FN_SEL_SCFA_0, FN_SEL_SCFA_1, + /* SEL_SOF1 [1] */ + FN_SEL_SOF1_0, FN_SEL_SOF1_1, + /* SEL_SSI7 [2] */ + FN_SEL_SSI7_0, FN_SEL_SSI7_1, FN_SEL_SSI7_2, 0, + /* SEL_SSI6 [1] */ + FN_SEL_SSI6_0, FN_SEL_SSI6_1, + /* SEL_SSI5 [2] */ + FN_SEL_SSI5_0, FN_SEL_SSI5_1, FN_SEL_SSI5_2, 0, + /* SEL_VI3 [1] */ + FN_SEL_VI3_0, FN_SEL_VI3_1, + /* SEL_VI2 [1] */ + FN_SEL_VI2_0, FN_SEL_VI2_1, + /* SEL_VI1 [1] */ + FN_SEL_VI1_0, FN_SEL_VI1_1, + /* SEL_VI0 [1] */ + FN_SEL_VI0_0, FN_SEL_VI0_1, + /* SEL_TSIF1 [2] */ + FN_SEL_TSIF1_0, FN_SEL_TSIF1_1, FN_SEL_TSIF1_2, 0, + /* RESERVED [1] */ + 0, 0, + /* SEL_LBS [1] */ + FN_SEL_LBS_0, FN_SEL_LBS_1, + /* SEL_TSIF0 [2] */ + FN_SEL_TSIF0_0, FN_SEL_TSIF0_1, FN_SEL_TSIF0_2, FN_SEL_TSIF0_3, + /* SEL_SOF3 [1] */ + FN_SEL_SOF3_0, FN_SEL_SOF3_1, + /* SEL_SOF0 [1] */ + FN_SEL_SOF0_0, FN_SEL_SOF0_1, } + }, + { PINMUX_CFG_REG_VAR("MOD_SEL2", 0xE6060094, 32, + 2, 1, 1, 1, 1, 2, 1, 2, 1, + 2, 1, 1, 1, 3, 3, 2, 3, 2, 2) { + /* RESEVED [2] */ + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESEVED [1] */ + 0, 0, + /* SEL_TMU1 [1] */ + FN_SEL_TMU1_0, FN_SEL_TMU1_1, + /* SEL_HSCIF1 [1] */ + FN_SEL_HSCIF1_0, FN_SEL_HSCIF1_1, + /* SEL_SCIFCLK [1] */ + FN_SEL_SCIFCLK_0, FN_SEL_SCIFCLK_1, + /* SEL_CAN0 [2] */ + FN_SEL_CAN0_0, FN_SEL_CAN0_1, FN_SEL_CAN0_2, FN_SEL_CAN0_3, + /* SEL_CANCLK [1] */ + FN_SEL_CANCLK_0, FN_SEL_CANCLK_1, + /* SEL_SCIFA2 [2] */ + FN_SEL_SCIFA2_0, FN_SEL_SCIFA2_1, FN_SEL_SCIFA2_2, 0, + /* SEL_CAN1 [1] */ + FN_SEL_CAN1_0, FN_SEL_CAN1_1, + /* RESEVED [2] */ + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESEVED [1] */ + 0, 0, + /* SEL_ADI [1] */ + FN_SEL_ADI_0, FN_SEL_ADI_1, + /* SEL_SSP [1] */ + FN_SEL_SSP_0, FN_SEL_SSP_1, + /* SEL_FM [3] */ + FN_SEL_FM_0, FN_SEL_FM_1, FN_SEL_FM_2, FN_SEL_FM_3, + FN_SEL_FM_4, FN_SEL_FM_5, FN_SEL_FM_6, 0, + /* SEL_HSCIF0 [3] */ + FN_SEL_HSCIF0_0, FN_SEL_HSCIF0_1, FN_SEL_HSCIF0_2, + FN_SEL_HSCIF0_3, FN_SEL_HSCIF0_4, FN_SEL_HSCIF0_5, 0, 0, + /* SEL_GPS [2] */ + FN_SEL_GPS_0, FN_SEL_GPS_1, FN_SEL_GPS_2, 0, + /* SEL_RDS [3] */ + FN_SEL_RDS_0, FN_SEL_RDS_1, FN_SEL_RDS_2, + FN_SEL_RDS_3, FN_SEL_RDS_4, FN_SEL_RDS_5, 0, 0, + /* SEL_SIM [2] */ + FN_SEL_SIM_0, FN_SEL_SIM_1, FN_SEL_SIM_2, 0, + /* SEL_SSI8 [2] */ + FN_SEL_SSI8_0, FN_SEL_SSI8_1, FN_SEL_SSI8_2, 0, } + }, + { PINMUX_CFG_REG_VAR("MOD_SEL3", 0xE6060098, 32, + 1, 1, 2, 4, 4, 2, 2, + 4, 2, 3, 2, 3, 2) { + /* SEL_IICDVFS [1] */ + FN_SEL_IICDVFS_0, FN_SEL_IICDVFS_1, + /* SEL_IIC0 [1] */ + FN_SEL_IIC0_0, FN_SEL_IIC0_1, + /* RESEVED [2] */ + 0, 0, 0, 0, + /* RESEVED [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESEVED [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESEVED [2] */ + 0, 0, 0, 0, + /* SEL_IEB [2] */ + FN_SEL_IEB_0, FN_SEL_IEB_1, FN_SEL_IEB_2, 0, + /* RESEVED [4] */ + 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, + /* RESEVED [2] */ + 0, 0, 0, 0, + /* SEL_IIC2 [3] */ + FN_SEL_IIC2_0, FN_SEL_IIC2_1, FN_SEL_IIC2_2, FN_SEL_IIC2_3, + FN_SEL_IIC2_4, 0, 0, 0, + /* SEL_IIC1 [2] */ + FN_SEL_IIC1_0, FN_SEL_IIC1_1, FN_SEL_IIC1_2, 0, + /* SEL_I2C2 [3] */ + FN_SEL_I2C2_0, FN_SEL_I2C2_1, FN_SEL_I2C2_2, FN_SEL_I2C2_3, + FN_SEL_I2C2_4, 0, 0, 0, + /* SEL_I2C1 [2] */ + FN_SEL_I2C1_0, FN_SEL_I2C1_1, FN_SEL_I2C1_2, 0, } + }, + { PINMUX_CFG_REG("INOUTSEL0", 0xE6050004, 32, 1) { GP_INOUTSEL(0) } }, + { PINMUX_CFG_REG("INOUTSEL1", 0xE6051004, 32, 1) { + 0, 0, + 0, 0, + GP_1_29_IN, GP_1_29_OUT, + GP_1_28_IN, GP_1_28_OUT, + GP_1_27_IN, GP_1_27_OUT, + GP_1_26_IN, GP_1_26_OUT, + GP_1_25_IN, GP_1_25_OUT, + GP_1_24_IN, GP_1_24_OUT, + GP_1_23_IN, GP_1_23_OUT, + GP_1_22_IN, GP_1_22_OUT, + GP_1_21_IN, GP_1_21_OUT, + GP_1_20_IN, GP_1_20_OUT, + GP_1_19_IN, GP_1_19_OUT, + GP_1_18_IN, GP_1_18_OUT, + GP_1_17_IN, GP_1_17_OUT, + GP_1_16_IN, GP_1_16_OUT, + GP_1_15_IN, GP_1_15_OUT, + GP_1_14_IN, GP_1_14_OUT, + GP_1_13_IN, GP_1_13_OUT, + GP_1_12_IN, GP_1_12_OUT, + GP_1_11_IN, GP_1_11_OUT, + GP_1_10_IN, GP_1_10_OUT, + GP_1_9_IN, GP_1_9_OUT, + GP_1_8_IN, GP_1_8_OUT, + GP_1_7_IN, GP_1_7_OUT, + GP_1_6_IN, GP_1_6_OUT, + GP_1_5_IN, GP_1_5_OUT, + GP_1_4_IN, GP_1_4_OUT, + GP_1_3_IN, GP_1_3_OUT, + GP_1_2_IN, GP_1_2_OUT, + GP_1_1_IN, GP_1_1_OUT, + GP_1_0_IN, GP_1_0_OUT, } + }, + { PINMUX_CFG_REG("INOUTSEL2", 0xE6052004, 32, 1) { + 0, 0, + 0, 0, + GP_2_29_IN, GP_2_29_OUT, + GP_2_28_IN, GP_2_28_OUT, + GP_2_27_IN, GP_2_27_OUT, + GP_2_26_IN, GP_2_26_OUT, + GP_2_25_IN, GP_2_25_OUT, + GP_2_24_IN, GP_2_24_OUT, + GP_2_23_IN, GP_2_23_OUT, + GP_2_22_IN, GP_2_22_OUT, + GP_2_21_IN, GP_2_21_OUT, + GP_2_20_IN, GP_2_20_OUT, + GP_2_19_IN, GP_2_19_OUT, + GP_2_18_IN, GP_2_18_OUT, + GP_2_17_IN, GP_2_17_OUT, + GP_2_16_IN, GP_2_16_OUT, + GP_2_15_IN, GP_2_15_OUT, + GP_2_14_IN, GP_2_14_OUT, + GP_2_13_IN, GP_2_13_OUT, + GP_2_12_IN, GP_2_12_OUT, + GP_2_11_IN, GP_2_11_OUT, + GP_2_10_IN, GP_2_10_OUT, + GP_2_9_IN, GP_2_9_OUT, + GP_2_8_IN, GP_2_8_OUT, + GP_2_7_IN, GP_2_7_OUT, + GP_2_6_IN, GP_2_6_OUT, + GP_2_5_IN, GP_2_5_OUT, + GP_2_4_IN, GP_2_4_OUT, + GP_2_3_IN, GP_2_3_OUT, + GP_2_2_IN, GP_2_2_OUT, + GP_2_1_IN, GP_2_1_OUT, + GP_2_0_IN, GP_2_0_OUT, } + }, + { PINMUX_CFG_REG("INOUTSEL3", 0xE6053004, 32, 1) { GP_INOUTSEL(3) } }, + { PINMUX_CFG_REG("INOUTSEL4", 0xE6054004, 32, 1) { GP_INOUTSEL(4) } }, + { PINMUX_CFG_REG("INOUTSEL5", 0xE6055004, 32, 1) { GP_INOUTSEL(5) } }, + { }, +}; + +static struct pinmux_data_reg pinmux_data_regs[] = { + { PINMUX_DATA_REG("INDT0", 0xE6050008, 32) { GP_INDT(0) } }, + { PINMUX_DATA_REG("INDT1", 0xE6051008, 32) { + 0, 0, GP_1_29_DATA, GP_1_28_DATA, + GP_1_27_DATA, GP_1_26_DATA, GP_1_25_DATA, GP_1_24_DATA, + GP_1_23_DATA, GP_1_22_DATA, GP_1_21_DATA, GP_1_20_DATA, + GP_1_19_DATA, GP_1_18_DATA, GP_1_17_DATA, GP_1_16_DATA, + GP_1_15_DATA, GP_1_14_DATA, GP_1_13_DATA, GP_1_12_DATA, + GP_1_11_DATA, GP_1_10_DATA, GP_1_9_DATA, GP_1_8_DATA, + GP_1_7_DATA, GP_1_6_DATA, GP_1_5_DATA, GP_1_4_DATA, + GP_1_3_DATA, GP_1_2_DATA, GP_1_1_DATA, GP_1_0_DATA } + }, + { PINMUX_DATA_REG("INDT2", 0xE6052008, 32) { + 0, 0, GP_2_29_DATA, GP_2_28_DATA, + GP_2_27_DATA, GP_2_26_DATA, GP_2_25_DATA, GP_2_24_DATA, + GP_2_23_DATA, GP_2_22_DATA, GP_2_21_DATA, GP_2_20_DATA, + GP_2_19_DATA, GP_2_18_DATA, GP_2_17_DATA, GP_2_16_DATA, + GP_2_15_DATA, GP_2_14_DATA, GP_2_13_DATA, GP_2_12_DATA, + GP_2_11_DATA, GP_2_10_DATA, GP_2_9_DATA, GP_2_8_DATA, + GP_2_7_DATA, GP_2_6_DATA, GP_2_5_DATA, GP_2_4_DATA, + GP_2_3_DATA, GP_2_2_DATA, GP_2_1_DATA, GP_2_0_DATA } + }, + { PINMUX_DATA_REG("INDT3", 0xE6053008, 32) { GP_INDT(3) } }, + { PINMUX_DATA_REG("INDT4", 0xE6054008, 32) { GP_INDT(4) } }, + { PINMUX_DATA_REG("INDT5", 0xE6055008, 32) { GP_INDT(5) } }, + { }, +}; + +static struct pinmux_info r8a7790_pinmux_info = { + .name = "r8a7790_pfc", + + .unlock_reg = 0xe6060000, /* PMMR */ + + .reserved_id = PINMUX_RESERVED, + .data = { PINMUX_DATA_BEGIN, PINMUX_DATA_END }, + .input = { PINMUX_INPUT_BEGIN, PINMUX_INPUT_END }, + .output = { PINMUX_OUTPUT_BEGIN, PINMUX_OUTPUT_END }, + .mark = { PINMUX_MARK_BEGIN, PINMUX_MARK_END }, + .function = { PINMUX_FUNCTION_BEGIN, PINMUX_FUNCTION_END }, + + .first_gpio = GPIO_GP_0_0, + .last_gpio = GPIO_FN_TCLK1_B, + + .gpios = pinmux_gpios, + .cfg_regs = pinmux_config_regs, + .data_regs = pinmux_data_regs, + + .gpio_data = pinmux_data, + .gpio_data_size = ARRAY_SIZE(pinmux_data), +}; + +void r8a7790_pinmux_init(void) +{ + register_pinmux(&r8a7790_pinmux_info); +} diff --git a/arch/arm/include/asm/arch-rmobile/gpio.h b/arch/arm/include/asm/arch-rmobile/gpio.h index 6b5e4ed..877b394 100644 --- a/arch/arm/include/asm/arch-rmobile/gpio.h +++ b/arch/arm/include/asm/arch-rmobile/gpio.h @@ -7,6 +7,9 @@ void sh73a0_pinmux_init(void); #elif defined(CONFIG_R8A7740) #include "r8a7740-gpio.h" void r8a7740_pinmux_init(void); +#elif defined(CONFIG_R8A7790) +#include "r8a7790-gpio.h" +void r8a7790_pinmux_init(void); #endif
#endif /* __ASM_ARCH_GPIO_H */ diff --git a/arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h b/arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h new file mode 100644 index 0000000..444e361 --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/r8a7790-gpio.h @@ -0,0 +1,387 @@ +#ifndef __ASM_R8A7790_H__ +#define __ASM_R8A7790_H__ + +/* Pin Function Controller: + * GPIO_FN_xx - GPIO used to select pin function + * GPIO_GP_x_x - GPIO mapped to real I/O pin on CPU + */ +enum { + GPIO_GP_0_0, GPIO_GP_0_1, GPIO_GP_0_2, GPIO_GP_0_3, + GPIO_GP_0_4, GPIO_GP_0_5, GPIO_GP_0_6, GPIO_GP_0_7, + GPIO_GP_0_8, GPIO_GP_0_9, GPIO_GP_0_10, GPIO_GP_0_11, + GPIO_GP_0_12, GPIO_GP_0_13, GPIO_GP_0_14, GPIO_GP_0_15, + GPIO_GP_0_16, GPIO_GP_0_17, GPIO_GP_0_18, GPIO_GP_0_19, + GPIO_GP_0_20, GPIO_GP_0_21, GPIO_GP_0_22, GPIO_GP_0_23, + GPIO_GP_0_24, GPIO_GP_0_25, GPIO_GP_0_26, GPIO_GP_0_27, + GPIO_GP_0_28, GPIO_GP_0_29, GPIO_GP_0_30, GPIO_GP_0_31, + + GPIO_GP_1_0, GPIO_GP_1_1, GPIO_GP_1_2, GPIO_GP_1_3, + GPIO_GP_1_4, GPIO_GP_1_5, GPIO_GP_1_6, GPIO_GP_1_7, + GPIO_GP_1_8, GPIO_GP_1_9, GPIO_GP_1_10, GPIO_GP_1_11, + GPIO_GP_1_12, GPIO_GP_1_13, GPIO_GP_1_14, GPIO_GP_1_15, + GPIO_GP_1_16, GPIO_GP_1_17, GPIO_GP_1_18, GPIO_GP_1_19, + GPIO_GP_1_20, GPIO_GP_1_21, GPIO_GP_1_22, GPIO_GP_1_23, + GPIO_GP_1_24, GPIO_GP_1_25, GPIO_GP_1_26, GPIO_GP_1_27, + GPIO_GP_1_28, GPIO_GP_1_29, + + GPIO_GP_2_0, GPIO_GP_2_1, GPIO_GP_2_2, GPIO_GP_2_3, + GPIO_GP_2_4, GPIO_GP_2_5, GPIO_GP_2_6, GPIO_GP_2_7, + GPIO_GP_2_8, GPIO_GP_2_9, GPIO_GP_2_10, GPIO_GP_2_11, + GPIO_GP_2_12, GPIO_GP_2_13, GPIO_GP_2_14, GPIO_GP_2_15, + GPIO_GP_2_16, GPIO_GP_2_17, GPIO_GP_2_18, GPIO_GP_2_19, + GPIO_GP_2_20, GPIO_GP_2_21, GPIO_GP_2_22, GPIO_GP_2_23, + GPIO_GP_2_24, GPIO_GP_2_25, GPIO_GP_2_26, GPIO_GP_2_27, + GPIO_GP_2_28, GPIO_GP_2_29, + + GPIO_GP_3_0, GPIO_GP_3_1, GPIO_GP_3_2, GPIO_GP_3_3, + GPIO_GP_3_4, GPIO_GP_3_5, GPIO_GP_3_6, GPIO_GP_3_7, + GPIO_GP_3_8, GPIO_GP_3_9, GPIO_GP_3_10, GPIO_GP_3_11, + GPIO_GP_3_12, GPIO_GP_3_13, GPIO_GP_3_14, GPIO_GP_3_15, + GPIO_GP_3_16, GPIO_GP_3_17, GPIO_GP_3_18, GPIO_GP_3_19, + GPIO_GP_3_20, GPIO_GP_3_21, GPIO_GP_3_22, GPIO_GP_3_23, + GPIO_GP_3_24, GPIO_GP_3_25, GPIO_GP_3_26, GPIO_GP_3_27, + GPIO_GP_3_28, GPIO_GP_3_29, GPIO_GP_3_30, GPIO_GP_3_31, + + GPIO_GP_4_0, GPIO_GP_4_1, GPIO_GP_4_2, GPIO_GP_4_3, + GPIO_GP_4_4, GPIO_GP_4_5, GPIO_GP_4_6, GPIO_GP_4_7, + GPIO_GP_4_8, GPIO_GP_4_9, GPIO_GP_4_10, GPIO_GP_4_11, + GPIO_GP_4_12, GPIO_GP_4_13, GPIO_GP_4_14, GPIO_GP_4_15, + GPIO_GP_4_16, GPIO_GP_4_17, GPIO_GP_4_18, GPIO_GP_4_19, + GPIO_GP_4_20, GPIO_GP_4_21, GPIO_GP_4_22, GPIO_GP_4_23, + GPIO_GP_4_24, GPIO_GP_4_25, GPIO_GP_4_26, GPIO_GP_4_27, + GPIO_GP_4_28, GPIO_GP_4_29, GPIO_GP_4_30, GPIO_GP_4_31, + + GPIO_GP_5_0, GPIO_GP_5_1, GPIO_GP_5_2, GPIO_GP_5_3, + GPIO_GP_5_4, GPIO_GP_5_5, GPIO_GP_5_6, GPIO_GP_5_7, + GPIO_GP_5_8, GPIO_GP_5_9, GPIO_GP_5_10, GPIO_GP_5_11, + GPIO_GP_5_12, GPIO_GP_5_13, GPIO_GP_5_14, GPIO_GP_5_15, + GPIO_GP_5_16, GPIO_GP_5_17, GPIO_GP_5_18, GPIO_GP_5_19, + GPIO_GP_5_20, GPIO_GP_5_21, GPIO_GP_5_22, GPIO_GP_5_23, + GPIO_GP_5_24, GPIO_GP_5_25, GPIO_GP_5_26, GPIO_GP_5_27, + GPIO_GP_5_28, GPIO_GP_5_29, GPIO_GP_5_30, GPIO_GP_5_31, + + GPIO_FN_VI1_DATA7_VI1_B7, GPIO_FN_USB0_PWEN, GPIO_FN_USB0_OVC_VBUS, + GPIO_FN_USB2_PWEN, GPIO_FN_USB2_OVC, GPIO_FN_AVS1, GPIO_FN_AVS2, + GPIO_FN_DU_DOTCLKIN0, GPIO_FN_DU_DOTCLKIN2, + + /* IPSR0 */ + GPIO_FN_D1, GPIO_FN_MSIOF3_SYNC_B, GPIO_FN_VI3_DATA1, GPIO_FN_VI0_G5, + GPIO_FN_VI0_G5_B, GPIO_FN_D2, GPIO_FN_MSIOF3_RXD_B, GPIO_FN_VI3_DATA2, + GPIO_FN_VI0_G6, GPIO_FN_VI0_G6_B, GPIO_FN_D3, GPIO_FN_MSIOF3_TXD_B, + GPIO_FN_VI3_DATA3, GPIO_FN_VI0_G7, GPIO_FN_VI0_G7_B, GPIO_FN_D4, + GPIO_FN_SCIFB1_RXD_F, GPIO_FN_SCIFB0_RXD_C, GPIO_FN_VI3_DATA4, + GPIO_FN_VI0_R0, GPIO_FN_VI0_R0_B, GPIO_FN_RX0_B, GPIO_FN_D5, + GPIO_FN_SCIFB1_TXD_F, GPIO_FN_SCIFB0_TXD_C, GPIO_FN_VI3_DATA5, + GPIO_FN_VI0_R1, GPIO_FN_VI0_R1_B, GPIO_FN_TX0_B, GPIO_FN_D6, + GPIO_FN_SCL2_C, GPIO_FN_VI3_DATA6, GPIO_FN_VI0_R2, GPIO_FN_VI0_R2_B, + GPIO_FN_SCL2_CIS_C, GPIO_FN_D7, GPIO_FN_AD_DI_B, GPIO_FN_SDA2_C, + GPIO_FN_VI3_DATA7, GPIO_FN_VI0_R3, GPIO_FN_VI0_R3_B, GPIO_FN_SDA2_CIS_C, + GPIO_FN_D8, GPIO_FN_SCIFA1_SCK_C, GPIO_FN_AVB_TXD0, GPIO_FN_MII_TXD0, + GPIO_FN_VI0_G0, GPIO_FN_VI0_G0_B, GPIO_FN_VI2_DATA0_VI2_B0, + + /* IPSR1 */ + GPIO_FN_D9, GPIO_FN_SCIFA1_RXD_C, GPIO_FN_AVB_TXD1, GPIO_FN_MII_TXD1, + GPIO_FN_VI0_G1, GPIO_FN_VI0_G1_B, GPIO_FN_VI2_DATA1_VI2_B1, GPIO_FN_D10, + GPIO_FN_SCIFA1_TXD_C, GPIO_FN_AVB_TXD2, GPIO_FN_MII_TXD2, + GPIO_FN_VI0_G2, GPIO_FN_VI0_G2_B, GPIO_FN_VI2_DATA2_VI2_B2, GPIO_FN_D11, + GPIO_FN_SCIFA1_CTS_N_C, GPIO_FN_AVB_TXD3, GPIO_FN_MII_TXD3, + GPIO_FN_VI0_G3, GPIO_FN_VI0_G3_B, GPIO_FN_VI2_DATA3_VI2_B3, + GPIO_FN_D12, GPIO_FN_SCIFA1_RTS_N_C, GPIO_FN_AVB_TXD4, + GPIO_FN_VI0_HSYNC_N, GPIO_FN_VI0_HSYNC_N_B, GPIO_FN_VI2_DATA4_VI2_B4, + GPIO_FN_D13, GPIO_FN_AVB_TXD5, GPIO_FN_VI0_VSYNC_N, + GPIO_FN_VI0_VSYNC_N_B, GPIO_FN_VI2_DATA5_VI2_B5, GPIO_FN_D14, + GPIO_FN_SCIFB1_RXD_C, GPIO_FN_AVB_TXD6, GPIO_FN_RX1_B, + GPIO_FN_VI0_CLKENB, GPIO_FN_VI0_CLKENB_B, GPIO_FN_VI2_DATA6_VI2_B6, + GPIO_FN_D15, GPIO_FN_SCIFB1_TXD_C, GPIO_FN_AVB_TXD7, GPIO_FN_TX1_B, + GPIO_FN_VI0_FIELD, GPIO_FN_VI0_FIELD_B, GPIO_FN_VI2_DATA7_VI2_B7, + GPIO_FN_A0, GPIO_FN_PWM3, GPIO_FN_A1, GPIO_FN_PWM4, + + /* IPSR2 */ + GPIO_FN_A2, GPIO_FN_PWM5, GPIO_FN_MSIOF1_SS1_B, GPIO_FN_A3, + GPIO_FN_PWM6, GPIO_FN_MSIOF1_SS2_B, GPIO_FN_A4, GPIO_FN_MSIOF1_TXD_B, + GPIO_FN_TPU0TO0, GPIO_FN_A5, GPIO_FN_SCIFA1_TXD_B, GPIO_FN_TPU0TO1, + GPIO_FN_A6, GPIO_FN_SCIFA1_RTS_N_B, GPIO_FN_TPU0TO2, GPIO_FN_A7, + GPIO_FN_SCIFA1_SCK_B, GPIO_FN_AUDIO_CLKOUT_B, GPIO_FN_TPU0TO3, + GPIO_FN_A8, GPIO_FN_SCIFA1_RXD_B, GPIO_FN_SSI_SCK5_B, GPIO_FN_VI0_R4, + GPIO_FN_VI0_R4_B, GPIO_FN_SCIFB2_RXD_C, GPIO_FN_VI2_DATA0_VI2_B0_B, + GPIO_FN_A9, GPIO_FN_SCIFA1_CTS_N_B, GPIO_FN_SSI_WS5_B, GPIO_FN_VI0_R5, + GPIO_FN_VI0_R5_B, GPIO_FN_SCIFB2_TXD_C, GPIO_FN_VI2_DATA1_VI2_B1_B, + GPIO_FN_A10, GPIO_FN_SSI_SDATA5_B, GPIO_FN_MSIOF2_SYNC, GPIO_FN_VI0_R6, + GPIO_FN_VI0_R6_B, GPIO_FN_VI2_DATA2_VI2_B2_B, + + /* IPSR3 */ + GPIO_FN_A11, GPIO_FN_SCIFB2_CTS_N_B, GPIO_FN_MSIOF2_SCK, GPIO_FN_VI1_R0, + GPIO_FN_VI1_R0_B, GPIO_FN_VI2_G0, GPIO_FN_VI2_DATA3_VI2_B3_B, + GPIO_FN_A12, GPIO_FN_SCIFB2_RXD_B, GPIO_FN_MSIOF2_TXD, GPIO_FN_VI1_R1, + GPIO_FN_VI1_R1_B, GPIO_FN_VI2_G1, GPIO_FN_VI2_DATA4_VI2_B4_B, + GPIO_FN_A13, GPIO_FN_SCIFB2_RTS_N_B, GPIO_FN_EX_WAIT2, + GPIO_FN_MSIOF2_RXD, GPIO_FN_VI1_R2, GPIO_FN_VI1_R2_B, GPIO_FN_VI2_G2, + GPIO_FN_VI2_DATA5_VI2_B5_B, GPIO_FN_A14, GPIO_FN_SCIFB2_TXD_B, + GPIO_FN_ATACS11_N, GPIO_FN_MSIOF2_SS1, GPIO_FN_A15, + GPIO_FN_SCIFB2_SCK_B, GPIO_FN_ATARD1_N, GPIO_FN_MSIOF2_SS2, GPIO_FN_A16, + GPIO_FN_ATAWR1_N, GPIO_FN_A17, GPIO_FN_AD_DO_B, GPIO_FN_ATADIR1_N, + GPIO_FN_A18, GPIO_FN_AD_CLK_B, GPIO_FN_ATAG1_N, GPIO_FN_A19, + GPIO_FN_AD_NCS_N_B, GPIO_FN_ATACS01_N, GPIO_FN_EX_WAIT0_B, GPIO_FN_A20, + GPIO_FN_SPCLK, GPIO_FN_VI1_R3, GPIO_FN_VI1_R3_B, GPIO_FN_VI2_G4, + + /* IPSR4 */ + GPIO_FN_A21, GPIO_FN_MOSI_IO0, GPIO_FN_VI1_R4, GPIO_FN_VI1_R4_B, + GPIO_FN_VI2_G5, GPIO_FN_A22, GPIO_FN_MISO_IO1, GPIO_FN_VI1_R5, + GPIO_FN_VI1_R5_B, GPIO_FN_VI2_G6, GPIO_FN_A23, GPIO_FN_IO2, + GPIO_FN_VI1_G7, GPIO_FN_VI1_G7_B, GPIO_FN_VI2_G7, GPIO_FN_A24, + GPIO_FN_IO3, GPIO_FN_VI1_R7, GPIO_FN_VI1_R7_B, GPIO_FN_VI2_CLKENB, + GPIO_FN_VI2_CLKENB_B, GPIO_FN_A25, GPIO_FN_SSL, GPIO_FN_VI1_G6, + GPIO_FN_VI1_G6_B, GPIO_FN_VI2_FIELD, GPIO_FN_VI2_FIELD_B, GPIO_FN_CS0_N, + GPIO_FN_VI1_R6, GPIO_FN_VI1_R6_B, GPIO_FN_VI2_G3, GPIO_FN_MSIOF0_SS2_B, + GPIO_FN_CS1_N_A26, GPIO_FN_SPEEDIN, GPIO_FN_VI0_R7, GPIO_FN_VI0_R7_B, + GPIO_FN_VI2_CLK, GPIO_FN_VI2_CLK_B, GPIO_FN_EX_CS0_N, GPIO_FN_HRX1_B, + GPIO_FN_VI1_G5, GPIO_FN_VI1_G5_B, GPIO_FN_VI2_R0, GPIO_FN_HTX0_B, + GPIO_FN_MSIOF0_SS1_B, GPIO_FN_EX_CS1_N, GPIO_FN_GPS_CLK, + GPIO_FN_HCTS1_N_B, GPIO_FN_VI1_FIELD, GPIO_FN_VI1_FIELD_B, + GPIO_FN_VI2_R1, GPIO_FN_EX_CS2_N, GPIO_FN_GPS_SIGN, GPIO_FN_HRTS1_N_B, + GPIO_FN_VI3_CLKENB, GPIO_FN_VI1_G0, GPIO_FN_VI1_G0_B, GPIO_FN_VI2_R2, + + /* IPSR5 */ + GPIO_FN_EX_CS3_N, GPIO_FN_GPS_MAG, GPIO_FN_VI3_FIELD, GPIO_FN_VI1_G1, + GPIO_FN_VI1_G1_B, GPIO_FN_VI2_R3, GPIO_FN_EX_CS4_N, + GPIO_FN_MSIOF1_SCK_B, GPIO_FN_VI3_HSYNC_N, + GPIO_FN_VI2_HSYNC_N, GPIO_FN_SCL1, GPIO_FN_VI2_HSYNC_N_B, + GPIO_FN_INTC_EN0_N, GPIO_FN_SCL1_CIS, GPIO_FN_EX_CS5_N, GPIO_FN_CAN0_RX, + GPIO_FN_MSIOF1_RXD_B, GPIO_FN_VI3_VSYNC_N, GPIO_FN_VI1_G2, + GPIO_FN_VI1_G2_B, GPIO_FN_VI2_R4, GPIO_FN_SDA1, GPIO_FN_INTC_EN1_N, + GPIO_FN_SDA1_CIS, GPIO_FN_BS_N, GPIO_FN_IETX, GPIO_FN_HTX1_B, + GPIO_FN_CAN1_TX, GPIO_FN_DRACK0, GPIO_FN_IETX_C, GPIO_FN_RD_N, + GPIO_FN_CAN0_TX, GPIO_FN_SCIFA0_SCK_B, GPIO_FN_RD_WR_N, GPIO_FN_VI1_G3, + GPIO_FN_VI1_G3_B, GPIO_FN_VI2_R5, GPIO_FN_SCIFA0_RXD_B, + GPIO_FN_INTC_IRQ4_N, GPIO_FN_WE0_N, GPIO_FN_IECLK, GPIO_FN_CAN_CLK, + GPIO_FN_VI2_VSYNC_N, GPIO_FN_SCIFA0_TXD_B, GPIO_FN_VI2_VSYNC_N_B, + GPIO_FN_WE1_N, GPIO_FN_IERX, GPIO_FN_CAN1_RX, GPIO_FN_VI1_G4, + GPIO_FN_VI1_G4_B, GPIO_FN_VI2_R6, GPIO_FN_SCIFA0_CTS_N_B, + GPIO_FN_IERX_C, GPIO_FN_EX_WAIT0, GPIO_FN_IRQ3, GPIO_FN_INTC_IRQ3_N, + GPIO_FN_VI3_CLK, GPIO_FN_SCIFA0_RTS_N_B, GPIO_FN_HRX0_B, + GPIO_FN_MSIOF0_SCK_B, GPIO_FN_DREQ0_N, GPIO_FN_VI1_HSYNC_N, + GPIO_FN_VI1_HSYNC_N_B, GPIO_FN_VI2_R7, GPIO_FN_SSI_SCK78_C, + GPIO_FN_SSI_WS78_B, + + /* IPSR6 */ + GPIO_FN_DACK0, GPIO_FN_IRQ0, GPIO_FN_INTC_IRQ0_N, GPIO_FN_SSI_SCK6_B, + GPIO_FN_VI1_VSYNC_N, GPIO_FN_VI1_VSYNC_N_B, GPIO_FN_SSI_WS78_C, + GPIO_FN_DREQ1_N, GPIO_FN_VI1_CLKENB, GPIO_FN_VI1_CLKENB_B, + GPIO_FN_SSI_SDATA7_C, GPIO_FN_SSI_SCK78_B, GPIO_FN_DACK1, GPIO_FN_IRQ1, + GPIO_FN_INTC_IRQ1_N, GPIO_FN_SSI_WS6_B, GPIO_FN_SSI_SDATA8_C, + GPIO_FN_DREQ2_N, GPIO_FN_HSCK1_B, GPIO_FN_HCTS0_N_B, + GPIO_FN_MSIOF0_TXD_B, GPIO_FN_DACK2, GPIO_FN_IRQ2, GPIO_FN_INTC_IRQ2_N, + GPIO_FN_SSI_SDATA6_B, GPIO_FN_HRTS0_N_B, GPIO_FN_MSIOF0_RXD_B, + GPIO_FN_ETH_CRS_DV, GPIO_FN_RMII_CRS_DV, GPIO_FN_STP_ISCLK_0_B, + GPIO_FN_TS_SDEN0_D, GPIO_FN_GLO_Q0_C, GPIO_FN_SCL2_E, + GPIO_FN_SCL2_CIS_E, GPIO_FN_ETH_RX_ER, GPIO_FN_RMII_RX_ER, + GPIO_FN_STP_ISD_0_B, GPIO_FN_TS_SPSYNC0_D, GPIO_FN_GLO_Q1_C, + GPIO_FN_SDA2_E, GPIO_FN_SDA2_CIS_E, GPIO_FN_ETH_RXD0, GPIO_FN_RMII_RXD0, + GPIO_FN_STP_ISEN_0_B, GPIO_FN_TS_SDAT0_D, GPIO_FN_GLO_I0_C, + GPIO_FN_SCIFB1_SCK_G, GPIO_FN_SCK1_E, GPIO_FN_ETH_RXD1, + GPIO_FN_RMII_RXD1, GPIO_FN_HRX0_E, GPIO_FN_STP_ISSYNC_0_B, + GPIO_FN_TS_SCK0_D, GPIO_FN_GLO_I1_C, GPIO_FN_SCIFB1_RXD_G, + GPIO_FN_RX1_E, GPIO_FN_ETH_LINK, GPIO_FN_RMII_LINK, GPIO_FN_HTX0_E, + GPIO_FN_STP_IVCXO27_0_B, GPIO_FN_SCIFB1_TXD_G, GPIO_FN_TX1_E, + GPIO_FN_ETH_REF_CLK, GPIO_FN_RMII_REF_CLK, GPIO_FN_HCTS0_N_E, + GPIO_FN_STP_IVCXO27_1_B, GPIO_FN_HRX0_F, + + /* IPSR7 */ + GPIO_FN_ETH_MDIO, GPIO_FN_RMII_MDIO, GPIO_FN_HRTS0_N_E, + GPIO_FN_SIM0_D_C, GPIO_FN_HCTS0_N_F, GPIO_FN_ETH_TXD1, + GPIO_FN_RMII_TXD1, GPIO_FN_HTX0_F, GPIO_FN_BPFCLK_G, GPIO_FN_RDS_CLK_F, + GPIO_FN_ETH_TX_EN, GPIO_FN_RMII_TX_EN, GPIO_FN_SIM0_CLK_C, + GPIO_FN_HRTS0_N_F, GPIO_FN_ETH_MAGIC, GPIO_FN_RMII_MAGIC, + GPIO_FN_SIM0_RST_C, GPIO_FN_ETH_TXD0, GPIO_FN_RMII_TXD0, + GPIO_FN_STP_ISCLK_1_B, GPIO_FN_TS_SDEN1_C, GPIO_FN_GLO_SCLK_C, + GPIO_FN_ETH_MDC, GPIO_FN_RMII_MDC, GPIO_FN_STP_ISD_1_B, + GPIO_FN_TS_SPSYNC1_C, GPIO_FN_GLO_SDATA_C, GPIO_FN_PWM0, + GPIO_FN_SCIFA2_SCK_C, GPIO_FN_STP_ISEN_1_B, GPIO_FN_TS_SDAT1_C, + GPIO_FN_GLO_SS_C, GPIO_FN_PWM1, GPIO_FN_SCIFA2_TXD_C, + GPIO_FN_STP_ISSYNC_1_B, GPIO_FN_TS_SCK1_C, GPIO_FN_GLO_RFON_C, + GPIO_FN_PCMOE_N, GPIO_FN_PWM2, GPIO_FN_PWMFSW0, GPIO_FN_SCIFA2_RXD_C, + GPIO_FN_PCMWE_N, GPIO_FN_IECLK_C, GPIO_FN_DU1_DOTCLKIN, + GPIO_FN_AUDIO_CLKC, GPIO_FN_AUDIO_CLKOUT_C, GPIO_FN_VI0_CLK, + GPIO_FN_ATACS00_N, GPIO_FN_AVB_RXD1, GPIO_FN_MII_RXD1, + GPIO_FN_VI0_DATA0_VI0_B0, GPIO_FN_ATACS10_N, GPIO_FN_AVB_RXD2, + GPIO_FN_MII_RXD2, + + /* IPSR8 */ + GPIO_FN_VI0_DATA1_VI0_B1, GPIO_FN_ATARD0_N, GPIO_FN_AVB_RXD3, + GPIO_FN_MII_RXD3, GPIO_FN_VI0_DATA2_VI0_B2, GPIO_FN_ATAWR0_N, + GPIO_FN_AVB_RXD4, GPIO_FN_VI0_DATA3_VI0_B3, GPIO_FN_ATADIR0_N, + GPIO_FN_AVB_RXD5, GPIO_FN_VI0_DATA4_VI0_B4, GPIO_FN_ATAG0_N, + GPIO_FN_AVB_RXD6, GPIO_FN_VI0_DATA5_VI0_B5, GPIO_FN_EX_WAIT1, + GPIO_FN_AVB_RXD7, GPIO_FN_VI0_DATA6_VI0_B6, GPIO_FN_AVB_RX_ER, + GPIO_FN_MII_RX_ER, GPIO_FN_VI0_DATA7_VI0_B7, GPIO_FN_AVB_RX_CLK, + GPIO_FN_MII_RX_CLK, GPIO_FN_VI1_CLK, GPIO_FN_AVB_RX_DV, + GPIO_FN_MII_RX_DV, GPIO_FN_VI1_DATA0_VI1_B0, GPIO_FN_SCIFA1_SCK_D, + GPIO_FN_AVB_CRS, GPIO_FN_MII_CRS, GPIO_FN_VI1_DATA1_VI1_B1, + GPIO_FN_SCIFA1_RXD_D, GPIO_FN_AVB_MDC, GPIO_FN_MII_MDC, + GPIO_FN_VI1_DATA2_VI1_B2, GPIO_FN_SCIFA1_TXD_D, GPIO_FN_AVB_MDIO, + GPIO_FN_MII_MDIO, GPIO_FN_VI1_DATA3_VI1_B3, GPIO_FN_SCIFA1_CTS_N_D, + GPIO_FN_AVB_GTX_CLK, GPIO_FN_VI1_DATA4_VI1_B4, GPIO_FN_SCIFA1_RTS_N_D, + GPIO_FN_AVB_MAGIC, GPIO_FN_MII_MAGIC, GPIO_FN_VI1_DATA5_VI1_B5, + GPIO_FN_AVB_PHY_INT, GPIO_FN_VI1_DATA6_VI1_B6, GPIO_FN_AVB_GTXREFCLK, + GPIO_FN_SD0_CLK, GPIO_FN_VI1_DATA0_VI1_B0_B, GPIO_FN_SD0_CMD, + GPIO_FN_SCIFB1_SCK_B, GPIO_FN_VI1_DATA1_VI1_B1_B, + + /* IPSR9 */ + GPIO_FN_SD0_DAT0, GPIO_FN_SCIFB1_RXD_B, GPIO_FN_VI1_DATA2_VI1_B2_B, + GPIO_FN_SD0_DAT1, GPIO_FN_SCIFB1_TXD_B, GPIO_FN_VI1_DATA3_VI1_B3_B, + GPIO_FN_SD0_DAT2, GPIO_FN_SCIFB1_CTS_N_B, GPIO_FN_VI1_DATA4_VI1_B4_B, + GPIO_FN_SD0_DAT3, GPIO_FN_SCIFB1_RTS_N_B, GPIO_FN_VI1_DATA5_VI1_B5_B, + GPIO_FN_SD0_CD, GPIO_FN_MMC0_D6, GPIO_FN_TS_SDEN0_B, GPIO_FN_USB0_EXTP, + GPIO_FN_GLO_SCLK, GPIO_FN_VI1_DATA6_VI1_B6_B, GPIO_FN_SCL1_B, + GPIO_FN_SCL1_CIS_B, GPIO_FN_VI2_DATA6_VI2_B6_B, GPIO_FN_SD0_WP, + GPIO_FN_MMC0_D7, GPIO_FN_TS_SPSYNC0_B, GPIO_FN_USB0_IDIN, + GPIO_FN_GLO_SDATA, GPIO_FN_VI1_DATA7_VI1_B7_B, GPIO_FN_SDA1_B, + GPIO_FN_SDA1_CIS_B, GPIO_FN_VI2_DATA7_VI2_B7_B, GPIO_FN_SD1_CLK, + GPIO_FN_AVB_TX_EN, GPIO_FN_MII_TX_EN, GPIO_FN_SD1_CMD, + GPIO_FN_AVB_TX_ER, GPIO_FN_MII_TX_ER, GPIO_FN_SCIFB0_SCK_B, + GPIO_FN_SD1_DAT0, GPIO_FN_AVB_TX_CLK, GPIO_FN_MII_TX_CLK, + GPIO_FN_SCIFB0_RXD_B, GPIO_FN_SD1_DAT1, GPIO_FN_AVB_LINK, + GPIO_FN_MII_LINK, GPIO_FN_SCIFB0_TXD_B, GPIO_FN_SD1_DAT2, + GPIO_FN_AVB_COL, GPIO_FN_MII_COL, GPIO_FN_SCIFB0_CTS_N_B, + GPIO_FN_SD1_DAT3, GPIO_FN_AVB_RXD0, GPIO_FN_MII_RXD0, + GPIO_FN_SCIFB0_RTS_N_B, GPIO_FN_SD1_CD, GPIO_FN_MMC1_D6, + GPIO_FN_TS_SDEN1, GPIO_FN_USB1_EXTP, GPIO_FN_GLO_SS, GPIO_FN_VI0_CLK_B, + GPIO_FN_SCL2_D, GPIO_FN_SCL2_CIS_D, GPIO_FN_SIM0_CLK_B, + GPIO_FN_VI3_CLK_B, + + /* IPSR10 */ + GPIO_FN_SD1_WP, GPIO_FN_MMC1_D7, GPIO_FN_TS_SPSYNC1, GPIO_FN_USB1_IDIN, + GPIO_FN_GLO_RFON, GPIO_FN_VI1_CLK_B, GPIO_FN_SDA2_D, GPIO_FN_SDA2_CIS_D, + GPIO_FN_SIM0_D_B, GPIO_FN_SD2_CLK, GPIO_FN_MMC0_CLK, GPIO_FN_SIM0_CLK, + GPIO_FN_VI0_DATA0_VI0_B0_B, GPIO_FN_TS_SDEN0_C, GPIO_FN_GLO_SCLK_B, + GPIO_FN_VI3_DATA0_B, GPIO_FN_SD2_CMD, GPIO_FN_MMC0_CMD, GPIO_FN_SIM0_D, + GPIO_FN_VI0_DATA1_VI0_B1_B, GPIO_FN_SCIFB1_SCK_E, GPIO_FN_SCK1_D, + GPIO_FN_TS_SPSYNC0_C, GPIO_FN_GLO_SDATA_B, GPIO_FN_VI3_DATA1_B, + GPIO_FN_SD2_DAT0, GPIO_FN_MMC0_D0, GPIO_FN_FMCLK_B, + GPIO_FN_VI0_DATA2_VI0_B2_B, GPIO_FN_SCIFB1_RXD_E, GPIO_FN_RX1_D, + GPIO_FN_TS_SDAT0_C, GPIO_FN_GLO_SS_B, GPIO_FN_VI3_DATA2_B, + GPIO_FN_SD2_DAT1, GPIO_FN_MMC0_D1, GPIO_FN_FMIN_B, GPIO_FN_RDS_DATA, + GPIO_FN_VI0_DATA3_VI0_B3_B, GPIO_FN_SCIFB1_TXD_E, GPIO_FN_TX1_D, + GPIO_FN_TS_SCK0_C, GPIO_FN_GLO_RFON_B, GPIO_FN_VI3_DATA3_B, + GPIO_FN_SD2_DAT2, GPIO_FN_MMC0_D2, GPIO_FN_BPFCLK_B, GPIO_FN_RDS_CLK, + GPIO_FN_VI0_DATA4_VI0_B4_B, GPIO_FN_HRX0_D, GPIO_FN_TS_SDEN1_B, + GPIO_FN_GLO_Q0_B, GPIO_FN_VI3_DATA4_B, GPIO_FN_SD2_DAT3, + GPIO_FN_MMC0_D3, GPIO_FN_SIM0_RST, GPIO_FN_VI0_DATA5_VI0_B5_B, + GPIO_FN_HTX0_D, GPIO_FN_TS_SPSYNC1_B, GPIO_FN_GLO_Q1_B, + GPIO_FN_VI3_DATA5_B, GPIO_FN_SD2_CD, GPIO_FN_MMC0_D4, + GPIO_FN_TS_SDAT0_B, GPIO_FN_USB2_EXTP, GPIO_FN_GLO_I0, + GPIO_FN_VI0_DATA6_VI0_B6_B, GPIO_FN_HCTS0_N_D, GPIO_FN_TS_SDAT1_B, + GPIO_FN_GLO_I0_B, GPIO_FN_VI3_DATA6_B, + + /* IPSR11 */ + GPIO_FN_SD2_WP, GPIO_FN_MMC0_D5, GPIO_FN_TS_SCK0_B, GPIO_FN_USB2_IDIN, + GPIO_FN_GLO_I1, GPIO_FN_VI0_DATA7_VI0_B7_B, GPIO_FN_HRTS0_N_D, + GPIO_FN_TS_SCK1_B, GPIO_FN_GLO_I1_B, GPIO_FN_VI3_DATA7_B, + GPIO_FN_SD3_CLK, GPIO_FN_MMC1_CLK, GPIO_FN_SD3_CMD, GPIO_FN_MMC1_CMD, + GPIO_FN_MTS_N, GPIO_FN_SD3_DAT0, GPIO_FN_MMC1_D0, GPIO_FN_STM_N, + GPIO_FN_SD3_DAT1, GPIO_FN_MMC1_D1, GPIO_FN_MDATA, GPIO_FN_SD3_DAT2, + GPIO_FN_MMC1_D2, GPIO_FN_SDATA, GPIO_FN_SD3_DAT3, GPIO_FN_MMC1_D3, + GPIO_FN_SCKZ, GPIO_FN_SD3_CD, GPIO_FN_MMC1_D4, GPIO_FN_TS_SDAT1, + GPIO_FN_VSP, GPIO_FN_GLO_Q0, GPIO_FN_SIM0_RST_B, GPIO_FN_SD3_WP, + GPIO_FN_MMC1_D5, GPIO_FN_TS_SCK1, GPIO_FN_GLO_Q1, GPIO_FN_FMIN_C, + GPIO_FN_RDS_DATA_B, GPIO_FN_FMIN_E, GPIO_FN_RDS_DATA_D, GPIO_FN_FMIN_F, + GPIO_FN_RDS_DATA_E, GPIO_FN_MLB_CLK, GPIO_FN_SCL2_B, GPIO_FN_SCL2_CIS_B, + GPIO_FN_MLB_SIG, GPIO_FN_SCIFB1_RXD_D, GPIO_FN_RX1_C, GPIO_FN_SDA2_B, + GPIO_FN_SDA2_CIS_B, GPIO_FN_MLB_DAT, GPIO_FN_SPV_EVEN, + GPIO_FN_SCIFB1_TXD_D, GPIO_FN_TX1_C, GPIO_FN_BPFCLK_C, + GPIO_FN_RDS_CLK_B, GPIO_FN_SSI_SCK0129, GPIO_FN_CAN_CLK_B, + GPIO_FN_MOUT0, + + /* IPSR12 */ + GPIO_FN_SSI_WS0129, GPIO_FN_CAN0_TX_B, GPIO_FN_MOUT1, + GPIO_FN_SSI_SDATA0, GPIO_FN_CAN0_RX_B, GPIO_FN_MOUT2, + GPIO_FN_SSI_SDATA1, GPIO_FN_CAN1_TX_B, GPIO_FN_MOUT5, + GPIO_FN_SSI_SDATA2, GPIO_FN_CAN1_RX_B, GPIO_FN_SSI_SCK1, GPIO_FN_MOUT6, + GPIO_FN_SSI_SCK34, GPIO_FN_STP_OPWM_0, GPIO_FN_SCIFB0_SCK, + GPIO_FN_MSIOF1_SCK, GPIO_FN_CAN_DEBUG_HW_TRIGGER, GPIO_FN_SSI_WS34, + GPIO_FN_STP_IVCXO27_0, GPIO_FN_SCIFB0_RXD, GPIO_FN_MSIOF1_SYNC, + GPIO_FN_CAN_STEP0, GPIO_FN_SSI_SDATA3, GPIO_FN_STP_ISCLK_0, + GPIO_FN_SCIFB0_TXD, GPIO_FN_MSIOF1_SS1, GPIO_FN_CAN_TXCLK, + GPIO_FN_SSI_SCK4, GPIO_FN_STP_ISD_0, GPIO_FN_SCIFB0_CTS_N, + GPIO_FN_MSIOF1_SS2, GPIO_FN_SSI_SCK5_C, GPIO_FN_CAN_DEBUGOUT0, + GPIO_FN_SSI_WS4, GPIO_FN_STP_ISEN_0, GPIO_FN_SCIFB0_RTS_N, + GPIO_FN_MSIOF1_TXD, GPIO_FN_SSI_WS5_C, GPIO_FN_CAN_DEBUGOUT1, + GPIO_FN_SSI_SDATA4, GPIO_FN_STP_ISSYNC_0, GPIO_FN_MSIOF1_RXD, + GPIO_FN_CAN_DEBUGOUT2, GPIO_FN_SSI_SCK5, GPIO_FN_SCIFB1_SCK, + GPIO_FN_IERX_B, GPIO_FN_DU2_EXHSYNC_DU2_HSYNC, GPIO_FN_QSTH_QHS, + GPIO_FN_CAN_DEBUGOUT3, GPIO_FN_SSI_WS5, GPIO_FN_SCIFB1_RXD, + GPIO_FN_IECLK_B, GPIO_FN_DU2_EXVSYNC_DU2_VSYNC, GPIO_FN_QSTB_QHE, + GPIO_FN_CAN_DEBUGOUT4, + + /* IPSR13 */ + GPIO_FN_SSI_SDATA5, GPIO_FN_SCIFB1_TXD, GPIO_FN_IETX_B, GPIO_FN_DU2_DR2, + GPIO_FN_LCDOUT2, GPIO_FN_CAN_DEBUGOUT5, GPIO_FN_SSI_SCK6, + GPIO_FN_SCIFB1_CTS_N, GPIO_FN_BPFCLK_D, GPIO_FN_RDS_CLK_C, + GPIO_FN_DU2_DR3, GPIO_FN_LCDOUT3, GPIO_FN_CAN_DEBUGOUT6, + GPIO_FN_BPFCLK_F, GPIO_FN_RDS_CLK_E, GPIO_FN_SSI_WS6, + GPIO_FN_SCIFB1_RTS_N, GPIO_FN_CAN0_TX_D, GPIO_FN_DU2_DR4, + GPIO_FN_LCDOUT4, GPIO_FN_CAN_DEBUGOUT7, GPIO_FN_SSI_SDATA6, + GPIO_FN_FMIN_D, GPIO_FN_RDS_DATA_C, GPIO_FN_DU2_DR5, GPIO_FN_LCDOUT5, + GPIO_FN_CAN_DEBUGOUT8, GPIO_FN_SSI_SCK78, GPIO_FN_STP_IVCXO27_1, + GPIO_FN_SCK1, GPIO_FN_SCIFA1_SCK, GPIO_FN_DU2_DR6, GPIO_FN_LCDOUT6, + GPIO_FN_CAN_DEBUGOUT9, GPIO_FN_SSI_WS78, GPIO_FN_STP_ISCLK_1, + GPIO_FN_SCIFB2_SCK, GPIO_FN_SCIFA2_CTS_N, GPIO_FN_DU2_DR7, + GPIO_FN_LCDOUT7, GPIO_FN_CAN_DEBUGOUT10, GPIO_FN_SSI_SDATA7, + GPIO_FN_STP_ISD_1, GPIO_FN_SCIFB2_RXD, GPIO_FN_SCIFA2_RTS_N, + GPIO_FN_TCLK2, GPIO_FN_QSTVA_QVS, GPIO_FN_CAN_DEBUGOUT11, + GPIO_FN_BPFCLK_E, GPIO_FN_RDS_CLK_D, GPIO_FN_SSI_SDATA7_B, + GPIO_FN_FMIN_G, GPIO_FN_RDS_DATA_F, GPIO_FN_SSI_SDATA8, + GPIO_FN_STP_ISEN_1, GPIO_FN_SCIFB2_TXD, GPIO_FN_CAN0_TX_C, + GPIO_FN_CAN_DEBUGOUT12, GPIO_FN_SSI_SDATA8_B, GPIO_FN_SSI_SDATA9, + GPIO_FN_STP_ISSYNC_1, GPIO_FN_SCIFB2_CTS_N, GPIO_FN_SSI_WS1, + GPIO_FN_SSI_SDATA5_C, GPIO_FN_CAN_DEBUGOUT13, GPIO_FN_AUDIO_CLKA, + GPIO_FN_SCIFB2_RTS_N, GPIO_FN_CAN_DEBUGOUT14, + + /* IPSR14 */ + GPIO_FN_AUDIO_CLKB, GPIO_FN_SCIF_CLK, GPIO_FN_CAN0_RX_D, + GPIO_FN_DVC_MUTE, GPIO_FN_CAN0_RX_C, GPIO_FN_CAN_DEBUGOUT15, + GPIO_FN_REMOCON, GPIO_FN_SCIFA0_SCK, GPIO_FN_HSCK1, GPIO_FN_SCK0, + GPIO_FN_MSIOF3_SS2, GPIO_FN_DU2_DG2, GPIO_FN_LCDOUT10, GPIO_FN_SDA1_C, + GPIO_FN_SDA1_CIS_C, GPIO_FN_SCIFA0_RXD, GPIO_FN_HRX1, GPIO_FN_RX0, + GPIO_FN_DU2_DR0, GPIO_FN_LCDOUT0, GPIO_FN_SCIFA0_TXD, GPIO_FN_HTX1, + GPIO_FN_TX0, GPIO_FN_DU2_DR1, GPIO_FN_LCDOUT1, GPIO_FN_SCIFA0_CTS_N, + GPIO_FN_HCTS1_N, GPIO_FN_CTS0_N, GPIO_FN_MSIOF3_SYNC, GPIO_FN_DU2_DG3, + GPIO_FN_LCDOUT11, GPIO_FN_PWM0_B, GPIO_FN_SCL1_C, GPIO_FN_SCL1_CIS_C, + GPIO_FN_SCIFA0_RTS_N, GPIO_FN_HRTS1_N, GPIO_FN_RTS0_N_TANS, + GPIO_FN_MSIOF3_SS1, GPIO_FN_DU2_DG0, GPIO_FN_LCDOUT8, GPIO_FN_PWM1_B, + GPIO_FN_SCIFA1_RXD, GPIO_FN_AD_DI, GPIO_FN_RX1, + GPIO_FN_DU2_EXODDF_DU2_ODDF_DISP_CDE, GPIO_FN_QCPV_QDE, + GPIO_FN_SCIFA1_TXD, GPIO_FN_AD_DO, GPIO_FN_TX1, GPIO_FN_DU2_DG1, + GPIO_FN_LCDOUT9, GPIO_FN_SCIFA1_CTS_N, GPIO_FN_AD_CLK, + GPIO_FN_CTS1_N, GPIO_FN_MSIOF3_RXD, GPIO_FN_DU0_DOTCLKOUT, GPIO_FN_QCLK, + GPIO_FN_SCIFA1_RTS_N, GPIO_FN_AD_NCS_N, GPIO_FN_RTS1_N_TANS, + GPIO_FN_MSIOF3_TXD, GPIO_FN_DU1_DOTCLKOUT, GPIO_FN_QSTVB_QVE, + GPIO_FN_HRTS0_N_C, + + /* IPSR15 */ + GPIO_FN_SCIFA2_SCK, GPIO_FN_FMCLK, GPIO_FN_MSIOF3_SCK, GPIO_FN_DU2_DG7, + GPIO_FN_LCDOUT15, GPIO_FN_SCIF_CLK_B, GPIO_FN_SCIFA2_RXD, GPIO_FN_FMIN, + GPIO_FN_DU2_DB0, GPIO_FN_LCDOUT16, GPIO_FN_SCL2, GPIO_FN_SCL2_CIS, + GPIO_FN_SCIFA2_TXD, GPIO_FN_BPFCLK, GPIO_FN_DU2_DB1, GPIO_FN_LCDOUT17, + GPIO_FN_SDA2, GPIO_FN_SDA2_CIS, GPIO_FN_HSCK0, GPIO_FN_TS_SDEN0, + GPIO_FN_DU2_DG4, GPIO_FN_LCDOUT12, GPIO_FN_HCTS0_N_C, GPIO_FN_HRX0, + GPIO_FN_DU2_DB2, GPIO_FN_LCDOUT18, GPIO_FN_HTX0, GPIO_FN_DU2_DB3, + GPIO_FN_LCDOUT19, GPIO_FN_HCTS0_N, GPIO_FN_SSI_SCK9, GPIO_FN_DU2_DB4, + GPIO_FN_LCDOUT20, GPIO_FN_HRTS0_N, GPIO_FN_SSI_WS9, GPIO_FN_DU2_DB5, + GPIO_FN_LCDOUT21, GPIO_FN_MSIOF0_SCK, GPIO_FN_TS_SDAT0, GPIO_FN_ADICLK, + GPIO_FN_DU2_DB6, GPIO_FN_LCDOUT22, GPIO_FN_MSIOF0_SYNC, GPIO_FN_TS_SCK0, + GPIO_FN_SSI_SCK2, GPIO_FN_ADIDATA, GPIO_FN_DU2_DB7, GPIO_FN_LCDOUT23, + GPIO_FN_SCIFA2_RXD_B, GPIO_FN_MSIOF0_SS1, GPIO_FN_ADICHS0, + GPIO_FN_DU2_DG5, GPIO_FN_LCDOUT13, GPIO_FN_MSIOF0_TXD, GPIO_FN_ADICHS1, + GPIO_FN_DU2_DG6, GPIO_FN_LCDOUT14, + + /* IPSR16 */ + GPIO_FN_MSIOF0_SS2, GPIO_FN_AUDIO_CLKOUT, GPIO_FN_ADICHS2, + GPIO_FN_DU2_DISP, GPIO_FN_QPOLA, GPIO_FN_HTX0_C, GPIO_FN_SCIFA2_TXD_B, + GPIO_FN_MSIOF0_RXD, GPIO_FN_TS_SPSYNC0, GPIO_FN_SSI_WS2, + GPIO_FN_ADICS_SAMP, GPIO_FN_DU2_CDE, GPIO_FN_QPOLB, GPIO_FN_HRX0_C, + GPIO_FN_USB1_PWEN, GPIO_FN_AUDIO_CLKOUT_D, GPIO_FN_USB1_OVC, + GPIO_FN_TCLK1_B, +}; + +#endif /* __ASM_R8A7790_H__ */ diff --git a/arch/arm/include/asm/arch-rmobile/r8a7790.h b/arch/arm/include/asm/arch-rmobile/r8a7790.h new file mode 100644 index 0000000..4ade1b5 --- /dev/null +++ b/arch/arm/include/asm/arch-rmobile/r8a7790.h @@ -0,0 +1,598 @@ +/* + * arch/arm/include/asm/arch-rmobile/r8a7790.h + * This file is r8a7790 processor definition. + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __ASM_ARCH_R8A7790_H +#define __ASM_ARCH_R8A7790_H + +/* + * R8A7790 I/O Addresses + */ +#define RWDT_BASE 0xE6020000 +#define SWDT_BASE 0xE6030000 +#define LBSC_BASE 0xFEC00200 +#define DBSC3_0_BASE 0xE6790000 +#define DBSC3_1_BASE 0xE67A0000 +#define TMU_BASE 0xE61E0000 +#define GPIO5_BASE 0xE6055000 + +#define S3C_BASE 0xE6784000 +#define S3C_INT_BASE 0xE6784A00 +#define S3C_MEDIA_BASE 0xE6784B00 + +#define S3C_QOS_DCACHE_BASE 0xE6784BDC +#define S3C_QOS_CCI0_BASE 0xE6784C00 +#define S3C_QOS_CCI1_BASE 0xE6784C24 +#define S3C_QOS_MXI_BASE 0xE6784C48 +#define S3C_QOS_AXI_BASE 0xE6784C6C + +#define DBSC3_0_QOS_R0_BASE 0xE6791000 +#define DBSC3_0_QOS_R1_BASE 0xE6791100 +#define DBSC3_0_QOS_R2_BASE 0xE6791200 +#define DBSC3_0_QOS_R3_BASE 0xE6791300 +#define DBSC3_0_QOS_R4_BASE 0xE6791400 +#define DBSC3_0_QOS_R5_BASE 0xE6791500 +#define DBSC3_0_QOS_R6_BASE 0xE6791600 +#define DBSC3_0_QOS_R7_BASE 0xE6791700 +#define DBSC3_0_QOS_R8_BASE 0xE6791800 +#define DBSC3_0_QOS_R9_BASE 0xE6791900 +#define DBSC3_0_QOS_R10_BASE 0xE6791A00 +#define DBSC3_0_QOS_R11_BASE 0xE6791B00 +#define DBSC3_0_QOS_R12_BASE 0xE6791C00 +#define DBSC3_0_QOS_R13_BASE 0xE6791D00 +#define DBSC3_0_QOS_R14_BASE 0xE6791E00 +#define DBSC3_0_QOS_R15_BASE 0xE6791F00 +#define DBSC3_0_QOS_W0_BASE 0xE6792000 +#define DBSC3_0_QOS_W1_BASE 0xE6792100 +#define DBSC3_0_QOS_W2_BASE 0xE6792200 +#define DBSC3_0_QOS_W3_BASE 0xE6792300 +#define DBSC3_0_QOS_W4_BASE 0xE6792400 +#define DBSC3_0_QOS_W5_BASE 0xE6792500 +#define DBSC3_0_QOS_W6_BASE 0xE6792600 +#define DBSC3_0_QOS_W7_BASE 0xE6792700 +#define DBSC3_0_QOS_W8_BASE 0xE6792800 +#define DBSC3_0_QOS_W9_BASE 0xE6792900 +#define DBSC3_0_QOS_W10_BASE 0xE6792A00 +#define DBSC3_0_QOS_W11_BASE 0xE6792B00 +#define DBSC3_0_QOS_W12_BASE 0xE6792C00 +#define DBSC3_0_QOS_W13_BASE 0xE6792D00 +#define DBSC3_0_QOS_W14_BASE 0xE6792E00 +#define DBSC3_0_QOS_W15_BASE 0xE6792F00 + +#define CCI_400_MAXOT_1 0xF0091110 +#define CCI_400_MAXOT_2 0xF0092110 +#define CCI_400_QOSCNTL_1 0xF009110C +#define CCI_400_QOSCNTL_2 0xF009210C + +#define MXI_BASE 0xFE960000 + +#define SYS_AXI_SYX64TO128_BASE 0xFF800300 +#define SYS_AXI_AVB_BASE 0xFF800340 +#define SYS_AXI_G2D_BASE 0xFF800540 +#define SYS_AXI_IMP0_BASE 0xFF800580 +#define SYS_AXI_IMP1_BASE 0xFF8005C0 +#define SYS_AXI_IMUX0_BASE 0xFF800600 +#define SYS_AXI_IMUX1_BASE 0xFF800640 +#define SYS_AXI_IMUX2_BASE 0xFF800680 +#define SYS_AXI_LBS_BASE 0xFF8006C0 +#define SYS_AXI_MMUDS_BASE 0xFF800700 +#define SYS_AXI_MMUM_BASE 0xFF800740 +#define SYS_AXI_MMUR_BASE 0xFF800780 +#define SYS_AXI_MMUS0_BASE 0xFF8007C0 +#define SYS_AXI_MMUS1_BASE 0xFF800800 +#define SYS_AXI_MTSB0_BASE 0xFF800880 +#define SYS_AXI_MTSB1_BASE 0xFF8008C0 +#define SYS_AXI_PCI_BASE 0xFF800900 +#define SYS_AXI_RTX_BASE 0xFF800940 +#define SYS_AXI_SDS0_BASE 0xFF800A80 +#define SYS_AXI_SDS1_BASE 0xFF800AC0 +#define SYS_AXI_USB20_BASE 0xFF800C00 +#define SYS_AXI_USB21_BASE 0xFF800C40 +#define SYS_AXI_USB22_BASE 0xFF800C80 +#define SYS_AXI_USB30_BASE 0xFF800CC0 + +#define RT_AXI_SHX_BASE 0xFF810100 +#define RT_AXI_RDS_BASE 0xFF8101C0 +#define RT_AXI_RTX64TO128_BASE 0xFF810200 +#define RT_AXI_STPRO_BASE 0xFF810240 + +#define MP_AXI_ADSP_BASE 0xFF820100 +#define MP_AXI_ASDS0_BASE 0xFF8201C0 +#define MP_AXI_ASDS1_BASE 0xFF820200 +#define MP_AXI_MLP_BASE 0xFF820240 +#define MP_AXI_MMUMP_BASE 0xFF820280 +#define MP_AXI_SPU_BASE 0xFF8202C0 +#define MP_AXI_SPUC_BASE 0xFF820300 + +#define SYS_AXI256_AXI128TO256_BASE 0xFF860100 +#define SYS_AXI256_SYX_BASE 0xFF860140 +#define SYS_AXI256_MPX_BASE 0xFF860180 +#define SYS_AXI256_MXI_BASE 0xFF8601C0 + +#define CCI_AXI_MMUS0_BASE 0xFF880100 +#define CCI_AXI_SYX2_BASE 0xFF880140 +#define CCI_AXI_MMUR_BASE 0xFF880180 +#define CCI_AXI_MMUDS_BASE 0xFF8801C0 +#define CCI_AXI_MMUM_BASE 0xFF880200 +#define CCI_AXI_MXI_BASE 0xFF880240 +#define CCI_AXI_MMUS1_BASE 0xFF880280 +#define CCI_AXI_MMUMP_BASE 0xFF8802C0 + +#define MEDIA_AXI_JPR_BASE 0xFE964100 +#define MEDIA_AXI_JPW_BASE 0xFE966100 +#define MEDIA_AXI_GCU0R_BASE 0xFE964140 +#define MEDIA_AXI_GCU0W_BASE 0xFE966140 +#define MEDIA_AXI_GCU1R_BASE 0xFE964180 +#define MEDIA_AXI_GCU1W_BASE 0xFE966180 +#define MEDIA_AXI_TDMR_BASE 0xFE964500 +#define MEDIA_AXI_TDMW_BASE 0xFE966500 +#define MEDIA_AXI_VSP0CR_BASE 0xFE964540 +#define MEDIA_AXI_VSP0CW_BASE 0xFE966540 +#define MEDIA_AXI_VSP1CR_BASE 0xFE964580 +#define MEDIA_AXI_VSP1CW_BASE 0xFE966580 +#define MEDIA_AXI_VSPDU0CR_BASE 0xFE9645C0 +#define MEDIA_AXI_VSPDU0CW_BASE 0xFE9665C0 +#define MEDIA_AXI_VSPDU1CR_BASE 0xFE964600 +#define MEDIA_AXI_VSPDU1CW_BASE 0xFE966600 +#define MEDIA_AXI_VIN0W_BASE 0xFE966900 +#define MEDIA_AXI_VSP0R_BASE 0xFE964D00 +#define MEDIA_AXI_VSP0W_BASE 0xFE966D00 +#define MEDIA_AXI_FDP0R_BASE 0xFE964D40 +#define MEDIA_AXI_FDP0W_BASE 0xFE966D40 +#define MEDIA_AXI_IMSR_BASE 0xFE964D80 +#define MEDIA_AXI_IMSW_BASE 0xFE966D80 +#define MEDIA_AXI_VSP1R_BASE 0xFE965100 +#define MEDIA_AXI_VSP1W_BASE 0xFE967100 +#define MEDIA_AXI_FDP1R_BASE 0xFE965140 +#define MEDIA_AXI_FDP1W_BASE 0xFE967140 +#define MEDIA_AXI_IMRR_BASE 0xFE965180 +#define MEDIA_AXI_IMRW_BASE 0xFE967180 +#define MEDIA_AXI_FDP2R_BASE 0xFE9651C0 +#define MEDIA_AXI_FDP2W_BASE 0xFE966DC0 +#define MEDIA_AXI_VSPD0R_BASE 0xFE965500 +#define MEDIA_AXI_VSPD0W_BASE 0xFE967500 +#define MEDIA_AXI_VSPD1R_BASE 0xFE965540 +#define MEDIA_AXI_VSPD1W_BASE 0xFE967540 +#define MEDIA_AXI_DU0R_BASE 0xFE965580 +#define MEDIA_AXI_DU0W_BASE 0xFE967580 +#define MEDIA_AXI_DU1R_BASE 0xFE9655C0 +#define MEDIA_AXI_DU1W_BASE 0xFE9675C0 +#define MEDIA_AXI_VCP0CR_BASE 0xFE965900 +#define MEDIA_AXI_VCP0CW_BASE 0xFE967900 +#define MEDIA_AXI_VCP0VR_BASE 0xFE965940 +#define MEDIA_AXI_VCP0VW_BASE 0xFE967940 +#define MEDIA_AXI_VPC0R_BASE 0xFE965980 +#define MEDIA_AXI_VCP1CR_BASE 0xFE965D00 +#define MEDIA_AXI_VCP1CW_BASE 0xFE967D00 +#define MEDIA_AXI_VCP1VR_BASE 0xFE965D40 +#define MEDIA_AXI_VCP1VW_BASE 0xFE967D40 +#define MEDIA_AXI_VPC1R_BASE 0xFE965D80 + +#define SYS_AXI_AVBDMSCR 0xFF802000 +#define SYS_AXI_SYX2DMSCR 0xFF802004 +#define SYS_AXI_CC50DMSCR 0xFF802008 +#define SYS_AXI_CC51DMSCR 0xFF80200C +#define SYS_AXI_CCIDMSCR 0xFF802010 +#define SYS_AXI_CSDMSCR 0xFF802014 +#define SYS_AXI_DDMDMSCR 0xFF802018 +#define SYS_AXI_ETHDMSCR 0xFF80201C +#define SYS_AXI_G2DDMSCR 0xFF802020 +#define SYS_AXI_IMP0DMSCR 0xFF802024 +#define SYS_AXI_IMP1DMSCR 0xFF802028 +#define SYS_AXI_LBSDMSCR 0xFF80202C +#define SYS_AXI_MMUDSDMSCR 0xFF802030 +#define SYS_AXI_MMUMXDMSCR 0xFF802034 +#define SYS_AXI_MMURDDMSCR 0xFF802038 +#define SYS_AXI_MMUS0DMSCR 0xFF80203C +#define SYS_AXI_MMUS1DMSCR 0xFF802040 +#define SYS_AXI_MPXDMSCR 0xFF802044 +#define SYS_AXI_MTSB0DMSCR 0xFF802048 +#define SYS_AXI_MTSB1DMSCR 0xFF80204C +#define SYS_AXI_PCIDMSCR 0xFF802050 +#define SYS_AXI_RTXDMSCR 0xFF802054 +#define SYS_AXI_SAT0DMSCR 0xFF802058 +#define SYS_AXI_SAT1DMSCR 0xFF80205C +#define SYS_AXI_SDM0DMSCR 0xFF802060 +#define SYS_AXI_SDM1DMSCR 0xFF802064 +#define SYS_AXI_SDS0DMSCR 0xFF802068 +#define SYS_AXI_SDS1DMSCR 0xFF80206C +#define SYS_AXI_ETRABDMSCR 0xFF802070 +#define SYS_AXI_ETRKFDMSCR 0xFF802074 +#define SYS_AXI_UDM0DMSCR 0xFF802078 +#define SYS_AXI_UDM1DMSCR 0xFF80207C +#define SYS_AXI_USB20DMSCR 0xFF802080 +#define SYS_AXI_USB21DMSCR 0xFF802084 +#define SYS_AXI_USB22DMSCR 0xFF802088 +#define SYS_AXI_USB30DMSCR 0xFF80208C +#define SYS_AXI_X128TO64SLVDMSCR 0xFF802100 +#define SYS_AXI_X64TO128SLVDMSCR 0xFF802104 +#define SYS_AXI_AVBSLVDMSCR 0xFF802108 +#define SYS_AXI_SYX2SLVDMSCR 0xFF80210C +#define SYS_AXI_ETHSLVDMSCR 0xFF802110 +#define SYS_AXI_GICSLVDMSCR 0xFF802114 +#define SYS_AXI_IMPSLVDMSCR 0xFF802118 +#define SYS_AXI_IMX0SLVDMSCR 0xFF80211C +#define SYS_AXI_IMX1SLVDMSCR 0xFF802120 +#define SYS_AXI_IMX2SLVDMSCR 0xFF802124 +#define SYS_AXI_LBSSLVDMSCR 0xFF802128 +#define SYS_AXI_MMC0SLVDMSCR 0xFF80212C +#define SYS_AXI_MMC1SLVDMSCR 0xFF802130 +#define SYS_AXI_MPXSLVDMSCR 0xFF802134 +#define SYS_AXI_MTSB0SLVDMSCR 0xFF802138 +#define SYS_AXI_MTSB1SLVDMSCR 0xFF80213C +#define SYS_AXI_MXTSLVDMSCR 0xFF802140 +#define SYS_AXI_PCISLVDMSCR 0xFF802144 +#define SYS_AXI_SYAPBSLVDMSCR 0xFF802148 +#define SYS_AXI_QSAPBSLVDMSCR 0xFF80214C +#define SYS_AXI_RTXSLVDMSCR 0xFF802150 +#define SYS_AXI_SAT0SLVDMSCR 0xFF802168 +#define SYS_AXI_SAT1SLVDMSCR 0xFF80216C +#define SYS_AXI_SDAP0SLVDMSCR 0xFF802170 +#define SYS_AXI_SDAP1SLVDMSCR 0xFF802174 +#define SYS_AXI_SDAP2SLVDMSCR 0xFF802178 +#define SYS_AXI_SDAP3SLVDMSCR 0xFF80217C +#define SYS_AXI_SGXSLVDMSCR 0xFF802180 +#define SYS_AXI_STBSLVDMSCR 0xFF802188 +#define SYS_AXI_STMSLVDMSCR 0xFF80218C +#define SYS_AXI_TSPL0SLVDMSCR 0xFF802194 +#define SYS_AXI_TSPL1SLVDMSCR 0xFF802198 +#define SYS_AXI_TSPL2SLVDMSCR 0xFF80219C +#define SYS_AXI_USB20SLVDMSCR 0xFF8021A0 +#define SYS_AXI_USB21SLVDMSCR 0xFF8021A4 +#define SYS_AXI_USB22SLVDMSCR 0xFF8021A8 +#define SYS_AXI_USB30SLVDMSCR 0xFF8021AC + +#define RT_AXI_CBMDMSCR 0xFF812000 +#define RT_AXI_DBDMSCR 0xFF812004 +#define RT_AXI_RDMDMSCR 0xFF812008 +#define RT_AXI_RDSDMSCR 0xFF81200C +#define RT_AXI_STRDMSCR 0xFF812010 +#define RT_AXI_SY2RTDMSCR 0xFF812014 +#define RT_AXI_CBSSLVDMSCR 0xFF812100 +#define RT_AXI_DBSSLVDMSCR 0xFF812104 +#define RT_AXI_RTAP1SLVDMSCR 0xFF812108 +#define RT_AXI_RTAP2SLVDMSCR 0xFF81210C +#define RT_AXI_RTAP3SLVDMSCR 0xFF812110 +#define RT_AXI_RT2SYSLVDMSCR 0xFF812114 +#define RT_AXI_A128TO64SLVDMSCR 0xFF812118 +#define RT_AXI_A64TO128SLVDMSCR 0xFF81211C +#define RT_AXI_A64TO128CSLVDMSCR 0xFF812120 +#define RT_AXI_UTLBRSLVDMSCR 0xFF812128 + +#define MP_AXI_ADSPDMSCR 0xFF822000 +#define MP_AXI_ASDM0DMSCR 0xFF822004 +#define MP_AXI_ASDM1DMSCR 0xFF822008 +#define MP_AXI_ASDS0DMSCR 0xFF82200C +#define MP_AXI_ASDS1DMSCR 0xFF822010 +#define MP_AXI_MLPDMSCR 0xFF822014 +#define MP_AXI_MMUMPDMSCR 0xFF822018 +#define MP_AXI_SPUDMSCR 0xFF82201C +#define MP_AXI_SPUCDMSCR 0xFF822020 +#define MP_AXI_SY2MPDMSCR 0xFF822024 +#define MP_AXI_ADSPSLVDMSCR 0xFF822100 +#define MP_AXI_MLMSLVDMSCR 0xFF822104 +#define MP_AXI_MPAP4SLVDMSCR 0xFF822108 +#define MP_AXI_MPAP5SLVDMSCR 0xFF82210C +#define MP_AXI_MPAP6SLVDMSCR 0xFF822110 +#define MP_AXI_MPAP7SLVDMSCR 0xFF822114 +#define MP_AXI_MP2SYSLVDMSCR 0xFF822118 +#define MP_AXI_MP2SY2SLVDMSCR 0xFF82211C +#define MP_AXI_MPXAPSLVDMSCR 0xFF822124 +#define MP_AXI_SPUSLVDMSCR 0xFF822128 +#define MP_AXI_UTLBMPSLVDMSCR 0xFF82212C + +#define ADM_AXI_ASDM0DMSCR 0xFF842000 +#define ADM_AXI_ASDM1DMSCR 0xFF842004 +#define ADM_AXI_MPAP1SLVDMSCR 0xFF842104 +#define ADM_AXI_MPAP2SLVDMSCR 0xFF842108 +#define ADM_AXI_MPAP3SLVDMSCR 0xFF84210C + +#define DM_AXI_RDMDMSCR 0xFF852000 +#define DM_AXI_SDM0DMSCR 0xFF852004 +#define DM_AXI_SDM1DMSCR 0xFF852008 +#define DM_AXI_MMAP0SLVDMSCR 0xFF852100 +#define DM_AXI_MMAP1SLVDMSCR 0xFF852104 +#define DM_AXI_QSPAPSLVDMSCR 0xFF852108 +#define DM_AXI_RAP4SLVDMSCR 0xFF85210C +#define DM_AXI_RAP5SLVDMSCR 0xFF852110 +#define DM_AXI_SAP4SLVDMSCR 0xFF852114 +#define DM_AXI_SAP5SLVDMSCR 0xFF852118 +#define DM_AXI_SAP6SLVDMSCR 0xFF85211C +#define DM_AXI_SAP65SLVDMSCR 0xFF852120 +#define DM_AXI_SDAP0SLVDMSCR 0xFF852124 +#define DM_AXI_SDAP1SLVDMSCR 0xFF852128 +#define DM_AXI_SDAP2SLVDMSCR 0xFF85212C +#define DM_AXI_SDAP3SLVDMSCR 0xFF852130 + +#define SYS_AXI256_SYXDMSCR 0xFF862000 +#define SYS_AXI256_MPXDMSCR 0xFF862004 +#define SYS_AXI256_MXIDMSCR 0xFF862008 +#define SYS_AXI256_X128TO256SLVDMSCR 0xFF862100 +#define SYS_AXI256_X256TO128SLVDMSCR 0xFF862104 +#define SYS_AXI256_SYXSLVDMSCR 0xFF862108 +#define SYS_AXI256_CCXSLVDMSCR 0xFF86210C +#define SYS_AXI256_S3CSLVDMSCR 0xFF862110 + +#define MXT_SYXDMSCR 0xFF872000 +#define MXT_CMM0SLVDMSCR 0xFF872100 +#define MXT_CMM1SLVDMSCR 0xFF872104 +#define MXT_CMM2SLVDMSCR 0xFF872108 +#define MXT_FDPSLVDMSCR 0xFF87210C +#define MXT_IMRSLVDMSCR 0xFF872110 +#define MXT_VINSLVDMSCR 0xFF872114 +#define MXT_VPC0SLVDMSCR 0xFF872118 +#define MXT_VPC1SLVDMSCR 0xFF87211C +#define MXT_VSP0SLVDMSCR 0xFF872120 +#define MXT_VSP1SLVDMSCR 0xFF872124 +#define MXT_VSPD0SLVDMSCR 0xFF872128 +#define MXT_VSPD1SLVDMSCR 0xFF87212C +#define MXT_MAP1SLVDMSCR 0xFF872130 +#define MXT_MAP2SLVDMSCR 0xFF872134 + +#define CCI_AXI_MMUS0DMSCR 0xFF882000 +#define CCI_AXI_SYX2DMSCR 0xFF882004 +#define CCI_AXI_MMURDMSCR 0xFF882008 +#define CCI_AXI_MMUDSDMSCR 0xFF88200C +#define CCI_AXI_MMUMDMSCR 0xFF882010 +#define CCI_AXI_MXIDMSCR 0xFF882014 +#define CCI_AXI_MMUS1DMSCR 0xFF882018 +#define CCI_AXI_MMUMPDMSCR 0xFF88201C +#define CCI_AXI_DVMDMSCR 0xFF882020 +#define CCI_AXI_CCISLVDMSCR 0xFF882100 + +#define CCI_AXI_IPMMUIDVMCR 0xFF880400 +#define CCI_AXI_IPMMURDVMCR 0xFF880404 +#define CCI_AXI_IPMMUS0DVMCR 0xFF880408 +#define CCI_AXI_IPMMUS1DVMCR 0xFF88040C +#define CCI_AXI_IPMMUMPDVMCR 0xFF880410 +#define CCI_AXI_IPMMUDSDVMCR 0xFF880414 +#define CCI_AXI_AX2ADDRMASK 0xFF88041C + +#ifndef __ASSEMBLY__ +#include <asm/types.h> + +/* RWDT */ +struct r8a7790_rwdt { + u32 rwtcnt; /* 0x00 */ + u32 rwtcsra; /* 0x04 */ + u16 rwtcsrb; /* 0x08 */ +}; + +/* SWDT */ +struct r8a7790_swdt { + u32 swtcnt; /* 0x00 */ + u32 swtcsra; /* 0x04 */ + u16 swtcsrb; /* 0x08 */ +}; + +/* LBSC */ +struct r8a7790_lbsc { + u32 cs0ctrl; + u32 cs1ctrl; + u32 ecs0ctrl; + u32 ecs1ctrl; + u32 ecs2ctrl; + u32 ecs3ctrl; + u32 ecs4ctrl; + u32 ecs5ctrl; + u32 dummy0[4]; /* 0x20 .. 0x2C */ + u32 cswcr0; + u32 cswcr1; + u32 ecswcr0; + u32 ecswcr1; + u32 ecswcr2; + u32 ecswcr3; + u32 ecswcr4; + u32 ecswcr5; + u32 exdmawcr0; + u32 exdmawcr1; + u32 exdmawcr2; + u32 dummy1[9]; /* 0x5C .. 0x7C */ + u32 cspwcr0; + u32 cspwcr1; + u32 ecspwcr0; + u32 ecspwcr1; + u32 ecspwcr2; + u32 ecspwcr3; + u32 ecspwcr4; + u32 ecspwcr5; + u32 exwtsync; + u32 dummy2[3]; /* 0xA4 .. 0xAC */ + u32 cs0bstctl; + u32 cs0btph; + u32 dummy3[2]; /* 0xB8 .. 0xBC */ + u32 cs1gdst; + u32 ecs0gdst; + u32 ecs1gdst; + u32 ecs2gdst; + u32 ecs3gdst; + u32 ecs4gdst; + u32 ecs5gdst; + u32 dummy4[5]; /* 0xDC .. 0xEC */ + u32 exdmaset0; + u32 exdmaset1; + u32 exdmaset2; + u32 dummy5[5]; /* 0xFC .. 0x10C */ + u32 exdmcr0; + u32 exdmcr1; + u32 exdmcr2; + u32 dummy6[5]; /* 0x11C .. 0x12C */ + u32 bcintsr; + u32 bcintcr; + u32 bcintmr; + u32 dummy7; /* 0x13C */ + u32 exbatlv; + u32 exwtsts; + u32 dummy8[14]; /* 0x148 .. 0x17C */ + u32 atacsctrl; + u32 dummy9[15]; /* 0x184 .. 0x1BC */ + u32 exbct; + u32 extct; +}; + +/* DBSC3 */ +struct r8a7790_dbsc3 { + u32 dummy0[3]; /* 0x00 .. 0x08 */ + u32 dbstate1; + u32 dbacen; + u32 dbrfen; + u32 dbcmd; + u32 dbwait; + u32 dbkind; + u32 dbconf0; + u32 dummy1[2]; /* 0x28 .. 0x2C */ + u32 dbphytype; + u32 dummy2[3]; /* 0x34 .. 0x3C */ + u32 dbtr0; + u32 dbtr1; + u32 dbtr2; + u32 dummy3; /* 0x4C */ + u32 dbtr3; + u32 dbtr4; + u32 dbtr5; + u32 dbtr6; + u32 dbtr7; + u32 dbtr8; + u32 dbtr9; + u32 dbtr10; + u32 dbtr11; + u32 dbtr12; + u32 dbtr13; + u32 dbtr14; + u32 dbtr15; + u32 dbtr16; + u32 dbtr17; + u32 dbtr18; + u32 dbtr19; + u32 dummy4[7]; /* 0x94 .. 0xAC */ + u32 dbbl; + u32 dummy5[3]; /* 0xB4 .. 0xBC */ + u32 dbadj0; + u32 dummy6; /* 0xC4 */ + u32 dbadj2; + u32 dummy7[5]; /* 0xCC .. 0xDC */ + u32 dbrfcnf0; + u32 dbrfcnf1; + u32 dbrfcnf2; + u32 dummy8[2]; /* 0xEC .. 0xF0 */ + u32 dbcalcnf; + u32 dbcaltr; + u32 dummy9; /* 0xFC */ + u32 dbrnk0; + u32 dummy10[31]; /* 0x104 .. 0x17C */ + u32 dbpdncnf; + u32 dummy11[47]; /* 0x184 ..0x23C */ + u32 dbdfistat; + u32 dbdficnt; + u32 dummy12[14]; /* 0x248 .. 0x27C */ + u32 dbpdlck; + u32 dummy13[3]; /* 0x284 .. 0x28C */ + u32 dbpdrga; + u32 dummy14[3]; /* 0x294 .. 0x29C */ + u32 dbpdrgd; + u32 dummy15[24]; /* 0x2A4 .. 0x300 */ + u32 dbbs0cnt1; + u32 dummy16[30]; /* 0x308 .. 0x37C */ + u32 dbwt0cnf0; + u32 dbwt0cnf1; + u32 dbwt0cnf2; + u32 dbwt0cnf3; + u32 dbwt0cnf4; +}; + +/* GPIO */ +struct r8a7790_gpio { + u32 iointsel; + u32 inoutsel; + u32 outdt; + u32 indt; + u32 intdt; + u32 intclr; + u32 intmsk; + u32 posneg; + u32 edglevel; + u32 filonoff; + u32 intmsks; + u32 mskclrs; + u32 outdtsel; + u32 outdth; + u32 outdtl; + u32 bothedge; +}; + +/* S3C(QoS) */ +struct r8a7790_s3c { + u32 s3cexcladdmsk; + u32 s3cexclidmsk; + u32 s3cadsplcr; + u32 s3cmaar; + u32 dummy0; /* 0x10 */ + u32 s3crorr; + u32 s3cworr; + u32 s3carcr22; + u32 dummy1[2]; /* 0x20 .. 0x24 */ + u32 s3cmctr; + u32 dummy2; /* 0x2C */ + u32 cconf0; + u32 cconf1; + u32 cconf2; + u32 cconf3; +}; + +struct r8a7790_s3c_qos { + u32 s3cqos0; + u32 s3cqos1; + u32 s3cqos2; + u32 s3cqos3; + u32 s3cqos4; + u32 s3cqos5; + u32 s3cqos6; + u32 s3cqos7; + u32 s3cqos8; +}; + +/* DBSC(QoS) */ +struct r8a7790_dbsc3_qos { + u32 dblgcnt; + u32 dbtmval0; + u32 dbtmval1; + u32 dbtmval2; + u32 dbtmval3; + u32 dbrqctr; + u32 dbthres0; + u32 dbthres1; + u32 dbthres2; + u32 dblgqon; +}; + +/* MXI(QoS) */ +struct r8a7790_mxi { + u32 dummy0[10]; /* 0x00 .. 0x24 */ + u32 mxs3cracr; + u32 dummy1[5]; /* 0x2C .. 0x3C */ + u32 mxrtcr; + u32 mxwtcr; +}; + +/* AXI(QoS) */ +struct r8a7790_axi_qos { + u32 qosconf; + u32 qosctset0; + u32 qosctset1; + u32 qosctset2; + u32 qosctset3; + u32 qosreqctr; + u32 qosthres0; + u32 qosthres1; + u32 qosthres2; + u32 qosqon; +}; + +#endif + +#endif /* __ASM_ARCH_R8A7790_H */ diff --git a/arch/arm/include/asm/arch-rmobile/rmobile.h b/arch/arm/include/asm/arch-rmobile/rmobile.h index ac17561..ab39f67 100644 --- a/arch/arm/include/asm/arch-rmobile/rmobile.h +++ b/arch/arm/include/asm/arch-rmobile/rmobile.h @@ -6,6 +6,8 @@ #include <asm/arch/sh73a0.h> #elif defined(CONFIG_R8A7740) #include <asm/arch/r8a7740.h> +#elif defined(CONFIG_R8A7790) +#include <asm/arch/r8a7790.h> #else #error "SOC Name not defined" #endif
The lager board has R8A7790, 2GB DDR3-SDRAM, USB, Ethernet, and more.
This patch supports the following functions: - DDR3-SDRAM - SCIF - QSPI - Ethernet
Signed-off-by: Kouei Abe kouei.abe.cp@renesas.com Signed-off-by: Hisashi Nakamura hisashi.nakamura.ak@renesas.com Signed-off-by: Ryo Kataoka ryo.kataoka.wt@renesas.com Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/arm/include/asm/mach-types.h | 13 + board/renesas/lager/Makefile | 35 ++ board/renesas/lager/lager.c | 357 ++++++++++++ board/renesas/lager/qos.c | 1112 +++++++++++++++++++++++++++++++++++++ board/renesas/lager/qos.h | 12 + boards.cfg | 2 + include/configs/lager.h | 186 +++++++ 7 files changed, 1717 insertions(+) create mode 100644 board/renesas/lager/Makefile create mode 100644 board/renesas/lager/lager.c create mode 100644 board/renesas/lager/qos.c create mode 100644 board/renesas/lager/qos.h create mode 100644 include/configs/lager.h
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 440b041..67b88ad 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -1106,6 +1106,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_OMAP5_SEVM 3777 #define MACH_TYPE_ARMADILLO_800EVA 3863 #define MACH_TYPE_KZM9G 4140 +#define MACH_TYPE_LAGER 4538
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -14235,6 +14236,18 @@ extern unsigned int __machine_arch_type; # define machine_is_kzm9g() (0) #endif
+#ifdef CONFIG_MACH_LAGER +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_LAGER +# endif +# define machine_is_lager() (machine_arch_type == MACH_TYPE_LAGER) +#else +# define machine_is_lager() (0) +#endif + /* * These have not yet been registered */ diff --git a/board/renesas/lager/Makefile b/board/renesas/lager/Makefile new file mode 100644 index 0000000..acf2ebe --- /dev/null +++ b/board/renesas/lager/Makefile @@ -0,0 +1,35 @@ +# +# board/renesas/lager/Makefile +# +# Copyright (C) 2013 Renesas Electronics Corporation +# +# SPDX-License-Identifier: GPL-2.0 +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := lager.o qos.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/renesas/lager/lager.c b/board/renesas/lager/lager.c new file mode 100644 index 0000000..ba923d5 --- /dev/null +++ b/board/renesas/lager/lager.c @@ -0,0 +1,357 @@ +/* + * board/renesas/lager/lager.c + * This file is lager board support. + * + * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <netdev.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/arch/rmobile.h> +#include <miiphy.h> +#include "qos.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define s_init_wait(cnt) \ + ({ \ + u32 i = 0x10000 * cnt; \ + while (i > 0) \ + i--; \ + }) + +#define dbpdrgd_check(bsc) \ + ({ \ + while ((readl(&bsc->dbpdrgd) & 0x1) != 0x1) \ + ; \ + }) + +#if defined(CONFIG_NORFLASH) +static void bsc_init(void) +{ + struct r8a7790_lbsc *lbsc = (struct r8a7790_lbsc *)LBSC_BASE; + struct r8a7790_dbsc3 *dbsc3_0 = (struct r8a7790_dbsc3 *)DBSC3_0_BASE; + + /* LBSC */ + writel(0x00000020, &lbsc->cs0ctrl); + writel(0x00000020, &lbsc->cs1ctrl); + writel(0x00002020, &lbsc->ecs0ctrl); + writel(0x00002020, &lbsc->ecs1ctrl); + + writel(0x077F077F, &lbsc->cswcr0); + writel(0x077F077F, &lbsc->cswcr1); + writel(0x077F077F, &lbsc->ecswcr0); + writel(0x077F077F, &lbsc->ecswcr1); + + /* DBSC3 */ + s_init_wait(10); + + writel(0x0000A55A, &dbsc3_0->dbpdlck); + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x80000000, &dbsc3_0->dbpdrgd); + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000006, &dbsc3_0->dbpdrga); + writel(0x0001C000, &dbsc3_0->dbpdrgd); + + writel(0x00000023, &dbsc3_0->dbpdrga); + writel(0x00FD2480, &dbsc3_0->dbpdrgd); + + writel(0x00000010, &dbsc3_0->dbpdrga); + writel(0xF004649B, &dbsc3_0->dbpdrgd); + + writel(0x0000000F, &dbsc3_0->dbpdrga); + writel(0x00181EE4, &dbsc3_0->dbpdrgd); + + writel(0x0000000E, &dbsc3_0->dbpdrga); + writel(0x33C03812, &dbsc3_0->dbpdrgd); + + writel(0x00000003, &dbsc3_0->dbpdrga); + writel(0x0300C481, &dbsc3_0->dbpdrgd); + + writel(0x00000007, &dbsc3_0->dbkind); + writel(0x10030A02, &dbsc3_0->dbconf0); + writel(0x00000001, &dbsc3_0->dbphytype); + writel(0x00000000, &dbsc3_0->dbbl); + writel(0x0000000B, &dbsc3_0->dbtr0); + writel(0x00000008, &dbsc3_0->dbtr1); + writel(0x00000000, &dbsc3_0->dbtr2); + writel(0x0000000B, &dbsc3_0->dbtr3); + writel(0x000C000B, &dbsc3_0->dbtr4); + writel(0x00000027, &dbsc3_0->dbtr5); + writel(0x0000001C, &dbsc3_0->dbtr6); + writel(0x00000005, &dbsc3_0->dbtr7); + writel(0x00000018, &dbsc3_0->dbtr8); + writel(0x00000008, &dbsc3_0->dbtr9); + writel(0x0000000C, &dbsc3_0->dbtr10); + writel(0x00000009, &dbsc3_0->dbtr11); + writel(0x00000012, &dbsc3_0->dbtr12); + writel(0x000000D0, &dbsc3_0->dbtr13); + writel(0x00140005, &dbsc3_0->dbtr14); + writel(0x00050004, &dbsc3_0->dbtr15); + writel(0x70233005, &dbsc3_0->dbtr16); + writel(0x000C0000, &dbsc3_0->dbtr17); + writel(0x00000300, &dbsc3_0->dbtr18); + writel(0x00000040, &dbsc3_0->dbtr19); + writel(0x00000001, &dbsc3_0->dbrnk0); + writel(0x00020001, &dbsc3_0->dbadj0); + writel(0x20082008, &dbsc3_0->dbadj2); + writel(0x00020002, &dbsc3_0->dbwt0cnf0); + writel(0x0000000F, &dbsc3_0->dbwt0cnf4); + + writel(0x00000015, &dbsc3_0->dbpdrga); + writel(0x00000D70, &dbsc3_0->dbpdrgd); + + writel(0x00000016, &dbsc3_0->dbpdrga); + writel(0x00000006, &dbsc3_0->dbpdrgd); + + writel(0x00000017, &dbsc3_0->dbpdrga); + writel(0x00000018, &dbsc3_0->dbpdrgd); + + writel(0x00000012, &dbsc3_0->dbpdrga); + writel(0x9D5CBB66, &dbsc3_0->dbpdrgd); + + writel(0x00000013, &dbsc3_0->dbpdrga); + writel(0x1A868300, &dbsc3_0->dbpdrgd); + + writel(0x00000023, &dbsc3_0->dbpdrga); + writel(0x00FDB6C0, &dbsc3_0->dbpdrgd); + + writel(0x00000014, &dbsc3_0->dbpdrga); + writel(0x300214D8, &dbsc3_0->dbpdrgd); + + writel(0x0000001A, &dbsc3_0->dbpdrga); + writel(0x930035C7, &dbsc3_0->dbpdrgd); + + writel(0x00000060, &dbsc3_0->dbpdrga); + writel(0x330657B2, &dbsc3_0->dbpdrgd); + + writel(0x00000011, &dbsc3_0->dbpdrga); + writel(0x1000040B, &dbsc3_0->dbpdrgd); + + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x00000071, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x2100FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + writel(0x0000FA00, &dbsc3_0->dbcmd); + + writel(0x110000DB, &dbsc3_0->dbcmd); + + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x00000181, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000001, &dbsc3_0->dbpdrga); + writel(0x0000FE01, &dbsc3_0->dbpdrgd); + + writel(0x00000004, &dbsc3_0->dbpdrga); + dbpdrgd_check(dbsc3_0); + + writel(0x00000000, &dbsc3_0->dbbs0cnt1); + writel(0x01004C20, &dbsc3_0->dbcalcnf); + writel(0x014000AA, &dbsc3_0->dbcaltr); + writel(0x00000140, &dbsc3_0->dbrfcnf0); + writel(0x00081860, &dbsc3_0->dbrfcnf1); + writel(0x00010000, &dbsc3_0->dbrfcnf2); + writel(0x00000001, &dbsc3_0->dbrfen); + writel(0x00000001, &dbsc3_0->dbacen); +} +#else +#define bsc_init() do {} while (0) +#endif /* CONFIG_NORFLASH */ + +void s_init(void) +{ + struct r8a7790_rwdt *rwdt = (struct r8a7790_rwdt *)RWDT_BASE; + struct r8a7790_swdt *swdt = (struct r8a7790_swdt *)SWDT_BASE; + + /* Watchdog init */ + writel(0xA5A5A500, &rwdt->rwtcsra); + writel(0xA5A5A500, &swdt->swtcsra); + + /* QoS(Quality-of-Service) Init */ + qos_init(); + + /* BSC init */ + bsc_init(); +} + +#define MSTPSR1 0xE6150038 +#define SMSTPCR1 0xE6150134 +#define TMU0_MSTP125 (1 << 25) + +#define MSTPSR7 0xE61501C4 +#define SMSTPCR7 0xE615014C +#define SCIF0_MSTP721 (1 << 21) + +#define MSTPSR8 0xE61509A0 +#define SMSTPCR8 0xE6150990 +#define ETHER_MSTP813 (1 << 13) + +#define PMMR 0xE6060000 +#define GPSR4 0xE6060014 +#define IPSR14 0xE6060058 + +#define set_guard_reg(addr, mask, value) \ +{ \ + u32 val; \ + val = (readl(addr) & ~(mask)) | (value); \ + writel(~val, PMMR); \ + writel(val, addr); \ +} + +#define mstp_setbits(type, addr, saddr, set) \ + out_##type((saddr), in_##type(addr) | (set)) +#define mstp_clrbits(type, addr, saddr, clear) \ + out_##type((saddr), in_##type(addr) & ~(clear)) +#define mstp_setbits_le32(addr, saddr, set) \ + mstp_setbits(le32, addr, saddr, set) +#define mstp_clrbits_le32(addr, saddr, clear) \ + mstp_clrbits(le32, addr, saddr, clear) + +int board_early_init_f(void) +{ + /* TMU0 */ + mstp_clrbits_le32(MSTPSR1, SMSTPCR1, TMU0_MSTP125); + +#if defined(CONFIG_NORFLASH) + /* SCIF0 */ + set_guard_reg(GPSR4, 0x34000000, 0x00000000); + set_guard_reg(IPSR14, 0x00000FC7, 0x00000481); + set_guard_reg(GPSR4, 0x00000000, 0x34000000); +#endif + + mstp_clrbits_le32(MSTPSR7, SMSTPCR7, SCIF0_MSTP721); + + /* ETHER */ + mstp_clrbits_le32(MSTPSR8, SMSTPCR8, ETHER_MSTP813); + + return 0; +} + +DECLARE_GLOBAL_DATA_PTR; +int board_init(void) +{ + /* board id for linux */ + gd->bd->bi_arch_number = MACH_TYPE_LAGER; + /* adress of boot parameters */ + gd->bd->bi_boot_params = LAGER_SDRAM_BASE + 0x100; + + /* Init PFC controller */ + r8a7790_pinmux_init(); + + /* ETHER Enable */ + gpio_request(GPIO_FN_ETH_CRS_DV, NULL); + gpio_request(GPIO_FN_ETH_RX_ER, NULL); + gpio_request(GPIO_FN_ETH_RXD0, NULL); + gpio_request(GPIO_FN_ETH_RXD1, NULL); + gpio_request(GPIO_FN_ETH_LINK, NULL); + gpio_request(GPIO_FN_ETH_REF_CLK, NULL); + gpio_request(GPIO_FN_ETH_MDIO, NULL); + gpio_request(GPIO_FN_ETH_TXD1, NULL); + gpio_request(GPIO_FN_ETH_TX_EN, NULL); + gpio_request(GPIO_FN_ETH_MAGIC, NULL); + gpio_request(GPIO_FN_ETH_TXD0, NULL); + gpio_request(GPIO_FN_ETH_MDC, NULL); + gpio_request(GPIO_FN_IRQ0, NULL); + + gpio_request(GPIO_GP_5_31, NULL); /* PHY_RST */ + gpio_direction_output(GPIO_GP_5_31, 0); + mdelay(20); + gpio_set_value(GPIO_GP_5_31, 1); + udelay(1); + + return 0; +} + +#define CXR24 0xEE7003C0 /* MAC address high register */ +#define CXR25 0xEE7003C8 /* MAC address low register */ +int board_eth_init(bd_t *bis) +{ + int ret = -ENODEV; + +#ifdef CONFIG_SH_ETHER + u32 val; + unsigned char enetaddr[6]; + + ret = sh_eth_initialize(bis); + if (!eth_getenv_enetaddr("ethaddr", enetaddr)) + return ret; + + /* Set Mac address */ + val = enetaddr[0] << 24 | enetaddr[1] << 16 | + enetaddr[2] << 8 | enetaddr[3]; + writel(val, CXR24); + + val = enetaddr[4] << 8 | enetaddr[5]; + writel(val, CXR25); + +#endif + + return ret; +} + +/* lager has KSZ8041NL/RNL */ +#define PHY_CONTROL1 0x1E +#define PHY_LED_MODE 0xC0000 +#define PHY_LED_MODE_ACK 0x4000 +int board_phy_config(struct phy_device *phydev) +{ + int ret = phy_read(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1); + ret &= ~PHY_LED_MODE; + ret |= PHY_LED_MODE_ACK; + ret = phy_write(phydev, MDIO_DEVAD_NONE, PHY_CONTROL1, (u16)ret); + + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + + return 0; +} + +const struct rmobile_sysinfo sysinfo = { + CONFIG_RMOBILE_BOARD_STRING +}; + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = LAGER_SDRAM_BASE; + gd->bd->bi_dram[0].size = LAGER_SDRAM_SIZE; +} + +int board_late_init(void) +{ + return 0; +} + +void reset_cpu(ulong addr) +{ +} diff --git a/board/renesas/lager/qos.c b/board/renesas/lager/qos.c new file mode 100644 index 0000000..756be18 --- /dev/null +++ b/board/renesas/lager/qos.c @@ -0,0 +1,1112 @@ +/* + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mach-types.h> +#include <asm/io.h> +#include <asm/arch/rmobile.h> + +enum { + DBSC3_R00, DBSC3_R01, DBSC3_R02, DBSC3_R03, DBSC3_R04, + DBSC3_R05, DBSC3_R06, DBSC3_R07, DBSC3_R08, DBSC3_R09, + DBSC3_R10, DBSC3_R11, DBSC3_R12, DBSC3_R13, DBSC3_R14, + DBSC3_R15, + DBSC3_W00, DBSC3_W01, DBSC3_W02, DBSC3_W03, DBSC3_W04, + DBSC3_W05, DBSC3_W06, DBSC3_W07, DBSC3_W08, DBSC3_W09, + DBSC3_W10, DBSC3_W11, DBSC3_W12, DBSC3_W13, DBSC3_W14, + DBSC3_W15, + DBSC3_NR, +}; + +static const u32 dbsc3_qos_addr[DBSC3_NR] = { + [DBSC3_R00] = DBSC3_0_QOS_R0_BASE, + [DBSC3_R01] = DBSC3_0_QOS_R1_BASE, + [DBSC3_R02] = DBSC3_0_QOS_R2_BASE, + [DBSC3_R03] = DBSC3_0_QOS_R3_BASE, + [DBSC3_R04] = DBSC3_0_QOS_R4_BASE, + [DBSC3_R05] = DBSC3_0_QOS_R5_BASE, + [DBSC3_R06] = DBSC3_0_QOS_R6_BASE, + [DBSC3_R07] = DBSC3_0_QOS_R7_BASE, + [DBSC3_R08] = DBSC3_0_QOS_R8_BASE, + [DBSC3_R09] = DBSC3_0_QOS_R9_BASE, + [DBSC3_R10] = DBSC3_0_QOS_R10_BASE, + [DBSC3_R11] = DBSC3_0_QOS_R11_BASE, + [DBSC3_R12] = DBSC3_0_QOS_R12_BASE, + [DBSC3_R13] = DBSC3_0_QOS_R13_BASE, + [DBSC3_R14] = DBSC3_0_QOS_R14_BASE, + [DBSC3_R15] = DBSC3_0_QOS_R15_BASE, + [DBSC3_W00] = DBSC3_0_QOS_W0_BASE, + [DBSC3_W01] = DBSC3_0_QOS_W1_BASE, + [DBSC3_W02] = DBSC3_0_QOS_R2_BASE, + [DBSC3_W03] = DBSC3_0_QOS_R3_BASE, + [DBSC3_W04] = DBSC3_0_QOS_R4_BASE, + [DBSC3_W05] = DBSC3_0_QOS_R5_BASE, + [DBSC3_W06] = DBSC3_0_QOS_R6_BASE, + [DBSC3_W07] = DBSC3_0_QOS_R7_BASE, + [DBSC3_W08] = DBSC3_0_QOS_R8_BASE, + [DBSC3_W09] = DBSC3_0_QOS_R9_BASE, + [DBSC3_W10] = DBSC3_0_QOS_W10_BASE, + [DBSC3_W11] = DBSC3_0_QOS_W11_BASE, + [DBSC3_W12] = DBSC3_0_QOS_W12_BASE, + [DBSC3_W13] = DBSC3_0_QOS_W13_BASE, + [DBSC3_W14] = DBSC3_0_QOS_W14_BASE, + [DBSC3_W15] = DBSC3_0_QOS_W15_BASE, +}; + +void qos_init(void) +{ + int i; + struct r8a7790_s3c *s3c; + struct r8a7790_s3c_qos *s3c_qos; + struct r8a7790_dbsc3_qos *qos_addr; + struct r8a7790_mxi *mxi; + struct r8a7790_axi_qos *axi_qos; + + /* S3C -QoS */ + s3c = (struct r8a7790_s3c *)S3C_BASE; + writel(0x80FF1D0D, &s3c->s3cadsplcr); + writel(0x0F0F0505, &s3c->s3crorr); + writel(0x0F0F0505, &s3c->s3cworr); + + /* QoS Control Registers */ + s3c_qos = (struct r8a7790_s3c_qos *)S3C_QOS_CCI0_BASE; + writel(0x00800080, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7790_s3c_qos *)S3C_QOS_CCI1_BASE; + writel(0x00800080, &s3c_qos->s3cqos0); + writel(0x20410001, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410001, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7790_s3c_qos *)S3C_QOS_MXI_BASE; + writel(0x00810081, &s3c_qos->s3cqos0); + writel(0x20410FFF, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410FFF, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + s3c_qos = (struct r8a7790_s3c_qos *)S3C_QOS_AXI_BASE; + writel(0x00810081, &s3c_qos->s3cqos0); + writel(0x20410FFF, &s3c_qos->s3cqos1); + writel(0x200A2023, &s3c_qos->s3cqos2); + writel(0x20502001, &s3c_qos->s3cqos3); + writel(0x20142032, &s3c_qos->s3cqos4); + writel(0x20410FFF, &s3c_qos->s3cqos5); + writel(0x200A2023, &s3c_qos->s3cqos6); + writel(0x20502001, &s3c_qos->s3cqos7); + writel(0x20142032, &s3c_qos->s3cqos8); + + /* DBSC -QoS */ + /* DBSC0 - Read/Write */ + for (i = DBSC3_R00; i < DBSC3_NR; i++) { + qos_addr = (struct r8a7790_dbsc3_qos *)dbsc3_qos_addr[i]; + writel(0x00000203, &qos_addr->dblgcnt); + writel(0x00002064, &qos_addr->dbtmval0); + writel(0x00002048, &qos_addr->dbtmval1); + writel(0x00002032, &qos_addr->dbtmval2); + writel(0x00002019, &qos_addr->dbtmval3); + writel(0x00000001, &qos_addr->dbrqctr); + writel(0x00002019, &qos_addr->dbthres0); + writel(0x00002019, &qos_addr->dbthres1); + writel(0x00002019, &qos_addr->dbthres2); + writel(0x00000000, &qos_addr->dblgqon); + } + /* CCI-400 -OoS */ + writel(0x20001000, CCI_400_MAXOT_1); + writel(0x20001000, CCI_400_MAXOT_2); + writel(0x0000000C, CCI_400_QOSCNTL_1); + writel(0x0000000C, CCI_400_QOSCNTL_2); + + /* MXI -OoS */ + /* Transaction Control (MXI) */ + mxi = (struct r8a7790_mxi *)MXI_BASE; + writel(0x00200000, &mxi->mxs3cracr); + writel(0x00000013, &mxi->mxrtcr); + writel(0x00000013, &mxi->mxrtcr); + + /* AXI -QoS */ + /* Transaction Control (MXI) */ + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_SYX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_AVB_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_G2D_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_IMP0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_IMP1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_IMUX0_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_IMUX1_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_IMUX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_LBS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002064, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002064, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002064, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002064, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002064, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MTSB0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_MTSB1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_PCI_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_RTX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_SDS0_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_SDS1_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200A, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_USB20_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_USB21_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_USB22_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI_USB30_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (RT-AXI) */ + axi_qos = (struct r8a7790_axi_qos *)RT_AXI_SHX_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)RT_AXI_RDS_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)RT_AXI_RTX64TO128_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002006, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)RT_AXI_STPRO_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (MP-AXI) */ + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_ADSP_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_ASDS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_ASDS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_MLP_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x0000212C, &axi_qos->qosthres0); + writel(0x000020C8, &axi_qos->qosthres1); + writel(0x00002034, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_SPU_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MP_AXI_SPUC_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200D, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (SYS-AXI256) */ + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI256_AXI128TO256_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI256_SYX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI256_MPX_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)SYS_AXI256_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (CCI-AXI) */ + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUS0_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_SYX2_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUDS_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUM_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MXI_BASE; + writel(0x00000002, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00002005, &axi_qos->qosctset1); + writel(0x00002003, &axi_qos->qosctset2); + writel(0x00002001, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUS1_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)CCI_AXI_MMUMP_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + /* QoS Register (Media-AXI) */ + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_JPR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_JPW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002018, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_GCU0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_GCU0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_GCU1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_GCU1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_TDMR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_TDMW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002014, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP0CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP0CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP1CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP1CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPDU0CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosctset1); + writel(0x00000000, &axi_qos->qosctset2); + writel(0x00000000, &axi_qos->qosctset3); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPDU0CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPDU1CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPDU1CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VIN0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002008, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002005, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002007, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_IMSR_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_IMSW_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002003, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSP1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002006, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_IMRR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_IMRW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002004, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP2R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_FDP2W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPD0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPD0W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200B, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPD1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VSPD1W_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200B, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_DU0R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_DU0W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_DU1R_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002002, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_DU1W_BASE; + writel(0x00000001, &axi_qos->qosconf); + writel(0x00002003, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP0CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP0CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002009, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP0VR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP0VW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VPC0R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP1CR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP1CW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002009, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP1VR_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VCP1VW_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x0000200F, &axi_qos->qosctset0); + writel(0x00000001, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000001, &axi_qos->qosqon); + + axi_qos = (struct r8a7790_axi_qos *)MEDIA_AXI_VPC1R_BASE; + writel(0x00000000, &axi_qos->qosconf); + writel(0x00002001, &axi_qos->qosctset0); + writel(0x00000000, &axi_qos->qosreqctr); + writel(0x00002006, &axi_qos->qosthres0); + writel(0x00002004, &axi_qos->qosthres1); + writel(0x00002002, &axi_qos->qosthres2); + writel(0x00000000, &axi_qos->qosqon); + + /* CCI-AXI Function Register */ + writel(0x00000011, CCI_AXI_IPMMUIDVMCR); + writel(0x00000011, CCI_AXI_IPMMURDVMCR); + writel(0x00000011, CCI_AXI_IPMMUS0DVMCR); + writel(0x00000011, CCI_AXI_IPMMUS1DVMCR); + writel(0x00000011, CCI_AXI_IPMMUMPDVMCR); + writel(0x00000011, CCI_AXI_IPMMUDSDVMCR); + writel(0x0000F700, CCI_AXI_AX2ADDRMASK); +} diff --git a/board/renesas/lager/qos.h b/board/renesas/lager/qos.h new file mode 100644 index 0000000..9a6c046 --- /dev/null +++ b/board/renesas/lager/qos.h @@ -0,0 +1,12 @@ +/* + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __QOS_H__ +#define __QOS_H__ + +void qos_init(void); + +#endif diff --git a/boards.cfg b/boards.cfg index be810c7..8e38d3c 100644 --- a/boards.cfg +++ b/boards.cfg @@ -341,6 +341,8 @@ u8500_href arm armv7 u8500 st-eric snowball arm armv7 snowball st-ericsson u8500 kzm9g arm armv7 kzm9g kmc rmobile armadillo-800eva arm armv7 armadillo-800eva atmark-techno rmobile +lager arm armv7 lager renesas rmobile +lager_nor arm armv7 lager renesas rmobile lager:NORFLASH zynq arm armv7 zynq xilinx zynq zynq_dcc arm armv7 zynq xilinx zynq zynq:ZYNQ_DCC socfpga_cyclone5 arm armv7 socfpga altera socfpga diff --git a/include/configs/lager.h b/include/configs/lager.h new file mode 100644 index 0000000..9ee9159 --- /dev/null +++ b/include/configs/lager.h @@ -0,0 +1,186 @@ +/* + * include/configs/lager.h + * This file is lager board configuration. + * + * Copyright (C) 2013 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __LAGER_H +#define __LAGER_H + +#undef DEBUG +#define CONFIG_ARMV7 +#define CONFIG_R8A7790 +#define CONFIG_RMOBILE +#define CONFIG_RMOBILE_BOARD_STRING "Lager" +#define CONFIG_SH_GPIO_PFC + +#include <asm/arch/rmobile.h> + +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_RUN +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NFS +#define CONFIG_CMD_BOOTZ + +#if defined(CONFIG_NORFLASH) +#define CONFIG_CMD_FLASH +#else +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI +#endif + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING +#define CONFIG_OF_LIBFDT + +/* #define CONFIG_OF_LIBFDT */ +#define BOARD_LATE_INIT + +#define CONFIG_BAUDRATE 38400 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_USE_ARCH_MEMSET +#define CONFIG_USE_ARCH_MEMCPY +#define CONFIG_TMU_TIMER + +/* STACK */ +#define CONFIG_SYS_INIT_SP_ADDR 0xE827fffc +#define STACK_AREA_SIZE 0xC000 +#define LOW_LEVEL_MERAM_STACK \ + (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4) + +/* MEMORY */ +#define LAGER_SDRAM_BASE 0x40000000 +#define LAGER_SDRAM_SIZE (2048u * 1024 * 1024) +#define LAGER_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE +#define CONFIG_CONS_SCIF0 +#define SCIF0_BASE 0xe6e60000 +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_MEMTEST_START (LAGER_SDRAM_BASE) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 504 * 1024 * 1024) +#undef CONFIG_SYS_ALT_MEMTEST +#undef CONFIG_SYS_MEMTEST_SCRATCH +#undef CONFIG_SYS_LOADS_BAUD_CHANGE + +#define CONFIG_SYS_SDRAM_BASE (LAGER_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (LAGER_UBOOT_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) +#define CONFIG_SYS_GBL_DATA_SIZE (256) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +#if defined(CONFIG_CMD_FLASH) +/* USE NOR FLASH */ +#define CONFIG_SYS_TEXT_BASE 0x00000000 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_FLASH_SHOW_PROGRESS 45 +#define CONFIG_SYS_FLASH_BASE 0x00000000 +#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MB */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_FLASH_BANKS_LIST { (CONFIG_SYS_FLASH_BASE) } +#define CONFIG_SYS_FLASH_BANKS_SIZES { (CONFIG_SYS_FLASH_SIZE) } + +#define CONFIG_SYS_FLASH_ERASE_TOUT 3000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 3000 +#define CONFIG_SYS_FLASH_LOCK_TOUT 3000 +#define CONFIG_SYS_FLASH_UNLOCK_TOUT 3000 + +/* ENV setting */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_ENV_SECT_SIZE (256 * 1024) +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN) + +#else +/* USE SPI */ +#define CONFIG_SYS_TEXT_BASE 0xE8080000 +#define CONFIG_SPI +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SH_QSPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SH_QSPI_BASE 0xE6B10000 + +/* ENV setting */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE (256 * 1024) +#define CONFIG_ENV_ADDR 0xC0000 +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#endif + +/* SH Ether */ +#define CONFIG_NET_MULTI +#define CONFIG_SH_ETHER +#define CONFIG_SH_ETHER_USE_PORT 0 +#define CONFIG_SH_ETHER_PHY_ADDR 0x1 +#define CONFIG_SH_ETHER_PHY_MODE PHY_INTERFACE_MODE_RMII +#define CONFIG_SH_ETHER_ALIGNE_SIZE 64 +#define CONFIG_SH_ETHER_CACHE_WRITEBACK +#define CONFIG_SH_ETHER_CACHE_INVALIDATE +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_BITBANGMII +#define CONFIG_BITBANGMII_MULTI + +/* Board Clock */ +#define CONFIG_BASE_CLK_FREQ 20000000u +#define CONFIG_SH_TMU_CLK_FREQ (CONFIG_BASE_CLK_FREQ / 2) /* EXT / 2 */ +#define CONFIG_PLL1_CLK_FREQ (CONFIG_BASE_CLK_FREQ * 156 / 2) +#define CONFIG_PLL1_DIV2_CLK_FREQ (CONFIG_PLL1_CLK_FREQ / 2) +#define CONFIG_MP_CLK_FREQ (CONFIG_PLL1_DIV2_CLK_FREQ / 15) +#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_MP_CLK_FREQ + +#define CONFIG_SYS_TMU_CLK_DIV 4 +#define CONFIG_SYS_HZ 1000 + +#endif /* __LAGER_H */
Hi Nobuhiro,
On Thu, 22 Aug 2013 13:23:28 +0900, Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 440b041..67b88ad 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -1106,6 +1106,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_OMAP5_SEVM 3777 #define MACH_TYPE_ARMADILLO_800EVA 3863 #define MACH_TYPE_KZM9G 4140 +#define MACH_TYPE_LAGER 4538
Do not modify mach-types.h; if the machine type was reserved but is not yet in machine-types, then you should define the machine type in the board's header file, possibly with preprocessing directives to #error when the same definition appears in mach-types.h making the board's one obsolete.
Please rebase as boards.cfg has changed, and do add maintainer addresses to these two lines.
Amicalement,
Hi, Albert.
(2013/09/19 18:04), Albert ARIBAUD wrote:
Hi Nobuhiro,
OK, I will remove this from patch.
I see. I will update my patches and re-send. Thank you for your review!
Amicalement,
Best regards, Nobuhiro
Albert ARIBAUD
Nobuhiro Iwamatsu
