[PATCH 00/11] Fuzzing and ASAN for sandbox
This series sets up a basic fuzzing infrastructure that works with sandbox. The example fuzz test towards the end of the series will find something pretty quickly (that something is fixed by "virtio_ring: Maintain a shadow copy of descriptors" from another series).
There is some refactoring to stop using '.' prefixed sections that elf defines as being for system use and clang's ASAN instrumentation happily adds redzones between, but that's not what we want for things like linker lists where the linker script has carefully placed the sections contiguously.
It may require patches from the "Fix misc ASAN reports" series to be applied as I've already dealt with the first set of ASAN reports from running the tests.
Andrew Scull (11): sandbox: Set the EFI symbols in linker script sandbox: Migrate getopt section to linker list linker_lists: Rename sections to remove . prefix sandbox: Add support for Address Sanitizer fuzzing_engine: Add fuzzing engine uclass test: fuzz: Add framework for fuzzing sandbox: Decouple program entry from sandbox init sandbox: Add libfuzzer integration sandbox: Implement fuzzing engine driver fuzz: virtio: Add fuzzer for vring RFC: Hack dlmalloc to poison memory
Kconfig | 15 + arch/Kconfig | 2 + arch/arc/cpu/u-boot.lds | 4 +- arch/arm/config.mk | 4 +- arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds | 4 +- arch/arm/cpu/armv7/sunxi/u-boot-spl.lds | 4 +- arch/arm/cpu/armv8/u-boot-spl.lds | 4 +- arch/arm/cpu/armv8/u-boot.lds | 4 +- arch/arm/cpu/u-boot-spl.lds | 4 +- arch/arm/cpu/u-boot.lds | 6 +- arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 2 +- arch/arm/mach-at91/armv7/u-boot-spl.lds | 2 +- arch/arm/mach-omap2/u-boot-spl.lds | 4 +- arch/arm/mach-orion5x/u-boot-spl.lds | 4 +- arch/arm/mach-rockchip/u-boot-tpl-v8.lds | 4 +- arch/arm/mach-zynq/u-boot-spl.lds | 4 +- arch/arm/mach-zynq/u-boot.lds | 4 +- arch/m68k/cpu/u-boot.lds | 4 +- arch/microblaze/cpu/u-boot-spl.lds | 4 +- arch/microblaze/cpu/u-boot.lds | 4 +- arch/mips/config.mk | 2 +- arch/mips/cpu/u-boot-spl.lds | 4 +- arch/mips/cpu/u-boot.lds | 4 +- arch/nds32/cpu/n1213/u-boot.lds | 4 +- arch/nios2/cpu/u-boot.lds | 4 +- arch/powerpc/cpu/mpc83xx/u-boot.lds | 4 +- arch/powerpc/cpu/mpc85xx/u-boot-nand.lds | 4 +- arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds | 4 +- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 4 +- arch/powerpc/cpu/mpc85xx/u-boot.lds | 4 +- arch/riscv/cpu/u-boot-spl.lds | 4 +- arch/riscv/cpu/u-boot.lds | 4 +- arch/sandbox/config.mk | 15 +- arch/sandbox/cpu/os.c | 97 +++++- arch/sandbox/cpu/start.c | 12 +- arch/sandbox/cpu/u-boot-spl.lds | 10 +- arch/sandbox/cpu/u-boot.lds | 42 +-- arch/sandbox/dts/test.dts | 4 + arch/sandbox/include/asm/fuzzing_engine.h | 25 ++ arch/sandbox/include/asm/getopt.h | 19 +- arch/sandbox/include/asm/main.h | 18 ++ arch/sandbox/include/asm/sections.h | 25 -- arch/sandbox/lib/Makefile | 2 +- arch/sandbox/lib/sections.c | 13 - arch/sh/cpu/u-boot.lds | 4 +- arch/x86/cpu/u-boot-64.lds | 6 +- arch/x86/cpu/u-boot-spl.lds | 6 +- arch/x86/cpu/u-boot.lds | 6 +- arch/x86/lib/elf_ia32_efi.lds | 4 +- arch/x86/lib/elf_x86_64_efi.lds | 4 +- arch/xtensa/cpu/u-boot.lds | 2 +- arch/xtensa/include/asm/ldscript.h | 4 +- board/compulab/cm_t335/u-boot.lds | 4 +- board/cssi/MCR3000/u-boot.lds | 4 +- .../davinci/da8xxevm/u-boot-spl-da850evm.lds | 2 +- board/qualcomm/dragonboard820c/u-boot.lds | 4 +- board/samsung/common/exynos-uboot-spl.lds | 4 +- board/synopsys/iot_devkit/u-boot.lds | 4 +- board/ti/am335x/u-boot.lds | 4 +- board/vscom/baltos/u-boot.lds | 4 +- common/dlmalloc.c | 284 +++++++++++++++--- configs/sandbox_defconfig | 1 + doc/api/linker_lists.rst | 22 +- doc/develop/commands.rst | 4 +- doc/develop/driver-model/of-plat.rst | 4 +- drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/fuzzing_engine/Kconfig | 17 ++ drivers/fuzzing_engine/Makefile | 8 + .../fuzzing_engine/fuzzing_engine-uclass.c | 28 ++ .../fuzzing_engine/sandbox_fuzzing_engine.c | 35 +++ include/compiler.h | 1 + include/dm/uclass-id.h | 1 + include/fuzzing_engine.h | 51 ++++ include/linker_lists.h | 18 +- include/linux/types.h | 1 + include/test/fuzz.h | 51 ++++ test/Makefile | 1 + test/fuzz/Makefile | 8 + test/fuzz/cmd_fuzz.c | 82 +++++ test/fuzz/virtio.c | 72 +++++ 81 files changed, 909 insertions(+), 264 deletions(-) create mode 100644 arch/sandbox/include/asm/fuzzing_engine.h create mode 100644 arch/sandbox/include/asm/main.h delete mode 100644 arch/sandbox/lib/sections.c create mode 100644 drivers/fuzzing_engine/Kconfig create mode 100644 drivers/fuzzing_engine/Makefile create mode 100644 drivers/fuzzing_engine/fuzzing_engine-uclass.c create mode 100644 drivers/fuzzing_engine/sandbox_fuzzing_engine.c create mode 100644 include/fuzzing_engine.h create mode 100644 include/test/fuzz.h create mode 100644 test/fuzz/Makefile create mode 100644 test/fuzz/cmd_fuzz.c create mode 100644 test/fuzz/virtio.c
The sandbox doesn't populate the EFI lists so explicitly set the list start and end symbols to indicate that the lists are empty. This simplifies the linker scripts, removed references to non-existant sections and removes '.' prefixed sections that conflicted with clang's ASAN.
Signed-off-by: Andrew Scull ascull@google.com --- arch/sandbox/cpu/u-boot.lds | 32 +++++--------------------------- arch/sandbox/lib/Makefile | 2 +- arch/sandbox/lib/sections.c | 13 ------------- 3 files changed, 6 insertions(+), 41 deletions(-) delete mode 100644 arch/sandbox/lib/sections.c
diff --git a/arch/sandbox/cpu/u-boot.lds b/arch/sandbox/cpu/u-boot.lds index 6d710618f5..dd675cc3d2 100644 --- a/arch/sandbox/cpu/u-boot.lds +++ b/arch/sandbox/cpu/u-boot.lds @@ -19,33 +19,11 @@ SECTIONS *(.u_boot_sandbox_getopt_end) }
- .__efi_runtime_start : { - *(.__efi_runtime_start) - } - - .efi_runtime : { - *(efi_runtime_text) - *(efi_runtime_data) - } - - .__efi_runtime_stop : { - *(.__efi_runtime_stop) - } - - .efi_runtime_rel_start : - { - *(.__efi_runtime_rel_start) - } - - .efi_runtime_rel : { - *(.relefi_runtime_text) - *(.relefi_runtime_data) - } - - .efi_runtime_rel_stop : - { - *(.__efi_runtime_rel_stop) - } + /* Sandbox has empty EFI runtime lists. */ + __efi_runtime_start = .; + __efi_runtime_stop = __efi_runtime_start; + __efi_runtime_rel_start = .; + __efi_runtime_rel_stop = __efi_runtime_rel_start;
.dynsym : { diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index a2bc5a7ee6..05f06180f8 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -5,7 +5,7 @@ # (C) Copyright 2002-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
-obj-y += fdt_fixup.o interrupts.o sections.o +obj-y += fdt_fixup.o interrupts.o obj-$(CONFIG_PCI) += pci_io.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o diff --git a/arch/sandbox/lib/sections.c b/arch/sandbox/lib/sections.c deleted file mode 100644 index 2559eeea38..0000000000 --- a/arch/sandbox/lib/sections.c +++ /dev/null @@ -1,13 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Albert ARIBAUD albert.u.boot@aribaud.net - * - */ -#include <linux/compiler.h> - -char __efi_runtime_start[0] __section(".__efi_runtime_start"); -char __efi_runtime_stop[0] __section(".__efi_runtime_stop"); -char __efi_runtime_rel_start[0] - __section(".__efi_runtime_rel_start"); -char __efi_runtime_rel_stop[0] - __section(".__efi_runtime_rel_stop");
Hi Andrew,
I guess this it OK but it does make sandbox different in the link scripts. Would it be possible to change the naming to avoid the ASAN thing (which I don't understand)?
In u-boot.map I see:
10636 .text.efi_runtime 10637 0x00000000000df50a 0x72d /tmp/cctuEBRS.ltrans19.ltrans.o 10638 0x00000000000df50a efi_get_time 10639 0x00000000000df519 efi_set_time 10640 0x00000000000df528 efi_unimplemented.lto_priv.0 10641 0x00000000000df54a efi_update_capsule_unsupported 10642 0x00000000000df559 efi_query_capsule_caps_unsupported
So there are definively functions that should go between __efi_runtime_start and __efi_runtime_stop.
If ._efi_runtime_start == .__efi_runtime_stop, there is a bug in the linker script. Deleting the symbols is the wrong way to deal with this deficiency. Instead ensure correct placement of the functions marked as __efi_runtime and the data marked as __efi_runtime_data.
Best regards
Heinrich
- .efi_runtime : {
*(efi_runtime_text)
*(efi_runtime_data)
.dynsym : {
- Copyright 2013 Albert ARIBAUD albert.u.boot@aribaud.net
I notice you point at the .text.efi_runtime section rather than the .efi_runtime_text section that's listed in the sandbox linker script. Looking at the other architectures, sandbox doesn't match them, through whatever course of history, but it sounds like it's meant to. I can try updating this patch to use the blocks below and see how sandbox handles it.
.efi_runtime : { *(.text.efi_runtime*) *(.rodata.efi_runtime*) *(.data.efi_runtime*) }
.efi_runtime_rel : { *(.rel*.efi_runtime) *(.rel*.efi_runtime.*) }
Best regards
Heinrich
.efi_runtime : {
*(efi_runtime_text)
*(efi_runtime_data)
__efi_runtime_rel_stop = __efi_runtime_rel_start; .dynsym : {
Use the common infrastructure to create a linker list of the sandbox command line flags rather than using a custom method.
The list is changed from containing pointers to containing structs and the uses are updated accordingly.
Signed-off-by: Andrew Scull ascull@google.com --- arch/sandbox/cpu/os.c | 21 ++++++++++----------- arch/sandbox/cpu/start.c | 10 +++++----- arch/sandbox/cpu/u-boot-spl.lds | 6 ------ arch/sandbox/cpu/u-boot.lds | 6 ------ arch/sandbox/include/asm/getopt.h | 19 ++++++++++++------- arch/sandbox/include/asm/sections.h | 25 ------------------------- 6 files changed, 27 insertions(+), 60 deletions(-)
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index d83c862182..72a72029f2 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -424,9 +424,8 @@ static struct option *long_opts;
int os_parse_args(struct sandbox_state *state, int argc, char *argv[]) { - struct sandbox_cmdline_option **sb_opt = - __u_boot_sandbox_option_start(); - size_t num_options = __u_boot_sandbox_option_count(); + struct sandbox_cmdline_option *sb_opt = SANDBOX_CMDLINE_OPT_START(); + size_t num_options = SANDBOX_CMDLINE_OPT_COUNT(); size_t i;
int hidden_short_opt; @@ -455,17 +454,17 @@ int os_parse_args(struct sandbox_state *state, int argc, char *argv[]) hidden_short_opt = 0x100; si = 0; for (i = 0; i < num_options; ++i) { - long_opts[i].name = sb_opt[i]->flag; - long_opts[i].has_arg = sb_opt[i]->has_arg ? + long_opts[i].name = sb_opt[i].flag; + long_opts[i].has_arg = sb_opt[i].has_arg ? required_argument : no_argument; long_opts[i].flag = NULL;
- if (sb_opt[i]->flag_short) { - short_opts[si++] = long_opts[i].val = sb_opt[i]->flag_short; + if (sb_opt[i].flag_short) { + short_opts[si++] = long_opts[i].val = sb_opt[i].flag_short; if (long_opts[i].has_arg == required_argument) short_opts[si++] = ':'; } else - long_opts[i].val = sb_opt[i]->flag_short = hidden_short_opt++; + long_opts[i].val = sb_opt[i].flag_short = hidden_short_opt++; } short_opts[si] = '\0';
@@ -480,9 +479,9 @@ int os_parse_args(struct sandbox_state *state, int argc, char *argv[]) */ while ((c = getopt_long(argc, argv, short_opts, long_opts, NULL)) != -1) { for (i = 0; i < num_options; ++i) { - if (sb_opt[i]->flag_short == c) { - if (sb_opt[i]->callback(state, optarg)) { - state->parse_err = sb_opt[i]->flag; + if (sb_opt[i].flag_short == c) { + if (sb_opt[i].callback(state, optarg)) { + state->parse_err = sb_opt[i].flag; return 0; } break; diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 13b0731ec3..5cb47e1156 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -58,9 +58,8 @@ static int h_compare_opt(const void *p1, const void *p2) int sandbox_early_getopt_check(void) { struct sandbox_state *state = state_get_current(); - struct sandbox_cmdline_option **sb_opt = - __u_boot_sandbox_option_start(); - size_t num_options = __u_boot_sandbox_option_count(); + struct sandbox_cmdline_option *sb_opt = SANDBOX_CMDLINE_OPT_START(); + size_t num_options = SANDBOX_CMDLINE_OPT_COUNT(); size_t i; int max_arg_len, max_noarg_len; struct sandbox_cmdline_option **sorted_opt; @@ -84,7 +83,7 @@ int sandbox_early_getopt_check(void)
max_arg_len = 0; for (i = 0; i < num_options; ++i) - max_arg_len = max((int)strlen(sb_opt[i]->flag), max_arg_len); + max_arg_len = max((int)strlen(sb_opt[i].flag), max_arg_len); max_noarg_len = max_arg_len + 7;
/* Sort the options */ @@ -94,7 +93,8 @@ int sandbox_early_getopt_check(void) printf("No memory to sort options\n"); os_exit(1); } - memcpy(sorted_opt, sb_opt, size); + for (i = 0; i < num_options; ++i) + sorted_opt[i] = &sb_opt[i]; qsort(sorted_opt, num_options, sizeof(*sorted_opt), h_compare_opt);
for (i = 0; i < num_options; ++i) { diff --git a/arch/sandbox/cpu/u-boot-spl.lds b/arch/sandbox/cpu/u-boot-spl.lds index 6754f4ef6c..5c19d090cb 100644 --- a/arch/sandbox/cpu/u-boot-spl.lds +++ b/arch/sandbox/cpu/u-boot-spl.lds @@ -20,12 +20,6 @@ SECTIONS *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.priv_data*))) __priv_data_end = .; } - - _u_boot_sandbox_getopt : { - *(.u_boot_sandbox_getopt_start) - KEEP(*(.u_boot_sandbox_getopt)) - *(.u_boot_sandbox_getopt_end) - } }
INSERT AFTER .data; diff --git a/arch/sandbox/cpu/u-boot.lds b/arch/sandbox/cpu/u-boot.lds index dd675cc3d2..c3fc67a15b 100644 --- a/arch/sandbox/cpu/u-boot.lds +++ b/arch/sandbox/cpu/u-boot.lds @@ -13,12 +13,6 @@ SECTIONS KEEP(*(SORT(.u_boot_list*))); }
- _u_boot_sandbox_getopt : { - *(.u_boot_sandbox_getopt_start) - *(.u_boot_sandbox_getopt) - *(.u_boot_sandbox_getopt_end) - } - /* Sandbox has empty EFI runtime lists. */ __efi_runtime_start = .; __efi_runtime_stop = __efi_runtime_start; diff --git a/arch/sandbox/include/asm/getopt.h b/arch/sandbox/include/asm/getopt.h index d2145ad6e2..a4b510bd20 100644 --- a/arch/sandbox/include/asm/getopt.h +++ b/arch/sandbox/include/asm/getopt.h @@ -9,6 +9,8 @@ #ifndef __SANDBOX_GETOPT_H #define __SANDBOX_GETOPT_H
+#include <linker_lists.h> + struct sandbox_state;
/* @@ -36,18 +38,13 @@ struct sandbox_cmdline_option { * magic junk that makes this all work. */ #define _SANDBOX_CMDLINE_OPT(f, s, ha, h) \ - static struct sandbox_cmdline_option sandbox_cmdline_option_##f = { \ + ll_entry_declare(struct sandbox_cmdline_option, f, sandbox_getopt) = { \ .flag = #f, \ .flag_short = s, \ .help = h, \ .has_arg = ha, \ .callback = sandbox_cmdline_cb_##f, \ - }; \ - /* Ppointer to the struct in a special section for the linker script */ \ - static __used __section(".u_boot_sandbox_getopt") \ - struct sandbox_cmdline_option \ - *sandbox_cmdline_option_##f##_ptr = \ - &sandbox_cmdline_option_##f + }
/** * Macros for end code to declare new command line flags. @@ -69,4 +66,12 @@ struct sandbox_cmdline_option { */ #define SANDBOX_CMDLINE_OPT_SHORT(f, s, ha, h) _SANDBOX_CMDLINE_OPT(f, s, ha, h)
+/** Get the start of the list of command line flags. */ +#define SANDBOX_CMDLINE_OPT_START() \ + ll_entry_start(struct sandbox_cmdline_option, sandbox_getopt) + +/** Get the number of entries in the command line flags list. */ +#define SANDBOX_CMDLINE_OPT_COUNT() \ + ll_entry_count(struct sandbox_cmdline_option, sandbox_getopt) + #endif diff --git a/arch/sandbox/include/asm/sections.h b/arch/sandbox/include/asm/sections.h index f4351ae7db..c335cb2061 100644 --- a/arch/sandbox/include/asm/sections.h +++ b/arch/sandbox/include/asm/sections.h @@ -11,29 +11,4 @@
#include <asm-generic/sections.h>
-struct sandbox_cmdline_option; - -static inline struct sandbox_cmdline_option ** -__u_boot_sandbox_option_start(void) -{ - static char start[0] __aligned(4) __attribute__((unused)) - __section(".u_boot_sandbox_getopt_start"); - - return (struct sandbox_cmdline_option **)&start; -} - -static inline struct sandbox_cmdline_option ** -__u_boot_sandbox_option_end(void) -{ - static char end[0] __aligned(4) __attribute__((unused)) - __section(".u_boot_sandbox_getopt_end"); - - return (struct sandbox_cmdline_option **)&end; -} - -static inline size_t __u_boot_sandbox_option_count(void) -{ - return __u_boot_sandbox_option_end() - __u_boot_sandbox_option_start(); -} - #endif
Rename the sections used to implement linker lists so they begin with '__u_boot_list' rather than '.u_boot_list'. The double underscore at the start is still distinct from the single underscore used by the symbol names.
Having a '.' in the section names conflicts with clang's ASAN instrumentation which tries to add redzones between the linker list elements, causing expected accesses to fail. However, clang doesn't try to add redzones to user sections, which are names with all alphanumeric and underscore characters.
Signed-off-by: Andrew Scull ascull@google.com --- arch/arc/cpu/u-boot.lds | 4 ++-- arch/arm/config.mk | 4 ++-- arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds | 4 ++-- arch/arm/cpu/armv7/sunxi/u-boot-spl.lds | 4 ++-- arch/arm/cpu/armv8/u-boot-spl.lds | 4 ++-- arch/arm/cpu/armv8/u-boot.lds | 4 ++-- arch/arm/cpu/u-boot-spl.lds | 4 ++-- arch/arm/cpu/u-boot.lds | 6 ++--- arch/arm/mach-at91/arm926ejs/u-boot-spl.lds | 2 +- arch/arm/mach-at91/armv7/u-boot-spl.lds | 2 +- arch/arm/mach-omap2/u-boot-spl.lds | 4 ++-- arch/arm/mach-orion5x/u-boot-spl.lds | 4 ++-- arch/arm/mach-rockchip/u-boot-tpl-v8.lds | 4 ++-- arch/arm/mach-zynq/u-boot-spl.lds | 4 ++-- arch/arm/mach-zynq/u-boot.lds | 4 ++-- arch/m68k/cpu/u-boot.lds | 4 ++-- arch/microblaze/cpu/u-boot-spl.lds | 4 ++-- arch/microblaze/cpu/u-boot.lds | 4 ++-- arch/mips/config.mk | 2 +- arch/mips/cpu/u-boot-spl.lds | 4 ++-- arch/mips/cpu/u-boot.lds | 4 ++-- arch/nds32/cpu/n1213/u-boot.lds | 4 ++-- arch/nios2/cpu/u-boot.lds | 4 ++-- arch/powerpc/cpu/mpc83xx/u-boot.lds | 4 ++-- arch/powerpc/cpu/mpc85xx/u-boot-nand.lds | 4 ++-- arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds | 4 ++-- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 4 ++-- arch/powerpc/cpu/mpc85xx/u-boot.lds | 4 ++-- arch/riscv/cpu/u-boot-spl.lds | 4 ++-- arch/riscv/cpu/u-boot.lds | 4 ++-- arch/sandbox/config.mk | 4 ++-- arch/sandbox/cpu/u-boot-spl.lds | 4 ++-- arch/sandbox/cpu/u-boot.lds | 4 ++-- arch/sh/cpu/u-boot.lds | 4 ++-- arch/x86/cpu/u-boot-64.lds | 6 ++--- arch/x86/cpu/u-boot-spl.lds | 6 ++--- arch/x86/cpu/u-boot.lds | 6 ++--- arch/x86/lib/elf_ia32_efi.lds | 4 ++-- arch/x86/lib/elf_x86_64_efi.lds | 4 ++-- arch/xtensa/cpu/u-boot.lds | 2 +- arch/xtensa/include/asm/ldscript.h | 4 ++-- board/compulab/cm_t335/u-boot.lds | 4 ++-- board/cssi/MCR3000/u-boot.lds | 4 ++-- .../davinci/da8xxevm/u-boot-spl-da850evm.lds | 2 +- board/qualcomm/dragonboard820c/u-boot.lds | 4 ++-- board/samsung/common/exynos-uboot-spl.lds | 4 ++-- board/synopsys/iot_devkit/u-boot.lds | 4 ++-- board/ti/am335x/u-boot.lds | 4 ++-- board/vscom/baltos/u-boot.lds | 4 ++-- doc/api/linker_lists.rst | 22 +++++++++---------- doc/develop/commands.rst | 4 ++-- doc/develop/driver-model/of-plat.rst | 4 ++-- include/linker_lists.h | 18 +++++++-------- 53 files changed, 121 insertions(+), 121 deletions(-)
diff --git a/arch/arc/cpu/u-boot.lds b/arch/arc/cpu/u-boot.lds index e12145c768..9f2973da65 100644 --- a/arch/arc/cpu/u-boot.lds +++ b/arch/arc/cpu/u-boot.lds @@ -39,8 +39,8 @@ SECTIONS }
. = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); }
. = ALIGN(4); diff --git a/arch/arm/config.mk b/arch/arm/config.mk index b107b1af27..b3548ce243 100644 --- a/arch/arm/config.mk +++ b/arch/arm/config.mk @@ -141,11 +141,11 @@ endif # limit ourselves to the sections we want in the .bin. ifdef CONFIG_ARM64 OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .data \ - -j .u_boot_list -j .rela.dyn -j .got -j .got.plt \ + -j __u_boot_list -j .rela.dyn -j .got -j .got.plt \ -j .binman_sym_table -j .text_rest else OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .hash \ - -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn \ + -j .data -j .got -j .got.plt -j __u_boot_list -j .rel.dyn \ -j .binman_sym_table -j .text_rest endif
diff --git a/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds b/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds index 9a000ac5d3..c108736811 100644 --- a/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds +++ b/arch/arm/cpu/arm926ejs/sunxi/u-boot-spl.lds @@ -29,8 +29,8 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } > .sram
. = ALIGN(4); diff --git a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds index 942c29fc95..306a4ddf3c 100644 --- a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds +++ b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds @@ -38,8 +38,8 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); diff --git a/arch/arm/cpu/armv8/u-boot-spl.lds b/arch/arm/cpu/armv8/u-boot-spl.lds index 730eb93dbc..d02b788e60 100644 --- a/arch/arm/cpu/armv8/u-boot-spl.lds +++ b/arch/arm/cpu/armv8/u-boot-spl.lds @@ -46,9 +46,9 @@ SECTIONS } >.sram #endif
- .u_boot_list : { + __u_boot_list : { . = ALIGN(8); - KEEP(*(SORT(.u_boot_list*))); + KEEP(*(SORT(__u_boot_list*))); } >.sram
.image_copy_end : { diff --git a/arch/arm/cpu/armv8/u-boot.lds b/arch/arm/cpu/armv8/u-boot.lds index 2554980595..8fe4682dd2 100644 --- a/arch/arm/cpu/armv8/u-boot.lds +++ b/arch/arm/cpu/armv8/u-boot.lds @@ -109,8 +109,8 @@ SECTIONS . = .;
. = ALIGN(8); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); }
. = ALIGN(8); diff --git a/arch/arm/cpu/u-boot-spl.lds b/arch/arm/cpu/u-boot-spl.lds index 97899a567f..fb2189d50d 100644 --- a/arch/arm/cpu/u-boot-spl.lds +++ b/arch/arm/cpu/u-boot-spl.lds @@ -32,8 +32,8 @@ SECTIONS }
. = ALIGN(4); diff --git a/arch/arm/cpu/u-boot.lds b/arch/arm/cpu/u-boot.lds index 0eb164d2e6..f25f72b2e0 100644 --- a/arch/arm/cpu/u-boot.lds +++ b/arch/arm/cpu/u-boot.lds @@ -15,7 +15,7 @@ ENTRY(_start) SECTIONS { #ifndef CONFIG_CMDLINE - /DISCARD/ : { *(.u_boot_list_2_cmd_*) } + /DISCARD/ : { *(__u_boot_list_2_cmd_*) } #endif #if defined(CONFIG_ARMV7_SECURE_BASE) && defined(CONFIG_ARMV7_NONSEC) /* @@ -149,8 +149,8 @@ SECTIONS . = .;
. = ALIGN(4); diff --git a/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds index 74f6355229..1a8bf94dee 100644 --- a/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds +++ b/arch/arm/mach-at91/arm926ejs/u-boot-spl.lds @@ -29,7 +29,7 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); - .u_boot_list : { KEEP(*(SORT(.u_boot_list*))) } > .sram + __u_boot_list : { KEEP(*(SORT(__u_boot_list*))) } > .sram
. = ALIGN(4); __image_copy_end = .; diff --git a/arch/arm/mach-at91/armv7/u-boot-spl.lds b/arch/arm/mach-at91/armv7/u-boot-spl.lds index 950ea55d7c..6ca725fc4c 100644 --- a/arch/arm/mach-at91/armv7/u-boot-spl.lds +++ b/arch/arm/mach-at91/armv7/u-boot-spl.lds @@ -36,7 +36,7 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); __image_copy_end = .; diff --git a/arch/arm/mach-omap2/u-boot-spl.lds b/arch/arm/mach-omap2/u-boot-spl.lds index 88d81f9b98..1d6e5d45b4 100644 --- a/arch/arm/mach-omap2/u-boot-spl.lds +++ b/arch/arm/mach-omap2/u-boot-spl.lds @@ -33,8 +33,8 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } >.sram
. = ALIGN(4); diff --git a/arch/arm/mach-orion5x/u-boot-spl.lds b/arch/arm/mach-orion5x/u-boot-spl.lds index a537fe0295..154bb12060 100644 --- a/arch/arm/mach-orion5x/u-boot-spl.lds +++ b/arch/arm/mach-orion5x/u-boot-spl.lds @@ -41,8 +41,8 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.nor
. = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } > .nor
. = ALIGN(4); diff --git a/arch/arm/mach-rockchip/u-boot-tpl-v8.lds b/arch/arm/mach-rockchip/u-boot-tpl-v8.lds index 9869972e22..74618eba59 100644 --- a/arch/arm/mach-rockchip/u-boot-tpl-v8.lds +++ b/arch/arm/mach-rockchip/u-boot-tpl-v8.lds @@ -39,9 +39,9 @@ SECTIONS *(.data*) }
.image_copy_end : { diff --git a/arch/arm/mach-zynq/u-boot-spl.lds b/arch/arm/mach-zynq/u-boot-spl.lds index 106d2e390b..8c18d3f91f 100644 --- a/arch/arm/mach-zynq/u-boot-spl.lds +++ b/arch/arm/mach-zynq/u-boot-spl.lds @@ -37,8 +37,8 @@ SECTIONS } > .sram
. = ALIGN(4); diff --git a/arch/arm/mach-zynq/u-boot.lds b/arch/arm/mach-zynq/u-boot.lds index 91c32e89e8..a5169fd915 100644 --- a/arch/arm/mach-zynq/u-boot.lds +++ b/arch/arm/mach-zynq/u-boot.lds @@ -54,8 +54,8 @@ SECTIONS . = .;
. = ALIGN(4); diff --git a/arch/m68k/cpu/u-boot.lds b/arch/m68k/cpu/u-boot.lds index affb2d9374..133f79150b 100644 --- a/arch/m68k/cpu/u-boot.lds +++ b/arch/m68k/cpu/u-boot.lds @@ -60,8 +60,8 @@ SECTIONS . = .;
. = .; diff --git a/arch/microblaze/cpu/u-boot-spl.lds b/arch/microblaze/cpu/u-boot-spl.lds index 7883a64b15..4ac5a21524 100644 --- a/arch/microblaze/cpu/u-boot-spl.lds +++ b/arch/microblaze/cpu/u-boot-spl.lds @@ -37,8 +37,8 @@ SECTIONS }
. = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } __init_end = . ;
diff --git a/arch/microblaze/cpu/u-boot.lds b/arch/microblaze/cpu/u-boot.lds index 2b316cc7f5..8bd515b099 100644 --- a/arch/microblaze/cpu/u-boot.lds +++ b/arch/microblaze/cpu/u-boot.lds @@ -41,8 +41,8 @@ SECTIONS }
diff --git a/arch/mips/config.mk b/arch/mips/config.mk index faf4129ac1..04f3627805 100644 --- a/arch/mips/config.mk +++ b/arch/mips/config.mk @@ -65,6 +65,6 @@ PLATFORM_CPPFLAGS += -msoft-float KBUILD_LDFLAGS += -G 0 -static -n -nostdlib PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections LDFLAGS_FINAL += --gc-sections -OBJCOPYFLAGS += -j .text -j .rodata -j .data -j .u_boot_list +OBJCOPYFLAGS += -j .text -j .rodata -j .data -j __u_boot_list
LDFLAGS_STANDALONE += --gc-sections diff --git a/arch/mips/cpu/u-boot-spl.lds b/arch/mips/cpu/u-boot-spl.lds index 28ea4f2a48..194398be85 100644 --- a/arch/mips/cpu/u-boot-spl.lds +++ b/arch/mips/cpu/u-boot-spl.lds @@ -29,8 +29,8 @@ SECTIONS
#if defined(CONFIG_SPL_DM) || defined(CONFIG_SPL_LOADER_SUPPORT) . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } > .spl_mem #endif
diff --git a/arch/mips/cpu/u-boot.lds b/arch/mips/cpu/u-boot.lds index 86496737d3..9a4ebcd151 100644 --- a/arch/mips/cpu/u-boot.lds +++ b/arch/mips/cpu/u-boot.lds @@ -33,8 +33,8 @@ SECTIONS }
. = ALIGN(4); diff --git a/arch/nds32/cpu/n1213/u-boot.lds b/arch/nds32/cpu/n1213/u-boot.lds index 4abaf0af1a..1040171415 100644 --- a/arch/nds32/cpu/n1213/u-boot.lds +++ b/arch/nds32/cpu/n1213/u-boot.lds @@ -35,8 +35,8 @@ SECTIONS }
. = ALIGN(4); diff --git a/arch/nios2/cpu/u-boot.lds b/arch/nios2/cpu/u-boot.lds index cbf54b4610..5b9e27d940 100644 --- a/arch/nios2/cpu/u-boot.lds +++ b/arch/nios2/cpu/u-boot.lds @@ -32,8 +32,8 @@ SECTIONS */
/* INIT DATA sections - "Small" data (see the gcc -G option) diff --git a/arch/powerpc/cpu/mpc83xx/u-boot.lds b/arch/powerpc/cpu/mpc83xx/u-boot.lds index d10f528da4..1a1e537b2a 100644 --- a/arch/powerpc/cpu/mpc83xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc83xx/u-boot.lds @@ -42,8 +42,8 @@ SECTIONS . = .;
diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds b/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds index 75b0285e4e..3a9746c860 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-nand.lds @@ -59,8 +59,8 @@ SECTIONS
. = .; diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds index a2193bf768..fc2519d0b1 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds @@ -35,8 +35,8 @@ SECTIONS } _edata = .;
. = ALIGN(8); diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index 27a5fe6306..2f59b4fc12 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -43,8 +43,8 @@ SECTIONS _edata = .;
. = .; diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index 22bbac51aa..b6855f5571 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -66,8 +66,8 @@ SECTIONS . = .;
. = .; diff --git a/arch/riscv/cpu/u-boot-spl.lds b/arch/riscv/cpu/u-boot-spl.lds index d0495ce248..993536302a 100644 --- a/arch/riscv/cpu/u-boot-spl.lds +++ b/arch/riscv/cpu/u-boot-spl.lds @@ -40,8 +40,8 @@ SECTIONS
. = ALIGN(4);
. = ALIGN(4); diff --git a/arch/riscv/cpu/u-boot.lds b/arch/riscv/cpu/u-boot.lds index c00d17c736..1c937aebee 100644 --- a/arch/riscv/cpu/u-boot.lds +++ b/arch/riscv/cpu/u-boot.lds @@ -44,8 +44,8 @@ SECTIONS
. = ALIGN(4);
. = ALIGN(4); diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index 2b1b657831..c42de2ff27 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -44,13 +44,13 @@ EFI_TARGET := --target=efi-app-ia32 else ifeq ($(HOST_ARCH),$(HOST_ARCH_AARCH64)) EFI_LDS := ${SRCDIR}/../../../arch/arm/lib/elf_aarch64_efi.lds OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .data \ - -j .u_boot_list -j .rela.dyn -j .got -j .got.plt \ + -j __u_boot_list -j .rela.dyn -j .got -j .got.plt \ -j .binman_sym_table -j .text_rest \ -j .efi_runtime -j .efi_runtime_rel else ifeq ($(HOST_ARCH),$(HOST_ARCH_ARM)) EFI_LDS := ${SRCDIR}/../../../arch/arm/lib/elf_arm_efi.lds OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .hash \ - -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn \ + -j .data -j .got -j .got.plt -j __u_boot_list -j .rel.dyn \ -j .binman_sym_table -j .text_rest \ -j .efi_runtime -j .efi_runtime_rel else ifeq ($(HOST_ARCH),$(HOST_ARCH_RISCV32)) diff --git a/arch/sandbox/cpu/u-boot-spl.lds b/arch/sandbox/cpu/u-boot-spl.lds index 5c19d090cb..046ed0875b 100644 --- a/arch/sandbox/cpu/u-boot-spl.lds +++ b/arch/sandbox/cpu/u-boot-spl.lds @@ -9,8 +9,8 @@ SECTIONS {
/* Private data for devices with OF_PLATDATA_RT */ diff --git a/arch/sandbox/cpu/u-boot.lds b/arch/sandbox/cpu/u-boot.lds index c3fc67a15b..cc2db24420 100644 --- a/arch/sandbox/cpu/u-boot.lds +++ b/arch/sandbox/cpu/u-boot.lds @@ -9,8 +9,8 @@ SECTIONS {
/* Sandbox has empty EFI runtime lists. */ diff --git a/arch/sh/cpu/u-boot.lds b/arch/sh/cpu/u-boot.lds index 4cc97737f1..ff80ce78f3 100644 --- a/arch/sh/cpu/u-boot.lds +++ b/arch/sh/cpu/u-boot.lds @@ -70,8 +70,8 @@ SECTIONS } >ram PROVIDE (_egot = .);
- .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } >ram
PROVIDE (__init_end = .); diff --git a/arch/x86/cpu/u-boot-64.lds b/arch/x86/cpu/u-boot-64.lds index 92a30c2a38..53c56043a9 100644 --- a/arch/x86/cpu/u-boot-64.lds +++ b/arch/x86/cpu/u-boot-64.lds @@ -12,7 +12,7 @@ ENTRY(_start) SECTIONS { #ifndef CONFIG_CMDLINE - /DISCARD/ : { *(.u_boot_list_2_cmd_*) } + /DISCARD/ : { *(__u_boot_list_2_cmd_*) } #endif
#ifdef CONFIG_SYS_TEXT_BASE @@ -41,8 +41,8 @@ SECTIONS . = ALIGN(4);
. = ALIGN(4); diff --git a/arch/x86/cpu/u-boot-spl.lds b/arch/x86/cpu/u-boot-spl.lds index 346f60bdac..a0a2a06a18 100644 --- a/arch/x86/cpu/u-boot-spl.lds +++ b/arch/x86/cpu/u-boot-spl.lds @@ -12,7 +12,7 @@ ENTRY(_start) SECTIONS { #ifndef CONFIG_CMDLINE - /DISCARD/ : { *(.u_boot_list_2_cmd_*) } + /DISCARD/ : { *(__u_boot_list_2_cmd_*) } #endif
. = IMAGE_TEXT_BASE; /* Location of bootcode in flash */ @@ -25,8 +25,8 @@ SECTIONS . = ALIGN(4);
. = ALIGN(4); diff --git a/arch/x86/cpu/u-boot.lds b/arch/x86/cpu/u-boot.lds index 22fde01e74..7c87209834 100644 --- a/arch/x86/cpu/u-boot.lds +++ b/arch/x86/cpu/u-boot.lds @@ -12,7 +12,7 @@ ENTRY(_start) SECTIONS { #ifndef CONFIG_CMDLINE - /DISCARD/ : { *(.u_boot_list_2_cmd_*) } + /DISCARD/ : { *(__u_boot_list_2_cmd_*) } #endif
. = CONFIG_SYS_TEXT_BASE; /* Location of bootcode in flash */ @@ -39,8 +39,8 @@ SECTIONS . = ALIGN(4);
. = ALIGN(4); diff --git a/arch/x86/lib/elf_ia32_efi.lds b/arch/x86/lib/elf_ia32_efi.lds index aad61e7f81..6d89c1fbd5 100644 --- a/arch/x86/lib/elf_ia32_efi.lds +++ b/arch/x86/lib/elf_ia32_efi.lds @@ -51,7 +51,7 @@ SECTIONS
/* U-Boot lists and device tree */ . = ALIGN(8); - *(SORT(.u_boot_list*)); + *(SORT(__u_boot_list*)); . = ALIGN(8); *(.dtb*); } @@ -69,7 +69,7 @@ SECTIONS *(.data.rel.local) *(.data.rel.ro) *(.data.rel*) - *(.rel.u_boot_list*) + *(.rel__u_boot_list*) } . = ALIGN(4096); .reloc : /* This is the PECOFF .reloc section! */ diff --git a/arch/x86/lib/elf_x86_64_efi.lds b/arch/x86/lib/elf_x86_64_efi.lds index 75727400aa..ada024c05c 100644 --- a/arch/x86/lib/elf_x86_64_efi.lds +++ b/arch/x86/lib/elf_x86_64_efi.lds @@ -50,7 +50,7 @@ SECTIONS
/* U-Boot lists and device tree */ . = ALIGN(8); - *(SORT(.u_boot_list*)); + *(SORT(__u_boot_list*)); . = ALIGN(8); *(.dtb*); } @@ -63,7 +63,7 @@ SECTIONS *(.rela.data*) *(.rela.got) *(.rela.stab) - *(.rela.u_boot_list*) + *(.rela__u_boot_list*) }
. = ALIGN(4096); diff --git a/arch/xtensa/cpu/u-boot.lds b/arch/xtensa/cpu/u-boot.lds index 493f3fdb99..37dc92b308 100644 --- a/arch/xtensa/cpu/u-boot.lds +++ b/arch/xtensa/cpu/u-boot.lds @@ -78,7 +78,7 @@ SECTIONS SECTION_text(XTENSA_SYS_TEXT_ADDR, FOLLOWING(.DoubleExceptionVector.text)) SECTION_rodata(ALIGN(16), FOLLOWING(.text)) SECTION_u_boot_list(ALIGN(16), FOLLOWING(.rodata)) - SECTION_data(ALIGN(16), FOLLOWING(.u_boot_list)) + SECTION_data(ALIGN(16), FOLLOWING(__u_boot_list))
__reloc_end = .; __init_end = .; diff --git a/arch/xtensa/include/asm/ldscript.h b/arch/xtensa/include/asm/ldscript.h index 08f5d0135e..4f75483356 100644 --- a/arch/xtensa/include/asm/ldscript.h +++ b/arch/xtensa/include/asm/ldscript.h @@ -100,10 +100,10 @@ }
#define SECTION_u_boot_list(_vma_, _lma_) \ - .u_boot_list _vma_ : _lma_ \ + __u_boot_list _vma_ : _lma_ \ { \ _u_boot_list_start = ABSOLUTE(.); \ - KEEP(*(SORT(.u_boot_list*))); \ + KEEP(*(SORT(__u_boot_list*))); \ _u_boot_list_end = ABSOLUTE(.); \ }
diff --git a/board/compulab/cm_t335/u-boot.lds b/board/compulab/cm_t335/u-boot.lds index b00e466d58..4993880461 100644 --- a/board/compulab/cm_t335/u-boot.lds +++ b/board/compulab/cm_t335/u-boot.lds @@ -36,8 +36,8 @@ SECTIONS . = .;
. = ALIGN(4); diff --git a/board/cssi/MCR3000/u-boot.lds b/board/cssi/MCR3000/u-boot.lds index 70aef3241c..24b535e724 100644 --- a/board/cssi/MCR3000/u-boot.lds +++ b/board/cssi/MCR3000/u-boot.lds @@ -59,8 +59,8 @@ SECTIONS . = .;
. = .; diff --git a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds index 8f04911306..de1c9c6fce 100644 --- a/board/davinci/da8xxevm/u-boot-spl-da850evm.lds +++ b/board/davinci/da8xxevm/u-boot-spl-da850evm.lds @@ -36,7 +36,7 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram
. = ALIGN(4); - .u_boot_list : { KEEP(*(SORT(.u_boot_list*))); } >.sram + __u_boot_list : { KEEP(*(SORT(__u_boot_list*))); } >.sram
. = ALIGN(4); .rel.dyn : { diff --git a/board/qualcomm/dragonboard820c/u-boot.lds b/board/qualcomm/dragonboard820c/u-boot.lds index dcf8256cec..5251b59fbe 100644 --- a/board/qualcomm/dragonboard820c/u-boot.lds +++ b/board/qualcomm/dragonboard820c/u-boot.lds @@ -49,8 +49,8 @@ SECTIONS . = .;
. = ALIGN(8); diff --git a/board/samsung/common/exynos-uboot-spl.lds b/board/samsung/common/exynos-uboot-spl.lds index 5b32f7feb8..73cd97a1b1 100644 --- a/board/samsung/common/exynos-uboot-spl.lds +++ b/board/samsung/common/exynos-uboot-spl.lds @@ -32,8 +32,8 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram . = ALIGN(4);
- .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); + __u_boot_list : { + KEEP(*(SORT(__u_boot_list*))); } >.sram . = ALIGN(4);
diff --git a/board/synopsys/iot_devkit/u-boot.lds b/board/synopsys/iot_devkit/u-boot.lds index d083168705..dca2e2daee 100644 --- a/board/synopsys/iot_devkit/u-boot.lds +++ b/board/synopsys/iot_devkit/u-boot.lds @@ -39,8 +39,8 @@ SECTIONS } > ROM
/* Mark RAM's LMA */ . = ALIGN(4); diff --git a/board/ti/am335x/u-boot.lds b/board/ti/am335x/u-boot.lds index 03c1d5f73b..087dee8bb2 100644 --- a/board/ti/am335x/u-boot.lds +++ b/board/ti/am335x/u-boot.lds @@ -72,8 +72,8 @@ SECTIONS . = .;
. = ALIGN(4); diff --git a/board/vscom/baltos/u-boot.lds b/board/vscom/baltos/u-boot.lds index 315ba5b99a..cb2ee67697 100644 --- a/board/vscom/baltos/u-boot.lds +++ b/board/vscom/baltos/u-boot.lds @@ -53,8 +53,8 @@ SECTIONS . = .;
. = ALIGN(4); diff --git a/doc/api/linker_lists.rst b/doc/api/linker_lists.rst index 7063fdc831..3cd447f187 100644 --- a/doc/api/linker_lists.rst +++ b/doc/api/linker_lists.rst @@ -13,7 +13,7 @@ then the corresponding input section name is
- .u_boot_list_ + 2_ + @_list + _2_ + @_entry + __u_boot_list_ + 2_ + @_list + _2_ + @_entry
and the C variable name is
@@ -23,7 +23,7 @@ and the C variable name is
This ensures uniqueness for both input section and C variable name.
-Note that the names differ only in the first character, "." for the +Note that the names differ only in the characters, "__" for the section and "_" for the variable, so that the linker cannot confuse section and symbol names. From now on, both names will be referred to as @@ -63,11 +63,11 @@ iterated at least once.
- .u_boot_list_2_array_1 - .u_boot_list_2_array_2_first - .u_boot_list_2_array_2_second - .u_boot_list_2_array_2_third - .u_boot_list_2_array_3 + __u_boot_list_2_array_1 + __u_boot_list_2_array_2_first + __u_boot_list_2_array_2_second + __u_boot_list_2_array_2_third + __u_boot_list_2_array_3
If lists must be divided into sublists (e.g. for iterating only on part of a list), one can simply give the list a name of the form @@ -129,17 +129,17 @@ the compiler cannot update the alignment of the linker_list item.
In the first case, an 8-byte 'fill' region is added::
- .u_boot_list_2_driver_2_testbus_drv + __u_boot_list_2_driver_2_testbus_drv 0x0000000000270018 0x80 test/built-in.o 0x0000000000270018 _u_boot_list_2_driver_2_testbus_drv - .u_boot_list_2_driver_2_testfdt1_drv + __u_boot_list_2_driver_2_testfdt1_drv 0x0000000000270098 0x80 test/built-in.o 0x0000000000270098 _u_boot_list_2_driver_2_testfdt1_drv *fill* 0x0000000000270118 0x8 - .u_boot_list_2_driver_2_testfdt_drv + __u_boot_list_2_driver_2_testfdt_drv 0x0000000000270120 0x80 test/built-in.o 0x0000000000270120 _u_boot_list_2_driver_2_testfdt_drv - .u_boot_list_2_driver_2_testprobe_drv + __u_boot_list_2_driver_2_testprobe_drv 0x00000000002701a0 0x80 test/built-in.o 0x00000000002701a0 _u_boot_list_2_driver_2_testprobe_drv
diff --git a/doc/develop/commands.rst b/doc/develop/commands.rst index c72d1b0aaa..ede880d248 100644 --- a/doc/develop/commands.rst +++ b/doc/develop/commands.rst @@ -169,8 +169,8 @@ by writing in u-boot.lds ($(srctree)/board/boardname/u-boot.lds) these
.. code-block:: c
Writing tests diff --git a/doc/develop/driver-model/of-plat.rst b/doc/develop/driver-model/of-plat.rst index 237af38ad4..b454f7be85 100644 --- a/doc/develop/driver-model/of-plat.rst +++ b/doc/develop/driver-model/of-plat.rst @@ -707,9 +707,9 @@ Link errors / undefined reference Sometimes dtoc does not find the problem for you, but something is wrong and you get a link error, e.g.::
- :(.u_boot_list_2_udevice_2_spl_test5+0x0): undefined reference to + :(__u_boot_list_2_udevice_2_spl_test5+0x0): undefined reference to `_u_boot_list_2_driver_2_sandbox_spl_test' - /usr/bin/ld: dts/dt-uclass.o:(.u_boot_list_2_uclass_2_misc+0x8): + /usr/bin/ld: dts/dt-uclass.o:(__u_boot_list_2_uclass_2_misc+0x8): undefined reference to `_u_boot_list_2_uclass_driver_2_misc'
The first one indicates that the device cannot find its driver. This means that diff --git a/include/linker_lists.h b/include/linker_lists.h index 0575164ce4..d3da9d44e8 100644 --- a/include/linker_lists.h +++ b/include/linker_lists.h @@ -70,7 +70,7 @@ #define ll_entry_declare(_type, _name, _list) \ _type _u_boot_list_2_##_list##_2_##_name __aligned(4) \ __attribute__((unused)) \ - __section(".u_boot_list_2_"#_list"_2_"#_name) + __section("__u_boot_list_2_"#_list"_2_"#_name)
/** * ll_entry_declare_list() - Declare a list of link-generated array entries @@ -93,7 +93,7 @@ #define ll_entry_declare_list(_type, _name, _list) \ _type _u_boot_list_2_##_list##_2_##_name[] __aligned(4) \ __attribute__((unused)) \ - __section(".u_boot_list_2_"#_list"_2_"#_name) + __section("__u_boot_list_2_"#_list"_2_"#_name)
/* * We need a 0-byte-size type for iterator symbols, and the compiler @@ -110,7 +110,7 @@ * @_list: Name of the list in which this entry is placed * * This function returns ``(_type *)`` pointer to the very first entry of a - * linker-generated array placed into subsection of .u_boot_list section + * linker-generated array placed into subsection of __u_boot_list section * specified by _list argument. * * Since this macro defines an array start symbol, its leftmost index @@ -126,7 +126,7 @@ ({ \ static char start[0] __aligned(CONFIG_LINKER_LIST_ALIGN) \ __attribute__((unused)) \ - __section(".u_boot_list_2_"#_list"_1"); \ + __section("__u_boot_list_2_"#_list"_1"); \ (_type *)&start; \ })
@@ -137,7 +137,7 @@ * (with underscores instead of dots) * * This function returns ``(_type *)`` pointer after the very last entry of - * a linker-generated array placed into subsection of .u_boot_list + * a linker-generated array placed into subsection of __u_boot_list * section specified by _list argument. * * Since this macro defines an array end symbol, its leftmost index @@ -152,7 +152,7 @@ #define ll_entry_end(_type, _list) \ ({ \ static char end[0] __aligned(4) __attribute__((unused)) \ - __section(".u_boot_list_2_"#_list"_3"); \ + __section("__u_boot_list_2_"#_list"_3"); \ (_type *)&end; \ }) /** @@ -161,7 +161,7 @@ * @_list: Name of the list of which the number of elements is computed * * This function returns the number of elements of a linker-generated array - * placed into subsection of .u_boot_list section specified by _list + * placed into subsection of __u_boot_list section specified by _list * argument. The result is of an unsigned int type. * * Example: @@ -246,7 +246,7 @@ #define ll_start(_type) \ ({ \ static char start[0] __aligned(4) __attribute__((unused)) \ - __section(".u_boot_list_1"); \ + __section("__u_boot_list_1"); \ (_type *)&start; \ })
@@ -269,7 +269,7 @@ #define ll_end(_type) \ ({ \ static char end[0] __aligned(4) __attribute__((unused)) \ - __section(".u_boot_list_3"); \ + __section("__u_boot_list_3"); \ (_type *)&end; \ })
Add CONFIG_ASAN to build with the Address Sanitizer. This only works with the sandbox so the config is likewise dependent. The resulting executable will have ASAN instrumentation, including the leak detector that can be disabled with the ASAN_OPTIONS environment variable:
ASAN_OPTIONS=detect_leaks=0 ./u-boot
Since u-boot uses its own dlmalloc, dynamic allocations aren't automatically instrumented, but stack variables and globals are.
Instrumentation could be added to dlmalloc to poison and unpoison memory as it is allocated and deallocated, and to introduce redzones between allocations. Alternatively, the sandbox may be able to play games with the system allocator and somehow still keep the required memory abstraction. No effort to address dynamic allocation is made by this patch.
Signed-off-by: Andrew Scull ascull@google.com --- Kconfig | 7 +++++++ arch/sandbox/config.mk | 8 ++++++++ configs/sandbox_defconfig | 1 + 3 files changed, 16 insertions(+)
diff --git a/Kconfig b/Kconfig index 9dd9ec7f6d..ae7e92611d 100644 --- a/Kconfig +++ b/Kconfig @@ -137,6 +137,13 @@ config CC_COVERAGE Enabling this option will pass "--coverage" to gcc to compile and link code instrumented for coverage analysis.
+config ASAN + bool "Enable AddressSanitizer" + depends on SANDBOX + help + Enables AddressSanitizer to discover out-of-bounds accesses, + use-after-free, double-free and memory leaks. + config CC_HAS_ASM_INLINE def_bool $(success,echo 'void foo(void) { asm inline (""); }' | $(CC) -x c - -c -o /dev/null)
diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index c42de2ff27..d7ce66fb6c 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -15,7 +15,14 @@ PLATFORM_LIBS += $(shell $(SDL_CONFIG) --libs) PLATFORM_CPPFLAGS += $(shell $(SDL_CONFIG) --cflags) endif
+SANITIZERS := +ifdef CONFIG_ASAN +SANITIZERS += -fsanitize=address +endif +KBUILD_CFLAGS += $(SANITIZERS) + cmd_u-boot__ = $(CC) -o $@ -Wl,-T u-boot.lds $(u-boot-init) \ + $(SANITIZERS) \ $(LTO_FINAL_LDFLAGS) \ -Wl,--whole-archive \ $(u-boot-main) \ @@ -24,6 +31,7 @@ cmd_u-boot__ = $(CC) -o $@ -Wl,-T u-boot.lds $(u-boot-init) \ $(PLATFORM_LIBS) -Wl,-Map -Wl,u-boot.map
cmd_u-boot-spl = (cd $(obj) && $(CC) -o $(SPL_BIN) -Wl,-T u-boot-spl.lds \ + $(SANITIZERS) \ $(LTO_FINAL_LDFLAGS) \ $(patsubst $(obj)/%,%,$(u-boot-spl-init)) \ -Wl,--whole-archive \ diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7ebeb89264..4862af07cd 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -1,3 +1,4 @@ +CONFIG_ASAN=y CONFIG_SYS_TEXT_BASE=0 CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_NR_DRAM_BANKS=1
Hi Andrew,
I have toyed with what to do here. I originally was thinking of using normal malloc() instead of dlmalloc() when running sandbox. But then of course it makes sandbox very diffferent from other archs, so it is not desirable. So I did not go down that path. Having said that, os_malloc() is used for some sandbox-specific things.
I would love to have an extra string parameter to malloc() which indicates what is doing the allocation (malloc_tag(size_t size, char *id)), so it is easier to see failures and get an annotated 'core dump'. But again, changing the alloc API is not so nice.
One weird thing to be aware of is that truetype fonts cause constant allocs and frees. It happens in the background but you'll notice it if you start tracing things.
On Mon, 11 Apr 2022 at 19:35, Simon Glass sjg@chromium.org wrote:
Hi Andrew,
Using the system allocator would give the nicest ASAN experience because a special allocator gets injected that tracks where allocations were made etc. so when a problem occurs it can point to the likely allocations automatically.
How did you go about keeping the memory model when using the system allocator?
This new class of device will provide fuzzing inputs from a fuzzing engine.
Signed-off-by: Andrew Scull ascull@google.com --- drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/fuzzing_engine/Kconfig | 6 +++ drivers/fuzzing_engine/Makefile | 7 +++ .../fuzzing_engine/fuzzing_engine-uclass.c | 28 ++++++++++ include/dm/uclass-id.h | 1 + include/fuzzing_engine.h | 51 +++++++++++++++++++ 7 files changed, 96 insertions(+) create mode 100644 drivers/fuzzing_engine/Kconfig create mode 100644 drivers/fuzzing_engine/Makefile create mode 100644 drivers/fuzzing_engine/fuzzing_engine-uclass.c create mode 100644 include/fuzzing_engine.h
diff --git a/drivers/Kconfig b/drivers/Kconfig index b26ca8cf70..54ad7f82fa 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -40,6 +40,8 @@ source "drivers/fastboot/Kconfig"
source "drivers/firmware/Kconfig"
+source "drivers/fuzzing_engine/Kconfig" + source "drivers/fpga/Kconfig"
source "drivers/gpio/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..10a4a317c9 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -113,6 +113,7 @@ obj-$(CONFIG_W1) += w1/ obj-$(CONFIG_W1_EEPROM) += w1-eeprom/
obj-$(CONFIG_MACH_PIC32) += ddr/microchip/ +obj-$(CONFIG_FUZZ) += fuzzing_engine/ obj-$(CONFIG_DM_HWSPINLOCK) += hwspinlock/ obj-$(CONFIG_DM_RNG) += rng/ endif diff --git a/drivers/fuzzing_engine/Kconfig b/drivers/fuzzing_engine/Kconfig new file mode 100644 index 0000000000..f405fc75e8 --- /dev/null +++ b/drivers/fuzzing_engine/Kconfig @@ -0,0 +1,6 @@ +config DM_FUZZING_ENGINE + bool "Driver support for fuzzing engine devices" + depends on DM + help + Enable driver model for fuzzing engine devices. This interface is + used to get fuzzing inputs from a fuzzing engine. diff --git a/drivers/fuzzing_engine/Makefile b/drivers/fuzzing_engine/Makefile new file mode 100644 index 0000000000..acd894999c --- /dev/null +++ b/drivers/fuzzing_engine/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2022 Google, Inc. +# Written by Andrew Scull ascull@google.com +# + +obj-$(CONFIG_DM_FUZZING_ENGINE) += fuzzing_engine-uclass.o diff --git a/drivers/fuzzing_engine/fuzzing_engine-uclass.c b/drivers/fuzzing_engine/fuzzing_engine-uclass.c new file mode 100644 index 0000000000..b16f1c4cfb --- /dev/null +++ b/drivers/fuzzing_engine/fuzzing_engine-uclass.c @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#define LOG_CATEGORY UCLASS_FUZZING_ENGINE + +#include <common.h> +#include <dm.h> +#include <fuzzing_engine.h> + +int dm_fuzzing_engine_get_input(struct udevice *dev, + const uint8_t **data, + size_t *size) +{ + const struct dm_fuzzing_engine_ops *ops = device_get_ops(dev); + + if (!ops->get_input) + return -ENOSYS; + + return ops->get_input(dev, data, size); +} + +UCLASS_DRIVER(fuzzing_engine) = { + .name = "fuzzing_engine", + .id = UCLASS_FUZZING_ENGINE, +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index 0e26e1d138..b9411f1d59 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -53,6 +53,7 @@ enum uclass_id { UCLASS_ETH, /* Ethernet device */ UCLASS_ETH_PHY, /* Ethernet PHY device */ UCLASS_FIRMWARE, /* Firmware */ + UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ UCLASS_HASH, /* Hash device */ diff --git a/include/fuzzing_engine.h b/include/fuzzing_engine.h new file mode 100644 index 0000000000..357346e93d --- /dev/null +++ b/include/fuzzing_engine.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#ifndef __FUZZING_ENGINE_H +#define __FUZZING_ENGINE_H + +struct udevice; + +/** + * dm_fuzzing_engine_get_input() - get an input from the fuzzing engine device + * + * The function will return a pointer to the input data and the size of the + * data pointed to. The pointer will remain valid until the next invocation of + * this function. + * + * @dev: fuzzing engine device + * @data: output pointer to input data + * @size output size of input data + * Return: 0 if OK, -ve on error + */ +int dm_fuzzing_engine_get_input(struct udevice *dev, + const uint8_t **data, + size_t *size); + +/** + * struct dm_fuzzing_engine_ops - operations for the fuzzing engine uclass + * + * This contains the functions implemented by a fuzzing engine device. + */ +struct dm_fuzzing_engine_ops { + /** + * @get_input() - get an input + * + * The function will return a pointer to the input data and the size of + * the data pointed to. The pointer will remain valid until the next + * invocation of this function. + * + * @get_input.dev: fuzzing engine device + * @get_input.data: output pointer to input data + * @get_input.size output size of input data + * @get_input.Return: 0 if OK, -ve on error + */ + int (*get_input)(struct udevice *dev, + const uint8_t **data, + size_t *size); +}; + +#endif /* __FUZZING_ENGINE_H */
Hi Andrew,
How about just fuzz/ for the directory ?
depends on DM
help
Can you expand a bit what these things are?
Add the basic infrastructure for declaring fuzz tests and a command to invoke them.
Signed-off-by: Andrew Scull ascull@google.com --- Kconfig | 8 +++++ include/test/fuzz.h | 51 +++++++++++++++++++++++++++ test/Makefile | 1 + test/fuzz/Makefile | 7 ++++ test/fuzz/cmd_fuzz.c | 82 ++++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 149 insertions(+) create mode 100644 include/test/fuzz.h create mode 100644 test/fuzz/Makefile create mode 100644 test/fuzz/cmd_fuzz.c
diff --git a/Kconfig b/Kconfig index ae7e92611d..ce0a69d6aa 100644 --- a/Kconfig +++ b/Kconfig @@ -144,6 +144,14 @@ config ASAN Enables AddressSanitizer to discover out-of-bounds accesses, use-after-free, double-free and memory leaks.
+config FUZZ + bool "Enable fuzzing" + depends on DM_FUZZING_ENGINE + select ASAN + help + Enables the fuzzing infrastructure to generate fuzzing data and run + fuzz tests. + config CC_HAS_ASM_INLINE def_bool $(success,echo 'void foo(void) { asm inline (""); }' | $(CC) -x c - -c -o /dev/null)
diff --git a/include/test/fuzz.h b/include/test/fuzz.h new file mode 100644 index 0000000000..d4c57540eb --- /dev/null +++ b/include/test/fuzz.h @@ -0,0 +1,51 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#ifndef __TEST_FUZZ_H +#define __TEST_FUZZ_H + +#include <linker_lists.h> +#include <linux/types.h> + +/** + * struct fuzz_test - Information about a fuzz test + * + * @name: Name of fuzz test + * @func: Function to call to perform fuzz test on an input + * @flags: Flags indicate pre-conditions for fuzz test + */ +struct fuzz_test { + const char *name; + int (*func)(const uint8_t * data, size_t size); + int flags; +}; + +/** + * FUZZ_TEST() - register a fuzz test + * + * The fuzz test function must return 0 as other values are reserved for future + * use. + * + * @_name: the name of the fuzz test function + * @_flags: an integer field that can be evaluated by the fuzzer + * implementation + */ +#define FUZZ_TEST(_name, _flags) \ + ll_entry_declare(struct fuzz_test, _name, fuzz_tests) = { \ + .name = #_name, \ + .func = _name, \ + .flags = _flags, \ + } + +/** Get the start of the list of fuzz tests */ +#define FUZZ_TEST_START() \ + ll_entry_start(struct fuzz_test, fuzz_tests) + +/** Get the number of elements in the list of fuzz tests */ +#define FUZZ_TEST_COUNT() \ + ll_entry_count(struct fuzz_test, fuzz_tests) + +#endif /* __TEST_FUZZ_H */ diff --git a/test/Makefile b/test/Makefile index b3b2902e2e..bb2b0b5c73 100644 --- a/test/Makefile +++ b/test/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_ut.o obj-$(CONFIG_$(SPL_)CMDLINE) += command_ut.o obj-$(CONFIG_$(SPL_)UT_COMPRESSION) += compression.o obj-y += dm/ +obj-$(CONFIG_FUZZ) += fuzz/ obj-$(CONFIG_$(SPL_)CMDLINE) += print_ut.o obj-$(CONFIG_$(SPL_)CMDLINE) += str_ut.o obj-$(CONFIG_UT_TIME) += time_ut.o diff --git a/test/fuzz/Makefile b/test/fuzz/Makefile new file mode 100644 index 0000000000..03eeeeb497 --- /dev/null +++ b/test/fuzz/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2022 Google, Inc. +# Written by Andrew Scull ascull@google.com +# + +obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_fuzz.o diff --git a/test/fuzz/cmd_fuzz.c b/test/fuzz/cmd_fuzz.c new file mode 100644 index 0000000000..0cc01dc199 --- /dev/null +++ b/test/fuzz/cmd_fuzz.c @@ -0,0 +1,82 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#include <command.h> +#include <common.h> +#include <dm.h> +#include <fuzzing_engine.h> +#include <test/fuzz.h> + +static struct fuzz_test *find_fuzz_test(const char *name) +{ + struct fuzz_test *fuzzer = FUZZ_TEST_START(); + size_t count = FUZZ_TEST_COUNT(); + size_t i; + + for (i = 0; i < count; ++i) { + if (strcmp(name, fuzzer->name) == 0) + return fuzzer; + ++fuzzer; + } + + return NULL; +} + +static struct udevice *find_fuzzing_engine(void) +{ + struct udevice *dev; + + if (uclass_first_device(UCLASS_FUZZING_ENGINE, &dev)) + return NULL; + + return dev; +} + +static int do_fuzz(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + struct fuzz_test *fuzzer; + struct udevice *dev; + + if (argc != 2) + return CMD_RET_USAGE; + + fuzzer = find_fuzz_test(argv[1]); + if (!fuzzer) { + printf("Could not find fuzzer: %s\n", argv[1]); + return 1; + } + + dev = find_fuzzing_engine(); + if (!dev) { + puts("No fuzzing engine available\n"); + return 1; + } + + while (1) { + const uint8_t *data; + size_t size; + + if (dm_fuzzing_engine_get_input(dev, &data, &size)) { + puts("Fuzzing engine failed\n"); + return 1; + } + + fuzzer->func(data, size); + } + + return 1; +} + +#ifdef CONFIG_SYS_LONGHELP +static char fuzz_help_text[] = + "[fuzz-test-name] - execute the named fuzz test\n" + ; +#endif /* CONFIG_SYS_LONGHELP */ + +U_BOOT_CMD( + fuzz, CONFIG_SYS_MAXARGS, 1, do_fuzz, + "fuzz tests", fuzz_help_text +);
Move the program's entry point to os.c, in preparation for a separate fuzzing entry point to be added.
Signed-off-by: Andrew Scull ascull@google.com --- arch/sandbox/cpu/os.c | 6 ++++++ arch/sandbox/cpu/start.c | 2 +- arch/sandbox/include/asm/main.h | 18 ++++++++++++++++++ 3 files changed, 25 insertions(+), 1 deletion(-) create mode 100644 arch/sandbox/include/asm/main.h
diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 72a72029f2..5ea4135741 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -27,6 +27,7 @@ #include <linux/types.h>
#include <asm/getopt.h> +#include <asm/main.h> #include <asm/sections.h> #include <asm/state.h> #include <os.h> @@ -1000,3 +1001,8 @@ void os_relaunch(char *argv[]) execv(argv[0], argv); os_exit(1); } + +int main(int argc, char *argv[]) +{ + return sandbox_main(argc, argv); +} diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index 5cb47e1156..ba67f4fbd7 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -451,7 +451,7 @@ void sandbox_reset(void) os_relaunch(os_argv); }
-int main(int argc, char *argv[]) +int sandbox_main(int argc, char *argv[]) { struct sandbox_state *state; void * text_base; diff --git a/arch/sandbox/include/asm/main.h b/arch/sandbox/include/asm/main.h new file mode 100644 index 0000000000..7a2f0d3a8d --- /dev/null +++ b/arch/sandbox/include/asm/main.h @@ -0,0 +1,18 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#ifndef __ASM_SANDBOX_MAIN_H +#define __ASM_SANDBOX_MAIN_H + +/** + * sandbox_main() - main entrypoint for sandbox + * + * @argc: the number of arguments passed to the program + * @argv: array of argc+1 pointers, of which the last one is null + */ +int sandbox_main(int argc, char *argv[]); + +#endif /* __ASM_SANDBOX_MAIN_H */
Add an implementation of LLVMFuzzerTestOneInput() that starts the sandbox on a secondary thread and exposes a function to synchronize the generation of fuzzing inputs with their consumption by the sandbox.
Signed-off-by: Andrew Scull ascull@google.com --- arch/sandbox/config.mk | 3 + arch/sandbox/cpu/os.c | 70 +++++++++++++++++++++++ arch/sandbox/include/asm/fuzzing_engine.h | 25 ++++++++ 3 files changed, 98 insertions(+) create mode 100644 arch/sandbox/include/asm/fuzzing_engine.h
diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index d7ce66fb6c..5fbe1f50e3 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -19,6 +19,9 @@ SANITIZERS := ifdef CONFIG_ASAN SANITIZERS += -fsanitize=address endif +ifdef CONFIG_FUZZ +SANITIZERS += -fsanitize=fuzzer +endif KBUILD_CFLAGS += $(SANITIZERS)
cmd_u-boot__ = $(CC) -o $@ -Wl,-T u-boot.lds $(u-boot-init) \ diff --git a/arch/sandbox/cpu/os.c b/arch/sandbox/cpu/os.c index 5ea4135741..cd45d7b6b6 100644 --- a/arch/sandbox/cpu/os.c +++ b/arch/sandbox/cpu/os.c @@ -8,6 +8,7 @@ #include <dirent.h> #include <errno.h> #include <fcntl.h> +#include <pthread.h> #include <getopt.h> #include <setjmp.h> #include <signal.h> @@ -26,6 +27,7 @@ #include <linux/compiler_attributes.h> #include <linux/types.h>
+#include <asm/fuzzing_engine.h> #include <asm/getopt.h> #include <asm/main.h> #include <asm/sections.h> @@ -1002,7 +1004,75 @@ void os_relaunch(char *argv[]) os_exit(1); }
+ +#ifdef CONFIG_FUZZ +static void *fuzzer_thread(void * ptr) +{ + char cmd[64]; + char *argv[5] = {"./u-boot", "-T", "-c", cmd, NULL}; + const char *fuzz_test; + + /* Find which test to run from an environment variable. */ + fuzz_test = getenv("UBOOT_SB_FUZZ_TEST"); + if (!fuzz_test) + os_abort(); + + snprintf(cmd, sizeof(cmd), "fuzz %s", fuzz_test); + + sandbox_main(4, argv); + os_abort(); + return NULL; +} + +static bool fuzzer_initialized = false; +static pthread_mutex_t fuzzer_mutex = PTHREAD_MUTEX_INITIALIZER; +static pthread_cond_t fuzzer_cond = PTHREAD_COND_INITIALIZER; +static const uint8_t *fuzzer_data; +static size_t fuzzer_size; + +int sandbox_fuzzing_engine_get_input(const uint8_t **data, size_t *size) +{ + if (!fuzzer_initialized) + return -ENOSYS; + + /* Tell the main thread we need new inputs then wait for them. */ + pthread_mutex_lock(&fuzzer_mutex); + pthread_cond_signal(&fuzzer_cond); + pthread_cond_wait(&fuzzer_cond, &fuzzer_mutex); + *data = fuzzer_data; + *size = fuzzer_size; + pthread_mutex_unlock(&fuzzer_mutex); + return 0; +} + +int LLVMFuzzerTestOneInput(const uint8_t *data, size_t size) +{ + static pthread_t tid; + + pthread_mutex_lock(&fuzzer_mutex); + + /* Initialize the sandbox on another thread. */ + if (!fuzzer_initialized) { + fuzzer_initialized = true; + if (pthread_create(&tid, NULL, fuzzer_thread, NULL)) + os_abort(); + pthread_cond_wait(&fuzzer_cond, &fuzzer_mutex); + } + + /* Hand over the input. */ + fuzzer_data = data; + fuzzer_size = size; + pthread_cond_signal(&fuzzer_cond); + + /* Wait for the inputs to be finished with. */ + pthread_cond_wait(&fuzzer_cond, &fuzzer_mutex); + pthread_mutex_unlock(&fuzzer_mutex); + + return 0; +} +#else int main(int argc, char *argv[]) { return sandbox_main(argc, argv); } +#endif diff --git a/arch/sandbox/include/asm/fuzzing_engine.h b/arch/sandbox/include/asm/fuzzing_engine.h new file mode 100644 index 0000000000..cf6396363b --- /dev/null +++ b/arch/sandbox/include/asm/fuzzing_engine.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#ifndef __ASM_FUZZING_ENGINE_H +#define __ASM_FUZZING_ENGINE_H + +/** Function to get fuzzing engine input data. */ +/** + * sandbox_fuzzing_engine_get_input() - get an input from the sandbox fuzzing + * engine + * + * The function will return a pointer to the input data and the size of the + * data pointed to. The pointer will remain valid until the next invocation of + * this function. + * + * @data: output pointer to input data + * @size output size of input data + * Return: 0 if OK, -ve on error + */ +int sandbox_fuzzing_engine_get_input(const uint8_t **data, size_t *size); + +#endif /* __ASM_FUZZING_ENGINE_H */
Add a fuzzing engine driver for the sandbox to take inputs from libfuzzer and expose them to the fuzz tests.
Signed-off-by: Andrew Scull ascull@google.com --- arch/Kconfig | 2 ++ arch/sandbox/dts/test.dts | 4 +++ drivers/fuzzing_engine/Kconfig | 11 ++++++ drivers/fuzzing_engine/Makefile | 1 + .../fuzzing_engine/sandbox_fuzzing_engine.c | 35 +++++++++++++++++++ 5 files changed, 53 insertions(+) create mode 100644 drivers/fuzzing_engine/sandbox_fuzzing_engine.c
diff --git a/arch/Kconfig b/arch/Kconfig index e6191446a3..6320a98db6 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -135,6 +135,7 @@ config SANDBOX select BZIP2 select CMD_POWEROFF select DM + select DM_FUZZING_ENGINE select DM_GPIO select DM_I2C select DM_KEYBOARD @@ -170,6 +171,7 @@ config SANDBOX imply CRC32_VERIFY imply FAT_WRITE imply FIRMWARE + imply FUZZING_ENGINE_SANDBOX imply HASH_VERIFY imply LZMA imply TEE diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 48ca3e1e47..848329fda5 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -71,6 +71,10 @@ }; };
+ fuzzing-engine { + compatible = "sandbox,sandbox-fuzzing-engine"; + }; + reboot-mode0 { compatible = "reboot-mode-gpio"; gpios = <&gpio_c 0 GPIO_ACTIVE_HIGH>, <&gpio_c 1 GPIO_ACTIVE_HIGH>; diff --git a/drivers/fuzzing_engine/Kconfig b/drivers/fuzzing_engine/Kconfig index f405fc75e8..6311385222 100644 --- a/drivers/fuzzing_engine/Kconfig +++ b/drivers/fuzzing_engine/Kconfig @@ -4,3 +4,14 @@ config DM_FUZZING_ENGINE help Enable driver model for fuzzing engine devices. This interface is used to get fuzzing inputs from a fuzzing engine. + +if DM_FUZZING_ENGINE + +config FUZZING_ENGINE_SANDBOX + bool "Sanbox fuzzing engine" + depends on SANDBOX + default y + help + Enable fuzzing engine for sandbox. + +endif diff --git a/drivers/fuzzing_engine/Makefile b/drivers/fuzzing_engine/Makefile index acd894999c..073743ba94 100644 --- a/drivers/fuzzing_engine/Makefile +++ b/drivers/fuzzing_engine/Makefile @@ -5,3 +5,4 @@ #
obj-$(CONFIG_DM_FUZZING_ENGINE) += fuzzing_engine-uclass.o +obj-$(CONFIG_FUZZING_ENGINE_SANDBOX) += sandbox_fuzzing_engine.o diff --git a/drivers/fuzzing_engine/sandbox_fuzzing_engine.c b/drivers/fuzzing_engine/sandbox_fuzzing_engine.c new file mode 100644 index 0000000000..4d187deaa4 --- /dev/null +++ b/drivers/fuzzing_engine/sandbox_fuzzing_engine.c @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#include <common.h> +#include <dm.h> +#include <fuzzing_engine.h> +#include <asm/fuzzing_engine.h> + +static int get_input(struct udevice *dev, + const uint8_t **data, + size_t *size) +{ + return sandbox_fuzzing_engine_get_input(data, size); +} + +static const struct dm_fuzzing_engine_ops sandbox_fuzzing_engine_ops = { + .get_input = get_input, +}; + +static const struct udevice_id sandbox_fuzzing_engine_match[] = { + { + .compatible = "sandbox,sandbox-fuzzing-engine", + }, + {}, +}; + +U_BOOT_DRIVER(sandbox_fuzzing_engine) = { + .name = "sandbox-fuzzing-engine", + .id = UCLASS_FUZZING_ENGINE, + .of_match = sandbox_fuzzing_engine_match, + .ops = &sandbox_fuzzing_engine_ops, +};
Hi Andrew,
Thoughts below
fuzzing-engine {
depends on SANDBOX
default y
help
- Copyright (c) 2022 Google, Inc.
- Written by Andrew Scull ascull@google.com
size_t *size)
In the interests of brevity, perhaps sb_fuzz_engine as the prefix, or sbfuzz_engine?
Do you need the second 'sandbox-' ?
2.35.1.1094.g7c7d902a7c-goog
On Mon, 11 Apr 2022 at 19:36, Simon Glass sjg@chromium.org wrote:
Hi Andrew,
Thoughts below
fuzzing-engine {
depends on SANDBOX
default y
help
size_t *size)
I've left them longform for now as they symbols don't get widely used.
I was copying "sandbox,sandbox-rng" but turns out that was the odd-one-out. Dropping the 'sandbox-'
Add a fuzzer to test the vring handling code against unexpected mutations from the virtio device.
After building the sandbox with CONFIG_FUZZ=y, the fuzzer can be invoked with by:
UBOOT_SB_FUZZ_TEST=fuzz_vring ./u-boot
This fuzzer finds unvalidated inputs in the vring driver that allow a buggy or malicious device to make the driver chase wild pointers.
Signed-off-by: Andrew Scull ascull@google.com --- test/fuzz/Makefile | 1 + test/fuzz/virtio.c | 72 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 73 insertions(+) create mode 100644 test/fuzz/virtio.c
diff --git a/test/fuzz/Makefile b/test/fuzz/Makefile index 03eeeeb497..663b79ce80 100644 --- a/test/fuzz/Makefile +++ b/test/fuzz/Makefile @@ -5,3 +5,4 @@ #
obj-$(CONFIG_$(SPL_)CMDLINE) += cmd_fuzz.o +obj-$(CONFIG_VIRTIO_SANDBOX) += virtio.o diff --git a/test/fuzz/virtio.c b/test/fuzz/virtio.c new file mode 100644 index 0000000000..e5363d5638 --- /dev/null +++ b/test/fuzz/virtio.c @@ -0,0 +1,72 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Google, Inc. + * Written by Andrew Scull ascull@google.com + */ + +#include <common.h> +#include <dm.h> +#include <virtio.h> +#include <virtio_ring.h> +#include <test/fuzz.h> + +static int fuzz_vring(const uint8_t *data, size_t size) +{ + struct udevice *bus, *dev; + struct virtio_dev_priv *uc_priv; + struct virtqueue *vq; + struct virtio_sg sg[2]; + struct virtio_sg *sgs[2]; + unsigned int len; + u8 buffer[2][32]; + + /* hackily hardcode vring sizes */ + size_t num = 4; + size_t desc_size = (sizeof(struct vring_desc) * num); + size_t avail_size = (3 + num) * sizeof(u16); + size_t used_size = (3 * sizeof(u16)) + (sizeof(struct vring_used_elem) * num); + + if (size < (desc_size + avail_size + used_size)) + return 0; + + /* check probe success */ + if (uclass_first_device(UCLASS_VIRTIO, &bus) || !bus) + panic("Could not find virtio bus\n"); + + /* check the child virtio-rng device is bound */ + if (device_find_first_child(bus, &dev) || !dev) + panic("Could not find virtio device\n"); + + /* + * fake the virtio device probe by filling in uc_priv->vdev + * which is used by virtio_find_vqs/virtio_del_vqs. + */ + uc_priv = dev_get_uclass_priv(bus); + uc_priv->vdev = dev; + + /* prepare the scatter-gather buffer */ + sg[0].addr = buffer[0]; + sg[0].length = sizeof(buffer[0]); + sg[1].addr = buffer[1]; + sg[1].length = sizeof(buffer[1]); + sgs[0] = &sg[0]; + sgs[1] = &sg[1]; + + if (virtio_find_vqs(dev, 1, &vq)) + panic("Could not find vqs\n"); + if (virtqueue_add(vq, sgs, 0, 1)) + panic("Could not add to virtqueue\n"); + /* Simulate device writing to vring */ + memcpy(vq->vring.desc, data, desc_size); + memcpy(vq->vring.avail, data + desc_size, avail_size); + memcpy(vq->vring.used, data + desc_size + avail_size, used_size); + /* Make sure there is a response */ + if (vq->vring.used->idx == 0) + vq->vring.used->idx = 1; + virtqueue_get_buf(vq, &len); + if (virtio_del_vqs(dev)) + panic("Could not delete vqs\n"); + + return 0; +} +FUZZ_TEST(fuzz_vring, 0);
Hi Andrew,
unsigned int len;
u8 buffer[2][32];
size_t num = 4;
Do we have to panic? Could this use some sort of assert function, or similar? It seems like we should try to show the error then return an error code from this function, rather than just panic in the middle. We could have something like the ut_assert... stuff.
sgs[0] = &sg[0];
sgs[1] = &sg[1];
Hi Andrew,
unsigned int len;
u8 buffer[2][32];
size_t num = 4;
Would a basic assert() be better rather than handling with panic()? We should never see this fail, and if it does we want something quite dramatic to happen so that the fuzzer notices and tells us something went wrong.
sgs[0] = &sg[0];
sgs[1] = &sg[1];
This is a hugely ugly hack to poison and unpoison memory allocated by dlmalloc. It wraps every access dlmalloc makes to the metadata breifly allow it access, taking care not to then poison the parts of the record which overlap.
The result is very small redzones between the allocations, which has limted value but has able to spot immediate buffer overruns.
The instrumentation is extremely intrusive and would be benefited by more intrusions to increase redzone sizes etc.
Signed-off-by: Andrew Scull ascull@google.com --- common/dlmalloc.c | 284 ++++++++++++++++++++++++++++++++++++------ include/compiler.h | 1 + include/linux/types.h | 1 + 3 files changed, 245 insertions(+), 41 deletions(-)
diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 11729e8c85..614f004579 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -8,6 +8,8 @@ * as file malloc-2.6.6.c. */
+#define DEBUG + #include <common.h> #include <log.h> #include <asm/global_data.h> @@ -16,6 +18,8 @@ #define DEBUG #endif
+#include <sanitizer/asan_interface.h> + #include <malloc.h> #include <asm/io.h>
@@ -31,6 +35,17 @@ void malloc_stats();
DECLARE_GLOBAL_DATA_PTR;
+/* +#undef ASAN_POISON_MEMORY_REGION +#define ASAN_POISON_MEMORY_REGION(p, s) do { \ + if ((uintptr_t)p == 0x0000150200c0) { \ + printf("size %lx\n", s); \ + *(int*)NULL = 9; \ + } \ + __asan_poison_memory_region(p, s); \ +} while (0) +*/ + /* Emulation of sbrk for WIN32 All code within the ifdef WIN32 is untested by me. @@ -409,12 +424,26 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+
/* Ptr to next physical malloc_chunk. */
-#define next_chunk(p) ((mchunkptr)( ((char*)(p)) + ((p)->size & ~PREV_INUSE) )) +#define _next_chunk(p) ((mchunkptr)( ((char*)(p)) + ((p)->size & ~PREV_INUSE) )) +#define next_chunk(p) ({ \ + mchunkptr _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + mchunkptr _ret = _next_chunk(_ptr); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + })
/* Ptr to previous physical malloc_chunk */
-#define prev_chunk(p)\ +#define _prev_chunk(p)\ ((mchunkptr)( ((char*)(p)) - ((p)->prev_size) )) +#define prev_chunk(p) ({ \ + mchunkptr _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(_ptr, SIZE_SZ); \ + mchunkptr _ret = _prev_chunk(_ptr); \ + ASAN_POISON_MEMORY_REGION(_ptr, SIZE_SZ); \ + _ret; \ + })
/* Treat space at ptr + offset as a chunk */ @@ -430,35 +459,102 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+
/* extract p's inuse bit */
-#define inuse(p)\ +#define _inuse(p)\ ((((mchunkptr)(((char*)(p))+((p)->size & ~PREV_INUSE)))->size) & PREV_INUSE) +#define inuse(p) ({ \ + mchunkptr _p = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + mchunkptr _ptr = ((mchunkptr)(((char*)_p)+(_p->size & ~PREV_INUSE))); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + INTERNAL_SIZE_T _ret = _inuse(_p); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + ASAN_POISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + })
/* extract inuse bit of previous chunk */
-#define prev_inuse(p) ((p)->size & PREV_INUSE) +#define _prev_inuse(p) ((p)->size & PREV_INUSE) +#define prev_inuse(p) ({ \ + mchunkptr _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + INTERNAL_SIZE_T _ret = _prev_inuse(_ptr); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + })
/* check for mmap()'ed chunk */
-#define chunk_is_mmapped(p) ((p)->size & IS_MMAPPED) +#define _chunk_is_mmapped(p) ((p)->size & IS_MMAPPED) +#define chunk_is_mmapped(p) ({ \ + mchunkptr _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + INTERNAL_SIZE_T _ret = _chunk_is_mmapped(_ptr); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + })
/* set/clear chunk as in use without otherwise disturbing */
-#define set_inuse(p)\ +#define _set_inuse(p)\ ((mchunkptr)(((char*)(p)) + ((p)->size & ~PREV_INUSE)))->size |= PREV_INUSE - -#define clear_inuse(p)\ +#define set_inuse(p, s) ({ \ + mchunkptr _p = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + mchunkptr _ptr = ((mchunkptr)(((char*)_p)+(_p->size & ~PREV_INUSE))); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _set_inuse(_p, (s)); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + ASAN_POISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + }) + +#define _clear_inuse(p)\ ((mchunkptr)(((char*)(p)) + ((p)->size & ~PREV_INUSE)))->size &= ~(PREV_INUSE) +#define clear_inuse(p, s) ({ \ + __typeof__(p) _p = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + mchunkptr _ptr = ((mchunkptr)(((char*)_p)+(_p->size & ~PREV_INUSE))); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _clear_inuse(_p, (s)); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + ASAN_POISON_MEMORY_REGION(((char*)_p) + SIZE_SZ, SIZE_SZ); \ + })
/* check/set/clear inuse bits in known places */
-#define inuse_bit_at_offset(p, s)\ +#define _inuse_bit_at_offset(p, s)\ (((mchunkptr)(((char*)(p)) + (s)))->size & PREV_INUSE) - -#define set_inuse_bit_at_offset(p, s)\ +#define inuse_bit_at_offset(p, s) ({ \ + __typeof__(p) _p = (p); \ + __typeof__(s) _s = (s); \ + __typeof__(p) _ptr = (mchunkptr)(((char*)_p) + _s); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + INTERNAL_SIZE_T _ret = _inuse_bit_at_offset(_p, _s); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + }) + +#define _set_inuse_bit_at_offset(p, s)\ (((mchunkptr)(((char*)(p)) + (s)))->size |= PREV_INUSE) - -#define clear_inuse_bit_at_offset(p, s)\ +#define set_inuse_bit_at_offset(p, s) ({ \ + __typeof__(p) _p = (p); \ + __typeof__(s) _s = (s); \ + __typeof__(p) _ptr = (mchunkptr)(((char*)_p) + _s); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _set_inuse_bit_at_offset(_p, _s); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + }) + +#define _clear_inuse_bit_at_offset(p, s)\ (((mchunkptr)(((char*)(p)) + (s)))->size &= ~(PREV_INUSE)) +#define clear_inuse_bit_at_offset(p, s) ({ \ + __typeof__(p) _p = (p); \ + __typeof__(s) _s = (s); \ + __typeof__(p) _ptr = (mchunkptr)(((char*)_p) + _s); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _clear_inuse_bit_at_offset(_p, _s); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + })
@@ -469,19 +565,46 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+
/* Get size, ignoring use bits */
-#define chunksize(p) ((p)->size & ~(SIZE_BITS)) +#define _chunksize(p) ((p)->size & ~(SIZE_BITS)) +#define chunksize(p) ({ \ + mchunkptr _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + INTERNAL_SIZE_T _ret = _chunksize(_ptr); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _ret; \ + })
/* Set size at head, without disturbing its use bit */
-#define set_head_size(p, s) ((p)->size = (((p)->size & PREV_INUSE) | (s))) +#define _set_head_size(p, s) ((p)->size = (((p)->size & PREV_INUSE) | (s))) +#define set_head_size(p, s) ({ \ + __typeof__(p) _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _set_head_size(_ptr, (s)); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + })
/* Set size/use ignoring previous bits in header */
-#define set_head(p, s) ((p)->size = (s)) +#define _set_head(p, s) ((p)->size = (s)) +#define set_head(p, s) ({ \ + __typeof__(p) _ptr = (p); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + _set_head(_ptr, (s)); \ + ASAN_POISON_MEMORY_REGION(((char*)_ptr) + SIZE_SZ, SIZE_SZ); \ + })
/* Set size at footer (only when chunk is not in use) */
-#define set_foot(p, s) (((mchunkptr)((char*)(p) + (s)))->prev_size = (s)) +#define _set_foot(p, s) (((mchunkptr)((char*)(p) + (s)))->prev_size = (s)) +#define set_foot(p, s) ({ \ + __typeof__(p) _p = (p); \ + __typeof__(s) _s = (s); \ + __typeof__(p) _ptr = (mchunkptr)(((char*)_p) + _s); \ + ASAN_UNPOISON_MEMORY_REGION(_ptr, SIZE_SZ); \ + _set_foot(_p, (s)); \ + ASAN_POISON_MEMORY_REGION(_ptr, SIZE_SZ); \ + })
@@ -604,8 +727,11 @@ void *sbrk(ptrdiff_t increment) * if we are giving memory back make sure we clear it out since * we set MORECORE_CLEARS to 1 */ - if (increment < 0) + if (increment < 0) { + ASAN_UNPOISON_MEMORY_REGION((void *)new, -increment); memset((void *)new, 0, -increment); + ASAN_POISON_MEMORY_REGION((void *)new, -increment); + }
if ((new < mem_malloc_start) || (new > mem_malloc_end)) return (void *)MORECORE_FAILURE; @@ -630,13 +756,24 @@ void mem_malloc_init(ulong start, ulong size) #ifdef CONFIG_SYS_MALLOC_CLEAR_ON_INIT memset((void *)mem_malloc_start, 0x0, size); #endif + ASAN_POISON_MEMORY_REGION((void *)start, size); malloc_bin_reloc(); }
/* field-extraction macros */
-#define first(b) ((b)->fd) -#define last(b) ((b)->bk) +#define first(b) ({ \ + ASAN_UNPOISON_MEMORY_REGION(((char*)b) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + void *_ret = (b)->fd; \ + ASAN_UNPOISON_MEMORY_REGION(((char*)b) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + _ret; \ + }) +#define last(b) ({ \ + ASAN_UNPOISON_MEMORY_REGION(((char*)b) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + void *_ret = (b)->bk; \ + ASAN_UNPOISON_MEMORY_REGION(((char*)b) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + _ret; \ + })
/* Indexing into bins @@ -781,7 +918,7 @@ static void do_check_chunk(mchunkptr p) static void do_check_chunk(p) mchunkptr p; #endif { - INTERNAL_SIZE_T sz = p->size & ~PREV_INUSE; + INTERNAL_SIZE_T sz = chunksize(p);
/* No checkable chunk is mmapped */ assert(!chunk_is_mmapped(p)); @@ -802,7 +939,7 @@ static void do_check_free_chunk(mchunkptr p) static void do_check_free_chunk(p) mchunkptr p; #endif { - INTERNAL_SIZE_T sz = p->size & ~PREV_INUSE; + INTERNAL_SIZE_T sz = chunksize(p); mchunkptr next = chunk_at_offset(p, sz);
do_check_chunk(p); @@ -816,14 +953,22 @@ static void do_check_free_chunk(p) mchunkptr p; assert((sz & MALLOC_ALIGN_MASK) == 0); assert(aligned_OK(chunk2mem(p))); /* ... matching footer field */ + ASAN_UNPOISON_MEMORY_REGION(next, SIZE_SZ); assert(next->prev_size == sz); + ASAN_POISON_MEMORY_REGION(next, SIZE_SZ); /* ... and is fully consolidated */ assert(prev_inuse(p)); assert (next == top || inuse(next));
/* ... and has minimally sane links */ + ASAN_UNPOISON_MEMORY_REGION(((char*)p) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); + ASAN_UNPOISON_MEMORY_REGION(((char*)p->fd) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); + ASAN_UNPOISON_MEMORY_REGION(((char*)p->bk) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); assert(p->fd->bk == p); assert(p->bk->fd == p); + ASAN_POISON_MEMORY_REGION(((char*)p->fd) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); + ASAN_POISON_MEMORY_REGION(((char*)p->bk) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); + ASAN_POISON_MEMORY_REGION(((char*)p) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); } else /* markers are always of size SIZE_SZ */ assert(sz == SIZE_SZ); @@ -867,7 +1012,7 @@ static void do_check_malloced_chunk(mchunkptr p, INTERNAL_SIZE_T s) static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s; #endif { - INTERNAL_SIZE_T sz = p->size & ~PREV_INUSE; + INTERNAL_SIZE_T sz = chunksize(p); long room = sz - s;
do_check_inuse_chunk(p); @@ -919,31 +1064,48 @@ static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s;
#define frontlink(P, S, IDX, BK, FD) \ { \ + ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ if (S < MAX_SMALLBIN_SIZE) \ { \ IDX = smallbin_index(S); \ mark_binblock(IDX); \ BK = bin_at(IDX); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD = BK->fd; \ P->bk = BK; \ P->fd = FD; \ + ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD->bk = BK->fd = P; \ } \ else \ { \ IDX = bin_index(S); \ BK = bin_at(IDX); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD = BK->fd; \ + ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ if (FD == BK) mark_binblock(IDX); \ else \ { \ - while (FD != BK && S < chunksize(FD)) FD = FD->fd; \ + while (FD != BK && S < chunksize(FD)) { \ + mchunkptr old = FD; \ + FD = FD->fd; \ + ASAN_POISON_MEMORY_REGION(((char*)old) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + } \ + mchunkptr oldbk = BK; \ BK = FD->bk; \ + ASAN_POISON_MEMORY_REGION(((char*)oldbk) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ } \ P->bk = BK; \ P->fd = FD; \ FD->bk = BK->fd = P; \ } \ + ASAN_POISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_POISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_POISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ }
@@ -951,18 +1113,26 @@ static void do_check_malloced_chunk(p, s) mchunkptr p; INTERNAL_SIZE_T s;
#define unlink(P, BK, FD) \ { \ + ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ BK = P->bk; \ FD = P->fd; \ + ASAN_POISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD->bk = BK; \ BK->fd = FD; \ + ASAN_POISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ + ASAN_POISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ } \
/* Place p as the last remainder */
#define link_last_remainder(P) \ { \ + ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ last_remainder->fd = last_remainder->bk = P; \ P->fd = P->bk = last_remainder; \ + ASAN_POISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ }
/* Clear the last_remainder bin */ @@ -1280,6 +1450,14 @@ static void malloc_extend_top(nb) INTERNAL_SIZE_T nb;
+#define publish_mem(p) ({ \ + __typeof__(p) _chunk = (p); \ + Void_t *_ret = chunk2mem(_chunk); \ + INTERNAL_SIZE_T _size = malloc_usable_size(_ret); \ + ASAN_UNPOISON_MEMORY_REGION(_ret, _size); \ + _ret; \ + }) + #if __STD_C Void_t* mALLOc(size_t bytes) #else @@ -1339,7 +1517,7 @@ Void_t* mALLOc(bytes) size_t bytes; unlink(victim, bck, fwd); set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); }
idx += 2; /* Set for bin scan below. We've already scanned 2 bins. */ @@ -1350,7 +1528,11 @@ Void_t* mALLOc(bytes) size_t bytes; idx = bin_index(nb); bin = bin_at(idx);
- for (victim = last(bin); victim != bin; victim = victim->bk) + for (victim = last(bin); victim != bin; + ASAN_UNPOISON_MEMORY_REGION((char*)victim + 2*SIZE_SZ, 2*sizeof(uintptr_t)), + victim = victim->bk, + ASAN_POISON_MEMORY_REGION((char*)victim + 2*SIZE_SZ, 2*sizeof(uintptr_t)) + ) { victim_size = chunksize(victim); remainder_size = victim_size - nb; @@ -1366,7 +1548,7 @@ Void_t* mALLOc(bytes) size_t bytes; unlink(victim, bck, fwd); set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); } }
@@ -1389,7 +1571,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_head(remainder, remainder_size | PREV_INUSE); set_foot(remainder, remainder_size); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); }
clear_last_remainder; @@ -1398,7 +1580,7 @@ Void_t* mALLOc(bytes) size_t bytes; { set_inuse_bit_at_offset(victim, victim_size); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); }
/* Else place in bin */ @@ -1439,7 +1621,11 @@ Void_t* mALLOc(bytes) size_t bytes; { /* Find and use first big enough chunk ... */
- for (victim = last(bin); victim != bin; victim = victim->bk) + for (victim = last(bin); victim != bin; + ASAN_UNPOISON_MEMORY_REGION((char*)victim + 2*SIZE_SZ, 2*sizeof(uintptr_t)), + victim = victim->bk, + ASAN_POISON_MEMORY_REGION((char*)victim + 2*SIZE_SZ, 2*sizeof(uintptr_t)) + ) { victim_size = chunksize(victim); remainder_size = victim_size - nb; @@ -1453,7 +1639,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_head(remainder, remainder_size | PREV_INUSE); set_foot(remainder, remainder_size); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); }
else if (remainder_size >= 0) /* take */ @@ -1461,7 +1647,7 @@ Void_t* mALLOc(bytes) size_t bytes; set_inuse_bit_at_offset(victim, victim_size); unlink(victim, bck, fwd); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + return publish_mem(victim); }
} @@ -1509,7 +1695,7 @@ Void_t* mALLOc(bytes) size_t bytes; /* If big and would otherwise need to extend, try to use mmap instead */ if ((unsigned long)nb >= (unsigned long)mmap_threshold && (victim = mmap_chunk(nb))) - return chunk2mem(victim); + return publish_mem(victim); #endif
/* Try to extend */ @@ -1523,7 +1709,8 @@ Void_t* mALLOc(bytes) size_t bytes; top = chunk_at_offset(victim, nb); set_head(top, remainder_size | PREV_INUSE); check_malloced_chunk(victim, nb); - return chunk2mem(victim); + + return publish_mem(victim);
@@ -1578,8 +1765,12 @@ void fREe(mem) Void_t* mem; if (mem == NULL) /* free(0) has no effect */ return;
+ ASAN_POISON_MEMORY_REGION(mem, malloc_usable_size(mem)); + p = mem2chunk(mem); + ASAN_UNPOISON_MEMORY_REGION(((char*)p) + SIZE_SZ, SIZE_SZ); hd = p->size; + ASAN_POISON_MEMORY_REGION(((char*)p) + SIZE_SZ, SIZE_SZ);
#if HAVE_MMAP if (hd & IS_MMAPPED) /* release mmapped memory. */ @@ -1601,7 +1792,9 @@ void fREe(mem) Void_t* mem;
if (!(hd & PREV_INUSE)) /* consolidate backward */ { + ASAN_UNPOISON_MEMORY_REGION(((char*)p), SIZE_SZ); prevsz = p->prev_size; + ASAN_POISON_MEMORY_REGION(((char*)p), SIZE_SZ); p = chunk_at_offset(p, -((long) prevsz)); sz += prevsz; unlink(p, bck, fwd); @@ -1620,20 +1813,25 @@ void fREe(mem) Void_t* mem;
if (!(hd & PREV_INUSE)) /* consolidate backward */ { + ASAN_UNPOISON_MEMORY_REGION(p, SIZE_SZ); prevsz = p->prev_size; + ASAN_POISON_MEMORY_REGION(p, SIZE_SZ); p = chunk_at_offset(p, -((long) prevsz)); sz += prevsz;
+ ASAN_UNPOISON_MEMORY_REGION((char*)p + 2*SIZE_SZ, 2*sizeof(uintptr_t)); if (p->fd == last_remainder) /* keep as last_remainder */ islr = 1; else unlink(p, bck, fwd); + ASAN_POISON_MEMORY_REGION((char*)p + 2*SIZE_SZ, 2*sizeof(uintptr_t)); }
if (!(inuse_bit_at_offset(next, nextsz))) /* consolidate forward */ { sz += nextsz;
+ ASAN_UNPOISON_MEMORY_REGION((char*)next + 2*SIZE_SZ, 2*sizeof(uintptr_t)); if (!islr && next->fd == last_remainder) /* re-insert last_remainder */ { islr = 1; @@ -1641,6 +1839,7 @@ void fREe(mem) Void_t* mem; } else unlink(next, bck, fwd); + ASAN_POISON_MEMORY_REGION((char*)next + 2*SIZE_SZ, 2*sizeof(uintptr_t)); }
@@ -1747,7 +1946,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; { #if HAVE_MREMAP newp = mremap_chunk(oldp, nb); - if(newp) return chunk2mem(newp); + if(newp) return publish_mem(newp); #endif /* Note the extra SIZE_SZ overhead. */ if(oldsize - SIZE_SZ >= nb) return oldmem; /* do nothing */ @@ -1782,7 +1981,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; top = chunk_at_offset(oldp, nb); set_head(top, (newsize - nb) | PREV_INUSE); set_head_size(oldp, nb); - return chunk2mem(oldp); + return publish_mem(oldp); } }
@@ -1895,7 +2094,7 @@ Void_t* rEALLOc(oldmem, bytes) Void_t* oldmem; size_t bytes; }
check_inuse_chunk(newp); - return chunk2mem(newp); + return publish_mem(newp); }
@@ -2006,7 +2205,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; { #if HAVE_MMAP if(chunk_is_mmapped(p)) - return chunk2mem(p); /* nothing more to do */ + return publish_mem(p); /* nothing more to do */ #endif } else /* misaligned */ @@ -2032,7 +2231,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; { newp->prev_size = p->prev_size + leadsize; set_head(newp, newsize|IS_MMAPPED); - return chunk2mem(newp); + return publish_mem(newp); } #endif
@@ -2060,7 +2259,7 @@ Void_t* mEMALIGn(alignment, bytes) size_t alignment; size_t bytes; }
check_inuse_chunk(p); - return chunk2mem(p); + return publish_mem(p);
@@ -2318,7 +2517,10 @@ static void malloc_update_mallinfo() for (i = 1; i < NAV; ++i) { b = bin_at(i); - for (p = last(b); p != b; p = p->bk) + for (p = last(b); p != b; + ASAN_UNPOISON_MEMORY_REGION((char*)p + 2*SIZE_SZ, 2*sizeof(uintptr_t)), + p = p->bk, + ASAN_POISON_MEMORY_REGION((char*)p + 2*SIZE_SZ, 2*sizeof(uintptr_t))) { #ifdef DEBUG check_free_chunk(p); diff --git a/include/compiler.h b/include/compiler.h index ef7b2cb1f7..7f7e82daf7 100644 --- a/include/compiler.h +++ b/include/compiler.h @@ -126,6 +126,7 @@ typedef __u32 u32;
/* Type for `void *' pointers. */ typedef unsigned long int uintptr_t; +typedef long int intptr_t;
#include <linux/string.h> #include <linux/types.h> diff --git a/include/linux/types.h b/include/linux/types.h index baa2c491ea..d86d2611c0 100644 --- a/include/linux/types.h +++ b/include/linux/types.h @@ -25,6 +25,7 @@ typedef __kernel_uid16_t uid16_t; typedef __kernel_gid16_t gid16_t;
typedef unsigned long uintptr_t; +typedef long intptr_t;
#ifdef CONFIG_UID16 /* This is defined by include/asm-{arch}/posix_types.h */
Hi Andrew,
This actually seems very useful to me. I wonder if it could be split into a few patches, for easier review?
Also what is the mechanism to enable/disable this?
I've made a few comments anyway.
The changes to include/ need a look. I'm not sure whether we can avoid them, but if not, they could go in their own patch.
- as file malloc-2.6.6.c.
+#define DEBUG
- if ((uintptr_t)p == 0x0000150200c0) { \
*(int*)NULL = 9; \
- __asan_poison_memory_region(p, s); \
+} while (0) +*/
Where is that defined?
_ret; \
How about ASON_CURE() for brevity
ASON_POISON() ?
_ret; \
_ret; \
_ret; \
_ret; \
_ret; \
_ret; \
if (increment < 0)
} if ((new < mem_malloc_start) || (new > mem_malloc_end)) return (void *)MORECORE_FAILURE;
_ret; \
_ret; \
do_check_chunk(p);
- ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ if (S < MAX_SMALLBIN_SIZE) \ { \ IDX = smallbin_index(S); \ mark_binblock(IDX); \ BK = bin_at(IDX); \
- ASAN_UNPOISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD = BK->fd; \ P->bk = BK; \ P->fd = FD; \
- ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD->bk = BK->fd = P; \ } \ else \ { \ IDX = bin_index(S); \ BK = bin_at(IDX); \
- ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ if (FD == BK) mark_binblock(IDX); \ else \ { \
FD = FD->fd; \
- ASAN_POISON_MEMORY_REGION(((char*)oldbk) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \
} \ P->bk = BK; \ P->fd = FD; \ FD->bk = BK->fd = P; \ } \ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \
- ASAN_POISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \
- ASAN_POISON_MEMORY_REGION(((char*)BK) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \
- ASAN_POISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \
- ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ BK = P->bk; \ FD = P->fd; \
- ASAN_UNPOISON_MEMORY_REGION(((char*)FD) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ FD->bk = BK; \ BK->fd = FD; \
- ASAN_UNPOISON_MEMORY_REGION(((char*)P) + 2*SIZE_SZ, 2*sizeof(uintptr_t)); \ last_remainder->fd = last_remainder->bk = P; \ P->fd = P->bk = last_remainder; \
Could use a comment
_ret; \
{ victim_size = chunksize(victim); remainder_size = victim_size - nb;)
}return publish_mem(victim); }
return publish_mem(victim); } else if (remainder_size >= 0) /* take */
#endif
/* Try to extend */
- return publish_mem(victim);
- ASAN_POISON_MEMORY_REGION(mem, malloc_usable_size(mem));
- p = mem2chunk(mem);
- ASAN_UNPOISON_MEMORY_REGION(((char*)p) + SIZE_SZ, SIZE_SZ); hd = p->size;
- ASAN_POISON_MEMORY_REGION(((char*)p) + SIZE_SZ, SIZE_SZ);
- ASAN_POISON_MEMORY_REGION((char*)next + 2*SIZE_SZ, 2*sizeof(uintptr_t)); }
- if(newp) return publish_mem(newp);
- return publish_mem(newp);
}return publish_mem(newp);
#endif
- return publish_mem(p);
p = p->bk,
{ASAN_POISON_MEMORY_REGION((char*)p + 2*SIZE_SZ, 2*sizeof(uintptr_t)))
#ifdef CONFIG_UID16 /* This is defined by include/asm-{arch}/posix_types.h */ -- 2.35.1.1094.g7c7d902a7c-goog
Hi Andrew,
This is an integration with ASAN [1] so it's enabled/disabled along with CONFIG_ASAN (although not fully in this extremely messy hack).
If this level of intrucivity is acceptable, there's a reasonable amount of cleanup that could be done, some that you've pointed out, but the macros are still going to be littered all around unless a deeper understanding of the dlmalloc implementation makes further simplification possible. Even after cleaning up, the limitations from the commit message would still apply, limitations that wouldn't exist with the system allocator.
[1] -- https://github.com/google/sanitizers/wiki/AddressSanitizerManualPoisoning
+#define DEBUG
*(int*)NULL = 9; \
+} while (0) +*/
_ret; \
ASON_POISON() ?
_ret; \
_ret; \
_ret; \
_ret; \
_ret; \
_ret; \
if (increment < 0)
_ret; \
_ret; \
do_check_chunk(p);
FD = FD->fd; \
Could use a comment
_ret; \
#endif
/* Try to extend */
#endif
p = p->bk,
Andrew Scull
