[U-Boot] [PATCH v4 0/2] arm: vf610: add NAND flash support
This patch set adds NAND Flash Controller (NFC) support for Freescale Vybrid ARM SoCs (vf610).
The driver is based on Bill Pringlemeirs prelineary patch sent in January 2014 to the MTD mailing list: http://lists.infradead.org/pipermail/linux-arm-kernel/2014-January/226623.ht...
Changes in v4 - Drop preparation patches 1 and 2 since they are already merged upstream - Add memcpy accessor function vf610_nfc_memcpy - Remove disabled code
Changes in v3 - Further optimizations in vf610_nfc_send_command(s) to avoid performance hit by additional barriers introduced through using writel/readl - Removed unnecessary barrier and added comment - Use void __iomem * as memory base data type - Set page to -1 on read error to allow reread of pages by the higher layers - Minor style fixes
Changes in v2: - Renamed the driver from fsl_nfc to vf610_nfc - Use writel/readl in register access functions - Optimized some register accesses by read/write value only once in code - Use CONFIG_SYS_NAND_SELF_INIT and fix board_nand_init implementation - Removed uncommented code/fixed comments - Add CONFIG_USE_ARCH_MEMCPY for improved NAND performance - Use hweight32 for improved count_written_bits performance - Implement page_read/page_write rather than reuse MTD stacks version
Stefan Agner (2): mtd: nand: add Freescale vf610_nfc driver arm: vf610: add NAND support for vf610twr
board/freescale/vf610twr/vf610twr.c | 47 ++- configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 3 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/vf610_nfc.c | 721 ++++++++++++++++++++++++++++++++++++ include/configs/vf610twr.h | 46 ++- 6 files changed, 815 insertions(+), 5 deletions(-) create mode 100644 configs/vf610twr_nand_defconfig create mode 100644 drivers/mtd/nand/vf610_nfc.c
This adds initial support for Freescale NFC (NAND Flash Controller) found in ARM Vybrid SoC's, Power Architecture MPC5125 and others. The driver is called vf610_nfc since this is the first supported and tested hardware platform supported by the driver.
Signed-off-by: Stefan Agner stefan@agner.ch --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/vf610_nfc.c | 721 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 722 insertions(+) create mode 100644 drivers/mtd/nand/vf610_nfc.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index bf1312a..eef86d1 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -51,6 +51,7 @@ obj-$(CONFIG_NAND_KB9202) += kb9202_nand.o obj-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o obj-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o obj-$(CONFIG_NAND_MPC5121_NFC) += mpc5121_nfc.o +obj-$(CONFIG_NAND_VF610_NFC) += vf610_nfc.o obj-$(CONFIG_NAND_MXC) += mxc_nand.o obj-$(CONFIG_NAND_MXS) += mxs_nand.o obj-$(CONFIG_NAND_NDFC) += ndfc.o diff --git a/drivers/mtd/nand/vf610_nfc.c b/drivers/mtd/nand/vf610_nfc.c new file mode 100644 index 0000000..f0eba9a --- /dev/null +++ b/drivers/mtd/nand/vf610_nfc.c @@ -0,0 +1,721 @@ +/* + * Copyright 2009-2014 Freescale Semiconductor, Inc. and others + * + * Description: MPC5125, VF610, MCF54418 and Kinetis K70 Nand driver. + * Ported to U-Boot by Stefan Agner + * Based on RFC driver posted on Kernel Mailing list by Bill Pringlemeir + * Jason ported to M54418TWR and MVFA5. + * Authors: Stefan Agner stefan.agner@toradex.com + * Bill Pringlemeir bpringlemeir@nbsps.com + * Shaohui Xie b21989@freescale.com + * Jason Jin Jason.jin@freescale.com + * + * Based on original driver mpc5121_nfc.c. + * + * This is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * Limitations: + * - Untested on MPC5125 and M54418. + * - DMA not used. + * - 2K pages or less. + * - Only 2K page w. 64+OOB and hardware ECC. + */ + +#include <common.h> +#include <malloc.h> + +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/partitions.h> + +#include <nand.h> +#include <errno.h> +#include <asm/io.h> + +/* Register Offsets */ +#define NFC_FLASH_CMD1 0x3F00 +#define NFC_FLASH_CMD2 0x3F04 +#define NFC_COL_ADDR 0x3F08 +#define NFC_ROW_ADDR 0x3F0c +#define NFC_ROW_ADDR_INC 0x3F14 +#define NFC_FLASH_STATUS1 0x3F18 +#define NFC_FLASH_STATUS2 0x3F1c +#define NFC_CACHE_SWAP 0x3F28 +#define NFC_SECTOR_SIZE 0x3F2c +#define NFC_FLASH_CONFIG 0x3F30 +#define NFC_IRQ_STATUS 0x3F38 + +/* Addresses for NFC MAIN RAM BUFFER areas */ +#define NFC_MAIN_AREA(n) ((n) * 0x1000) + +#define PAGE_2K 0x0800 +#define OOB_64 0x0040 + +/* + * NFC_CMD2[CODE] values. See section: + * - 31.4.7 Flash Command Code Description, Vybrid manual + * - 23.8.6 Flash Command Sequencer, MPC5125 manual + * + * Briefly these are bitmasks of controller cycles. + */ +#define READ_PAGE_CMD_CODE 0x7EE0 +#define PROGRAM_PAGE_CMD_CODE 0x7FC0 +#define ERASE_CMD_CODE 0x4EC0 +#define READ_ID_CMD_CODE 0x4804 +#define RESET_CMD_CODE 0x4040 +#define STATUS_READ_CMD_CODE 0x4068 + +/* NFC ECC mode define */ +#define ECC_BYPASS 0 +#define ECC_45_BYTE 6 + +/*** Register Mask and bit definitions */ + +/* NFC_FLASH_CMD1 Field */ +#define CMD_BYTE2_MASK 0xFF000000 +#define CMD_BYTE2_SHIFT 24 + +/* NFC_FLASH_CM2 Field */ +#define CMD_BYTE1_MASK 0xFF000000 +#define CMD_BYTE1_SHIFT 24 +#define CMD_CODE_MASK 0x00FFFF00 +#define CMD_CODE_SHIFT 8 +#define BUFNO_MASK 0x00000006 +#define BUFNO_SHIFT 1 +#define START_BIT (1<<0) + +/* NFC_COL_ADDR Field */ +#define COL_ADDR_MASK 0x0000FFFF +#define COL_ADDR_SHIFT 0 + +/* NFC_ROW_ADDR Field */ +#define ROW_ADDR_MASK 0x00FFFFFF +#define ROW_ADDR_SHIFT 0 +#define ROW_ADDR_CHIP_SEL_RB_MASK 0xF0000000 +#define ROW_ADDR_CHIP_SEL_RB_SHIFT 28 +#define ROW_ADDR_CHIP_SEL_MASK 0x0F000000 +#define ROW_ADDR_CHIP_SEL_SHIFT 24 + +/* NFC_FLASH_STATUS2 Field */ +#define STATUS_BYTE1_MASK 0x000000FF + +/* NFC_FLASH_CONFIG Field */ +#define CONFIG_ECC_SRAM_ADDR_MASK 0x7FC00000 +#define CONFIG_ECC_SRAM_ADDR_SHIFT 22 +#define CONFIG_ECC_SRAM_REQ_BIT (1<<21) +#define CONFIG_DMA_REQ_BIT (1<<20) +#define CONFIG_ECC_MODE_MASK 0x000E0000 +#define CONFIG_ECC_MODE_SHIFT 17 +#define CONFIG_FAST_FLASH_BIT (1<<16) +#define CONFIG_16BIT (1<<7) +#define CONFIG_BOOT_MODE_BIT (1<<6) +#define CONFIG_ADDR_AUTO_INCR_BIT (1<<5) +#define CONFIG_BUFNO_AUTO_INCR_BIT (1<<4) +#define CONFIG_PAGE_CNT_MASK 0xF +#define CONFIG_PAGE_CNT_SHIFT 0 + +/* NFC_IRQ_STATUS Field */ +#define IDLE_IRQ_BIT (1<<29) +#define IDLE_EN_BIT (1<<20) +#define CMD_DONE_CLEAR_BIT (1<<18) +#define IDLE_CLEAR_BIT (1<<17) + +#define NFC_TIMEOUT (1000) + +/* ECC status placed at end of buffers. */ +#define ECC_SRAM_ADDR ((PAGE_2K+256-8) >> 3) +#define ECC_STATUS_MASK 0x80 +#define ECC_ERR_COUNT 0x3F + +/* + * ECC status is stored at NFC_CFG[ECCADD] +4 for little-endian + * and +7 for big-endian SOC. + */ +#ifdef CONFIG_VF610 +#define ECC_OFFSET 4 +#else +#define ECC_OFFSET 7 +#endif + +struct vf610_nfc { + struct mtd_info *mtd; + struct nand_chip chip; + void __iomem *regs; + uint column; + int spareonly; + int page; + /* Status and ID are in alternate locations. */ + int alt_buf; +#define ALT_BUF_ID 1 +#define ALT_BUF_STAT 2 + struct clk *clk; +}; + +#define mtd_to_nfc(_mtd) (struct vf610_nfc *)((struct nand_chip *)_mtd->priv)->priv; + +static u8 bbt_pattern[] = {'B', 'b', 't', '0' }; +static u8 mirror_pattern[] = {'1', 't', 'b', 'B' }; + +static struct nand_bbt_descr bbt_main_descr = { + .options = NAND_BBT_LASTBLOCK | NAND_BBT_CREATE | NAND_BBT_WRITE | + NAND_BBT_2BIT | NAND_BBT_VERSION, + .offs = 11, + .len = 4, + .veroffs = 15, + .maxblocks = 4, + .pattern = bbt_pattern, +}; + +static struct nand_bbt_descr bbt_mirror_descr = { + .options = NAND_BBT_LASTBLOCK | NAND_BBT_CREATE | NAND_BBT_WRITE | + NAND_BBT_2BIT | NAND_BBT_VERSION, + .offs = 11, + .len = 4, + .veroffs = 15, + .maxblocks = 4, + .pattern = mirror_pattern, +}; + +static struct nand_ecclayout vf610_nfc_ecc45 = { + .eccbytes = 45, + .eccpos = {19, 20, 21, 22, 23, + 24, 25, 26, 27, 28, 29, 30, 31, + 32, 33, 34, 35, 36, 37, 38, 39, + 40, 41, 42, 43, 44, 45, 46, 47, + 48, 49, 50, 51, 52, 53, 54, 55, + 56, 57, 58, 59, 60, 61, 62, 63}, + .oobfree = { + {.offset = 8, + .length = 11} } +}; + +static inline u32 vf610_nfc_read(struct mtd_info *mtd, uint reg) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + + return readl(nfc->regs + reg); +} + +static inline void vf610_nfc_write(struct mtd_info *mtd, uint reg, u32 val) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + + writel(val, nfc->regs + reg); +} + +static inline void vf610_nfc_set(struct mtd_info *mtd, uint reg, u32 bits) +{ + vf610_nfc_write(mtd, reg, vf610_nfc_read(mtd, reg) | bits); +} + +static inline void vf610_nfc_clear(struct mtd_info *mtd, uint reg, u32 bits) +{ + vf610_nfc_write(mtd, reg, vf610_nfc_read(mtd, reg) & ~bits); +} + +static inline void vf610_nfc_set_field(struct mtd_info *mtd, u32 reg, + u32 mask, u32 shift, u32 val) +{ + vf610_nfc_write(mtd, reg, + (vf610_nfc_read(mtd, reg) & (~mask)) | val << shift); +} + +static inline void vf610_nfc_memcpy(void *dst, const void *src, size_t n) +{ + /* + * Use this accessor for the interal SRAM buffers. On ARM we can + * treat the SRAM buffer as if its memory, hence use memcpy + */ + memcpy(dst, src, n); +} + +/* Clear flags for upcoming command */ +static inline void vf610_nfc_clear_status(void __iomem *regbase) +{ + void __iomem *reg = regbase + NFC_IRQ_STATUS; + u32 tmp = __raw_readl(reg); + tmp |= CMD_DONE_CLEAR_BIT | IDLE_CLEAR_BIT; + __raw_writel(tmp, reg); +} + +/* Wait for complete operation */ +static inline void vf610_nfc_done(struct mtd_info *mtd) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + uint start; + + /* + * Barrier is needed after this write. This write need + * to be done before reading the next register the first + * time. + * vf610_nfc_set implicates such a barrier by using writel + * to write to the register. + */ + vf610_nfc_set(mtd, NFC_FLASH_CMD2, START_BIT); + + start = get_timer(0); + + while (!(vf610_nfc_read(mtd, NFC_IRQ_STATUS) & IDLE_IRQ_BIT)) { + if (get_timer(start) > NFC_TIMEOUT) { + printf("Timeout while waiting for !BUSY.\n"); + return; + } + } + vf610_nfc_clear_status(nfc->regs); +} + +static u8 vf610_nfc_get_id(struct mtd_info *mtd, int col) +{ + u32 flash_id; + + if (col < 4) { + flash_id = vf610_nfc_read(mtd, NFC_FLASH_STATUS1); + return (flash_id >> (3-col)*8) & 0xff; + } else { + flash_id = vf610_nfc_read(mtd, NFC_FLASH_STATUS2); + return flash_id >> 24; + } +} + +static u8 vf610_nfc_get_status(struct mtd_info *mtd) +{ + return vf610_nfc_read(mtd, NFC_FLASH_STATUS2) & STATUS_BYTE1_MASK; +} + +/* Single command */ +static void vf610_nfc_send_command(void __iomem *regbase, u32 cmd_byte1, + u32 cmd_code) +{ + void __iomem *reg = regbase + NFC_FLASH_CMD2; + u32 tmp; + vf610_nfc_clear_status(regbase); + + tmp = __raw_readl(reg); + tmp &= ~(CMD_BYTE1_MASK | CMD_CODE_MASK | BUFNO_MASK); + tmp |= cmd_byte1 << CMD_BYTE1_SHIFT; + tmp |= cmd_code << CMD_CODE_SHIFT; + __raw_writel(tmp, reg); +} + +/* Two commands */ +static void vf610_nfc_send_commands(void __iomem *regbase, u32 cmd_byte1, + u32 cmd_byte2, u32 cmd_code) +{ + void __iomem *reg = regbase + NFC_FLASH_CMD1; + u32 tmp; + vf610_nfc_send_command(regbase, cmd_byte1, cmd_code); + + tmp = __raw_readl(reg); + tmp &= ~CMD_BYTE2_MASK; + tmp |= cmd_byte2 << CMD_BYTE2_SHIFT; + __raw_writel(tmp, reg); +} + +static void vf610_nfc_addr_cycle(struct mtd_info *mtd, int column, int page) +{ + if (column != -1) { + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + if (nfc->chip.options | NAND_BUSWIDTH_16) + column = column/2; + vf610_nfc_set_field(mtd, NFC_COL_ADDR, COL_ADDR_MASK, + COL_ADDR_SHIFT, column); + } + if (page != -1) + vf610_nfc_set_field(mtd, NFC_ROW_ADDR, ROW_ADDR_MASK, + ROW_ADDR_SHIFT, page); +} + +/* Send command to NAND chip */ +static void vf610_nfc_command(struct mtd_info *mtd, unsigned command, + int column, int page) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + + nfc->column = max(column, 0); + nfc->spareonly = 0; + nfc->alt_buf = 0; + + switch (command) { + case NAND_CMD_PAGEPROG: + nfc->page = -1; + vf610_nfc_send_commands(nfc->regs, NAND_CMD_SEQIN, + command, PROGRAM_PAGE_CMD_CODE); + vf610_nfc_addr_cycle(mtd, column, page); + break; + + case NAND_CMD_RESET: + vf610_nfc_send_command(nfc->regs, command, RESET_CMD_CODE); + break; + /* + * NFC does not support sub-page reads and writes, + * so emulate them using full page transfers. + */ + case NAND_CMD_READOOB: + nfc->spareonly = 1; + case NAND_CMD_SEQIN: /* Pre-read for partial writes. */ + case NAND_CMD_READ0: + column = 0; + /* Already read? */ + if (nfc->page == page) + return; + nfc->page = page; + vf610_nfc_send_commands(nfc->regs, NAND_CMD_READ0, + NAND_CMD_READSTART, READ_PAGE_CMD_CODE); + vf610_nfc_addr_cycle(mtd, column, page); + break; + + case NAND_CMD_ERASE1: + if (nfc->page == page) + nfc->page = -1; + vf610_nfc_send_commands(nfc->regs, command, + NAND_CMD_ERASE2, ERASE_CMD_CODE); + vf610_nfc_addr_cycle(mtd, column, page); + break; + + case NAND_CMD_READID: + nfc->alt_buf = ALT_BUF_ID; + vf610_nfc_send_command(nfc->regs, command, READ_ID_CMD_CODE); + break; + + case NAND_CMD_STATUS: + nfc->alt_buf = ALT_BUF_STAT; + vf610_nfc_send_command(nfc->regs, command, STATUS_READ_CMD_CODE); + break; + default: + return; + } + + vf610_nfc_done(mtd); +} + +static inline void vf610_nfc_read_spare(struct mtd_info *mtd, void *buf, + int len) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + + len = min(mtd->oobsize, (uint)len); + if (len > 0) + vf610_nfc_memcpy(buf, nfc->regs + mtd->writesize, len); +} + +/* Read data from NFC buffers */ +static void vf610_nfc_read_buf(struct mtd_info *mtd, u_char *buf, int len) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + uint c = nfc->column; + uint l; + + /* Handle main area */ + if (!nfc->spareonly) { + l = min((uint)len, mtd->writesize - c); + nfc->column += l; + + if (!nfc->alt_buf) + vf610_nfc_memcpy(buf, nfc->regs + NFC_MAIN_AREA(0) + c, l); + else + if (nfc->alt_buf & ALT_BUF_ID) + *buf = vf610_nfc_get_id(mtd, c); + else + *buf = vf610_nfc_get_status(mtd); + + buf += l; + len -= l; + } + + /* Handle spare area access */ + if (len) { + nfc->column += len; + vf610_nfc_read_spare(mtd, buf, len); + } +} + +/* Write data to NFC buffers */ +static void vf610_nfc_write_buf(struct mtd_info *mtd, const u_char *buf, + int len) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + uint c = nfc->column; + uint l; + + l = min((uint)len, mtd->writesize + mtd->oobsize - c); + nfc->column += l; + vf610_nfc_memcpy(nfc->regs + NFC_MAIN_AREA(0) + c, buf, l); +} + +/* Read byte from NFC buffers */ +static u8 vf610_nfc_read_byte(struct mtd_info *mtd) +{ + u8 tmp; + vf610_nfc_read_buf(mtd, &tmp, sizeof(tmp)); + return tmp; +} + +/* Read word from NFC buffers */ +static u16 vf610_nfc_read_word(struct mtd_info *mtd) +{ + u16 tmp; + vf610_nfc_read_buf(mtd, (u_char *)&tmp, sizeof(tmp)); + return tmp; +} + +/* If not provided, upper layers apply a fixed delay. */ +static int vf610_nfc_dev_ready(struct mtd_info *mtd) +{ + /* NFC handles R/B internally; always ready. */ + return 1; +} + +/* + * This function supports Vybrid only (MPC5125 would have full RB and four CS) + */ +static void vf610_nfc_select_chip(struct mtd_info *mtd, int chip) +{ +#ifdef CONFIG_VF610 + u32 tmp = vf610_nfc_read(mtd, NFC_ROW_ADDR); + tmp &= ~(ROW_ADDR_CHIP_SEL_RB_MASK | ROW_ADDR_CHIP_SEL_MASK); + tmp |= 1 << ROW_ADDR_CHIP_SEL_RB_SHIFT; + + if (chip == 0) + tmp |= 1 << ROW_ADDR_CHIP_SEL_SHIFT; + else if (chip == 1) + tmp |= 2 << ROW_ADDR_CHIP_SEL_SHIFT; + + vf610_nfc_write(mtd, NFC_ROW_ADDR, tmp); +#endif +} + +/* Count the number of 0's in buff upto max_bits */ +static inline int count_written_bits(uint8_t *buff, int size, int max_bits) +{ + uint32_t *buff32 = (uint32_t *)buff; + int k, written_bits = 0; + + for (k = 0; k < (size / 4); k++) { + written_bits += hweight32(~buff32[k]); + if (written_bits > max_bits) + break; + } + + return written_bits; +} + +static inline int vf610_nfc_correct_data(struct mtd_info *mtd, u_char *dat) +{ + struct vf610_nfc *nfc = mtd_to_nfc(mtd); + u8 ecc_status; + u8 ecc_count; + int flip; + + ecc_status = __raw_readb(nfc->regs + ECC_SRAM_ADDR * 8 + ECC_OFFSET); + ecc_count = ecc_status & ECC_ERR_COUNT; + if (!(ecc_status & ECC_STATUS_MASK)) + return ecc_count; + + /* If 'ecc_count' zero or less then buffer is all 0xff or erased. */ + flip = count_written_bits(dat, nfc->chip.ecc.size, ecc_count); + + /* ECC failed. */ + if (flip > ecc_count) { + nfc->page = -1; + return -1; + } + + /* Erased page. */ + memset(dat, 0xff, nfc->chip.ecc.size); + return 0; +} + + +static int vf610_nfc_read_page(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int oob_required, int page) +{ + int eccsize = chip->ecc.size; + int stat; + uint8_t *p = buf; + + + vf610_nfc_read_buf(mtd, p, eccsize); + + if (oob_required) + vf610_nfc_read_buf(mtd, chip->oob_poi, mtd->oobsize); + + stat = vf610_nfc_correct_data(mtd, p); + + if (stat < 0) + mtd->ecc_stats.failed++; + else + mtd->ecc_stats.corrected += stat; + + return 0; +} + +/* + * ECC will be calculated automatically + */ +static int vf610_nfc_write_page(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, int oob_required) +{ + vf610_nfc_write_buf(mtd, buf, mtd->writesize); + if (oob_required) + vf610_nfc_write_buf(mtd, chip->oob_poi, mtd->oobsize); + + return 0; +} + +struct vf610_nfc_config { + int hardware_ecc; + int width; + int flash_bbt; +}; + +static int vf610_nfc_nand_init(int devnum, void __iomem *addr) +{ + struct mtd_info *mtd = &nand_info[devnum]; + struct nand_chip *chip; + struct vf610_nfc *nfc; + int err = 0; + int page_sz; + struct vf610_nfc_config cfg = { + .hardware_ecc = 1, +#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT + .width = 16, +#else + .width = 8, +#endif + .flash_bbt = 1, + }; + + nfc = malloc(sizeof(*nfc)); + if (!nfc) { + printf(KERN_ERR "%s: Memory exhausted!\n", __func__); + return -ENOMEM; + } + + chip = &nfc->chip; + nfc->regs = addr; + + mtd->priv = chip; + chip->priv = nfc; + + if (cfg.width == 16) { + chip->options |= NAND_BUSWIDTH_16; + vf610_nfc_set(mtd, NFC_FLASH_CONFIG, CONFIG_16BIT); + } else { + chip->options &= ~NAND_BUSWIDTH_16; + vf610_nfc_clear(mtd, NFC_FLASH_CONFIG, CONFIG_16BIT); + } + + chip->dev_ready = vf610_nfc_dev_ready; + chip->cmdfunc = vf610_nfc_command; + chip->read_byte = vf610_nfc_read_byte; + chip->read_word = vf610_nfc_read_word; + chip->read_buf = vf610_nfc_read_buf; + chip->write_buf = vf610_nfc_write_buf; + chip->select_chip = vf610_nfc_select_chip; + + /* Bad block options. */ + if (cfg.flash_bbt) + chip->bbt_options = NAND_BBT_USE_FLASH | NAND_BBT_CREATE; + + /* Default to software ECC until flash ID. */ + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_MODE_MASK, + CONFIG_ECC_MODE_SHIFT, ECC_BYPASS); + + chip->bbt_td = &bbt_main_descr; + chip->bbt_md = &bbt_mirror_descr; + + page_sz = PAGE_2K + OOB_64; + page_sz += cfg.width == 16 ? 1 : 0; + vf610_nfc_write(mtd, NFC_SECTOR_SIZE, page_sz); + + /* Set configuration register. */ + vf610_nfc_clear(mtd, NFC_FLASH_CONFIG, CONFIG_ADDR_AUTO_INCR_BIT); + vf610_nfc_clear(mtd, NFC_FLASH_CONFIG, CONFIG_BUFNO_AUTO_INCR_BIT); + vf610_nfc_clear(mtd, NFC_FLASH_CONFIG, CONFIG_BOOT_MODE_BIT); + vf610_nfc_clear(mtd, NFC_FLASH_CONFIG, CONFIG_DMA_REQ_BIT); + vf610_nfc_set(mtd, NFC_FLASH_CONFIG, CONFIG_FAST_FLASH_BIT); + + /* Enable Idle IRQ */ + vf610_nfc_set(mtd, NFC_IRQ_STATUS, IDLE_EN_BIT); + + /* PAGE_CNT = 1 */ + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, CONFIG_PAGE_CNT_MASK, + CONFIG_PAGE_CNT_SHIFT, 1); + + /* Set ECC_STATUS offset */ + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_SRAM_ADDR_MASK, + CONFIG_ECC_SRAM_ADDR_SHIFT, ECC_SRAM_ADDR); + + /* first scan to find the device and get the page size */ + if (nand_scan_ident(mtd, CONFIG_SYS_MAX_NAND_DEVICE, NULL)) { + err = -ENXIO; + goto error; + } + + chip->ecc.mode = NAND_ECC_SOFT; /* default */ + + page_sz = mtd->writesize + mtd->oobsize; + + /* Single buffer only, max 256 OOB minus ECC status */ + if (page_sz > PAGE_2K + 256 - 8) { + dev_err(nfc->dev, "Unsupported flash size\n"); + err = -ENXIO; + goto error; + } + page_sz += cfg.width == 16 ? 1 : 0; + vf610_nfc_write(mtd, NFC_SECTOR_SIZE, page_sz); + + if (cfg.hardware_ecc) { + if (mtd->writesize != PAGE_2K && mtd->oobsize < 64) { + dev_err(nfc->dev, "Unsupported flash with hwecc\n"); + err = -ENXIO; + goto error; + } + + chip->ecc.layout = &vf610_nfc_ecc45; + + /* propagate ecc.layout to mtd_info */ + mtd->ecclayout = chip->ecc.layout; + chip->ecc.read_page = vf610_nfc_read_page; + chip->ecc.write_page = vf610_nfc_write_page; + chip->ecc.mode = NAND_ECC_HW; + + chip->ecc.bytes = 45; + chip->ecc.size = PAGE_2K; + chip->ecc.strength = 24; + + /* set ECC mode to 45 bytes OOB with 24 bits correction */ + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_MODE_MASK, + CONFIG_ECC_MODE_SHIFT, ECC_45_BYTE); + + /* Enable ECC_STATUS */ + vf610_nfc_set(mtd, NFC_FLASH_CONFIG, CONFIG_ECC_SRAM_REQ_BIT); + } + + /* second phase scan */ + err = nand_scan_tail(mtd); + if (err) + return err; + + err = nand_register(devnum); + if (err) + return err; + + return 0; + +error: + return err; +} + +void board_nand_init(void) +{ + int err = vf610_nfc_nand_init(0, (void __iomem *)CONFIG_SYS_NAND_BASE); + if (err) + printf("VF610 NAND init failed (err %d)\n", err); +}
Acked-by: Bill Pringlemeir bpringlemeir@nbsps.com
Thanks. I will merge it into u-boot-imx.
Best regards, Stefano Babic
Hi Stefan,
By applying I have seen some other minor issues. checkpatch reports some warnings, can you fix them ?
WARNING: line over 80 characters #200: FILE: drivers/mtd/nand/vf610_nfc.c:157: +#define mtd_to_nfc(_mtd) (struct vf610_nfc *)((struct nand_chip *)_mtd->priv)->priv;
CHECK: Alignment should match open parenthesis #367: FILE: drivers/mtd/nand/vf610_nfc.c:324: + vf610_nfc_set_field(mtd, NFC_COL_ADDR, COL_ADDR_MASK, + COL_ADDR_SHIFT, column);
CHECK: Alignment should match open parenthesis #371: FILE: drivers/mtd/nand/vf610_nfc.c:328: + vf610_nfc_set_field(mtd, NFC_ROW_ADDR, ROW_ADDR_MASK, + ROW_ADDR_SHIFT, page);
CHECK: Alignment should match open parenthesis #388: FILE: drivers/mtd/nand/vf610_nfc.c:345: + vf610_nfc_send_commands(nfc->regs, NAND_CMD_SEQIN, + command, PROGRAM_PAGE_CMD_CODE);
CHECK: Alignment should match open parenthesis #409: FILE: drivers/mtd/nand/vf610_nfc.c:366: + vf610_nfc_send_commands(nfc->regs, NAND_CMD_READ0, + NAND_CMD_READSTART, READ_PAGE_CMD_CODE);
CHECK: Alignment should match open parenthesis #417: FILE: drivers/mtd/nand/vf610_nfc.c:374: + vf610_nfc_send_commands(nfc->regs, command, + NAND_CMD_ERASE2, ERASE_CMD_CODE);
WARNING: line over 80 characters #428: FILE: drivers/mtd/nand/vf610_nfc.c:385: + vf610_nfc_send_command(nfc->regs, command, STATUS_READ_CMD_CODE);
WARNING: line over 80 characters #460: FILE: drivers/mtd/nand/vf610_nfc.c:417: + vf610_nfc_memcpy(buf, nfc->regs + NFC_MAIN_AREA(0) + c, l);
CHECK: Alignment should match open parenthesis #668: FILE: drivers/mtd/nand/vf610_nfc.c:625: + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_MODE_MASK,
CHECK: Alignment should match open parenthesis #690: FILE: drivers/mtd/nand/vf610_nfc.c:647: + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, CONFIG_PAGE_CNT_MASK, + CONFIG_PAGE_CNT_SHIFT, 1);
CHECK: Alignment should match open parenthesis #694: FILE: drivers/mtd/nand/vf610_nfc.c:651: + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_SRAM_ADDR_MASK,
CHECK: Alignment should match open parenthesis #737: FILE: drivers/mtd/nand/vf610_nfc.c:694: + vf610_nfc_set_field(mtd, NFC_FLASH_CONFIG, + CONFIG_ECC_MODE_MASK,
- Copyright 2009-2014 Freescale Semiconductor, Inc. and others
- Description: MPC5125, VF610, MCF54418 and Kinetis K70 Nand driver.
- Ported to U-Boot by Stefan Agner
- Based on RFC driver posted on Kernel Mailing list by Bill Pringlemeir
- Jason ported to M54418TWR and MVFA5.
- Authors: Stefan Agner stefan.agner@toradex.com
Bill Pringlemeir <bpringlemeir@nbsps.com>
Shaohui Xie <b21989@freescale.com>
Jason Jin <Jason.jin@freescale.com>
- Based on original driver mpc5121_nfc.c.
- This is free software; you can redistribute it and/or modify it
- under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Limitations:
- DMA not used.
- 2K pages or less.
- NFC_CMD2[CODE] values. See section:
- Briefly these are bitmasks of controller cycles.
- ECC status is stored at NFC_CFG[ECCADD] +4 for little-endian
- and +7 for big-endian SOC.
+struct vf610_nfc {
- struct mtd_info *mtd;
- struct nand_chip chip;
- void __iomem *regs;
- uint column;
- int spareonly;
- int page;
- /* Status and ID are in alternate locations. */
- int alt_buf;
- struct clk *clk;
The ending semicolon should be not part of the macro.
This adds NAND support for the Vybrid tower system (TWR-VF65GS10) provided by the vf610_nfc driver. Full 16-Bit bus width is supported. Also an aditional config vf610twr_nand is introduced which gets the environment from NAND. However, booting U-Boot from NAND is not yet possible due to missing boot configuration block (BCB).
Signed-off-by: Stefan Agner stefan@agner.ch --- board/freescale/vf610twr/vf610twr.c | 47 ++++++++++++++++++++++++++++++++++--- configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 3 +++ include/configs/vf610twr.h | 46 +++++++++++++++++++++++++++++++++++- 4 files changed, 93 insertions(+), 5 deletions(-) create mode 100644 configs/vf610twr_nand_defconfig
diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index 54a9f2c..4d09796 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -278,6 +278,39 @@ static void setup_iomux_i2c(void) imx_iomux_v3_setup_multiple_pads(i2c0_pads, ARRAY_SIZE(i2c0_pads)); }
+#ifdef CONFIG_NAND_VF610_NFC +static void setup_iomux_nfc(void) +{ + static const iomux_v3_cfg_t nfc_pads[] = { + VF610_PAD_PTD31__NF_IO15, + VF610_PAD_PTD30__NF_IO14, + VF610_PAD_PTD29__NF_IO13, + VF610_PAD_PTD28__NF_IO12, + VF610_PAD_PTD27__NF_IO11, + VF610_PAD_PTD26__NF_IO10, + VF610_PAD_PTD25__NF_IO9, + VF610_PAD_PTD24__NF_IO8, + VF610_PAD_PTD23__NF_IO7, + VF610_PAD_PTD22__NF_IO6, + VF610_PAD_PTD21__NF_IO5, + VF610_PAD_PTD20__NF_IO4, + VF610_PAD_PTD19__NF_IO3, + VF610_PAD_PTD18__NF_IO2, + VF610_PAD_PTD17__NF_IO1, + VF610_PAD_PTD16__NF_IO0, + VF610_PAD_PTB24__NF_WE_B, + VF610_PAD_PTB25__NF_CE0_B, + VF610_PAD_PTB27__NF_RE_B, + VF610_PAD_PTC26__NF_RB_B, + VF610_PAD_PTC27__NF_ALE, + VF610_PAD_PTC28__NF_CLE + }; + + imx_iomux_v3_setup_multiple_pads(nfc_pads, ARRAY_SIZE(nfc_pads)); +} +#endif + + static void setup_iomux_qspi(void) { static const iomux_v3_cfg_t qspi0_pads[] = { @@ -354,6 +387,8 @@ static void clock_init(void) CCM_CCGR7_SDHC1_CTRL_MASK); clrsetbits_le32(&ccm->ccgr9, CCM_REG_CTRL_MASK, CCM_CCGR9_FEC0_CTRL_MASK | CCM_CCGR9_FEC1_CTRL_MASK); + clrsetbits_le32(&ccm->ccgr10, CCM_REG_CTRL_MASK, + CCM_CCGR10_NFC_CTRL_MASK);
clrsetbits_le32(&anadig->pll2_ctrl, ANADIG_PLL2_CTRL_POWERDOWN, ANADIG_PLL2_CTRL_ENABLE | ANADIG_PLL2_CTRL_DIV_SELECT); @@ -373,14 +408,17 @@ static void clock_init(void) CCM_CACRR_IPG_CLK_DIV(1) | CCM_CACRR_BUS_CLK_DIV(2) | CCM_CACRR_ARM_CLK_DIV(0)); clrsetbits_le32(&ccm->cscmr1, CCM_REG_CTRL_MASK, - CCM_CSCMR1_ESDHC1_CLK_SEL(3) | CCM_CSCMR1_QSPI0_CLK_SEL(3)); + CCM_CSCMR1_ESDHC1_CLK_SEL(3) | CCM_CSCMR1_QSPI0_CLK_SEL(3) | + CCM_CSCMR1_NFC_CLK_SEL(0)); clrsetbits_le32(&ccm->cscdr1, CCM_REG_CTRL_MASK, CCM_CSCDR1_RMII_CLK_EN); clrsetbits_le32(&ccm->cscdr2, CCM_REG_CTRL_MASK, - CCM_CSCDR2_ESDHC1_EN | CCM_CSCDR2_ESDHC1_CLK_DIV(0)); + CCM_CSCDR2_ESDHC1_EN | CCM_CSCDR2_ESDHC1_CLK_DIV(0) | + CCM_CSCDR2_NFC_EN); clrsetbits_le32(&ccm->cscdr3, CCM_REG_CTRL_MASK, CCM_CSCDR3_QSPI0_EN | CCM_CSCDR3_QSPI0_DIV(1) | - CCM_CSCDR3_QSPI0_X2_DIV(1) | CCM_CSCDR3_QSPI0_X4_DIV(3)); + CCM_CSCDR3_QSPI0_X2_DIV(1) | CCM_CSCDR3_QSPI0_X4_DIV(3) | + CCM_CSCDR3_NFC_PRE_DIV(5)); clrsetbits_le32(&ccm->cscmr2, CCM_REG_CTRL_MASK, CCM_CSCMR2_RMII_CLK_SEL(0)); } @@ -411,6 +449,9 @@ int board_early_init_f(void) setup_iomux_enet(); setup_iomux_i2c(); setup_iomux_qspi(); +#ifdef CONFIG_NAND_VF610_NFC + setup_iomux_nfc(); +#endif
return 0; } diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 10e6432..7de374a 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -1,3 +1,3 @@ -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" CONFIG_ARM=y CONFIG_TARGET_VF610TWR=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig new file mode 100644 index 0000000..e78db26 --- /dev/null +++ b/configs/vf610twr_nand_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_ARM=y +CONFIG_TARGET_VF610TWR=y diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 0342550..6fd0b17 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -14,6 +14,7 @@
#define CONFIG_VF610
+#define CONFIG_SYS_GENERIC_BOARD #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
@@ -44,6 +45,41 @@
#undef CONFIG_CMD_IMLS
+/* NAND support */ +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS + +#ifdef CONFIG_CMD_NAND +#define CONFIG_NAND_VF610_NFC +#define CONFIG_SYS_NAND_SELF_INIT +#define CONFIG_USE_ARCH_MEMCPY +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR + +/* UBI */ +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_CMD_MTDPARTS +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_MTD_DEVICE +#define CONFIG_MTD_PARTITIONS + +/* Dynamic MTD partition support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define MTDIDS_DEFAULT "nand0=fsl_nfc" +#define MTDPARTS_DEFAULT "mtdparts=fsl_nfc:" \ + "128k(vf-bcb)ro," \ + "1408k(u-boot)ro," \ + "512k(u-boot-env)," \ + "4m(kernel)," \ + "512k(fdt)," \ + "-(rootfs)" +#endif + #define CONFIG_MMC #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 @@ -218,11 +254,19 @@ /* FLASH and environment organization */ #define CONFIG_SYS_NO_FLASH
+#ifdef CONFIG_ENV_IS_IN_MMC #define CONFIG_ENV_SIZE (8 * 1024) -#define CONFIG_ENV_IS_IN_MMC
#define CONFIG_ENV_OFFSET (12 * 64 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0 +#endif + +#ifdef CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_SIZE (64 * 2048) +#define CONFIG_ENV_SECT_SIZE (64 * 2048) +#define CONFIG_ENV_RANGE (512 * 1024) +#define CONFIG_ENV_OFFSET 0x180000 +#endif
#define CONFIG_OF_LIBFDT #define CONFIG_CMD_BOOTZ
Bill Pringlemeir
Stefan Agner
Stefano Babic
