[U-Boot] Please pull u-boot-fsl-qoriq master
Tom,
The following changes since commit 37b608a52dcb13312a4f7ccea199cd6bac76d298:
powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200 (2015-01-23 16:56:09 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to 41ba57d0c7968506ddcc71604bd39131acf6ee23:
fsl/ls1021qds: Add deep sleep support (2015-01-24 09:12:32 -0600)
---------------------------------------------------------------- Alison Wang (5): ls102xa: etsec: Select ge0_clk125 for eTSEC clock muxing as default arm: ls102xa: Update snoop settings for CCI-400 ls102xa: fdt: Disable QSPI and DSPI in NOR/NAND/SD boot arm: ls102xa: Add LPUART support for LS1021AQDS board arm: ls102xa: Add LPUART support for LS1021ATWR board
Ruchika Gupta (2): arm: ls102xa: Add dummy gpio.h to enable CONFIG_OF_CONTROL crypto/fsl: Add fixup for crypto node
Xiubo Li (1): ls102xa: dcu: Add platform support for DCU on LS1021AQDS board
York Sun (1): arm/ls1021a: Add workaround for DDR erratum A008378
tang yuantian (2): ARM: HYP/non-sec: Make variable gic_dist_addr as a local one fsl/ls1021qds: Add deep sleep support
arch/arm/cpu/armv7/ls102xa/fdt.c | 49 ++++++ arch/arm/cpu/armv7/virt-v7.c | 9 +- arch/arm/include/asm/arch-ls102xa/config.h | 5 + arch/arm/include/asm/arch-ls102xa/gpio.h | 15 ++ arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 4 + arch/powerpc/cpu/mpc8xxx/fdt.c | 170 ------------------- arch/powerpc/include/asm/config.h | 1 + board/freescale/ls1021aqds/MAINTAINERS | 1 + board/freescale/ls1021aqds/Makefile | 1 + board/freescale/ls1021aqds/dcu.c | 92 +++++++++++ board/freescale/ls1021aqds/ddr.c | 17 ++ board/freescale/ls1021aqds/ls1021aqds.c | 86 +++++++++- board/freescale/ls1021aqds/ls1021aqds_qixis.h | 2 + board/freescale/ls1021atwr/MAINTAINERS | 1 + board/freescale/ls1021atwr/ls1021atwr.c | 25 +-- configs/ls1021aqds_nor_lpuart_defconfig | 3 + configs/ls1021atwr_nor_lpuart_defconfig | 3 + drivers/crypto/fsl/Makefile | 1 + drivers/crypto/fsl/sec.c | 184 +++++++++++++++++++++ drivers/ddr/fsl/fsl_ddr_gen4.c | 8 + include/configs/ls1021aqds.h | 41 ++++- include/configs/ls1021atwr.h | 12 ++ include/fsl_ddr.h | 6 + 23 files changed, 545 insertions(+), 191 deletions(-) create mode 100644 arch/arm/include/asm/arch-ls102xa/gpio.h create mode 100644 board/freescale/ls1021aqds/dcu.c create mode 100644 configs/ls1021aqds_nor_lpuart_defconfig create mode 100644 configs/ls1021atwr_nor_lpuart_defconfig create mode 100644 drivers/crypto/fsl/sec.c
Thanks.
York
On Sat, Jan 24, 2015 at 09:44:14AM -0600, York Sun wrote:
Tom,
York Sun
