[U-Boot] Flashing SPI NOR via DFU
I am trying to use DFU to flash the SPI NOR on a mx6qsabresd. These are the changes I made:
--- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -80,6 +80,7 @@ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ "console=" CONFIG_CONSOLE_DEV "\0" \ + "dfu_alt_info=u-boot raw 0x0 0xc0000\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ @@ -238,6 +239,15 @@ #define CONFIG_G_DNL_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_PRODUCT_NUM 0xa4a5 #define CONFIG_G_DNL_MANUFACTURER "FSL" + +/* USB Device Firmware Update support */ +#define CONFIG_CMD_DFU +#define CONFIG_USB_FUNCTION_DFU +#define CONFIG_DFU_MMC +#define CONFIG_DFU_SF +#define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M +#define DFU_DEFAULT_POLL_TIMEOUT 300
Then I run: => dfu 0 sf 0:0:25000000:0 SF: Detected M25P32 with page size 256 Bytes, erase size 64 KiB, total 4 MiB
and on the PC host: sudo dfu-util -D u-boot.imx -a u-boot dfu-util 0.8
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc. Copyright 2010-2014 Tormod Volden and Stefan Schmidt This program is Free Software and has ABSOLUTELY NO WARRANTY Please report bugs to dfu-util@lists.gnumonks.org
dfu-util: Invalid DFU suffix signature dfu-util: A valid DFU suffix will be required in a future dfu-util release!!! Opening DFU capable USB device... ID 0525:a4a5 Run-time device DFU version 0110 Claiming USB DFU Interface... Setting Alternate Setting #0 ... Determining device status: state = dfuIDLE, status = 0 dfuIDLE, continuing DFU mode device DFU version 0110 Device returned transfer size 4096 Copying data from PC to DFU device Download [=========================] 100% 478208 bytes Download done. state(7) = dfuMANIFEST, status(0) = No error condition is present state(10) = dfuERROR, status(14) = Something went wrong, but the device does not know what it was Done!
and the mx6qsabresd hangs at the download mark: ########
I used the dfu_alt_info from Boundary Devices' U-boot.
I am able to flash the SD card (need to adjust dfu_alt_info in this case), so DFU is working.
Is there anything I am missing to get SPI NOR to be flashed via DFU?
Thanks,
Fabio Estevam
Ok, so I fixed this first error and sent a patch for it.
Regards,
Fabio Estevam
Fabio Estevam
