[PATCH 1/2] gpio: mxc_gpio: change gpio index for i.MX8
Since the i.MX8 GPIO banks are indexed from 0 not 1 on other i.MX platforms, so we have to adjust the index accordingly.
Signed-off-by: Adrian Alonso adrian.alonso@nxp.com Signed-off-by: Ye Li ye.li@nxp.com --- drivers/gpio/mxc_gpio.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/mxc_gpio.c b/drivers/gpio/mxc_gpio.c index a851893..90d36fb 100644 --- a/drivers/gpio/mxc_gpio.c +++ b/drivers/gpio/mxc_gpio.c @@ -281,7 +281,10 @@ static int mxc_gpio_probe(struct udevice *dev) char name[18], *str;
banknum = plat->bank_index; - sprintf(name, "GPIO%d_", banknum + 1); + if (IS_ENABLED(CONFIG_ARCH_IMX8)) + sprintf(name, "GPIO%d_", banknum); + else + sprintf(name, "GPIO%d_", banknum + 1); str = strdup(name); if (!str) return -ENOMEM;
Current aliases missed gpio0 node, and this node shoud be aliased to gpio index 0 to align with i.MX8QXP. Otherwise, we will get below message when running "gpio status" command, and see the reason by "dm uclass".
=> gpio status Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000' Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000' Device 'gpio@5d0b0000': seq 2 is in use by 'gpio@5d0a0000'
=> dm uclass uclass 36: gpio 0 * gpio@5d080000 @ fbaefb90, seq 0, (req -1) 1 * gpio@5d090000 @ fbaefc70, seq 1, (req 0) 2 * gpio@5d0a0000 @ fbaefd50, seq 2, (req 1) 3 * gpio@5d0b0000 @ fbaefe30, seq 5, (req 2) 4 * gpio@5d0c0000 @ fbaeff10, seq 3, (req 3) 5 * gpio@5d0d0000 @ fbaefff0, seq 4, (req 4) 6 * gpio@5d0e0000 @ fbaf00d0, seq 6, (req 5) 7 * gpio@5d0f0000 @ fbaf01b0, seq 7, (req 6)
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/dts/fsl-imx8qm.dtsi | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8qm.dtsi b/arch/arm/dts/fsl-imx8qm.dtsi index 2e887ad..88aeaf6 100644 --- a/arch/arm/dts/fsl-imx8qm.dtsi +++ b/arch/arm/dts/fsl-imx8qm.dtsi @@ -21,13 +21,14 @@ aliases { ethernet0 = &fec1; ethernet1 = &fec2; - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; - gpio5 = &gpio6; - gpio6 = &gpio7; + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + gpio3 = &gpio3; + gpio4 = &gpio4; + gpio5 = &gpio5; + gpio6 = &gpio6; + gpio7 = &gpio7; serial0 = &lpuart0; serial1 = &lpuart1; serial2 = &lpuart2;
Current aliases missed gpio0 node, and this node shoud be aliased to gpio index 0 to align with i.MX8QXP. Otherwise, we will get below message when running "gpio status" command, and see the reason by "dm uclass". => gpio status Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000' Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000' Device 'gpio@5d0b0000': seq 2 is in use by 'gpio@5d0a0000' => dm uclass uclass 36: gpio 0 * gpio@5d080000 @ fbaefb90, seq 0, (req -1) 1 * gpio@5d090000 @ fbaefc70, seq 1, (req 0) 2 * gpio@5d0a0000 @ fbaefd50, seq 2, (req 1) 3 * gpio@5d0b0000 @ fbaefe30, seq 5, (req 2) 4 * gpio@5d0c0000 @ fbaeff10, seq 3, (req 3) 5 * gpio@5d0d0000 @ fbaefff0, seq 4, (req 4) 6 * gpio@5d0e0000 @ fbaf00d0, seq 6, (req 5) 7 * gpio@5d0f0000 @ fbaf01b0, seq 7, (req 6) Signed-off-by: Ye Li ye.li@nxp.com
Best regards, Stefano Babic
Since the i.MX8 GPIO banks are indexed from 0 not 1 on other i.MX platforms, so we have to adjust the index accordingly. Signed-off-by: Adrian Alonso adrian.alonso@nxp.com Signed-off-by: Ye Li ye.li@nxp.com
sbabic@denx.de
Ye Li
